SEGGER J-Link GDB Server V6.12d LogFile Logging started @ 2017-01-18 13:41 03-00000000-00-00000000-0023: -----GDB Server start settings----- 03-00000000-00-00000000-0023: GDBInit file: none 03-00000000-00-00000000-0023: GDB Server Listening port: 2331 03-00000000-00-00000000-0023: SWO raw output listening port: 2332 03-00000000-00-00000000-0023: Terminal I/O port: 2333 03-00000000-00-00000000-002D: Accept remote connection: localhost only 03-00000000-00-00000000-0021: Generate logfile: on 03-00000000-00-00000000-0021: Verify download: on 03-00000000-00-00000000-0021: Init regs on start: on 03-00000000-00-00000000-0022: Silent mode: off 03-00000000-00-00000000-0021: Single run mode: on 03-00000000-00-00000000-0023: Target connection timeout: 0 ms 03-00000000-00-00000000-0023: ------J-Link related settings------ 03-00000000-00-00000000-0022: J-Link Host interface: USB 03-00000000-00-00000000-0023: J-Link script: none 03-00000000-00-00000000-0023: J-Link settings file: none 03-00000000-00-00000000-0023: ------Target related settings------ 03-00000000-00-00000000-002A: Target device: STM32L476VG 03-00000000-00-00000000-0022: Target interface: SWD 03-00000000-00-00000000-0026: Target interface speed: 1000kHz 03-00000000-00-00000000-0025: Target endian: little 03-00000000-00-00000001-0017: Connecting to J-Link... 02-00000000-00-00000185-0031: Firmware: J-Link V9 compiled Dec 16 2016 15:34:10 02-00000000-00-00000185-000F: Hardware: V9.30 02-00000000-00-00000185-000E: S/N: 269305306 02-00000000-00-00000185-000F: OEM: SEGGER-EDU 02-00000000-00-00000193-005B: Feature(s): FlashBP, GDBWEBSRV Webserver running on local port 19080 (0192ms, 0192ms total) 02-00000000-00-00000194-0037: TC3EF2700 000:002 returns O.K. (0193ms, 0193ms total) 03-00000000-00-00000194-0014: J-Link is connected. 02-00000000-00-00000194-0068: TC3EF2700 000:195 JLINK_ExecCommand("HideDeviceSelection=1", ...). returns 0x00 (0000ms, 0193ms total) 02-00000000-00-00000194-0068: TC3EF2700 000:195 JLINK_ExecCommand("DisableInfoWinFlashDL", ...). returns 0x00 (0000ms, 0193ms total) 02-00000000-00-00000194-0069: TC3EF2700 000:195 JLINK_ExecCommand("DisableInfoWinFlashBPs", ...). returns 0x00 (0000ms, 0193ms total) 02-00000000-00-00000194-005A: TC3EF2700 000:195 JLINK_SetFlashProgProgressCallback(...) returned (0000ms, 0193ms total) 02-00000000-00-00000389-00A1: TC3EF2700 000:195 JLINK_ExecCommand("device = STM32L476VG", ...). /opt/SEGGER/JLink/JLinkDevices.xml evaluated successfully. returns 0x00 (0195ms, 0388ms total) 02-00000000-00-00000389-006E: TC3EF2700 000:390 JLINK_ExecCommand("SetFlashRewriteBehavior = 1", ...). returns 0x00 (0000ms, 0388ms total) 02-00000000-00-00000389-0045: TC3EF2700 000:390 JLINK_GetFirmwareString(...) (0000ms, 0388ms total) 03-00000000-00-00000389-0031: Firmware: J-Link V9 compiled Dec 16 2016 15:34:10 02-00000000-00-00000389-0054: TC3EF2700 000:390 JLINK_GetHardwareVersion() returns 0x16B48 (0000ms, 0388ms total) 03-00000000-00-00000389-000F: Hardware: V9.30 03-00000000-00-00000389-000E: S/N: 269305306 03-00000000-00-00000389-000F: OEM: SEGGER-EDU 03-00000000-00-00000389-0018: Feature(s): FlashBP, GDB 02-00000000-00-00000391-004D: TC3EF2700 000:390 JLINK_GetHWStatus(...) returns 0x00 (0002ms, 0390ms total) 02-00000000-00-00000391-0040: TC3EF2700 000:392 JLINK_EnableSoftBPs(ON) (0000ms, 0390ms total) 03-00000000-00-00000392-001A: Checking target voltage... 03-00000000-00-00000392-0016: Target voltage: 3.31 V 03-00000000-00-00000392-001D: Listening on TCP/IP port 2331 03-00000000-00-00000392-0017: Connecting to target... 02-00000000-00-00000392-0039: TC3EF2700 000:393 JLINK_ClrError() (0000ms, 0390ms total) 02-00000000-00-00000395-004D: TC3EF2700 000:393 JLINK_GetHWStatus(...) returns 0x00 (0003ms, 0393ms total) 02-00000000-00-00000398-0059: TC3EF2700 000:396 JLINK_TIF_Select(JLINKARM_TIF_SWD) returns 0x00 (0003ms, 0396ms total) 02-00000000-00-00000399-003D: TC3EF2700 000:399 JLINK_SetSpeed(1000) (0001ms, 0397ms total) 02-00000000-00-00000399-0048: TC3EF2700 000:400 JLINK_GetSpeed() returns 0x3E8 (0000ms, 0397ms total) 02-00000000-00-00000399-007B: TC3EF2700 000:400 JLINK_SetResetType(JLINKARM_RESET_TYPE_NORMAL) returns JLINKARM_RESET_TYPE_NORMAL (0000ms, 0397ms total) 02-00000000-00-00000399-003F: TC3EF2700 000:400 JLINK_SetResetDelay(0) (0000ms, 0397ms total) 02-00000000-00-00000399-0059: TC3EF2700 000:400 JLINK_SetEndian(ARM_ENDIAN_LITTLE) returns 0x00 (0000ms, 0397ms total) 02-00000000-00-00000467-01F9: TC3EF2700 000:400 JLINK_Connect() >0x108 TIF>Found SWD-DP with ID 0x2BA01477 >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> 02-00000000-00-00000551-01FA: >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> 02-00000000-00-00000627-01F9: >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x108 TIF>Found SWD-DP with ID 0x2BA01477 >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> 02-00000000-00-00000672-01EF: >0x21 TIF>AP-IDR: 0x24770011, Type: AHB-APAHB-AP ROM: 0xE00FF000 (Base addr. of first ROM table) >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x28 TIF> >0x0D TIF> >0x21 TIF> >0x0D TIF> >0x21 TIF>Found Cortex-M4 r0p1, Little endian. -- CPU_ReadMem(4 bytes @ 0xE000EDF0) -- CPU_ReadMem(4 bytes @ 0xE0002000) -- CPU_ReadMem(4 bytes @ 0xE000EDFC) -- CPU_ReadMem(4 bytes @ 0xE0001000) -- CPU_WriteMem(4 bytes @ 0xE0001000) 02-00000000-00-00000683-01EC: -- CPU_ReadMem(4 bytes @ 0xE000ED88) -- CPU_WriteMem(4 bytes @ 0xE000ED88) -- CPU_ReadMem(4 bytes @ 0xE000ED88) -- CPU_WriteMem(4 bytes @ 0xE000ED88)CoreSight components:ROMTbl 0 @ E00FF000 -- CPU_ReadMem(16 bytes @ 0xE00FF000) -- CPU_ReadMem(16 bytes @ 0xE000EFF0) -- CPU_ReadMem(16 bytes @ 0xE000EFE0)ROMTbl 0 [0]: FFF0F000, CID: B105E00D, PID: 000BB00C SCS -- CPU_ReadMem(16 bytes @ 0xE0001FF0) -- CPU_ReadMem(16 bytes @ 0xE0001FE0)ROMTbl 0 [1]: FFF02000, CID: B105E00D, PID: 003BB002 DWT 02-00000000-00-00000692-01D9: -- CPU_ReadMem(16 bytes @ 0xE0002FF0) -- CPU_ReadMem(16 bytes @ 0xE0002FE0)ROMTbl 0 [2]: FFF03000, CID: B105E00D, PID: 002BB003 FPB -- CPU_ReadMem(16 bytes @ 0xE0000FF0) -- CPU_ReadMem(16 bytes @ 0xE0000FE0)ROMTbl 0 [3]: FFF01000, CID: B105E00D, PID: 003BB001 ITM -- CPU_ReadMem(16 bytes @ 0xE00FF010) -- CPU_ReadMem(16 bytes @ 0xE0040FF0) -- CPU_ReadMem(16 bytes @ 0xE0040FE0)ROMTbl 0 [4]: FFF41000, CID: B105900D, PID: 000BB9A1 TPIU -- CPU_ReadMem(16 bytes @ 0xE0041FF0) 02-00000000-00-00000695-0083: -- CPU_ReadMem(16 bytes @ 0xE0041FE0)ROMTbl 0 [5]: FFF42000, CID: B105900D, PID: 000BB925 ETM returns 0x00 (0296ms, 0693ms total) 02-00000000-00-00000699-00A6: TC3EF2700 000:696 JLINK_GetIdData(...) >0x0D TIF> >0x21 TIF> ScanLen=4 NumDevices=1 aId[0]=0x2BA01477 aIrRead[0]=0 aScanLen[0]=0 aScanRead[0]=0 (0003ms, 0696ms total) 02-00000000-00-00000699-004C: TC3EF2700 000:700 JLINK_GetDeviceFamily() returns 14 (0000ms, 0697ms total) 02-00000000-00-00000699-0051: TC3EF2700 000:700 JLINK_CORE_GetFound() returns 0xE0000FF (0000ms, 0697ms total) 02-00000000-00-00000699-0048: TC3EF2700 000:700 JLINK_IsHalted() returns FALSE (0000ms, 0697ms total) 02-00000000-00-00000706-0043: TC3EF2700 000:701 JLINK_Halt() returns 0x00 (0006ms, 0703ms total) 02-00000000-00-00000707-0047: TC3EF2700 000:707 JLINK_IsHalted() returns TRUE (0001ms, 0704ms total) 02-00000000-00-00000707-0055: TC3EF2700 000:708 JLINK_WriteReg(R0, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0055: TC3EF2700 000:708 JLINK_WriteReg(R1, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0055: TC3EF2700 000:708 JLINK_WriteReg(R2, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0055: TC3EF2700 000:708 JLINK_WriteReg(R3, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0055: TC3EF2700 000:708 JLINK_WriteReg(R4, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0055: TC3EF2700 000:708 JLINK_WriteReg(R5, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0055: TC3EF2700 000:708 JLINK_WriteReg(R6, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0055: TC3EF2700 000:708 JLINK_WriteReg(R7, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0055: TC3EF2700 000:708 JLINK_WriteReg(R8, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0055: TC3EF2700 000:708 JLINK_WriteReg(R9, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0056: TC3EF2700 000:708 JLINK_WriteReg(R10, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0056: TC3EF2700 000:708 JLINK_WriteReg(R11, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0056: TC3EF2700 000:708 JLINK_WriteReg(R12, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-005B: TC3EF2700 000:708 JLINK_WriteReg(R13 (SP), 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0056: TC3EF2700 000:708 JLINK_WriteReg(R14, 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-005B: TC3EF2700 000:708 JLINK_WriteReg(R15 (PC), 0x00000000) returns 0x00 (0000ms, 0703ms total) 02-00000000-00-00000707-0057: TC3EF2700 000:708 JLINK_WriteReg(XPSR, 0x01000000) returns 0x00 (0000ms, 0703ms total) 03-00000000-00-00000707-0013: Connected to target 03-00000000-00-00000707-001D: Waiting for GDB connection... 03-00000000-00-00001190-0016: Connected to 127.0.0.1 03-00000000-00-00001206-0015: Reading all registers 02-00000000-00-00001206-004E: TBA7FC700 001:207 JLINK_ReadReg(R0) returns 0x00000000 (0000ms, 0703ms total) 02-00000000-00-00001206-004E: TBA7FC700 001:207 JLINK_ReadReg(R1) returns 0x00000000 (0000ms, 0703ms total) 02-00000000-00-00001207-004E: TBA7FC700 001:208 JLINK_ReadReg(R2) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004E: TBA7FC700 001:208 JLINK_ReadReg(R3) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004E: TBA7FC700 001:208 JLINK_ReadReg(R4) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004E: TBA7FC700 001:208 JLINK_ReadReg(R5) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004E: TBA7FC700 001:208 JLINK_ReadReg(R6) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004E: TBA7FC700 001:208 JLINK_ReadReg(R7) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004E: TBA7FC700 001:208 JLINK_ReadReg(R8) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004E: TBA7FC700 001:208 JLINK_ReadReg(R9) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004F: TBA7FC700 001:208 JLINK_ReadReg(R10) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004F: TBA7FC700 001:208 JLINK_ReadReg(R11) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004F: TBA7FC700 001:208 JLINK_ReadReg(R12) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-0054: TBA7FC700 001:208 JLINK_ReadReg(R13 (SP)) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004F: TBA7FC700 001:208 JLINK_ReadReg(R14) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-0054: TBA7FC700 001:208 JLINK_ReadReg(R15 (PC)) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-0050: TBA7FC700 001:208 JLINK_ReadReg(XPSR) returns 0x01000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004F: TBA7FC700 001:208 JLINK_ReadReg(MSP) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-004F: TBA7FC700 001:208 JLINK_ReadReg(PSP) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-0053: TBA7FC700 001:208 JLINK_ReadReg(PRIMASK) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-0053: TBA7FC700 001:208 JLINK_ReadReg(BASEPRI) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-0055: TBA7FC700 001:208 JLINK_ReadReg(FAULTMASK) returns 0x00000000 (0000ms, 0704ms total) 02-00000000-00-00001207-0053: TBA7FC700 001:208 JLINK_ReadReg(CONTROL) returns 0x04000000 (0000ms, 0704ms total) 02-00000000-00-00001218-0051: TBA7FC700 001:208 JLINK_ReadReg(FPSCR) returns 0x20000010 (0011ms, 0715ms total) 02-00000000-00-00001219-0050: TBA7FC700 001:220 JLINK_ReadReg(FPS0) returns 0xFEFA39EF (0000ms, 0716ms total) 02-00000000-00-00001219-0050: TBA7FC700 001:220 JLINK_ReadReg(FPS1) returns 0x3FE62E42 (0000ms, 0716ms total) 02-00000000-00-00001219-0050: TBA7FC700 001:220 JLINK_ReadReg(FPS2) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0050: TBA7FC700 001:220 JLINK_ReadReg(FPS3) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0050: TBA7FC700 001:220 JLINK_ReadReg(FPS4) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0050: TBA7FC700 001:220 JLINK_ReadReg(FPS5) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0050: TBA7FC700 001:220 JLINK_ReadReg(FPS6) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0050: TBA7FC700 001:220 JLINK_ReadReg(FPS7) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0050: TBA7FC700 001:220 JLINK_ReadReg(FPS8) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0050: TBA7FC700 001:220 JLINK_ReadReg(FPS9) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS10) returns 0x4E2AAAAA (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS11) returns 0x3F000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS12) returns 0x4E2AAAAA (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS13) returns 0x3F304AFC (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS14) returns 0x48000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS15) returns 0x47B04AFC (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS16) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS17) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS18) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS19) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS20) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS21) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS22) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS23) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS24) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS25) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS26) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS27) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS28) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS29) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS30) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001219-0051: TBA7FC700 001:220 JLINK_ReadReg(FPS31) returns 0x00000000 (0000ms, 0716ms total) 02-00000000-00-00001221-009D: TBA7FC700 001:220 JLINK_ReadMem (0x00000000, 0x0004 Bytes, ...) -- CPU_ReadMem(4 bytes @ 0x00000000) - Data: 00 80 01 20 returns 0x00 (0002ms, 0718ms total) 03-00000000-00-00001222-0035: Read 4 bytes @ address 0x00000000 (Data = 0x20018000) 02-00000000-00-00001224-0097: TBA7FC700 001:223 JLINK_ReadMem (0x00000000, 0x0002 Bytes, ...) -- CPU_ReadMem(2 bytes @ 0x00000000) - Data: 00 80 returns 0x00 (0002ms, 0721ms total) 03-00000000-00-00001224-0031: Read 2 bytes @ address 0x00000000 (Data = 0x8000) 02-00000000-00-00001234-003D: TBA7FC700 001:234 JLINK_SetSpeed(1000) (0001ms, 0722ms total) 02-00000000-00-00001235-0048: TBA7FC700 001:235 JLINK_GetSpeed() returns 0x3E8 (0001ms, 0723ms total) 03-00000000-00-00001235-0026: Target interface speed set to 1000 kHz 02-00000000-00-00001235-0042: TBA7FC700 001:236 JLINK_ResetPullsRESET(ON) (0000ms, 0723ms total) 02-00000000-00-00001272-01F0: TBA7FC700 001:237 JLINK_Reset() -- CPU_WriteMem(4 bytes @ 0xE000EDF0) -- CPU_WriteMem(4 bytes @ 0xE000EDFC) >0x35 TIF> -- CPU_WriteMem(4 bytes @ 0xE000ED0C) -- CPU_ReadMem(4 bytes @ 0xE000EDF0) -- CPU_ReadMem(4 bytes @ 0xE000EDF0) -- CPU_WriteMem(4 bytes @ 0xE000EDF0) -- CPU_WriteMem(4 bytes @ 0xE000EDFC) -- CPU is running -- CPU_ReadMem(4 bytes @ 0xE000EDF0) -- CPU_WriteMem(4 bytes @ 0xE0002000) -- CPU_ReadMem(4 bytes @ 0xE000EDFC) -- CPU_ReadMem(4 bytes @ 0xE0001000) (0036ms, 0760ms total) 03-00000000-00-00001273-0010: Resetting target 03-00000000-00-00001273-0015: Halting target CPU... 02-00000000-00-00001273-0043: TBA7FC700 001:274 JLINK_Halt() returns 0x00 (0000ms, 0761ms total) 02-00000000-00-00001273-0047: TBA7FC700 001:274 JLINK_IsHalted() returns TRUE (0000ms, 0761ms total) 02-00000000-00-00001273-0054: TBA7FC700 001:274 JLINK_ReadReg(R15 (PC)) returns 0x080112D4 (0000ms, 0761ms total) 03-00000000-00-00001273-0022: ...Target halted (PC = 0x080112D4) 02-00000000-00-00001273-0053: TBA7FC700 001:274 JLINK_ReadReg(PRIMASK) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-0053: TBA7FC700 001:274 JLINK_ReadReg(BASEPRI) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-0055: TBA7FC700 001:274 JLINK_ReadReg(FAULTMASK) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-0053: TBA7FC700 001:274 JLINK_ReadReg(CONTROL) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-0050: TBA7FC700 001:274 JLINK_ReadReg(CFBP) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-0050: TBA7FC700 001:274 JLINK_ReadReg(IPSR) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-0050: TBA7FC700 001:274 JLINK_ReadReg(EPSR) returns 0x01000000 (0000ms, 0761ms total) 02-00000000-00-00001273-0050: TBA7FC700 001:274 JLINK_ReadReg(APSR) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-0050: TBA7FC700 001:274 JLINK_ReadReg(XPSR) returns 0x01000000 (0000ms, 0761ms total) 02-00000000-00-00001273-0054: TBA7FC700 001:274 JLINK_ReadReg(R15 (PC)) returns 0x080112D4 (0000ms, 0761ms total) 02-00000000-00-00001273-004F: TBA7FC700 001:274 JLINK_ReadReg(R14) returns 0xFFFFFFFF (0000ms, 0761ms total) 02-00000000-00-00001273-004F: TBA7FC700 001:274 JLINK_ReadReg(PSP) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-004F: TBA7FC700 001:274 JLINK_ReadReg(MSP) returns 0x20018000 (0000ms, 0761ms total) 02-00000000-00-00001273-0054: TBA7FC700 001:274 JLINK_ReadReg(R13 (SP)) returns 0x20018000 (0000ms, 0761ms total) 02-00000000-00-00001273-004F: TBA7FC700 001:274 JLINK_ReadReg(R12) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-004F: TBA7FC700 001:274 JLINK_ReadReg(R11) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-004F: TBA7FC700 001:274 JLINK_ReadReg(R10) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-004E: TBA7FC700 001:274 JLINK_ReadReg(R9) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-004E: TBA7FC700 001:274 JLINK_ReadReg(R8) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-004E: TBA7FC700 001:274 JLINK_ReadReg(R7) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-004E: TBA7FC700 001:274 JLINK_ReadReg(R6) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-004E: TBA7FC700 001:274 JLINK_ReadReg(R5) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001273-004E: TBA7FC700 001:274 JLINK_ReadReg(R4) returns 0x00000000 (0000ms, 0761ms total) 02-00000000-00-00001274-004E: TBA7FC700 001:275 JLINK_ReadReg(R3) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001274-004E: TBA7FC700 001:275 JLINK_ReadReg(R2) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001274-004E: TBA7FC700 001:275 JLINK_ReadReg(R1) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001274-004E: TBA7FC700 001:275 JLINK_ReadReg(R0) returns 0x00000000 (0000ms, 0762ms total) 03-00000000-00-00001274-003A: R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000 03-00000000-00-00001274-003A: R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000 03-00000000-00-00001274-003A: R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000 03-00000000-00-00001274-003A: R12= 00000000, R13= 20018000, MSP= 20018000, PSP= 00000000 03-00000000-00-00001274-0026: R14(LR) = FFFFFFFF, R15(PC) = 080112D4 03-00000000-00-00001274-003A: XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000 03-00000000-00-00001274-003F: CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00 03-00000000-00-00001275-0015: Reading all registers 02-00000000-00-00001276-004E: TBA7FC700 001:277 JLINK_ReadReg(R0) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004E: TBA7FC700 001:277 JLINK_ReadReg(R1) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004E: TBA7FC700 001:277 JLINK_ReadReg(R2) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004E: TBA7FC700 001:277 JLINK_ReadReg(R3) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004E: TBA7FC700 001:277 JLINK_ReadReg(R4) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004E: TBA7FC700 001:277 JLINK_ReadReg(R5) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004E: TBA7FC700 001:277 JLINK_ReadReg(R6) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004E: TBA7FC700 001:277 JLINK_ReadReg(R7) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004E: TBA7FC700 001:277 JLINK_ReadReg(R8) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004E: TBA7FC700 001:277 JLINK_ReadReg(R9) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004F: TBA7FC700 001:277 JLINK_ReadReg(R10) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004F: TBA7FC700 001:277 JLINK_ReadReg(R11) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004F: TBA7FC700 001:277 JLINK_ReadReg(R12) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-0054: TBA7FC700 001:277 JLINK_ReadReg(R13 (SP)) returns 0x20018000 (0000ms, 0762ms total) 02-00000000-00-00001276-004F: TBA7FC700 001:277 JLINK_ReadReg(R14) returns 0xFFFFFFFF (0000ms, 0762ms total) 02-00000000-00-00001276-0054: TBA7FC700 001:277 JLINK_ReadReg(R15 (PC)) returns 0x080112D4 (0000ms, 0762ms total) 02-00000000-00-00001276-0050: TBA7FC700 001:277 JLINK_ReadReg(XPSR) returns 0x01000000 (0000ms, 0762ms total) 02-00000000-00-00001276-004F: TBA7FC700 001:277 JLINK_ReadReg(MSP) returns 0x20018000 (0000ms, 0762ms total) 02-00000000-00-00001276-004F: TBA7FC700 001:277 JLINK_ReadReg(PSP) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-0053: TBA7FC700 001:277 JLINK_ReadReg(PRIMASK) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-0053: TBA7FC700 001:277 JLINK_ReadReg(BASEPRI) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-0055: TBA7FC700 001:277 JLINK_ReadReg(FAULTMASK) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001276-0053: TBA7FC700 001:277 JLINK_ReadReg(CONTROL) returns 0x00000000 (0000ms, 0762ms total) 02-00000000-00-00001287-0051: TBA7FC700 001:277 JLINK_ReadReg(FPSCR) returns 0x00000000 (0011ms, 0773ms total) 02-00000000-00-00001287-0050: TBA7FC700 001:288 JLINK_ReadReg(FPS0) returns 0x00000000 (0000ms, 0773ms total) 02-00000000-00-00001288-0050: TBA7FC700 001:288 JLINK_ReadReg(FPS1) returns 0x00000000 (0000ms, 0773ms total) 02-00000000-00-00001288-0050: TBA7FC700 001:289 JLINK_ReadReg(FPS2) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0050: TBA7FC700 001:289 JLINK_ReadReg(FPS3) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0050: TBA7FC700 001:289 JLINK_ReadReg(FPS4) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0050: TBA7FC700 001:289 JLINK_ReadReg(FPS5) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0050: TBA7FC700 001:289 JLINK_ReadReg(FPS6) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0050: TBA7FC700 001:289 JLINK_ReadReg(FPS7) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0050: TBA7FC700 001:289 JLINK_ReadReg(FPS8) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0050: TBA7FC700 001:289 JLINK_ReadReg(FPS9) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS10) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS11) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS12) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS13) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS14) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS15) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS16) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS17) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS18) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS19) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS20) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS21) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS22) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS23) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS24) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS25) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS26) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS27) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS28) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS29) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS30) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001288-0051: TBA7FC700 001:289 JLINK_ReadReg(FPS31) returns 0x00000000 (0000ms, 0774ms total) 02-00000000-00-00001290-00F6: TBA7FC700 001:289 JLINK_ReadMem (0x080112D4, 0x0004 Bytes, ...) -- CPU_ReadMem(64 bytes @ 0x080112C0) -- Updating C cache (64 bytes @ 0x080112C0) -- Read from C cache (4 bytes @ 0x080112D4) - Data: DF F8 68 D0 returns 0x00 (0002ms, 0776ms total) 03-00000000-00-00001291-0035: Read 4 bytes @ address 0x080112D4 (Data = 0xD068F8DF) 02-00000000-00-00001291-009E: TBA7FC700 001:292 JLINK_ReadMem (0x080112D4, 0x0002 Bytes, ...) -- Read from C cache (2 bytes @ 0x080112D4) - Data: DF F8 returns 0x00 (0000ms, 0776ms total) 03-00000000-00-00001291-0031: Read 2 bytes @ address 0x080112D4 (Data = 0xF8DF) 02-00000000-00-00001293-003C: TBA7FC700 001:293 JLINK_SetMaxSpeed() (0001ms, 0777ms total) 02-00000000-00-00001293-0048: TBA7FC700 001:294 JLINK_GetSpeed() returns 0x7D0 (0000ms, 0777ms total) 03-00000000-00-00001293-002D: Select auto target interface speed (2000 kHz) 02-00000000-00-00001295-0061: TBA7FC700 001:296 JLINK_ExecCommand("EnableFlashBPs", ...). returns 0x00 (0000ms, 0777ms total) 03-00000000-00-00001295-0019: Flash breakpoints enabled 02-00000000-00-00001540-00A4: TBA7FC700 001:541 JLINK_ReadMem (0x080112D4, 0x0004 Bytes, ...) -- Read from C cache (4 bytes @ 0x080112D4) - Data: DF F8 68 D0 returns 0x00 (0000ms, 0777ms total) 03-00000000-00-00001540-0035: Read 4 bytes @ address 0x080112D4 (Data = 0xD068F8DF) 02-00000000-00-00001541-009E: TBA7FC700 001:542 JLINK_ReadMem (0x080112D4, 0x0002 Bytes, ...) -- Read from C cache (2 bytes @ 0x080112D4) - Data: DF F8 returns 0x00 (0000ms, 0777ms total) 03-00000000-00-00001541-0031: Read 2 bytes @ address 0x080112D4 (Data = 0xF8DF) 02-00000000-00-00001542-009E: TBA7FC700 001:543 JLINK_ReadMem (0x080112D6, 0x0002 Bytes, ...) -- Read from C cache (2 bytes @ 0x080112D6) - Data: 68 D0 returns 0x00 (0000ms, 0777ms total) 03-00000000-00-00001542-0031: Read 2 bytes @ address 0x080112D6 (Data = 0xD068) 03-00000000-00-00001544-002A: Downloading 392 bytes @ address 0x08000000 02-00000000-00-00001546-00A1: TBA7FC700 001:545 JLINK_WriteMem(0x08000000, 0x0188 Bytes, ...) - Data: 00 80 01 20 D5 12 01 08 75 13 01 08 19 5C 00 08 ... returns 0x188 (0001ms, 0778ms total) 02-00000000-00-00001546-00D2: TBA7FC700 001:547 JLINK_ReadMem (0x08000000, 0x0188 Bytes, ...) -- Read from flash cache (392 bytes @ 0x08000000) - Data: 00 80 01 20 D5 12 01 08 75 13 01 08 19 5C 00 08 ... returns 0x00 (0000ms, 0779ms total) 03-00000000-00-00001546-000E: - Verified OK 03-00000000-00-00001548-002C: Downloading 16272 bytes @ address 0x08000190 02-00000000-00-00001548-00A2: TBA7FC700 001:549 JLINK_WriteMem(0x08000190, 0x3F90 Bytes, ...) - Data: 81 F0 00 41 02 E0 00 BF 83 F0 00 43 30 B5 4F EA ... returns 0x3F90 (0000ms, 0779ms total) 02-00000000-00-00001548-00D4: TBA7FC700 001:549 JLINK_ReadMem (0x08000190, 0x3F90 Bytes, ...) -- Read from flash cache (16272 bytes @ 0x08000190) - Data: 81 F0 00 41 02 E0 00 BF 83 F0 00 43 30 B5 4F EA ... returns 0x00 (0000ms, 0779ms total) 03-00000000-00-00001548-000E: - Verified OK 03-00000000-00-00001549-002C: Downloading 16016 bytes @ address 0x08004120 02-00000000-00-00001549-00A2: TBA7FC700 001:550 JLINK_WriteMem(0x08004120, 0x3E90 Bytes, ...) - Data: 42 F6 D0 72 83 54 00 F5 3F 52 53 61 93 61 42 F6 ... returns 0x3E90 (0000ms, 0779ms total) 02-00000000-00-00001549-00D4: TBA7FC700 001:550 JLINK_ReadMem (0x08004120, 0x3E90 Bytes, ...) -- Read from flash cache (16016 bytes @ 0x08004120) - Data: 42 F6 D0 72 83 54 00 F5 3F 52 53 61 93 61 42 F6 ... returns 0x00 (0000ms, 0779ms total) 03-00000000-00-00001549-000E: - Verified OK 03-00000000-00-00001550-002C: Downloading 16128 bytes @ address 0x08007FB0 02-00000000-00-00001550-00A2: TBA7FC700 001:551 JLINK_WriteMem(0x08007FB0, 0x3F00 Bytes, ...) - Data: 10 F0 04 0F 01 D0 83 F0 61 03 10 F0 08 0F 01 D0 ... returns 0x3F00 (0000ms, 0779ms total) 02-00000000-00-00001550-00D4: TBA7FC700 001:551 JLINK_ReadMem (0x08007FB0, 0x3F00 Bytes, ...) -- Read from flash cache (16128 bytes @ 0x08007FB0) - Data: 10 F0 04 0F 01 D0 83 F0 61 03 10 F0 08 0F 01 D0 ... returns 0x00 (0000ms, 0779ms total) 03-00000000-00-00001550-000E: - Verified OK 03-00000000-00-00001550-002C: Downloading 15984 bytes @ address 0x0800BEB0 02-00000000-00-00001550-00A2: TBA7FC700 001:551 JLINK_WriteMem(0x0800BEB0, 0x3E70 Bytes, ...) - Data: 80 7B C6 F8 14 B0 4F F4 80 6A C6 F8 18 A0 4F F0 ... returns 0x3E70 (0000ms, 0779ms total) 02-00000000-00-00001550-00D4: TBA7FC700 001:551 JLINK_ReadMem (0x0800BEB0, 0x3E70 Bytes, ...) -- Read from flash cache (15984 bytes @ 0x0800BEB0) - Data: 80 7B C6 F8 14 B0 4F F4 80 6A C6 F8 18 A0 4F F0 ... returns 0x00 (0000ms, 0779ms total) 03-00000000-00-00001551-000E: - Verified OK 03-00000000-00-00001551-002C: Downloading 15888 bytes @ address 0x0800FD20 02-00000000-00-00001551-00A2: TBA7FC700 001:552 JLINK_WriteMem(0x0800FD20, 0x3E10 Bytes, ...) - Data: 93 60 20 68 82 68 23 6C 01 3B 21 6D 0B 43 A1 6C ... returns 0x3E10 (0000ms, 0780ms total) 02-00000000-00-00001551-00D4: TBA7FC700 001:552 JLINK_ReadMem (0x0800FD20, 0x3E10 Bytes, ...) -- Read from flash cache (15888 bytes @ 0x0800FD20) - Data: 93 60 20 68 82 68 23 6C 01 3B 21 6D 0B 43 A1 6C ... returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001551-000E: - Verified OK 03-00000000-00-00001551-002B: Downloading 1776 bytes @ address 0x08013B30 02-00000000-00-00001551-00A1: TBA7FC700 001:552 JLINK_WriteMem(0x08013B30, 0x06F0 Bytes, ...) - Data: 0A 06 9E 42 C8 BF 01 31 FF F7 08 FF 00 F1 14 05 ... returns 0x6F0 (0000ms, 0780ms total) 02-00000000-00-00001551-00D3: TBA7FC700 001:552 JLINK_ReadMem (0x08013B30, 0x06F0 Bytes, ...) -- Read from flash cache (1776 bytes @ 0x08013B30) - Data: 0A 06 9E 42 C8 BF 01 31 FF F7 08 FF 00 F1 14 05 ... returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001551-000E: - Verified OK 03-00000000-00-00001551-002B: Downloading 1168 bytes @ address 0x08014220 02-00000000-00-00001551-00A1: TBA7FC700 001:552 JLINK_WriteMem(0x08014220, 0x0490 Bytes, ...) - Data: E4 9A 00 20 E4 9A 00 20 00 00 00 00 00 00 00 00 ... returns 0x490 (0000ms, 0780ms total) 02-00000000-00-00001551-00D3: TBA7FC700 001:552 JLINK_ReadMem (0x08014220, 0x0490 Bytes, ...) -- Read from flash cache (1168 bytes @ 0x08014220) - Data: E4 9A 00 20 E4 9A 00 20 00 00 00 00 00 00 00 00 ... returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001551-000E: - Verified OK 03-00000000-00-00001552-0028: Downloading 8 bytes @ address 0x080146B0 02-00000000-00-00001552-0084: TBA7FC700 001:553 JLINK_WriteMem(0x080146B0, 0x0008 Bytes, ...) - Data: 68 D6 FF 7F 01 00 00 00 returns 0x08 (0000ms, 0780ms total) 02-00000000-00-00001552-00B4: TBA7FC700 001:553 JLINK_ReadMem (0x080146B0, 0x0008 Bytes, ...) -- Read from flash cache (8 bytes @ 0x080146B0) - Data: 68 D6 FF 7F 01 00 00 00 returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001552-000E: - Verified OK 03-00000000-00-00001552-0029: Downloading 40 bytes @ address 0x080146B8 02-00000000-00-00001552-00A0: TBA7FC700 001:553 JLINK_WriteMem(0x080146B8, 0x0028 Bytes, ...) - Data: A5 0C 00 08 A9 5D 00 08 B5 A2 00 08 0D A9 00 08 ... returns 0x28 (0000ms, 0780ms total) 02-00000000-00-00001552-00D1: TBA7FC700 001:553 JLINK_ReadMem (0x080146B8, 0x0028 Bytes, ...) -- Read from flash cache (40 bytes @ 0x080146B8) - Data: A5 0C 00 08 A9 5D 00 08 B5 A2 00 08 0D A9 00 08 ... returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001552-000E: - Verified OK 03-00000000-00-00001553-0028: Downloading 8 bytes @ address 0x080146E0 02-00000000-00-00001553-0084: TBA7FC700 001:554 JLINK_WriteMem(0x080146E0, 0x0008 Bytes, ...) - Data: 81 0C 00 08 99 BC 00 08 returns 0x08 (0000ms, 0780ms total) 02-00000000-00-00001553-00B4: TBA7FC700 001:554 JLINK_ReadMem (0x080146E0, 0x0008 Bytes, ...) -- Read from flash cache (8 bytes @ 0x080146E0) - Data: 81 0C 00 08 99 BC 00 08 returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001553-000E: - Verified OK 03-00000000-00-00001553-002A: Downloading 488 bytes @ address 0x080146E8 02-00000000-00-00001553-00A1: TBA7FC700 001:554 JLINK_WriteMem(0x080146E8, 0x01E8 Bytes, ...) - Data: 01 00 00 00 84 43 01 08 6C 43 01 08 54 43 01 08 ... returns 0x1E8 (0000ms, 0780ms total) 02-00000000-00-00001553-00D2: TBA7FC700 001:554 JLINK_ReadMem (0x080146E8, 0x01E8 Bytes, ...) -- Read from flash cache (488 bytes @ 0x080146E8) - Data: 01 00 00 00 84 43 01 08 6C 43 01 08 54 43 01 08 ... returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001553-000E: - Verified OK 02-00000000-00-00001554-00A8: TBA7FC700 001:555 JLINK_ReadMem (0x080112D4, 0x0004 Bytes, ...) -- Read from flash cache (4 bytes @ 0x080112D4) - Data: DF F8 68 D0 returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001554-0035: Read 4 bytes @ address 0x080112D4 (Data = 0xD068F8DF) 02-00000000-00-00001554-00A2: TBA7FC700 001:555 JLINK_ReadMem (0x080112D4, 0x0002 Bytes, ...) -- Read from flash cache (2 bytes @ 0x080112D4) - Data: DF F8 returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001554-0031: Read 2 bytes @ address 0x080112D4 (Data = 0xF8DF) 02-00000000-00-00001554-00A2: TBA7FC700 001:555 JLINK_ReadMem (0x080112D6, 0x0002 Bytes, ...) -- Read from flash cache (2 bytes @ 0x080112D6) - Data: 68 D0 returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001554-0031: Read 2 bytes @ address 0x080112D6 (Data = 0xD068) 02-00000000-00-00001596-00A2: TBA7FC700 001:597 JLINK_ReadMem (0x08005618, 0x0002 Bytes, ...) -- Read from flash cache (2 bytes @ 0x08005618) - Data: 08 B5 returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001596-0031: Read 2 bytes @ address 0x08005618 (Data = 0xB508) 02-00000000-00-00001603-00A2: TBA7FC700 001:604 JLINK_ReadMem (0x08005618, 0x0002 Bytes, ...) -- Read from flash cache (2 bytes @ 0x08005618) - Data: 08 B5 returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001603-0031: Read 2 bytes @ address 0x08005618 (Data = 0xB508) 02-00000000-00-00001603-00A2: TBA7FC700 001:604 JLINK_ReadMem (0x08005734, 0x0002 Bytes, ...) -- Read from flash cache (2 bytes @ 0x08005734) - Data: 2E 48 returns 0x00 (0000ms, 0780ms total) 03-00000000-00-00001603-0031: Read 2 bytes @ address 0x08005734 (Data = 0x482E) 02-00000000-00-00001609-0042: TBA7FC700 001:610 JLINK_ResetPullsRESET(ON) (0000ms, 0780ms total) 02-00000000-00-00001657-01ED: TBA7FC700 001:610 JLINK_Reset() -- -------------------------------------- -- Start of determining dirty areas in flash cache -- End of determining dirty areas -- Start of preparing flash programming -- Calculating RAM usage -- RAM usage = 6028 Bytes -- Preserving CPU registers -- Preparing memory -- Determining CPU clock frequency -- Preparing target -- Downloading RAMCode -- Checking target RAM -- Preparing RAMCode -- End of preparing flash programming -- CPU speed could not be measured. 03-00000000-00-00001658-0013: Comparing flash [ 03-00000000-00-00002100-000A: .......... 03-00000000-00-00002544-0011: ..........] Done. 02-00000000-00-00002545-01F9: -- Start of comparing flash -- CRC check was estimated as fastest method -- Comparing range 0x8000000 - 0x8014FFF (42 Sectors, 84 KB), using multi-block CRC calculation -- All CRCs match -- Comparing range 0x8000000 - 0x8014FFF (42 Sectors, 84 KB), using alternative multi-block CRC calculation -- All CRCs match -- End of comparing flash -- Start of erasing sectors -- End of erasing sectors -- Start of flash programming -- End of flash programming -- Start of verifying flash -- End of verifying flash 03-00000000-00-00002545-002E: Verifying flash [....................] Done. 02-00000000-00-00002568-01DB: -- Start of restoring -- Restoring RAMCode -- Restore target -- Restore memory -- Restoring CPU registers -- End of restoring -- Flash download skipped. Flash contents already match -- Flash download skipped. Flash contents already match -- CPU_WriteMem(4 bytes @ 0xE000EDF0) -- CPU_WriteMem(4 bytes @ 0xE000EDFC) >0x35 TIF> -- CPU_WriteMem(4 bytes @ 0xE000ED0C) -- CPU_ReadMem(4 bytes @ 0xE000EDF0) -- CPU_ReadMem(4 bytes @ 0xE000EDF0) -- CPU_WriteMem(4 bytes @ 0xE000EDF0) 02-00000000-00-00002586-00E4: -- CPU_WriteMem(4 bytes @ 0xE000EDFC) -- CPU is running -- CPU_ReadMem(4 bytes @ 0xE000EDF0) -- CPU_WriteMem(4 bytes @ 0xE0002000) -- CPU_ReadMem(4 bytes @ 0xE000EDFC) -- CPU_ReadMem(4 bytes @ 0xE0001000) (0977ms, 1757ms total) 03-00000000-00-00002587-0010: Resetting target 03-00000000-00-00002587-0015: Halting target CPU... 02-00000000-00-00002588-004D: TC36F1700 002:588 JLINK_GetHWStatus(...) returns 0x00 (0001ms, 1758ms total) 02-00000000-00-00002590-0043: TBA7FC700 002:591 JLINK_Halt() returns 0x00 (0000ms, 1759ms total) 02-00000000-00-00002590-0047: TBA7FC700 002:591 JLINK_IsHalted() returns TRUE (0000ms, 1759ms total) 02-00000000-00-00002591-0054: TBA7FC700 002:592 JLINK_ReadReg(R15 (PC)) returns 0x080112D4 (0000ms, 1759ms total) 03-00000000-00-00002591-0022: ...Target halted (PC = 0x080112D4) 02-00000000-00-00002591-00A2: TBA7FC700 002:592 JLINK_ReadMem (0x08005618, 0x0002 Bytes, ...) -- Read from flash cache (2 bytes @ 0x08005618) - Data: 08 B5 returns 0x00 (0000ms, 1759ms total) 03-00000000-00-00002591-0031: Read 2 bytes @ address 0x08005618 (Data = 0xB508) 02-00000000-00-00002592-0053: TBA7FC700 002:593 JLINK_ReadReg(PRIMASK) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-0053: TBA7FC700 002:593 JLINK_ReadReg(BASEPRI) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-0055: TBA7FC700 002:593 JLINK_ReadReg(FAULTMASK) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-0053: TBA7FC700 002:593 JLINK_ReadReg(CONTROL) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-0050: TBA7FC700 002:593 JLINK_ReadReg(CFBP) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-0050: TBA7FC700 002:593 JLINK_ReadReg(IPSR) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-0050: TBA7FC700 002:593 JLINK_ReadReg(EPSR) returns 0x01000000 (0000ms, 1759ms total) 02-00000000-00-00002592-0050: TBA7FC700 002:593 JLINK_ReadReg(APSR) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-0050: TBA7FC700 002:593 JLINK_ReadReg(XPSR) returns 0x01000000 (0000ms, 1759ms total) 02-00000000-00-00002592-0054: TBA7FC700 002:593 JLINK_ReadReg(R15 (PC)) returns 0x080112D4 (0000ms, 1759ms total) 02-00000000-00-00002592-004F: TBA7FC700 002:593 JLINK_ReadReg(R14) returns 0xFFFFFFFF (0000ms, 1759ms total) 02-00000000-00-00002592-004F: TBA7FC700 002:593 JLINK_ReadReg(PSP) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004F: TBA7FC700 002:593 JLINK_ReadReg(MSP) returns 0x20018000 (0000ms, 1759ms total) 02-00000000-00-00002592-0054: TBA7FC700 002:593 JLINK_ReadReg(R13 (SP)) returns 0x20018000 (0000ms, 1759ms total) 02-00000000-00-00002592-004F: TBA7FC700 002:593 JLINK_ReadReg(R12) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004F: TBA7FC700 002:593 JLINK_ReadReg(R11) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004F: TBA7FC700 002:593 JLINK_ReadReg(R10) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004E: TBA7FC700 002:593 JLINK_ReadReg(R9) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004E: TBA7FC700 002:593 JLINK_ReadReg(R8) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004E: TBA7FC700 002:593 JLINK_ReadReg(R7) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004E: TBA7FC700 002:593 JLINK_ReadReg(R6) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004E: TBA7FC700 002:593 JLINK_ReadReg(R5) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004E: TBA7FC700 002:593 JLINK_ReadReg(R4) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004E: TBA7FC700 002:593 JLINK_ReadReg(R3) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004E: TBA7FC700 002:593 JLINK_ReadReg(R2) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004E: TBA7FC700 002:593 JLINK_ReadReg(R1) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002592-004E: TBA7FC700 002:593 JLINK_ReadReg(R0) returns 0x00000000 (0000ms, 1759ms total) 03-00000000-00-00002593-003A: R0 = 00000000, R1 = 00000000, R2 = 00000000, R3 = 00000000 03-00000000-00-00002593-003A: R4 = 00000000, R5 = 00000000, R6 = 00000000, R7 = 00000000 03-00000000-00-00002593-003A: R8 = 00000000, R9 = 00000000, R10= 00000000, R11= 00000000 03-00000000-00-00002593-003A: R12= 00000000, R13= 20018000, MSP= 20018000, PSP= 00000000 03-00000000-00-00002593-0026: R14(LR) = FFFFFFFF, R15(PC) = 080112D4 03-00000000-00-00002593-003A: XPSR 01000000, APSR 00000000, EPSR 01000000, IPSR 00000000 03-00000000-00-00002593-003F: CFBP 00000000, CONTROL 00, FAULTMASK 00, BASEPRI 00, PRIMASK 00 03-00000000-00-00002593-0015: Reading all registers 02-00000000-00-00002593-004E: TBA7FC700 002:594 JLINK_ReadReg(R0) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-004E: TBA7FC700 002:594 JLINK_ReadReg(R1) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-004E: TBA7FC700 002:594 JLINK_ReadReg(R2) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-004E: TBA7FC700 002:594 JLINK_ReadReg(R3) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-004E: TBA7FC700 002:594 JLINK_ReadReg(R4) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-004E: TBA7FC700 002:594 JLINK_ReadReg(R5) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-004E: TBA7FC700 002:594 JLINK_ReadReg(R6) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-004E: TBA7FC700 002:594 JLINK_ReadReg(R7) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-004E: TBA7FC700 002:594 JLINK_ReadReg(R8) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-004E: TBA7FC700 002:594 JLINK_ReadReg(R9) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-004F: TBA7FC700 002:594 JLINK_ReadReg(R10) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-004F: TBA7FC700 002:594 JLINK_ReadReg(R11) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-004F: TBA7FC700 002:594 JLINK_ReadReg(R12) returns 0x00000000 (0000ms, 1759ms total) 02-00000000-00-00002593-0054: TBA7FC700 002:594 JLINK_ReadReg(R13 (SP)) returns 0x20018000 (0000ms, 1759ms total) 02-00000000-00-00002594-004F: TBA7FC700 002:595 JLINK_ReadReg(R14) returns 0xFFFFFFFF (0000ms, 1760ms total) 02-00000000-00-00002594-0054: TBA7FC700 002:595 JLINK_ReadReg(R15 (PC)) returns 0x080112D4 (0000ms, 1760ms total) 02-00000000-00-00002594-0050: TBA7FC700 002:595 JLINK_ReadReg(XPSR) returns 0x01000000 (0000ms, 1760ms total) 02-00000000-00-00002594-004F: TBA7FC700 002:595 JLINK_ReadReg(MSP) returns 0x20018000 (0000ms, 1760ms total) 02-00000000-00-00002594-004F: TBA7FC700 002:595 JLINK_ReadReg(PSP) returns 0x00000000 (0000ms, 1760ms total) 02-00000000-00-00002594-0053: TBA7FC700 002:595 JLINK_ReadReg(PRIMASK) returns 0x00000000 (0000ms, 1760ms total) 02-00000000-00-00002594-0053: TBA7FC700 002:595 JLINK_ReadReg(BASEPRI) returns 0x00000000 (0000ms, 1760ms total) 02-00000000-00-00002594-0055: TBA7FC700 002:595 JLINK_ReadReg(FAULTMASK) returns 0x00000000 (0000ms, 1760ms total) 02-00000000-00-00002594-0053: TBA7FC700 002:595 JLINK_ReadReg(CONTROL) returns 0x00000000 (0000ms, 1760ms total) 02-00000000-00-00002601-0051: TBA7FC700 002:595 JLINK_ReadReg(FPSCR) returns 0x00000000 (0007ms, 1767ms total) 02-00000000-00-00002602-0050: TBA7FC700 002:602 JLINK_ReadReg(FPS0) returns 0x00000000 (0001ms, 1768ms total) 02-00000000-00-00002602-0050: TBA7FC700 002:603 JLINK_ReadReg(FPS1) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0050: TBA7FC700 002:603 JLINK_ReadReg(FPS2) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0050: TBA7FC700 002:603 JLINK_ReadReg(FPS3) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0050: TBA7FC700 002:603 JLINK_ReadReg(FPS4) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0050: TBA7FC700 002:603 JLINK_ReadReg(FPS5) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0050: TBA7FC700 002:603 JLINK_ReadReg(FPS6) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0050: TBA7FC700 002:603 JLINK_ReadReg(FPS7) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0050: TBA7FC700 002:603 JLINK_ReadReg(FPS8) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0050: TBA7FC700 002:603 JLINK_ReadReg(FPS9) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS10) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS11) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS12) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS13) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS14) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS15) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS16) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS17) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS18) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS19) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS20) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS21) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS22) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS23) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS24) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS25) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS26) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS27) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS28) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS29) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS30) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-0051: TBA7FC700 002:603 JLINK_ReadReg(FPS31) returns 0x00000000 (0000ms, 1768ms total) 02-00000000-00-00002602-00A8: TBA7FC700 002:603 JLINK_ReadMem (0x080112D4, 0x0004 Bytes, ...) -- Read from flash cache (4 bytes @ 0x080112D4) - Data: DF F8 68 D0 returns 0x00 (0000ms, 1768ms total) 03-00000000-00-00002602-0035: Read 4 bytes @ address 0x080112D4 (Data = 0xD068F8DF) 02-00000000-00-00002602-00A2: TBA7FC700 002:603 JLINK_ReadMem (0x080112D4, 0x0002 Bytes, ...) -- Read from flash cache (2 bytes @ 0x080112D4) - Data: DF F8 returns 0x00 (0000ms, 1768ms total) 03-00000000-00-00002602-0031: Read 2 bytes @ address 0x080112D4 (Data = 0xF8DF) 02-00000000-00-00002603-00A2: TBA7FC700 002:604 JLINK_ReadMem (0x080112D6, 0x0002 Bytes, ...) -- Read from flash cache (2 bytes @ 0x080112D6) - Data: 68 D0 returns 0x00 (0000ms, 1768ms total) 03-00000000-00-00002603-0031: Read 2 bytes @ address 0x080112D6 (Data = 0xD068) 02-00000000-00-00002603-006A: TBA7FC700 002:604 JLINK_SetBPEx(Addr = 0x08005618, Type = 0x02) returns 0x00000001 (0000ms, 1768ms total) 03-00000000-00-00002603-0044: Setting breakpoint @ address 0x08005618, Size = 2, BPHandle = 0x0001 02-00000000-00-00002603-006A: TBA7FC700 002:604 JLINK_SetBPEx(Addr = 0x08005734, Type = 0x02) returns 0x00000002 (0000ms, 1768ms total) 03-00000000-00-00002603-0044: Setting breakpoint @ address 0x08005734, Size = 2, BPHandle = 0x0002 03-00000000-00-00002604-0016: Starting target CPU... 02-00000000-00-00002604-0047: TBA7FC700 002:605 JLINK_IsHalted() returns TRUE (0000ms, 1768ms total) 02-00000000-00-00002614-01CF: TBA7FC700 002:605 JLINK_GoEx(MaxEmulInsts = -1, Flags = 0x00) -- CPU_WriteMem(4 bytes @ 0xE0002000) -- CPU_WriteMem(4 bytes @ 0xE0002000) -- CPU_ReadMem(4 bytes @ 0xE0001000) -- CPU_WriteMem(4 bytes @ 0xE0002008) -- CPU_WriteMem(4 bytes @ 0xE000200C) -- CPU_WriteMem(4 bytes @ 0xE0002010) -- CPU_WriteMem(4 bytes @ 0xE0002014) -- CPU_WriteMem(4 bytes @ 0xE0002018) -- CPU_WriteMem(4 bytes @ 0xE000201C) -- CPU_WriteMem(4 bytes @ 0xE0001004) (0010ms, 1778ms total) 02-00000000-00-00002616-0048: TBA7FC700 002:615 JLINK_IsHalted() returns FALSE (0002ms, 1780ms total) 02-00000000-00-00002639-0048: TBA7FC700 002:638 JLINK_IsHalted() returns FALSE (0002ms, 1780ms total) 02-00000000-00-00002661-0048: TBA7FC700 002:661 JLINK_IsHalted() returns FALSE (0001ms, 1779ms total) 02-00000000-00-00002683-0048: TBA7FC700 002:683 JLINK_IsHalted() returns FALSE (0001ms, 1779ms total) 02-00000000-00-00002709-0047: TBA7FC700 002:705 JLINK_IsHalted() returns TRUE (0005ms, 1783ms total) 02-00000000-00-00002710-0054: TBA7FC700 002:711 JLINK_ReadReg(R15 (PC)) returns 0x08005618 (0000ms, 1778ms total) 02-00000000-00-00002711-006E: TBA7FC700 002:711 JLINK_GetMOEs(...) -- CPU_ReadMem(4 bytes @ 0xE000ED30) returns 0x01 (0001ms, 1779ms total) 02-00000000-00-00002712-00A4: TBA7FC700 002:713 JLINK_ReadMemU16(0x08005618, 0x0001 Items, ...) -- Read from flash cache (2 bytes @ 0x08005618) - Data: 08 B5 returns 0x01 (0000ms, 1780ms total) 03-00000000-00-00002712-002A: ...Breakpoint reached @ address 0x08005618 03-00000000-00-00002732-0015: Reading all registers 02-00000000-00-00002732-004E: TBA7FC700 002:733 JLINK_ReadReg(R0) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-004E: TBA7FC700 002:733 JLINK_ReadReg(R1) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-004E: TBA7FC700 002:733 JLINK_ReadReg(R2) returns 0x00000001 (0000ms, 1780ms total) 02-00000000-00-00002732-004E: TBA7FC700 002:733 JLINK_ReadReg(R3) returns 0x2000BC94 (0000ms, 1780ms total) 02-00000000-00-00002732-004E: TBA7FC700 002:733 JLINK_ReadReg(R4) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-004E: TBA7FC700 002:733 JLINK_ReadReg(R5) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-004E: TBA7FC700 002:733 JLINK_ReadReg(R6) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-004E: TBA7FC700 002:733 JLINK_ReadReg(R7) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-004E: TBA7FC700 002:733 JLINK_ReadReg(R8) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-004E: TBA7FC700 002:733 JLINK_ReadReg(R9) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-004F: TBA7FC700 002:733 JLINK_ReadReg(R10) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-004F: TBA7FC700 002:733 JLINK_ReadReg(R11) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-004F: TBA7FC700 002:733 JLINK_ReadReg(R12) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-0054: TBA7FC700 002:733 JLINK_ReadReg(R13 (SP)) returns 0x20018000 (0000ms, 1780ms total) 02-00000000-00-00002732-004F: TBA7FC700 002:733 JLINK_ReadReg(R14) returns 0x0801133F (0000ms, 1780ms total) 02-00000000-00-00002732-0054: TBA7FC700 002:733 JLINK_ReadReg(R15 (PC)) returns 0x08005618 (0000ms, 1780ms total) 02-00000000-00-00002732-0050: TBA7FC700 002:733 JLINK_ReadReg(XPSR) returns 0x61000000 (0000ms, 1780ms total) 02-00000000-00-00002732-004F: TBA7FC700 002:733 JLINK_ReadReg(MSP) returns 0x20018000 (0000ms, 1780ms total) 02-00000000-00-00002732-004F: TBA7FC700 002:733 JLINK_ReadReg(PSP) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-0053: TBA7FC700 002:733 JLINK_ReadReg(PRIMASK) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-0053: TBA7FC700 002:733 JLINK_ReadReg(BASEPRI) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-0055: TBA7FC700 002:733 JLINK_ReadReg(FAULTMASK) returns 0x00000000 (0000ms, 1780ms total) 02-00000000-00-00002732-0053: TBA7FC700 002:733 JLINK_ReadReg(CONTROL) returns 0x04000000 (0000ms, 1780ms total) 02-00000000-00-00002739-0051: TBA7FC700 002:733 JLINK_ReadReg(FPSCR) returns 0x20000000 (0007ms, 1787ms total) 02-00000000-00-00002740-0050: TBA7FC700 002:741 JLINK_ReadReg(FPS0) returns 0x3FB504F3 (0000ms, 1788ms total) 02-00000000-00-00002740-0050: TBA7FC700 002:741 JLINK_ReadReg(FPS1) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0050: TBA7FC700 002:741 JLINK_ReadReg(FPS2) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0050: TBA7FC700 002:741 JLINK_ReadReg(FPS3) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0050: TBA7FC700 002:741 JLINK_ReadReg(FPS4) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0050: TBA7FC700 002:741 JLINK_ReadReg(FPS5) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0050: TBA7FC700 002:741 JLINK_ReadReg(FPS6) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0050: TBA7FC700 002:741 JLINK_ReadReg(FPS7) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0050: TBA7FC700 002:741 JLINK_ReadReg(FPS8) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0050: TBA7FC700 002:741 JLINK_ReadReg(FPS9) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS10) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS11) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS12) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS13) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS14) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS15) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS16) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS17) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS18) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS19) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS20) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS21) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS22) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS23) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS24) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS25) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS26) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS27) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS28) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS29) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS30) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-0051: TBA7FC700 002:741 JLINK_ReadReg(FPS31) returns 0x00000000 (0000ms, 1788ms total) 02-00000000-00-00002740-00A8: TBA7FC700 002:741 JLINK_ReadMem (0x08005618, 0x0004 Bytes, ...) -- Read from flash cache (4 bytes @ 0x08005618) - Data: 08 B5 73 4B returns 0x00 (0000ms, 1788ms total) 03-00000000-00-00002740-0035: Read 4 bytes @ address 0x08005618 (Data = 0x4B73B508) 03-00000000-00-00002742-0032: Removing breakpoint @ address 0x08005618, Size = 2 02-00000000-00-00002742-005B: TBA7FC700 002:743 JLINK_ClrBPEx(BPHandle = 0x00000001) returns 0x00 (0000ms, 1788ms total) 03-00000000-00-00002745-0032: Removing breakpoint @ address 0x08005734, Size = 2 02-00000000-00-00002746-005B: TBA7FC700 002:747 JLINK_ClrBPEx(BPHandle = 0x00000002) returns 0x00 (0000ms, 1788ms total) 02-00000000-00-00004793-004D: TC36F1700 004:792 JLINK_GetHWStatus(...) returns 0x00 (0002ms, 1790ms total) 02-00000000-00-00006997-004D: TC36F1700 006:996 JLINK_GetHWStatus(...) returns 0x00 (0002ms, 1793ms total) 02-00000000-00-00008924-006A: TBA7FC700 008:925 JLINK_SetBPEx(Addr = 0x08005734, Type = 0x02) returns 0x00000003 (0000ms, 1794ms total) 03-00000000-00-00008924-0044: Setting breakpoint @ address 0x08005734, Size = 2, BPHandle = 0x0003 03-00000000-00-00008924-0016: Starting target CPU... 02-00000000-00-00008926-0047: TBA7FC700 008:925 JLINK_IsHalted() returns TRUE (0002ms, 1796ms total) 02-00000000-00-00008933-0111: TBA7FC700 008:927 JLINK_GoEx(MaxEmulInsts = -1, Flags = 0x00) -- CPU_WriteMem(4 bytes @ 0xE0002000) -- CPU_ReadMem(4 bytes @ 0xE0001000) -- CPU_WriteMem(4 bytes @ 0xE000ED30) -- CPU_WriteMem(4 bytes @ 0xE0002008) -- CPU_WriteMem(4 bytes @ 0xE000200C) (0007ms, 1801ms total) 02-00000000-00-00008935-0048: TBA7FC700 008:934 JLINK_IsHalted() returns FALSE (0002ms, 1803ms total) 02-00000000-00-00008957-0048: TBA7FC700 008:957 JLINK_IsHalted() returns FALSE (0001ms, 1802ms total) 02-00000000-00-00008980-0048: TBA7FC700 008:979 JLINK_IsHalted() returns FALSE (0002ms, 1803ms total) 02-00000000-00-00009003-0048: TBA7FC700 009:002 JLINK_IsHalted() returns FALSE (0002ms, 1803ms total) 02-00000000-00-00009025-0048: TBA7FC700 009:025 JLINK_IsHalted() returns FALSE (0001ms, 1802ms total) 02-00000000-00-00009048-0048: TBA7FC700 009:047 JLINK_IsHalted() returns FALSE (0002ms, 1803ms total) 02-00000000-00-00009075-0047: TBA7FC700 009:070 JLINK_IsHalted() returns TRUE (0006ms, 1807ms total) 02-00000000-00-00009076-0054: TBA7FC700 009:077 JLINK_ReadReg(R15 (PC)) returns 0x08005734 (0000ms, 1801ms total) 02-00000000-00-00009078-006E: TBA7FC700 009:077 JLINK_GetMOEs(...) -- CPU_ReadMem(4 bytes @ 0xE000ED30) returns 0x01 (0001ms, 1802ms total) 02-00000000-00-00009078-00A4: TBA7FC700 009:079 JLINK_ReadMemU16(0x08005734, 0x0001 Items, ...) -- Read from flash cache (2 bytes @ 0x08005734) - Data: 2E 48 returns 0x01 (0000ms, 1803ms total) 03-00000000-00-00009078-002A: ...Breakpoint reached @ address 0x08005734 03-00000000-00-00009098-0015: Reading all registers 02-00000000-00-00009098-004E: TBA7FC700 009:099 JLINK_ReadReg(R0) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-004E: TBA7FC700 009:099 JLINK_ReadReg(R1) returns 0x08005615 (0000ms, 1803ms total) 02-00000000-00-00009098-004E: TBA7FC700 009:099 JLINK_ReadReg(R2) returns 0x00000004 (0000ms, 1803ms total) 02-00000000-00-00009098-004E: TBA7FC700 009:099 JLINK_ReadReg(R3) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-004E: TBA7FC700 009:099 JLINK_ReadReg(R4) returns 0x20003924 (0000ms, 1803ms total) 02-00000000-00-00009098-004E: TBA7FC700 009:099 JLINK_ReadReg(R5) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-004E: TBA7FC700 009:099 JLINK_ReadReg(R6) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-004E: TBA7FC700 009:099 JLINK_ReadReg(R7) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-004E: TBA7FC700 009:099 JLINK_ReadReg(R8) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-004E: TBA7FC700 009:099 JLINK_ReadReg(R9) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-004F: TBA7FC700 009:099 JLINK_ReadReg(R10) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-004F: TBA7FC700 009:099 JLINK_ReadReg(R11) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-004F: TBA7FC700 009:099 JLINK_ReadReg(R12) returns 0x2000A80C (0000ms, 1803ms total) 02-00000000-00-00009098-0054: TBA7FC700 009:099 JLINK_ReadReg(R13 (SP)) returns 0x20017FF8 (0000ms, 1803ms total) 02-00000000-00-00009098-004F: TBA7FC700 009:099 JLINK_ReadReg(R14) returns 0x0800568B (0000ms, 1803ms total) 02-00000000-00-00009098-0054: TBA7FC700 009:099 JLINK_ReadReg(R15 (PC)) returns 0x08005734 (0000ms, 1803ms total) 02-00000000-00-00009098-0050: TBA7FC700 009:099 JLINK_ReadReg(XPSR) returns 0x41000000 (0000ms, 1803ms total) 02-00000000-00-00009098-004F: TBA7FC700 009:099 JLINK_ReadReg(MSP) returns 0x20017FF8 (0000ms, 1803ms total) 02-00000000-00-00009098-004F: TBA7FC700 009:099 JLINK_ReadReg(PSP) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-0053: TBA7FC700 009:099 JLINK_ReadReg(PRIMASK) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-0053: TBA7FC700 009:099 JLINK_ReadReg(BASEPRI) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-0055: TBA7FC700 009:099 JLINK_ReadReg(FAULTMASK) returns 0x00000000 (0000ms, 1803ms total) 02-00000000-00-00009098-0053: TBA7FC700 009:099 JLINK_ReadReg(CONTROL) returns 0x04000000 (0000ms, 1803ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:099 JLINK_ReadReg(FPSCR) returns 0x20000010 (0008ms, 1811ms total) 02-00000000-00-00009106-0050: TBA7FC700 009:107 JLINK_ReadReg(FPS0) returns 0xFEFA39EF (0000ms, 1811ms total) 02-00000000-00-00009106-0050: TBA7FC700 009:107 JLINK_ReadReg(FPS1) returns 0x3FE62E42 (0000ms, 1811ms total) 02-00000000-00-00009106-0050: TBA7FC700 009:107 JLINK_ReadReg(FPS2) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0050: TBA7FC700 009:107 JLINK_ReadReg(FPS3) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0050: TBA7FC700 009:107 JLINK_ReadReg(FPS4) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0050: TBA7FC700 009:107 JLINK_ReadReg(FPS5) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0050: TBA7FC700 009:107 JLINK_ReadReg(FPS6) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0050: TBA7FC700 009:107 JLINK_ReadReg(FPS7) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0050: TBA7FC700 009:107 JLINK_ReadReg(FPS8) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0050: TBA7FC700 009:107 JLINK_ReadReg(FPS9) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS10) returns 0x4E2AAAAA (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS11) returns 0x3F000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS12) returns 0x4E2AAAAA (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS13) returns 0x3F030E04 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS14) returns 0x48000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS15) returns 0x47830E04 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS16) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS17) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS18) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS19) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS20) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS21) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS22) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS23) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS24) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS25) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS26) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS27) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS28) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS29) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS30) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-0051: TBA7FC700 009:107 JLINK_ReadReg(FPS31) returns 0x00000000 (0000ms, 1811ms total) 02-00000000-00-00009106-00A8: TBA7FC700 009:107 JLINK_ReadMem (0x08005734, 0x0004 Bytes, ...) -- Read from flash cache (4 bytes @ 0x08005734) - Data: 2E 48 FE F7 returns 0x00 (0000ms, 1811ms total) 03-00000000-00-00009106-0035: Read 4 bytes @ address 0x08005734 (Data = 0xF7FE482E) 03-00000000-00-00009107-0032: Removing breakpoint @ address 0x08005734, Size = 2 02-00000000-00-00009107-005B: TBA7FC700 009:108 JLINK_ClrBPEx(BPHandle = 0x00000003) returns 0x00 (0000ms, 1811ms total) 02-00000000-00-00009202-004D: TC36F1700 009:199 JLINK_GetHWStatus(...) returns 0x00 (0003ms, 1814ms total) 02-00000000-00-00011403-004D: TC36F1700 011:403 JLINK_GetHWStatus(...) returns 0x00 (0001ms, 1816ms total) 03-00000000-00-00012641-0019: Performing single step... 02-00000000-00-00012659-016B: TBA7FC700 012:649 JLINK_Step() -- Read from flash cache (2 bytes @ 0x08005734) -- CPU_ReadMem(4 bytes @ 0xE000ED18) -- CPU_WriteMem(4 bytes @ 0xE000ED18) -- CPU_ReadMem(4 bytes @ 0xE000ED18) -- CPU_WriteMem(4 bytes @ 0xE000ED18) -- CPU_ReadMem(4 bytes @ 0xE0001004) -- Read from flash cache (4 bytes @ 0x080057F0) -- Simulated returns 0x00 (0011ms, 1828ms total) 02-00000000-00-00012660-0047: TBA7FC700 012:661 JLINK_IsHalted() returns TRUE (0000ms, 1829ms total) 02-00000000-00-00012660-0054: TBA7FC700 012:661 JLINK_ReadReg(R15 (PC)) returns 0x08005736 (0000ms, 1829ms total) 02-00000000-00-00012660-0049: TBA7FC700 012:661 JLINK_GetMOEs(...) returns 0x01 (0000ms, 1829ms total) 02-00000000-00-00012660-00A4: TBA7FC700 012:661 JLINK_ReadMemU16(0x08005736, 0x0001 Items, ...) -- Read from flash cache (2 bytes @ 0x08005736) - Data: FE F7 returns 0x01 (0000ms, 1829ms total) 03-00000000-00-00012660-002A: ...Breakpoint reached @ address 0x08005736 03-00000000-00-00012660-0015: Reading all registers 02-00000000-00-00012660-004E: TBA7FC700 012:661 JLINK_ReadReg(R0) returns 0x20003924 (0000ms, 1829ms total) 02-00000000-00-00012660-004E: TBA7FC700 012:661 JLINK_ReadReg(R1) returns 0x08005615 (0000ms, 1829ms total) 02-00000000-00-00012660-004E: TBA7FC700 012:661 JLINK_ReadReg(R2) returns 0x00000004 (0000ms, 1829ms total) 02-00000000-00-00012660-004E: TBA7FC700 012:661 JLINK_ReadReg(R3) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-004E: TBA7FC700 012:661 JLINK_ReadReg(R4) returns 0x20003924 (0000ms, 1829ms total) 02-00000000-00-00012660-004E: TBA7FC700 012:661 JLINK_ReadReg(R5) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-004E: TBA7FC700 012:661 JLINK_ReadReg(R6) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-004E: TBA7FC700 012:661 JLINK_ReadReg(R7) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-004E: TBA7FC700 012:661 JLINK_ReadReg(R8) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-004E: TBA7FC700 012:661 JLINK_ReadReg(R9) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-004F: TBA7FC700 012:661 JLINK_ReadReg(R10) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-004F: TBA7FC700 012:661 JLINK_ReadReg(R11) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-004F: TBA7FC700 012:661 JLINK_ReadReg(R12) returns 0x2000A80C (0000ms, 1829ms total) 02-00000000-00-00012660-0054: TBA7FC700 012:661 JLINK_ReadReg(R13 (SP)) returns 0x20017FF8 (0000ms, 1829ms total) 02-00000000-00-00012660-004F: TBA7FC700 012:661 JLINK_ReadReg(R14) returns 0x0800568B (0000ms, 1829ms total) 02-00000000-00-00012660-0054: TBA7FC700 012:661 JLINK_ReadReg(R15 (PC)) returns 0x08005736 (0000ms, 1829ms total) 02-00000000-00-00012660-0050: TBA7FC700 012:661 JLINK_ReadReg(XPSR) returns 0x41000000 (0000ms, 1829ms total) 02-00000000-00-00012660-004F: TBA7FC700 012:661 JLINK_ReadReg(MSP) returns 0x20017FF8 (0000ms, 1829ms total) 02-00000000-00-00012660-004F: TBA7FC700 012:661 JLINK_ReadReg(PSP) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0053: TBA7FC700 012:661 JLINK_ReadReg(PRIMASK) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0053: TBA7FC700 012:661 JLINK_ReadReg(BASEPRI) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0055: TBA7FC700 012:661 JLINK_ReadReg(FAULTMASK) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0053: TBA7FC700 012:661 JLINK_ReadReg(CONTROL) returns 0x04000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0051: TBA7FC700 012:661 JLINK_ReadReg(FPSCR) returns 0x20000010 (0000ms, 1829ms total) 02-00000000-00-00012660-0050: TBA7FC700 012:661 JLINK_ReadReg(FPS0) returns 0xFEFA39EF (0000ms, 1829ms total) 02-00000000-00-00012660-0050: TBA7FC700 012:661 JLINK_ReadReg(FPS1) returns 0x3FE62E42 (0000ms, 1829ms total) 02-00000000-00-00012660-0050: TBA7FC700 012:661 JLINK_ReadReg(FPS2) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0050: TBA7FC700 012:661 JLINK_ReadReg(FPS3) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0050: TBA7FC700 012:661 JLINK_ReadReg(FPS4) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0050: TBA7FC700 012:661 JLINK_ReadReg(FPS5) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0050: TBA7FC700 012:661 JLINK_ReadReg(FPS6) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0050: TBA7FC700 012:661 JLINK_ReadReg(FPS7) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0050: TBA7FC700 012:661 JLINK_ReadReg(FPS8) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0050: TBA7FC700 012:661 JLINK_ReadReg(FPS9) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0051: TBA7FC700 012:661 JLINK_ReadReg(FPS10) returns 0x4E2AAAAA (0000ms, 1829ms total) 02-00000000-00-00012660-0051: TBA7FC700 012:661 JLINK_ReadReg(FPS11) returns 0x3F000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0051: TBA7FC700 012:661 JLINK_ReadReg(FPS12) returns 0x4E2AAAAA (0000ms, 1829ms total) 02-00000000-00-00012660-0051: TBA7FC700 012:661 JLINK_ReadReg(FPS13) returns 0x3F030E04 (0000ms, 1829ms total) 02-00000000-00-00012660-0051: TBA7FC700 012:661 JLINK_ReadReg(FPS14) returns 0x48000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0051: TBA7FC700 012:661 JLINK_ReadReg(FPS15) returns 0x47830E04 (0000ms, 1829ms total) 02-00000000-00-00012660-0051: TBA7FC700 012:661 JLINK_ReadReg(FPS16) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0051: TBA7FC700 012:661 JLINK_ReadReg(FPS17) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0051: TBA7FC700 012:661 JLINK_ReadReg(FPS18) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0051: TBA7FC700 012:661 JLINK_ReadReg(FPS19) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012660-0051: TBA7FC700 012:661 JLINK_ReadReg(FPS20) returns 0x00000000 (0000ms, 1829ms total) 02-00000000-00-00012661-0051: TBA7FC700 012:662 JLINK_ReadReg(FPS21) returns 0x00000000 (0000ms, 1830ms total) 02-00000000-00-00012661-0051: TBA7FC700 012:662 JLINK_ReadReg(FPS22) returns 0x00000000 (0000ms, 1830ms total) 02-00000000-00-00012661-0051: TBA7FC700 012:662 JLINK_ReadReg(FPS23) returns 0x00000000 (0000ms, 1830ms total) 02-00000000-00-00012661-0051: TBA7FC700 012:662 JLINK_ReadReg(FPS24) returns 0x00000000 (0000ms, 1830ms total) 02-00000000-00-00012661-0051: TBA7FC700 012:662 JLINK_ReadReg(FPS25) returns 0x00000000 (0000ms, 1830ms total) 02-00000000-00-00012661-0051: TBA7FC700 012:662 JLINK_ReadReg(FPS26) returns 0x00000000 (0000ms, 1830ms total) 02-00000000-00-00012661-0051: TBA7FC700 012:662 JLINK_ReadReg(FPS27) returns 0x00000000 (0000ms, 1830ms total) 02-00000000-00-00012661-0051: TBA7FC700 012:662 JLINK_ReadReg(FPS28) returns 0x00000000 (0000ms, 1830ms total) 02-00000000-00-00012661-0051: TBA7FC700 012:662 JLINK_ReadReg(FPS29) returns 0x00000000 (0000ms, 1830ms total) 02-00000000-00-00012661-0051: TBA7FC700 012:662 JLINK_ReadReg(FPS30) returns 0x00000000 (0000ms, 1830ms total) 02-00000000-00-00012661-0051: TBA7FC700 012:662 JLINK_ReadReg(FPS31) returns 0x00000000 (0000ms, 1830ms total) 02-00000000-00-00012661-00A8: TBA7FC700 012:662 JLINK_ReadMem (0x08005736, 0x0004 Bytes, ...) -- Read from flash cache (4 bytes @ 0x08005736) - Data: FE F7 97 FF returns 0x00 (0000ms, 1830ms total) 03-00000000-00-00012661-0035: Read 4 bytes @ address 0x08005736 (Data = 0xFF97F7FE) 02-00000000-00-00012661-006A: TBA7FC700 012:662 JLINK_SetBPEx(Addr = 0x08005734, Type = 0x02) returns 0x00000004 (0000ms, 1830ms total) 03-00000000-00-00012661-0044: Setting breakpoint @ address 0x08005734, Size = 2, BPHandle = 0x0004 03-00000000-00-00012661-0016: Starting target CPU... 02-00000000-00-00012661-0047: TBA7FC700 012:662 JLINK_IsHalted() returns TRUE (0000ms, 1830ms total) 02-00000000-00-00012672-00EB: TBA7FC700 012:662 JLINK_GoEx(MaxEmulInsts = -1, Flags = 0x00) -- CPU_WriteMem(4 bytes @ 0xE0002000) -- CPU_ReadMem(4 bytes @ 0xE0001000) -- CPU_WriteMem(4 bytes @ 0xE000ED30) -- CPU_WriteMem(4 bytes @ 0xE0001004) (0011ms, 1841ms total) 02-00000000-00-00012678-0047: TBA7FC700 012:674 JLINK_IsHalted() returns TRUE (0005ms, 1847ms total) 02-00000000-00-00012678-0054: TBA7FC700 012:679 JLINK_ReadReg(R15 (PC)) returns 0x08005734 (0000ms, 1842ms total) 02-00000000-00-00012680-006E: TBA7FC700 012:679 JLINK_GetMOEs(...) -- CPU_ReadMem(4 bytes @ 0xE000ED30) returns 0x01 (0002ms, 1844ms total) 02-00000000-00-00012681-00A4: TBA7FC700 012:681 JLINK_ReadMemU16(0x08005734, 0x0001 Items, ...) -- Read from flash cache (2 bytes @ 0x08005734) - Data: 2E 48 returns 0x01 (0001ms, 1845ms total) 03-00000000-00-00012681-002A: ...Breakpoint reached @ address 0x08005734 03-00000000-00-00012701-0015: Reading all registers 02-00000000-00-00012701-004E: TBA7FC700 012:702 JLINK_ReadReg(R0) returns 0x20005440 (0000ms, 1845ms total) 02-00000000-00-00012701-004E: TBA7FC700 012:702 JLINK_ReadReg(R1) returns 0x08005615 (0000ms, 1845ms total) 02-00000000-00-00012701-004E: TBA7FC700 012:702 JLINK_ReadReg(R2) returns 0x00000000 (0000ms, 1845ms total) 02-00000000-00-00012701-004E: TBA7FC700 012:702 JLINK_ReadReg(R3) returns 0x00000001 (0000ms, 1845ms total) 02-00000000-00-00012701-004E: TBA7FC700 012:702 JLINK_ReadReg(R4) returns 0x20003924 (0000ms, 1845ms total) 02-00000000-00-00012701-004E: TBA7FC700 012:702 JLINK_ReadReg(R5) returns 0x00000000 (0000ms, 1845ms total) 02-00000000-00-00012701-004E: TBA7FC700 012:702 JLINK_ReadReg(R6) returns 0x00000000 (0000ms, 1845ms total) 02-00000000-00-00012701-004E: TBA7FC700 012:702 JLINK_ReadReg(R7) returns 0x00000000 (0000ms, 1845ms total) 02-00000000-00-00012701-004E: TBA7FC700 012:702 JLINK_ReadReg(R8) returns 0x00000000 (0000ms, 1845ms total) 02-00000000-00-00012701-004E: TBA7FC700 012:702 JLINK_ReadReg(R9) returns 0x00000000 (0000ms, 1845ms total) 02-00000000-00-00012701-004F: TBA7FC700 012:702 JLINK_ReadReg(R10) returns 0x00000000 (0000ms, 1845ms total) 02-00000000-00-00012701-004F: TBA7FC700 012:702 JLINK_ReadReg(R11) returns 0x00000000 (0000ms, 1845ms total) 02-00000000-00-00012701-004F: TBA7FC700 012:702 JLINK_ReadReg(R12) returns 0x2000A80C (0000ms, 1845ms total) 02-00000000-00-00012701-0054: TBA7FC700 012:702 JLINK_ReadReg(R13 (SP)) returns 0x20017FF8 (0000ms, 1845ms total) 02-00000000-00-00012701-004F: TBA7FC700 012:702 JLINK_ReadReg(R14) returns 0x0800572B (0000ms, 1845ms total) 02-00000000-00-00012701-0054: TBA7FC700 012:702 JLINK_ReadReg(R15 (PC)) returns 0x08005734 (0000ms, 1845ms total) 02-00000000-00-00012701-0050: TBA7FC700 012:702 JLINK_ReadReg(XPSR) returns 0x21000000 (0000ms, 1845ms total) 02-00000000-00-00012701-004F: TBA7FC700 012:702 JLINK_ReadReg(MSP) returns 0x20017FF8 (0000ms, 1845ms total) 02-00000000-00-00012701-004F: TBA7FC700 012:702 JLINK_ReadReg(PSP) returns 0x00000000 (0000ms, 1845ms total) 02-00000000-00-00012701-0053: TBA7FC700 012:702 JLINK_ReadReg(PRIMASK) returns 0x00000000 (0000ms, 1845ms total) 02-00000000-00-00012701-0053: TBA7FC700 012:702 JLINK_ReadReg(BASEPRI) returns 0x00000000 (0000ms, 1845ms total) 02-00000000-00-00012701-0055: TBA7FC700 012:702 JLINK_ReadReg(FAULTMASK) returns 0x00000000 (0000ms, 1845ms total) 02-00000000-00-00012701-0053: TBA7FC700 012:702 JLINK_ReadReg(CONTROL) returns 0x04000000 (0000ms, 1845ms total) 02-00000000-00-00012707-0051: TBA7FC700 012:702 JLINK_ReadReg(FPSCR) returns 0x20000010 (0006ms, 1851ms total) 02-00000000-00-00012707-0050: TBA7FC700 012:708 JLINK_ReadReg(FPS0) returns 0xFEFA39EF (0000ms, 1851ms total) 02-00000000-00-00012707-0050: TBA7FC700 012:708 JLINK_ReadReg(FPS1) returns 0x3FE62E42 (0000ms, 1851ms total) 02-00000000-00-00012707-0050: TBA7FC700 012:708 JLINK_ReadReg(FPS2) returns 0x00000000 (0000ms, 1851ms total) 02-00000000-00-00012707-0050: TBA7FC700 012:708 JLINK_ReadReg(FPS3) returns 0x00000000 (0000ms, 1851ms total) 02-00000000-00-00012708-0050: TBA7FC700 012:708 JLINK_ReadReg(FPS4) returns 0x00000000 (0000ms, 1851ms total) 02-00000000-00-00012708-0050: TBA7FC700 012:709 JLINK_ReadReg(FPS5) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0050: TBA7FC700 012:709 JLINK_ReadReg(FPS6) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0050: TBA7FC700 012:709 JLINK_ReadReg(FPS7) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0050: TBA7FC700 012:709 JLINK_ReadReg(FPS8) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0050: TBA7FC700 012:709 JLINK_ReadReg(FPS9) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS10) returns 0x4E2AAAAA (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS11) returns 0x3F000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS12) returns 0x4E2AAAAA (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS13) returns 0x3F030E04 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS14) returns 0x48000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS15) returns 0x47830E04 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS16) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS17) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS18) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS19) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS20) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS21) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS22) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS23) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS24) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS25) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS26) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS27) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS28) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS29) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS30) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-0051: TBA7FC700 012:709 JLINK_ReadReg(FPS31) returns 0x00000000 (0000ms, 1852ms total) 02-00000000-00-00012708-00A8: TBA7FC700 012:709 JLINK_ReadMem (0x08005734, 0x0004 Bytes, ...) -- Read from flash cache (4 bytes @ 0x08005734) - Data: 2E 48 FE F7 returns 0x00 (0000ms, 1852ms total) 03-00000000-00-00012708-0035: Read 4 bytes @ address 0x08005734 (Data = 0xF7FE482E) 03-00000000-00-00012709-0032: Removing breakpoint @ address 0x08005734, Size = 2 02-00000000-00-00012709-005B: TBA7FC700 012:710 JLINK_ClrBPEx(BPHandle = 0x00000004) returns 0x00 (0000ms, 1852ms total) 02-00000000-00-00013605-004D: TC36F1700 013:605 JLINK_GetHWStatus(...) returns 0x00 (0001ms, 1853ms total) 03-00000000-00-00015375-0016: Starting target CPU... 02-00000000-00-00015377-0047: TBA7FC700 015:376 JLINK_IsHalted() returns TRUE (0002ms, 1856ms total) 02-00000000-00-00015385-00C5: TBA7FC700 015:379 JLINK_GoEx(MaxEmulInsts = -1, Flags = 0x00) -- CPU_ReadMem(4 bytes @ 0xE0001000) -- CPU_WriteMem(4 bytes @ 0xE000ED30) -- CPU_WriteMem(4 bytes @ 0xE0002008) (0006ms, 1860ms total) 02-00000000-00-00015386-0048: TBA7FC700 015:386 JLINK_IsHalted() returns FALSE (0001ms, 1862ms total) 02-00000000-00-00015409-0048: TBA7FC700 015:408 JLINK_IsHalted() returns FALSE (0002ms, 1863ms total) 02-00000000-00-00015432-0048: TBA7FC700 015:431 JLINK_IsHalted() returns FALSE (0002ms, 1863ms total) 02-00000000-00-00015454-0048: TBA7FC700 015:454 JLINK_IsHalted() returns FALSE (0001ms, 1862ms total) 02-00000000-00-00015478-0048: TBA7FC700 015:476 JLINK_IsHalted() returns FALSE (0003ms, 1864ms total) 02-00000000-00-00015499-0048: TBA7FC700 015:499 JLINK_IsHalted() returns FALSE (0001ms, 1862ms total) 02-00000000-00-00015521-0048: TBA7FC700 015:521 JLINK_IsHalted() returns FALSE (0001ms, 1862ms total) 02-00000000-00-00015543-0048: TBA7FC700 015:543 JLINK_IsHalted() returns FALSE (0001ms, 1862ms total) 02-00000000-00-00015565-0048: TBA7FC700 015:565 JLINK_IsHalted() returns FALSE (0001ms, 1862ms total) 02-00000000-00-00015588-0048: TBA7FC700 015:587 JLINK_IsHalted() returns FALSE (0002ms, 1863ms total) 02-00000000-00-00015611-0048: TBA7FC700 015:610 JLINK_IsHalted() returns FALSE (0002ms, 1863ms total) 02-00000000-00-00015634-0048: TBA7FC700 015:633 JLINK_IsHalted() returns FALSE (0002ms, 1863ms total) 02-00000000-00-00015657-0048: TBA7FC700 015:656 JLINK_IsHalted() returns FALSE (0002ms, 1863ms total) 02-00000000-00-00015680-0048: TBA7FC700 015:679 JLINK_IsHalted() returns FALSE (0002ms, 1863ms total) 02-00000000-00-00015703-0048: TBA7FC700 015:702 JLINK_IsHalted() returns FALSE (0002ms, 1863ms total) 02-00000000-00-00015726-0048: TBA7FC700 015:725 JLINK_IsHalted() returns FALSE (0002ms, 1863ms total) 02-00000000-00-00015748-0048: TBA7FC700 015:747 JLINK_IsHalted() returns FALSE (0002ms, 1863ms total) 02-00000000-00-00015771-0048: TBA7FC700 015:770 JLINK_IsHalted() returns FALSE (0002ms, 1863ms total) 02-00000000-00-00015793-0048: TBA7FC700 015:793 JLINK_IsHalted() returns FALSE (0001ms, 1862ms total) 02-00000000-00-00015809-004D: TC36F1700 015:807 JLINK_GetHWStatus(...) returns 0x00 (0003ms, 1864ms total) 02-00000000-00-00015815-0048: TBA7FC700 015:815 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00015838-0048: TBA7FC700 015:837 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00015860-0048: TBA7FC700 015:860 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00015882-0048: TBA7FC700 015:882 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00015904-0048: TBA7FC700 015:904 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00015926-0048: TBA7FC700 015:925 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00015950-0048: TBA7FC700 015:948 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00015972-0048: TBA7FC700 015:971 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00015995-0048: TBA7FC700 015:994 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016018-0048: TBA7FC700 016:017 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016041-0048: TBA7FC700 016:040 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016064-0048: TBA7FC700 016:063 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016087-0048: TBA7FC700 016:086 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016111-0048: TBA7FC700 016:109 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00016133-0048: TBA7FC700 016:132 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016156-0048: TBA7FC700 016:155 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016180-0048: TBA7FC700 016:178 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00016201-0048: TBA7FC700 016:201 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00016224-0048: TBA7FC700 016:223 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016247-0048: TBA7FC700 016:246 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016269-0048: TBA7FC700 016:269 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00016292-0048: TBA7FC700 016:291 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016314-0048: TBA7FC700 016:314 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00016339-0048: TBA7FC700 016:336 JLINK_IsHalted() returns FALSE (0004ms, 1869ms total) 02-00000000-00-00016362-0048: TBA7FC700 016:360 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00016383-0048: TBA7FC700 016:383 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00016406-0048: TBA7FC700 016:405 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016428-0048: TBA7FC700 016:427 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016450-0048: TBA7FC700 016:450 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00016474-0048: TBA7FC700 016:472 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00016496-0048: TBA7FC700 016:495 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016518-0048: TBA7FC700 016:518 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00016541-0048: TBA7FC700 016:540 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016564-0048: TBA7FC700 016:563 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016588-0048: TBA7FC700 016:586 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00016609-0048: TBA7FC700 016:609 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00016631-0048: TBA7FC700 016:631 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00016655-0048: TBA7FC700 016:653 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00016678-0048: TBA7FC700 016:676 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00016700-0048: TBA7FC700 016:699 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016724-0048: TBA7FC700 016:722 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00016747-0048: TBA7FC700 016:745 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00016770-0048: TBA7FC700 016:768 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016793-0048: TBA7FC700 016:791 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00016814-0048: TBA7FC700 016:814 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00016837-0048: TBA7FC700 016:836 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016861-0048: TBA7FC700 016:859 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00016882-0048: TBA7FC700 016:882 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00016905-0048: TBA7FC700 016:904 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016927-0048: TBA7FC700 016:927 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00016950-0048: TBA7FC700 016:949 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00016972-0048: TBA7FC700 016:972 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00016995-0048: TBA7FC700 016:994 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00017019-0048: TBA7FC700 017:017 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00017042-0048: TBA7FC700 017:040 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00017064-0048: TBA7FC700 017:063 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00017085-0048: TBA7FC700 017:086 JLINK_IsHalted() returns FALSE (0000ms, 1865ms total) 02-00000000-00-00017107-0048: TBA7FC700 017:107 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017129-0048: TBA7FC700 017:129 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017151-0048: TBA7FC700 017:151 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017173-0048: TBA7FC700 017:173 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017195-0048: TBA7FC700 017:195 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017219-0048: TBA7FC700 017:217 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00017241-0048: TBA7FC700 017:240 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017263-0048: TBA7FC700 017:262 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00017286-0048: TBA7FC700 017:285 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00017307-0048: TBA7FC700 017:307 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017329-0048: TBA7FC700 017:329 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017353-0048: TBA7FC700 017:351 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00017375-0048: TBA7FC700 017:374 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00017396-0048: TBA7FC700 017:396 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017418-0048: TBA7FC700 017:418 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017444-0048: TBA7FC700 017:440 JLINK_IsHalted() returns FALSE (0005ms, 1870ms total) 02-00000000-00-00017466-0048: TBA7FC700 017:465 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00017489-0048: TBA7FC700 017:488 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00017511-0048: TBA7FC700 017:511 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017533-0048: TBA7FC700 017:533 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017556-0048: TBA7FC700 017:555 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00017578-0048: TBA7FC700 017:578 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017600-0048: TBA7FC700 017:600 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017623-0048: TBA7FC700 017:622 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00017645-0048: TBA7FC700 017:645 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017667-0048: TBA7FC700 017:667 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017689-0048: TBA7FC700 017:689 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017712-0048: TBA7FC700 017:711 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00017736-0048: TBA7FC700 017:734 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00017757-0048: TBA7FC700 017:757 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017779-0048: TBA7FC700 017:779 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017802-0048: TBA7FC700 017:801 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00017824-0048: TBA7FC700 017:824 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017846-0048: TBA7FC700 017:846 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017868-0048: TBA7FC700 017:868 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017892-0048: TBA7FC700 017:890 JLINK_IsHalted() returns FALSE (0003ms, 1868ms total) 02-00000000-00-00017913-0048: TBA7FC700 017:913 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017936-0048: TBA7FC700 017:935 JLINK_IsHalted() returns FALSE (0002ms, 1867ms total) 02-00000000-00-00017957-0048: TBA7FC700 017:957 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00017979-0048: TBA7FC700 017:979 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00018001-0048: TBA7FC700 018:001 JLINK_IsHalted() returns FALSE (0001ms, 1866ms total) 02-00000000-00-00018011-004D: TC36F1700 018:011 JLINK_GetHWStatus(...) returns 0x00 (0001ms, 1866ms total) 02-00000000-00-00018023-0048: TBA7FC700 018:023 JLINK_IsHalted() returns FALSE (0001ms, 1868ms total) 02-00000000-00-00018045-0048: TBA7FC700 018:045 JLINK_IsHalted() returns FALSE (0001ms, 1868ms total) 02-00000000-00-00018067-0048: TBA7FC700 018:067 JLINK_IsHalted() returns FALSE (0001ms, 1868ms total) 02-00000000-00-00018090-0048: TBA7FC700 018:089 JLINK_IsHalted() returns FALSE (0002ms, 1869ms total) 02-00000000-00-00018113-0048: TBA7FC700 018:112 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018136-0048: TBA7FC700 018:135 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018158-0048: TBA7FC700 018:158 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00018181-0048: TBA7FC700 018:180 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018203-0048: TBA7FC700 018:203 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00018225-0048: TBA7FC700 018:225 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00018248-0048: TBA7FC700 018:247 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018270-0048: TBA7FC700 018:270 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00018293-0048: TBA7FC700 018:292 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018316-0048: TBA7FC700 018:315 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018339-0048: TBA7FC700 018:338 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018361-0048: TBA7FC700 018:361 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00018384-0048: TBA7FC700 018:383 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018407-0048: TBA7FC700 018:406 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018431-0048: TBA7FC700 018:429 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00018453-0048: TBA7FC700 018:452 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018477-0048: TBA7FC700 018:475 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018500-0048: TBA7FC700 018:498 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00018521-0048: TBA7FC700 018:521 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00018543-0048: TBA7FC700 018:543 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00018569-0048: TBA7FC700 018:565 JLINK_IsHalted() returns FALSE (0005ms, 1875ms total) 02-00000000-00-00018591-0048: TBA7FC700 018:590 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018615-0048: TBA7FC700 018:613 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00018638-0048: TBA7FC700 018:636 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00018659-0048: TBA7FC700 018:659 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00018682-0048: TBA7FC700 018:681 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018704-0048: TBA7FC700 018:704 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00018727-0048: TBA7FC700 018:726 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018750-0048: TBA7FC700 018:749 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018773-0048: TBA7FC700 018:772 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018796-0048: TBA7FC700 018:795 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018819-0048: TBA7FC700 018:818 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018842-0048: TBA7FC700 018:841 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018864-0048: TBA7FC700 018:864 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00018887-0048: TBA7FC700 018:886 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018911-0048: TBA7FC700 018:909 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00018933-0048: TBA7FC700 018:932 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00018955-0048: TBA7FC700 018:955 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00018978-0048: TBA7FC700 018:976 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00019001-0048: TBA7FC700 019:000 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019025-0048: TBA7FC700 019:023 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00019048-0048: TBA7FC700 019:046 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00019072-0048: TBA7FC700 019:069 JLINK_IsHalted() returns FALSE (0004ms, 1874ms total) 02-00000000-00-00019094-0048: TBA7FC700 019:093 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019118-0048: TBA7FC700 019:116 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00019141-0048: TBA7FC700 019:139 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019164-0048: TBA7FC700 019:162 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00019185-0048: TBA7FC700 019:185 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019208-0048: TBA7FC700 019:207 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019230-0048: TBA7FC700 019:230 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019252-0048: TBA7FC700 019:252 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019274-0048: TBA7FC700 019:274 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019296-0048: TBA7FC700 019:296 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019318-0048: TBA7FC700 019:318 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019340-0048: TBA7FC700 019:340 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019363-0048: TBA7FC700 019:362 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019386-0048: TBA7FC700 019:385 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019409-0048: TBA7FC700 019:408 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019432-0048: TBA7FC700 019:431 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019454-0048: TBA7FC700 019:454 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019476-0048: TBA7FC700 019:476 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019499-0048: TBA7FC700 019:498 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019522-0048: TBA7FC700 019:521 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019545-0048: TBA7FC700 019:544 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019567-0048: TBA7FC700 019:567 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019589-0048: TBA7FC700 019:589 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019612-0048: TBA7FC700 019:610 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00019634-0048: TBA7FC700 019:634 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019656-0048: TBA7FC700 019:656 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019679-0048: TBA7FC700 019:678 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019702-0048: TBA7FC700 019:701 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019725-0048: TBA7FC700 019:724 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019748-0048: TBA7FC700 019:747 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019771-0048: TBA7FC700 019:770 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019794-0048: TBA7FC700 019:793 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019816-0048: TBA7FC700 019:816 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019839-0048: TBA7FC700 019:837 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00019862-0048: TBA7FC700 019:861 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019884-0048: TBA7FC700 019:884 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019906-0048: TBA7FC700 019:906 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00019929-0048: TBA7FC700 019:927 JLINK_IsHalted() returns FALSE (0003ms, 1873ms total) 02-00000000-00-00019952-0048: TBA7FC700 019:951 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019975-0048: TBA7FC700 019:974 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00019998-0048: TBA7FC700 019:997 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00020021-0048: TBA7FC700 020:020 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00020044-0048: TBA7FC700 020:043 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00020066-0048: TBA7FC700 020:066 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00020089-0048: TBA7FC700 020:088 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00020112-0048: TBA7FC700 020:111 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00020134-0048: TBA7FC700 020:134 JLINK_IsHalted() returns FALSE (0001ms, 1871ms total) 02-00000000-00-00020157-0048: TBA7FC700 020:156 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00020180-0048: TBA7FC700 020:179 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00020203-0048: TBA7FC700 020:202 JLINK_IsHalted() returns FALSE (0002ms, 1872ms total) 02-00000000-00-00020214-004D: TC36F1700 020:213 JLINK_GetHWStatus(...) returns 0x00 (0002ms, 1872ms total) 02-00000000-00-00020226-0048: TBA7FC700 020:225 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020249-0048: TBA7FC700 020:248 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020272-0048: TBA7FC700 020:271 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020295-0048: TBA7FC700 020:294 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020317-0048: TBA7FC700 020:317 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00020339-0048: TBA7FC700 020:338 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020361-0048: TBA7FC700 020:360 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020384-0048: TBA7FC700 020:383 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020407-0048: TBA7FC700 020:406 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020430-0048: TBA7FC700 020:429 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020453-0048: TBA7FC700 020:452 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020476-0048: TBA7FC700 020:475 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020499-0048: TBA7FC700 020:498 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020522-0048: TBA7FC700 020:521 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020545-0048: TBA7FC700 020:544 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020567-0048: TBA7FC700 020:567 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00020589-0048: TBA7FC700 020:589 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00020611-0048: TBA7FC700 020:610 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020633-0048: TBA7FC700 020:632 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020655-0048: TBA7FC700 020:654 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020678-0048: TBA7FC700 020:677 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020701-0048: TBA7FC700 020:700 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020724-0048: TBA7FC700 020:723 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020747-0048: TBA7FC700 020:746 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020771-0048: TBA7FC700 020:769 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020793-0048: TBA7FC700 020:792 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020815-0048: TBA7FC700 020:815 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00020838-0048: TBA7FC700 020:837 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020859-0048: TBA7FC700 020:859 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00020883-0048: TBA7FC700 020:881 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020904-0048: TBA7FC700 020:904 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00020926-0048: TBA7FC700 020:926 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00020949-0048: TBA7FC700 020:948 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020972-0048: TBA7FC700 020:971 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00020995-0048: TBA7FC700 020:994 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021018-0048: TBA7FC700 021:017 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021041-0048: TBA7FC700 021:040 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021063-0048: TBA7FC700 021:063 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00021087-0048: TBA7FC700 021:085 JLINK_IsHalted() returns FALSE (0003ms, 1876ms total) 02-00000000-00-00021108-0048: TBA7FC700 021:108 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00021131-0048: TBA7FC700 021:130 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021153-0048: TBA7FC700 021:153 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00021176-0048: TBA7FC700 021:175 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021198-0048: TBA7FC700 021:198 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00021220-0048: TBA7FC700 021:220 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00021243-0048: TBA7FC700 021:242 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021269-0048: TBA7FC700 021:265 JLINK_IsHalted() returns FALSE (0005ms, 1878ms total) 02-00000000-00-00021291-0048: TBA7FC700 021:290 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021314-0048: TBA7FC700 021:313 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021336-0048: TBA7FC700 021:336 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00021360-0048: TBA7FC700 021:358 JLINK_IsHalted() returns FALSE (0003ms, 1876ms total) 02-00000000-00-00021382-0048: TBA7FC700 021:381 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021405-0048: TBA7FC700 021:404 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021428-0048: TBA7FC700 021:427 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021451-0048: TBA7FC700 021:450 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021476-0048: TBA7FC700 021:473 JLINK_IsHalted() returns FALSE (0004ms, 1877ms total) 02-00000000-00-00021497-0048: TBA7FC700 021:497 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00021520-0048: TBA7FC700 021:519 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021543-0048: TBA7FC700 021:542 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021566-0048: TBA7FC700 021:565 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021589-0048: TBA7FC700 021:588 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021612-0048: TBA7FC700 021:611 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021636-0048: TBA7FC700 021:634 JLINK_IsHalted() returns FALSE (0003ms, 1876ms total) 02-00000000-00-00021658-0048: TBA7FC700 021:657 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021681-0048: TBA7FC700 021:680 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021704-0048: TBA7FC700 021:703 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021726-0048: TBA7FC700 021:726 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00021749-0048: TBA7FC700 021:748 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021773-0048: TBA7FC700 021:771 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021794-0048: TBA7FC700 021:794 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00021816-0048: TBA7FC700 021:816 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00021839-0048: TBA7FC700 021:838 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021862-0048: TBA7FC700 021:861 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021885-0048: TBA7FC700 021:884 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021908-0048: TBA7FC700 021:907 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021931-0048: TBA7FC700 021:930 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00021953-0048: TBA7FC700 021:953 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00021975-0048: TBA7FC700 021:975 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00021998-0048: TBA7FC700 021:997 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022021-0048: TBA7FC700 022:020 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022044-0048: TBA7FC700 022:043 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022067-0048: TBA7FC700 022:066 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022090-0048: TBA7FC700 022:089 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022113-0048: TBA7FC700 022:112 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022136-0048: TBA7FC700 022:135 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022158-0048: TBA7FC700 022:158 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00022181-0048: TBA7FC700 022:179 JLINK_IsHalted() returns FALSE (0003ms, 1876ms total) 02-00000000-00-00022204-0048: TBA7FC700 022:203 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022227-0048: TBA7FC700 022:226 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022250-0048: TBA7FC700 022:249 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022273-0048: TBA7FC700 022:272 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022296-0048: TBA7FC700 022:295 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022319-0048: TBA7FC700 022:318 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022342-0048: TBA7FC700 022:341 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022365-0048: TBA7FC700 022:364 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022387-0048: TBA7FC700 022:387 JLINK_IsHalted() returns FALSE (0001ms, 1874ms total) 02-00000000-00-00022409-0048: TBA7FC700 022:408 JLINK_IsHalted() returns FALSE (0002ms, 1875ms total) 02-00000000-00-00022418-004D: TC36F1700 022:418 JLINK_GetHWStatus(...) returns 0x00 (0001ms, 1874ms total) 02-00000000-00-00022432-0048: TBA7FC700 022:431 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00022455-0048: TBA7FC700 022:454 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00022478-0048: TBA7FC700 022:477 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00022500-0048: TBA7FC700 022:500 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00022522-0048: TBA7FC700 022:522 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00022544-0048: TBA7FC700 022:544 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00022567-0048: TBA7FC700 022:566 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00022590-0048: TBA7FC700 022:589 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00022614-0048: TBA7FC700 022:611 JLINK_IsHalted() returns FALSE (0004ms, 1878ms total) 02-00000000-00-00022637-0048: TBA7FC700 022:635 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00022659-0048: TBA7FC700 022:658 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00022681-0048: TBA7FC700 022:681 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00022703-0048: TBA7FC700 022:703 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00022725-0048: TBA7FC700 022:725 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00022748-0048: TBA7FC700 022:746 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00022771-0048: TBA7FC700 022:770 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00022794-0048: TBA7FC700 022:793 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00022816-0048: TBA7FC700 022:816 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00022839-0048: TBA7FC700 022:838 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00022861-0048: TBA7FC700 022:861 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00022883-0048: TBA7FC700 022:883 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00022905-0048: TBA7FC700 022:905 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00022929-0048: TBA7FC700 022:927 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00022950-0048: TBA7FC700 022:950 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00022972-0048: TBA7FC700 022:972 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00022995-0048: TBA7FC700 022:994 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00023016-0048: TBA7FC700 023:016 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023038-0048: TBA7FC700 023:038 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023060-0048: TBA7FC700 023:060 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023082-0048: TBA7FC700 023:082 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023104-0048: TBA7FC700 023:104 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023126-0048: TBA7FC700 023:126 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023150-0048: TBA7FC700 023:148 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023173-0048: TBA7FC700 023:171 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023194-0048: TBA7FC700 023:194 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023217-0048: TBA7FC700 023:216 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00023239-0048: TBA7FC700 023:239 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023263-0048: TBA7FC700 023:261 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023286-0048: TBA7FC700 023:284 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023307-0048: TBA7FC700 023:307 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023331-0048: TBA7FC700 023:329 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023354-0048: TBA7FC700 023:352 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023377-0048: TBA7FC700 023:375 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023405-0048: TBA7FC700 023:400 JLINK_IsHalted() returns FALSE (0006ms, 1880ms total) 02-00000000-00-00023426-0048: TBA7FC700 023:426 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023448-0048: TBA7FC700 023:448 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023470-0048: TBA7FC700 023:470 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023494-0048: TBA7FC700 023:492 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023517-0048: TBA7FC700 023:515 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023538-0048: TBA7FC700 023:538 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023562-0048: TBA7FC700 023:560 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023588-0048: TBA7FC700 023:583 JLINK_IsHalted() returns FALSE (0006ms, 1880ms total) 02-00000000-00-00023611-0048: TBA7FC700 023:609 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023633-0048: TBA7FC700 023:632 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00023657-0048: TBA7FC700 023:654 JLINK_IsHalted() returns FALSE (0004ms, 1878ms total) 02-00000000-00-00023680-0048: TBA7FC700 023:678 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023703-0048: TBA7FC700 023:701 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023726-0048: TBA7FC700 023:724 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023749-0048: TBA7FC700 023:747 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023772-0048: TBA7FC700 023:770 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023795-0048: TBA7FC700 023:793 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023818-0048: TBA7FC700 023:816 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023839-0048: TBA7FC700 023:839 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023868-0048: TBA7FC700 023:863 JLINK_IsHalted() returns FALSE (0006ms, 1880ms total) 02-00000000-00-00023891-0048: TBA7FC700 023:889 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023914-0048: TBA7FC700 023:912 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00023937-0048: TBA7FC700 023:935 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00023958-0048: TBA7FC700 023:958 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00023982-0048: TBA7FC700 023:980 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00024018-0048: TBA7FC700 024:003 JLINK_IsHalted() returns FALSE (0016ms, 1890ms total) 02-00000000-00-00024043-0048: TBA7FC700 024:039 JLINK_IsHalted() returns FALSE (0005ms, 1879ms total) 02-00000000-00-00024066-0048: TBA7FC700 024:064 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00024089-0048: TBA7FC700 024:087 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00024112-0048: TBA7FC700 024:110 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00024133-0048: TBA7FC700 024:133 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00024157-0048: TBA7FC700 024:155 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00024178-0048: TBA7FC700 024:178 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00024201-0048: TBA7FC700 024:201 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00024223-0048: TBA7FC700 024:223 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00024246-0048: TBA7FC700 024:245 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00024268-0048: TBA7FC700 024:268 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00024291-0048: TBA7FC700 024:289 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00024314-0048: TBA7FC700 024:313 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00024336-0048: TBA7FC700 024:336 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00024358-0048: TBA7FC700 024:358 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00024380-0048: TBA7FC700 024:380 JLINK_IsHalted() returns FALSE (0001ms, 1875ms total) 02-00000000-00-00024403-0048: TBA7FC700 024:401 JLINK_IsHalted() returns FALSE (0003ms, 1877ms total) 02-00000000-00-00024426-0048: TBA7FC700 024:425 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00024449-0048: TBA7FC700 024:448 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00024472-0048: TBA7FC700 024:471 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00024495-0048: TBA7FC700 024:494 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00024518-0048: TBA7FC700 024:517 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00024541-0048: TBA7FC700 024:540 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00024564-0048: TBA7FC700 024:563 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00024587-0048: TBA7FC700 024:586 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00024610-0048: TBA7FC700 024:609 JLINK_IsHalted() returns FALSE (0002ms, 1876ms total) 02-00000000-00-00024620-004D: TC36F1700 024:620 JLINK_GetHWStatus(...) returns 0x00 (0001ms, 1875ms total) 02-00000000-00-00024632-0048: TBA7FC700 024:632 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00024654-0048: TBA7FC700 024:654 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00024677-0048: TBA7FC700 024:676 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00024699-0048: TBA7FC700 024:699 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00024721-0048: TBA7FC700 024:721 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00024744-0048: TBA7FC700 024:743 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00024767-0048: TBA7FC700 024:766 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00024790-0048: TBA7FC700 024:789 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00024813-0048: TBA7FC700 024:812 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00024836-0048: TBA7FC700 024:835 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00024859-0048: TBA7FC700 024:858 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00024882-0048: TBA7FC700 024:881 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00024904-0048: TBA7FC700 024:904 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00024926-0048: TBA7FC700 024:926 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00024948-0048: TBA7FC700 024:948 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00024971-0048: TBA7FC700 024:970 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00024995-0048: TBA7FC700 024:993 JLINK_IsHalted() returns FALSE (0003ms, 1878ms total) 02-00000000-00-00025016-0048: TBA7FC700 025:016 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025039-0048: TBA7FC700 025:038 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025062-0048: TBA7FC700 025:061 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025084-0048: TBA7FC700 025:084 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025107-0048: TBA7FC700 025:106 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025130-0048: TBA7FC700 025:129 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025153-0048: TBA7FC700 025:152 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025176-0048: TBA7FC700 025:175 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025199-0048: TBA7FC700 025:198 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025222-0048: TBA7FC700 025:221 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025245-0048: TBA7FC700 025:244 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025267-0048: TBA7FC700 025:267 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025290-0048: TBA7FC700 025:289 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025313-0048: TBA7FC700 025:312 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025336-0048: TBA7FC700 025:335 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025359-0048: TBA7FC700 025:358 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025382-0048: TBA7FC700 025:381 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025404-0048: TBA7FC700 025:404 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025427-0048: TBA7FC700 025:426 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025450-0048: TBA7FC700 025:449 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025473-0048: TBA7FC700 025:472 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025496-0048: TBA7FC700 025:495 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025519-0048: TBA7FC700 025:518 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025541-0048: TBA7FC700 025:541 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025564-0048: TBA7FC700 025:563 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025587-0048: TBA7FC700 025:586 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025609-0048: TBA7FC700 025:609 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025632-0048: TBA7FC700 025:631 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025654-0048: TBA7FC700 025:654 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025677-0048: TBA7FC700 025:676 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025700-0048: TBA7FC700 025:699 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025723-0048: TBA7FC700 025:722 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025745-0048: TBA7FC700 025:745 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025768-0048: TBA7FC700 025:767 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025790-0048: TBA7FC700 025:790 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025812-0048: TBA7FC700 025:812 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025834-0048: TBA7FC700 025:834 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025857-0048: TBA7FC700 025:856 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025880-0048: TBA7FC700 025:879 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025903-0048: TBA7FC700 025:902 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025926-0048: TBA7FC700 025:925 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00025948-0048: TBA7FC700 025:948 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025970-0048: TBA7FC700 025:970 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00025993-0048: TBA7FC700 025:992 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00026016-0048: TBA7FC700 026:015 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00026039-0048: TBA7FC700 026:038 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00026061-0048: TBA7FC700 026:061 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00026084-0048: TBA7FC700 026:083 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00026107-0048: TBA7FC700 026:106 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00026129-0048: TBA7FC700 026:129 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00026152-0048: TBA7FC700 026:151 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00026175-0048: TBA7FC700 026:174 JLINK_IsHalted() returns FALSE (0002ms, 1877ms total) 02-00000000-00-00026197-0048: TBA7FC700 026:197 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 02-00000000-00-00026219-0048: TBA7FC700 026:219 JLINK_IsHalted() returns FALSE (0001ms, 1876ms total) 03-00000000-00-00026220-001C: GDB closed TCP/IP connection
