# Register addresses #Keil (main:start) set RCC_APB2ENR 0x40021018 #0x0 set AFIO_MAPR 0x40010004 #0x0 set DBGMCU_CR 0xe0042004 #0xE7 set COREDEBUG_DEMCR 0xe000edfc #0x01000000 set TPI_ACPR 0xe0040010 #0x0 //0 bei synchronous mode set TPI_SPPR 0xe00400f0 #0x0 set TPI_FFCR 0xe0040304 #0x102 TPIU_SSPSR 0xE0040000 #0x0B TPIU_CSPSR 0xE0040004 #0x01 TRIGGER 0xE0040EE8 #0x0 FIFO data 0 0xE0040EEC #0x0 set DWT_CTRL 0xe0001000 #0x4005061F --T32 set ITM_LAR 0xe0000fb0 #0x0 set ITM_TCR 0xe0000e80 #0x0001000D --T32 set ITM_TER 0xe0000e00 #0xFFFFFFFF --T32 TPR 0xE0000E40 #0x0F set ETM_LAR 0xe0041fb0 #0x0 set ETM_CR 0xe0041000 #0x00000910 --T32: 0x0410 set ETM_CCR 0xE0041004 #0x8C840000 //RO set ETM_TRIG 0xE0041008 #0x000077FF --T32: 0x77EF ETM_SR 0xE0041010 #0x0 ETM_SCR 0xE0041014 #0x??? --T32: 0x00020D09 ETMTEEVR 0xE0041020 #0x0000006F --T32: ???? ETMTECR1 0xE0041024 #0x0 ETMFFLR 0xE0041028 #0x0 ETMCNTRLDVR1 0xE0041140 #0x0 ETMSYNCFR 0xE00411E0 #sync frequency register ETMIDR 0xE00411E4 #4114F242 ETMCCER 0xE00411E8 #0x00018800 ETMTESSEICR 0xE00411F0 #0x0 ETMTSEVR 0xE00411F8 #0x0 ETMTRACEIDR 0xE0041200 #0x02 --T32: 0x01 ETMIDR2 0xE0041208 #0x00 ETMPDSR 0xE0041314 #0x01 ITMISCIN 0xE0041EE0 #0x10 ITTRIGOUT 0xE0041EE8 #0x0 ETM_ITATBCTR2 0xE0041EF0 #0x01 //RO ETM_ITATBCTR0 0xE0041EF8 #0x00 //WO ETMITCTRL 0xE0041F00 #0x0 ETMCLAIMSET 0xE0041FA0 #0x0F ETMCLAIMCLR 0xE0041FA4 #0x0 ETMLAR 0xE0041FB0 #0x0 //lock Access reg ETMLSR 0xE0041FB4 #0x01 ETMAUTHSTATUS 0xE0041FB8 #0xC0 ETMDEVTYPE 0xE0041FCC #0x13 //default set ETM_TRACEIDR 0xe0041200 #0x02 set ETM_TECR1 0xe0041024 #0x0 set ETM_FFRR 0xe0041028 #0x0 set ETM_FFLR 0xe004102c #0x0 # Stop the CPU while we configure init halt # STM32 IO pin config setbits $RCC_APB2ENR 1 ;# AFIOEN setbits $AFIO_MAPR 0x2000000 ;# Disable JTAG setbits $DBGMCU_CR 0x20 ;# Enable trace IO pins # TPIU config setbits $COREDEBUG_DEMCR 0x1000000 ;# Enable access to trace regs mww $TPI_ACPR 0 ;# Trace clock divider HCLK/(x+1) mww $TPI_SPPR 2 ;# Pin protocol = NRZ/USART mww $TPI_FFCR 0x102 ;# Enable TPIU framing (0x100 to disable) # DWT config mww $DWT_CTRL 0x40011a01 ;# 1/512 PC sampling, exc trace # ITM config mww $ITM_LAR 0xC5ACCE55 mww $ITM_TCR 0x0001000d ;# TraceBusID 1, enable dwt/itm/sync mww $ITM_TER 0xffffffff ;# Enable all stimulus ports # ETM config mww $ETM_LAR 0xC5ACCE55 setbits $ETM_CR 0x400 ;# ETM programming mode mww $ETM_CR 0xd80 ;# Stall processor, report all branches # mww $ETM_CR 0x800 ;# No stalling, only indirect branches mww $ETM_TRACEIDR 2 ;# TraceBusID 2 mww $ETM_TECR1 0x1000000 ;# Trace always enabled mww $ETM_FFRR 0x1000000 ;# Stalling always enabled mww $ETM_FFLR 24 ;# Stall when less than N bytes free in FIFO (1..24) # clearbits $ETM_CR 0x400 ;# Start tracing # Resume CPU and exit openocd resume shutdown
