0 Temperatur Sensor 1 Temperature sensor 1 15 0.1 °C 2 Temperatur Sensor 2 Temperature sensor 2 15 0.1 °C 4 Temperatur Sensor 3 Temperature sensor 3 15 0.1 °C 6 Temperatur Sensor 4 Temperature sensor 4 15 0.1 °C 8 Temperatur Sensor 5 Temperature sensor 5 15 0.1 °C 10 Temperatur Sensor 6 Temperature sensor 6 15 0.1 °C 12 Temperatur Sensor 7 Temperature sensor 7 15 0.1 °C 14 Temperatur Sensor 8 Temperature sensor 8 15 0.1 °C 16 Temperatur Sensor 9 Temperature sensor 9 15 0.1 °C 18 Temperatur Sensor 10 Temperature sensor 10 15 0.1 °C 20 Temperatur Sensor 11 Temperature sensor 11 15 0.1 °C 22 Temperatur Sensor 12 Temperature sensor 12 15 0.1 °C 24 Temperatur Sensor 13 Temperature sensor 13 15 0.1 °C 26 Temperatur Sensor 14 Temperature sensor 14 15 0.1 °C 28 Temperatur Sensor 15 Temperature sensor 15 15 0.1 °C 30 Einstrahlung Sensor 16 Irradiation sensor 16 15 1 W/qm 32 Temperatur Sensor 17 Temperature sensor 17 15 0.1 °C 34 Temperatur Sensor 18 Temperature sensor 18 15 0.1 °C 36 Temperatur Sensor 19 Temperature sensor 19 15 0.1 °C 38 Temperatur Sensor 20 Temperature sensor 20 15 0.1 °C 40 Volumenstrom Sensor 13 Flow sensor 13 31 1 l/h 44 Volumenstrom Sensor 14 Flow sensor 14 31 1 l/h 48 Volumenstrom Sensor 15 Flow sensor 15 31 1 l/h 52 Volumenstrom Sensor 17 Flow sensor 17 31 1 l/h 56 Volumenstrom Sensor 18 Flow sensor 18 31 1 l/h 60 Volumenstrom Sensor 19 Flow sensor 19 31 1 l/h 64 Volumenstrom Sensor 20 Flow sensor 20 31 1 l/h 104 Volumenstrom Sensor 21 Flow sensor 21 31 1 l/h 68 Druck Sensor 17 Pressure sensor 17 15 0.01 bar 70 Druck Sensor 18 Pressure sensor 18 15 0.01 bar 72 Druck Sensor 19 Pressure sensor 19 15 0.01 bar 74 Druck Sensor 20 Pressure sensor 20 15 0.01 bar 76 Drehzahl Relais 1 Pump speed 1 8 1 % 77 Drehzahl Relais 2 Pump speed 2 8 1 % 78 Drehzahl Relais 3 Pump speed 3 8 1 % 79 Drehzahl Relais 4 Pump speed 4 8 1 % 80 Drehzahl Relais 5 Pump speed 5 8 1 % 81 Drehzahl Relais 6 Pump speed 6 8 1 % 82 Drehzahl Relais 7 Pump speed 7 8 1 % 83 Drehzahl Relais 8 Pump speed 8 8 1 % 84 Drehzahl Relais 9 Pump speed 9 8 1 % 85 Drehzahl Relais 10 Pump speed 10 8 1 % 86 Drehzahl Relais 11 Pump speed 11 8 1 % 87 Drehzahl Relais 12 Pump speed 12 8 1 % 88 Drehzahl Relais 13 Pump speed 13 8 1 % 89 Drehzahl Relais 14 Pump speed 14 8 1 % 100 Ausgang A Output A 8 1 % 101 Ausgang B Output B 8 1 % 102 Ausgang C Output C 8 1 % 103 Ausgang D Output D 8 1 % 92 Systemdatum System date 31 1 r
