(module Resistor_Horizontal_RM10mm_22Apr2011 (layer F.Cu) (tedit 53C56262)
  (descr "Resistor, Axial,  RM 10mm, 1/3W,")
  (tags "Resistor, Axial, RM 10mm, 1/3W,")
  (fp_text reference R (at 0.24892 -3.50012) (layer F.SilkS)
    (effects (font (thickness 0.3048)))
  (fp_text value Resistor_Horizontal_RM10mm_22Apr2011 (at 3.81 3.81) (layer F.SilkS) hide
    (effects (font (size 1.50114 1.50114) (thickness 0.20066)))
  (fp_line (start -2.46126 0) (end -3.47726 0) (layer F.SilkS) (width 0.381))
  (fp_line (start 2.61874 0) (end 3.63474 0) (layer F.SilkS) (width 0.381))
  (fp_line (start -2.46126 -1.27) (end 2.61874 -1.27) (layer F.SilkS) (width 0.381))
  (fp_line (start 2.61874 -1.27) (end 2.61874 1.27) (layer F.SilkS) (width 0.381))
  (fp_line (start 2.61874 1.27) (end -2.46126 1.27) (layer F.SilkS) (width 0.381))
  (fp_line (start -2.46126 1.27) (end -2.46126 -1.27) (layer F.SilkS) (width 0.381))
  (pad 1 thru_hole circle (at -5.00126 0) (size 1.99898 1.99898) (drill 1.00076) (layers *.Cu *.Mask))
  (pad 2 thru_hole circle (at 5.15874 0) (size 1.99898 1.99898) (drill 1.00076) (layers *.Cu *.Mask))
