$regfile = "2313def.dat" $crystal = 3690000 ' 74xx165 ' hard wire CE_N (SR pin 15) to GND sclk_sr_in alias portd.0 ' connect to CP (SR pin 2) lclk_sr_in alias portd.1 ' connect to PL_N (SR pin 1) data_sr_in alias pind.2 ' connect to Q7 (SR pin 9) config sclk_sr_in = output config lclk_sr_in = output config data_sr_in = input reset sclk_sr_in set lclk_sr_in ' 74xx595 ' hard wire OE (SR pin 13) to VCC lclk_sr_out alias portb.4 ' connect to STCP (SR pin 12) data_sr_out alias portb.5 ' connect to DS (SR pin 14) mr_sr_out alias portb.6 ' connect to MR_N (SR pin 10) sclk_sr_out alias portb.7 ' connect to SHCP (SR pin 11) config portb = output reset mr_sr_out reset lclk_sr_out reset data_sr_out reset sclk_sr_out set mr_sr_out ' set master reset to high (MR is low active) dim data_in as byte dim data_out as byte do reset lclk_sr_in ' latch clock low waitms 1 set lclk_sr_in ' latch clock high waitms 1 shiftin data_sr_in, sclk_sr_in, data_in, 1 data_out = not data_in shiftout data_sr_out, sclk_sr_out, data_out, 1 waitms 1 set lclk_sr_out ' latch clock high waitms 1 reset lclk_sr_out ' latch clock low waitms 10 loop end
