Version 4 SHEET 1 1132 1092 WIRE 16 96 16 112 WIRE -32 96 -32 112 WIRE 32 48 256 48 WIRE 288 48 288 80 WIRE 288 160 288 192 WIRE -272 48 -240 48 WIRE -208 48 -240 48 WIRE -352 48 -384 48 WIRE 96 336 256 336 WIRE 288 336 288 368 WIRE 288 448 288 480 WIRE 16 336 -48 336 WIRE -240 48 -240 336 WIRE -240 336 -128 336 WIRE -208 48 -48 48 WIRE 48 624 256 624 WIRE 288 624 288 656 WIRE 288 736 288 768 WIRE -32 624 -240 624 WIRE -240 624 -240 336 WIRE 256 48 288 48 WIRE 256 336 288 336 WIRE 256 624 288 624 FLAG -32 112 0 FLAG 288 192 0 FLAG 16 112 0 FLAG -384 48 0 FLAG -208 48 in FLAG 256 48 out FLAG 288 480 0 FLAG 256 336 out1 FLAG 288 768 0 FLAG 256 624 out2 SYMBOL sw -64 48 R270 WINDOW 0 24 96 VRight 0 WINDOW 3 -23 96 VRight 0 SYMATTR InstName S1 SYMATTR Value C_LIMIT SYMBOL voltage -256 48 M270 WINDOW 123 -32 56 VBottom 0 WINDOW 39 -32 56 VBottom 0 WINDOW 0 32 56 VTop 0 WINDOW 3 -64 0 VRight 0 SYMATTR InstName V1 SYMATTR Value PWL(0 0 1 2 2 0 3 -2 4 0 4.5 1.05 5 1.05) SYMBOL res 272 64 R0 SYMATTR InstName R1 SYMATTR Value 1 SYMBOL voltage -144 336 R270 WINDOW 0 32 56 VTop 0 WINDOW 3 -32 56 VBottom 0 SYMATTR InstName V3 SYMATTR Value 0 SYMBOL res 272 352 R0 SYMATTR InstName R2 SYMATTR Value 1 SYMBOL bi 16 336 R270 WINDOW 0 32 40 VTop 0 WINDOW 3 -32 40 VBottom 0 WINDOW 123 -60 40 VBottom 0 SYMATTR InstName B1 SYMATTR Value I=LIMIT(-1, I(V3), 1) SYMATTR Value2 Rpar=1G SYMBOL current -32 624 R270 WINDOW 0 32 40 VTop 0 WINDOW 3 -32 40 VBottom 0 WINDOW 123 -32 40 VBottom 0 WINDOW 39 -32 40 VBottom 0 SYMATTR InstName I1 SYMATTR Value TBL(-1u -1 1u 1) SYMBOL res 272 640 R0 SYMATTR InstName R3 SYMATTR Value 1 TEXT 8 -40 Center 0 !.MODEL C_LIMIT SW(Ron=1m Vt=-1 Ilimit=1) TEXT -658 -62 Left 0 !.TRAN 5 TEXT 8 -72 Center 0 ;Current limiter with SW model TEXT 8 232 Center 0 ;Current limiter with B current source TEXT -664 -272 Left 0 ;Different Current Limiters TEXT -664 -160 Left 0 ;Watch the artifacts of the switch SW current limiter. \nThe overshoot is lower the smaller the minimum timestep is set in .TRAN, e.g. .TRAN 0 5 0 0.1m TEXT -664 -224 Left 0 ;A resistor in parallel to B1 is mandatory, otherwise this circuit will not converge.\nA resistor value of Rpar <= 1G is recommended. TEXT 8 520 Center 0 ;Current limiter with I current source RECTANGLE Normal 176 448 -160 256 2 RECTANGLE Normal 176 160 -160 -16 2 RECTANGLE Normal 176 720 -160 544 2
