22:49:58 --------- 22:49:58 27.01.17 Start program V2.2.14320-64 22:49:58 IDE: Lazarus LCL 1.1.0.0, Free Pascal FPC 2.6.3, Zeos 7.0.3-stable 22:49:58 Compile: 20.Mrz.2014 22:25:32 22:49:58 Use INI file: C:\EleLa\EleLa.ini 22:49:58 Parameter [DB] Protocol=mysql-5 22:49:58 Parameter [DB] HostName=213.136.73.62 22:49:58 Parameter [DB] Port=3306 22:49:58 Parameter [DB] Database=elela 22:49:58 Parameter [DB] User=elela 22:49:58 Parameter [DB] Password=***** 22:49:58 Parameter [Programm] VorlageDir=C:\EleLa\Vorlage\ 22:49:58 Parameter [Programm] TempDir=C:\EleLa\Temp\ 22:49:58 Parameter [Programm] QueryCancel=1 22:49:58 Parameter [Programm] VersionCheck=1 22:49:58 Parameter [Bauteil] DefHandbuchDir=C:\EleLa\Handbuch 22:49:58 Parameter [Projekt] DefHandbuchDir=C:\EleLa\Projekt 22:49:58 Connect database... 22:49:59 DB.Version: SQLite-DLL: 3.8.8.1 / MySQL: 5.7.17 22:49:59 Database Version: V2.2.13C01 22:50:00 Database connected. 22:50:29 --------- 22:50:29 27.01.17 Start program V3.0.17107-64 22:50:29 IDE: Lazarus LCL 1.4.4.0, Free Pascal FPC 2.6.4, Zeos 7.1.4-stable 22:50:29 Compile: 08.Jan.2017 13:41:52 SVN: 92 22:50:29 Use INI file: C:\EleLa\EleLa.ini 22:50:29 Parameter [DB] Protocol=mysql-5 22:50:29 Parameter [DB] HostName=213.136.73.62 22:50:29 Parameter [DB] Port=3306 22:50:29 Parameter [DB] Database=elela 22:50:29 Parameter [DB] User=elela 22:50:29 Parameter [DB] Password=***** 22:50:29 Parameter [Programm] VorlageDir=C:\EleLa\Vorlage\ 22:50:29 Parameter [Programm] TempDir=C:\EleLa\Temp\ 22:50:29 Parameter [Programm] QueryCancel=1 22:50:29 Parameter [Programm] VersionCheck=1 22:50:29 Parameter [Bauteil] DefHandbuchDir=C:\EleLa\Handbuch 22:50:29 Parameter [Projekt] DefHandbuchDir=C:\EleLa\Projekt 22:50:29 Parameter [Projekt] GeraetDefHandbuchDir=C:\EleLa\Gerät 22:50:29 Parameter [Projekt] DokuDefHandbuchDir=C:\EleLa\Doku 22:50:31 Connect database... 22:50:31 DB.Version: SQLite-DLL: 3.8.8.1 / MySQL: 5.7.17 22:50:31 Database Version: V2.2.13C01 22:50:31 Do Update 54 from Database. 22:50:31 RenameField (bauteillager,Menge,Menge,DOUBLE) 22:50:36 Error: Database-Update Nr. 54 error! Make the update manually. 22:50:36 SQL: ALTER IGNORE TABLE `bauteillager` CHANGE `Menge` `Menge` DOUBLE NULL DEFAULT NULL 22:50:37 Error on Test/Update Database. 22:50:37 Error: Cannot open database! SQL Error: Unknown column 'l.Einheit' in 'field list' (qGehause) 22:50:37 Connect database... 22:50:37 DB.Version: SQLite-DLL: 3.8.8.1 / MySQL: 5.7.17 22:50:37 22:50:37 ------------------------------- 22:50:37 Error!!! Database is newer as this EleLa program. Cannot open the database! 22:50:37 Please update EleLa to a newer version. 22:50:37 ------------------------------- 22:50:37
