g++ -c -I. -Iblock -Iboard -Icommon -Iimp -Ipackage -Ipool -Ischematic -Iutil -Iconstraints -g3 -D_USE_MATH_DEFINES -fdata-sections -ffunction-sections -pthread -std=c++11 -pthread -I/usr/include/uuid -I/usr/include/gtkmm-3.0 -I/usr/lib/x86_64-linux-gnu/gtkmm-3.0/include -I/usr/include/atkmm-1.6 -I/usr/include/gtk-3.0/unix-print -I/usr/include/gdkmm-3.0 -I/usr/lib/x86_64-linux-gnu/gdkmm-3.0/include -I/usr/include/giomm-2.4 -I/usr/lib/x86_64-linux-gnu/giomm-2.4/include -I/usr/include/pangomm-1.4 -I/usr/lib/x86_64-linux-gnu/pangomm-1.4/include -I/usr/include/glibmm-2.4 -I/usr/lib/x86_64-linux-gnu/glibmm-2.4/include -I/usr/include/gtk-3.0 -I/usr/include/at-spi2-atk/2.0 -I/usr/include/at-spi-2.0 -I/usr/include/dbus-1.0 -I/usr/lib/x86_64-linux-gnu/dbus-1.0/include -I/usr/include/gtk-3.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/mirclient -I/usr/include/mircommon -I/usr/include/mircookie -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/harfbuzz -I/usr/include/pango-1.0 -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/cairomm-1.0 -I/usr/lib/x86_64-linux-gnu/cairomm-1.0/include -I/usr/include/sigc++-2.0 -I/usr/lib/x86_64-linux-gnu/sigc++-2.0/include -I/usr/include/cairo -I/usr/include/librsvg-2.0 -I/usr/include/gdk-pixbuf-2.0 -I/usr/include/libpng12 -I/usr/include/cairo -I/usr/include/glib-2.0 -I/usr/lib/x86_64-linux-gnu/glib-2.0/include -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/libpng12 -MP -MMD -pthread -Wall -Wshadow -std=c++14 schematic/schematic.cpp -o schematic/schematic.o In file included from /usr/include/x86_64-linux-gnu/c++/5/bits/c++allocator.h:33:0, from /usr/include/c++/5/bits/allocator.h:46, from /usr/include/c++/5/string:41, from /usr/include/c++/5/bits/locale_classes.h:40, from /usr/include/c++/5/bits/ios_base.h:41, from /usr/include/c++/5/ios:42, from /usr/include/c++/5/ostream:38, from /usr/include/c++/5/iostream:39, from util/uuid.hpp:8, from schematic/schematic.hpp:2, from schematic/schematic.cpp:1: /usr/include/c++/5/ext/new_allocator.h: In instantiation of ‘void __gnu_cxx::new_allocator<_Tp>::construct(_Up*, _Args&& ...) [with _Up = std::pair, horizon::Connection>; _Args = {horizon::UUIDPath<2u>, horizon::uuid_ptr&}; _Tp = std::_Rb_tree_node, horizon::Connection> >]’: /usr/include/c++/5/bits/alloc_traits.h:530:4: required from ‘static void std::allocator_traits >::construct(std::allocator_traits >::allocator_type&, _Up*, _Args&& ...) [with _Up = std::pair, horizon::Connection>; _Args = {horizon::UUIDPath<2u>, horizon::uuid_ptr&}; _Tp = std::_Rb_tree_node, horizon::Connection> >; std::allocator_traits >::allocator_type = std::allocator, horizon::Connection> > >]’ /usr/include/c++/5/bits/stl_tree.h:529:32: required from ‘void std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::_M_construct_node(std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::_Link_type, _Args&& ...) [with _Args = {horizon::UUIDPath<2u>, horizon::uuid_ptr&}; _Key = horizon::UUIDPath<2u>; _Val = std::pair, horizon::Connection>; _KeyOfValue = std::_Select1st, horizon::Connection> >; _Compare = std::less >; _Alloc = std::allocator, horizon::Connection> >; std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::_Link_type = std::_Rb_tree_node, horizon::Connection> >*]’ /usr/include/c++/5/bits/stl_tree.h:546:21: required from ‘std::_Rb_tree_node<_Val>* std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::_M_create_node(_Args&& ...) [with _Args = {horizon::UUIDPath<2u>, horizon::uuid_ptr&}; _Key = horizon::UUIDPath<2u>; _Val = std::pair, horizon::Connection>; _KeyOfValue = std::_Select1st, horizon::Connection> >; _Compare = std::less >; _Alloc = std::allocator, horizon::Connection> >; std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::_Link_type = std::_Rb_tree_node, horizon::Connection> >*]’ /usr/include/c++/5/bits/stl_tree.h:2123:33: required from ‘std::pair, bool> std::_Rb_tree<_Key, _Val, _KeyOfValue, _Compare, _Alloc>::_M_emplace_unique(_Args&& ...) [with _Args = {horizon::UUIDPath<2u>, horizon::uuid_ptr&}; _Key = horizon::UUIDPath<2u>; _Val = std::pair, horizon::Connection>; _KeyOfValue = std::_Select1st, horizon::Connection> >; _Compare = std::less >; _Alloc = std::allocator, horizon::Connection> >]’ /usr/include/c++/5/bits/stl_map.h:559:64: required from ‘std::pair, std::_Select1st >, _Compare, typename __gnu_cxx::__alloc_traits<_Alloc>::rebind >::other>::iterator, bool> std::map<_Key, _Tp, _Compare, _Alloc>::emplace(_Args&& ...) [with _Args = {horizon::UUIDPath<2u>, horizon::uuid_ptr&}; _Key = horizon::UUIDPath<2u>; _Tp = horizon::Connection; _Compare = std::less >; _Alloc = std::allocator, horizon::Connection> >; typename std::_Rb_tree<_Key, std::pair, std::_Select1st >, _Compare, typename __gnu_cxx::__alloc_traits<_Alloc>::rebind >::other>::iterator = std::_Rb_tree_iterator, horizon::Connection> >]’ schematic/schematic.cpp:85:105: required from here /usr/include/c++/5/ext/new_allocator.h:120:4: error: no matching function for call to ‘std::pair, horizon::Connection>::pair(horizon::UUIDPath<2u>, horizon::uuid_ptr&)’ { ::new((void *)__p) _Up(std::forward<_Args>(__args)...); } ^ In file included from /usr/include/c++/5/bits/stl_algobase.h:64:0, from /usr/include/c++/5/bits/char_traits.h:39, from /usr/include/c++/5/ios:40, from /usr/include/c++/5/ostream:38, from /usr/include/c++/5/iostream:39, from util/uuid.hpp:8, from schematic/schematic.hpp:2, from schematic/schematic.cpp:1: /usr/include/c++/5/bits/stl_pair.h:206:9: note: candidate: template std::pair<_T1, _T2>::pair(std::tuple<_Args1 ...>&, std::tuple<_Args2 ...>&, std::_Index_tuple<_Indexes1 ...>, std::_Index_tuple<_Indexes2 ...>) pair(tuple<_Args1...>&, tuple<_Args2...>&, ^ /usr/include/c++/5/bits/stl_pair.h:206:9: note: template argument deduction/substitution failed: In file included from /usr/include/x86_64-linux-gnu/c++/5/bits/c++allocator.h:33:0, from /usr/include/c++/5/bits/allocator.h:46, from /usr/include/c++/5/string:41, from /usr/include/c++/5/bits/locale_classes.h:40, from /usr/include/c++/5/bits/ios_base.h:41, from /usr/include/c++/5/ios:42, from /usr/include/c++/5/ostream:38, from /usr/include/c++/5/iostream:39, from util/uuid.hpp:8, from schematic/schematic.hpp:2, from schematic/schematic.cpp:1: /usr/include/c++/5/ext/new_allocator.h:120:4: note: ‘horizon::UUIDPath<2u>’ is not derived from ‘std::tuple<_Args1 ...>’ { ::new((void *)__p) _Up(std::forward<_Args>(__args)...); } ^ In file included from /usr/include/c++/5/bits/stl_algobase.h:64:0, from /usr/include/c++/5/bits/char_traits.h:39, from /usr/include/c++/5/ios:40, from /usr/include/c++/5/ostream:38, from /usr/include/c++/5/iostream:39, from util/uuid.hpp:8, from schematic/schematic.hpp:2, from schematic/schematic.cpp:1: /usr/include/c++/5/bits/stl_pair.h:155:9: note: candidate: template std::pair<_T1, _T2>::pair(std::piecewise_construct_t, std::tuple<_Args1 ...>, std::tuple<_Args2 ...>) pair(piecewise_construct_t, tuple<_Args1...>, tuple<_Args2...>); ^ /usr/include/c++/5/bits/stl_pair.h:155:9: note: template argument deduction/substitution failed: In file included from /usr/include/x86_64-linux-gnu/c++/5/bits/c++allocator.h:33:0, from /usr/include/c++/5/bits/allocator.h:46, from /usr/include/c++/5/string:41, from /usr/include/c++/5/bits/locale_classes.h:40, from /usr/include/c++/5/bits/ios_base.h:41, from /usr/include/c++/5/ios:42, from /usr/include/c++/5/ostream:38, from /usr/include/c++/5/iostream:39, from util/uuid.hpp:8, from schematic/schematic.hpp:2, from schematic/schematic.cpp:1: /usr/include/c++/5/ext/new_allocator.h:120:4: note: cannot convert ‘std::forward >((* & __args#0))’ (type ‘horizon::UUIDPath<2u>’) to type ‘std::piecewise_construct_t’ { ::new((void *)__p) _Up(std::forward<_Args>(__args)...); } ^ In file included from /usr/include/c++/5/bits/stl_algobase.h:64:0, from /usr/include/c++/5/bits/char_traits.h:39, from /usr/include/c++/5/ios:40, from /usr/include/c++/5/ostream:38, from /usr/include/c++/5/iostream:39, from util/uuid.hpp:8, from schematic/schematic.hpp:2, from schematic/schematic.cpp:1: /usr/include/c++/5/bits/stl_pair.h:150:12: note: candidate: template constexpr std::pair<_T1, _T2>::pair(std::pair<_U1, _U2>&&) constexpr pair(pair<_U1, _U2>&& __p) ^ /usr/include/c++/5/bits/stl_pair.h:150:12: note: template argument deduction/substitution failed: In file included from /usr/include/x86_64-linux-gnu/c++/5/bits/c++allocator.h:33:0, from /usr/include/c++/5/bits/allocator.h:46, from /usr/include/c++/5/string:41, from /usr/include/c++/5/bits/locale_classes.h:40, from /usr/include/c++/5/bits/ios_base.h:41, from /usr/include/c++/5/ios:42, from /usr/include/c++/5/ostream:38, from /usr/include/c++/5/iostream:39, from util/uuid.hpp:8, from schematic/schematic.hpp:2, from schematic/schematic.cpp:1: /usr/include/c++/5/ext/new_allocator.h:120:4: note: ‘horizon::UUIDPath<2u>’ is not derived from ‘std::pair<_T1, _T2>’ { ::new((void *)__p) _Up(std::forward<_Args>(__args)...); } ^ In file included from /usr/include/c++/5/bits/stl_algobase.h:64:0, from /usr/include/c++/5/bits/char_traits.h:39, from /usr/include/c++/5/ios:40, from /usr/include/c++/5/ostream:38, from /usr/include/c++/5/iostream:39, from util/uuid.hpp:8, from schematic/schematic.hpp:2, from schematic/schematic.cpp:1: /usr/include/c++/5/bits/stl_pair.h:144:12: note: candidate: template constexpr std::pair<_T1, _T2>::pair(_U1&&, _U2&&) constexpr pair(_U1&& __x, _U2&& __y) ^ /usr/include/c++/5/bits/stl_pair.h:144:12: note: template argument deduction/substitution failed: /usr/include/c++/5/bits/stl_pair.h:141:38: error: no type named ‘type’ in ‘struct std::enable_if’ template constexpr std::pair<_T1, _T2>::pair(const _T1&, _U2&&) constexpr pair(const _T1& __x, _U2&& __y) ^ /usr/include/c++/5/bits/stl_pair.h:138:12: note: template argument deduction/substitution failed: /usr/include/c++/5/bits/stl_pair.h:136:27: error: no type named ‘type’ in ‘struct std::enable_if’ template constexpr std::pair<_T1, _T2>::pair(_U1&&, const _T2&) constexpr pair(_U1&& __x, const _T2& __y) ^ /usr/include/c++/5/bits/stl_pair.h:133:12: note: template argument deduction/substitution failed: In file included from /usr/include/x86_64-linux-gnu/c++/5/bits/c++allocator.h:33:0, from /usr/include/c++/5/bits/allocator.h:46, from /usr/include/c++/5/string:41, from /usr/include/c++/5/bits/locale_classes.h:40, from /usr/include/c++/5/bits/ios_base.h:41, from /usr/include/c++/5/ios:42, from /usr/include/c++/5/ostream:38, from /usr/include/c++/5/iostream:39, from util/uuid.hpp:8, from schematic/schematic.hpp:2, from schematic/schematic.cpp:1: /usr/include/c++/5/ext/new_allocator.h:120:4: note: cannot convert ‘std::forward&>((* & __args#1))’ (type ‘horizon::uuid_ptr’) to type ‘const horizon::Connection&’ { ::new((void *)__p) _Up(std::forward<_Args>(__args)...); } ^ In file included from /usr/include/c++/5/bits/stl_algobase.h:64:0, from /usr/include/c++/5/bits/char_traits.h:39, from /usr/include/c++/5/ios:40, from /usr/include/c++/5/ostream:38, from /usr/include/c++/5/iostream:39, from util/uuid.hpp:8, from schematic/schematic.hpp:2, from schematic/schematic.cpp:1: /usr/include/c++/5/bits/stl_pair.h:128:17: note: candidate: constexpr std::pair<_T1, _T2>::pair(std::pair<_T1, _T2>&&) [with _T1 = const horizon::UUIDPath<2u>; _T2 = horizon::Connection] constexpr pair(pair&&) = default; ^ /usr/include/c++/5/bits/stl_pair.h:128:17: note: candidate expects 1 argument, 2 provided /usr/include/c++/5/bits/stl_pair.h:127:17: note: candidate: constexpr std::pair<_T1, _T2>::pair(const std::pair<_T1, _T2>&) [with _T1 = const horizon::UUIDPath<2u>; _T2 = horizon::Connection] constexpr pair(const pair&) = default; ^ /usr/include/c++/5/bits/stl_pair.h:127:17: note: candidate expects 1 argument, 2 provided /usr/include/c++/5/bits/stl_pair.h:124:12: note: candidate: template constexpr std::pair<_T1, _T2>::pair(const std::pair<_U1, _U2>&) constexpr pair(const pair<_U1, _U2>& __p) ^ /usr/include/c++/5/bits/stl_pair.h:124:12: note: template argument deduction/substitution failed: In file included from /usr/include/x86_64-linux-gnu/c++/5/bits/c++allocator.h:33:0, from /usr/include/c++/5/bits/allocator.h:46, from /usr/include/c++/5/string:41, from /usr/include/c++/5/bits/locale_classes.h:40, from /usr/include/c++/5/bits/ios_base.h:41, from /usr/include/c++/5/ios:42, from /usr/include/c++/5/ostream:38, from /usr/include/c++/5/iostream:39, from util/uuid.hpp:8, from schematic/schematic.hpp:2, from schematic/schematic.cpp:1: /usr/include/c++/5/ext/new_allocator.h:120:4: note: ‘horizon::UUIDPath<2u>’ is not derived from ‘const std::pair<_T1, _T2>’ { ::new((void *)__p) _Up(std::forward<_Args>(__args)...); } ^ In file included from /usr/include/c++/5/bits/stl_algobase.h:64:0, from /usr/include/c++/5/bits/char_traits.h:39, from /usr/include/c++/5/ios:40, from /usr/include/c++/5/ostream:38, from /usr/include/c++/5/iostream:39, from util/uuid.hpp:8, from schematic/schematic.hpp:2, from schematic/schematic.cpp:1: /usr/include/c++/5/bits/stl_pair.h:112:26: note: candidate: constexpr std::pair<_T1, _T2>::pair(const _T1&, const _T2&) [with _T1 = const horizon::UUIDPath<2u>; _T2 = horizon::Connection] _GLIBCXX_CONSTEXPR pair(const _T1& __a, const _T2& __b) ^ /usr/include/c++/5/bits/stl_pair.h:112:26: note: no known conversion for argument 2 from ‘horizon::uuid_ptr’ to ‘const horizon::Connection&’ /usr/include/c++/5/bits/stl_pair.h:108:26: note: candidate: constexpr std::pair<_T1, _T2>::pair() [with _T1 = const horizon::UUIDPath<2u>; _T2 = horizon::Connection] _GLIBCXX_CONSTEXPR pair() ^ /usr/include/c++/5/bits/stl_pair.h:108:26: note: candidate expects 0 arguments, 2 provided Makefile:238: die Regel für Ziel „schematic/schematic.o“ scheiterte make: *** [schematic/schematic.o] Fehler 1
