[ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 3.13.0-107-generic (buildd@lcy01-29) (gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.3) ) #154-Ubuntu SMP Mon Dec 19 19:20:26 UTC 2016 (Ubuntu 3.13.0-107.154-generic 3.13.11-ckt39) [ 0.000000] KERNEL supported cpus: [ 0.000000] Intel GenuineIntel [ 0.000000] AMD AuthenticAMD [ 0.000000] NSC Geode by NSC [ 0.000000] Cyrix CyrixInstead [ 0.000000] Centaur CentaurHauls [ 0.000000] Transmeta GenuineTMx86 [ 0.000000] Transmeta TransmetaCPU [ 0.000000] UMC UMC UMC UMC [ 0.000000] e820: BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable [ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x000000000009ffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000000d2000-0x00000000000d3fff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000000dc000-0x00000000000fffff] reserved [ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x000000005ff5ffff] usable [ 0.000000] BIOS-e820: [mem 0x000000005ff60000-0x000000005ff77fff] ACPI data [ 0.000000] BIOS-e820: [mem 0x000000005ff78000-0x000000005ff79fff] ACPI NVS [ 0.000000] BIOS-e820: [mem 0x000000005ff80000-0x000000005fffffff] reserved [ 0.000000] BIOS-e820: [mem 0x00000000ff800000-0x00000000ffffffff] reserved [ 0.000000] Notice: NX (Execute Disable) protection missing in CPU! [ 0.000000] SMBIOS 2.3 present. [ 0.000000] DMI: IBM 2672CEG/2672CEG, BIOS 1QET78WW (2.15 ) 11/18/2004 [ 0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved [ 0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable [ 0.000000] e820: last_pfn = 0x5ff60 max_arch_pfn = 0x1000000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-CFFFF write-protect [ 0.000000] D0000-DBFFF uncachable [ 0.000000] DC000-DFFFF write-back [ 0.000000] E0000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 000000000 mask FC0000000 write-back [ 0.000000] 1 base 040000000 mask FE0000000 write-back [ 0.000000] 2 base 05FF80000 mask FFFF80000 uncachable [ 0.000000] 3 disabled [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] PAT not supported by CPU. [ 0.000000] original variable MTRRs [ 0.000000] reg 0, base: 0GB, range: 1GB, type WB [ 0.000000] reg 1, base: 1GB, range: 512MB, type WB [ 0.000000] reg 2, base: 1572352KB, range: 512KB, type UC [ 0.000000] total RAM covered: 1535M [ 0.000000] Found optimal setting for mtrr clean up [ 0.000000] gran_size: 64K chunk_size: 1M num_reg: 3 lose cover RAM: 0G [ 0.000000] New variable MTRRs [ 0.000000] reg 0, base: 0GB, range: 1GB, type WB [ 0.000000] reg 1, base: 1GB, range: 512MB, type WB [ 0.000000] reg 2, base: 1572352KB, range: 512KB, type UC [ 0.000000] Scanning 1 areas for low memory corruption [ 0.000000] initial memory mapped: [mem 0x00000000-0x01ffffff] [ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384 [ 0.000000] init_memory_mapping: [mem 0x00000000-0x000fffff] [ 0.000000] [mem 0x00000000-0x000fffff] page 4k [ 0.000000] init_memory_mapping: [mem 0x37200000-0x373fffff] [ 0.000000] [mem 0x37200000-0x373fffff] page 2M [ 0.000000] init_memory_mapping: [mem 0x34000000-0x371fffff] [ 0.000000] [mem 0x34000000-0x371fffff] page 2M [ 0.000000] init_memory_mapping: [mem 0x00100000-0x33ffffff] [ 0.000000] [mem 0x00100000-0x001fffff] page 4k [ 0.000000] [mem 0x00200000-0x33ffffff] page 2M [ 0.000000] init_memory_mapping: [mem 0x37400000-0x37bfdfff] [ 0.000000] [mem 0x37400000-0x379fffff] page 2M [ 0.000000] [mem 0x37a00000-0x37bfdfff] page 4k [ 0.000000] BRK [0x01ba6000, 0x01ba6fff] PGTABLE [ 0.000000] RAMDISK: [mem 0x374e8000-0x37a6bfff] [ 0.000000] ACPI: RSDP 000f6b40 000024 (v02 IBM ) [ 0.000000] ACPI: XSDT 5ff6ae9e 00004C (v01 IBM TP-1Q 00002150 LTP 00000000) [ 0.000000] ACPI: FACP 5ff6af00 0000F4 (v03 IBM TP-1Q 00002150 IBM 00000001) [ 0.000000] ACPI BIOS Warning (bug): 32/64X length mismatch in FADT/Gpe1Block: 0/32 (20131115/tbfadt-572) [ 0.000000] ACPI BIOS Warning (bug): Optional FADT field Gpe1Block has zero address or length: 0x000000000000102C/0x0 (20131115/tbfadt-603) [ 0.000000] ACPI: DSDT 5ff6b0e7 00CD04 (v01 IBM TP-1Q 00002150 MSFT 0100000E) [ 0.000000] ACPI: FACS 5ff79000 000040 [ 0.000000] ACPI: SSDT 5ff6b0b4 000033 (v01 IBM TP-1Q 00002150 MSFT 0100000E) [ 0.000000] ACPI: ECDT 5ff77deb 000052 (v01 IBM TP-1Q 00002150 IBM 00000001) [ 0.000000] ACPI: TCPA 5ff77e3d 000032 (v01 IBM TP-1Q 00002150 PTL 00000001) [ 0.000000] ACPI: BOOT 5ff77fd8 000028 (v01 IBM TP-1Q 00002150 LTP 00000001) [ 0.000000] 643MB HIGHMEM available. [ 0.000000] 891MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 37bfe000 [ 0.000000] low ram: 0 - 37bfe000 [ 0.000000] BRK [0x01ba7000, 0x01ba7fff] PGTABLE [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x00001000-0x00ffffff] [ 0.000000] Normal [mem 0x01000000-0x37bfdfff] [ 0.000000] HighMem [mem 0x37bfe000-0x5ff5ffff] [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x00001000-0x0009efff] [ 0.000000] node 0: [mem 0x00100000-0x5ff5ffff] [ 0.000000] On node 0 totalpages: 392958 [ 0.000000] free_area_init_node: node 0, pgdat c19ab980, node_mem_map f68e8020 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3998 pages, LIFO batch:0 [ 0.000000] Normal zone: 1752 pages used for memmap [ 0.000000] Normal zone: 224254 pages, LIFO batch:31 [ 0.000000] HighMem zone: 1287 pages used for memmap [ 0.000000] HighMem zone: 164706 pages, LIFO batch:31 [ 0.000000] Using APIC driver default [ 0.000000] ACPI: PM-Timer IO Port: 0x1008 [ 0.000000] smpboot: Allowing 1 CPUs, 0 hotplug CPUs [ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic" [ 0.000000] APIC: disable apic facility [ 0.000000] APIC: switched to apic NOOP [ 0.000000] nr_irqs_gsi: 16 [ 0.000000] PM: Registered nosave memory: [mem 0x0009f000-0x0009ffff] [ 0.000000] PM: Registered nosave memory: [mem 0x000a0000-0x000d1fff] [ 0.000000] PM: Registered nosave memory: [mem 0x000d2000-0x000d3fff] [ 0.000000] PM: Registered nosave memory: [mem 0x000d4000-0x000dbfff] [ 0.000000] PM: Registered nosave memory: [mem 0x000dc000-0x000fffff] [ 0.000000] e820: [mem 0x60000000-0xff7fffff] available for PCI devices [ 0.000000] Booting paravirtualized kernel on bare hardware [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 14 pages/cpu @f7be7000 s35520 r0 d21824 u57344 [ 0.000000] pcpu-alloc: s35520 r0 d21824 u57344 alloc=14*4096 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 391174 [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.13.0-107-generic root=UUID=3140e3dc-ef5f-466d-b233-db5ce654e223 ro forcepae quiet splash vt.handoff=7 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] allocated 3144440 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Initializing HighMem for node 0 (00037bfe:0005ff60) [ 0.000000] Memory: 1537924K/1571832K available (6587K kernel code, 642K rwdata, 2780K rodata, 884K init, 924K bss, 33908K reserved, 658824K highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xfff14000 - 0xfffff000 ( 940 kB) [ 0.000000] pkmap : 0xffc00000 - 0xffe00000 (2048 kB) [ 0.000000] vmalloc : 0xf83fe000 - 0xffbfe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf7bfe000 ( 891 MB) [ 0.000000] .init : 0xc19c9000 - 0xc1aa6000 ( 884 kB) [ 0.000000] .data : 0xc166f24a - 0xc19c8900 (3429 kB) [ 0.000000] .text : 0xc1000000 - 0xc166f24a (6588 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1. [ 0.000000] NR_IRQS:2304 nr_irqs:256 16 [ 0.000000] CPU 0 irqstacks, hard=f6008000 soft=f600a000 [ 0.000000] Console: colour dummy device 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] tsc: Fast TSC calibration using PIT [ 0.000000] tsc: Detected 1398.868 MHz processor [ 0.004005] Calibrating delay loop (skipped), value calculated using timer frequency.. 2797.73 BogoMIPS (lpj=5595472) [ 0.004012] pid_max: default: 32768 minimum: 301 [ 0.004074] Security Framework initialized [ 0.004117] AppArmor: AppArmor initialized [ 0.004121] Yama: becoming mindful. [ 0.004265] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.004271] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.004793] Initializing cgroup subsys memory [ 0.004815] Initializing cgroup subsys devices [ 0.004820] Initializing cgroup subsys freezer [ 0.004825] Initializing cgroup subsys blkio [ 0.004830] Initializing cgroup subsys perf_event [ 0.004836] Initializing cgroup subsys hugetlb [ 0.004884] PAE forced! [ 0.004888] Disabling lock debugging due to kernel taint [ 0.004901] mce: CPU supports 5 MCE banks [ 0.004938] Last level iTLB entries: 4KB 128, 2MB 0, 4MB 2 [ 0.004938] Last level dTLB entries: 4KB 128, 2MB 0, 4MB 8 [ 0.004938] tlb_flushall_shift: 6 [ 0.023469] Freeing SMP alternatives memory: 32K (c1aa6000 - c1aae000) [ 0.026020] ACPI: Core revision 20131115 [ 0.037885] ACPI: All ACPI Tables successfully acquired [ 0.037897] ACPI: setting ELCR to 0200 (from 0800) [ 0.040009] ftrace: allocating 27950 entries in 55 pages [ 0.056270] smpboot: weird, boot CPU (#0) not listed by the BIOS [ 0.056281] smpboot: SMP motherboard not detected [ 0.056285] smpboot: Local APIC not detected. Using dummy APIC emulation. [ 0.056288] smpboot: SMP disabled [ 0.056313] Performance Events: [ 0.056320] no APIC, boot with the "lapic" boot parameter to force-enable it. [ 0.056322] no hardware sampling interrupt available. [ 0.056327] p6 PMU driver. [ 0.056333] ... version: 0 [ 0.056335] ... bit width: 32 [ 0.056337] ... generic registers: 2 [ 0.056340] ... value mask: 00000000ffffffff [ 0.056343] ... max period: 000000007fffffff [ 0.056345] ... fixed-purpose events: 0 [ 0.056347] ... event mask: 0000000000000003 [ 0.061196] x86: Booted up 1 node, 1 CPUs [ 0.061206] smpboot: Total of 1 processors activated (2797.73 BogoMIPS) [ 0.061329] NMI watchdog: disabled (cpu0): not supported (no LAPIC?) [ 0.061542] devtmpfs: initialized [ 0.061967] EVM: security.selinux [ 0.061970] EVM: security.SMACK64 [ 0.061972] EVM: security.ima [ 0.061975] EVM: security.capability [ 0.062163] PM: Registering ACPI NVS region [mem 0x5ff78000-0x5ff79fff] (8192 bytes) [ 0.064542] pinctrl core: initialized pinctrl subsystem [ 0.064692] regulator-dummy: no parameters [ 0.064734] RTC time: 9:26:23, date: 02/10/17 [ 0.064816] NET: Registered protocol family 16 [ 0.065156] EISA bus registered [ 0.065161] cpuidle: using governor ladder [ 0.065164] cpuidle: using governor menu [ 0.065336] ACPI: bus type PCI registered [ 0.065340] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5 [ 0.065747] PCI: PCI BIOS revision 2.10 entry at 0xfd8d6, last bus=8 [ 0.065750] PCI: Using configuration type 1 for base access [ 0.068206] bio: create slab at 0 [ 0.068486] ACPI: Added _OSI(Module Device) [ 0.068490] ACPI: Added _OSI(Processor Device) [ 0.068493] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.068497] ACPI: Added _OSI(Processor Aggregator Device) [ 0.071477] ACPI : EC: EC description table is found, configuring boot EC [ 0.084701] ACPI: Interpreter enabled [ 0.084701] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S1_] (20131115/hwxface-580) [ 0.084701] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [\_S2_] (20131115/hwxface-580) [ 0.084701] ACPI: (supports S0 S3 S4 S5) [ 0.084701] ACPI: Using PIC for interrupt routing [ 0.084701] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug [ 0.085098] ACPI: ACPI Dock Station Driver: 3 docks/bays found [ 0.090490] ACPI: Power Resource [PUBS] (on) [ 0.101441] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 9 10 *11) [ 0.101649] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 9 10 *11) [ 0.101854] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 7 9 10 *11) [ 0.102058] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 7 9 10 *11) [ 0.102263] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 9 10 *11) [ 0.102417] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 9 10 11) *0, disabled. [ 0.102572] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 9 10 11) *0, disabled. [ 0.102778] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 9 10 *11) [ 0.102890] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.102902] acpi PNP0A03:00: _OSC: OS supports [ASPM ClockPM Segments MSI] [ 0.102912] acpi PNP0A03:00: _OSC failed (AE_NOT_FOUND); disabling ASPM [ 0.102957] acpi PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored) [ 0.102962] acpi PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored) [ 0.102967] acpi PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored) [ 0.102972] acpi PNP0A03:00: host bridge window [mem 0x000d4000-0x000d7fff] (ignored) [ 0.102976] acpi PNP0A03:00: host bridge window [mem 0x000d8000-0x000dbfff] (ignored) [ 0.102981] acpi PNP0A03:00: host bridge window [mem 0x60000000-0xfebfffff] (ignored) [ 0.102986] PCI: root bus 00: using default resources [ 0.102992] acpi PNP0A03:00: fail to add MMCONFIG information, can't access extended PCI configuration space under this bridge. [ 0.103213] PCI host bridge to bus 0000:00 [ 0.103220] pci_bus 0000:00: root bus resource [bus 00-ff] [ 0.103224] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] [ 0.103229] pci_bus 0000:00: root bus resource [mem 0x00000000-0xfffffffff] [ 0.103247] pci 0000:00:00.0: [8086:3340] type 00 class 0x060000 [ 0.103261] pci 0000:00:00.0: reg 0x10: [mem 0xd0000000-0xdfffffff pref] [ 0.103404] pci 0000:00:01.0: [8086:3341] type 01 class 0x060400 [ 0.103557] pci 0000:00:1d.0: [8086:24c2] type 00 class 0x0c0300 [ 0.103607] pci 0000:00:1d.0: reg 0x20: [io 0x1800-0x181f] [ 0.104061] pci 0000:00:1d.0: System wakeup disabled by ACPI [ 0.104130] pci 0000:00:1d.1: [8086:24c4] type 00 class 0x0c0300 [ 0.104182] pci 0000:00:1d.1: reg 0x20: [io 0x1820-0x183f] [ 0.104282] pci 0000:00:1d.1: System wakeup disabled by ACPI [ 0.104348] pci 0000:00:1d.2: [8086:24c7] type 00 class 0x0c0300 [ 0.104398] pci 0000:00:1d.2: reg 0x20: [io 0x1840-0x185f] [ 0.104499] pci 0000:00:1d.2: System wakeup disabled by ACPI [ 0.104579] pci 0000:00:1d.7: [8086:24cd] type 00 class 0x0c0320 [ 0.104605] pci 0000:00:1d.7: reg 0x10: [mem 0xc0000000-0xc00003ff] [ 0.104710] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold [ 0.104826] pci 0000:00:1e.0: [8086:2448] type 01 class 0x060400 [ 0.104911] pci 0000:00:1e.0: System wakeup disabled by ACPI [ 0.104973] pci 0000:00:1f.0: [8086:24cc] type 00 class 0x060100 [ 0.105050] pci 0000:00:1f.0: address space collision: [io 0x1000-0x107f] conflicts with ACPI CPU throttle [??? 0x00001010-0x00001015 flags 0x80000000] [ 0.105057] pci 0000:00:1f.0: quirk: [io 0x1180-0x11bf] claimed by ICH4 GPIO [ 0.105160] pci 0000:00:1f.1: [8086:24ca] type 00 class 0x01018a [ 0.105178] pci 0000:00:1f.1: reg 0x10: [io 0x0000-0x0007] [ 0.105191] pci 0000:00:1f.1: reg 0x14: [io 0x0000-0x0003] [ 0.105203] pci 0000:00:1f.1: reg 0x18: [io 0x0000-0x0007] [ 0.105216] pci 0000:00:1f.1: reg 0x1c: [io 0x0000-0x0003] [ 0.105228] pci 0000:00:1f.1: reg 0x20: [io 0x1860-0x186f] [ 0.105241] pci 0000:00:1f.1: reg 0x24: [mem 0x00000000-0x000003ff] [ 0.105354] pci 0000:00:1f.3: [8086:24c3] type 00 class 0x0c0500 [ 0.105405] pci 0000:00:1f.3: reg 0x20: [io 0x1880-0x189f] [ 0.105528] pci 0000:00:1f.5: [8086:24c5] type 00 class 0x040100 [ 0.105547] pci 0000:00:1f.5: reg 0x10: [io 0x1c00-0x1cff] [ 0.105559] pci 0000:00:1f.5: reg 0x14: [io 0x18c0-0x18ff] [ 0.105571] pci 0000:00:1f.5: reg 0x18: [mem 0xc0000c00-0xc0000dff] [ 0.105583] pci 0000:00:1f.5: reg 0x1c: [mem 0xc0000800-0xc00008ff] [ 0.105636] pci 0000:00:1f.5: PME# supported from D0 D3hot D3cold [ 0.105739] pci 0000:00:1f.6: [8086:24c6] type 00 class 0x070300 [ 0.105758] pci 0000:00:1f.6: reg 0x10: [io 0x2400-0x24ff] [ 0.105770] pci 0000:00:1f.6: reg 0x14: [io 0x2000-0x207f] [ 0.105838] pci 0000:00:1f.6: PME# supported from D0 D3hot D3cold [ 0.105900] pci 0000:00:1f.6: System wakeup disabled by ACPI [ 0.106034] pci 0000:01:00.0: [1002:4c59] type 00 class 0x030000 [ 0.106053] pci 0000:01:00.0: reg 0x10: [mem 0xe0000000-0xe7ffffff pref] [ 0.106064] pci 0000:01:00.0: reg 0x14: [io 0x3000-0x30ff] [ 0.106074] pci 0000:01:00.0: reg 0x18: [mem 0xc0100000-0xc010ffff] [ 0.106103] pci 0000:01:00.0: reg 0x30: [mem 0x00000000-0x0001ffff pref] [ 0.106137] pci 0000:01:00.0: supports D1 D2 [ 0.106237] pci 0000:00:01.0: PCI bridge to [bus 01] [ 0.106242] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff] [ 0.106248] pci 0000:00:01.0: bridge window [mem 0xc0100000-0xc01fffff] [ 0.106254] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe7ffffff pref] [ 0.106393] acpiphp: Slot [1-1] registered [ 0.106415] pci 0000:02:00.0: [1180:0476] type 02 class 0x060700 [ 0.106433] pci 0000:02:00.0: proprietary Ricoh MMC controller disabled (via cardbus function) [ 0.106437] pci 0000:02:00.0: MMC cards are now supported by standard SDHCI controller [ 0.106452] pci 0000:02:00.0: reg 0x10: [mem 0xb0000000-0xb0000fff] [ 0.106483] pci 0000:02:00.0: supports D1 D2 [ 0.106488] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.106579] pci 0000:02:00.1: [1180:0476] type 02 class 0x060700 [ 0.106599] pci 0000:02:00.1: reg 0x10: [mem 0xb1000000-0xb1000fff] [ 0.106630] pci 0000:02:00.1: supports D1 D2 [ 0.106634] pci 0000:02:00.1: PME# supported from D0 D1 D2 D3hot D3cold [ 0.106729] pci 0000:02:00.2: [1180:0552] type 00 class 0x0c0010 [ 0.106749] pci 0000:02:00.2: reg 0x10: [mem 0xc0202000-0xc02027ff] [ 0.106825] pci 0000:02:00.2: PME# supported from D0 D3hot D3cold [ 0.106925] pci 0000:02:02.0: [8086:1043] type 00 class 0x028000 [ 0.106946] pci 0000:02:02.0: reg 0x10: [mem 0xc0200000-0xc0200fff] [ 0.107103] pci 0000:02:08.0: [8086:103d] type 00 class 0x020000 [ 0.107123] pci 0000:02:08.0: reg 0x10: [mem 0xc0201000-0xc0201fff] [ 0.107135] pci 0000:02:08.0: reg 0x14: [io 0x8000-0x803f] [ 0.107203] pci 0000:02:08.0: supports D1 D2 [ 0.107207] pci 0000:02:08.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.107317] pci 0000:00:1e.0: PCI bridge to [bus 02-08] (subtractive decode) [ 0.107324] pci 0000:00:1e.0: bridge window [io 0x4000-0x8fff] [ 0.107331] pci 0000:00:1e.0: bridge window [mem 0xc0200000-0xcfffffff] [ 0.107338] pci 0000:00:1e.0: bridge window [mem 0xe8000000-0xefffffff pref] [ 0.107342] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode) [ 0.107347] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xfffffffff] (subtractive decode) [ 0.107414] pci_bus 0000:03: busn_res: can not insert [bus 03-ff] under [bus 02-08] (conflicts with (null) [bus 02-08]) [ 0.107422] pci_bus 0000:03: busn_res: [bus 03-ff] end is updated to 06 [ 0.107481] pci_bus 0000:07: busn_res: can not insert [bus 07-ff] under [bus 02-08] (conflicts with (null) [bus 02-08]) [ 0.107487] pci_bus 0000:07: busn_res: [bus 07-ff] end is updated to 07 [ 0.107504] pci_bus 0000:00: on NUMA node 0 [ 0.109082] ACPI: \_SB_.PCI0: notify handler is installed [ 0.109160] Found 1 acpi root devices [ 0.109319] ACPI : EC: GPE = 0x1c, I/O: command/status = 0x66, data = 0x62 [ 0.109548] vgaarb: setting as boot device: PCI:0000:01:00.0 [ 0.109552] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none [ 0.109557] vgaarb: loaded [ 0.109560] vgaarb: bridge control possible 0000:01:00.0 [ 0.110045] SCSI subsystem initialized [ 0.110141] libata version 3.00 loaded. [ 0.110198] ACPI: bus type USB registered [ 0.110244] usbcore: registered new interface driver usbfs [ 0.110264] usbcore: registered new interface driver hub [ 0.110307] usbcore: registered new device driver usb [ 0.110502] PCI: Using ACPI for IRQ routing [ 0.110642] PCI: pci_cache_line_size set to 64 bytes [ 0.110709] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff] [ 0.110714] e820: reserve RAM buffer [mem 0x5ff60000-0x5fffffff] [ 0.110914] NetLabel: Initializing [ 0.110917] NetLabel: domain hash size = 128 [ 0.110919] NetLabel: protocols = UNLABELED CIPSOv4 [ 0.110944] NetLabel: unlabeled traffic allowed by default [ 0.111206] Switched to clocksource pit [ 0.123865] AppArmor: AppArmor Filesystem Enabled [ 0.123969] pnp: PnP ACPI init [ 0.124006] ACPI: bus type PNP registered [ 0.125074] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.125081] system 00:00: [mem 0x000c0000-0x000c3fff] could not be reserved [ 0.125086] system 00:00: [mem 0x000c4000-0x000c7fff] could not be reserved [ 0.125091] system 00:00: [mem 0x000c8000-0x000cbfff] could not be reserved [ 0.125096] system 00:00: [mem 0x000cc000-0x000cffff] could not be reserved [ 0.125101] system 00:00: [mem 0x000d0000-0x000d3fff] could not be reserved [ 0.125107] system 00:00: [mem 0x000dc000-0x000dffff] could not be reserved [ 0.125112] system 00:00: [mem 0x000e0000-0x000e3fff] could not be reserved [ 0.125117] system 00:00: [mem 0x000e4000-0x000e7fff] could not be reserved [ 0.125122] system 00:00: [mem 0x000e8000-0x000ebfff] could not be reserved [ 0.125127] system 00:00: [mem 0x000ec000-0x000effff] could not be reserved [ 0.125132] system 00:00: [mem 0x000f0000-0x000fffff] could not be reserved [ 0.125138] system 00:00: [mem 0x00100000-0x5fffffff] could not be reserved [ 0.125143] system 00:00: [mem 0xfec00000-0xffffffff] could not be reserved [ 0.125152] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.125314] system 00:01: [io 0x1000-0x107f] could not be reserved [ 0.125320] system 00:01: [io 0x1180-0x11bf] has been reserved [ 0.125325] system 00:01: [io 0x15e0-0x15ef] has been reserved [ 0.125330] system 00:01: [io 0x1600-0x167f] has been reserved [ 0.125336] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.125366] pnp 00:02: [dma 4] [ 0.125406] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.125457] pnp 00:03: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.125527] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.125584] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.125638] pnp 00:06: Plug and Play ACPI device, IDs PNP0303 (active) [ 0.125699] pnp 00:07: Plug and Play ACPI device, IDs IBM3780 PNP0f13 (active) [ 0.125753] pnp 00:08: [dma 2] [ 0.125813] pnp 00:08: Plug and Play ACPI device, IDs PNP0700 (active) [ 0.125970] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (disabled) [ 0.126230] pnp 00:0a: Plug and Play ACPI device, IDs PNP0400 (active) [ 0.126413] pnp 00:0b: Plug and Play ACPI device, IDs IBM0071 PNP0511 (disabled) [ 0.127503] pnp: PnP ACPI: found 12 devices [ 0.127506] ACPI: bus type PNP unregistered [ 0.127512] PnPBIOS: Disabled by ACPI PNP [ 0.165178] Switched to clocksource acpi_pm [ 0.165229] pci 0000:00:1f.0: BAR 13: [io 0x1000-0x107f] has bogus alignment [ 0.165247] pci 0000:00:1f.1: BAR 5: assigned [mem 0x60000000-0x600003ff] [ 0.165260] pci 0000:01:00.0: BAR 6: assigned [mem 0xc0120000-0xc013ffff pref] [ 0.165265] pci 0000:00:01.0: PCI bridge to [bus 01] [ 0.165270] pci 0000:00:01.0: bridge window [io 0x3000-0x3fff] [ 0.165277] pci 0000:00:01.0: bridge window [mem 0xc0100000-0xc01fffff] [ 0.165283] pci 0000:00:01.0: bridge window [mem 0xe0000000-0xe7ffffff pref] [ 0.165298] pci 0000:02:00.0: res[15]=[mem 0x04000000-0x03ffffff pref] get_res_add_size add_size 4000000 [ 0.165303] pci 0000:02:00.0: res[16]=[mem 0x04000000-0x03ffffff] get_res_add_size add_size 4000000 [ 0.165309] pci 0000:02:00.1: res[15]=[mem 0x04000000-0x03ffffff pref] get_res_add_size add_size 4000000 [ 0.165314] pci 0000:02:00.1: res[16]=[mem 0x04000000-0x03ffffff] get_res_add_size add_size 4000000 [ 0.165319] pci 0000:02:00.0: res[13]=[io 0x0100-0x00ff] get_res_add_size add_size 100 [ 0.165323] pci 0000:02:00.0: res[14]=[io 0x0100-0x00ff] get_res_add_size add_size 100 [ 0.165328] pci 0000:02:00.1: res[13]=[io 0x0100-0x00ff] get_res_add_size add_size 100 [ 0.165332] pci 0000:02:00.1: res[14]=[io 0x0100-0x00ff] get_res_add_size add_size 100 [ 0.165338] pci 0000:02:00.0: BAR 15: assigned [mem 0xe8000000-0xebffffff pref] [ 0.165343] pci 0000:02:00.0: BAR 16: assigned [mem 0xc4000000-0xc7ffffff] [ 0.165348] pci 0000:02:00.1: BAR 15: assigned [mem 0xec000000-0xefffffff pref] [ 0.165354] pci 0000:02:00.1: BAR 16: assigned [mem 0xc8000000-0xcbffffff] [ 0.165359] pci 0000:02:00.0: BAR 13: assigned [io 0x4000-0x40ff] [ 0.165363] pci 0000:02:00.0: BAR 14: assigned [io 0x4400-0x44ff] [ 0.165368] pci 0000:02:00.1: BAR 13: assigned [io 0x4800-0x48ff] [ 0.165373] pci 0000:02:00.1: BAR 14: assigned [io 0x4c00-0x4cff] [ 0.165379] pci 0000:02:00.0: CardBus bridge to [bus 03-06] [ 0.165383] pci 0000:02:00.0: bridge window [io 0x4000-0x40ff] [ 0.165389] pci 0000:02:00.0: bridge window [io 0x4400-0x44ff] [ 0.165396] pci 0000:02:00.0: bridge window [mem 0xe8000000-0xebffffff pref] [ 0.165402] pci 0000:02:00.0: bridge window [mem 0xc4000000-0xc7ffffff] [ 0.165409] pci 0000:02:00.1: CardBus bridge to [bus 07] [ 0.165413] pci 0000:02:00.1: bridge window [io 0x4800-0x48ff] [ 0.165419] pci 0000:02:00.1: bridge window [io 0x4c00-0x4cff] [ 0.165426] pci 0000:02:00.1: bridge window [mem 0xec000000-0xefffffff pref] [ 0.165432] pci 0000:02:00.1: bridge window [mem 0xc8000000-0xcbffffff] [ 0.165439] pci 0000:00:1e.0: PCI bridge to [bus 02-08] [ 0.165444] pci 0000:00:1e.0: bridge window [io 0x4000-0x8fff] [ 0.165452] pci 0000:00:1e.0: bridge window [mem 0xc0200000-0xcfffffff] [ 0.165459] pci 0000:00:1e.0: bridge window [mem 0xe8000000-0xefffffff pref] [ 0.165469] pci_bus 0000:00: resource 4 [io 0x0000-0xffff] [ 0.165474] pci_bus 0000:00: resource 5 [mem 0x00000000-0xfffffffff] [ 0.165479] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff] [ 0.165483] pci_bus 0000:01: resource 1 [mem 0xc0100000-0xc01fffff] [ 0.165488] pci_bus 0000:01: resource 2 [mem 0xe0000000-0xe7ffffff pref] [ 0.165493] pci_bus 0000:02: resource 0 [io 0x4000-0x8fff] [ 0.165497] pci_bus 0000:02: resource 1 [mem 0xc0200000-0xcfffffff] [ 0.165502] pci_bus 0000:02: resource 2 [mem 0xe8000000-0xefffffff pref] [ 0.165506] pci_bus 0000:02: resource 4 [io 0x0000-0xffff] [ 0.165510] pci_bus 0000:02: resource 5 [mem 0x00000000-0xfffffffff] [ 0.165515] pci_bus 0000:03: resource 0 [io 0x4000-0x40ff] [ 0.165519] pci_bus 0000:03: resource 1 [io 0x4400-0x44ff] [ 0.165524] pci_bus 0000:03: resource 2 [mem 0xe8000000-0xebffffff pref] [ 0.165528] pci_bus 0000:03: resource 3 [mem 0xc4000000-0xc7ffffff] [ 0.165533] pci_bus 0000:07: resource 0 [io 0x4800-0x48ff] [ 0.165537] pci_bus 0000:07: resource 1 [io 0x4c00-0x4cff] [ 0.165542] pci_bus 0000:07: resource 2 [mem 0xec000000-0xefffffff pref] [ 0.165546] pci_bus 0000:07: resource 3 [mem 0xc8000000-0xcbffffff] [ 0.165629] NET: Registered protocol family 2 [ 0.166132] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.166180] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 0.166263] TCP: Hash tables configured (established 8192 bind 8192) [ 0.166333] TCP: reno registered [ 0.166339] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.166363] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.166492] NET: Registered protocol family 1 [ 0.166888] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11 [ 0.166894] PCI: setting IRQ 11 as level-triggered [ 0.167204] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 11 [ 0.167501] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 11 [ 0.167797] ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 11 [ 0.167888] pci 0000:01:00.0: Video device with shadowed ROM [ 0.167917] pci 0000:02:08.0: Firmware left e100 interrupts enabled; disabling [ 0.167923] PCI: CLS 32 bytes, default 64 [ 0.168042] Trying to unpack rootfs image as initramfs... [ 0.406368] Freeing initrd memory: 5648K (f74e8000 - f7a6c000) [ 0.406632] Simple Boot Flag at 0x35 set to 0x1 [ 0.406815] microcode: CPU0 sig=0x695, pf=0x20, revision=0x5 [ 0.406939] microcode: Microcode Update Driver: v2.00 , Peter Oruba [ 0.406944] Scanning for low memory corruption every 60 seconds [ 0.407476] Initialise system trusted keyring [ 0.407570] audit: initializing netlink socket (disabled) [ 0.407598] type=2000 audit(1486718783.401:1): initialized [ 0.451059] bounce pool size: 64 pages [ 0.451095] HugeTLB registered 2 MB page size, pre-allocated 0 pages [ 0.453939] zbud: loaded [ 0.454083] VFS: Disk quotas dquot_6.5.2 [ 0.454182] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.455138] fuse init (API version 7.22) [ 0.455291] msgmni has been set to 1728 [ 0.455408] Key type big_key registered [ 0.455859] Key type asymmetric registered [ 0.455863] Asymmetric key parser 'x509' registered [ 0.455933] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252) [ 0.455982] io scheduler noop registered [ 0.455986] io scheduler deadline registered (default) [ 0.456081] io scheduler cfq registered [ 0.456323] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 0.456356] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 0.456451] vesafb: mode is 1024x768x32, linelength=4096, pages=0 [ 0.456454] vesafb: scrolling: redraw [ 0.456458] vesafb: Truecolor: size=0:8:8:8, shift=0:16:8:0 [ 0.457386] vesafb: framebuffer at 0xe0000000, mapped to 0xf8480000, using 3072k, total 3072k [ 0.475707] Console: switching to colour frame buffer device 128x48 [ 0.493794] fb0: VESA VGA frame buffer device [ 0.493847] intel_idle: does not run on family 6 model 9 [ 0.493860] ipmi message handler version 39.2 [ 0.494053] ACPI: Deprecated procfs I/F for AC is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared [ 0.494244] ACPI: AC Adapter [AC] (on-line) [ 0.494580] input: Lid Switch as /devices/LNXSYSTM:00/device:00/PNP0C0D:00/input/input0 [ 0.494723] ACPI: Lid Switch [LID] [ 0.494804] input: Sleep Button as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input1 [ 0.494812] ACPI: Sleep Button [SLPB] [ 0.494892] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2 [ 0.494897] ACPI: Power Button [PWRF] [ 0.495390] tsc: Marking TSC unstable due to TSC halts in idle [ 0.495404] ACPI: acpi_idle registered with cpuidle [ 0.497034] thermal LNXTHERM:00: registered as thermal_zone0 [ 0.497038] ACPI: Thermal Zone [THM0] (53 C) [ 0.497077] GHES: HEST is not enabled! [ 0.497295] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled [ 0.497495] serial 00:09: [io 0x03f8-0x03ff] [ 0.497551] serial 00:09: [irq 4] [ 0.497946] serial 00:09: activated [ 0.498015] 00:09: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 921600) is a NS16550A [ 0.500558] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11 [ 0.500835] Linux agpgart interface v0.103 [ 0.500977] agpgart-intel 0000:00:00.0: Intel 855PM Chipset [ 0.514575] isapnp: Scanning for PnP cards... [ 0.563736] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xd0000000 [ 0.566841] brd: module loaded [ 0.569903] loop: module loaded [ 0.570646] ata_piix 0000:00:1f.1: version 2.13 [ 0.570694] ata_piix 0000:00:1f.1: enabling device (0005 -> 0007) [ 0.573199] scsi0 : ata_piix [ 0.573536] scsi1 : ata_piix [ 0.573607] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1860 irq 14 [ 0.573611] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1868 irq 15 [ 0.574328] libphy: Fixed MDIO Bus: probed [ 0.574560] tun: Universal TUN/TAP device driver, 1.6 [ 0.574562] tun: (C) 1999-2004 Max Krasnyansky [ 0.574786] PPP generic driver version 2.4.2 [ 0.574982] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.575023] ehci-pci: EHCI PCI platform driver [ 0.575349] ehci-pci 0000:00:1d.7: EHCI Host Controller [ 0.575403] ehci-pci 0000:00:1d.7: new USB bus registered, assigned bus number 1 [ 0.575456] ehci-pci 0000:00:1d.7: debug port 1 [ 0.579437] ehci-pci 0000:00:1d.7: cache line size of 32 is not supported [ 0.579459] ehci-pci 0000:00:1d.7: irq 11, io mem 0xc0000000 [ 0.623454] ehci-pci 0000:00:1d.7: USB 2.0 started, EHCI 1.00 [ 0.623628] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 0.623634] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.623638] usb usb1: Product: EHCI Host Controller [ 0.623643] usb usb1: Manufacturer: Linux 3.13.0-107-generic ehci_hcd [ 0.623646] usb usb1: SerialNumber: 0000:00:1d.7 [ 0.623851] hub 1-0:1.0: USB hub found [ 0.623867] hub 1-0:1.0: 6 ports detected [ 0.624253] ehci-platform: EHCI generic platform driver [ 0.624273] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.624276] ohci-pci: OHCI PCI platform driver [ 0.624297] ohci-platform: OHCI generic platform driver [ 0.624312] uhci_hcd: USB Universal Host Controller Interface driver [ 0.624385] uhci_hcd 0000:00:1d.0: UHCI Host Controller [ 0.624395] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2 [ 0.624423] uhci_hcd 0000:00:1d.0: irq 11, io base 0x00001800 [ 0.624521] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.624525] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.624529] usb usb2: Product: UHCI Host Controller [ 0.624534] usb usb2: Manufacturer: Linux 3.13.0-107-generic uhci_hcd [ 0.624537] usb usb2: SerialNumber: 0000:00:1d.0 [ 0.624716] hub 2-0:1.0: USB hub found [ 0.624729] hub 2-0:1.0: 2 ports detected [ 0.624939] uhci_hcd 0000:00:1d.1: UHCI Host Controller [ 0.624949] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3 [ 0.624974] uhci_hcd 0000:00:1d.1: irq 11, io base 0x00001820 [ 0.625059] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.625064] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.625068] usb usb3: Product: UHCI Host Controller [ 0.625072] usb usb3: Manufacturer: Linux 3.13.0-107-generic uhci_hcd [ 0.625076] usb usb3: SerialNumber: 0000:00:1d.1 [ 0.625247] hub 3-0:1.0: USB hub found [ 0.625265] hub 3-0:1.0: 2 ports detected [ 0.625456] uhci_hcd 0000:00:1d.2: UHCI Host Controller [ 0.625466] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4 [ 0.625491] uhci_hcd 0000:00:1d.2: irq 11, io base 0x00001840 [ 0.625578] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 0.625583] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 0.625587] usb usb4: Product: UHCI Host Controller [ 0.625591] usb usb4: Manufacturer: Linux 3.13.0-107-generic uhci_hcd [ 0.625595] usb usb4: SerialNumber: 0000:00:1d.2 [ 0.625761] hub 4-0:1.0: USB hub found [ 0.625774] hub 4-0:1.0: 2 ports detected [ 0.626055] i8042: PNP: PS/2 Controller [PNP0303:KBD,PNP0f13:MOU] at 0x60,0x64 irq 1,12 [ 0.675872] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 0.675882] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 0.676112] mousedev: PS/2 mouse device common for all mice [ 0.676367] rtc_cmos 00:05: RTC can wake from S4 [ 0.676511] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0 [ 0.676534] rtc_cmos 00:05: alarms up to one month, y3k, 114 bytes nvram [ 0.676713] device-mapper: uevent: version 1.0.3 [ 0.676829] device-mapper: ioctl: 4.27.0-ioctl (2013-10-30) initialised: dm-devel@redhat.com [ 0.676873] platform eisa.0: Probing EISA bus 0 [ 0.676882] platform eisa.0: Cannot allocate resource for EISA slot 1 [ 0.676888] platform eisa.0: Cannot allocate resource for EISA slot 2 [ 0.676908] platform eisa.0: Cannot allocate resource for EISA slot 3 [ 0.676913] platform eisa.0: Cannot allocate resource for EISA slot 4 [ 0.676918] platform eisa.0: Cannot allocate resource for EISA slot 5 [ 0.676923] platform eisa.0: Cannot allocate resource for EISA slot 6 [ 0.676927] platform eisa.0: Cannot allocate resource for EISA slot 7 [ 0.676932] platform eisa.0: Cannot allocate resource for EISA slot 8 [ 0.676936] platform eisa.0: EISA: Detected 0 cards [ 0.676949] cpufreq-nforce2: No nForce2 chipset. [ 0.676955] ledtrig-cpu: registered to indicate activity on CPUs [ 0.677242] TCP: cubic registered [ 0.677448] NET: Registered protocol family 10 [ 0.677862] NET: Registered protocol family 17 [ 0.677883] Key type dns_resolver registered [ 0.678196] Using IPI No-Shortcut mode [ 0.678338] Loading compiled-in X.509 certificates [ 0.685942] Loaded X.509 cert 'Magrathea: Glacier signing key: 9480fc27b1a1d69e87a4facd6dad1ccfa3c12015' [ 0.685968] registered taskstats version 1 [ 0.686703] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3 [ 0.864895] isapnp: No Plug & Play device found [ 0.865021] Key type trusted registered [ 0.866796] ata1.00: HPA detected: current 73004018, native 78140160 [ 0.866804] ata1.00: ATA-6: HTS541040G9AT00, MB2OA60A, max UDMA/100 [ 0.866808] ata1.00: 73004018 sectors, multi 16: LBA [ 0.868091] ACPI: Deprecated procfs I/F for battery is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared [ 0.868108] ACPI: Battery Slot [BAT0] (battery present) [ 0.873821] Key type encrypted registered [ 0.873832] AppArmor: AppArmor sha1 policy hashing enabled [ 0.873837] IMA: No TPM chip found, activating TPM-bypass! [ 0.874175] regulator-dummy: disabling [ 0.874245] Magic number: 5:54:424 [ 0.874433] rtc_cmos 00:05: setting system clock to 2017-02-10 09:26:24 UTC (1486718784) [ 0.875303] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found [ 0.875307] EDD information not available. [ 0.875372] PM: Hibernation image not present or could not be loaded. [ 0.880539] ata1.00: configured for UDMA/100 [ 0.880752] scsi 0:0:0:0: Direct-Access ATA HTS541040G9AT00 MB2O PQ: 0 ANSI: 5 [ 0.881056] sd 0:0:0:0: [sda] 73004018 512-byte logical blocks: (37.3 GB/34.8 GiB) [ 0.881151] sd 0:0:0:0: [sda] Write Protect is off [ 0.881156] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00 [ 0.881198] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 0.881643] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 0.931268] sda: sda1 sda2 < sda5 > [ 0.931744] sd 0:0:0:0: [sda] Attached SCSI disk [ 0.932411] Freeing unused kernel memory: 884K (c19c9000 - c1aa6000) [ 0.932506] Write protecting the kernel text: 6592k [ 0.932638] Write protecting the kernel read-only data: 2784k [ 0.956351] systemd-udevd[97]: starting version 204 [ 1.044395] Floppy drive(s): fd0 is 1.44M [ 1.066162] FDC 0 is a National Semiconductor PC87306 [ 1.484903] psmouse serio1: alps: Unknown ALPS touchpad: E7=10 00 64, EC=10 00 64 [ 1.528552] EXT4-fs (sda1): INFO: recovery required on readonly filesystem [ 1.528561] EXT4-fs (sda1): write access will be enabled during recovery [ 1.821739] psmouse serio1: trackpoint: IBM TrackPoint firmware: 0x0e, buttons: 3/3 [ 1.835241] input: TPPS/2 IBM TrackPoint as /devices/platform/i8042/serio1/input/input5 [ 1.984048] usb 3-1: new full-speed USB device number 2 using uhci_hcd [ 2.109991] EXT4-fs (sda1): recovery complete [ 2.120671] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null) [ 2.151108] usb 3-1: New USB device found, idVendor=03eb, idProduct=0902 [ 2.151117] usb 3-1: New USB device strings: Mfr=0, Product=2, SerialNumber=0 [ 2.151122] usb 3-1: Product: USB 2.0 Hub [ 2.154152] hub 3-1:1.0: USB hub found [ 2.156103] hub 3-1:1.0: 4 ports detected [ 2.400055] usb 3-2: new full-speed USB device number 3 using uhci_hcd [ 2.569116] usb 3-2: New USB device found, idVendor=045e, idProduct=07b2 [ 2.569122] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 2.569127] usb 3-2: Product: Microsoft\xffffffc2\xffffffae\xffffffae Nano Transceiver v1.0 [ 2.569131] usb 3-2: Manufacturer: Microsoft [ 2.674694] random: nonblocking pool is initialized [ 2.812047] usb 4-1: new full-speed USB device number 2 using uhci_hcd [ 3.004654] usb 4-1: New USB device found, idVendor=1668, idProduct=0441 [ 3.004662] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0 [ 4.282348] init: plymouth-upstart-bridge main process (148) terminated with status 1 [ 4.282373] init: plymouth-upstart-bridge main process ended, respawning [ 4.289520] init: plymouth-upstart-bridge main process (160) terminated with status 1 [ 4.289546] init: plymouth-upstart-bridge main process ended, respawning [ 4.296504] init: plymouth-upstart-bridge main process (162) terminated with status 1 [ 4.296530] init: plymouth-upstart-bridge main process ended, respawning [ 4.303375] init: plymouth-upstart-bridge main process (164) terminated with status 1 [ 4.303400] init: plymouth-upstart-bridge main process ended, respawning [ 4.311462] init: plymouth-upstart-bridge main process (167) terminated with status 1 [ 4.311489] init: plymouth-upstart-bridge main process ended, respawning [ 15.360656] Adding 1569788k swap on /dev/sda5. Priority:-1 extents:1 across:1569788k FS [ 15.760790] systemd-udevd[270]: starting version 204 [ 16.063527] lp: driver loaded but no devices found [ 16.119378] ppdev: user-space parallel port driver [ 16.160282] parport_pc 00:0a: reported by Plug and Play ACPI [ 16.160332] parport0: PC-style at 0x3bc, irq 7 [PCSPP,TRISTATE] [ 16.249253] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro [ 16.260359] lp0: using parport0 (interrupt-driven). [ 16.304685] ACPI: Video Device [VID] (multi-head: yes rom: no post: no) [ 16.315350] input: Video Bus as /devices/LNXSYSTM:00/device:00/PNP0A03:00/device:03/LNXVIDEO:00/input/input6 [ 17.136129] type=1400 audit(1486718800.761:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/sbin/dhclient" pid=360 comm="apparmor_parser" [ 17.136140] type=1400 audit(1486718800.761:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=360 comm="apparmor_parser" [ 17.136148] type=1400 audit(1486718800.761:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=360 comm="apparmor_parser" [ 18.594336] init: bluetooth main process (463) terminated with status 1 [ 18.594363] init: bluetooth main process ended, respawning [ 18.614297] init: Failed to spawn smbd main process: unable to execute: No such file or directory [ 18.642233] init: Failed to spawn samba-ad-dc main process: unable to execute: No such file or directory [ 19.363311] type=1400 audit(1486718802.985:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=618 comm="apparmor_parser" [ 19.363330] type=1400 audit(1486718802.985:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/cupsd" pid=618 comm="apparmor_parser" [ 19.454741] init: bluetooth main process (619) terminated with status 1 [ 19.454769] init: bluetooth main process ended, respawning [ 19.934077] init: failsafe main process (508) killed by TERM signal [ 20.475075] init: cups main process (631) killed by HUP signal [ 20.475103] init: cups main process ended, respawning [ 20.479719] init: bluetooth main process (708) terminated with status 1 [ 20.479747] init: bluetooth main process ended, respawning [ 20.833065] init: bluetooth main process (767) terminated with status 1 [ 20.833092] init: bluetooth main process ended, respawning [ 21.012492] init: bluetooth main process (807) terminated with status 1 [ 21.012520] init: bluetooth main process ended, respawning [ 21.182670] init: bluetooth main process (832) terminated with status 1 [ 21.182696] init: bluetooth main process ended, respawning [ 21.424536] init: bluetooth main process (864) terminated with status 1 [ 21.424566] init: bluetooth main process ended, respawning [ 21.639374] init: bluetooth main process (896) terminated with status 1 [ 21.639408] init: bluetooth main process ended, respawning [ 21.770692] init: bluetooth main process (920) terminated with status 1 [ 21.770722] init: bluetooth main process ended, respawning [ 21.892291] init: bluetooth main process (944) terminated with status 1 [ 21.892320] init: bluetooth main process ended, respawning [ 22.022643] init: bluetooth main process (968) terminated with status 1 [ 22.022671] init: bluetooth respawning too fast, stopped [ 24.407829] type=1400 audit(1486718808.028:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=1039 comm="apparmor_parser" [ 24.407849] type=1400 audit(1486718808.028:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="chromium" pid=1039 comm="apparmor_parser" [ 24.413488] type=1400 audit(1486718808.036:9): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/sbin/dhclient" pid=1040 comm="apparmor_parser" [ 24.413509] type=1400 audit(1486718808.036:10): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=1040 comm="apparmor_parser" [ 24.413520] type=1400 audit(1486718808.036:11): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/connman/scripts/dhclient-script" pid=1040 comm="apparmor_parser" [ 24.445080] type=1400 audit(1486718808.068:12): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince" pid=1041 comm="apparmor_parser" [ 24.445102] type=1400 audit(1486718808.068:13): apparmor="STATUS" operation="profile_load" profile="unconfined" name="sanitized_helper" pid=1041 comm="apparmor_parser" [ 24.445112] type=1400 audit(1486718808.068:14): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince-previewer" pid=1041 comm="apparmor_parser" [ 24.445122] type=1400 audit(1486718808.068:15): apparmor="STATUS" operation="profile_load" profile="unconfined" name="sanitized_helper" pid=1041 comm="apparmor_parser" [ 24.445132] type=1400 audit(1486718808.068:16): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/evince-thumbnailer" pid=1041 comm="apparmor_parser" [ 24.830899] init: Failed to spawn gpu-manager main process: unable to execute: No such file or directory [ 27.921142] init: plymouth-upstart-bridge main process ended, respawning [ 27.959619] init: plymouth-upstart-bridge main process (1265) terminated with status 1 [ 27.959649] init: plymouth-upstart-bridge main process ended, respawning [ 49.572637] audit_printk_skb: 18 callbacks suppressed [ 49.572645] type=1400 audit(1486718833.196:23): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/cups/backend/cups-pdf" pid=1559 comm="apparmor_parser" [ 49.572662] type=1400 audit(1486718833.196:24): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/sbin/cupsd" pid=1559 comm="apparmor_parser" [ 1808.344094] usb 3-1: reset full-speed USB device number 2 using uhci_hcd [ 1808.464060] usb 3-1: device descriptor read/64, error -71 [ 1808.688060] usb 3-1: device descriptor read/64, error -71 [ 1808.904061] usb 3-1: reset full-speed USB device number 2 using uhci_hcd [ 1809.024075] usb 3-1: device descriptor read/64, error -71 [ 1809.248059] usb 3-1: device descriptor read/64, error -71 [ 1809.464061] usb 3-1: reset full-speed USB device number 2 using uhci_hcd [ 1809.872060] usb 3-1: device not accepting address 2, error -71 [ 1809.984061] usb 3-1: reset full-speed USB device number 2 using uhci_hcd [ 1810.392061] usb 3-1: device not accepting address 2, error -71 [ 1810.392133] usb 3-1: USB disconnect, device number 2 [ 1810.632067] usb 3-1: new full-speed USB device number 4 using uhci_hcd [ 1810.752060] usb 3-1: device descriptor read/64, error -71 [ 1810.976060] usb 3-1: device descriptor read/64, error -71 [ 1811.192060] usb 3-1: new full-speed USB device number 5 using uhci_hcd [ 1811.312071] usb 3-1: device descriptor read/64, error -71 [ 1811.536060] usb 3-1: device descriptor read/64, error -71 [ 1811.752061] usb 3-1: new full-speed USB device number 6 using uhci_hcd [ 1812.160062] usb 3-1: device not accepting address 6, error -71 [ 1812.272061] usb 3-1: new full-speed USB device number 7 using uhci_hcd [ 1812.680060] usb 3-1: device not accepting address 7, error -71 [ 1812.680100] hub 3-0:1.0: unable to enumerate USB device on port 1 [ 1934.892066] usb 1-3: new high-speed USB device number 6 using ehci-pci [ 1935.026331] usb 1-3: New USB device found, idVendor=090c, idProduct=1000 [ 1935.026345] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 1935.026355] usb 1-3: Product: USB DISK [ 1935.026364] usb 1-3: Manufacturer: SMI Corporation [ 1935.190717] usb-storage 1-3:1.0: USB Mass Storage device detected [ 1935.198399] scsi2 : usb-storage 1-3:1.0 [ 1935.198925] usbcore: registered new interface driver usb-storage [ 1936.513708] scsi 2:0:0:0: Direct-Access SMI USB DISK 1100 PQ: 0 ANSI: 0 CCS [ 1936.516671] sd 2:0:0:0: Attached scsi generic sg1 type 0 [ 1936.517528] sd 2:0:0:0: [sdb] 3934208 512-byte logical blocks: (2.01 GB/1.87 GiB) [ 1936.518390] sd 2:0:0:0: [sdb] Write Protect is off [ 1936.518405] sd 2:0:0:0: [sdb] Mode Sense: 43 00 00 00 [ 1936.519587] sd 2:0:0:0: [sdb] No Caching mode page found [ 1936.519602] sd 2:0:0:0: [sdb] Assuming drive cache: write through [ 1936.528087] sd 2:0:0:0: [sdb] No Caching mode page found [ 1936.528105] sd 2:0:0:0: [sdb] Assuming drive cache: write through [ 1936.529352] sdb: sdb1 [ 1936.534694] sd 2:0:0:0: [sdb] No Caching mode page found [ 1936.534710] sd 2:0:0:0: [sdb] Assuming drive cache: write through [ 1936.534723] sd 2:0:0:0: [sdb] Attached SCSI removable disk [ 1938.170078] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
