[ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Linux version 3.2.0-23-generic (buildd@palmer) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu4) ) #36-Ubuntu SMP Tue Apr 10 20:41:14 UTC 2012 (Ubuntu 3.2.0-23.36-generic 3.2.14) [ 0.000000] KERNEL supported cpus: [ 0.000000] Intel GenuineIntel [ 0.000000] AMD AuthenticAMD [ 0.000000] NSC Geode by NSC [ 0.000000] Cyrix CyrixInstead [ 0.000000] Centaur CentaurHauls [ 0.000000] Transmeta GenuineTMx86 [ 0.000000] Transmeta TransmetaCPU [ 0.000000] UMC UMC UMC UMC [ 0.000000] BIOS-provided physical RAM map: [ 0.000000] BIOS-e820: 0000000000000000 - 000000000009dc00 (usable) [ 0.000000] BIOS-e820: 000000000009dc00 - 00000000000a0000 (reserved) [ 0.000000] BIOS-e820: 00000000000ca000 - 0000000000100000 (reserved) [ 0.000000] BIOS-e820: 0000000000100000 - 000000003fed0000 (usable) [ 0.000000] BIOS-e820: 000000003fed0000 - 000000003fee1000 (ACPI data) [ 0.000000] BIOS-e820: 000000003fee1000 - 000000003fee2000 (ACPI NVS) [ 0.000000] BIOS-e820: 000000003fee2000 - 0000000040000000 (reserved) [ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved) [ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec10000 (reserved) [ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved) [ 0.000000] BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved) [ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled in hardware: non-PAE kernel! [ 0.000000] NX (Execute Disable) protection: approximated by x86 segment limits [ 0.000000] DMI present. [ 0.000000] DMI: FUJITSU SIEMENS FUTRO S550 /D2703-A2, BIOS 6.00 R1.13.2703.A2 04/24/2009 [ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved) [ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable) [ 0.000000] last_pfn = 0x3fed0 max_arch_pfn = 0x100000 [ 0.000000] MTRR default type: uncachable [ 0.000000] MTRR fixed ranges enabled: [ 0.000000] 00000-9FFFF write-back [ 0.000000] A0000-BFFFF uncachable [ 0.000000] C0000-CBFFF write-protect [ 0.000000] CC000-E3FFF uncachable [ 0.000000] E4000-FFFFF write-protect [ 0.000000] MTRR variable ranges enabled: [ 0.000000] 0 base 0000000000 mask FFC0000000 write-back [ 0.000000] 1 disabled [ 0.000000] 2 disabled [ 0.000000] 3 disabled [ 0.000000] 4 disabled [ 0.000000] 5 disabled [ 0.000000] 6 disabled [ 0.000000] 7 disabled [ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106 [ 0.000000] found SMP MP-table at [c00f8200] f8200 [ 0.000000] initial memory mapped : 0 - 01c00000 [ 0.000000] Base memory trampoline at [c0099000] 99000 size 16384 [ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000 [ 0.000000] 0000000000 - 0000400000 page 4k [ 0.000000] 0000400000 - 0037400000 page 2M [ 0.000000] 0037400000 - 00377fe000 page 4k [ 0.000000] kernel direct mapping tables up to 377fe000 @ 1bfb000-1c00000 [ 0.000000] RAMDISK: 3eaf4000 - 3fecf000 [ 0.000000] Allocated new RAMDISK: 36423000 - 377fd73f [ 0.000000] Move RAMDISK from 000000003eaf4000 - 000000003fece73e to 36423000 - 377fd73e [ 0.000000] ACPI: RSDP 000f81d0 00014 (v00 PTLTD ) [ 0.000000] ACPI: RSDT 3fede61c 00034 (v01 PTLTD RSDT 00060000 LTP 00000000) [ 0.000000] ACPI: FACP 3fee0ed2 00074 (v01 FSC D2703/Ax 00060000 000F4240) [ 0.000000] ACPI: DSDT 3fede650 02882 (v01 FSC D2703/A2 00060000 MSFT 03000001) [ 0.000000] ACPI: FACS 3fee1fc0 00040 [ 0.000000] ACPI: APIC 3fee0f46 00046 (v01 PTLTD ? APIC 00060000 LTP 00000000) [ 0.000000] ACPI: MCFG 3fee0f8c 0003C (v01 PTLTD MCFG 00060000 LTP 00000000) [ 0.000000] ACPI: HPET 3fee0fc8 00038 (v01 PTLTD HPETTBL 00060000 LTP 00000001) [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] 134MB HIGHMEM available. [ 0.000000] 887MB LOWMEM available. [ 0.000000] mapped low ram: 0 - 377fe000 [ 0.000000] low ram: 0 - 377fe000 [ 0.000000] Zone PFN ranges: [ 0.000000] DMA 0x00000010 -> 0x00001000 [ 0.000000] Normal 0x00001000 -> 0x000377fe [ 0.000000] HighMem 0x000377fe -> 0x0003fed0 [ 0.000000] Movable zone start PFN for each node [ 0.000000] early_node_map[2] active PFN ranges [ 0.000000] 0: 0x00000010 -> 0x0000009d [ 0.000000] 0: 0x00000100 -> 0x0003fed0 [ 0.000000] On node 0 totalpages: 261725 [ 0.000000] free_area_init_node: node 0, pgdat c18258c0, node_mem_map f5c22200 [ 0.000000] DMA zone: 32 pages used for memmap [ 0.000000] DMA zone: 0 pages reserved [ 0.000000] DMA zone: 3949 pages, LIFO batch:0 [ 0.000000] Normal zone: 1744 pages used for memmap [ 0.000000] Normal zone: 221486 pages, LIFO batch:31 [ 0.000000] HighMem zone: 270 pages used for memmap [ 0.000000] HighMem zone: 34244 pages, LIFO batch:7 [ 0.000000] Using APIC driver default [ 0.000000] Detected use of extended apic ids on hypertransport bus [ 0.000000] ACPI: PM-Timer IO Port: 0x8008 [ 0.000000] ACPI: Local APIC address 0xfee00000 [ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled) [ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1]) [ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0]) [ 0.000000] IOAPIC[0]: apic_id 1, version 33, address 0xfec00000, GSI 0-23 [ 0.000000] ACPI: IRQ9 used by override. [ 0.000000] Using ACPI (MADT) for SMP configuration information [ 0.000000] ACPI: HPET id: 0x43538301 base: 0xfed00000 [ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs [ 0.000000] nr_irqs_gsi: 40 [ 0.000000] PM: Registered nosave memory: 000000000009d000 - 000000000009e000 [ 0.000000] PM: Registered nosave memory: 000000000009e000 - 00000000000a0000 [ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000ca000 [ 0.000000] PM: Registered nosave memory: 00000000000ca000 - 0000000000100000 [ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:a0000000) [ 0.000000] Booting paravirtualized kernel on bare hardware [ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1 [ 0.000000] PERCPU: Embedded 13 pages/cpu @f5800000 s31616 r0 d21632 u4194304 [ 0.000000] pcpu-alloc: s31616 r0 d21632 u4194304 alloc=1*4194304 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 259679 [ 0.000000] Kernel command line: bootkbd=de console-setup/layoutcode=de console-setup/variantcode=nodeadkeys locale=de_DE noprompt cdrom-detect/try-usb=true file=/cdrom/preseed/mint.seed boot=casper initrd=/casper/initrd.lz splash -- BOOT_IMAGE=/casper/vmlinuz [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Initializing CPU#0 [ 0.000000] allocated 4189184 bytes of page_cgroup [ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups [ 0.000000] Initializing HighMem for node 0 (000377fe:0003fed0) [ 0.000000] Memory: 1003372k/1047360k available (5627k kernel code, 43528k reserved, 2764k data, 712k init, 138056k highmem) [ 0.000000] virtual kernel memory layout: [ 0.000000] fixmap : 0xfff16000 - 0xfffff000 ( 932 kB) [ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB) [ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB) [ 0.000000] .init : 0xc1833000 - 0xc18e5000 ( 712 kB) [ 0.000000] .data : 0xc157ef84 - 0xc1832080 (2764 kB) [ 0.000000] .text : 0xc1000000 - 0xc157ef84 (5627 kB) [ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok. [ 0.000000] SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] RCU dyntick-idle grace-period acceleration is enabled. [ 0.000000] NR_IRQS:2304 nr_irqs:256 16 [ 0.000000] CPU 0 irqstacks, hard=f5008000 soft=f500a000 [ 0.000000] Console: colour VGA+ 80x25 [ 0.000000] console [tty0] enabled [ 0.000000] hpet clockevent registered [ 0.000000] Fast TSC calibration failed [ 0.000000] TSC: Unable to calibrate against PIT [ 0.000000] TSC: using HPET reference calibration [ 0.000000] Detected 999.879 MHz processor. [ 0.020005] Calibrating delay loop (skipped), value calculated using timer frequency.. 1999.75 BogoMIPS (lpj=3999516) [ 0.020220] pid_max: default: 32768 minimum: 301 [ 0.020379] Security Framework initialized [ 0.020521] AppArmor: AppArmor initialized [ 0.020623] Yama: becoming mindful. [ 0.020864] Mount-cache hash table entries: 512 [ 0.021272] Initializing cgroup subsys cpuacct [ 0.024019] Initializing cgroup subsys memory [ 0.024138] Initializing cgroup subsys devices [ 0.024242] Initializing cgroup subsys freezer [ 0.024348] Initializing cgroup subsys blkio [ 0.024464] Initializing cgroup subsys perf_event [ 0.024619] mce: CPU supports 5 MCE banks [ 0.024738] using AMD E400 aware idle routine [ 0.025271] SMP alternatives: switching to UP code [ 0.043215] Freeing SMP alternatives: 24k freed [ 0.043356] ACPI: Core revision 20110623 [ 0.052027] ftrace: allocating 25954 entries in 51 pages [ 0.056153] Enabling APIC mode: Flat. Using 1 I/O APICs [ 0.056673] ..TIMER: vector=0x30 apic1=0 pin1=0 apic2=-1 pin2=-1 [ 0.060003] ..MP-BIOS bug: 8254 timer not connected to IO-APIC [ 0.060003] ...trying to set up timer (IRQ0) through the 8259A ... [ 0.060003] ..... (found apic 0 pin 0) ... [ 0.101219] ....... works. [ 0.101316] CPU0: Mobile AMD Sempron(tm) Processor 2100+ stepping 02 [ 0.104005] Performance Events: AMD PMU driver. [ 0.104005] ... version: 0 [ 0.104005] ... bit width: 48 [ 0.104005] ... generic registers: 4 [ 0.104005] ... value mask: 0000ffffffffffff [ 0.104005] ... max period: 00007fffffffffff [ 0.104005] ... fixed-purpose events: 0 [ 0.104005] ... event mask: 000000000000000f [ 0.104005] NMI watchdog enabled, takes one hw-pmu counter. [ 0.104005] Brought up 1 CPUs [ 0.104005] Total of 1 processors activated (1999.75 BogoMIPS). [ 0.104005] devtmpfs: initialized [ 0.104005] EVM: security.selinux [ 0.104005] EVM: security.SMACK64 [ 0.104005] EVM: security.capability [ 0.104005] PM: Registering ACPI NVS region at 3fee1000 (4096 bytes) [ 0.105707] print_constraints: dummy: [ 0.105855] RTC time: 20:11:23, date: 03/10/17 [ 0.106036] NET: Registered protocol family 16 [ 0.106429] EISA bus registered [ 0.106533] node 0 link 0: io port [1000, fffff] [ 0.106540] TOM: 0000000040000000 aka 1024M [ 0.106643] node 0 link 0: mmio [fc000000, ffffffff] [ 0.106650] node 0 link 0: mmio [f8000000, fbffffff] [ 0.106656] node 0 link 0: mmio [a0000, bffff] [ 0.106662] node 0 link 0: mmio [f0000000, f7ffffff] [ 0.106668] node 0 link 0: mmio [e0000000, efffffff] [ 0.106674] node 0 link 0: mmio [40000000, dfffffff] [ 0.106681] bus: [00, ff] on node 0 link 0 [ 0.106687] bus: 00 index 0 [io 0x0000-0xffff] [ 0.106693] bus: 00 index 1 [mem 0x40000000-0xffffffff] [ 0.106698] bus: 00 index 2 [mem 0x000a0000-0x000bffff] [ 0.106770] ACPI: bus type pci registered [ 0.107010] PCI: MMCONFIG for domain 0000 [bus 00-11] at [mem 0xe0000000-0xe11fffff] (base 0xe0000000) [ 0.107158] PCI: MMCONFIG at [mem 0xe0000000-0xe11fffff] reserved in E820 [ 0.107266] PCI: Using MMCONFIG for extended config space [ 0.107369] PCI: Using configuration type 1 for base access [ 0.110543] bio: create slab at 0 [ 0.110846] ACPI: Added _OSI(Module Device) [ 0.110950] ACPI: Added _OSI(Processor Device) [ 0.111050] ACPI: Added _OSI(3.0 _SCP Extensions) [ 0.111152] ACPI: Added _OSI(Processor Aggregator Device) [ 0.112147] ACPI: EC: Look up EC in DSDT [ 0.115600] ACPI: Interpreter enabled [ 0.115715] ACPI: (supports S0 S3 S4 S5) [ 0.116027] ACPI: Using IOAPIC for interrupt routing [ 0.122829] ACPI: No dock devices found. [ 0.122938] HEST: Table not found. [ 0.123041] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug [ 0.123288] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff]) [ 0.123615] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] [ 0.123728] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] [ 0.123838] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] [ 0.123977] pci_root PNP0A03:00: host bridge window [mem 0x000c0000-0x000dffff] [ 0.124017] pci_root PNP0A03:00: host bridge window [mem 0x40000000-0xfebfffff] [ 0.124156] pci_root PNP0A03:00: host bridge window [mem 0xfed00000-0xfedfffff] [ 0.124302] pci_root PNP0A03:00: ignoring host bridge window [mem 0x000c0000-0x000dffff] (conflicts with reserved [mem 0x000ca000-0x000fffff]) [ 0.124478] pci 0000:00:00.0: [1002:7910] type 0 class 0x000600 [ 0.124506] pci 0000:00:00.0: reg 1c: [mem 0xe0000000-0xffffffff 64bit] [ 0.124554] pci 0000:00:06.0: [1002:7916] type 1 class 0x000604 [ 0.124612] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold [ 0.124619] pci 0000:00:06.0: PME# disabled [ 0.124646] pci 0000:00:07.0: [1002:7917] type 1 class 0x000604 [ 0.124700] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold [ 0.124707] pci 0000:00:07.0: PME# disabled [ 0.124752] pci 0000:00:13.0: [1002:4387] type 0 class 0x000c03 [ 0.124774] pci 0000:00:13.0: reg 10: [mem 0xfc204000-0xfc204fff] [ 0.124866] pci 0000:00:13.1: [1002:4388] type 0 class 0x000c03 [ 0.124887] pci 0000:00:13.1: reg 10: [mem 0xfc205000-0xfc205fff] [ 0.124978] pci 0000:00:13.2: [1002:4389] type 0 class 0x000c03 [ 0.124999] pci 0000:00:13.2: reg 10: [mem 0xfc206000-0xfc206fff] [ 0.125094] pci 0000:00:13.3: [1002:438a] type 0 class 0x000c03 [ 0.125115] pci 0000:00:13.3: reg 10: [mem 0xfc207000-0xfc207fff] [ 0.125206] pci 0000:00:13.4: [1002:438b] type 0 class 0x000c03 [ 0.125227] pci 0000:00:13.4: reg 10: [mem 0xfc208000-0xfc208fff] [ 0.125325] pci 0000:00:13.5: [1002:4386] type 0 class 0x000c03 [ 0.125354] pci 0000:00:13.5: reg 10: [mem 0xfc20a000-0xfc20a0ff] [ 0.125463] pci 0000:00:13.5: supports D1 D2 [ 0.125469] pci 0000:00:13.5: PME# supported from D0 D1 D2 D3hot [ 0.125476] pci 0000:00:13.5: PME# disabled [ 0.125510] pci 0000:00:14.0: [1002:4385] type 0 class 0x000c05 [ 0.125541] pci 0000:00:14.0: reg 10: [io 0x8400-0x840f] [ 0.125655] pci 0000:00:14.1: [1002:438c] type 0 class 0x000101 [ 0.125676] pci 0000:00:14.1: reg 10: [io 0x01f0-0x01f7] [ 0.125692] pci 0000:00:14.1: reg 14: [io 0x03f4-0x03f7] [ 0.125707] pci 0000:00:14.1: reg 18: [io 0x0000-0x0007] [ 0.125723] pci 0000:00:14.1: reg 1c: [io 0x0000-0x0003] [ 0.125738] pci 0000:00:14.1: reg 20: [io 0x8410-0x841f] [ 0.125795] pci 0000:00:14.2: [1002:4383] type 0 class 0x000403 [ 0.125826] pci 0000:00:14.2: reg 10: [mem 0xfc200000-0xfc203fff 64bit] [ 0.125915] pci 0000:00:14.2: PME# supported from D0 D3hot D3cold [ 0.125923] pci 0000:00:14.2: PME# disabled [ 0.125947] pci 0000:00:14.3: [1002:438d] type 0 class 0x000601 [ 0.126050] pci 0000:00:14.4: [1002:4384] type 1 class 0x000604 [ 0.126122] pci 0000:00:18.0: [1022:1100] type 0 class 0x000600 [ 0.126164] pci 0000:00:18.1: [1022:1101] type 0 class 0x000600 [ 0.126202] pci 0000:00:18.2: [1022:1102] type 0 class 0x000600 [ 0.126236] pci 0000:00:18.3: [1022:1103] type 0 class 0x000600 [ 0.126312] pci 0000:00:06.0: PCI bridge to [bus 01-06] [ 0.126479] pci 0000:07:00.0: [10ec:8168] type 0 class 0x000200 [ 0.126500] pci 0000:07:00.0: reg 10: [io 0x9000-0x90ff] [ 0.126530] pci 0000:07:00.0: reg 18: [mem 0xfc310000-0xfc310fff 64bit pref] [ 0.126552] pci 0000:07:00.0: reg 20: [mem 0xfc300000-0xfc30ffff 64bit pref] [ 0.126568] pci 0000:07:00.0: reg 30: [mem 0x00000000-0x0000ffff pref] [ 0.126631] pci 0000:07:00.0: supports D1 D2 [ 0.126636] pci 0000:07:00.0: PME# supported from D0 D1 D2 D3hot D3cold [ 0.126643] pci 0000:07:00.0: PME# disabled [ 0.132041] pci 0000:00:07.0: PCI bridge to [bus 07-0c] [ 0.134480] pci 0000:00:07.0: bridge window [io 0x9000-0x9fff] [ 0.134490] pci 0000:00:07.0: bridge window [mem 0xfc300000-0xfc3fffff 64bit pref] [ 0.134539] pci 0000:0d:07.0: [5333:8901] type 0 class 0x000300 [ 0.134563] pci 0000:0d:07.0: reg 10: [mem 0xf8000000-0xfbffffff] [ 0.134644] pci 0000:0d:07.0: reg 30: [mem 0x00000000-0x0000ffff pref] [ 0.134713] pci 0000:00:14.4: PCI bridge to [bus 0d-12] (subtractive decode) [ 0.134830] pci 0000:00:14.4: bridge window [mem 0xf8000000-0xfbffffff] [ 0.134839] pci 0000:00:14.4: bridge window [io 0x0000-0x0cf7] (subtractive decode) [ 0.134846] pci 0000:00:14.4: bridge window [io 0x0d00-0xffff] (subtractive decode) [ 0.134853] pci 0000:00:14.4: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode) [ 0.134860] pci 0000:00:14.4: bridge window [mem 0x40000000-0xfebfffff] (subtractive decode) [ 0.134867] pci 0000:00:14.4: bridge window [mem 0xfed00000-0xfedfffff] (subtractive decode) [ 0.134887] pci_bus 0000:00: on NUMA node 0 [ 0.134894] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT] [ 0.135087] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEXA._PRT] [ 0.135178] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.LAN_._PRT] [ 0.135227] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2P_._PRT] [ 0.135431] pci0000:00: Requesting ACPI _OSC control (0x1d) [ 0.135543] pci0000:00: ACPI _OSC request failed (AE_NOT_FOUND), returned control mask: 0x1d [ 0.135684] ACPI _OSC control for PCIe not granted, disabling ASPM [ 0.143246] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 7 9 10 11 12 14 15) *0, disabled. [ 0.144180] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 7 9 10 11 12 14 15) *0, disabled. [ 0.145132] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 7 9 10 11 12 14 15) *0, disabled. [ 0.146081] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 7 9 10 11 12 14 15) *0, disabled. [ 0.147029] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 7 9 10 11 12 14 15) *0, disabled. [ 0.148019] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 7 9 10 11 12 14 15) *0, disabled. [ 0.148964] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 7 9 10 11 12 14 15) *0, disabled. [ 0.149911] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 7 9 10 11 12 14 15) *0, disabled. [ 0.151053] vgaarb: device added: PCI:0000:0d:07.0,decodes=io+mem,owns=io+mem,locks=none [ 0.151193] vgaarb: loaded [ 0.151286] vgaarb: bridge control possible 0000:0d:07.0 [ 0.151723] i2c-core: driver [aat2870] using legacy suspend method [ 0.151832] i2c-core: driver [aat2870] using legacy resume method [ 0.152145] SCSI subsystem initialized [ 0.152364] libata version 3.00 loaded. [ 0.152485] usbcore: registered new interface driver usbfs [ 0.152622] usbcore: registered new interface driver hub [ 0.152782] usbcore: registered new device driver usb [ 0.153104] PCI: Using ACPI for IRQ routing [ 0.153737] PCI: pci_cache_line_size set to 64 bytes [ 0.153755] pci 0000:00:00.0: no compatible bridge window for [mem 0xe0000000-0xffffffff 64bit] [ 0.153999] reserve RAM buffer: 000000000009dc00 - 000000000009ffff [ 0.154006] reserve RAM buffer: 000000003fed0000 - 000000003fffffff [ 0.154249] NetLabel: Initializing [ 0.154350] NetLabel: domain hash size = 128 [ 0.154449] NetLabel: protocols = UNLABELED CIPSOv4 [ 0.154572] NetLabel: unlabeled traffic allowed by default [ 0.154810] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0 [ 0.155194] hpet0: 4 comparators, 32-bit 14.318180 MHz counter [ 0.157080] Switching to clocksource hpet [ 0.173386] AppArmor: AppArmor Filesystem Enabled [ 0.173562] pnp: PnP ACPI init [ 0.173697] ACPI: bus type pnp registered [ 0.173964] pnp 00:00: [bus 00-ff] [ 0.173972] pnp 00:00: [io 0x0000-0x0cf7 window] [ 0.173978] pnp 00:00: [io 0x0d00-0xffff window] [ 0.173983] pnp 00:00: [io 0x0cf8-0x0cff] [ 0.173989] pnp 00:00: [mem 0x000a0000-0x000bffff window] [ 0.173995] pnp 00:00: [mem 0x000c0000-0x000dffff window] [ 0.174001] pnp 00:00: [mem 0x40000000-0xfebfffff window] [ 0.174007] pnp 00:00: [mem 0xfed00000-0xfedfffff window] [ 0.174120] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active) [ 0.174503] pnp 00:01: [io 0x0010-0x001f] [ 0.174509] pnp 00:01: [io 0x0022-0x002d] [ 0.174514] pnp 00:01: [io 0x0030-0x003f] [ 0.174519] pnp 00:01: [io 0x0050-0x0053] [ 0.174524] pnp 00:01: [io 0x0062-0x0063] [ 0.174529] pnp 00:01: [io 0x0065-0x006f] [ 0.174534] pnp 00:01: [io 0x0074-0x007f] [ 0.174539] pnp 00:01: [io 0x0090-0x009f] [ 0.174544] pnp 00:01: [io 0x00a2-0x00b1] [ 0.174549] pnp 00:01: [io 0x00b2-0x00b3] [ 0.174554] pnp 00:01: [io 0x00b4-0x00bf] [ 0.174559] pnp 00:01: [io 0x00ec-0x00ef] [ 0.174564] pnp 00:01: [io 0x0072-0x0073] [ 0.174569] pnp 00:01: [io 0x004e-0x004f] [ 0.174574] pnp 00:01: [io 0x0600-0x067f] [ 0.174578] pnp 00:01: [io 0x040b] [ 0.174583] pnp 00:01: [io 0x04d0-0x04d1] [ 0.174588] pnp 00:01: [io 0x04d6] [ 0.174593] pnp 00:01: [io 0x087f] [ 0.174597] pnp 00:01: [io 0x0c00-0x0c01] [ 0.174602] pnp 00:01: [io 0x0c14] [ 0.174607] pnp 00:01: [io 0x0c50-0x0c52] [ 0.174612] pnp 00:01: [io 0x0c6c] [ 0.174616] pnp 00:01: [io 0x0c6f] [ 0.174621] pnp 00:01: [io 0x0cd0-0x0cd1] [ 0.174626] pnp 00:01: [io 0x0cd2-0x0cd3] [ 0.174631] pnp 00:01: [io 0x0cd4-0x0cd5] [ 0.174636] pnp 00:01: [io 0x0cd6-0x0cd7] [ 0.174641] pnp 00:01: [io 0x0cd8-0x0cdf] [ 0.174646] pnp 00:01: [io 0x8000-0x807f] [ 0.174651] pnp 00:01: [io 0x8100-0x81fe] [ 0.174656] pnp 00:01: [io 0xfe00] [ 0.174662] pnp 00:01: [mem 0xe0000000-0xefffffff] [ 0.174667] pnp 00:01: [mem 0xfec00000-0xfecfffff] [ 0.174672] pnp 00:01: [mem 0xfee00000-0xfeefffff] [ 0.174841] system 00:01: [io 0x0600-0x067f] has been reserved [ 0.174952] system 00:01: [io 0x040b] has been reserved [ 0.175057] system 00:01: [io 0x04d0-0x04d1] has been reserved [ 0.175164] system 00:01: [io 0x04d6] has been reserved [ 0.175269] system 00:01: [io 0x087f] has been reserved [ 0.175374] system 00:01: [io 0x0c00-0x0c01] has been reserved [ 0.175480] system 00:01: [io 0x0c14] has been reserved [ 0.175585] system 00:01: [io 0x0c50-0x0c52] has been reserved [ 0.175692] system 00:01: [io 0x0c6c] has been reserved [ 0.175797] system 00:01: [io 0x0c6f] has been reserved [ 0.175902] system 00:01: [io 0x0cd0-0x0cd1] has been reserved [ 0.176045] system 00:01: [io 0x0cd2-0x0cd3] has been reserved [ 0.176153] system 00:01: [io 0x0cd4-0x0cd5] has been reserved [ 0.176260] system 00:01: [io 0x0cd6-0x0cd7] has been reserved [ 0.176367] system 00:01: [io 0x0cd8-0x0cdf] has been reserved [ 0.176475] system 00:01: [io 0x8000-0x807f] has been reserved [ 0.176582] system 00:01: [io 0x8100-0x81fe] has been reserved [ 0.176689] system 00:01: [io 0xfe00] has been reserved [ 0.176796] system 00:01: [mem 0xe0000000-0xefffffff] has been reserved [ 0.176908] system 00:01: [mem 0xfec00000-0xfecfffff] could not be reserved [ 0.177020] system 00:01: [mem 0xfee00000-0xfeefffff] could not be reserved [ 0.177133] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active) [ 0.177159] pnp 00:02: [io 0x0000-0x000f] [ 0.177164] pnp 00:02: [io 0x0080-0x008f] [ 0.177169] pnp 00:02: [io 0x00c0-0x00df] [ 0.177175] pnp 00:02: [dma 4] [ 0.177248] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active) [ 0.177276] pnp 00:03: [io 0x0070-0x0071] [ 0.177301] pnp 00:03: [irq 8] [ 0.177378] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active) [ 0.177407] pnp 00:04: [io 0x00f0-0x00fe] [ 0.177420] pnp 00:04: [irq 13] [ 0.177492] pnp 00:04: Plug and Play ACPI device, IDs PNP0c04 (active) [ 0.177514] pnp 00:05: [io 0x0061] [ 0.177586] pnp 00:05: Plug and Play ACPI device, IDs PNP0800 (active) [ 0.177666] pnp 00:06: [mem 0xfed00000-0xfed00fff] [ 0.177749] pnp 00:06: Plug and Play ACPI device, IDs PNP0103 (active) [ 0.177779] pnp 00:07: [io 0x0060] [ 0.177784] pnp 00:07: [io 0x0064] [ 0.177797] pnp 00:07: [irq 1] [ 0.177872] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active) [ 0.177960] pnp 00:08: [irq 12] [ 0.178053] pnp 00:08: Plug and Play ACPI device, IDs PNP0f13 (active) [ 0.178375] pnp 00:09: [io 0x03f8-0x03ff] [ 0.178385] pnp 00:09: [irq 4] [ 0.178510] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.178763] pnp 00:0a: [io 0x02f8-0x02ff] [ 0.178773] pnp 00:0a: [irq 3] [ 0.178893] pnp 00:0a: Plug and Play ACPI device, IDs PNP0501 (active) [ 0.178905] pnp: PnP ACPI: found 11 devices [ 0.179008] ACPI: ACPI bus type pnp unregistered [ 0.179112] PnPBIOS: Disabled by ACPI PNP [ 0.218179] PCI: max bus depth: 1 pci_try_num: 2 [ 0.218234] pci 0000:00:07.0: BAR 14: assigned [mem 0x40000000-0x400fffff] [ 0.218352] pci 0000:00:14.4: BAR 15: assigned [mem 0x40100000-0x401fffff pref] [ 0.218492] pci 0000:00:06.0: BAR 14: assigned [mem 0x40200000-0x403fffff] [ 0.218604] pci 0000:00:06.0: BAR 15: assigned [mem 0x40400000-0x405fffff 64bit pref] [ 0.218747] pci 0000:00:06.0: BAR 13: assigned [io 0x1000-0x1fff] [ 0.218856] pci 0000:00:06.0: PCI bridge to [bus 01-06] [ 0.218960] pci 0000:00:06.0: bridge window [io 0x1000-0x1fff] [ 0.219069] pci 0000:00:06.0: bridge window [mem 0x40200000-0x403fffff] [ 0.219180] pci 0000:00:06.0: bridge window [mem 0x40400000-0x405fffff 64bit pref] [ 0.219324] pci 0000:07:00.0: BAR 6: assigned [mem 0xfc320000-0xfc32ffff pref] [ 0.219464] pci 0000:00:07.0: PCI bridge to [bus 07-0c] [ 0.219568] pci 0000:00:07.0: bridge window [io 0x9000-0x9fff] [ 0.219677] pci 0000:00:07.0: bridge window [mem 0x40000000-0x400fffff] [ 0.219788] pci 0000:00:07.0: bridge window [mem 0xfc300000-0xfc3fffff 64bit pref] [ 0.219934] pci 0000:0d:07.0: BAR 6: assigned [mem 0x40100000-0x4010ffff pref] [ 0.220084] pci 0000:00:14.4: PCI bridge to [bus 0d-12] [ 0.220193] pci 0000:00:14.4: bridge window [mem 0xf8000000-0xfbffffff] [ 0.220306] pci 0000:00:14.4: bridge window [mem 0x40100000-0x401fffff pref] [ 0.220458] pci 0000:00:06.0: enabling device (0000 -> 0003) [ 0.220568] pci 0000:00:06.0: setting latency timer to 64 [ 0.220579] pci 0000:00:07.0: setting latency timer to 64 [ 0.220593] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7] [ 0.220599] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff] [ 0.220605] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff] [ 0.220612] pci_bus 0000:00: resource 7 [mem 0x40000000-0xfebfffff] [ 0.220618] pci_bus 0000:00: resource 8 [mem 0xfed00000-0xfedfffff] [ 0.220624] pci_bus 0000:01: resource 0 [io 0x1000-0x1fff] [ 0.220630] pci_bus 0000:01: resource 1 [mem 0x40200000-0x403fffff] [ 0.220637] pci_bus 0000:01: resource 2 [mem 0x40400000-0x405fffff 64bit pref] [ 0.220644] pci_bus 0000:07: resource 0 [io 0x9000-0x9fff] [ 0.220650] pci_bus 0000:07: resource 1 [mem 0x40000000-0x400fffff] [ 0.220656] pci_bus 0000:07: resource 2 [mem 0xfc300000-0xfc3fffff 64bit pref] [ 0.220663] pci_bus 0000:0d: resource 1 [mem 0xf8000000-0xfbffffff] [ 0.220669] pci_bus 0000:0d: resource 2 [mem 0x40100000-0x401fffff pref] [ 0.220676] pci_bus 0000:0d: resource 4 [io 0x0000-0x0cf7] [ 0.220682] pci_bus 0000:0d: resource 5 [io 0x0d00-0xffff] [ 0.220688] pci_bus 0000:0d: resource 6 [mem 0x000a0000-0x000bffff] [ 0.220694] pci_bus 0000:0d: resource 7 [mem 0x40000000-0xfebfffff] [ 0.220700] pci_bus 0000:0d: resource 8 [mem 0xfed00000-0xfedfffff] [ 0.220797] NET: Registered protocol family 2 [ 0.221024] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.221700] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 0.222991] TCP bind hash table entries: 65536 (order: 7, 524288 bytes) [ 0.223667] TCP: Hash tables configured (established 131072 bind 65536) [ 0.223781] TCP reno registered [ 0.223881] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 0.224052] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 0.224331] NET: Registered protocol family 1 [ 0.224500] pci 0000:00:13.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 0.224649] pci 0000:00:13.0: PCI INT A disabled [ 0.224770] pci 0000:00:13.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17 [ 0.224898] pci 0000:00:13.1: PCI INT B disabled [ 0.225016] pci 0000:00:13.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 0.225141] pci 0000:00:13.2: PCI INT C disabled [ 0.225252] pci 0000:00:13.3: PCI INT B -> GSI 17 (level, low) -> IRQ 17 [ 0.225378] pci 0000:00:13.3: PCI INT B disabled [ 0.225489] pci 0000:00:13.4: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 0.225614] pci 0000:00:13.4: PCI INT C disabled [ 0.225734] pci 0000:00:13.5: PCI INT D -> GSI 19 (level, low) -> IRQ 19 [ 0.225862] pci 0000:00:13.5: PCI INT D disabled [ 0.226004] pci 0000:0d:07.0: Boot video device [ 0.226011] PCI: CLS 32 bytes, default 64 [ 0.226814] audit: initializing netlink socket (disabled) [ 0.226941] type=2000 audit(1489176682.224:1): initialized [ 0.277875] Trying to unpack rootfs image as initramfs... [ 0.344508] highmem bounce pool size: 64 pages [ 0.344627] HugeTLB registered 4 MB page size, pre-allocated 0 pages [ 0.376249] VFS: Disk quotas dquot_6.5.2 [ 0.376522] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.377997] fuse init (API version 7.17) [ 0.378326] msgmni has been set to 1690 [ 0.388917] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253) [ 0.396639] io scheduler noop registered [ 0.396751] io scheduler deadline registered [ 0.396886] io scheduler cfq registered (default) [ 0.397293] pcieport 0000:00:06.0: setting latency timer to 64 [ 0.397351] pcieport 0000:00:06.0: irq 40 for MSI/MSI-X [ 0.397442] pcieport 0000:00:07.0: setting latency timer to 64 [ 0.397481] pcieport 0000:00:07.0: irq 41 for MSI/MSI-X [ 0.397641] pci_hotplug: PCI Hot Plug PCI Core version: 0.5 [ 0.397812] pciehp: PCI Express Hot Plug Controller Driver version: 0.4 [ 0.398271] input: Power Button as /devices/LNXSYSTM:00/device:00/PNP0C0C:00/input/input0 [ 0.398423] ACPI: Power Button [PWRB] [ 0.398646] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1 [ 0.398790] ACPI: Power Button [PWRF] [ 0.401430] ERST: Table is not found! [ 0.401533] GHES: HEST is not enabled! [ 0.401900] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled [ 0.422615] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.422778] isapnp: Scanning for PnP cards... [ 0.557040] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A [ 0.605259] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A [ 0.689356] 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A [ 0.708959] Linux agpgart interface v0.103 [ 0.718831] brd: module loaded [ 0.720751] loop: module loaded [ 0.721348] pata_acpi 0000:00:14.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 0.721562] pata_acpi 0000:00:14.1: setting latency timer to 64 [ 0.722571] Fixed MDIO Bus: probed [ 0.722724] tun: Universal TUN/TAP device driver, 1.6 [ 0.722829] tun: (C) 1999-2004 Max Krasnyansky [ 0.728570] PPP generic driver version 2.4.2 [ 0.728950] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 0.729109] ehci_hcd 0000:00:13.5: PCI INT D -> GSI 19 (level, low) -> IRQ 19 [ 0.729253] ehci_hcd 0000:00:13.5: EHCI Host Controller [ 0.729467] ehci_hcd 0000:00:13.5: new USB bus registered, assigned bus number 1 [ 0.729659] ehci_hcd 0000:00:13.5: applying AMD SB600/SB700 USB freeze workaround [ 0.729816] ehci_hcd 0000:00:13.5: debug port 1 [ 0.729957] ehci_hcd 0000:00:13.5: irq 19, io mem 0xfc20a000 [ 0.740604] ehci_hcd 0000:00:13.5: USB 2.0 started, EHCI 1.00 [ 0.741116] hub 1-0:1.0: USB hub found [ 0.741225] hub 1-0:1.0: 10 ports detected [ 0.741517] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 0.741664] ohci_hcd 0000:00:13.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 0.741808] ohci_hcd 0000:00:13.0: OHCI Host Controller [ 0.742009] ohci_hcd 0000:00:13.0: new USB bus registered, assigned bus number 2 [ 0.742201] ohci_hcd 0000:00:13.0: irq 16, io mem 0xfc204000 [ 0.796756] hub 2-0:1.0: USB hub found [ 0.796873] hub 2-0:1.0: 2 ports detected [ 0.797129] ohci_hcd 0000:00:13.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17 [ 0.797274] ohci_hcd 0000:00:13.1: OHCI Host Controller [ 0.797473] ohci_hcd 0000:00:13.1: new USB bus registered, assigned bus number 3 [ 0.797672] ohci_hcd 0000:00:13.1: irq 17, io mem 0xfc205000 [ 0.880557] hub 3-0:1.0: USB hub found [ 0.880674] hub 3-0:1.0: 2 ports detected [ 0.880917] ohci_hcd 0000:00:13.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 0.881062] ohci_hcd 0000:00:13.2: OHCI Host Controller [ 0.881282] ohci_hcd 0000:00:13.2: new USB bus registered, assigned bus number 4 [ 0.881476] ohci_hcd 0000:00:13.2: irq 18, io mem 0xfc206000 [ 0.936677] hub 4-0:1.0: USB hub found [ 0.936795] hub 4-0:1.0: 2 ports detected [ 0.937045] ohci_hcd 0000:00:13.3: PCI INT B -> GSI 17 (level, low) -> IRQ 17 [ 0.937189] ohci_hcd 0000:00:13.3: OHCI Host Controller [ 0.937406] ohci_hcd 0000:00:13.3: new USB bus registered, assigned bus number 5 [ 0.937581] ohci_hcd 0000:00:13.3: irq 17, io mem 0xfc207000 [ 0.992666] hub 5-0:1.0: USB hub found [ 0.992784] hub 5-0:1.0: 2 ports detected [ 0.993034] ohci_hcd 0000:00:13.4: PCI INT C -> GSI 18 (level, low) -> IRQ 18 [ 0.993179] ohci_hcd 0000:00:13.4: OHCI Host Controller [ 0.993386] ohci_hcd 0000:00:13.4: new USB bus registered, assigned bus number 6 [ 0.993559] ohci_hcd 0000:00:13.4: irq 18, io mem 0xfc208000 [ 1.037689] isapnp: No Plug & Play device found [ 1.048466] hub 6-0:1.0: USB hub found [ 1.048582] hub 6-0:1.0: 2 ports detected [ 1.048841] uhci_hcd: USB Universal Host Controller Interface driver [ 1.049127] usbcore: registered new interface driver libusual [ 1.049332] i8042: PNP: PS/2 Controller [PNP0303:KEYB,PNP0f13:PS2M] at 0x60,0x64 irq 1,12 [ 1.057092] serio: i8042 KBD port at 0x60,0x64 irq 1 [ 1.057222] serio: i8042 AUX port at 0x60,0x64 irq 12 [ 1.057683] mousedev: PS/2 mouse device common for all mice [ 1.058135] rtc_cmos 00:03: RTC can wake from S4 [ 1.058409] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0 [ 1.058550] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs [ 1.058841] device-mapper: uevent: version 1.0.3 [ 1.059106] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com [ 1.059335] EISA: Probing bus 0 at eisa.0 [ 1.059435] EISA: Cannot allocate resource for mainboard [ 1.059540] Cannot allocate resource for EISA slot 1 [ 1.059643] Cannot allocate resource for EISA slot 2 [ 1.059746] Cannot allocate resource for EISA slot 3 [ 1.059849] Cannot allocate resource for EISA slot 4 [ 1.059952] Cannot allocate resource for EISA slot 5 [ 1.060099] Cannot allocate resource for EISA slot 6 [ 1.060201] Cannot allocate resource for EISA slot 7 [ 1.060304] Cannot allocate resource for EISA slot 8 [ 1.060409] EISA: Detected 0 cards. [ 1.060524] cpufreq-nforce2: No nForce2 chipset. [ 1.060626] cpuidle: using governor ladder [ 1.060752] cpuidle: using governor menu [ 1.060851] EFI Variables Facility v0.08 2004-May-17 [ 1.061442] TCP cubic registered [ 1.061836] NET: Registered protocol family 10 [ 1.064890] NET: Registered protocol family 17 [ 1.065049] Registering the dns_resolver key type [ 1.065218] Using IPI No-Shortcut mode [ 1.070345] PM: Hibernation image not present or could not be loaded. [ 1.070376] registered taskstats version 1 [ 1.081282] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2 [ 1.092614] usb 1-10: new high-speed USB device number 2 using ehci_hcd [ 1.276640] Refined TSC clocksource calibration: 999.987 MHz. [ 1.276761] Switching to clocksource tsc [ 1.880394] Freeing initrd memory: 20332k freed [ 1.908664] Initializing USB Mass Storage driver... [ 1.911562] scsi0 : usb-storage 1-10:1.0 [ 1.911887] usbcore: registered new interface driver usb-storage [ 1.911997] USB Mass Storage support registered. [ 1.923668] Magic number: 9:470:194 [ 1.923932] rtc_cmos 00:03: setting system clock to 2017-03-10 20:11:25 UTC (1489176685) [ 1.924160] powernow-k8: Power state transitions not supported [ 1.924301] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found [ 1.924406] EDD information not available. [ 1.924836] Freeing unused kernel memory: 712k freed [ 1.925757] Write protecting the kernel text: 5628k [ 1.925936] Write protecting the kernel read-only data: 2324k [ 1.986107] udevd[90]: starting version 175 [ 2.322834] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded [ 2.322985] r8169 0000:07:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19 [ 2.323139] r8169 0000:07:00.0: setting latency timer to 64 [ 2.323203] r8169 0000:07:00.0: irq 42 for MSI/MSI-X [ 2.330929] r8169 0000:07:00.0: eth0: RTL8168c/8111c at 0xf8012000, 00:19:99:5c:df:f0, XID 1c2000c0 IRQ 42 [ 2.331087] r8169 0000:07:00.0: eth0: jumbo features [frames: 6128 bytes, tx checksumming: ko] [ 2.395504] scsi1 : pata_atiixp [ 2.399530] scsi2 : pata_atiixp [ 2.400668] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x8410 irq 14 [ 2.400785] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x8418 irq 15 [ 2.909925] scsi 0:0:0:0: Direct-Access Intenso Rainbow Line 8.07 PQ: 0 ANSI: 2 [ 2.915010] sd 0:0:0:0: Attached scsi generic sg0 type 0 [ 2.916092] sd 0:0:0:0: [sda] 16433152 512-byte logical blocks: (8.41 GB/7.83 GiB) [ 2.916787] sd 0:0:0:0: [sda] Write Protect is off [ 2.916897] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00 [ 2.917407] sd 0:0:0:0: [sda] No Caching mode page present [ 2.917516] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 2.920415] sd 0:0:0:0: [sda] No Caching mode page present [ 2.920533] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 3.148326] sda: sda1 [ 3.150935] sd 0:0:0:0: [sda] No Caching mode page present [ 3.151048] sd 0:0:0:0: [sda] Assuming drive cache: write through [ 3.151158] sd 0:0:0:0: [sda] Attached SCSI removable disk [ 5.344037] floppy0: no floppy controllers found [ 6.598151] Btrfs loaded [ 6.615049] xor: automatically using best checksumming function: pIII_sse [ 6.632008] pIII_sse : 3027.000 MB/sec [ 6.632014] xor: using function: pIII_sse (3027.000 MB/sec) [ 6.634405] device-mapper: dm-raid45: initialized v0.2594b [ 7.682027] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 25.248041] floppy0: no floppy controllers found [ 39.116170] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 39.396696] udevd[920]: starting version 175 [ 41.702274] Bluetooth: Core ver 2.16 [ 41.702453] NET: Registered protocol family 31 [ 41.702459] Bluetooth: HCI device and connection manager initialized [ 41.702467] Bluetooth: HCI socket layer initialized [ 41.702471] Bluetooth: L2CAP socket layer initialized [ 41.702495] Bluetooth: SCO socket layer initialized [ 42.176095] Bluetooth: RFCOMM TTY layer initialized [ 42.176109] Bluetooth: RFCOMM socket layer initialized [ 42.176114] Bluetooth: RFCOMM ver 1.11 [ 42.277297] lp: driver loaded but no devices found [ 42.524098] device-mapper: multipath: version 1.3.0 loaded [ 42.980235] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 42.980245] Bluetooth: BNEP filters: protocol multicast [ 43.090944] ppdev: user-space parallel port driver [ 43.798974] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0x8400, revision 0 [ 44.023461] k8temp 0000:00:18.3: Temperature readouts might be wrong - check erratum #141 [ 44.188112] psmouse serio1: hgpk: ID: 00 00 3c [ 44.245095] SP5100 TCO timer: SP5100 TCO WatchDog Timer Driver v0.01 [ 44.248911] SP5100 TCO timer: mmio address 0xfec000f0 already in use [ 44.690030] init: failsafe main process (1093) killed by TERM signal [ 44.783200] s3fb 0000:0d:07.0: PCI INT A -> GSI 20 (level, low) -> IRQ 20 [ 44.885685] input: ImPS/2 Logitech Wheel Mouse as /devices/platform/i8042/serio1/input/input3 [ 45.062560] fbcon: S3 Trio64V2/DX (fb0) is primary device [ 46.130842] Console: switching to colour frame buffer device 160x64 [ 46.225809] fb0: S3 Trio64V2/DX on 0000:0d:07.0, 2 MB RAM, 65 MHz MCLK [ 46.600823] floppy0: no floppy controllers found [ 48.073478] snd_hda_intel 0000:00:14.2: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 48.222581] r8169 0000:07:00.0: eth0: link down [ 48.228570] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 48.229576] ADDRCONF(NETDEV_UP): eth0: link is not ready [ 48.333291] hda_codec: ALC262: BIOS auto-probing. [ 48.348789] input: HDA ATI SB Line as /devices/pci0000:00/0000:00:14.2/sound/card0/input4 [ 48.349302] input: HDA ATI SB Mic as /devices/pci0000:00/0000:00:14.2/sound/card0/input5 [ 48.349755] input: HDA ATI SB Front Headphone as /devices/pci0000:00/0000:00:14.2/sound/card0/input6 [ 48.350200] input: HDA ATI SB Line-Out as /devices/pci0000:00/0000:00:14.2/sound/card0/input7 [ 52.982868] init: alsa-restore main process (1471) terminated with status 99 [ 61.300610] init: plymouth-upstart-bridge main process (942) killed by TERM signal [ 108.182164] r8169 0000:07:00.0: eth0: link up [ 108.182559] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 118.592026] eth0: no IPv6 routers present
