(module ToggleSwitch-6P_Fun (layer F.Cu) (tedit 58C6EF26)
  (fp_text reference S** (at 0 -41) (layer F.SilkS)
    (effects (font (size 5 5) (thickness 0.5)))
  (fp_text value ToggleSwitch-6P_Fun (at 0 43) (layer F.Fab)
  (fp_line (start -64 -32) (end -65 -32) (layer F.SilkS) (width 0.25))
  (fp_line (start -64 -32) (end 65 -32) (layer F.SilkS) (width 3))
  (fp_line (start 65 -32) (end 65 32) (layer F.SilkS) (width 3))
  (fp_line (start 65 32) (end -65 32) (layer F.SilkS) (width 3))
  (fp_line (start -65 32) (end -65 -32) (layer F.SilkS) (width 3))
  (pad 1 thru_hole circle (at -50 -20) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 7 thru_hole circle (at -50 0) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 11 thru_hole circle (at 30 0) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 5 thru_hole circle (at 30 -20) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 17 thru_hole circle (at 30 20) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 16 thru_hole circle (at 10 20) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 4 thru_hole circle (at 10 -20) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 12 thru_hole circle (at 50 0) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 10 thru_hole circle (at 10 0) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 6 thru_hole circle (at 50 -20) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 18 thru_hole circle (at 50 20) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 15 thru_hole circle (at -10 20) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 3 thru_hole circle (at -10 -20) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 9 thru_hole circle (at -10 0) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 13 thru_hole circle (at -50 20) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 8 thru_hole circle (at -30 0) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 2 thru_hole circle (at -30 -20) (size 15 15) (drill 10) (layers *.Cu *.Mask))
  (pad 14 thru_hole circle (at -30 20) (size 15 15) (drill 10) (layers *.Cu *.Mask))
