(module Relays_Fujitsu-JV-KT-Series_RevA_28Mar2017 (layer F.Cu) (tedit 58DABF34)
  (fp_text reference K** (at 0 -7) (layer F.SilkS)
    (effects (font (size 1 1) (thickness 0.15)))
  (fp_text value Relays_Fujitsu-JV-KT-Series_RevA_28Mar2017 (at 0 7.5) (layer F.Fab)
  (fp_line (start 2.5 -1.5) (end 2.5 -1) (layer F.SilkS) (width 0.25))
  (fp_line (start 2.5 -1.5) (end 2.5 -3) (layer F.SilkS) (width 0.25))
  (fp_line (start 2.5 -3) (end 3 -3) (layer F.SilkS) (width 0.25))
  (fp_line (start 2.5 1) (end 2.5 2.5) (layer F.SilkS) (width 0.25))
  (fp_line (start 2.5 2.5) (end 3 2.5) (layer F.SilkS) (width 0.25))
  (fp_line (start 2.5 1) (end 1.5 -1) (layer F.SilkS) (width 0.25))
  (fp_line (start -8 -1.5) (end -7 -1.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -7 -1.5) (end -7 1.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -7 1.5) (end -8 1.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -8 1.5) (end -8 -1.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -2 1.5) (end -2 2.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -2 2.5) (end -3 2.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -2 -2.5) (end -2 -3.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -2 -3.5) (end -3 -3.5) (layer F.SilkS) (width 0.25))
  (fp_arc (start -2.5 1) (end -2 0.5) (angle 90) (layer F.SilkS) (width 0.25))
  (fp_arc (start -2.5 0) (end -2 -0.5) (angle 90) (layer F.SilkS) (width 0.25))
  (fp_arc (start -2.5 -1) (end -2 -1.5) (angle 90) (layer F.SilkS) (width 0.25))
  (fp_arc (start -2.5 -2) (end -2 -2.5) (angle 90) (layer F.SilkS) (width 0.25))
  (fp_line (start 9 -2) (end 9 2) (layer F.SilkS) (width 0.25))
  (fp_line (start -9 -2.3) (end -9 2.3) (layer F.SilkS) (width 0.25))
  (fp_line (start -9 -5.5) (end -9 -5.1) (layer F.SilkS) (width 0.25))
  (fp_line (start -8.5 5.5) (end -9 5.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -9 5.5) (end -9 5.2) (layer F.SilkS) (width 0.25))
  (fp_line (start 9 4.6) (end 9 5.5) (layer F.SilkS) (width 0.25))
  (fp_line (start 9 5.5) (end -3.8 5.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -3.8 -5.5) (end 9 -5.5) (layer F.SilkS) (width 0.25))
  (fp_line (start 9 -5.5) (end 9 -4.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -9 -5.5) (end -8.6 -5.5) (layer F.SilkS) (width 0.25))
  (pad A1 thru_hole oval (at -6.3 -3.8) (size 5.5 3.5) (drill 1.5) (layers *.Cu *.Mask))
  (pad A1 thru_hole oval (at -6.3 3.8) (size 5.5 3.5) (drill 1.5) (layers *.Cu *.Mask))
  (pad 14 thru_hole oval (at 6.3 -3.2) (size 5.5 3.5) (drill 1.6) (layers *.Cu *.Mask))
  (pad 11 thru_hole oval (at 6.3 3.1) (size 5.5 3.5) (drill 1.6) (layers *.Cu *.Mask))
