(module Relays_Fujitsu-JV-KT-Series_RevB_29Mar2017 (layer F.Cu) (tedit 58DAE4C6)
  (fp_text reference K** (at 0 -7) (layer F.SilkS)
    (effects (font (size 1 1) (thickness 0.15)))
  (fp_text value Relays_Fujitsu-JV-KT-Series_RevB_29Mar2017 (at 0 7.5) (layer F.Fab)
  (fp_line (start 9 5.5) (end 9 5.25) (layer F.SilkS) (width 0.25))
  (fp_line (start 9 1) (end 9 1.25) (layer F.SilkS) (width 0.25))
  (fp_line (start 9 -1.25) (end 9 1) (layer F.SilkS) (width 0.25))
  (fp_line (start 9 -5.5) (end 9 -5.25) (layer F.SilkS) (width 0.25))
  (fp_line (start -3.75 -5.5) (end -5.5 -5.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -3.75 5.5) (end -5.5 5.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -9 -1.75) (end -9 1.75) (layer F.SilkS) (width 0.25))
  (fp_line (start 3.5 -1.5) (end 3.5 -1) (layer F.SilkS) (width 0.25))
  (fp_line (start 3.5 -1.5) (end 3.5 -3) (layer F.SilkS) (width 0.25))
  (fp_line (start 3.5 -3) (end 4 -3) (layer F.SilkS) (width 0.25))
  (fp_line (start 3.5 1) (end 3.5 2.5) (layer F.SilkS) (width 0.25))
  (fp_line (start 3.5 2.5) (end 4 2.5) (layer F.SilkS) (width 0.25))
  (fp_line (start 3.5 1) (end 2.5 -1) (layer F.SilkS) (width 0.25))
  (fp_line (start -8 -1.5) (end -7 -1.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -7 -1.5) (end -7 1.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -7 1.5) (end -8 1.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -8 1.5) (end -8 -1.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -3.25 1.5) (end -3.25 2.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -3.25 2.5) (end -4.25 2.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -3.25 -2.5) (end -3.25 -3.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -3.25 -3.5) (end -4.25 -3.5) (layer F.SilkS) (width 0.25))
  (fp_arc (start -3.75 1) (end -3.25 0.5) (angle 90) (layer F.SilkS) (width 0.25))
  (fp_arc (start -3.75 0) (end -3.25 -0.5) (angle 90) (layer F.SilkS) (width 0.25))
  (fp_arc (start -3.75 -1) (end -3.25 -1.5) (angle 90) (layer F.SilkS) (width 0.25))
  (fp_arc (start -3.75 -2) (end -3.25 -2.5) (angle 90) (layer F.SilkS) (width 0.25))
  (fp_line (start 9 5.5) (end -3.8 5.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -3.8 -5.5) (end 9 -5.5) (layer F.SilkS) (width 0.25))
  (pad A1 thru_hole oval (at -7.6 -3.8) (size 5.5 3.5) (drill 1.5) (layers *.Cu *.Mask))
  (pad A1 thru_hole oval (at -7.6 3.8) (size 5.5 3.5) (drill 1.5) (layers *.Cu *.Mask))
  (pad 14 thru_hole oval (at 7.6 -3.2) (size 5.5 3.5) (drill 1.6) (layers *.Cu *.Mask))
  (pad 11 thru_hole oval (at 7.6 3.2) (size 5.5 3.5) (drill 1.6) (layers *.Cu *.Mask))
