=> boot switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf reading /extlinux/extlinux.conf 150 bytes read in 5 ms (29.3 KiB/s) Retrieving file: /hw_intf.conf reading /hw_intf.conf 109 bytes read in 3 ms (35.2 KiB/s) hw_conf.valid = 1 hw_conf.i2c1 = 1 hw_conf.i2c4 = 1 hw_conf.spi2 = 1 hw_conf.pwm2 = 1 hw_conf.pwm3 = 1 hw_conf.uart1 = 1 1: kernel-4.4 Retrieving file: /zImage reading /zImage 7017264 bytes read in 518 ms (12.9 MiB/s) append: earlyprintk console=ttyS1,115200n8 root=/dev/mmcblk0p2 rw init=/sbin/in1 Retrieving file: /rk3288-miniarm.dtb reading /rk3288-miniarm.dtb 45692 bytes read in 8 ms (5.4 MiB/s) ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Device Tree to 1fff1000, end 1ffff67b ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x500 [ 0.000000] Initializing cgroup subsys cpuset [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.16 (leslie_yu@incredible) (gcc version 5.4.0 27 [ 0.000000] CPU: ARMv7 Processor [410fc0d1] revision 1 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructie [ 0.000000] Machine model: rockchip,rk3288-miniarm [ 0.000000] cma: Reserved 128 MiB at 0x78000000 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] PERCPU: Embedded 13 pages/cpu @eef8d000 s24216 r8192 d20840 u5328 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pa2 [ 0.000000] Kernel command line: earlyprintk console=ttyS1,115200n8 root=/de1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 1931672K/2097152K available (11118K kernel code, 814K rw) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0efd964 (15319 kB) [ 0.000000] .init : 0xc0f00000 - 0xc1000000 (1024 kB) [ 0.000000] .data : 0xc1000000 - 0xc10cbb88 ( 815 kB) [ 0.000000] .bss : 0xc10cd000 - 0xc1153dac ( 540 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] L2C: failed to init: -19 [ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless [ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398s [ 0.000028] Switching to timer-based delay loop, resolution 41ns [ 0.002603] Console: colour dummy device 80x30 [ 0.002643] Calibrating delay loop (skipped), value calculated using timer f) [ 0.002667] pid_max: default: 32768 minimum: 301 [ 0.002798] Security Framework initialized [ 0.002815] Yama: becoming mindful. [ 0.002898] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.002919] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.004040] Initializing cgroup subsys devices [ 0.004070] Initializing cgroup subsys freezer [ 0.004112] CPU: Testing write buffer coherency: ok [ 0.004161] ftrace: allocating 38837 entries in 114 pages [ 0.114386] CPU0: update cpu_capacity 430 [ 0.114406] CPU0: thread -1, cpu 0, socket 5, mpidr 80000500 [ 0.114786] Setting up static identity map for 0x100000 - 0x1000b8 [ 0.118319] CPU1: update cpu_capacity 430 [ 0.118329] CPU1: thread -1, cpu 1, socket 5, mpidr 80000501 [ 0.120280] CPU2: update cpu_capacity 430 [ 0.120290] CPU2: thread -1, cpu 2, socket 5, mpidr 80000502 [ 0.122229] CPU3: update cpu_capacity 430 [ 0.122239] CPU3: thread -1, cpu 3, socket 5, mpidr 80000503 [ 0.122362] Brought up 4 CPUs [ 0.122403] SMP: Total of 4 processors activated (192.00 BogoMIPS). [ 0.122413] CPU: All CPU(s) started in SVC mode. [ 0.124255] devtmpfs: initialized [ 0.141983] VFP support v0.3: implementor 41 architecture 3 part 30 variant 0 [ 0.142479] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms [ 0.148567] pinctrl core: initialized pinctrl subsystem [ 0.149922] NET: Registered protocol family 16 [ 0.151782] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.174219] cpuidle: using governor ladder [ 0.204258] cpuidle: using governor menu [ 0.239722] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint. [ 0.239738] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.287930] iommu: Adding device ff930000.vop to group 0 [ 0.288062] iommu: Adding device ff940000.vop to group 1 [ 0.288197] iommu: Adding device ff9a0000.vpu-service to group 2 [ 0.288338] iommu: Adding device ff9c0000.hevc-service to group 3 [ 0.290095] SCSI subsystem initialized [ 0.290458] usbcore: registered new interface driver usbfs [ 0.290550] usbcore: registered new interface driver hub [ 0.290633] usbcore: registered new device driver usb [ 0.290847] Linux video capture interface: v2.00 [ 0.290909] pps_core: LinuxPPS API ver. 1 registered [ 0.290921] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom> [ 0.290958] PTP clock support registered [ 0.291704] rockchip ion: success to create - cma-heap [ 0.291733] rockchip ion: success to create - system-heap [ 0.292968] Advanced Linux Sound Architecture Driver Initialized. [ 0.293925] Bluetooth: Core ver 2.21 [ 0.293982] NET: Registered protocol family 31 [ 0.293994] Bluetooth: HCI device and connection manager initialized [ 0.294015] Bluetooth: HCI socket layer initialized [ 0.294032] Bluetooth: L2CAP socket layer initialized [ 0.294080] Bluetooth: SCO socket layer initialized [ 0.295478] clocksource: Switched to clocksource arch_sys_counter [ 0.376163] FS-Cache: Loaded [ 0.395638] NET: Registered protocol family 2 [ 0.396510] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 0.396624] TCP bind hash table entries: 8192 (order: 5, 163840 bytes) [ 0.396905] TCP: Hash tables configured (established 8192 bind 8192) [ 0.396991] UDP hash table entries: 512 (order: 2, 24576 bytes) [ 0.397062] UDP-Lite hash table entries: 512 (order: 2, 24576 bytes) [ 0.397375] NET: Registered protocol family 1 [ 0.397858] RPC: Registered named UNIX socket transport module. [ 0.397873] RPC: Registered udp transport module. [ 0.397883] RPC: Registered tcp transport module. [ 0.397893] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.398874] hw perfevents: enabled with armv7_cortex_a12 PMU driver, 7 counte [ 0.401235] futex hash table entries: 1024 (order: 4, 65536 bytes) [ 0.402096] Initialise system trusted keyring [ 0.416597] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.419341] NFS: Registering the id_resolver key type [ 0.419393] Key type id_resolver registered [ 0.419405] Key type id_legacy registered [ 0.419446] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.419485] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 0.420924] FS-Cache: Netfs 'cifs' registered for caching [ 0.421423] Key type cifs.spnego registered [ 0.421464] Key type cifs.idmap registered [ 0.421502] fuse init (API version 7.23) [ 0.422456] SGI XFS with ACLs, security attributes, realtime, no debug enabld [ 0.431174] NET: Registered protocol family 38 [ 0.431220] Key type asymmetric registered [ 0.431240] Asymmetric key parser 'x509' registered [ 0.431357] bounce: pool size: 64 pages [ 0.431645] Block layer SCSI generic (bsg) driver version 0.4 loaded (major ) [ 0.431671] io scheduler noop registered [ 0.431690] io scheduler deadline registered [ 0.431746] io scheduler cfq registered (default) [ 0.432371] rockchip-usb-phy phy: vbus_drv is not assigned! [ 0.436460] rk-vcodec ff9a0000.vpu-service: No core reset resource define [ 0.436546] rk-vcodec ff9a0000.vpu-service: do not have pd_video [ 0.436583] rk-vcodec ff9a0000.vpu-service: probe device [ 0.436662] rk-vcodec ff9a0000.vpu-service: vpu mmu dec eea84e10 [ 0.436718] rk-vcodec ff9a0000.vpu-service: checking hw id 4831 [ 0.437475] rk-vcodec ff9a0000.vpu-service: allocator is drm [ 0.437849] rk-vcodec ff9a0000.vpu-service: init success [ 0.438343] rk-vcodec ff9c0000.hevc-service: No aclk reset resource define [ 0.438362] rk-vcodec ff9c0000.hevc-service: No hclk reset resource define [ 0.438388] rk-vcodec ff9c0000.hevc-service: failed on clk_get pd_hevc [ 0.438515] rk-vcodec ff9c0000.hevc-service: do not have pd_video [ 0.438550] rk-vcodec ff9c0000.hevc-service: probe device [ 0.438631] rk-vcodec ff9c0000.hevc-service: vpu mmu dec eea85210 [ 0.438682] rk-vcodec ff9c0000.hevc-service: checking hw id 6867 [ 0.439210] rk-vcodec ff9c0000.hevc-service: allocator is drm [ 0.439575] rk-vcodec ff9c0000.hevc-service: init success [ 0.442916] dma-pl330 ff250000.dma-controller: Loaded driver for PL330 DMAC-0 [ 0.442939] dma-pl330 ff250000.dma-controller: DBUFF-128x8bytes Num_Ch6 [ 0.444164] dma-pl330 ffb20000.dma-controller: Loaded driver for PL330 DMAC-0 [ 0.444186] dma-pl330 ffb20000.dma-controller: DBUFF-64x8bytes Num_Cha0 [ 0.445092] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled [ 0.447969] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 37, base_baud =A [ 0.449075] console [ttyS1] disabled [ 0.449149] ff190000.serial: ttyS1 at MMIO 0xff190000 (irq = 38, base_baud =A [ 1.324168] console [ttyS1] enabled [ 1.328338] rockchip-pinctrl pinctrl: pin gpio7-22 already requested by ff68l [ 1.339079] rockchip-pinctrl pinctrl: pin-238 (ff690000.serial) status -22 [ 1.345987] rockchip-pinctrl pinctrl: could not request pin 238 (gpio7-22) fl [ 1.357220] dw-apb-uart ff690000.serial: Error applying setting, reverse thik [ 1.365435] ff690000.serial: ttyS2 at MMIO 0xff690000 (irq = 39, base_baud =A [ 1.375629] ff1b0000.serial: ttyS3 at MMIO 0xff1b0000 (irq = 40, base_baud =A [ 1.385309] dw-apb-uart: probe of ff1c0000.serial failed with error -28 [ 1.393495] [drm] Initialized drm 1.1.0 20060810 [ 1.403465] rockchip-drm display-subsystem: bound ff940000.vop (ops vop_comp) [ 1.411758] rockchip-drm display-subsystem: bound ff930000.vop (ops vop_comp) [ 1.419734] rockchip-drm display-subsystem: failed to bind ff960000.mipi (op7 [ 1.430178] rockchip-drm display-subsystem: master bind failed: -517 [ 1.436941] usbcore: registered new interface driver udl [ 1.442331] find panel: asus,tc358762 [ 1.446052] ff960000.mipi.0 supply power not found, using dummy regulator [ 1.453533] mali ffa30000.gpu: Failed to get regulator [ 1.458713] mali ffa30000.gpu: Power control initialization failed [ 1.466646] brd: module loaded [ 1.479341] loop: module loaded [ 1.483517] zram: Added device: zram0 [ 1.487281] lkdtm: No crash points registered, enable through debugfs [ 1.497474] tun: Universal TUN/TAP device driver, 1.6 [ 1.502530] tun: (C) 1999-2004 Max Krasnyansky [ 1.510468] rk_gmac-dwmac ff290000.ethernet: phy regulator is not available g [ 1.520242] PPP generic driver version 2.4.2 [ 1.524926] usbcore: registered new interface driver rndis_wlan [ 1.531184] usbcore: registered new interface driver rt2800usb [ 1.537080] Rockchip WiFi SYS interface (V1.00) ... [ 1.542109] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet drr [ 1.549610] usbcore: registered new interface driver pegasus [ 1.555347] usbcore: registered new interface driver rtl8150 [ 1.561124] usbcore: registered new interface driver r8152 [ 1.566736] usbcore: registered new interface driver asix [ 1.572213] usbcore: registered new interface driver ax88179_178a [ 1.578415] usbcore: registered new interface driver cdc_ether [ 1.584322] usbcore: registered new interface driver dm9601 [ 1.590045] usbcore: registered new interface driver smsc75xx [ 1.595939] usbcore: registered new interface driver smsc95xx [ 1.601768] usbcore: registered new interface driver net1080 [ 1.607542] usbcore: registered new interface driver rndis_host [ 1.613540] usbcore: registered new interface driver MOSCHIP usb-ethernet drr [ 1.621089] usbcore: registered new interface driver cdc_ncm [ 1.626860] usbcore: registered new interface driver cdc_mbim [ 1.632939] ff540000.usb supply vusb_d not found, using dummy regulator [ 1.639659] ff540000.usb supply vusb_a not found, using dummy regulator [ 2.507065] dwc2 ff540000.usb: DWC OTG Controller [ 2.511816] dwc2 ff540000.usb: new USB bus registered, assigned bus number 1 [ 2.518969] dwc2 ff540000.usb: irq 45, io mem 0x00000000 [ 2.524630] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.531460] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1 [ 2.538705] usb usb1: Product: DWC OTG Controller [ 2.543411] usb usb1: Manufacturer: Linux 4.4.16 dwc2_hsotg [ 2.549004] usb usb1: SerialNumber: ff540000.usb [ 2.554545] hub 1-0:1.0: USB hub found [ 2.558404] hub 1-0:1.0: 1 port detected [ 2.563184] ff580000.usb supply vusb_d not found, using dummy regulator [ 2.569911] ff580000.usb supply vusb_a not found, using dummy regulator [ 2.885656] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM [ 2.945530] usb 1-1: new high-speed USB device number 2 using dwc2 [ 3.157042] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610 [ 3.163750] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0 [ 3.170922] usb 1-1: Product: USB2.0 Hub [ 3.175905] hub 1-1:1.0: USB hub found [ 3.180005] hub 1-1:1.0: 4 ports detected [ 3.415950] dwc2 ff580000.usb: DWC OTG Controller [ 3.420692] dwc2 ff580000.usb: new USB bus registered, assigned bus number 2 [ 3.427820] dwc2 ff580000.usb: irq 46, io mem 0x00000000 [ 3.433381] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.440209] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1 [ 3.447451] usb usb2: Product: DWC OTG Controller [ 3.452158] usb usb2: Manufacturer: Linux 4.4.16 dwc2_hsotg [ 3.457757] usb usb2: SerialNumber: ff580000.usb [ 3.463300] hub 2-0:1.0: USB hub found [ 3.467168] hub 2-0:1.0: 1 port detected [ 3.472957] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.479537] ehci-platform: EHCI generic platform driver [ 3.485143] ehci-platform ff500000.usb: EHCI Host Controller [ 3.491142] ehci-platform ff500000.usb: new USB bus registered, assigned bus3 [ 3.499245] ehci-platform ff500000.usb: irq 44, io mem 0xff500000 [ 3.515528] ehci-platform ff500000.usb: USB 2.0 started, EHCI 1.00 [ 3.521985] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002 [ 3.528817] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber1 [ 3.536062] usb usb3: Product: EHCI Host Controller [ 3.540942] usb usb3: Manufacturer: Linux 4.4.16 ehci_hcd [ 3.546363] usb usb3: SerialNumber: ff500000.usb [ 3.551851] hub 3-0:1.0: USB hub found [ 3.555710] hub 3-0:1.0: 1 port detected [ 3.560644] usbcore: registered new interface driver cdc_acm [ 3.566357] cdc_acm: USB Abstract Control Model driver for USB modems and ISs [ 3.574596] usbcore: registered new interface driver cdc_wdm [ 3.580499] usbcore: registered new interface driver usb-storage [ 3.586696] usbcore: registered new interface driver usbserial [ 3.592593] usbcore: registered new interface driver usbserial_generic [ 3.599200] usbserial: USB Serial support registered for generic [ 3.605296] usbcore: registered new interface driver cp210x [ 3.610947] usbserial: USB Serial support registered for cp210x [ 3.617015] usbcore: registered new interface driver ftdi_sio [ 3.622817] usbserial: USB Serial support registered for FTDI USB Serial Deve [ 3.630417] usbcore: registered new interface driver keyspan [ 3.636163] usbserial: USB Serial support registered for Keyspan - (without ) [ 3.644034] usbserial: USB Serial support registered for Keyspan 1 port adapr [ 3.651419] usbserial: USB Serial support registered for Keyspan 2 port adapr [ 3.658943] usbserial: USB Serial support registered for Keyspan 4 port adapr [ 3.666385] usbcore: registered new interface driver option [ 3.672005] usbserial: USB Serial support registered for GSM modem (1-port) [ 3.679335] usbcore: registered new interface driver oti6858 [ 3.685043] usbserial: USB Serial support registered for oti6858 [ 3.691168] usbcore: registered new interface driver pl2303 [ 3.696835] usbserial: USB Serial support registered for pl2303 [ 3.702855] usbcore: registered new interface driver qcserial [ 3.708683] usbserial: USB Serial support registered for Qualcomm USB modem [ 3.715786] usbcore: registered new interface driver sierra [ 3.721406] usbserial: USB Serial support registered for Sierra USB modem [ 3.729413] usbcore: registered new interface driver iforce [ 3.735111] usbcore: registered new interface driver xpad [ 3.740799] usbcore: registered new interface driver usbtouchscreen [ 3.747603] i2c /dev entries driver [ 3.752143] rk3x-i2c ff140000.i2c: Initialized RK3xxx I2C bus at f091a000 [ 3.760123] tinker-mcu: tinker_mcu_probe: address = 0x45 [ 3.765440] tinker-mcu: send_cmds: 80 [ 3.769340] tinker-mcu: send_cmds: send command failed, ret = -6 [ 3.775349] tinker-mcu: tinker_mcu_probe: init_cmd_check failed, -6 [ 3.781889] tinker-ft5406: tinker_ft5406_probe: address = 0x38 [ 3.875530] usb 3-1: new high-speed USB device number 2 using ehci-platform [ 4.223299] usb 3-1: config 1 has an invalid interface number: 255 but max i6 [ 4.230645] usb 3-1: config 1 has no interface number 6 [ 4.237267] usb 3-1: New USB device found, idVendor=0bda, idProduct=481a [ 4.243980] usb 3-1: New USB device strings: Mfr=3, Product=1, SerialNumber=2 [ 4.251139] usb 3-1: Product: USB Audio [ 4.254979] usb 3-1: Manufacturer: Generic [ 4.259096] usb 3-1: SerialNumber: 201405280001 [ 4.385510] tinker-ft5406: tinker_ft5406_probe: wait connected timeout [ 4.392083] rk3x-i2c ff150000.i2c: Initialized RK3xxx I2C bus at f091c000 [ 4.399833] rk3x-i2c ff160000.i2c: Initialized RK3xxx I2C bus at f091e000 [ 4.406843] rockchip-pinctrl pinctrl: pin gpio7-19 already requested by ff98c [ 4.417397] rockchip-pinctrl pinctrl: pin-235 (ff170000.i2c) status -22 [ 4.424016] rockchip-pinctrl pinctrl: could not request pin 235 (gpio7-19) fl [ 4.435160] rk3x-i2c ff170000.i2c: Error applying setting, reverse things bak [ 4.443128] rk3x-i2c ff170000.i2c: Initialized RK3xxx I2C bus at f0920000 [ 4.451630] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.457917] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.464145] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.470270] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.476393] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.482487] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.488743] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.495004] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.501262] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.507384] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.513604] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.521038] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.527392] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.533664] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.540087] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.546922] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.553312] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.559623] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.566416] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.573616] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.580601] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.587706] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.594643] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.601889] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.608862] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.616751] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.623388] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.630032] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.636307] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.642400] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.648531] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.654622] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.660743] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.666865] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.672957] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.679344] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 4.685907] rk808-rtc rk808-rtc: rtc core: registered rk808-rtc as rtc0 [ 4.693043] rk3x-i2c ff650000.i2c: Initialized RK3xxx I2C bus at f0922000 [ 4.701919] at24 2-0050: 1024 byte 24c08 EEPROM, writable, 1 bytes/write [ 4.708694] rk3x-i2c ff660000.i2c: Initialized RK3xxx I2C bus at f0924000 [ 4.716477] imx219 2-0010: probing... [ 4.720274] vcc33_mipi: supplied by vcc_sys [ 4.724820] imx219 2-0010: probing successful [ 4.729865] usbcore: registered new interface driver uvcvideo [ 4.735644] USB Video Class driver (1.1.1) [ 4.740964] vcc_18: supplied by vcc_sys [ 4.745070] vcc_io: supplied by vcc_sys [ 4.749002] vccio_sd: supplied by vcc_io [ 4.754049] rk_tsadcv2_initialize: Missing rockchip,grf property [ 4.761497] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-m [ 4.770447] Bluetooth: Virtual HCI driver ver 1.5 [ 4.775411] Bluetooth: HCI UART driver ver 2.3 [ 4.779900] Bluetooth: HCI UART protocol H4 registered [ 4.785038] Bluetooth: HCI UART protocol Three-wire (H5) registered [ 4.791322] rtk_btcoex: rtk_btcoex_init: version: 1.2 [ 4.796388] rtk_btcoex: create workqueue [ 4.800690] rtk_btcoex: alloc buffers 1408, 2240 for ev and l2 [ 4.806699] usbcore: registered new interface driver bfusb [ 4.812321] usbcore: registered new interface driver btusb [ 4.817853] Bluetooth: Generic Bluetooth SDIO driver ver 0.1 [ 4.823888] vdd_arm: supplied by vcc_sys [ 4.828206] cpu cpu0: chip_version: 1 0x2 [ 4.834993] cpufreq-dt cpufreq-dt: failed register driver: -17 [ 4.840897] cpufreq-dt: probe of cpufreq-dt failed with error -17 [ 4.847194] sdhci: Secure Digital Host Controller Interface driver [ 4.853384] sdhci: Copyright(c) Pierre Ossman [ 4.857800] Synopsys Designware Multimedia Card Interface Driver [ 4.864420] dwmmc_rockchip ff0c0000.dwmmc: IDMAC supports 32-bit address mod. [ 4.871701] dwmmc_rockchip ff0c0000.dwmmc: Using internal DMA controller. [ 4.878498] dwmmc_rockchip ff0c0000.dwmmc: Version ID is 270a [ 4.884268] dwmmc_rockchip ff0c0000.dwmmc: DW MMC controller at irq 29,32 bio [ 4.894049] vcc33_sd: supplied by vcc_io [ 4.898378] rockchip-iodomain io-domains: Setting to 3300000 done [ 4.904465] rockchip-iodomain io-domains: Setting to 3300000 done [ 4.925509] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,) [ 4.946568] dwmmc_rockchip ff0c0000.dwmmc: 1 slots initialized [ 4.954922] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mod. [ 4.962240] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller. [ 4.969080] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a [ 4.975878] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bio [ 4.987677] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found [ 4.993859] dwmmc_rockchip ff0d0000.dwmmc: No vqmmc regulator found [ 5.000496] sdhci-pltfm: SDHCI platform and OF driver helper [ 5.006739] ledtrig-cpu: registered to indicate activity on CPUs [ 5.012791] hidraw: raw HID events driver (C) Jiri Kosina [ 5.020640] input: Generic USB Audio as /devices/platform/ff500000.usb/usb3/0 [ 5.067438] rockchip-iodomain io-domains: Setting to 3300000 done [ 5.073625] rockchip-iodomain io-domains: Setting to 1800000 done [ 5.085923] hid-generic 0003:0BDA:481A.0001: input,hiddev0,hidraw0: USB HID 5 [ 5.099603] usbcore: registered new interface driver usbhid [ 5.105178] usbhid: USB HID core driver [ 5.109329] ashmem: initialized [ 5.112943] vcc18_ldo1: supplied by vcc_sys [ 5.128786] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000) [ 5.807737] dwmmc_rockchip ff0c0000.dwmmc: Successfully tuned phase to 202 [ 5.814731] mmc0: new ultra high speed SDR104 SDHC card at address aaaa [ 5.824086] mmcblk0: mmc0:aaaa SE32G 29.7 GiB [ 5.832912] mmcblk0: p1 p2 p3 p4 [ 7.263424] usbcore: registered new interface driver snd-usb-audio [ 7.282220] u32 classifier [ 7.284986] Netfilter messages via NETLINK v0.30. [ 7.290034] nf_conntrack version 0.5.0 (16384 buckets, 65536 max) [ 7.296909] ctnetlink v0.93: registering with nfnetlink. [ 7.302646] ip_tables: (C) 2000-2006 Netfilter Core Team [ 7.308059] Initializing XFRM netlink socket [ 7.312961] NET: Registered protocol family 10 [ 7.318056] ip6_tables: (C) 2000-2006 Netfilter Core Team [ 7.323586] sit: IPv6 over IPv4 tunneling driver [ 7.328623] NET: Registered protocol family 17 [ 7.333076] NET: Registered protocol family 15 [ 7.337559] bridge: automatic filtering via arp/ip/ip6tables has been deprec. [ 7.350243] Bluetooth: RFCOMM TTY layer initialized [ 7.355125] Bluetooth: RFCOMM socket layer initialized [ 7.360282] Bluetooth: RFCOMM ver 1.11 [ 7.364037] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 7.369963] Bluetooth: HIDP socket layer initialized [ 7.374953] 8021q: 802.1Q VLAN Support v1.8 [ 7.379155] lib80211: common routines for IEEE802.11 drivers [ 7.384836] [WLAN_RFKILL]: Enter rfkill_wlan_init [ 7.389661] [WLAN_RFKILL]: Enter rfkill_wlan_probe [ 7.394459] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi_chip_type = ap6212 [ 7.401338] [WLAN_RFKILL]: wlan_platdata_parse_dt: enable wifi power control. [ 7.408469] [WLAN_RFKILL]: wlan_platdata_parse_dt: wifi power controled by g. [ 7.415895] [WLAN_RFKILL]: wlan_platdata_parse_dt: get property: WIFI,host_w. [ 7.425096] [WLAN_RFKILL]: rfkill_wlan_probe: init gpio [ 7.430317] [WLAN_RFKILL]: Exit rfkill_wlan_probe [ 7.435043] [BT_RFKILL]: Enter rfkill_rk_init [ 7.439605] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: uart_rts. [ 7.447792] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,reset. [ 7.455892] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_. [ 7.463887] [BT_RFKILL]: bluetooth_platdata_parse_dt: get property: BT,wake_. [ 7.472248] [BT_RFKILL]: Request irq for bt wakeup host [ 7.477494] [BT_RFKILL]: BT_WAKE_HOST IRQ fired [ 7.482031] [BT_RFKILL]: ** disable irq [ 7.485873] [BT_RFKILL]: bt_default device registered. [ 7.491043] Key type dns_resolver registered [ 7.495400] cif_isp10_v4l2_drv_probe: probing... [ 7.500077] cif_isp10_pltfrm_dev_init(1018) ERR: could not get default pinste [ 7.507379] cif_isp10_pltfrm_dev_init WARN: could not get pins_sleep pinstate [ 7.514498] cif_isp10_pltfrm_dev_init WARN: could not get pins_inactive pinse [ 7.547343] imx219.imx_camera_module_write_config(180) ERR: no active sensorn [ 7.555418] imx219.imx_camera_module_write_config(211) ERR: failed with erro4 [ 7.563225] imx219.pltfrm_camera_module_read_reg(990) ERR: i2c read from off6 [ 7.573440] imx219.pltfrm_camera_module_read_reg(990) ERR: i2c read from off6 [ 7.583517] imx219.imx219_check_camera_id(759) ERR: register read failed, ca? [ 7.592636] imx219.imx219_check_camera_id(776) ERR: failed with error (-6) [ 7.599523] imx219.imx_camera_module_attach(234) ERR: failed with error -6 [ 7.606390] cif_isp10_img_src_v4l2_i2c_subdev_to_img_src(59) ERR: failed wit6 [ 7.614289] cif_isp10_img_src_to_img_src(70) ERR: to_img_src failed! [ 7.620636] cif_isp10_img_src_to_img_src(78) ERR: failed with error -14 [ 7.627242] cif_isp10_img_srcs_init(1080) ERR: failed with error -14 [ 7.633582] cif_isp10_create(5412) ERR: cif_isp10_img_srcs_init failed [ 7.640102] cif_isp10_create(5447) ERR: failed with error -14 [ 7.646011] ThumbEE CPU extension supported. [ 7.650279] Registering SWP/SWPB emulation handler [ 7.655385] Loading compiled-in X.509 certificates [ 7.660956] rockchip-drm display-subsystem: bound ff940000.vop (ops vop_comp) [ 7.668983] rockchip-drm display-subsystem: bound ff930000.vop (ops vop_comp) [ 7.676936] panel doesn't be connected [ 7.680682] rockchip-drm display-subsystem: bound ff960000.mipi (ops dw_mipi) [ 7.688692] i2c i2c-6: of_i2c: modalias failure on /hdmi@ff980000/ports [ 7.695303] dwhdmi-rockchip ff980000.hdmi: registered DesignWare HDMI I2C bur [ 7.703077] dwhdmi-rockchip ff980000.hdmi: Detected HDMI controller 0x20:0xa1 [ 7.711296] rockchip-drm display-subsystem: bound ff980000.hdmi (ops dw_hdmi) [ 7.719636] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 7.726245] [drm] No driver support for vblank timestamp query. [ 7.732158] rockchip-drm display-subsystem: failed to parse display resources [ 7.739303] rockchip-drm display-subsystem: No connectors reported connecteds [ 7.747317] [drm] Cannot find any crtc or sizes - going 1024x768 [ 7.761728] Console: switching to colour frame buffer device 128x48 [ 7.772753] rockchip-drm display-subsystem: fb0: frame buffer device [ 7.805705] vdd_gpu: supplied by vcc_sys [ 7.809844] W : [File] : drivers/gpu/arm/midgard/platform/rk/mali_kbase_conf. [ 7.825070] mali ffa30000.gpu: GPU identified as 0x0750 r0p0 status 1 [ 7.831889] I : [File] : drivers/gpu/arm/midgard/backend/gpu/mali_kbase_devf. [ 7.846810] mali ffa30000.gpu: Probed as mali0 [ 7.851676] vcc33_lan: supplied by vcc_io [ 7.855748] rk_gmac-dwmac ff290000.ethernet: clock input or output? (input). [ 7.862784] rk_gmac-dwmac ff290000.ethernet: TX delay(0x30). [ 7.868451] rk_gmac-dwmac ff290000.ethernet: RX delay(0x10). [ 7.874176] rk_gmac-dwmac ff290000.ethernet: clock input from PHY [ 7.880271] rk_gmac-dwmac ff290000.ethernet: init for RGMII [ 7.890871] stmmac - user ID: 0x10, Synopsys ID: 0x35 [ 7.895918] Ring mode enabled [ 7.898965] DMA HW capability register supported [ 7.903484] Normal descriptors [ 7.906808] RX Checksum Offload Engine supported (type 2) [ 7.912279] TX Checksum insertion supported [ 7.916543] Wake-Up On Lan supported [ 7.920218] Enable RX Mitigation via HW Watchdog Timer [ 8.962827] libphy: stmmac: probed [ 8.966456] eth0: PHY ID 001cc915 at 0 IRQ POLL (stmmac-0:00) active [ 8.972861] eth0: PHY ID 001cc915 at 1 IRQ POLL (stmmac-0:01) [ 8.980819] dwmmc_rockchip ff0d0000.dwmmc: IDMAC supports 32-bit address mod. [ 8.988414] dwmmc_rockchip ff0d0000.dwmmc: Using internal DMA controller. [ 8.995244] dwmmc_rockchip ff0d0000.dwmmc: Version ID is 270a [ 9.001252] dwmmc_rockchip ff0d0000.dwmmc: DW MMC controller at irq 30,32 bio [ 9.011285] dwmmc_rockchip ff0d0000.dwmmc: No vmmc regulator found [ 9.017511] dwmmc_rockchip ff0d0000.dwmmc: No vqmmc regulator found [ 9.024031] dwmmc_rockchip ff0d0000.dwmmc: allocated mmc-pwrseq [ 9.030070] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 9.055511] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz,) [ 9.075527] dwmmc_rockchip ff0d0000.dwmmc: 1 slots initialized [ 9.085313] asoc-simple-card sound: i2s-hifi <-> ff890000.i2s mapping ok [ 9.093031] input: gpio-keys as /devices/platform/gpio-keys/input/input1 [ 9.100181] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ 9.101986] mmc_host mmc1: Bus speed (slot 0) = 50000000Hz (slot req 5000000) [ 9.102688] mmc1: new high speed SDIO card at address 0001 [ 9.121599] rk808-rtc rk808-rtc: setting system clock to 2013-01-18 08:52:36) [ 9.137280] vcc_sd: disabling [ 9.140250] vdd_logic: disabling [ 9.143737] ALSA device list: [ 9.146721] #0: Generic USB Audio at usb-ff500000.usb-1, high speed [ 9.153148] #1: rockchip,miniarm-codec [ 9.157245] ttyS1 - failed to request DMA [ 9.163520] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incoms [ 9.173704] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incoms [ 9.192475] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. ) [ 9.200592] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 9.209628] devtmpfs: mounted [ 9.213234] Freeing unused kernel memory: 1024K (c0f00000 - c1000000) [ 9.445998] systemd[1]: System time before build time, advancing clock. [ 9.472182] systemd[1]: Failed to insert module 'autofs4': Function not impld [ 9.481187] systemd[1]: Failed to insert module 'kdbus': Function not implemd [ 9.501938] random: systemd urandom read with 34 bits of entropy available Welcome to Debian GNU/Linux 8 (jessie)! [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Listening on Syslog Socket. [ OK ] Reached target Encrypted Volumes. [ OK ] Listening on fsck to fsckd communication Socket. [ OK ] Listening on udev Control Socket. [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Started Forward Password Requests to Wall Directory Watch. [ OK ] Reached target Remote File Systems (Pre). [ OK ] Reached target Remote File Systems. [ OK ] Listening on Journal Socket. [ OK ] Listening on udev Kernel Socket. [ OK ] Created slice User and Session Slice. [ OK ] Created slice System Slice. [ OK ] Created slice system-serial\x2dgetty.slice. Starting Journal Service... Starting Load Kernel Modules... Starting Nameserver information manager... [ OK ] Created slice system-systemd\x2dfsck.slice. [ OK ] Created slice system-getty.slice. Starting LSB: Prepare console... Starting Create list of required st... nodes for the current kernel... Mounting Debug File System... [ OK ] Reached target Slices. [ OK ] Started Load Kernel Modules. Mounting FUSE Control File System... Starting Apply Kernel Variables... Mounting Configuration File System... [ OK ] Started Create list of required sta...ce nodes for the current kernel. Starting Create Static Device Nodes in /dev... [ OK ] Started Apply Kernel Variables. [ OK ] Mounted FUSE Control File System. [ OK ] Mounted Configuration File System. [ OK ] Mounted Debug File System. [ OK ] Started Nameserver information manager. [ OK ] Started Create Static Device Nodes in /dev. Starting udev Kernel Device Manager... [ OK ] Started Journal Service. [ OK ] Started LSB: Prepare console. Starting LSB: Set console font and keymap... [ OK ] Started udev Kernel Device Manager. Starting LSB: Set preliminary keymap... [ OK ] Started LSB: Set preliminary keymap. Starting Remount Root and Kernel File Systems... [ 10.417540] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ OK ] Started LSB: Set console font and keymap. [ OK ] Started Remount Root and Kernel File Systems. Starting Load/Save Random Seed... Starting udev Coldplug all Devices... Starting Flush Journal to Persistent Storage... [ OK ] Reached target Local File Systems (Pre). [ OK ] Started Load/Save Random Seed. [ 10.575554] systemd-journald[136]: Received request to flush runtime journal1 [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started udev Coldplug all Devices. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Found device /dev/ttyS1. [ OK ] Found device /dev/mmcblk0p4. [ 11.082649] RTL871X: module init start [ 11.086450] RTL871X: rtl8723bs v4.4.0_17166.20160322_BTCOEX20151223-654a [ 11.093163] RTL871X: rtl8723bs BT-Coex version = BTCOEX20151223-654a Activating swap /dev/mmcblk0p4... [ 11.139054] Adding 3834364k swap on /dev/mmcblk0p4. Priority:-1 extents:1 aS [ OK ] Activated swap /dev/mmcblk0p4. [ OK [ 11.181466] RTL871X: hal_com_config_channel_plan chplan:0x20 ] Found device /dev/mmcblk0p3. [ 11.193729] RTL871X: rtw_ndev_init(wlan0) if1 mac_addr=f0:03:8c:06:0f:ef [ OK [ 11.211069] RTL871X: module init ret=0 ] Found device /dev/mmcblk0p1. [ OK ] Reached target Sound Card. Mounting /boot... [ 11.328495] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data. Starting File System Check on /dev/mmcblk0p3... [ OK ] Reached target Swap. [ OK ] Mounted /boot. [ OK ] Started File System Check on /dev/mmcblk0p3. Mounting /home... [ 11.513670] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. ) [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ OK ] Started File System Check Daemon to report status. [ OK ] Mounted /home. Starting Load/Save RF Kill Switch Status... [ OK ] Reached target Local File Systems. Starting Raise network interfaces... Starting Create Volatile Files and Directories... Starting Tell Plymouth To Write Out Runtime Data... [ OK ] Started Load/Save RF Kill Switch Status. [ OK ] Started Create Volatile Files and Directories. [ OK ] Started Tell Plymouth To Write Out Runtime Data. [ OK ] Reached target System Time Synchronized. Starting Update UTMP about System Boot/Shutdown... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Reached target System Initialization. [ OK ] Listening on GPS (Global Positioning System) Daemon Sockets. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Started ACPI Events Check. [ OK ] Reached target Paths. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Listening on ACPID Listen Socket. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. Starting Modem Manager... Starting System Logging Service... [ OK ] Started GPS (Global Positioning System) Daemon. Starting Login Service... [ OK ] Started ACPI event daemon. [ OK ] Started Bluetooth HCI UART service. [ 12.227569] ttyS0 - failed to request DMA [ OK ] Started Run anacron jobs. Starting Initialize hardware monitoring sensors... [ OK ] Started Setup rockchip platform environment. Starting Restore /etc/resolv.conf i...re the ppp link was shut d[ 120 own... [ 12.324075] rk3x-i2c ff660000.i2c: flags from: 0, 1, addr: 0x50 Starting Wi-Fi SDIO driver service... [ 12.343932] rk3x-i2c ff660000.i2c: flags from: 0, 1, addr: 0x51 Starting LSB: Load kernel modules needed to enable cpufreq scaling... [ 12.363751] rk3x-i2c ff660000.i2c: flags from: 0, 1, addr: 0x51 Starting Restore Sound Card State... [ 12.385307] random: nonblocking pool is initialized [ 12.385865] rk3x-i2c ff660000.i2c: flags from: 0, 1, addr: 0x52 [ OK ] Started D-Bus System Message Bus. [ 12.410019] rk3x-i2c ff660000.i2c: flags from: 0, 1, addr: 0x52 [ 12.429884] rk3x-i2c ff660000.i2c: flags from: 0, 1, addr: 0x53 [ 12.449690] rk3x-i2c ff660000.i2c: flags from: 0, 1, addr: 0x53 Starting Network Manager... Starting TEE Supplicant... [ OK ] Started System Logging Service. [ OK ] Started Restore /etc/resolv.conf if...fore the ppp link was shut down. [ OK ] Started Wi-Fi SDIO driver service. [ OK ] Started Restore Sound Card State. [ OK ] Started TEE Supplicant. [ OK ] Started Initialize hardware monitoring sensors. [ 12.981785] cfg80211: World regulatory domain updated: [ 12.986946] cfg80211: DFS Master region: unset [ 12.991294] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_ga) [ 13.001065] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 ) [ 13.009072] cfg80211: (2457000 KHz - 2482000 KHz @ 20000 KHz, 92000 KHz AU) [ 13.018473] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 ) [ 13.018477] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz A) [ 13.018483] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz A) [ 13.018487] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000) [ 13.018490] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 ) [ 13.018492] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0) [ OK ] Started Login Service. [ OK ] Started Network Manager. [ OK ] Started LSB: Load kernel modules needed to enable cpufreq scaling. Starting Network Manager Script Dispatcher Service... Starting Authenticate and Authorize Users to Run Privileged Tasks... [ OK ] Stopped TEE Supplicant. Starting TEE Supplicant... Starting LSB: set CPUFreq kernel parameters... Starting Network Manager Wait Online... [ OK ] Started TEE Supplicant. [ OK ] Started Network Manager Script Dispatcher Service. [ OK ] Started Authenticate and Authorize Users to Run Privileged Tasks. [ OK ] Started LSB: set CPUFreq kernel parameters. [ OK ] Started Modem Manager. [ OK ] Stopped TEE Supplicant. Starting TEE Supplicant... Starting Hostname Service... [ OK ] Started TEE Supplicant. [ OK ] Started Hostname Service. [ OK ] Stopped TEE Supplicant. [ 13.855559] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready Starting TEE Supplicant... [ OK ] Started Raise network interfaces. [ OK ] Started TEE Supplicant. [ OK ] Reached target Network. [ 14.025582] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready Starting Permit User Sessions... [ OK ] Started OpenBSD Secure Shell server. [ OK ] Started Permit User Sessions. Starting Light Display Manager... [ OK ] Stopped TEE Supplicant. Starting TEE Supplicant... [ OK ] Started TEE Supplicant. [ OK ] Started Light Display Manager. [ OK ] Stopped TEE Supplicant. Starting TEE Supplicant... [ OK ] Started TEE Supplicant. [ 14.899597] rtk_btcoex: Open BTCOEX [ 14.903089] rtk_btcoex: create_udpsocket: connect_port: 30001 [ 14.908945] rtk_btcoex: send msg INVITE_REQ with len:11 [ 14.922835] rtk_btcoex: BTCOEX hci_rev 0x1e4e [ 14.927207] rtk_btcoex: BTCOEX lmp_subver 0x2b06 [ 15.031869] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 15.040020] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ OK ] Stopped TEE Supplicant. Starting TEE Supplicant... Starting Bluetooth service... [ OK ] Started TEE Supplicant. [ OK ] Started Bluetooth service. [ OK ] Reached target Bluetooth. Starting WPA supplicant... [ OK ] Stopped TEE Supplicant. Starting TEE Supplicant... [ OK ] Started TEE Supplicant. [ OK ] Started WPA supplicant. [ 15.475045] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ OK ] Stopped TEE Supplicant. [FAILED] Failed to start TEE Supplicant. See 'systemctl status tee-supplicant.service' for details. [ 16.918662] RTL871X: nolinked power save enter [ 16.967618] RTL871X: nolinked power save leave [ 18.305928] RTL871X: nolinked power save enter [ 18.996285] rk_gmac-dwmac ff290000.ethernet eth0: Link is Up - 1Gbps/Full - x [ 40.110123] RTL871X: nolinked power save leave [ 41.447887] RTL871X: nolinked power save enter [FAILED] Failed to start Network Manager Wait Online. See 'systemctl status NetworkManager-wait-online.service' for details. [ OK ] Reached target Network is Online. Starting LSB: Advanced IEEE 802.11 management daemon... Starting /etc/rc.local Compatibility... Starting LSB: Start NTP daemon... Starting LSB: network benchmark... [ OK ] Started LSB: Advanced IEEE 802.11 management daemon. [ OK ] Started /etc/rc.local Compatibility. Starting Terminate Plymouth Boot Screen... Starting Wait for Plymouth Boot Screen to Quit... [ OK ] Started Terminate Plymouth Boot Screen. [ OK ] Started Wait for Plymouth Boot Screen to Quit. [ OK ] Started Serial Getty on ttyS1. [ OK ] Started Getty on tty1. [ OK ] Reached target Login Prompts. [ OK ] Started LSB: Start NTP daemon. [ OK ] Started LSB: network benchmark. [ OK ] Reached target Multi-User System. [ 43.947400] rk3x-i2c ff650000.i2c: flags from: 0, 1, addr: 0x1b [ OK ] Reached target Graphical Interface. Starting Update UTMP about System Runlevel Changes... [ OK ] Started Update UTMP about System Runlevel Changes. Debian GNU/Linux 8 linaro-alip ttyS1 linaro-alip login: root (automatic login)
