GXBB:BL1:08dafd:0a8993;FEAT:EDFC318C;POC:3;RCY:0;EMMC:0;READ:0;CHK:0; TE: 98667 no sdio debug board detected BL2 Built : 11:44:26, Nov 25 2015. gxb gfb13a3b-c2 - jcao@wonton Board ID = 8 set vcck to 1100 mv set vddee to 1050 mv CPU clk: 1536MHz DDR channel setting: DDR0 Rank0+1 same DDR0: 2048MB(auto) @ 912MHz(2T)-13 DataBus test pass! AddrBus test pass! Load fip header from eMMC, src: 0x0000c200, des: 0x01400000, size: 0x000000b0 Load bl30 from eMMC, src: 0x00010200, des: 0x01000000, size: 0x00009ef0 Sending bl30........................................OK. Run bl30... Load bl301 from eMMC, src: 0x0001c200, des: 0x01000000, size: 0x000012c0 Wait bl30...Done Sending bl301.....OK. Run bl301... bl31 from eMMC, src: 0x00020200, des: 0x10100000, size: 0x00011130 --- UART initialized after reboot --- [Reset cause: unknown] [Image: unknown, amlogic_v1.1.3046-00db630-dirty 2016-08-31 09:24:14 tao.zeng@droid04] bl30: check_permit, count is 1 bl30: check_permit: ok! chipidLoad bl33 from eMMC, src: 0x00034200, des: 0x01000000, size: 0x000685f0 : ef be ad de d f0 ad ba ef be ad de not ES chip [0.213478 Inits done] secure task start! high task start! low task start! NOTICE: BL3-1: v1.0(debug):4d2e34d NOTICE: BL3-1: Built : 17:08:35, Oct 29 2015 INFO: BL3-1: Initializing runtime services INFO: BL3-1: Preparing for EL3 exit to normal world INFO: BL3-1: Next image address = 0x1000000 INFO: BL3-1: Next image spsr = 0x3c9 U-Boot 2015.01-gbafc655 (Oct 17 2016 - 16:33:54) DRAM: 2 GiB Relocation Offset is: 76f3d000 ------------------------------------------------- * Welcome to Hardkernel's ODROID-C2 ------------------------------------------------- CPU : AMLogic S905 S/N : HKC213254DFD7BF9 MAC : 00:1e:06:33:c8:79 BID : HKC2211610 ------------------------------------------------- register usb cfg[1][0] = 0000000077f96b48 register usb cfg[0][1] = 0000000077f96b68 vpu detect type: 5 vpu clk_level = 7 set vpu clk: 666667000Hz, readback: 666660000Hz(0x300) MMC: aml_priv->desc_buf = 0x0000000073f35d30 aml_priv->desc_buf = 0x0000000073f37ec0 SDIO Port C: 0, SDIO Port B: 1 [mmc_init] mmc init success In: serial Out: serial Err: serial ---------------------------------- MMC Size : 32 GB ---------------------------------- reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 [CANVAS]addr=0x3f800000 width=3840, height=1440 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address Net: Meson_Ethernet Hit [Enter] key twice to stop autoboot: 0 reading boot.ini 5451 bytes read in 3 ms (1.7 MiB/s) cfgload: applying boot.ini... cfgload: setenv m "1080p60hz" # Progressive 60Hz cfgload: setenv m_bpp "32" cfgload: setenv hpd "true" cfgload: setenv condev "console=ttyS0,115200n8 console=tty0" # on both cfgload: setenv mesontimer "1" cfgload: setenv nographics "0" cfgload: setenv monitor_onoff "false" # true or false cfgload: setenv maxcpus "4" cfgload: setenv max_freq "1536" # 1.536GHz cfgload: if test "${m}" = "custombuilt"; then setenv cmode "modeline=${modeline}"; fi cfgload: setenv bootargs "root=LABEL=ROOT rootwait ro ${condev} no_console_suspend hdmimode=${m} ${comde} m_bpp=${m_bpp} vout" cfgload: setenv loadaddr "0x11000000" cfgload: setenv dtb_loadaddr "0x1000000" cfgload: setenv initrd_loadaddr "0x13000000" cfgload: usb start (Re)start USB... USB0: dwc_usb driver version: 2.94 6-June-2012 USB (1) peri reg base: c0000020 USB (1) use clock source: XTAL input, div: 1 USB (1) base addr: 0xc9100000 Force id mode: Host dwc_otg: Highspeed device found ! scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found cfgload: fatload usb 0:1 ${initrd_loadaddr} uInitrd ** Bad device usb 0 ** cfgload: fatload usb 0:1 ${loadaddr} Image ** Bad device usb 0 ** cfgload: fatload usb 0:1 ${dtb_loadaddr} meson64_odroidc2.dtb ** Bad device usb 0 ** cfgload: fdt addr ${dtb_loadaddr} libfdt fdt_check_header(): FDT_ERR_BADMAGIC cfgload: if test "${mesontimer}" = "0"; then fdt rm /meson_timer; fdt rm /cpus/cpu@0/timer; fdt rm /cpus/cpu@1/timer; fdt rm i cfgload: if test "${mesontimer}" = "1"; then fdt rm /timer; fi No FDT memory address configured. Please configure the FDT address via "fdt addr
" command. Aborting! cfgload: if test "${nographics}" = "1"; then fdt rm /reserved-memory; fdt rm /aocec; fi cfgload: if test "${nographics}" = "1"; then fdt rm /meson-fb; fdt rm /amhdmitx; fdt rm /picdec; fdt rm /ppmgr; fi cfgload: if test "${nographics}" = "1"; then fdt rm /meson-vout; fdt rm /mesonstream; fdt rm /meson-fb; fi cfgload: if test "${nographics}" = "1"; then fdt rm /deinterlace; fdt rm /codec_mm; fi cfgload: booti ${loadaddr} ${initrd_loadaddr} ${dtb_loadaddr} Bad Linux ARM64 Image magic! reading boot-logo.bmp.gz ** Unable to read file boot-logo.bmp.gz ** reading boot-logo.bmp ** Unable to read file boot-logo.bmp ** movi: the partiton 'logo' is reading... MMC read: dev # 0, block # 58976, count 4096 ... 4096 blocks read: OK hpd_state=1 set hdmitx VIC = 16 hdmitx phy setting done set hdmitx VIC = 16 hdmitx phy setting done Error: Bad gzipped data There is no valid bmp file at the given address movi: the partiton 'dtb' is reading... MMC read: dev # 0, block # 1504, count 128 ... 128 blocks read: OK movi: the partiton 'boot' is reading... MMC read: dev # 0, block # 1632, count 32768 ... 32768 blocks read: OK Bad Linux ARM64 Image magic!
