(module KICAD:Relays_Fujitsu-JV-KT-Series_RevE_03Apr2017 (layer F.Cu) (tedit 58E2B180)
  (fp_text reference K** (at 0 -6.5) (layer F.SilkS)
    (effects (font (size 1 1) (thickness 0.15)))
  (fp_text value Relays_Fujitsu-JV-KT-Series_RevE_03Mar2017 (at 0 8) (layer F.Fab)
  (fp_line (start -9.3 1.7) (end -9.3 -1.7) (layer F.SilkS) (width 0.25))
  (fp_line (start 8.5 -5.495) (end -5.2 -5.495) (layer F.SilkS) (width 0.25))
  (fp_line (start 8.5 1.67) (end 8.5 -0.33) (layer F.SilkS) (width 0.25))
  (fp_line (start -4.7 5.16) (end 4.7 5.16) (layer F.SilkS) (width 0.25))
  (fp_arc (start -3.65 -1.3) (end -3.15 -1.8) (angle 90) (layer F.SilkS) (width 0.25))
  (fp_arc (start -3.65 -0.3) (end -3.15 -0.8) (angle 90) (layer F.SilkS) (width 0.25))
  (fp_arc (start -3.65 0.7) (end -3.15 0.2) (angle 90) (layer F.SilkS) (width 0.25))
  (fp_arc (start -3.65 1.7) (end -3.15 1.2) (angle 90) (layer F.SilkS) (width 0.25))
  (fp_line (start -3.15 -2.8) (end -4.15 -2.8) (layer F.SilkS) (width 0.25))
  (fp_line (start -3.15 -1.8) (end -3.15 -2.8) (layer F.SilkS) (width 0.25))
  (fp_line (start -3.15 3.2) (end -4.15 3.2) (layer F.SilkS) (width 0.25))
  (fp_line (start -3.15 2.2) (end -3.15 3.2) (layer F.SilkS) (width 0.25))
  (fp_line (start 3.5 1.5) (end 2.5 -0.5) (layer F.SilkS) (width 0.25))
  (fp_line (start 3.5 3) (end 4 3) (layer F.SilkS) (width 0.25))
  (fp_line (start 3.5 1.5) (end 3.5 3) (layer F.SilkS) (width 0.25))
  (fp_line (start 3.5 -2.5) (end 4 -2.5) (layer F.SilkS) (width 0.25))
  (fp_line (start 3.5 -1) (end 3.5 -2.5) (layer F.SilkS) (width 0.25))
  (fp_line (start 3.5 -1) (end 3.5 -0.5) (layer F.SilkS) (width 0.25))
  (pad 14 thru_hole oval (at 7.62 3.81) (size 5.5 3.5) (drill 1.4) (layers *.Cu *.Mask))
  (pad 11 thru_hole oval (at 7.62 -2.54) (size 5.5 3.5) (drill 1.4) (layers *.Cu *.Mask))
  (pad A2 thru_hole oval (at -7.6 3.8) (size 5.5 3.5) (drill 1.2) (layers *.Cu *.Mask))
  (pad A1 thru_hole oval (at -7.6 -3.8) (size 5.5 3.5) (drill 1.2) (layers *.Cu *.Mask))
