====================================================================== Control Commands for NEC Projector No.BDT120009 Revision 3.0.26 Copyright (C) NEC Display Solutions, Ltd. 2002-2015 ---------------------------------------------------------------------- Updated on March 17, 2015 ---------------------------------------------------------------------- This file contains information about NEC projector control commands. Model Name GT : GT5000/6000 Series HT : HT1000/HT1100 Series LT : LT220/240/240K/260/260K/245/265 Series LT80 : LT280/380 Series MT : MT860/1060/1065/1075 Series WT : WT600/610/615 Series VT : VT770 Series NP2000 : NP1000/2000 Series NP3150 : NP1150/2150/3150/3151W Series NP905 : NP905/901W/VT800 Series NP3250 : NP1250/2250/3250/3251W Series P420 : NP-P350X/P420X/P350W Series PA600 : NP-PA600X/PA500X/PA550W/PA500U Series PX750 : NP-PX750U Series P501 : NP-P501X/P451X/P451W/P401W/PE501X Series PA622 : NP-PA721X/PA621X/PA671W/PA571W/PA621W/PA521U Series(MM) NP-PA722X/PA622X/PA672W/PA572W/PA622W/PA522U Series(HDBaseT) PX602 : NP-PX602UL/PX602WL Series PH1202 : NP-PH1202HL/PH1002HL Series ====================================================================== Contents 1. Projector Control 2. Connection Method 3. Interface Conditions 4. List of Commands 5. Command Descriptions 6. Communication Frame ====================================================================== 1. Projector Control ---------------------------------------------------------------------- NEC projectors make use of control commands that control the functions of the projector via connection with a personal computer or another device. ====================================================================== 2. Connection Method ---------------------------------------------------------------------- The following 3 kinds of connection methods are available for sending and receiving control commands. 1. Serial connection using the serial port on the projector A serial cable is required. 2. USB connection using the USB port on the projector A USB cable is required. 3. LAN connection 3-1. LAN connection using a wired LAN card A wired LAN card and LAN cable are required. 3-2. LAN connection using a wireless LAN card A wireless LAN card is required. 3-3. LAN connection using the LAN port on the projector A LAN cable is required. 3-4. LAN connection using a wireless LAN unit A wireless LAN unit is required. Status of supported connection +------------------+---------+---------+---------+---------+---------+---------+ | | (1) | (2) | (3-1) | (3-2) | (3-3) | (3-4) | | | Serial | USB | Wired | Wireless| Wired | Wireless| | | port | port | LAN card| LAN card| LAN port| LAN unit| +------------------+---------+---------+---------+---------+---------+---------+ | GT5000/6000 | Yes | Yes | Yes | Yes | Yes | No | +------------------+---------+---------+---------+---------+---------+---------+ | HT1000/HT1100 | Yes | No | No | No | No | No | +------------------+---------+---------+---------+---------+---------+---------+ | LT220/240/260 | Yes | No | Yes | Yes | No | No | +------------------+---------+---------+---------+---------+---------+---------+ | LT240K/260K | Yes | Yes | Yes | Yes | No | No | +------------------+---------+---------+---------+---------+---------+---------+ | LT245/265/280/380| Yes | No | No | Yes | Yes | No | +------------------+---------+---------+---------+---------+---------+---------+ | MT860/1060/1065 | Yes | Yes | Yes | Yes | No | No | | 1075 | | | | | | | +------------------+---------+---------+---------+---------+---------+---------+ | WT600/610/615 | Yes | Yes | Yes | Yes | No | No | +------------------+---------+---------+---------+---------+---------+---------+ | VT770 | Yes | No | No | No | No | No | +------------------+---------+---------+---------+---------+---------+---------+ | NP1000/2000 | Yes | No | No | Yes | Yes | No | +------------------+---------+---------+---------+---------+---------+---------+ | NP1150/2150/3150 | Yes | No | No | No | Yes | Yes | | NP3151W | | | | | | | +------------------+---------+---------+---------+---------+---------+---------+ | NP905/901W | Yes | No | No | No | Yes | Yes | +------------------+---------+---------+---------+---------+---------+---------+ | VT800 | Yes | No | No | No | Yes | No | +------------------+---------+---------+---------+---------+---------+---------+ | NP1250/2250/3250 | Yes | No | No | No | Yes | Yes | | NP3250W | | | | | | | +------------------+---------+---------+---------+---------+---------+---------+ | NP-P350X/P420X/ | Yes | No | No | No | Yes | Yes | | P350W | | | | | | | +------------------+---------+---------+---------+---------+---------+---------+ | NP-PA600X/PA500X/| Yes | No | No | No | Yes | Yes | | PA550W/PA500U | | | | | | | +------------------+---------+---------+---------+---------+---------+---------+ | NP-PX750U | Yes | No | No | No | Yes | Yes | +------------------+---------+---------+---------+---------+---------+---------+ | NP-P501X/P451X/ | Yes | No | No | No | Yes | Yes | | P451W/P401W | | | | | | | +------------------+---------+---------+---------+---------+---------+---------+ | NP-PE501X | Yes | No | No | No | No | No | +------------------+---------+---------+---------+---------+---------+---------+ | NP-PA721X/PA621X | Yes | No | No | No | Yes | No | | PA671W/PA571W | | | | | | | | PA621U/PA521U | | | | | | | | PA722X/PA622X | | | | | | | | PA672W/PA572W | | | | | | | | PA622U/PA522U | | | | | | | +------------------+---------+---------+---------+---------+---------+---------+ | NP-PX602UL | Yes | No | No | No | Yes | No | | PX602WL | | | | | | | +------------------+---------+---------+---------+---------+---------+---------+ | NP-PH1202HL | Yes | No | No | No | Yes | No | | PH1002HL | | | | | | | +------------------+---------+---------+---------+---------+---------+---------+ Yes: Supported No: Not supported * A USB cable is supplied as standard with the MT860/1060/1065/1075. * The GT5000/6000 does not come with a USB cable. * Note that a connection method using the supplied USB cable is not supported for the LT220/240/260. * The serial cable, LAN card and LAN cable are separately sold. ( CAUTION ) Before making connections, set the standby mode of the projector to "NORMAL" or "Idol mode". The projector cannot use the control commands in the power-saving condition, but the following model can use some control commands. [NP-P350X/P420X/P350W/PE501X Series] STANDBY MODE: "POWER-SAVING" +-----------------------------------+--------+--------+--------+ | Control Commnad | Serial | Wired |Wireless| | | port |LAN port|LAN unit| +-----------------------------------+--------+--------+--------+ | POWER ON | Yes | No | No | +-----------------------------------+--------+--------+--------+ Yes: Supported No: Not supported [NP-PA600X/PA500X/PA550W/PA500U Series] [NP-PX750U Series] [NP-P501X/P451X/P451W/P401W Series] [NP-PA621U / NP-PA622U Series] [NP-PX602UL/PX602WL Series] [NP-PH1202HL/PH1002HL Series] STANDBY MODE: "POWER-SAVING" +-----------------------------------+--------+--------+--------+ | Control Commnad | Serial | Wired |Wireless| | | port |LAN port|LAN unit| +-----------------------------------+--------+--------+--------+ | POWER ON | Yes | No | No | +-----------------------------------+--------+--------+--------+ STANDBY MODE: "NETWORK STANDBY" +-----------------------------------+--------+--------+--------+ | Control Commnad | Serial | Wired |Wireless| | | port |LAN port|LAN unit| +-----------------------------------+--------+--------+--------+ | POWER ON | Yes | Yes | Yes | +-----------------------------------+--------+--------+--------+ Yes: Supported No: Not supported ====================================================================== 3. Interface Conditions ---------------------------------------------------------------------- Serial connection ---------------------------------------------------------------------- The communications method conforms to the RS-232C standard. Baud rate: 38400 bps Data length: 8 bits Parity bit: No parity Stop bits: 1 bit Communications mode: Full duplex The control connector is described below. [ LT/HT/WT ] The PC CONTROL connector is a mini DIN 8-pin connector. 1 To TxD of PC 2 3 4 To GND of PC 5 6 7 To RxD of PC 8 * 2, 3, 5, 6, and 8 are used inside the projector. [ LT80/GT/MT/VT/NP2000/NP3150/NP905/NP3250/P420/PA600/PX750/P501/PA622/PX602/PH1202 ] The PC CONTROL connector is a D-SUB 9-pin connector. 1 2 To TxD of PC 3 To RxD of PC 4 5 To GND of PC 6 7 To CTS of PC 8 To RTS of PC 9 USB connection ---------------------------------------------------------------------- This conforms to the USB1.1 standard. Transfer speed: All speeds (supported) Endpoint: Control transfer Endpoint 0 Device class: HID class (Ver1.1) USB1.1 Standard: Universal Serial Bus Specification Revision 1.1 HID : Human Interface Device Connector Specifications 1 VBUS (Power supply) 2 D- (- Signal) 3 D+ (+ Signal) 4 GND (Ground) * Depending on the USB host controller in the personal computer, the USB connection may fail to operate. When using a USB hub, please use a self-powered type, not a bus-powered type. When using a USB hub, connection to the first stage of the USB hub is recommended. LAN connection ---------------------------------------------------------------------- [ Wired LAN port ] LAN interface Communication speed : Auto setting (10/100Mbps) Certified standard : IEEE802.3 (10BASE-T) IEEE802.3u (100BASE-TX, Auto-Negotiation) A LAN connector (8 male RJ-45 connector) 1 TD+ Transmit data (+) 2 TD- Transmit data (-) 3 RD+ Receive data (+) 4 Not used 5 Not used 6 RD- Receive data (-) 7 Not used 8 Not used [ Wired/wireless LAN card ] The LAN connections will differ depending on the commercial LAN card that is used. - For information on supported LAN cards, visit: Global : http://www.nec-pj.com/ [Port Number] The TCP port number used is "7142". ====================================================================== 4. List of Commands ---------------------------------------------------------------------- * Example for command ------------------------------------------------------------------------ Command name Example ------------------------------------------------------------------------ 006. RUNNING SENSE 00H 81H 00H 00H 00H 81H 007. COMMON DATA REQUEST 00H C0H 00H 00H 00H C0H 009. ERROR STATUS REQUEST 00H 88H 00H 00H 00H 88H 015. POWER ON 02H 00H 00H 00H 00H 02H 016. POWER OFF 02H 01H 00H 00H 00H 03H 018. INPUT SW CHANGE 02H 03H 00H 00H 02H CKS 020. PICTURE MUTE ON 02H 10H 00H 00H 00H 12H 021. PICTURE MUTE OFF 02H 11H 00H 00H 00H 13H 022. SOUND MUTE ON 02H 12H 00H 00H 00H 14H 023. SOUND MUTE OFF 02H 13H 00H 00H 00H 15H 024. ONSCREEN MUTE ON 02H 14H 00H 00H 00H 16H 025. ONSCREEN MUTE OFF 02H 15H 00H 00H 00H 17H 030-1. PICTURE ADJUST 03H 10H 00H 00H 05H CKS 030-2. VOLUME ADJUST 03H 10H 00H 00H 05H 05H CKS 030-3. BLANKING ADJUST 03H 10H 00H 00H 05H 06H CKS 030-4. IMAGE ADJUST 03H 10H 00H 00H 05H CKS 030-5. COLOR TEMPERATURE ADJUST 03H 10H 00H 00H 05H 13H CKS 030-6. WHITE BALANCE ADJUST 03H 10H 00H 00H 05H 14H CKS 030-8. KEYSTONE ADJUST 03H 10H 00H 00H 05H 15H CKS 030-10. SIGNAL LEVEL ADJUST 03H 10H 00H 00H 05H CKS 030-11. VIDEO MODE ADJUST 03H 10H 00H 00H 05H CKS 030-12. IMAGE MODE ADJUST 03H 10H 00H 00H 05H CKS 030-14. REF. WHITE BAL. ADJUST 03H 10H 00H 00H 05H CKS 030-15. OTHER ADJUST 03H 10H 00H 00H 05H CKS 031. FACTORY DEFAULT SET 03H 32H 00H 00H 01H DATA CKS 033. DATE, TIME REQUEST 03H 81H 00H 00H 00H 84H 037. INFORMATION REQUEST 03H 8AH 00H 00H 00H 8DH 037-1. LAMP INFORMATION REQUEST 03H 8CH 00H 00H 00H 8FH 037-2. LAMP INFORMATION REQUEST 2 03H 94H 00H 00H 00H 97H 037-3. FILTER INFORMATION REQUEST 03H 95H 00H 00H 00H 98H 037-4. LAMP INFORMATION REQUEST 3 03H 96H 00H 00H 02H CKS 038-1. PROJECTOR NAME SET 03H 8BH 00H 00H 32H 00H CKS 047. VIEWER CONTROL 01H 90H 00H 00H 01H CKS 048. VIEWER SLIDE REQUEST 01H 91H 00H 00H 00H 92H 049. STORE 03H 30H 00H 00H 00H 33H 050. REMOTE KEY CODE 02H 0FH 00H 00H 02H CKS 051. LENS MUTE ON (SHUTTER CLOSE) 02H 16H 00H 00H 00H 18H 052. LENS MUTE OFF (SHUTTER OPEN) 02H 17H 00H 00H 00H 19H 053. LENS CONTROL 02H 18H 00H 00H 02H CKS 053-1. LENS CONTROL REQUEST 02H 1CH 00H 00H 02H CKS 053-2. LENS CONTROL 2 02H 1DH 00H 00H 04H CKS 053-3. LENS MEMORY CUSTOM SET 02H 1EH 00H 00H 01H CKS 053-4. LENS MEMORY REFERENCE SET 02H 1FH 00H 00H 01H CKS 053-5. LENS MEMORY CONTROL REQUEST 02H 20H 00H 00H 01H CKS 053-6. LENS MEMORY CONTROL 02H 21H 00H 00H 02H CKS 053-7. LENS INFORMATION REQUEST 02H 22H 00H 00H 01H CKS 056. SLEEP TIMER REQUEST 03H 92H 00H 00H 00H CKS 057. SLEEP TIMER SET 03H 93H 00H 00H 02H CKS 058. FORCED ONSCREEN MUTE SET 02H 19H 00H 00H 01H DATA CKS 060. GAIN PARAMETER REQUEST 2 03H 04H 00H 00H 03H CKS 061. LAMP COOLING TIME REQUEST 03H 8DH 00H 00H 00H 90H 077. MUTE CONTROL 02H 1AH 00H 00H 02H CKS 078-1. SETTING REQUEST 00H 85H 00H 00H 01H 00H CKS 078-2. RUNNING STATUS REQUEST 00H 85H 00H 00H 01H 01H CKS 078-3. INPUT STATUS REQUEST 00H 85H 00H 00H 01H 02H CKS 078-4. MUTE STATUS REQUEST 00H 85H 00H 00H 01H 03H CKS 078-5. MODEL NAME REQUEST 00H 85H 00H 00H 01H 04H CKS 078-6. COVER STATUS REQUEST 00H 85H 00H 00H 01H 05H CKS 079. CAPTURE CONTROL 01H 98H 00H 00H 01H DATA CKS 091. DIGITAL ZOOM REQUEST 03H 20H 00H 00H 00H 23H 092-1. DIGITAL ZOOM MOUSE SET 03H 21H 00H 00H 06H CKS 092-2. DIGITAL ZOOM SET 03H 21H 00H 00H 04H CKS 092-3. DIGITAL ZOOM MOUSE CONTROL 03H 21H 00H 00H 02H CKS 097-1. MENU MODE REQUEST 03H B0H 00H 00H 01H 00H B4H 097-2. LANGUAGE REQUEST 03H B0H 00H 00H 01H 01H B5H 097-3. MENU COLOR SELECT REQUEST 03H B0H 00H 00H 01H 02H B6H 097-4. PROJECTOR POINTER REQUEST 03H B0H 00H 00H 01H 03H B7H 097-5. DISPLAY TIME REQUEST 03H B0H 00H 00H 01H 04H B8H 097-6. SOURCE DISPLAY REQUEST 03H B0H 00H 00H 01H 05H B9H 097-7. MESSAGE REQUEST 03H B0H 00H 00H 01H 06H BAH 097-8. LAMP MODE REQUEST 03H B0H 00H 00H 01H 07H BBH 097-9. IDLE MODE REQUEST 03H B0H 00H 00H 01H 08H BCH 097-10. CLOSED CAPTION REQUEST 03H B0H 00H 00H 01H 09H BDH 097-11. ORIENTATION REQUEST 03H B0H 00H 00H 01H 0AH BEH 097-12. BACKGROUND REQUEST 03H B0H 00H 00H 01H 0BH BFH 097-13. SCREEN TYPE REQUEST 03H B0H 00H 00H 01H 0CH C0H 097-14. SCREEN TRIGGER REQUEST 03H B0H 00H 00H 01H 0DH C1H 097-15. VIEWER START MODE REQUEST 03H B0H 00H 00H 01H 0EH C2H 097-16. VIEWER MODE REQUEST 03H B0H 00H 00H 01H 0FH C3H 097-17. VIEWER INTERVAL REQUEST 03H B0H 00H 00H 01H 10H C4H 097-18. CAPTURE OPTIONS REQUEST 03H B0H 00H 00H 01H 11H C5H 097-19. MOUSE BUTTON REQUEST 03H B0H 00H 00H 01H 12H C6H 097-20. MOUSE SENSITIVITY REQUEST 03H B0H 00H 00H 01H 13H C7H 097-21. SIGNAL SELECT REQUEST 03H B0H 00H 00H 02H 14H DATA CKS 097-23. AUTO START REQUEST 03H B0H 00H 00H 01H 16H CAH 097-24. POWER MANAGEMENT REQUEST 03H B0H 00H 00H 01H 17H CBH 097-25. POWER CONFIRMATION REQUEST 03H B0H 00H 00H 01H 18H CCH 097-26. KEYSTONE SAVE REQUEST 03H B0H 00H 00H 01H 19H CDH 097-27. FAN MODE REQUEST 03H B0H 00H 00H 01H 1AH CEH 097-28. BUILT IN SPEAKER REQUEST 03H B0H 00H 00H 01H 1BH CFH 097-29. REMOTE SENSOR REQUEST 03H B0H 00H 00H 02H 1CH DATA CKS 097-30. PANEL KEY LOCK REQUEST 03H B0H 00H 00H 01H 1DH D1H 097-31. S-VIDEO SELECT REQUEST 03H B0H 00H 00H 01H 1EH D2H 097-32. COMMUNICATION REQUEST 03H B0H 00H 00H 01H 1FH D3H 097-33. DEFAULT SOURCE REQUEST 03H B0H 00H 00H 02H 20H DATA CKS 097-34. PJ ID ENABLE REQUEST 03H B0H 00H 00H 01H 21H D5H 097-35. PJ ID REQUEST 03H B0H 00H 00H 01H 22H D6H 097-38. MENU PASSCODE REQUEST 03H B0H 00H 00H 01H 25H D9H 097-39. TEST PATTERN REQUEST 03H B0H 00H 00H 01H 26H DAH 097-40. COLOR UNIFORMITY REQUEST 03H B0H 00H 00H 01H 27H DBH 097-41. AUTO FUNCTIONS REQUEST 03H B0H 00H 00H 02H 28H DATA CKS 097-72. LOGO PASSCODE REQUEST 03H B0H 00H 00H 01H 47H FBH 097-73. RGBOUT TERMINAL REQUEST 03H B0H 00H 00H 01H 48H FCH 097-74. MOUSE MODE REQUEST 03H B0H 00H 00H 01H 49H FDH 097-75. MULTI DISPLAY REQUEST 03H B0H 00H 00H 01H 4AH FEH 097-76. MOTORIZED LENS REQUEST 03H B0H 00H 00H 01H 4BH FFH 097-77. LAMP TYPE REQUEST 03H B0H 00H 00H 01H 4CH 00H 097-78. 3D SURROUND REQUEST 03H B0H 00H 00H 01H 4DH 01H 097-79. WALL COLOR REQUEST 03H B0H 00H 00H 01H 4EH 02H 097-88. LAMP SELECT REQUEST 03H B0H 00H 00H 01H 57H 0BH 097-89. LAMP INTERVAL REQUEST 03H B0H 00H 00H 01H 58H 0CH 097-90. LAN CARD REQUEST 03H B0H 00H 00H 01H 59H 0DH 097-91. LAMP TYPE REQUEST 2 03H B0H 00H 00H 02H 5AH DATA CKS 097-92. ON/OFF TIMER REQUEST 03H B0H 00H 00H 01H 5BH 0FH 097-93. MOUSE POINTER REQUEST 03H B0H 00H 00H 01H 5CH 10H 097-94. BACK LIGHT REQUEST 03H B0H 00H 00H 01H 5DH 11H 097-100. LAST MEMORY REQUEST 03H B0H 00H 00H 01H 63H 17H 097-101. SYNC TERMINATION REQUEST 03H B0H 00H 00H 01H 64H 18H 097-102. LINK MODE REQUEST 03H B0H 00H 00H 01H 65H 19H 097-105. LUMI UNIFORMITY REQUEST 03H B0H 00H 00H 01H 68H 1CH 097-109. AUTO 3D REFORM REQUEST 1 03H B0H 00H 00H 01H 6CH 20H 097-110. AUTO 3D REFORM REQUEST 2 03H B0H 00H 00H 01H 6DH 21H 097-111. AUTO 3D REFORM REQUEST 3 03H B0H 00H 00H 01H 6EH 22H 097-145. VIEWER THUMBNAILS REQUEST 03H B0H 00H 00H 01H 90H 44H 097-148. KEYSTONE SELECT REQUEST 03H B0H 00H 00H 01H 93H 47H 097-174. REMOTE SENSOR REQUEST 03H B0H 00H 00H 01H ADH 61H 097-175. PROGRAM TIMER REQUEST 03H B0H 00H 00H 01H AEH 62H 097-176. PROGRAM TIMER DATA REQUEST 03H B0H 00H 00H 02H AFH DATA CKS 097-191. GEOMETRIC CORRECTION REQUEST03H B0H 00H 00H 01H BEH 72H 097-198. PIP/SIDE BY SIDE REQUEST 03H B0H 00H 00H 02H C5H DATA CKS 098-1. MENU MODE SET 03H B1H 00H 00H 02H 00H DATA CKS 098-2. LANGUAGE SET 03H B1H 00H 00H 02H 01H DATA CKS 098-3. MENU COLOR SELECT SET 03H B1H 00H 00H 02H 02H DATA CKS 098-4. PROJECTOR POINTER SET 03H B1H 00H 00H 02H 03H DATA CKS 098-5. DISPLAY TIME SET 03H B1H 00H 00H 02H 04H DATA CKS 098-6. SOURCE DISPLAY SET 03H B1H 00H 00H 02H 05H DATA CKS 098-7. MESSAGE SET 03H B1H 00H 00H 02H 06H DATA CKS 098-8. LAMP MODE SET 03H B1H 00H 00H 02H 07H DATA CKS 098-9. IDLE MODE SET 03H B1H 00H 00H 02H 08H DATA CKS 098-10. CLOSED CAPTION SET 03H B1H 00H 00H 02H 09H DATA CKS 098-11. ORIENTATION SET 03H B1H 00H 00H 02H 0AH DATA CKS 098-12. BACKGROUND SET 03H B1H 00H 00H 02H 0BH DATA CKS 098-13. SCREEN TYPE SET 03H B1H 00H 00H 02H 0CH DATA CKS 098-14. SCREEN TRIGGER SET 03H B1H 00H 00H 02H 0DH DATA CKS 098-15. VIEWER START MODE SET 03H B1H 00H 00H 02H 0EH DATA CKS 098-16. VIEWER PLAY MODE SET 03H B1H 00H 00H 02H 0FH DATA CKS 098-17. VIEWER PLAY INTERVAL SET 03H B1H 00H 00H 03H 10H CKS 098-18. CAPTURE OPTIONS SET 03H B1H 00H 00H 02H 11H DATA CKS 098-19. MOUSE BUTTON SET 03H B1H 00H 00H 02H 12H DATA CKS 098-20. MOUSE SENSITIVITY SET 03H B1H 00H 00H 02H 13H DATA CKS 098-21. SIGNAL SELECT SET 03H B1H 00H 00H 03H 14H CKS 098-23. AUTO START SET 03H B1H 00H 00H 02H 16H DATA CKS 098-24. POWER MANAGEMENT SET 03H B1H 00H 00H 02H 17H DATA CKS 098-25. POWER OFF CONFIRMATION SET 03H B1H 00H 00H 02H 18H DATA CKS 098-26. KEYSTONE SAVE SET 03H B1H 00H 00H 02H 19H DATA CKS 098-27. FAN MODE SET 03H B1H 00H 00H 02H 1AH DATA CKS 098-28. BUILT IN SPEAKER SET 03H B1H 00H 00H 02H 1BH DATA CKS 098-29. REMOTE SENSOR SET 03H B1H 00H 00H 03H 1CH CKS 098-30. CONTROL PANEL KEY LOCK SET 03H B1H 00H 00H 02H 1DH DATA CKS 098-31. S-VIDEO MODE SELECT SET 03H B1H 00H 00H 02H 1EH DATA CKS 098-32. COMMUNICATION SPEED SET 03H B1H 00H 00H 02H 1FH DATA CKS 098-33. DEFAULT SOURCE SELECT SET 03H B1H 00H 00H 03H 20H CKS 098-34. PROJECTOR ID ENABLE SET 03H B1H 00H 00H 02H 21H DATA CKS 098-35. PROJECTOR ID SET 03H B1H 00H 00H 02H 22H DATA CKS 098-39. TEST PATTERN SET 03H B1H 00H 00H 04H 26H CKS 098-40. COLOR UNIFORMITY SET 03H B1H 00H 00H 02H 27H DATA CKS 098-41. AUTO FUNCTIONS SET 03H B1H 00H 00H 03H 28H CKS 098-73. RGBOUT TERMINAL SET 03H B1H 00H 00H 02H 48H DATA CKS 098-74. MOUSE MODE SELECT SET 03H B1H 00H 00H 02H 49H DATA CKS 098-75. MULTI DISPLAY SET 03H B1H 00H 00H 02H 4AH CKS 098-78. 3D SURROUND SET 03H B1H 00H 00H 02H 4DH DATA CKS 098-79. WALL COLOR SET 03H B1H 00H 00H 02H 4EH DATA CKS 098-88. LAMP SELECT SET 03H B1H 00H 00H 02H 57H DATA CKS 098-89. LAMP INTERVAL SET 03H B1H 00H 00H 02H 58H DATA CKS 098-90. LAN CARD SET 03H B1H 00H 00H 02H 59H DATA CKS 098-92. ON/OFF TIMER SET 03H B1H 00H 00H 02H 5BH DATA CKS 098-93. MOUSE POINTER SET 03H B1H 00H 00H 02H 5CH DATA CKS 098-94. BACK LIGHT SET 03H B1H 00H 00H 02H 5DH DATA CKS 098-100. LAST MEMORY SET 03H B1H 00H 00H 02H 63H DATA CKS 098-101. SYNC TERMINATION SET 03H B1H 00H 00H 02H 64H DATA CKS 098-102. LINK MODE SET 03H B1H 00H 00H 02H 65H DATA CKS 098-105. LUMI UNIFORMITY SET 03H B1H 00H 00H 02H 68H DATA CKS 098-109. AUTO 3D REFORM SET 1 03H B1H 00H 00H 02H 6CH DATA CKS 098-110. AUTO 3D REFORM SET 2 03H B1H 00H 00H 02H 6DH DATA CKS 098-111. AUTO 3D REFORM SET 3 03H B1H 00H 00H 02H 6EH DATA CKS 098-145. VIEWER THUMBNAILS SET 03H B1H 00H 00H 02H 90H DATA CKS 098-148. KEYSTONE SELECT SET 03H B1H 00H 00H 02H 93H DATA CKS 098-174. REMOTE SENSOR SET 03H B1H 00H 00H 02H ADH DATA CKS 098-175. PROGRAM TIMER SET 03H B1H 00H 00H 02H AEH DATA CKS 098-176. PROGRAM TIMER DATA SET 03H B1H 00H 00H 0DH AFH CKS 098-191. GEOMETRIC CORRECTION SET 03H B1H 00H 00H 02H BEH DATA CKS 098-198. PIP/SIDE BY SIDE SET 03H B1H 00H 00H 03H C5H CKS 110. AUTO FUNCTIONS EXECUTE 03H B6H 00H 00H 01H BAH DATA CKS 305-1. BASE MODEL TYPE REQUEST 00H BFH 00H 00H 01H 00H CKS 305-2. VERSION INFORMATION REQUEST 00H BFH 00H 00H 02H 01H CKS 305-3. PROJECTOR INFORMATION REQUEST 00H BFH 00H 00H 01H 02H CKS * Availability by Model ---------------------------------------------------------------------- Model No. ------------------------- 01 : LT240/260 02 : MT1060/1065/1075 03 : HT1000 04 : LT220 05 : MT860 06 : WT600/610/615 07 : GT5000 08 : LT240K/260K 09 : GT6000 10 : HT1100 11 : VT770 12 : LT245/265 13 : LT280/380 14 : NP1000/2000 15 : NP1150/2150/3150/3151W 16 : NP905/901W/VT800 17 : NP1250/2250/3250/3250W 18 : NP-P350X/P420X/P350W 19 : NP-PA600X/PA500X/PA550W/PA500U 20 : NP-PX750U 21 : NP-P501X/P451X/P451W/P401W/PE501X 22 : NP-PA721X/PA621X/PA671W/PA571W/PA621W/PA521U/PA722X/PA622X/PA672W/PA572W/PA622W/PA522U 23 : NP-PX602UL/PX602WL 24 : NP-PH1202HL/PJ1002HL Meaning of Symbol ----------------------------------------------------- * :Supported ! :Is available depending on the model's version - :Not supported Availability by Model ------------------------------------------------------------------------------------------------------------- Command Name 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 ------------------------------------------------------------------------------------------------------------- 006. RUNNING SENSE * * * * * * * * * * * * * * * * * * * * * * * * 007. COMMON DATA REQUEST * * * * * * * * * * * * * * * * * * * * * * * * 009. ERROR STATUS REQUEST * * * * * * * * * * * * * * * * * * * * * * * * 015. POWER ON * * * * * * * * * * * * * * * * * * * * * * * * 016. POWER OFF * * * * * * * * * * * * * * * * * * * * * * * * 018. INPUT SW CHANGE * * * * * * * * * * * * * * * * * * * * * * * * 020. PICTURE MUTE ON * * * * * * * * * * * * * * * * * * * * * * * * 021. PICTURE MUTE OFF * * * * * * * * * * * * * * * * * * * * * * * * 022. SOUND MUTE ON * * * * * * * * * * * * * * * * * * * - * * - - 023. SOUND MUTE OFF * * * * * * * * * * * * * * * * * * * - * * - - 024. ONSCREEN MUTE ON * * * * * * * * * * * * * * * * * * * * * * * * 025. ONSCREEN MUTE OFF * * * * * * * * * * * * * * * * * - * * - * * * 030-1. PICTURE ADJUST Brightness * * * * * * * * * * * * * * * * * * * * * * * * Contrast * * * * * * * * * * * * * * * * * * * * * * * * Color * * * * * * * * * * * * * * * * * * * * * * * * Hue * * * * * * * * * * * * * * * * * * * * * * * * Sharpness * * * * * * * * * * * * * * * * * * * * * * * * V-Aperture - - * - - - * - * * - - - - - - - - - - - - - - 030-2. VOLUME ADJUST Volume * * * * * * * * * * * * * * * * * * * - * * - - Bass - * - - * - * - * - * - * * * * * - - - - - - - Treble - * - - * - * - * - * - * * * * * - - - - - - - Balance - - - - - - - - - - - - * * * * * - - - - - - - 030-3. BLANKING ADJUST * * * * * * * * * * - * * * - - - - * * - * * * 030-4. IMAGE ADJUST * * * * * * * * * * * * * * ! * * * * * * * * * 030-5. COLOR TEMPERATURE ADJUST * * * * * * * * * * * * * * ! * * * * * * * * * 030-6. WHITE BALANCE ADJUST * * * * * * * * * * * * * * ! * * * * * * * * * 030-8. KEYSTONE ADJUST * * * * * * * * * * * * * * * * * * * * * * * * 030-10. SIGNAL LEVEL ADJUST R/G/B Gain - Red - - - - - - * - * - - - - - - - - - - - - - - - R/G/B Gain - Green - - - - - - * - * - - - - - - - - - - - - - - - R/G/B Gain - Blue - - - - - - * - * - - - - - - - - - - - - - - - Y/Cb/Cr Gain - Y - - - - - - * - * - - - - - - - - - - - - - - - Y/Cb/Cr Gain - Cb - - - - - - * - * - - - - - - - - - - - - - - - Y/Cb/Cr Gain - Cr - - - - - - * - * - - - - - - - - - - - - - - - Y/Pb/Pr Gain - Y - - - - - - * - * - - - - - - - - - - - - - - - Y/Pb/Pr Gain - Pb - - - - - - * - * - - - - - - - - - - - - - - - Y/Pb/Pr Gain - Pr - - - - - - * - * - - - - - - - - - - - - - - - White Gain( Saturation ) - - - - - - * - * - - - - - - - - - - - - - - - 030-11. VIDEO MODE ADJUST Gamma * * * * * * * * * * * * * * ! * * * * * * * * * Noise Reduction * * * * * * * * * * * * * * - - - - - - - * * * Select Color Matrix * * * * * * * * * * * * * * ! * * - - - - * * * W/B Compress - Black - - * - - - * - * * - - - - - - - - - - - - - - Telecine - - - - - - * - * * - - * * - - - - - - - - - - Y/C Delay * * * * * * * * * * * * * * ! * * - * * - * * * YTR Adjustment - Gain * * * * * * * * * * * * * * ! * * - * * - * * * YTR Adjustment - Tap * * * * * * * * * * * * * * - - - - - - - - - - CTR Adjustment - Gain * * * * * * * * * * * * * * ! * * - * * - * * * CTR Adjustment - Tap * * * * * * * * * * * * * * - - - - - - - - - - 030-12. IMAGE MODE ADJUST Aspect Ratio Input Signal * * * * * * * * * * * * * * * * * * * * * * * * VD Delay * * * * * * * * * * * * * * - - - - - - - - - - VD Delay - Field Invert - - - - - - * - * - - * * * - - - - - - - - - - VD Delay - Offset - - - - - - * - * - - * * * - - - - - - - - - - Clamp Timing - Clamp * * * * * * * * * * * * * * * * * - * * - * * * Clamp Timing - ADJUST - * - - * * * - * * - * * * * * * * * * * * * * 030-14. REF. WHITE BAL. ADJUST - - - - - - * - * - - - * * ! * * * * * * * * * 030-15. OTHER ADJUST Overscan * * * * * * * * * * * * * * ! * * * * * * * * * Edge - - - - - - * - * - * * * * ! * * - * * - - - - Synchronize - - - - - - * - * - * - * * - - - - - - - * * * Signal Type * * * * * * * * * * * * * * ! * * - * * - * * * Setup Level - Setup Level - - * - - - * - * * - - - - - - - - - - - - - - Color Correction - Mode * * * * * * * * * * * * * * ! * * - * * - * * * Position - - * - - - - - - * - - - - - - - - - - - - - - Screen Position * * * * * * * * * * * * * * ! * * - * * - - - - Sweet Vision - - * - - - * - * * - - - - - - - - - - - - - - Sweet Vision - Split - - * - - - * - * * - - - - - - - - - - - - - - Sub Color - R * * * * * * - * - * - * x x - - - - - - - - - - Sub Color - G * * * * * * - * - * - * x x - - - - - - - - - - Sub Color - B * * * * * * - * - * - * x x - - - - - - - - - - Picture Management * * * * * * * * * * * * * * ! * * * * * * * * * Color Correction 2 - R * * * * * * * * * * * * * * - - - - * * - * * * Color Correction 2 - G * * * * * * * * * * * * * * - - - - * * - * * * Color Correction 2 - B * * * * * * * * * * * * * * - - - - * * - * * * Color Correction 2 - Y * * * * * * * * * * * * * * - - - - * * - * * * Color Correction 2 - M * * * * * * * * * * * * * * - - - - * * - * * * Color Correction 2 - C * * * * * * * * * * * * * * - - - - * * - * * * Color Correction 2 - Gain * * * * * * * * * * * * * * - - - - - - - - - - Color Temperature * * * * * * * * * * * * * * - - - - - - - - - - White Peaking * - - * - * - * - - * * - - - - - - - - - - - - 3D Y/C Separation - - * - - - * - * * - * * * - - - - - - - - - - 3D Y/C Separation On/Off - - - - - - - - - - - - * * ! * * - * * - - - - 3D Y/C Separation Mode - - - - - - - - - - - - * * - - - - - - - - - - Deinterlace - - * - - - * - * * - - * * - - - - - - - - - - Deinterlace On/Off - - - - - - - - - - - - * * - - - * - - * - - - Deinterlace Mode - - - - - - - - - - - - * * ! * * - * * - * * * Base Setting * * * * * * * * * * * * * * ! * * * * * * * * * Cornerstone - T-L H * * * * * * * * * * * * * * ! * * - * * * * * * Cornerstone - T-L V * * * * * * * * * * * * * * ! * * - * * * * * * Cornerstone - T-R H * * * * * * * * * * * * * * ! * * - * * * * * * Cornerstone - T-R V * * * * * * * * * * * * * * ! * * - * * * * * * Cornerstone - B-L H * * * * * * * * * * * * * * ! * * - * * * * * * Cornerstone - B-L V * * * * * * * * * * * * * * ! * * - * * * * * * Cornerstone - B-R H * * * * * * * * * * * * * * ! * * - * * * * * * Cornerstone - B-R V * * * * * * * * * * * * * * ! * * - * * * * * * Cornerstone - Execute * * * * * * * * * * * * * * ! * * - * * * * * * Contrast Enhancement - - * - - - * - * * - - - - ! - * - - - - - - - Variable Y/C Delay - - * - - - * - * * - * - - - - - - - - - - - - Tint Correction - - * - - - * - * * - - - - - - - - - - - - - - Y Gamma - - - - - - - - - - - - - - - - - - - - - - - - Ref.Color Cor. - R - - - - - - * - * - - - - - - - - - - - - - - - Ref.Color Cor. - G - - - - - - * - * - - - - - - - - - - - - - - - Ref.Color Cor. - B - - - - - - * - * - - - - - - - - - - - - - - - Ref.Color Cor. - Y - - - - - - * - * - - - - - - - - - - - - - - - Ref.Color Cor. - M - - - - - - * - * - - - - - - - - - - - - - - - Ref.Color Cor. - C - - - - - - * - * - - - - - - - - - - - - - - - Ref.Color Cor. - Color - - - - - - * - * - - - - - - - - - - - - - - - Saturation - - - - - - * - * - - - - - - - - - - - - - - - Pincushion / Horizontal - - - - - * - - - - - - - - - - - - - - - - - - Pincushion / Vertical - - - - - * - - - - - - - - - - - - - - - - - - Pincushion / Balance - - - - - * - - - - - - - - - - - - - - - - - - Digital Zoom / Zoom - - - - - * - - - - - - - - - - - - - - - - - - Digital Zoom / H Position - - - - - * - - - - - - - - - - - - - - - - - - Digital Zoom / V Position - - - - - * - - - - - - - - - - - - - - - - - - White Bal. Dual - Br R - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Dual - Br G - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Dual - Br B - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Dual - Cont R - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Dual - Cont G - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Dual - Cont B - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Lamp1 - Br R - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Lamp1 - Br G - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Lamp1 - Br B - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Lamp1 - Cont R - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Lamp1 - Cont G - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Lamp1 - Cont B - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Lamp2 - Br R - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Lamp2 - Br G - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Lamp2 - Br B - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Lamp2 - Cont R - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Lamp2 - Cont G - - - - - - ! - * - - - - - - - - - - - - - - - White Bal. Lamp2 - Cont B - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Dual - R - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Dual - G - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Dual - B - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Dual - Y - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Dual - M - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Dual - C - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Dual - Color - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp1 - R - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp1 - G - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp1 - B - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp1 - Y - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp1 - M - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp1 - C - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp1 - Color - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp2 - R - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp2 - G - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp2 - B - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp2 - Y - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp2 - M - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp2 - C - - - - - - ! - * - - - - - - - - - - - - - - - Color Cor. Lamp2 - Color - - - - - - ! - * - - - - - - - - - - - - - - - Picture Preset - - - - - - - - - * * - - - ! * * - * * - * * * SweetVision Mode - - - - - - - - - * - - - * - - - - - - - * * * SweetVision Level - - - - - - - - - * - - - * - - - - - - - * * * Vertical Enhancer - - - - - - - - - - - * * * - - - - - - - - - - I/P Converter - - - - - - - - - * * * x x - - - - - - - - - - Wall Color - - - - - - - - - - - * * * ! * * * * * * * * * Picture Mode - - - - - - - - - - - - - * ! * * - * * - * * * 031. FACTORY DEFAULT SET All data ( List ) ! * ! * * * * * * * * * * * ! * * * * * * * * * Signals being displayed * * * * * * * * * * * * * * ! * * * * * * * * * All data ( No List) * * * * * * * * * * * * * * ! * * - * * - * * * 033. DATE, TIME REQUEST - - - - - - * - * - - - - * ! * * * * * * * * * 037. INFORMATION REQUEST * * * * * * * * * * * * * * * * * * * * * * * * 037-1. LAMP INFORMATION REQUEST * * * * * * * * * * * * * * * * * * * * * * * * 037-2. LAMP INFORMATION REQUEST 2 * * * * * * * * * * * * * * * * * * * * * * * * 037-3. FILTER INFORMATION REQUEST - * - - * - * - * - - - * * * * * * * * * * - * 037-4. LAMP INFORMATION REQUEST 3 ! ! ! ! ! ! * * * * * * * * * * * * * * * * * * 038-1. PROJECTOR NAME SET * * * * * * * * * * * * * * ! * * * * * * * * * 047. VIEWER CONTROL * * * * * * * * * * * * * * ! * * * * * * - - - 048. VIEWER SLIDE REQUEST * * * * * * * * * * * ! ! ! ! * * * * * * - - - 049. STORE * * * * * * * * * * * * * * - - - - - - - - - - 050. REMOTE KEY CODE * * * * * * * * * * * * * * * * * * * * * * * * 051. LENS MUTE ON (SHUTTER CLOSE) - - - - - - - - - - - - - - - - - - - * - - * * 052. LENS MUTE OFF (SHUTTER OPEN) - - - - - - - - - - - - - - - - - - - * - - * * 053. LENS CONTROL Zoom - * - - * - * - * - - - - - - - - - - * - - * * Focus - * - - * - * - * - - - - - - - - - - * - - * * Lens Shift (H) - - - - - - * - * - - - - - - - - - - * - - * * Lens Shift (V) - - - - - - * - * - - - - - - - - - - * - - * * Stop - * - - * - * - * - - - - - - - - - - - - - * * 053-1. LENS CONTROL REQUEST - - - - - - * - * - - - - - - - - - - * - - - * 053-2. LENS CONTROL 2 - - - - - - * - * - - - - - - - - - - * - - - - 053-3. LENS MEMORY CUSTOM SET - - - - - - * - * - - - - - - - - - - * - - - * 053-4. LENS MEMORY REFERENCE SET - - - - - - * - * - - - - - - - - - - * - - - * 053-5. LENS MEMORY CONTROL REQUEST - - - - - - * - * - - - - - - - - - - * - - - * 053-6. LENS MEMORY CONTROL - - - - - - * - * - - - - - - - - - - * - - - * 053-7. LENS INFORMATION REQUEST - - - - - - * - * - - - - - - - - - - * - - - * 056. SLEEP TIMER REQUEST * * * * * * * * * - * * * * ! * * * * * * * * * 057. SLEEP TIMER SET * * * * * * * * * - * * * * ! * * * * * * * * * 058. FORCED ONSCREEN MUTE SET - - - - - - * - * - - - - - - - - * - - * * * * 060. GAIN PARAMETER REQUEST 2 * * * * * * * * * * * * * * * * * * * * * * * * 061. LAMP COOLING TIME REQUEST * * * * * * * * * * * * * * ! * * * * * * - - - 066. FACTORY DEFAULT SET 2 * * * * * * * * * * * * * * * * * * * * * * * * 077. MUTE CONTROL * * * * * * * * * * * * * * * * * * * * * * * * 078-1. SETTING REQUEST * * * * * * * * * * * * * * * * * * * * * * * * 078-2. RUNNING STATUS REQUEST * * * * * * * * * * * * * * * * * * * * * * * * 078-3. INPUT STATUS REQUEST * * * * * * * * * * * * * * * * * * * * * * * * 078-4. MUTE STATUS REQUEST * * * * * * * * * * * * * * * * * * * * * * * * 078-5. MODEL NAME REQUEST * * * * * * * * * * * * * * * * * * * * * * * * 078-6. COVER STATUS REQUEST - - - - - * - - - - - - - - - - - * * * * - * * 079. CAPTURE CONTROL * * * * * * * * * * * * * * * * * * * * * * * * 084. INFORMATION STRING REQUEST * * * * * * * * * * * * * * * * * * * * * * * * 091. DIGITAL ZOOM REQUEST ! * ! * * * * * * * * * * * - - - - - - - - - - 092-1. DIGITAL ZOOM MOUSE SET ! * ! * * * * * * * * * * * - - - - - - - - - - 092-2. DIGITAL ZOOM SET ! * ! * * * * * * * * * * * - - - - - - - - - - 092-3. DIGITAL ZOOM MOUSE CONTROL ! * ! * * * * * * * * * * * - - - - - - - - - - 097-1. MENU MODE REQUEST * * * * * * * * * * * * * * - - - - - - - - - - 097-2. LANGUAGE REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-3. MENU COLOR SELECT REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-4. PROJECTOR POINTER REQUEST * * - * * * * * * - * * * * - - - - - - - - - - 097-5. DISPLAY TIME REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-6. SOURCE DISPLAY REQUEST * * * * * * * * * * * * * * - - - * * * * * * * 097-7. MESSAGE REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-8. LAMP MODE REQUEST * * * * * * * * * * * * * * * * * * * * * * * * 097-9. IDLE MODE REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-10. CLOSED CAPTION REQUEST * * - * * * * * * - - ! - - - - - * * * * * * * 097-11. ORIENTATION REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-12. BACKGROUND REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-13. SCREEN TYPE REQUEST * * * * * * * * * * * * * * ! * * - * * - * * * 097-14. SCREEN TRIGGER REQUEST - - * - - - * - * * - - - - - - - - - - - - - - 097-15. VIEWER START MODE REQUEST * * * * * * * * * * * * * * ! * * - - - - - - - 097-16. VIEWER MODE REQUEST * * * * * * * * * * * * * * ! * * * * * * - - - 097-17. VIEWER INTERVAL REQUEST * * * * * * * * * * * * * * ! * * * * * * - - - 097-18. CAPTURE OPTIONS REQUEST * * * * * * * * * * * - - - - - - - - - - - - - 097-19. MOUSE BUTTON REQUEST * * - * * * * * * - * * * * ! * * * * * * * * * 097-20. MOUSE SENSITIVITY REQUEST * * - * * * * * * - * * * * ! * * * * * * * * * 097-21. SIGNAL SELECT REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-23. AUTO START REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-24. POWER MANAGEMENT REQUEST * * * * * * * * * * * * * * ! * * - * * - * * * 097-25. POWER CONFIRMATION REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-26. KEYSTONE SAVE REQUEST * * * * * * * * * * * * * * - - - * - - - - - - 097-27. FAN MODE REQUEST * * * * * * - * - * * - * * ! * * * * * * * * * 097-28. BUILT IN SPEAKER REQUEST - * - - * - * - * - - - - - - - - - - - - - - - 097-29. REMOTE SENSOR REQUEST - * - - * - * - * - * - - - - - - - - - - - - - 097-30. PANEL KEY LOCK REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-31. S-VIDEO SELECT REQUEST - * - - * - * - * - * - * * - - - - - - - - - - 097-32. COMMUNICATION REQUEST * * * * * * * * * * * * * * - - - * * * * * * * 097-33. DEFAULT SOURCE REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-34. PJ ID ENABLE REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-35. PJ ID REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-38. MENU PASSCODE REQUEST * * * * * * * * * * * * * * - - - - - - - - - - 097-39. TEST PATTERN REQUEST * * * * * * * * * * * * * * ! * * * * * * * * * 097-40. COLOR UNIFORMITY REQUEST - * - - * - * - * - - - * * ! * * * * - * * * * 097-41. AUTO FUNCTIONS REQUEST - * - - - - - - - - - - - - - - - - - - - - - - 097-72. LOGO PASSCODE REQUEST * * * * * * * * * * * * * * ! * * - * * - * * * 097-73. RGBOUT TERMINAL REQUEST * * - * * * * * * - * * * * ! * * - - - - - - - 097-74. MOUSE MODE REQUEST - * - - * - * - * - * - - - - - - - - - - - - - 097-75. MULTI DISPLAY REQUEST - ! - - ! * * * * - * * * * - - - - - - - - - - 097-76. MOTORIZED LENS REQUEST - * - - * - - - - - - - - - - - - - - - - - - - 097-77. LAMP TYPE REQUEST - * - - * - * - * - - - - - ! * * - * * - * * * 097-78. 3D SURROUND REQUEST - - * - - - - - - - - - * * ! * * - - - - - - - 097-79. WALL COLOR REQUEST - * - - * - - - - - - - - - - - - - - - - - - - 097-88. LAMP SELECT REQUEST - - - - - - * - * - - - - - - - - - - * - - - - 097-89. LAMP INTERVAL REQUEST - - - - - - * - * - - - - - - - - - - * - - - - 097-90. LAN CARD REQUEST - - - - - - * - * - - - - - - - - - - - - - - - 097-91. LAMP TYPE REQUEST 2 - - - - - - * - * - - - - - ! * * - * * - * * * 097-92. ON/OFF TIMER REQUEST - - - - - - * - * - - - - - - - - - - - - - - - 097-93. MOUSE POINTER REQUEST - ! - - ! * * * * - * * * * - - - - - - - - - - 097-94. BACK LIGHT REQUEST - - - - - - * - * - - - - - - - - - - - - - - - 097-100. LAST MEMORY REQUEST - - - - - - * - * - - - - - - - - - - - - - - - 097-101. SYNC TERMINATION REQUEST - - - - - - * - * - - - - - - - - - - - - * * * 097-102. LINK MODE REQUEST - - - - - - * - * - - - - - - - - - - - - - - - 097-105. LUMI UNIFORMITY REQUEST - - - - - - * - * - - - - - - - - - - - - - - - 097-109. AUTO 3D REFORM REQUEST 1 - ! - - - - - - - - - - - - - - - - - - - - - - 097-110. AUTO 3D REFORM REQUEST 2 - ! - - - - - - - - - - - - - - - - - - - - - - 097-111. AUTO 3D REFORM REQUEST 3 - ! - - - - - - - - - - - - - - - - - - - - - - 097-145. VIEWER THUMBNAILS REQUEST - - - - - - - - - - * * * * ! * * * * * * - - - 097-148. KEYSTONE SELECT REQUEST - - - - - - - - - - * * * - - - - - - - - - - - 097-174. REMOTE SENSOR REQUEST - - - - - - - - - - - - - * ! * * * * * * * * * 097-175. PROGRAM TIMER REQUEST - - - - - - - - - - - - - * ! * * * * * * * * * 097-176. PROGRAM TIMER DATA REQUEST - - - - - - - - - - - - - * ! * * - * * - * * * 097-191. GEOMETRIC CORRECTION REQUEST- - - - - - - - - - - - - - ! * * - * * - * * * 097-198. PIP/SIDE BY SIDE REQUEST - - - - - - - - - - - - - - ! * * - * * - * * * 098-1. MENU MODE SET * * * * * * * * * * * * * * - - - - - - - - - - 098-2. LANGUAGE SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-3. MENU COLOR SELECT SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-4. PROJECTOR POINTER SET * * - * * * * * * - * * * * - - - - - - - - - - 098-5. DISPLAY TIME SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-6. SOURCE DISPLAY SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-7. MESSAGE SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-8. LAMP MODE SET * * * * * * * * * * * * * * * * * * * * * * * * 098-9. IDLE MODE SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-10. CLOSED CAPTION SET * * - * * * * * * - * ! - - - - - * * * * * * * 098-11. ORIENTATION SET * * * * * * * * * * * * * * * * * * * * * * * * 098-12. BACKGROUND SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-13. SCREEN TYPE SET * * * * * * * * * * * * * * ! * * - * * - * * * 098-14. SCREEN TRIGGER SET - - * - - - * - * * - - - - - - - - - - - - - - 098-15. VIEWER START MODE SET * * * * * * * * * * * * * * ! * * - - - - - - - 098-16. VIEWER PLAY MODE SET * * * * * * * * * * * * * * ! * * * * * * - - - 098-17. VIEWER PLAY INTERVAL SET * * * * * * * * * * * * * * ! * * * * * * - - - 098-18. CAPTURE OPTIONS SET * * * * * * * * * * * - - - - - - - - - - - - - 098-19. MOUSE BUTTON SET * * - * * * * * * - * * * * ! * * * * * * * * * 098-20. MOUSE SENSITIVITY SET * * - * * * * * * - * * * * ! * * * * * * * * * 098-21. SIGNAL SELECT SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-23. AUTO START SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-24. POWER MANAGEMENT SET * * * * * * * * * - * * * * * * * * * * * * * * 098-25. POWER OFF CONFIRMATION SET * * * * * * * * * - * * * * ! * * - * * - * * * 098-26. KEYSTONE SAVE SET * * * * * * * * * * * * * * - - - * - - - - - - 098-27. FAN MODE SET * * * * * * - * - * * - * * ! * * * * * * * * * 098-28. BUILT IN SPEAKER SET - * - - * - * - * - - - - - - - - - - - - - - - 098-29. REMOTE SENSOR SET - * - - * - * - * - * - - - - - - - - - - - - - 098-30. CONTROL PANEL KEY LOCK SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-31. S-VIDEO MODE SELECT SET - * - - * - * - * - * - - - - - - - - - - - - - 098-32. COMMUNICATION SPEED SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-33. DEFAULT SOURCE SELECT SET * * * * * * * * * - * * * * ! * * * * * * * * * 098-34. PROJECTOR ID ENABLE SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-35. PROJECTOR ID SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-39. TEST PATTERN SET * * * * * * * * * * * * * * ! * * * * * * * * * 098-40. COLOR UNIFORMITY SET - * - - * - * - * - - - * * ! * * * * * * * * * 098-41. AUTO FUNCTIONS SET - * - - - - - - - - - - - - - - - - - - - - - - 098-73. RGBOUT TERMINAL SET * * - * * * * * * - * * * * ! * * - - - - - - - 098-74. MOUSE MODE SELECT SET - * - - * - * - * - * - - - - - - - - - - - - - 098-75. MULTI DISPLAY SET - ! - - ! * * * * - * * * * - - - - - - - - - - 098-78. 3D SURROUND SET - - * - - - - - - - * - * * ! * * - - - - - - - 098-79. WALL COLOR SET - * - - * - - - - - - - - - - - - - - - - - - - 098-88. LAMP SELECT SET - - - - - - * - * - - - - - - - - - - * - - - - 098-89. LAMP INTERVAL SET - - - - - - * - * - - - - - - - - - - * - - - - 098-90. LAN CARD SET - - - - - - * - * - - - - - - - - - - - - - - - 098-92. ON/OFF TIMER SET - - - - - - * - * - - - - - - - - - - - - - - - 098-93. MOUSE POINTER SET - ! - - ! * * * * - * * * * - - - - - - - - - - 098-94. BACK LIGHT SET - - - - - - * - * - - - - - - - - - - - - - - - 098-100. LAST MEMORY SET - - - - - - * - * - - - - - - - - - - - - - - - 098-101. SYNC TERMINATION SET - - - - - - * - * - - - - - - - - - - - - * * * 098-102. LINK MODE SET - - - - - - * - * - - - - - - - - - - - - - - - 098-105. LUMI UNIFORMITY SET - - - - - - * - * - - - - - - - - - - - - - - - 098-109. AUTO 3D REFORM SET 1 - ! - - - - - - - - - - - - - - - - - - - - - - 098-110. AUTO 3D REFORM SET 2 - ! - - - - - - - - - - - - - - - - - - - - - - 098-111. AUTO 3D REFORM SET 3 - ! - - - - - - - - - - - - - - - - - - - - - - 098-145. VIEWER THUMBNAILS SET - - - - - - - - - - * * * * ! * * * * * * - - - 098-148. KEYSTONE SELECT SET - - - - - - - - - - * * * - - - - - * * - - - - 098-174. REMOTE SENSOR SET - - - - - - - - - - - - - * ! * * * * * * * * * 098-175. PROGRAM TIMER SET - - - - - - - - - - - - - * ! * * * * * * * * * 098-176. PROGRAM TIMER DATA SET - - - - - - - - - - - - - * ! * * - * * - * * * 098-191. GEOMETRIC CORRECTION SET - - - - - - - - - - - - - - ! * * - * * - * * * 098-198. PIP/SIDE BY SIDE SET - - - - - - - - - - - - - - ! * * - * * - * * * 110. AUTO FUNCTIONS EXECUTE - * - - - - - - - - - - - - - - - - - - - - - - 305-1. BASE MODEL TYPE REQUEST - - - - - - - - - - - * * * * * * * * * * * * * 305-2. VERSION INFORMATION REQUEST - - - - - - - - - - - - - * * * * - * * - * * * 305-3. PROJECTOR INFORMATION REQUEST - - - - - - - - - - - * * * * * * * * * * * * * ====================================================================== 5. Command Descriptions ---------------------------------------------------------------------- Precautions with Inscriptions: (*1) Projector ID It is the value when forwarding a factory. This reflects the "Projector ID" that has been set to the projector. (*2) Model code : "xxH" inscription This will differ depending on the projector. In case of MT/NP2000 series 10H In case of NP3150 series 10H In case of NP3250 series 10H In case of PA600 series 10H In case of PX750 series 10H In case of PA622 series 10H In case of PX602 series 10H In case of PH1202 series 10H In case of LT/LT80 series 20H In case of VT/P420 series 40H In case of P501 series 40H In case of GT series 50H In case of HT series 60H In case of WT series 70H In case of NP905/901W/VT800 series 90H (*3) Checksum : "CKS" inscription This is the value of the lower 1 byte (8 bits) of the results calculated in byte units from all the of the data up to the immediately preceding data. Example) 20H 81H 01H 60H 01H 00H CKS 20H + 81H + 01H + 60H + 01H + 00H = 103H CKS = 03H (*4) Response error number This is the value of the error number at the time of an error. See "NAK" of "6-2. Data portion of response". (*5) Term “RGB” and “COMPUTER” On the HT1100, VT770, LT245/265/280/380, NP1000/2000 ,NP3150 series, NP905/901W/VT800, NP3250, NP-P350X/P420X/P350W, PA600 series, PX750 series, P501 series, PA621/PA622 series, PX602 series and PH1202 series the term "RGB connector" has been changed to "COMPUTER". (*6) Term “DVI” and “COMPUTER” On the LT380, NP1000/2000, NP3150 series and NP3250 series the term "DVI connector" has been changed to "COMPUTER". 006. RUNNING SENSE ********************************************************************** Function: This command acquires the operation mode of the projector. Command: 00H 81H 00H 00H 00H 81H Response: At the time of a success 20H 81H 01H xxH 01H DATA01 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Status of operation Bit 7 : Power On/Off processing 0 = No execution(Normal condition) 1 = During execution Bit 6 : Selecting signal processing 0 = No execution(Normal condition) 1 = During execution Bit 5 : Cooling processing 0 = No execution(Normal condition) 1 = During execution Bit 4 : External control mode 0 = OFF 1 = ON Bit 3 : No power-off period 0 = Power-off possible (Normal condition) 1 = Power-off Impossible Bit 2 : Reserved Bit 1 : Projector status 0 = Idling 1 = Power On Bit 0 : Reserved Response: At the time of a failure A0H 81H 01H xxH 02H DATA1H DATA02 CKS (*1) (*2) (*4) (*3) 007. COMMON DATA REQUEST ********************************************************************** Function: This command acquisition of the detailed conditions of the projector. Command: 00H C0H 00H 00H 00H C0H Response: At the time of a success 20H C0H 01H xxH 80H DATA01 .. DATA128 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Projector type See DATA70..71 DATA02 Projector ID 1 .. 64 DATA03 Reserved DATA04 Projector status 00H : Idling 01H : Power On DATA05 Cooling processing 00H : No execution(Normal condition) 01H : During execution DATA06 Indication signal number( Entry list number - 1 ) 0 .. 199 DATA07 Type 1 of input terminal to be selected (!) 01H : 1 02H : 2 03H : 3 04H : 4 05H : 5 DATA08 Type 2 of input terminal to be selected (!) 01H : RGB (*5) 02H : VIDEO 03H : S-VIDEO 04H : COMPONENT 05H : Reserved 06H : DIGITAL (*6) 07H : VIEWER 08H : SLOT1 09H : SLOT2 DATA09 Indication signal type * Valid only when Type 2 of input terminal is 02H or 03H x0H : NTSC3.58 x1H : NTSC4.43 x2H : PAL x3H : PAL60 x4H : SECAM x5H : B/W60 x6H : B/W50 x7H : PALNM x8H : NTSC3.58 LBX x9H : NTSC3.58 SQZ xDH : NTSC xEH : PAL-M xFH : PAL-N * x: undefined DATA10 .. 12 Reserved ( undefined ) DATA13 .. 20 Horizontal frequency of the indication signal(string) ( "000.00" kHz + NULL(0)+ NULL(0) ) DATA21 .. 28 Vertical frequency of the indication signal(string) ( "000.00" Hz + NULL(0)+ NULL(0) ) DATA29 Picture mute 00H : OFF 01H : ON DATA30 Sound mute 00H : OFF 01H : ON DATA31 .. 32 Reserved DATA33 Test pattern display 1 00H : No display(Normal condition) 00H Other : Displaying(Pattern ID) +------------+-----------------+----+----+----+----+----+----+----+----+----+----+----+----+----+ | Pattern ID | Pattern name | MT | LT |LT80| HT | GT | WT | VT | NP | NP | NP | NP |P420|P501| | | | | | | | | | |2000|3150|905 |3250| | | +------------+-----------------+----+----+----+----+----+----+----+----+----+----+----+----+----+ | 02H | Cross Hatch | - | * | - | * | - | - | - | - | * | * | * | * | * | | 03H | Gray Bars | * | * | * | * | * | * | * | * | * | * | * | * | * | | 04H | Raster(0%) | * | * | * | * | * | * | * | * | * | * | * | * | * | | 05H | Raster(25%) | * | * | * | * | * | * | * | * | * | * | * | * | * | | 06H | Raster(50%) | * | * | * | * | * | * | * | * | * | * | * | * | * | | 07H | Raster(100%) | * | * | * | * | * | * | * | * | * | * | * | * | * | | 08H | Focus | * | * | * | * | * | * | * | * | - | - | - | - | - | | 09H | Raster Blue | * | - | * | - | * | - | * | * | * | * | * | * | * | | 0AH | Gray Raster 30 | * | * | * | * | * | * | * | * | * | * | * | * | * | | 17H | Gray Raster 10 | * | * | * | * | * | * | * | * | * | * | * | * | * | | 18H | RAMP WBGR | - | * | - | * | - | * | - | - | - | - | - | - | - | | 19H | Blue Raster 60 | - | * | - | * | - | * | - | - | - | - | - | * | * | | 1DH | Cross Hatch 3 | * | *1 | * | - | * | * | * | * | - | - | - | - | - | +------------+-----------------+----+----+----+----+----+----+----+----+----+----+----+----+----+ [NP-PA600X/500X/550W/500U] [NP-PX750U] [NP-PA721X/PA621X/PA671W/PA571W/PA621W/PA521U/PA722X/PA622X/PA672W/PA572W/PA622W/PA522U] [NP-PX602UL/PX602WL] [NP-PH1202HL/PH1002HL] +------------+-----------------+----+----+----+----+----+ | Pattern ID | Pattern name |PA |PX |PA |PX |PH | | | |600 |750 |622 |602 |1202| +------------+-----------------+----+----+----+----+----+ | 01H | Cross Hatch | * | * | * | * | * | | 02H | Gray Bars | * | * | * | - | - | | 03H | Raster(0%) | * | * | * | * | * | | 04H | Raster(25%) | * | * | * | * | * | | 05H | Raster(50%) | * | * | * | * | * | | 06H | Raster(100%) | * | * | * | * | * | | 07H | Color Bar | * | * | * | * | * | | 18H | Gray Bars | - | - | - | * | * | +------------+-----------------+----+----+----+----+----+ * : Supported - : Not supported *1: Only LT240K/260K DATA34 Test pattern display 2 FFH : No display(Normal condition) FFH Other : Displaying Bit 2 : BLUE pattern 0 = OFF 1 = ON Bit 1 : GREEN pattern 0 = OFF 1 = ON Bit 0 : RED pattern 0 = OFF 1 = ON DATA35 .. 50 Reserved DATA51 .. 65 User registration name ( 14 characters + NULL ) DATA66 Forced On-screen mute 00H : OFF 01H : ON DATA67 On-screen display 00H : No display 01H : Displaying DATA68 Selecting signal processing 00H : No execution(Normal condition) 01H : During execution DATA69 Status of operation 00H : Idling 04H : Power On 05H : Cooling 06H : Idling(Error occurrence) Other than above : (nondisclosure) internal use of code during a state transition period DATA70 .. 71 Projector type +--------+--------+--------+-----------------+ | DATA01 | DATA70 | DATA71 | | +--------+--------+--------+-----------------+ | 01H | 00H | 03H | MT1060/1065 | | 01H | 01H | 03H | MT860 | | 01H | 02H | 03H | MT1075 | | 01H | 00H | 06H | NP1000/2000 | | 02H | 00H | 03H | LT240/260 | | 02H | 01H | 03H | LT220 | | 02H | 02H | 03H | LT240K/260K | | 02H | 00H | 05H | LT245/265 | | 02H | 00H | 06H | LT380 | | 02H | 01H | 06H | LT280 | | 03H | 00H | 04H | VT770 | | 04H | 00H | 03H | GT5000 | | 04H | 01H | 03H | GT6000 | | 05H | 00H | 03H | HT1000 | | 05H | 00H | 04H | HT1100 | | 06H | 00H | 03H | WT600 | | 06H | 00H | 05H | WT610/615 | | 10H | 00H | 08H | VT700 Series | | 12H | 00H | 08H | NP3150/2150/1150| | 12H | 01H | 08H | NP3151 | | 12H | 00H | 09H | NP905 | | 12H | 01H | 09H | NP901W | | 12H | 02H | 09H | VT800 | | 12H | 00H | 10H | NP3250/2250/1250| | 12H | 01H | 10H | NP3250W | | 13H | 00H | 11H | NP-P420X | | 13H | 01H | 11H | NP-P350X | | 13H | 02H | 11H | NP-P350W | | 15H | 00H | 10H | NP-PA600X | | 15H | 01H | 10H | NP-PA500X | | 15H | 02H | 10H | NP-PA550W | | 15H | 03H | 10H | NP-PA500U | | 17H | 00H | 10H | NP-PX750U | | 20H | 00H | 10H | NP-P501X | | 20H | 01H | 10H | NP-P451X | | 20H | 02H | 10H | NP-P451W | | 20H | 03H | 10H | NP-P401W | | 20H | 04H | 10H | NP-PE501X | | 21H | 00H | 10H | NP-PA621U | | 21H | 01H | 10H | NP-PA521U | | 21H | 02H | 10H | NP-PA671W | | 21H | 03H | 10H | NP-PA571W | | 21H | 04H | 10H | NP-PA721X | | 21H | 05H | 10H | NP-PA621X | | 21H | 00H | 11H | NP-PA622U | | 21H | 01H | 11H | NP-PA522U | | 21H | 02H | 11H | NP-PA672W | | 21H | 03H | 11H | NP-PA572W | | 21H | 04H | 11H | NP-PA722X | | 21H | 05H | 11H | NP-PA622X | | 25H | 00H | 10H | NP-PX602UL | | 25H | 01H | 10H | NP-PX602WL | | 26H | 00H | 10H | NP-PH1202HL | | 26H | 01H | 10H | NP-PH1002HL | +--------+--------+--------+-----------------+ DATA72 PC Card insertion 00H : Not inserted 01H : Inserted DATA73 USB Mouse connection 00H : Not connected 01H : Connected DATA74 Entry list type 01H : Default 02H : User DATA75 .. 82 Reserved DATA83 On-screen mute 00H : OFF 01H : ON DATA84 Reserved DATA85 Indicate Contents 00H = Picture signal displaying 01H = No signal 02H = Viewer displaying 03H = Test pattern displaying 04H = LAN displaying DATA86 .. 128 Reserved Response: At the time of a failure A0H C0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) (!) +-------------------------+-----------+----------------+ | Selected input terminal | DATA07 | DATA08 | +-------------------------+-----------+----------------+ | RGB or RGB1 (*5) | 1 (01H) | RGB (01H) | | RGB2 (*5) | 2 (02H) | RGB (01H) | | RGB3 (*5) | 3 (03H) | RGB (01H) | | Video | 1 (01H) | VIDEO (02H) | | S-Video | 1 (01H) | S-VIDEO (03H) | | Component | 1 (01H) | COMPONENT(04H) | | Component | 2 (02H) | COMPONENT(04H) | | Component | 3 (03H) | COMPONENT(04H) | | DVI or DVI(DIGITAL) (*6)| 1 (01H) | DIGITAL (06H) | | HDMI | 1 (01H) | DIGITAL (06H) | | DisplayPort | 2 (02H) | DIGITAL (06H) | | HDMI2 | 2 (02H) | DIGITAL (06H) | | SLOT | 3 (03H) | DIGITAL (06H) | | Viewer | 1 (01H) | VIEWER (07H) | | LAN / Network | 2 (02H) | VIEWER (07H) | | USB Display | 4 (04H) | VIEWER (07H) | | Slot1-1 | 1 (01H) | SLOT1 (08H) | | Slot1-2 | 2 (02H) | SLOT1 (08H) | | Slot2-1 | 1 (01H) | SLOT2 (09H) | | Slot2-2 | 2 (02H) | SLOT2 (09H) | | RGB(Video) | 2 (02H) | VIDEO (02H) | | RGB(S-Video) | 2 (02H) | S-VIDEO (03H) | +-------------------------+-----------+----------------+ 009. ERROR STATUS REQUEST ********************************************************************** Function: This command acquires the error information occurring with the projector. Command: 00H 88H 00H 00H 00H 88H Response: At the time of a success 20H 88H 01H xxH 0CH DATA01 .. DATA12 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- * The various bits are normal is "0" and error is "1". * "None" is "0" fixation. DATA01 Error Status(1) bit0 : Lamp cover error bit1 : Temperature error(Bimetal) bit2 : None bit3 : Fan error bit4 : Fan error bit5 : Power error bit6 : Lamp(or Lamp1) error bit7 : Lamp(or Lamp1) has reached its end of life DATA02 Error Status(2) bit0 : Lamp(or Lamp1) has been used beyond its limit bit1 : Formatter error bit2 : Lamp2 error bit3 : None bit4 : None bit5 : None bit6 : None bit7 : None DATA03 Error Status(3) bit0 : None bit1 : FPGA error bit2 : Temperature error(Sensor) bit3 : Lamp(or Lamp1) housing error (!) bit4 : Lamp(or Lamp1) data error (!) bit5 : Mirror cover error bit6 : Lamp2 has reached its end of life bit7 : Lamp2 has been used beyond its limit DATA03 Error Status(4) bit0 : Lamp2 housing error bit1 : Lamp2 data error bit2 : High temperature due to dust pile-up bit3 : A foreign object sensor error bit4 : None bit5 : None bit6 : None bit7 : None DATA05 .. 12 Reserved Response: At the time of a failure A0H 88H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: (!) LT/LT80/HT/NP: "None" 015. POWER ON ********************************************************************** Function: This command switches on the main power of the projector. Command: 02H 00H 00H 00H 00H 02H Response: At the time of a success 22H 00H 01H xxH 00H CKS (*1) (*2) (*3) Response: At the time of a failure A2H 00H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: The projector does not accept the other command during power on processing. 016. POWER OFF ********************************************************************** Function: This command switches off the main power of the projector. Command: 02H 01H 00H 00H 00H 03H Response: At the time of a success 22H 01H 01H xxH 00H CKS (*1) (*2) (*3) Response: At the time of a failure A2H 01H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: The projector doesn't accept the other command during power off processing.( It contains a cooling period.) 018. INPUT SW CHANGE ********************************************************************** Function: This command switches the input terminal or the entry list. Command: 02H 03H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Switching object 00H : Entry List 01H : Input terminal DATA02 Switching number --------------------------------------------------------- When the switching object is the "Signal list", the signal list number is specified. ( 0 .. 99 ) --------------------------------------------------------- When the switching object is the "Input connector", the input connector number is specified. +-----------------+---------------+----+----+----+----+----+----+----+----+----+----+----+----+----+----+----+----+----+----+ | Terminal number | Terminal name | MT | LT |LT80| HT | GT | WT | VT | NP | NP | NP | NP |P420| PA | PX |P501| PA | PX | PH | | | | | | | | | | |2000|3150|905 |3250| |600 |750 | |622 |602 |1202| +-----------------+---------------+----+----+----+----+----+----+----+----+----+----+----+----+----+----+----+----+----+----+ | 01H | RGB1(RGB) | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | | 02H | RGB2 | * | * | * | - | * | - | * | * | * | * | * | * | * | * | - | * | * | * | | 02H | DVI(ANALOG) | - | - | - | - | - | * | - | - | - | - | - | - | - | - | - | - | - | - | | 03H | RGB3(*5) | - | - | - | - | - | - | - | - | - | - | - | - | * | * | - | - | - | - | | 06H | Video | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | | 0BH | S-Video | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | | 10H | Component | - | - | * | * | - | - | - | * | * | - | * | - | - | - | - | - | - | - |(!!) | 11H | Component | - | - | - | * | - | - | - | - | - | - | - | - | - | - | - | - | - | - |(!!!) | 12H | Component | - | - | - | - | - | - | * | - | - | - | - | - | - | - | - | - | - | - | | 1AH | DVI | * | - | - | * | - | - | - | - | - | - | - | - | - | - | - | - | - | - |(!) | 1AH | DVI(DIGITAL) | - | - | * | - | * | * | - | * | * | - | * | - | - | - | - | - | - | - |(!) | 1AH | HDMI | - | - | - | - | - | - | - | - | - | * | - | * | * | * | * | - | - | - | | 1BH | DisplayPort | - | - | - | - | - | - | - | - | - | - | - | - | * | * | - | - | - | - | | 1BH | HDMI2 | - | - | - | - | - | - | - | - | - | - | - | - | - | - | * | - | - | - | | 1CH | SLOT | - | - | - | - | - | - | - | - | - | - | - | - | - | * | - | - | - | - | | 1FH | Viewer | * | * | * | * | * | * | * | * | * | * | * | * | * | * | * | - | - | - |(!!!!) | 20H | LAN/Network | * | * | * | - | * | * | - | * | * | * | * | * | * | * | * | * | * | * |(!!!!) | 07H | RGB(Video) | - | - | - | - | * | - | - | - | - | - | - | - | - | - | - | - | - | - | | 0CH | RGB(S-Video) | - | - | - | - | * | - | - | - | - | - | - | - | - | - | - | - | - | - | | 22H | USB Display | - | - | - | - | - | - | - | - | - | - | - | * | - | - | * | - | - | - | | 24H | SLOT1-1 | - | - | - | - | * | - | - | - | - | - | - | - | - | - | - | - | - | - | | 25H | SLOT1-2 | - | - | - | - | * | - | - | - | - | - | - | - | - | - | - | - | - | - | | 29H | SLOT2-1 | - | - | - | - | * | - | - | - | - | - | - | - | - | - | - | - | - | - | | 2AH | SLOT2-2 | - | - | - | - | * | - | - | - | - | - | - | - | - | - | - | - | - | - | | A1H | HDMI1 | - | - | - | - | - | - | - | - | - | - | - | - | - | - | - | * | * | * | | A2H | HDMI2 | - | - | - | - | - | - | - | - | - | - | - | - | - | - | - | * | - | - | | A6H | DisplayPort | - | - | - | - | - | - | - | - | - | - | - | - | - | - | - | * | * | * | | ABH | SLOT | - | - | - | - | - | - | - | - | - | - | - | - | - | - | - | - | * | * | +-----------------+---------------+----+----+----+----+----+----+----+----+----+----+----+----+----+----+----+----+----+----+ * : Supported - : Not supported (!): The MT860 and LT280 does not support a DVI connector. (!!) HT1000 (!!!) HT1100 (!!!!) The PE501X does not support a Viewer and a LAN/Network connector. Response: At the time of a success 22H 03H 01H xxH 01H DATA01 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Results 00H : Normal FFH : Error Response: At the time of a failure A2H 03H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * When switch to the Video connector 02H 03H 00H 00H 02H 01H 06H 0EH 020. PICTURE MUTE ON ********************************************************************** Function: This command blanks the picture. Command: 02H 10H 00H 00H 00H 12H Response: At the time of a success 22H 10H 01H xxH 00H CKS (*1) (*2) (*3) Response: At the time of a failure A2H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: * Picture mute is cancelled for the following: Input connector switching Video signal switching 021. PICTURE MUTE OFF ********************************************************************** Function: This command cancels the blank picture condition. Command: 02H 11H 00H 00H 00H 13H Response: At the time of a success 22H 11H 01H xxH 00H CKS (*1) (*2) (*3) Response: At the time of a failure A2H 11H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 022. SOUND MUTE ON ********************************************************************** Function: This command mutes the sound. Command: 02H 12H 00H 00H 00H 14H Response: At the time of a success 22H 12H 01H xxH 00H CKS (*1) (*2) (*3) Response: At the time of a failure A2H 12H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: * Sound mute is cancelled for the following: Input connector switching Video signal switching Volume adjustment 023. SOUND MUTE OFF ********************************************************************** Function: This command cancels the sound muting. Command: 02H 13H 00H 00H 00H 15H Response: At the time of a success 22H 13H 01H xxH 00H CKS (*1) (*2) (*3) Response: At the time of a failure A2H 13H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 024. ONSCREEN MUTE ON ********************************************************************** Function: This command blanks the on-screen display. Command: 02H 14H 00H 00H 00H 16H Response: At the time of a success 22H 14H 01H xxH 00H CKS (*1) (*2) (*3) Response: At the time of a failure A2H 14H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: * Onscreen mute is cancelled for the following: Input connector switching Video signal switching 025. ONSCREEN MUTE OFF ********************************************************************** Function: This command cancels the blanking of the on-screen display. Command: 02H 15H 00H 00H 00H 17H Response: At the time of a success 22H 15H 01H xxH 00H CKS (*1) (*2) (*3) Response: At the time of a failure A2H 15H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 030-1. PICTURE ADJUST ********************************************************************** Function: This command adjusts the Picture. Command: 03H 10H 00H 00H 05H DATA01 .. DATA05 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Adjustment items 00H : Brightness 01H : Contrast 02H : Color 03H : Hue 04H : Sharpness 1DH : V-Aperture/Vertical Detail (!) 93H : Contrast Select (!) DATA02 FFH fixed DATA03 Adjustment mode 00H : Absolute value specification 01H : Relative value specification DATA04 Adjustment value ( Lower ranking 8 bits ) DATA05 Adjustment value ( Upper ranking 8 bits ) Response: At the time of a success 23H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting Brightness to 10 03H 10H 00H 00H 05H 00H FFH 00H 0AH 00H 21H * Setting Brightness to -10 03H 10H 00H 00H 05H 00H FFH 00H F6H FFH 0CH (!) Method of Specifying the Absolute Value of Special Adjustment Values +------------------------+--------+--------+ | | DATA04 | DATA05 | +------------------------+--------+--------+ | Vertical Detail Off | 00H | 00H | | Vertical Detail 1 | 01H | 00H | | Vertical Detail 2 | 02H | 00H | | Vertical Detail 3 | 03H | 00H | +------------------------+--------+--------+ | Contrast Select Auto | 00H | 00H | | Contrast Select Manual | 01H | 00H | +------------------------+--------+--------+ 030-2. VOLUME ADJUST ********************************************************************** Function: This command sets the volume. Command: 03H 10H 00H 00H 05H DATA01 .. DATA05 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 05H fixed DATA02 Setting items 00H : Volume 01H : Bass 02H : Treble 03H : Balance DATA03 Setting mode 00H : Absolute value specification 01H : Relative value specification DATA04 Setting Value ( Lower ranking 8 bits ) DATA05 Setting Value ( Upper ranking 8 bits ) Response: At the time of a success 23H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting Volume to "10" 03H 10H 00H 00H 05H 05H 00H 00H 0AH 00H 27H 030-3. BLANKING ADJUST ********************************************************************** Function: This command adjusts the Blanking. Command: 03H 10H 00H 00H 05H DATA01 .. DATA05 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 06H fixed DATA02 Adjustment items 00H : Top 01H : Bottom 02H : Left 03H : Right DATA03 Adjustment mode 00H : Absolute value specification 01H : Relative value specification DATA04 Adjustment value ( Lower ranking 8 bits ) DATA05 Adjustment value ( Upper ranking 8 bits ) Response: At the time of a success 23H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting Blanking Top to 10 03H 10H 00H 00H 05H 06H 00H 00H 0AH 00H 28H 030-4. IMAGE ADJUST ********************************************************************** Function: This command adjusts the Image. Command: 03H 10H 00H 00H 05H DATA01 .. DATA05 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Adjustment items +--------+--------+-------------------------+ | DATA01 | DATA02 | Adjustment items | +--------+--------+-------------------------+ | 07H | FFH | Auto Adjust (!) | | 08H | 00H | Position H | | 08H | 01H | Position V | | 09H | 00H | Pixel Adjust Clock | | 09H | 01H | Pixel Adjust Phase | | 0AH | FFH | Video Filter (!) | | 0BH | FFH | Resolution (!) | | 10H | 00H | Sync Protection Upper | | 10H | 01H | Sync Protection Lower | +--------+--------+-------------------------+ DATA03 Adjustment mode 00H : Absolute value specification 01H : Relative value specification DATA04 Adjustment value ( Lower ranking 8 bits ) DATA05 Adjustment value ( Upper ranking 8 bits ) Response: At the time of a success 23H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting Position H to -10 03H 10H 00H 00H 05H 08H 00H 00H F6H FFH 15H (!) Method of Specifying the Absolute Value of Special Adjustment Values +---------------------+--------+--------+ | | DATA04 | DATA05 | +---------------------+--------+--------+ | Auto Adjust Off | 00H | 00H | | Auto Adjust On | 01H | 00H | | Auto Adjust Fine | 02H | 00H | +---------------------+--------+--------+ | Video Filter Off | 00H | 00H | | Video Filter Less | 01H | 00H | | Video Filter More | 02H | 00H | +---------------------+--------+--------+ | Resolution Native | 01H | 00H | | Resolution Auto | 00H | 00H | +---------------------+--------+--------+ 030-5. COLOR TEMPERATURE ADJUST ********************************************************************** Function: This command adjusts the Color Temperature. Command: 03H 10H 00H 00H 05H DATA01 .. DATA05 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 13H fixed DATA02 FFH fixed DATA03 Adjustment mode 00H : Absolute value specification 01H : Relative value specification DATA04 Adjustment value ( Lower ranking 8 bits ) DATA05 Adjustment value ( Upper ranking 8 bits ) Response: At the time of a success 23H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting Color Temperature to 3 03H 10H 00H 00H 05H 13H FFH 00H 03H 00H 2DH 030-6. WHITE BALANCE ADJUST ********************************************************************** Function: This command adjusts the White Balance. Command: 03H 10H 00H 00H 05H DATA01 .. DATA05 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 14H fixed DATA02 Adjustment items 00H : Brightness R 01H : Brightness G 02H : Brightness B 03H : Contrast R 04H : Contrast G 05H : Contrast B DATA03 Adjustment mode 00H : Absolute value specification 01H : Relative value specification DATA04 Adjustment value ( Lower ranking 8 bits ) DATA05 Adjustment value ( Upper ranking 8 bits ) Response: At the time of a success 23H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting Brightness R to 10 03H 10H 00H 00H 05H 14H 00H 00H 0AH 00H 36H * Setting Brightness R to -10 03H 10H 00H 00H 05H 14H 00H 00H F6H FFH 21H 030-8. KEYSTONE ADJUST ********************************************************************** Function: This command adjusts the Keystone. Command: 03H 10H 00H 00H 05H DATA01 .. DATA05 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 15H fixed DATA02 Adjustment items 00H : H 01H : V DATA03 Adjustment mode 00H : Absolute value specification 01H : Relative value specification DATA04 Adjustment value ( Lower ranking 8 bits ) DATA05 Adjustment value ( Upper ranking 8 bits ) Response: At the time of a success 23H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting Keystone H to 10 03H 10H 00H 00H 05H 15H 00H 00H 0AH 00H 37H * Setting Keystone H to -10 03H 10H 00H 00H 05H 15H 00H 00H F6H FFH 22H 030-10. SIGNAL LEVEL ADJUST ********************************************************************** Function: This command adjusts the Signal Level. Command: 03H 10H 00H 00H 05H DATA01 .. DATA05 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Adjustment items +--------+--------+-----------------------------+ | DATA01 | DATA02 | Adjustment items | +--------+--------+-----------------------------+ | 2EH | FFH | Auto Control(!) | | 2FH | 00H | R/G/B Gain R | | 2FH | 01H | R/G/B Gain G | | 2FH | 00H | R/G/B Gain B | | 30H | 00H | Y/Cb/Cr Gain Y | | 30H | 01H | Y/Cb/Cr Gain Cb | | 30H | 02H | Y/Cb/Cr Gain Cr | | 31H | 00H | Y/Pb/Pr Gain Y | | 31H | 01H | Y/Pb/Pr Gain Pb | | 31H | 02H | Y/Pb/Pr Gain Pr | | 39H | FFH | White Gain(Saturation Gain) | +--------+--------+-----------------------------+ DATA03 Adjustment mode 00H : Absolute value specification 01H : Relative value specification DATA04 Adjustment value ( Lower ranking 8 bits ) DATA05 Adjustment value ( Upper ranking 8 bits ) Response: At the time of a success 23H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting Signal Level R/G/B Gain to 10 03H 10H 00H 00H 05H 2FH 00H 00H 0AH 00H 51H (!) Auto Control (All data) 03H 10H 00H 00H 05H 2EH FFH 00H 00H 00H 45H (!) Auto Control (Signals being displayed) 03H 10H 00H 00H 05H 2EH FFH 00H 01H 00H 46H 030-11. VIDEO MODE ADJUST ********************************************************************** Function: This command adjusts the Video Mode. Command: 03H 10H 00H 00H 05H DATA01 .. DATA05 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Adjustment items +--------+--------+-------------------------+ | DATA01 | DATA02 | Adjustment items | +--------+--------+-------------------------+ | 16H | FFH | Gamma (!) | | 1AH | FFH | Noise Reduction Lumi (!)| | 1CH | FFH | Select Color Matrix (!) | | 21H | 01H | W/B Compress BlackEx (!)| | 23H | FFH | Y/C Delay | | 28H | 00H | YTR Adjust Gain | | 28H | 01H | YTR Adjust Tap | | 29H | 00H | CTR Adjust Gain | | 29H | 01H | CTR Adjust Tap | | 2BH | 00H | White Correct Position | | 9DH | 00H | Random NR (!) | | 9DH | 01H | Mosquito NR (!) | | 9DH | 02H | Block NR (!) | +--------+--------+-------------------------+ DATA03 Adjustment mode 00H : Absolute value specification 01H : Relative value specification DATA04 Adjustment value ( Lower ranking 8 bits ) DATA05 Adjustment value ( Upper ranking 8 bits ) Response: At the time of a success 23H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting Gamma to Black Detail 03H 10H 00H 00H 05H 16H FFH 00H 02H 00H 2FH (!) Method of Specifying the Absolute Value of Special Adjustment Values +---------------------------+--------+--------+ | | DATA04 | DATA05 | +---------------------------+--------+--------+ | Gamma Dynamic | 00H | 00H | | Gamma Natural | 01H | 00H | | Gamma Black Detail | 02H | 00H | | Noise Reduction Off | 00H | 00H | | Noise Reduction Low | 01H | 00H | | Noise Reduction Medium | 02H | 00H | | Noise Reduction High | 03H | 00H | | Select Color Matrix HDTV | 00H | 00H | | Select Color Matrix SDTV | 01H | 00H | | W/B Compress Off | 00H | 00H | | W/B Compress On | 01H | 00H | | W/B Compress Black Ex Off | 00H | 00H | | W/B Compress Black Ex 1 | 01H | 00H | | W/B Compress Black Ex 2 | 02H | 00H | | W/B Compress Black Ex 3 | 03H | 00H | | W/B Compress Black Ex 4 | 04H | 00H | | W/B Compress Black Ex 5 | 05H | 00H | +---------------------------+--------+--------+ 030-12. IMAGE MODE ADJUST ********************************************************************** Function: This command adjusts the Image Mode. Command: 03H 10H 00H 00H 05H DATA01 .. DATA05 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Adjustment items +--------+--------+---------------------------+ | DATA01 | DATA02 | Adjustment items | +--------+--------+---------------------------+ | 18H | 00H | Aspect Ratio Input (!) | | 25H | FFH | VD Delay (!) | | 25H | 00H | VD Delay Adjustment (!) | | 25H | 01H | VD Delay Field Invert (!) | | 25H | 02H | VD Delay Offset (!) | | 33H | 00H | Clamp Timing (!) | | 33H | 01H | Clamp Timing Adjust (!) | +--------+--------+---------------------------+ DATA03 Adjustment mode 00H : Absolute value specification 01H : Relative value specification DATA04 Adjustment value ( Lower ranking 8 bits ) DATA05 Adjustment value ( Upper ranking 8 bits ) Response: At the time of a success 23H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting the Aspect Ratio to Letter Box 03H 10H 00H 00H 05H 18H 00H 00H 01H 00H 31H (!) Method of Specifying the Absolute Value of Special Adjustment Values [ GT/HT/LT/LT80/MT/WT/VT/NP2000 ] +---------------------------+--------+--------+ | | DATA04 | DATA05 | +---------------------------+--------+--------+ | Aspect Ratio 4:3 (Window) | 00H | 00H | | Aspect Ratio 1.25:1(5:4) | 00H | 00H | | Aspect Ratio Letter Box | 01H | 00H | | Aspect Ratio 1.33:1(4:3) | 01H | 00H | | Aspect Ratio Wide Screen | 02H | 00H | | Aspect Ratio 1.78:1(16:9) | 02H | 00H | | Aspect Ratio Crop | 03H | 00H | | Aspect Ratio 1.85:1 | 03H | 00H | | Aspect Ratio 4:3 Fill | 04H | 00H | | Aspect Ratio 2.35:1 | 04H | 00H | | Aspect Ratio Normal | 05H | 00H | | Aspect Ratio Full | 06H | 00H | | Aspect Ratio Zoom | 07H | 00H | | Aspect Ratio Cinema | 08H | 00H | | Aspect Ratio V-Zoom | 09H | 00H | | Aspect Ratio Stadium | 0AH | 00H | | VD Delay Delay1 | 00H | 00H | | VD Delay Delay2 | 01H | 00H | | VD Delay Delay3 | 02H | 00H | | VD Delay Delay4 | 03H | 00H | | VD Delay Field Invert Off | 00H | 00H | | VD Delay Field Invert On | 01H | 00H | | Clamp Timing Mode 0 | 00H | 00H | | Clamp Timing Mode 1 | 01H | 00H | | Clamp Timing Mode 2 | 02H | 00H | | Clamp Timing Mode 3 | 03H | 00H | | Clamp Timing Mode 4 | 04H | 00H | | Clamp Timing Adjust | 05H | 00H | +---------------------------+--------+--------+ [ NP3150/NP905/NP3250 ] +---------------------------+--------+--------+ | | DATA04 | DATA05 | +---------------------------+--------+--------+ | Aspect Ratio 4:3 (Window) | 00H | 00H | | Aspect Ratio Letter Box | 01H | 00H | | Aspect Ratio Wide Screen | 02H | 00H | | Aspect Ratio 1.78:1(16:9) | 02H | 00H | | Aspect Ratio Zoom | 03H | 00H | | Aspect Ratio 4:3 Fill | 04H | 00H | | Aspect Ratio 5:4 | 0BH | 00H | | Aspect Ratio 16:10 | 0CH | 00H | | Aspect Ratio 15:9 | 0DH | 00H | +---------------------------+--------+--------+ [ P420/P501 ] +---------------------------+--------+--------+ | | DATA04 | DATA05 | +---------------------------+--------+--------+ | Aspect Ratio Normal / Auto| 00H | 00H | | Aspect Ratio Wide Zoom | 01H | 00H | | Aspect Ratio Cinema / 16:9| 02H | 00H | | Aspect Ratio Native | 03H | 00H | | Aspect Ratio 4:3 | 04H | 00H | | Aspect Ratio 15:9 | 05H | 00H | | Aspect Ratio 16:10 | 06H | 00H | | Aspect Ratio Letter Box | 07H | 00H | +---------------------------+--------+--------+ [ PA600/PX750 ] +---------------------------+--------+--------+ | | DATA04 | DATA05 | +---------------------------+--------+--------+ | Aspect Ratio 4:3 (Window) | 00H | 00H | | Aspect Ratio Letter Box | 01H | 00H | | Aspect Ratio Wide Screen | 02H | 00H | | Aspect Ratio 16:9 | 02H | 00H | | Aspect Ratio Zoom | 03H | 00H | | Aspect Ratio 4:3 Fill | 04H | 00H | | Aspect Ratio 5:4 | 0BH | 00H | | Aspect Ratio 16:10 | 0CH | 00H | | Aspect Ratio 15:9 | 0DH | 00H | | Aspect Ratio NATIVE | 0EH | 00H | | Aspect Ratio AUTO | 0FH | 00H | +---------------------------+--------+--------+ [ PA622/PX602/PH1202 ] +---------------------------+--------+--------+ | | DATA04 | DATA05 | +---------------------------+--------+--------+ | Aspect Ratio 4:3 (Window) | 00H | 00H | | Aspect Ratio Letter Box | 01H | 00H | | Aspect Ratio Wide Screen | 02H | 00H | | Aspect Ratio 16:9 | 02H | 00H | | Aspect Ratio Zoom | 06H | 00H | | Aspect Ratio Full | 06H | 00H | | Aspect Ratio 5:4 | 0BH | 00H | | Aspect Ratio 16:10 | 0CH | 00H | | Aspect Ratio 15:9 | 0DH | 00H | | Aspect Ratio NATIVE | 0EH | 00H | | Aspect Ratio AUTO | 0FH | 00H | +---------------------------+--------+--------+ 030-14. REF. WHITE BAL. ADJUST ********************************************************************** Function: This command adjusts the REF. WHITE BAL. Command: 03H 10H 00H 00H 05H DATA01 .. DATA05 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Adjustment items +--------+--------+-------------------------+ | DATA01 | DATA02 | Adjustment items | +--------+--------+-------------------------+ | 3AH | 00H | Brightness R | | 3AH | 01H | Brightness G | | 3AH | 02H | Brightness B | | 3AH | 03H | Contrast R | | 3AH | 04H | Contrast G | | 3AH | 05H | Contrast B | +--------+--------+-------------------------+ DATA03 Adjustment mode 00H : Absolute value specification 01H : Relative value specification DATA04 Adjustment value ( Lower ranking 8 bits ) DATA05 Adjustment value ( Upper ranking 8 bits ) Response: At the time of a success 23H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting Brightness R to 10 03H 10H 00H 00H 05H 3AH 00H 00H 0AH 00H 5CH 030-15. OTHER ADJUST ********************************************************************** Function: This command adjusts the various gains. Command: 03H 10H 00H 00H 05H DATA01 .. DATA05 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Adjustment items +--------+--------+------------------------------+ | DATA01 | DATA02 | Adjustment items | +--------+--------+------------------------------+ | 3BH | FFH | Overscan (!) | | 3CH | FFH | Edge (!) | | 3DH | 00H | Synchronize Off/On | | 3DH | 01H | Synchronize Adjsut | | 3FH | 00H | Signal Type RGB | | 3FH | 01H | Signal Type Component | | 40H | 00H | Col Correct On/Off(!) | | 40H | 01H | Col Correct G-R Gain | | 40H | 02H | Col Correct G-B Gain | | 40H | 03H | Col Correct B-R Gain | | 40H | 04H | Col Correct B-G Gain | | 40H | 05H | Col Correct R-G Gain | | 40H | 06H | Col Correct R-B Gain | | 40H | 07H | Col Correct U Gain | | 40H | 08H | Col Correct V Gain | | 41H | FFH | HD Delay (!) | | 42H | 00H | Ref. Pedestal U Level | | 42H | 01H | Ref. Pedestal V Level | | 43H | FFH | Stack Clock | | 44H | 00H | Sub Brightness R | | 44H | 01H | Sub Brightness G | | 44H | 02H | Sub Brightness B | | 45H | FFH | Y Contrast | | 46H | FFH | Y Gamma Correction (!) | | 47H | 00H | Setup Level IRE (!) | | 47H | 01H | Setup Level Adjust (!) | | 47H | 02H | Setup Level Correct (!) | | 48H | FFH | DCL | | 49H | FFH | Color Space (!) | | 4AH | FFH | RGB Sharpness | | 4BH | FFH | F-CLK Phase | | 4CH | 00H | Col Correct Mode (!) | | 4CH | 01H | Col Correct Color Tune1 | | 4CH | 02H | Col Correct Yellow1 | | 4CH | 03H | Col Correct Magenta1 | | 4CH | 04H | Col Correct Cyan1 | | 4CH | 05H | Col Correct White1 | | 4CH | 06H | Col Correct Color Tune2 | | 4CH | 07H | Col Correct Yellow2 | | 4CH | 08H | Col Correct Magenta2 | | 4CH | 09H | Col Correct Cyan2 | | 4CH | 0AH | Col Correct White2 | | 4DH | FFH | Through (!) | | 4EH | 00H | Ref. Auto White R | | 4EH | 01H | Ref. Auto White G | | 4EH | 02H | Ref. Auto White B | | 4FH | FFH | Position | | 50H | FFH | Screen Position | | 51H | 00H | Sweet Vision (!) | | 51H | 01H | Sweet Vision Split (!) | | 52H | 00H | Sub Color R | | 52H | 01H | Sub Color G | | 52H | 02H | Sub Color B | | 53H | FFH | Picture Management (!) | | 54H | 00H | Correct2 R | | 54H | 01H | Correct2 G | | 54H | 02H | Correct2 B | | 54H | 03H | Correct2 Y | | 54H | 04H | Correct2 M | | 54H | 05H | Correct2 C | | 54H | 06H | Correct2 Color | | 55H | FFH | Color Temperature | | 56H | FFH | White Peaking | | 57H | FFH | 3D Y/C Separation | | 57H | 00H | 3D Y/C Separation On/Off | | 57H | 01H | 3D Y/C Separation Mode | | 58H | FFH | Deinterlace | | 58H | 00H | Deinterlace On/Off | | 58H | 01H | Deinterlace Mode | | 59H | FFH | Base Setting / Reference (!) | | 5AH | 00H | Corner T-Left H (!!) | | 5AH | 01H | Corner T-Left V (!!) | | 5AH | 02H | Corner T-Right H (!!) | | 5AH | 03H | Corner T-Right V (!!) | | 5AH | 04H | Corner B-Right H (!!) | | 5AH | 05H | Corner B-Right V (!!) | | 5AH | 06H | Corner B-Left H (!!) | | 5AH | 07H | Corner B-Left V (!!) | | 5AH | 08H | Corner Execute (!!) | | 5BH | FFH | Contrast Enhancement (!) | | 5DH | FFH | Tint Correction | | 5FH | 00H | Ref. Color Cor. R | | 5FH | 01H | Ref. Color Cor. G | | 5FH | 02H | Ref. Color Cor. B | | 5FH | 03H | Ref. Color Cor. Y | | 5FH | 04H | Ref. Color Cor. M | | 5FH | 05H | Ref. Color Cor. C | | 5FH | 06H | Ref. Color Cor. Color | | 60H | FFH | Saturation | | 61H | 00H | Pincushion Horizontal | | 61H | 01H | Pincushion Vertical | | 61H | 02H | Balance(Vertical) | | 62H | 00H | Digital Zoom / Zoom | | 62H | 01H | Digital Zoom / H Pos | | 62H | 02H | Digital Zoom / V Pos | | 63H | 00H | White Bal. Dual Br R | | 63H | 01H | White Bal. Dual Br G | | 63H | 02H | White Bal. Dual Br B | | 63H | 03H | White Bal. Dual Cont R | | 63H | 04H | White Bal. Dual Cont G | | 63H | 05H | White Bal. Dual Cont B | | 64H | 00H | White Bal. Lamp1 Br R | | 64H | 01H | White Bal. Lamp1 Br G | | 64H | 02H | White Bal. Lamp1 Br B | | 64H | 03H | White Bal. Lamp1 Cont R | | 64H | 04H | White Bal. Lamp1 Cont G | | 64H | 05H | White Bal. Lamp1 Cont B | | 65H | 00H | White Bal. Lamp2 Br R | | 65H | 01H | White Bal. Lamp2 Br G | | 65H | 02H | White Bal. Lamp2 Br B | | 65H | 03H | White Bal. Lamp2 Cont R | | 65H | 04H | White Bal. Lamp2 Cont G | | 65H | 05H | White Bal. Lamp2 Cont B | | 66H | 00H | Color Cor. Dual R | | 66H | 01H | Color Cor. Dual G | | 66H | 02H | Color Cor. Dual B | | 66H | 03H | Color Cor. Dual Y | | 66H | 04H | Color Cor. Dual M | | 66H | 05H | Color Cor. Dual C | | 66H | 06H | Color Cor. Dual Color | | 67H | 00H | Color Cor. Lamp1 R | | 67H | 01H | Color Cor. Lamp1 G | | 67H | 02H | Color Cor. Lamp1 B | | 67H | 03H | Color Cor. Lamp1 Y | | 67H | 04H | Color Cor. Lamp1 M | | 67H | 05H | Color Cor. Lamp1 C | | 67H | 06H | Color Cor. Lamp1 Color | | 68H | 00H | Color Cor. Lamp2 R | | 68H | 01H | Color Cor. Lamp2 G | | 68H | 02H | Color Cor. Lamp2 B | | 68H | 03H | Color Cor. Lamp2 Y | | 68H | 04H | Color Cor. Lamp2 M | | 68H | 05H | Color Cor. Lamp2 C | | 68H | 06H | Color Cor. Lamp2 Color | | 90H | FFH | Picture Preset | | 91H | FFH | SweetVision Mode (!!!) | | 92H | FFH | SweetVision Level (!!!) | | 94H | FFH | Virtical Enhancer | | 95H | FFH | I/P Converter | | 96H | FFH | Lamp Mode Adjust | | 97H | FFH | Wall Color | | 9CH | FFH | Picture Mode | | 9EH | 00H | Multi Screen Mode | | 9EH | 01H | Multi Screen Contrast | | 9EH | 02H | Multi Screen Brightness | | 9FH | 00H | Dynamic Contrast | +--------+--------+------------------------------+ DATA03 Adjustment mode 00H : Absolute value specification 01H : Relative value specification DATA04 Adjustment value ( Lower ranking 8 bits ) DATA05 Adjustment value ( Upper ranking 8 bits ) Response: At the time of a success 23H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 10H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting Overscan to 10% 03H 10H 00H 00H 05H 3BH FFH 00H 02H 00H 54H (!) Method of Specifying the Absolute Value of Special Adjustment Values +---------------------------+--------+--------+ | | DATA04 | DATA05 | +---------------------------+--------+--------+ | Overscan 0% | 00H | 00H | | Overscan 5% | 01H | 00H | | Overscan 10% | 02H | 00H | | Overscan 25% | 03H | 00H | | Edge Auto | 00H | 00H | | Edge Less | 01H | 00H | | Edge More | 02H | 00H | | Setup Level Correct Off | 00H | 00H | | Setup Level Correct On | 01H | 00H | | Setup Level 0 IRE | 00H | 00H | | Setup Level 0.75 IRE | 01H | 00H | | Setup Level Adjust | 02H | 00H | | Color Space Component | 01H | 00H | | Color Space RGB | 02H | 00H | | Color Space NTSC | 03H | 00H | | Color Space Graphics | 04H | 00H | | Col Correct Off | 00H | 00H | | Col Correct On | 01H | 00H | | HD Delay Off | 00H | 00H | | HD Delay On | 01H | 00H | | Y Gamma Correction Off | 00H | 00H | | Y Gamma Correction On | 01H | 00H | | Correct Mode Off | 00H | 00H | | Correct Mode Mode 1 | 01H | 00H | | Correct Mode Mode 2 | 02H | 00H | | Correct Mode Mode 3 | 03H | 00H | | Correct Mode sRGB | 04H | 00H | | Correct Mode User1 | 05H | 00H | | Correct Mode User2 | 06H | 00H | | Correct Mode White Off | 00H | 00H | | Correct Mode White ON | 01H | 00H | | Through Off | 00H | 00H | | Through On | 01H | 00H | | Sweet Vision Off | 00H | 00H | | Sweet Vision Low | 01H | 00H | | Sweet Vision Medium | 02H | 00H | | Sweet Vision High | 03H | 00H | | Sweet Vision Split Off | 00H | 00H | | Sweet Vision Split On | 01H | 00H | | Pic Manage Presen(Graph) | 00H | 00H | | Pic Manage sRGB | 01H | 00H | | Pic Manage Graph(Game) | 02H | 00H | | Pic Manage Video | 03H | 00H | | Pic Manage Movie | 04H | 00H | | Pic Manage User1(User) | 05H | 00H | | Pic Manage User2 | 06H | 00H | | Pic Manage User3 | 07H | 00H | | Pic Manage User4 | 08H | 00H | | Color Temperature Off | 00H | 00H | | Color Temperature On | 01H | 00H | | Picture Management 1 | 00H | 00H | | Picture Management 2 | 01H | 00H | | Picture Management 3 | 02H | 00H | | Picture Management 4 | 03H | 00H | | Picture Management 5 | 04H | 00H | | Picture Management 6 | 05H | 00H | | Picture Management 7 | 06H | 00H | | Reference High-Bright | 00H | 00H | | Reference Presentation | 01H | 00H | | Reference Video | 02H | 00H | | Reference Movie | 03H | 00H | | Reference Graphic | 04H | 00H | | Reference sRGB | 05H | 00H | | Reference DICOM.SIM | 06H | 00H | | Base Setting Presen(Graph)| 00H | 00H | | Base Setting sRGB | 01H | 00H | | Base Setting Graph(Game) | 02H | 00H | | Base Setting Video | 03H | 00H | | Base Setting Movie | 04H | 00H | | Cornerstone (Execute) | 00H | 00H | | Cornerstone (Reset) | 01H | 00H | | Contrast Enhancement -3 | 00H | 00H | | Contrast Enhancement -2 | 01H | 00H | | Contrast Enhancement -1 | 02H | 00H | | Contrast Enhancement Off | 03H | 00H | | Contrast Enhancement 1 | 04H | 00H | | Contrast Enhancement 2 | 05H | 00H | | Contrast Enhancement 3 | 06H | 00H | | Picture Preset User1 | 00H | 00H | | Picture Preset User2 | 01H | 00H | | Picture Preset User3 | 02H | 00H | | Picture Preset User4 | 03H | 00H | | Picture Preset User5 | 04H | 00H | | SweetVision Mode Off (!!!)| 00H | 00H | | SweetVision Mode On (!!!) | 01H | 00H | | Vertical Enhancer Off | 00H | 00H | | Vertical Enhancer 1 | 01H | 00H | | Vertical Enhancer 2 | 02H | 00H | | Vertical Enhancer 3 | 03H | 00H | | I/P Converter Auto | 00H | 00H | | I/P Converter Still | 01H | 00H | | I/P Converter Interlace | 02H | 00H | | Wall Color Off | 00H | 00H | | Wall Color Light blue | 01H | 00H | | Wall Color Pink | 02H | 00H | | Wall Color Light rose | 03H | 00H | | Wall Color Light yellow | 04H | 00H | | Wall Color Light green | 05H | 00H | | Wall Color Sky blue | 06H | 00H | | Wall Color Blackboard | 07H | 00H | | Multi Screen Mode Off | 00H | 00H | | Multi Screen Mode On | 01H | 00H | | Dynamic Contrast Off | 00H | 00H | | Dynamic Contrast On | 01H | 00H | +---------------------------+--------+--------+ (!!) Cornerstone Adjustment Method (0,0) (0,0) +------------------|------------------+ |(Adjustment point 1) |(Adjustment point 2) | | | | | | | | -- -- | | | | | | | | |(Adjustment point 4) |(Adjustment point 3) +------------------|------------------+ (0,0) (0,0) +---------------------+--------+------------------------------------+ | Adjustment object | DATA01 | DATA02 | DATA03 | DATA04 .. DATA05 | +---------------------+--------+--------+--------+------------------+ | Adjustment point 1 | | | | Adjustment | | Horizontal position | 5AH | 00H | 00H | position data | +---------------------+--------+--------+--------+------------------+ | Adjustment point 1 | | | | Adjustment | | Vertical position | 5AH | 01H | 00H | position data | +---------------------+--------+--------+--------+------------------+ | Adjustment point 2 | | | | Adjustment | | Horizontal position | 5AH | 02H | 00H | position data | +---------------------+--------+--------+--------+------------------+ | Adjustment point 2 | | | | Adjustment | | Vertical position | 5AH | 03H | 00H | position data | +---------------------+--------+--------+--------+------------------+ | Adjustment point 3 | | | | Adjustment | | Horizontal position | 5AH | 04H | 00H | position data | +---------------------+--------+--------+--------+------------------+ | Adjustment point 3 | | | | Adjustment | | Vertical position | 5AH | 05H | 00H | position data | +---------------------+--------+--------+--------+------------------+ | Adjustment point 4 | | | | Adjustment | | Horizontal position | 5AH | 06H | 00H | position data | +---------------------+--------+--------+--------+------------------+ | Adjustment point 4 | | | | Adjustment | | Vertical position | 5AH | 07H | 00H | position data | +---------------------+--------+--------+--------+------------------+ | Adjustment | | | | | | execution | 5AH | 08H | 00H | 0000H | +---------------------+--------+--------+--------+------------------+ Command example: * Setting Cornerstone adjustment point 1 to x1:(50,20) and adjustment point 3 to x3:(-20,-10) +------------------|------------------+ | x1 <-Adjustment point 1 | |(50,20) | | | | | | | -- -- | | | | | | | (-20,-10) | | Adjustment point 3-> x3 | +------------------|------------------+ 1) Setting the horizontal position of adjustment point 1 to 50 03H 10H 00H 00H 05H 5AH 00H 00H 32H 00H A4H 2) Setting the vertical position of adjustment point 1 to 20 03H 10H 00H 00H 05H 5AH 01H 00H 14H 00H 87H 3) Setting the horizontal position of adjustment point 3 to -20 03H 10H 00H 00H 05H 5AH 04H 00H ECH FFH 61H 4) Setting the vertical position of adjustment point 3 to -10 03H 10H 00H 00H 05H 5AH 05H 00H F6H FFH 6CH 5) Adjustment Execution 03H 10H 00H 00H 05H 5AH 08H 00H 00H 00H 7AH * Resetting Cornerstone 03H 10H 00H 00H 05H 5AH 08H 00H 01H 00H 7BH (!!!) On the NP1000/2000, "SweetVision" has been changed to "Contrast Enhancement". 031. FACTORY DEFAULT SET ********************************************************************** Function: This command resets the projector setting values to the defaults. Command: 03H 32H 00H 00H 01H DATA01 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Target 00H : All data ( Including Entry List ) 01H : Signals being displayed 02H : All data ( No Including Entry List ) Response: At the time of a success 23H 32H 01H xxH 00H CKS (*1) (*2) (*3) Response: At the time of a failure A3H 32H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 033. DATE/TIME REQUEST ********************************************************************** Function: This command acquires the current date and time of the projector. Command: 03H 81H 00H 00H 00H 84H Response: At the time of a success 23H 81H 01H xxH 08H DATA01 .. DATA08 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Day data (1 .. 31) DATA02 Month data (1 .. 12) DATA03 .. 04 Year data DATA05 Day of week data 00H : Sunday 01H : Monday 02H : Tuesday 03H : Wednesday 04H : Thursday 05H : Friday 06H : Saturday DATA06 Seconds data (0 .. 59) DATA07 Minutes data (0 .. 59) DATA08 Hours data (0 .. 23) Response: At the time of a failure A3H 81H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 037. INFORMATION REQUEST ********************************************************************** Function: This command acquires the projector information. Command: 03H 8AH 00H 00H 00H 8DH Response: At the time of a success 23H 8AH 01H xxH 62H DATA01 .. DATA98 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 49 Projector name (NULL termination character string) DATA50 .. 82 Reserved DATA83 .. 86 Lamp Hour Meter (second) (!) DATA87 .. 90 Filter Usage (second) DATA91 .. 94 Panel Usage (second) DATA95 .. 98 Projector Usage (second) Response: At the time of a failure A3H 8AH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: (!) Lamp Hour Meter This is the timer for normal lamp mode conversion. Lamp Timer Acquisition Examples DATA83 DATA84 DATA85 DATA86 : Lamp Timer 00H 00H 00H 00H : Total 0 seconds C0H 65H 52H 00H : Total 5400000 seconds = 1500 hours 00H E4H 57H 00H : Total 5760000 seconds = 1600 hours * The projector's hours of use is displayed in terms of Normal mode values. It is also displayed with truncated a number after decimal point. 037-1. LAMP INFORMATION REQUEST ********************************************************************** Function: This command acquires the lamp information (in terms of Normal mode values) of projector. Command: 03H 8CH 00H 00H 00H 8FH Response: At the time of a success 23H 8CH 01H xxH 10H DATA01 .. DATA16 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 04 Lamp Hour Meter(Normal mode) (second) DATA05 .. 08 Reserved DATA09 .. 12 Lamp Use Warning Starting Time(Normal mode) (second) DATA13 .. 16 Lamp Use Prohibited Time(Normal mode) (second) Response: At the time of a failure A3H 8CH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: Example for acquiring remaining lamp time (in terms of Normal mode values) : Lamp Hour Meter (Normal mode) DATA01 DATA02 DATA03 DATA04 30H 2AH 00H 00H : 10800 second : Starting time for lamp usage warning message (in terms of Normal mode values) DATA09 DATA10 DATA11 DATA12 00H DDH 6DH 00H : 7200000 second Lamp remaining time (in terms of Normal mode values) = (7200000 - 10800) / 3600 = 1997 hour 037-2. LAMP INFORMATION REQUEST 2 ********************************************************************** Function: This command acquires lamp remaining amount. Command: 03H 94H 00H 00H 00H 97H Response: At the time of a success 23H 94H 01H xxH 05H DATA01 .. DATA05 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 04 Reserved DATA05 lamp remaining amount (100% to -10%) Response: At the time of a failure A3H 94H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 037-3. FILTER INFORMATION REQUEST ********************************************************************** Function: This command acquires the information about the projector's filter. Command: 03H 95H 00H 00H 00H 98H Response: At the time of a success 23H 95H 01H xxH 08H DATA01 .. DATA08 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 04 Filter usage time (second) DATA05 .. 08 Starting time for filter usage warning message (second) Response: At the time of a failure A3H 95H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 037-4. LAMP INFORMATION REQUEST 3 ********************************************************************** Function: This command acquires the information on the projector lamp. Command: 03H 96H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Target 00H : Lamp1 01H : Lamp2 DATA02 item 00H: Lamp Hour Meter (second) (!) 01H: Lamp usage time (second) (!!) 04H: lamp remaining amount until lamp warning message (100% to -10%) 05H : Lamp usage time (Normal mode)(second) 06H : Lamp usage time (Eco mode)(second) 07H : Lamp usage time (Eco2 mode)(second) 08H: Remaining time until lamp warning message starts to appear (in terms of specified values) 09H: Remaining time until lamp warning message starts to appear (in terms of Normal mode values) 0AH: Remaining time until lamp warning message starts to appear (in terms of Eco mode values) 0BH : Remaining time until lamp warning message starts to appear (in terms of Eco2 mode values) 10H: Remaining time until inhibition of lamp usage (in terms of specified values) 11H: Remaining time until inhibition of lamp usage (in terms of Normal mode values) 12H: Remaining time until inhibition of lamp usage (in terms of Eco mode values) 14H : Lamp usage time (Auto mode)(second) 15H : Remaining time until lamp warning message starts to appear (in terms of Auto mode values) 16H : Remaining time until inhibition of lamp usage (in terms of Auto mode values) Response: At the time of a success 23H 96H 01H xxH 06H DATA01 .. DATA06 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 same values as DATA01 of the command DATA02 same values as DATA02 of the command DATA03 .. 06 Acquired information Response: At the time of a failure A3H 96H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: * In case of acquiring lamp's use of hours 03H 96H 00H 00H 02H 00H 01H 9CH Example of acquisition DATA03 DATA04 DATA05 DATA06: lamp's use of hours 50H 46H 00H 00H: 18000 seconds Lamp's use of hours = 18000/3600 = 5 hours * In case of acquiring the remaining time until lamp warning message starts to appear (in terms of specified values) 03H 96H 00H 00H 02H 00H 08H A3H Example of acquisition DATA03 DATA04 DATA05 DATA06: Remaining time 40H 7EH 05H 00H: 360000 seconds Remaining time until lamp warning message starts to appear = 360000/ 3600= 100 hours (!) Lamp Hour Meter This is the timer for normal lamp mode conversion. (!!) Lamp usage time This is the lamp total usage. It is displayed in the projector's menu. 038-1. PROJECTOR NAME SET ********************************************************************** Function: This command sets projector name. Command: 03H 8BH 00H 00H 32H 00H DATA01 .. DATA49 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 16 Projector name (NULL termination character string) DATA17 .. 49 Reserved Response: At the time of a success 23H 8BH 01H xxH 02H 00H DATA01 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Results 00H : Normal 01H : Error 02H : Error( Length over ) Response: At the time of a failure A3H 8BH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 047. VIEWER CONTROL ********************************************************************** Function: This command controls the viewer display. Command: 01H 90H 00H 00H 01H DATA01 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Control contents 00H : Auto Play 01H : Auto Play Stop 02H : Slide Previous 03H : Slide Forward Response: At the time of a success 21H 90H 01H xxH 01H DATA01 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Results 00H : Normal 01H : Error Response: At the time of a failure A1H 90H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: * Only valid while the viewer is displayed. 048. VIEWER SLIDE STATUS REQUEST ********************************************************************** Function: This command acquires the viewer display information. Command: 01H 91H 00H 00H 00H 92H Response: At the time of a success 21H 91H 01H xxH 05H DATA01 .. DATA05 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Viewer Control 00H : Enable 01H : Disable DATA02 .. 03 Total number of slides in the folder (WORD type) DATA04 .. 05 Currently displayed slide number (WORD type) Response: At the time of a failure A1H 91H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: * Valid only while the viewer is displayed. 049. STORE ********************************************************************** Function: This command stores the adjustment values. Command: 03H 30H 00H 00H 00H 33H Response: At the time of a success 23H 30H 01H xxH 00H CKS (*1) (*2) (*3) Response: At the time of a failure A3H 30H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 050. REMOTE KEY CODE ********************************************************************** Function: This command sends remote control key codes of projector. Command: 02H 0FH 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Remote control key code (Word type) Key number DATA01 DATA02 Key name -------------------------------------------- 1 01H 00H POWER 2 02H 00H POWER ON 3 03H 00H POWER OFF 4 04H 00H SOURCE (AUTO) 5 05H 00H AUTO (!) 6 06H 00H MENU 7 07H 00H UP 8 08H 00H DOWN 9 09H 00H RIGHT 10 0AH 00H LEFT 11 0BH 00H ENTER 12 0CH 00H CANCEL 13 0DH 00H HELP 14 0EH 00H POINTER 15 0FH 00H MAGNIFY UP 16 10H 00H MAGNIFY DOWN 17 11H 00H PICTURE MUTE 18 12H 00H SOUND MUTE 19 13H 00H MUTE 20 14H 00H FOCUS UP 21 15H 00H FOCUS DOWN 22 16H 00H ZOOM UP 23 17H 00H ZOOM DOWN 30 1EH 00H STORE 31 1FH 00H MUTE ALL OFF 37 25H 00H R 38 26H 00H G 39 27H 00H B 40 28H 00H OSD MUTE 41 29H 00H PICTURE 42 2AH 00H WHITE BAL 43 2BH 00H IMAGE 44 2CH 00H TEST 45 2DH 00H UNDO 46 2EH 00H 1 47 2FH 00H 2 48 30H 00H 3 49 31H 00H 4 50 32H 00H 5 51 33H 00H 6 52 34H 00H 7 53 35H 00H 8 54 36H 00H 9 55 37H 00H 0 56 38H 00H POSITION 57 39H 00H INFO. 58 3AH 00H PIXEL 59 3BH 00H KEYSTONE 60 3CH 00H AMPLITUDE 61 3DH 00H INPUT LIST 66 42H 00H BS 71 47H 00H PICMUTE ON 72 48H 00H PICMUTE OFF 73 49H 00H SNDMUTE ON 74 4AH 00H SNDMUTE OFF 75 4BH 00H RGB1(*5) 76 4CH 00H RGB2(*5) 77 4DH 00H RGB3 78 4EH 00H YCBCR 79 4FH 00H VIDEO1 80 50H 00H VIDEO2 81 51H 00H S-VIDEO1 82 52H 00H S-VIDEO2 83 53H 00H DIGITAL1 84 54H 00H DIGITAL2 85 55H 00H PC CARD 132 84H 00H VOLUME UP 133 85H 00H VOLUME DOWN 134 86H 00H KEYSTONE UP 135 87H 00H KEYSTONE DOWN 136 88H 00H SLIDE UP 137 89H 00H SLIDE DOWN 138 8AH 00H FREEZE 158 9EH 00H FILE 159 9FH 00H PAGE 163 A3H 00H ASPECT 164 A4H 00H VIDEO3 165 A5H 00H VIDEO4 166 A6H 00H S-VIDEO3 167 A7H 00H S-VIDEO4 200 C8H 00H ZOOM 201 C9H 00H FOCUS 214 D6H 00H 3D REFORM 215 D7H 00H SOURCE (!!) 216 D8H 00H RGB(*5) 217 D9H 00H VIDEO 218 DAH 00H 3D REFORM RESET 221 DDH 00H AUTO (SHORT) 222 DEH 00H AUTO (LONG) 225 E1H 00H COMPONENT 226 E2H 00H ZOOM POS UP(HT) 227 E3H 00H ZOOM POS DOWN(HT) 228 E4H 00H DVI/DVI(DIGITAL) (*6) 229 E5H 00H LAN/Network 232 E8H 00H D ZOOM UP(WT) 233 E9H 00H D ZOOM DOWN(WT) 238 EEH 00H LAMP MODE/ECO Response: At the time of a success 22H 0FH 01H xxH 01H DATA01 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Results 00H : Normal FFH : Error Response: At the time of a failure A2H 0FH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Sending the AUTO key code 02H 0FH 00H 00H 02H 05H 00H 18H * Sending the AUTO (SHORT) key code 02H 0FH 00H 00H 02H DDH 00H F0H Supplement: (!) About AUTO key The MT series model with the built-in image sensor does not support the AUTO key. Use the AUTO (SHORT) key. (!!) About SOURCE key For P420 and P501 series only, SEQSOURCE(source select) acts as same as SOURCE (AUTO). 051. LENS MUTE ON (SHUTTER CLOSE) ********************************************************************** Function: This command closes a lens shutter and blanks the picture. Command: 02H 16H 00H 00H 00H 18H Response: At the time of a success 22H 16H 01H xxH 00H CKS (*1) (*2) (*3) Response: At the time of a failure A2H 16H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 052. LENS MUTE OFF (SHUTTER OPEN) ********************************************************************** Function: This command open a lens shutter and cancels the blank picture condition. Command: 02H 17H 00H 00H 00H 19H Response: At the time of a success 22H 17H 01H *0H 00H CKS (*1) (*2) (*3) Response: At the time of a failure A2H 17H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 053. LENS CONTROL ********************************************************************** Function: This command controls the lens. (Time specification) Command: 02H 18H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Target 00H : Zoom 01H : Focus DATA02 Contents 00H : Stops 01H : Drives for 1 second in the direction of plus 02H : Drives for 0.5 second in the direction of plus 03H : Drives for 0.25 second in the direction of plus FDH : Drives for 0.25 second in the direction of minus FEH : Drives for 0.5 second in the direction of minus FFH : Drives for 1 second in the direction of minus Response: At the time of a success 22H 18H 01H xxH 01H DATA01 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Results 00H : Normal 01H : Error Response: At the time of a failure A2H 18H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: While the lens is being driven, the same command can be issued for control purposes without causing a stop. 053-1. LENS CONTROL REQUEST ********************************************************************** Function: This command acquires the information on the lens control. Command: 02H 1CH 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Target 00H : Zoom 01H : Focus 02H : Lens Shift (H) 03H : Lens Shift (V) DATA02 00H fixed Response: At the time of a success 22H 1CH 01H xxH 08H DATA01 .. DATA08 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 same values as DATA01 of the command DATA02 same values as DATA02 of the command DATA03 Maximum adjustable range (Lower ranking 8 bits) DATA04 Maximum adjustable range (Upper ranking 8 bits) DATA05 Minimum adjustable range (Lower ranking 8 bits) DATA06 Minimum adjustable range (Upper ranking 8 bits) DATA07 Current values (Lower ranking 8 bits) DATA08 Current values (Upper ranking 8 bits) Response: At the time of a failure A2H 1CH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 053-2. LENS CONTROL 2 ********************************************************************** Function: This command controls the lens. Command: 02H 1DH 00H 00H 04H DATA01 .. DATA04 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Target 00H : Zoom 01H : Focus 02H : Lens Shift (H) 03H : Lens Shift (V) FFH : Stop (!) DATA02 Setting mode 00H : Absolute value specification 02H : Relative value specification DATA04 Adjustment value ( Lower ranking 8 bits ) DATA05 Adjustment value ( Upper ranking 8 bits ) Response: At the time of a success 22H 1DH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 same values as DATA01 of the command DATA02 same values as DATA02 of the command Response: At the time of a failure A2H 1DH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) (!) If specifying “Stop”, Setting mode and adjustment values are not referenced 053-3. LENS MEMORY CUSTOM SET ********************************************************************** Function: This command executes the "Use Custom Point" or "Set Custom Point". Command: 02H 1EH 00H 00H 01H DATA01 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Target 00H : Use Custom Point 01H : Set Custom Point Response: At the time of a success 22H 1EH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 same values as DATA01 of the command DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A2H 1EH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 053-4. LENS MEMORY REFERENCE SET ********************************************************************** Function: This command executes the "Use Reference Point" or "Set Reference Point". Command: 02H 1FH 00H 00H 01H DATA01 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Target 00H : Use Reference Point 01H : Set Reference Point 02H : Return to Factory Default( Reset ) Response: At the time of a success 22H 1FH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 same values as DATA01 of the command DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A2H 1FH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 053-5. LENS MEMORY CONTROL REQUEST ********************************************************************** Function: This command acquires the information on the lens memory function. Command: 02H 20H 00H 00H 01H DATA01 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Target 00H : Use Point on Signal Change 01H : Picture mute during lens shift Response: At the time of a success 22H 20H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 same values as DATA01 of the command DATA02 Setting Value 00H : Inactive 01H : Active Response: At the time of a failure A2H 20H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 053-6. LENS MEMORY CONTROL ********************************************************************** Function: This command controls the lens memory function. Command: 02H 21H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Target 00H : Use Point on Signal Change 01H : Picture mute during lens shift DATA02 Setting Value 00H : Inactive 01H : Active Response: At the time of a success 22H 21H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 same values as DATA01 of the command DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A2H 21H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 053-7. LENS INFORMATION REQUEST ********************************************************************** Function: This command acquires the lenz information of projector. Command: 02H 22H 00H 00H 01H DATA01 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Target 00H : Status of operation Response: At the time of a success 22H 22H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 same values as DATA01 of the command DATA02 Value Bit 7 : Reserved Bit 6 : Reserved Bit 5 : Reserved Bit 4 : Lens Shift (V) 0 : Idling 1 : During execution Bit 3 : Lens Shift (H) 0 : Idling 1 : During execution Bit 2 : Lens Focus 0 : Idling 1 : During execution Bit 1 : Lens Zoom 0 : Idling 1 : During execution Bit 0 : Lens Memory 0 : Idling 1 : During execution Response: At the time of a failure A2H 22H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 056. SLEEP TIMER REQUEST ********************************************************************** Function: This command acquires the remaining time of sleep timer. Command: 03H 92H 00H 00H 00H 95H Response: At the time of a success 23H 92H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Lower ranking 8 bits of remaining time (unit: second) (!) DATA02 Upper ranking 8 bits of remaining time (unit: second) (!) Response: At the time of a failure A3H 92H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: (!) Example of acquisition of remaining time DATA01 DATA02 Time 00H 00H : 0 Seconds = stops 08H 07H : 1800 Seconds = Remaining 30 minutes 20H 1CH : 7200 Seconds = Remaining 2 hours 057. SLEEP TIMER SET ********************************************************************** Function: This command sets sleep timer. Command: 03H 93H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Lower ranking 8 bits of setting time(unit: second)(!) DATA02 Upper ranking 8 bits of setting time(unit: second)(!) Response: At the time of a success 23H 93H 01H xxH 01H DATA01 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Results 00H : Normal 01H : Error Response: At the time of a failure A3H 93H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: * Setting the sleep timer to 30 minutes (1800 seconds) 03H 93H 00H 00H 02H 08H 07H A7H * Stopping the sleep timer 03H 93H 00H 00H 02H 00H 00H 98H 058. ONSCREEN MUTE SET ********************************************************************** Function: This command controls the mute of forced on-screen. Command: 02H 19H 00H 00H 01H DATA01 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Setting Value 00H : OFF 01H : ON Response: At the time of a success 22H 19H 01H xxH 01H DATA01 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Results 00H : Normal 01H : Error Response: At the time of a failure A2H 19H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 060. GAIN PARAMETER REQUEST 2 ********************************************************************** Function: This command acquires the adjustment values. Command: 03H 04H 00H 00H 03H DATA01 .. DATA03 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Acquirement items (!) DATA03 00H fixed Response: At the time of a success 23H 04H 01H xxH 0DH DATA01 .. DATA13 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Adjustment status 00H : Displaying impossible 01H : Adjustment impossible 02H : Adjustment possible FFH : Selected gain is not available. DATA02 Maximum adjustment value ( Lower ranking 8 bits ) DATA03 Maximum adjustment value ( Upper ranking 8 bits ) DATA04 Minimum adjustment value ( Lower ranking 8 bits ) DATA05 Minimum adjustment value ( Upper ranking 8 bits ) DATA06 Default adjustment value ( Lower ranking 8 bits ) DATA07 Default adjustment value ( Upper ranking 8 bits ) DATA08 Current value ( Lower ranking 8 bits ) DATA09 Current value ( Upper ranking 8 bits ) DATA10 .. 13 Reserved Response: At the time of a failure A3H 04H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) (!) Acquirement items +--------+--------+--------------------------------------+ | DATA01 | DATA02 | Acquirement name | +--------+--------+--------------------------------------+ | 00H | 00H | Picture / Brightness | | 01H | 00H | Picture / Contrast | | 02H | 00H | Picture / Color | | 03H | 00H | Picture / Hue | | 04H | 00H | Picture / Sharpness | | 05H | 00H | Volume | | 05H | 01H | Sound / Bass | | 05H | 02H | Sound / Treble | | 05H | 03H | Sound / Balance | | 06H | 00H | Blanking / Top | | 06H | 01H | Blanking / Bottom | | 06H | 02H | Blanking / Left | | 06H | 03H | Blanking / Right | | 06H | 04H | Blanking / On/Off | | 07H | 00H | Image / Auto Adjust | | 08H | 00H | Image / Position H | | 08H | 01H | Image / Position V | | 09H | 00H | Image / Pixel Adjust Clock | | 09H | 01H | Image / Pixel Adjust Phase | | 0AH | 00H | Image / Video Filter | | 0BH | 00H | Image / Resolution | | 0CH | 00H | Image / Amplitude H | | 0CH | 01H | Image / Amplitude V | | 0DH | 00H | Image / Input Signal Size H | | 0DH | 01H | Image / Input Signal Size V | | 0EH | 00H | Image / Output Signal Size H | | 0EH | 01H | Image / Output Signal Size V | | 0FH | 00H | Image / Output Position H | | 0FH | 01H | Image / Output Position V | | 10H | 00H | Image / Sync Protection Upper | | 10H | 01H | Image / Sync Protection Lower | | 13H | 00H | Color Temperature | | 14H | 00H | White Balance / Brightness R | | 14H | 01H | White Balance / Brightness G | | 14H | 02H | White Balance / Brightness B | | 14H | 03H | White Balance / Contrast R | | 14H | 04H | White Balance / Contrast G | | 14H | 05H | White Balance / Contrast B | | 15H | 00H | Keystone H | | 15H | 01H | Keystone V | | 16H | 00H | Video Mode Gamma | | 18H | 00H | Aspect Ratio / Input Signal | | 18H | 01H | Aspect Ratio / Display Area | | 19H | 00H | Motion Level | | 1AH | 00H | Noise Reduction / Luminance | | 1BH | 00H | Noise Reduction / Chrominance | | 1CH | 00H | Select Color Matrix | | 1DH | 00H | V-Aperture / Vertical Detail | | 21H | 00H | W/B Compress White | | 21H | 01H | W/B Compress Black / Black Expansion | | 22H | 00H | Telecine | | 23H | 00H | Y/C Delay | | 24H | 00H | Dithering | | 25H | 00H | VD Delay / Adjustment | | 25H | 01H | VD Delay / Field Invert | | 25H | 02H | VD Delay / Offset | | 26H | 00H | Motion Select | | 27H | 00H | Select Color Matrix Type | | 28H | 00H | YTR Adjustment / Gain | | 28H | 01H | YTR Adjustment / Tap | | 28H | 02H | YTR Adjustment / Gain2 | | 28H | 03H | YTR Adjustment / Tap2 | | 29H | 00H | CTR Adjustment / Gain | | 29H | 01H | CTR Adjustment / Tap | | 29H | 02H | CTR Adjustment / Gain2 | | 29H | 03H | CTR Adjustment / Tap2 | | 2AH | 00H | Sharpness Tap | | 2BH | 00H | White Correct / Position | | 2BH | 01H | White Correct / Gain | | 2CH | 00H | Black Correct / Position | | 2CH | 01H | Black Correct / Gain | | 2CH | 02H | Black Correct / Inv Gain | | 2DH | 00H | Lamp Output | | 2EH | 00H | Signal Level / Auto Control | | 2FH | 00H | Signal Level / R/G/B Gain R | | 2FH | 01H | Signal Level / R/G/B Gain G | | 2FH | 02H | Signal Level / R/G/B Gain B | | 30H | 00H | Signal Level / Y/Cb/Cr Gain Y | | 30H | 01H | Signal Level / Y/Cb/Cr Gain Cb | | 30H | 02H | Signal Level / Y/Cb/Cr Gain Cr | | 31H | 00H | Signal Level / Y/Pb/Pr Gain Y | | 31H | 01H | Signal Level / Y/Pb/Pr Gain Pb | | 31H | 02H | Signal Level / Y/Pb/Pr Gain Pr | | 33H | 00H | Clamp Timing | | 33H | 01H | Clamp Timing / Adjust | | 34H | 00H | Convergence / Red H | | 34H | 01H | Convergence / Red V | | 34H | 02H | Convergence / Green H | | 34H | 03H | Convergence / Green V | | 34H | 04H | Convergence / Blue H | | 34H | 05H | Convergence / Blue V | | 35H | 00H | Switcher Gain / R | | 35H | 01H | Switcher Gain / G | | 35H | 02H | Switcher Gain / B | | 36H | 00H | Switcher Gain / Volume | | 37H | 00H | Panel Size / H | | 37H | 01H | Panel Size / V | | 38H | 00H | Panel Position / H | | 38H | 01H | Panel Position / V | | 39H | 00H | Signal Level / White Gain | | 3AH | 00H | Ref. White Bal. / Brightness R | | 3AH | 01H | Ref. White Bal. / Brightness G | | 3AH | 02H | Ref. White Bal. / Brightness B | | 3AH | 03H | Ref. White Bal. / Contrast R | | 3AH | 04H | Ref. White Bal. / Contrast G | | 3AH | 05H | Ref. White Bal. / Contrast B | | 3BH | 00H | Overscan | | 3CH | 00H | Edge | | 3DH | 00H | Synchronize / Off/On | | 3DH | 01H | Synchronize / Adjust | | 3EH | 00H | Input Signal Position / H | | 3EH | 01H | Input Signal Position / V | | 3FH | 00H | Signal Type | | 40H | 00H | Color Correct / On/Off | | 40H | 01H | Color Correct / G-R Gain | | 40H | 02H | Color Correct / G-B Gain | | 40H | 03H | Color Correct / B-R Gain | | 40H | 04H | Color Correct / B-G Gain | | 40H | 05H | Color Correct / R-G Gain | | 40H | 06H | Color Correct / R-B Gain | | 40H | 07H | Color Correct / U Gain | | 40H | 08H | Color Correct / V Gain | | 41H | 00H | HD Delay | | 42H | 00H | Ref. Pedestal Level / U Level | | 42H | 01H | Ref. Pedestal Level / V Level | | 43H | 00H | Stack Clock | | 44H | 00H | Sub Brightness / R | | 44H | 01H | Sub Brightness / G | | 44H | 02H | Sub Brightness / B | | 45H | 00H | Y Contrast | | 46H | 00H | Y Gamma Correction | | 47H | 00H | Setup Level | | 47H | 01H | Setup Level / Adjust | | 47H | 02H | Setup Level / Correction | | 48H | 00H | DCL | | 49H | 00H | Color Space | | 4AH | 00H | RGB Sharpness | | 4BH | 00H | F-CLK Phase | | 4CH | 00H | Color Correction / Mode | | 4CH | 01H | Color Correction / Color Tune | | 4CH | 02H | Color Correction / Yellow | | 4CH | 03H | Color Correction / Magenta | | 4CH | 04H | Color Correction / Cyan | | 4CH | 05H | Color Correction / White | | 4CH | 06H | Color Correction / Color Tune | | 4CH | 07H | Color Correction / Yellow | | 4CH | 08H | Color Correction / Magenta | | 4CH | 09H | Color Correction / Cyan | | 4CH | 0AH | Color Correction / White | | 4DH | 00H | Through | | 4EH | 00H | Ref. Auto White / Color Temp R | | 4EH | 01H | Ref. Auto White / Color Temp G | | 4EH | 02H | Ref. Auto White / Color Temp B | | 4FH | 00H | Position | | 50H | 00H | Screen Position | | 51H | 00H | Sweet Vision | | 51H | 01H | Sweet Vision / Split | | 52H | 00H | Sub Color / R | | 52H | 01H | Sub Color / G | | 52H | 02H | Sub Color / B | | 53H | 00H | Picture Management | | 54H | 00H | Color Correction 2 Red | | 54H | 01H | Color Correction 2 Green | | 54H | 02H | Color Correction 2 Blue | | 54H | 03H | Color Correction 2 Yellow | | 54H | 04H | Color Correction 2 Magenta | | 54H | 05H | Color Correction 2 Cyan | | 54H | 06H | Color Correction 2 Color Gain | | 55H | 00H | Color Temperature(Enable) | | 56H | 00H | White Peaking | | 57H | 00H | 3D Y/C Separation | | 58H | 00H | Deinterlace | | 59H | 00H | Base Setting | | 5AH | 00H | Cornerstone T-Left H | | 5AH | 01H | Cornerstone T-Left V | | 5AH | 02H | Cornerstone T-Right H | | 5AH | 03H | Cornerstone T-Right V | | 5AH | 04H | Cornerstone B-Right H | | 5AH | 05H | Cornerstone B-Right V | | 5AH | 06H | Cornerstone B-Left H | | 5AH | 07H | Cornerstone B-Left V | | 5AH | 08H | Cornerstone Execute | | 5BH | 00H | Contrast Enhancement | | 5CH | 00H | Variable Y/C Delay | | 5DH | 00H | Tint Correction | | 5EH | 00H | Y Gamma | | 5FH | 00H | Ref. Color Cor. / Red | | 5FH | 01H | Ref. Color Cor. / Green | | 5FH | 02H | Ref. Color Cor. / Blue | | 5FH | 03H | Ref. Color Cor. / Yellow | | 5FH | 04H | Ref. Color Cor. / Magenta | | 5FH | 05H | Ref. Color Cor. / Cyan | | 5FH | 06H | Ref. Color Cor. / Color Gain | | 60H | 00H | Saturation | | 61H | 00H | Pincushion / Horizontal | | 61H | 01H | Pincushion / Vertical | | 61H | 02H | Pincushion / Balance | | 62H | 00H | Digital Zoom / Zoom | | 62H | 01H | Digital Zoom / Horizontal Position | | 62H | 02H | Digital Zoom / Vertical Position | | 63H | 00H | White Bal. Dual / Brightness R | | 63H | 01H | White Bal. Dual / Brightness G | | 63H | 02H | White Bal. Dual / Brightness B | | 63H | 03H | White Bal. Dual / Contrast R | | 63H | 04H | White Bal. Dual / Contrast G | | 63H | 05H | White Bal. Dual / Contrast B | | 64H | 00H | White Bal. Lamp1 / Brightness R | | 64H | 01H | White Bal. Lamp1 / Brightness G | | 64H | 02H | White Bal. Lamp1 / Brightness B | | 64H | 03H | White Bal. Lamp1 / Contrast R | | 64H | 04H | White Bal. Lamp1 / Contrast G | | 64H | 05H | White Bal. Lamp1 / Contrast B | | 65H | 00H | White Bal. Lamp2 / Brightness R | | 65H | 01H | White Bal. Lamp2 / Brightness G | | 65H | 02H | White Bal. Lamp2 / Brightness B | | 65H | 03H | White Bal. Lamp2 / Contrast R | | 65H | 04H | White Bal. Lamp2 / Contrast G | | 65H | 05H | White Bal. Lamp2 / Contrast B | | 66H | 00H | Color Cor. Dual / Red | | 66H | 01H | Color Cor. Dual / Green | | 66H | 02H | Color Cor. Dual / Blue | | 66H | 03H | Color Cor. Dual / Yellow | | 66H | 04H | Color Cor. Dual / Magenta | | 66H | 05H | Color Cor. Dual / Cyan | | 66H | 06H | Color Cor. Dual / Color Gain | | 67H | 00H | Color Cor. Lamp1 / Red | | 67H | 01H | Color Cor. Lamp1 / Green | | 67H | 02H | Color Cor. Lamp1 / Blue | | 67H | 03H | Color Cor. Lamp1 / Yellow | | 67H | 04H | Color Cor. Lamp1 / Magenta | | 67H | 05H | Color Cor. Lamp1 / Cyan | | 67H | 06H | Color Cor. Lamp1 / Color Gain | | 68H | 00H | Color Cor. Lamp2 / Red | | 68H | 01H | Color Cor. Lamp2 / Green | | 68H | 02H | Color Cor. Lamp2 / Blue | | 68H | 03H | Color Cor. Lamp2 / Yellow | | 68H | 04H | Color Cor. Lamp2 / Magenta | | 68H | 05H | Color Cor. Lamp2 / Cyan | | 68H | 06H | Color Cor. Lamp2 / Color Gain | | 90H | 00H | Picture Preset | | 91H | 00H | SweetVision Mode (!) | | 92H | 00H | SweetVision Level (!) | | 94H | 00H | Vertical Enhancer | | 95H | 00H | I/P Converter | | 96H | 00H | Lamp Mode Adjust | | 97H | 00H | Wall Color | | 9CH | 00H | Picture Mode | | 9FH | 00H | Dynamic Contrast | +--------+--------+--------------------------------------+ Command example: * In case of acquiring Picture Brightness 03H 04H 00H 00H 03H 00H 00H 00H 0AH (!) On the NP1000/2000, "SweetVision" has been changed to "Contrast Enhancement". 061. LAMP COOLING TIME REQUEST ********************************************************************** Function: This command acquires lamp cooling time. Command: 03H 8DH 00H 00H 00H 90H Response: At the time of a success 23H 8DH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Lower ranking 8 bits of cooling time(unit: second) (!) DATA02 Upper ranking 8 bits of cooling time(unit: second) (!) Response: At the time of a failure A3H 8DH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: (!) Example of acquisition of cooling time DATA01 DATA02 Time 3CH 00H : 60 Second 066. FACTORY DEFAULT SET 2 ********************************************************************** Function: This command uses to return the projector's setting values to the factory preset. Command: 03H 33H 00H 00H 02H DATA01 00H CKS (*3) Data Portion Contents ----------------------------------------------------------------- DATA01 Setting Contents 00H : All data ( No Including Entry List ) 01H : Current signal 02H : All data ( Including Entry list ) Response: At the time of a success 23H 33H 01H xxH 01H DATA01 CKS (*1) (*2) (*3) Data Portion Contents ----------------------------------------------------------------- DATA01 Results 00H : Normal 01H : Error Response: At the time of a failure A3H 33H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 077. MUTE CONTROL ********************************************************************** Function: This command controls the mute of picture, sound and on-screen. Command: 02H 1AH 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Setting items 00H : Image 01H : Sound 02H : On-Screen DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 22H 1AH 01H xxH 01H DATA01 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Results 00H : Normal 01H : Error Response: At the time of a failure A2H 1AH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: * Sound mute is cancelled in the following cases: Input connector switching Video signal switching Volume adjustment 078-1. SETTING REQUEST ********************************************************************** Function: This command acquires the function information of projector. Command: 00H 85H 00H 00H 01H 00H 86H Response: At the time of a success 20H 85H 01H xxH 20H DATA01 .. DATA32 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 03 Projector type +--------+--------+--------+-----------------+ | DATA01 | DATA02 | DATA03 | | +--------+--------+--------+-----------------+ | 01H | 00H | 03H | MT1060/1065 | | 01H | 01H | 03H | MT860 | | 01H | 02H | 03H | MT1075 | | 01H | 00H | 06H | NP1000/2000 | | 02H | 00H | 03H | LT240/260 | | 02H | 01H | 03H | LT220 | | 02H | 02H | 03H | LT240K/260K | | 02H | 00H | 05H | LT245/265 | | 02H | 00H | 06H | LT380 | | 02H | 01H | 06H | LT280 | | 04H | 00H | 03H | GT5000 | | 04H | 01H | 03H | GT6000 | | 05H | 00H | 03H | HT1000 | | 06H | 00H | 03H | WT600 | | 06H | 00H | 05H | WT610/615 | | 10H | 00H | 08H | VT700 Series | | 12H | 00H | 08H | NP3150/2150/1150| | 12H | 01H | 08H | NP3151W | | 12H | 00H | 09H | NP905 | | 12H | 01H | 09H | NP901W | | 12H | 02H | 09H | VT800 | | 12H | 00H | 10H | NP3250/2250/1250| | 12H | 01H | 10H | NP3250W | | 13H | 00H | 11H | NP-P420X | | 13H | 01H | 11H | NP-P350X | | 13H | 02H | 11H | NP-P350W | | 15H | 00H | 10H | NP-PA600X | | 15H | 01H | 10H | NP-PA500X | | 15H | 02H | 10H | NP-PA550W | | 15H | 03H | 10H | NP-PA500U | | 17H | 00H | 10H | NP-PX750U | | 20H | 00H | 10H | NP-P501X | | 20H | 01H | 10H | NP-P451X | | 20H | 02H | 10H | NP-P451W | | 20H | 03H | 10H | NP-P401W | | 20H | 04H | 10H | NP-PE501X | | 21H | 00H | 10H | NP-PA621U | | 21H | 01H | 10H | NP-PA521U | | 21H | 02H | 10H | NP-PA671W | | 21H | 03H | 10H | NP-PA571W | | 21H | 04H | 10H | NP-PA721X | | 21H | 05H | 10H | NP-PA621X | | 21H | 00H | 11H | NP-PA622U | | 21H | 01H | 11H | NP-PA522U | | 21H | 02H | 11H | NP-PA672W | | 21H | 03H | 11H | NP-PA572W | | 21H | 04H | 11H | NP-PA722X | | 21H | 05H | 11H | NP-PA622X | | 25H | 00H | 10H | NP-PX602UL | | 25H | 01H | 10H | NP-PX602WL | | 26H | 00H | 10H | NP-PH1202HL | | 26H | 01H | 10H | NP-PH1002HL | +--------+--------+--------+-----------------+ DATA04 Sound function 00H : Not available 01H : Available DATA05 Calendar function 00H : No function 01H or 03H : Timer function, sleep timer function 02H : Sleep timer function DATA06 .. 32 Reserved Response: At the time of a failure A0H 85H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 078-2. RUNNING STATUS REQUEST ********************************************************************** Function: This command acquires the status of the projector operation. Command: 00H 85H 00H 00H 01H 01H 87H Response: At the time of a success 20H 85H 01H xxH 10H DATA01 .. DATA16 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Reserved DATA03 Projector status 00H : Idling 01H : Power On DATA04 Cooling processing 00H : No execution(Normal condition) 01H : During execution DATA05 Power On/Off processing 00H : No execution(Normal condition) 01H : During execution DATA06 Status of operation 00H : Idling 04H : Power On 05H : Cooling 06H : Idling(Error occurrence) Other than above : (nondisclosure) internal use of code during a state transition period DATA07 PC Card insertion 00H : Not inserted 01H : Inserted DATA08 USB Mouse connection 00H : Not connected 01H : Connected DATA09 .. 16 Reserved Response: At the time of a failure A0H 85H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 078-3. INPUT STATUS REQUEST ********************************************************************** Function: This command acquires the status of input signal of the projector. Command: 00H 85H 00H 00H 01H 02H 88H Response: At the time of a success 20H 85H 01H xxH 10H DATA01 .. DATA16 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Selecting signal processing 00H : No execution(Normal condition) 01H : During execution DATA02 Signal number( Entry list number - 1 ) 0 .. 199 DATA03 .. 04 Selected input terminal +-------------------+--------+--------+ | Terminal name | DATA03 | DATA04 | +-------------------+--------+--------+ | RGB1(RGB)(*5) | 01H | 01H | | RGB2(*5) | 02H | 01H | | RGB3(*5) | 03H | 01H | | Video | 01H | 02H | | S-Video | 01H | 03H | | Component | 01H | 04H | | Component | 02H | 04H | | Component | 03H | 04H | | DVI (*6) | 01H | 06H | | DVI(DIGITAL) (*6) | 01H | 06H | | HDMI | 01H | 06H | | DisplayPort | 02H | 06H | | HDMI2 | 02H | 06H | | SLOT | 03H | 06H | | Viewer | 01H | 07H | | LAN / Network | 02H | 07H | | USB Display | 04H | 07H | | Slot1-1 | 01H | 08H | | Slot1-2 | 02H | 08H | | Slot2-1 | 01H | 09H | | Slot2-2 | 02H | 09H | | RGB(Video) | 02H | 02H | | RGB(S-Video) | 02H | 03H | +-------------------+--------+--------+ DATA05 Entry list type 01H : Default 02H : User DATA06 Test pattern display 00H : No display(Normal condition) 01H : Displaying DATA07 ..08 Reserved DATA09 Indicate Contents 00H = Picture signal displaying 01H = No signal 02H = Viewer displaying 03H = Test pattern displaying 04H = LAN displaying DATA10 .. 16 Reserved Response: At the time of a failure A0H 85H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 078-4. MUTE STATUS REQUEST ********************************************************************** Function: This command acquires the status of the mute of projector. Command: 00H 85H 00H 00H 01H 03H 89H Response: At the time of a success 20H 85H 01H xxH 10H DATA01 .. DATA16 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Picture mute 00H : OFF 01H : ON DATA02 Sound mute 00H : OFF 01H : ON DATA03 On-screen mute 00H : OFF 01H : ON DATA04 Forced on-screen mute 00H : OFF 01H : ON DATA05 On-screen display 00H : No display 01H : Displaying DATA06 .. 16 Reserved Response: At the time of a failure A0H 85H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 078-5. MODEL NAME REQUEST ********************************************************************** Function: This command acquires the model name of the projector. Command: 00H 85H 00H 00H 01H 04H 8AH Response: At the time of a success 20H 85H 01H xxH 20H DATA01 .. DATA32 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 32 Model name (NULL termination character string) Response: At the time of a failure A0H 85H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 078-6. COVER STATUS REQUEST ********************************************************************** Function: This command acquires the status of lens cover of the projector. Command: 00H 85H 00H 00H 01H 05H 8BH Response: At the time of a success 20H 85H 01H xxH 01H DATA01 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Lens cover 00H : Normal 01H : Cover Close Response: At the time of a failure A0H 85H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 079. CAPTURE CONTROL ********************************************************************** Function: This command controls the Capture feature. Command: 01H 98H 00H 00H 01H DATA01 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Target 00H : Capture (!) 01H : Freeze ON 02H : Freeze OFF Response: At the time of a success 21H 98H 01H xxH 01H DATA01 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Results 00H : Normal 01H : Error Response: At the time of a failure A1H 98H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) (!) LT280/380, NP1000/2000 : This function is not supported. 084. INFORMATION STRING REQUEST ********************************************************************** Function: This command acquires information item name and the current value with character string ( English ). Command: 00H D0H 00H 00H 03H DATA01 DATA02 CKS (*3) Data Portion Contents ----------------------------------------------------------------- DATA01 Information type number Information type Number Description ---------------------------------------------------- 0 (00H) Source Name 1 (01H) Input Terminal 2 (02H) Entry No. 3 (03H) Horizontal Frequency 4 (04H) Vertical Frequency 5 (05H) Sync Polarity 6 (06H) Signal Type 7 (07H) Video Type 8 (08H) Sync Type 9 (09H) Interlace 10 (0AH) User Name 11 (0BH) Serial Number 12 (0CH) Remaining Lamp Time (%) 13 (0DH) Lamp Hour Meter 14 (0EH) Filter Usage 15 (0FH) Projector Usage 16 (10H) Panel Usage 17 (11H) Projector ID 19 (13H) BIOS Version 20 (14H) Firmware Version 21 (15H) Data Version DATA02 Selection for character string to be acquired 00H : Item name 01H : Value Response: At the time of a success 20H D0H 01H xxH ??H DATA01 .. DATA?? CKS (*1) (*2) (*3) Data Portion Contents ----------------------------------------------------------------- DATA01 Same as DATA01 of the transmit data DATA02 Same as DATA02 of the transmit data DATA03 String length of item name / value ( not including NULL character ) DATA04 .. DATAxx Character string of item name / value ( NULL termination character string ) Response: At the time of a failure A0H D0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 091. DIGITAL ZOOM REQUEST ********************************************************************** Function: This command acquires the digital zoom( Magnify ) information. Command: 03H 20H 00H 00H 00H 23H Response: At the time of a success 23H 20H 01H xxH 20H DATA01 .. DATA32 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 .. 02 Digital Zoom adjustment value (short type) (!) DATA03 .. 04 Maximum value of Digital Zoom adjustment range (short type) (!) DATA05 .. 06 Minimum value of Digital Zoom adjustment range (short type) (!) DATA07 .. 08 X coordinates of mouse cursor display position (short type) (!) DATA09 .. 10 Y coordinates of mouse cursor display position (short type) (!) DATA11 .. 12 Upper left X coordinates of mouse cursor display range (short type) (!) DATA13 .. 14 Upper right Y coordinates of mouse cursor display range (short type) (!) DATA15 .. 16 Lower right X coordinates of mouse cursor display range (short type) (!) DATA17 .. 18 Lower right Y coordinates of mouse cursor display range (short type) (!) DATA19 Mouse cursor display (!) 00H : Not displayed 01H : Displayed DATA20 .. 32 Reserved Response: At the time of a failure A3H 20H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: (!) Example of acquisition at time of XGA (1024x768) signal projection DATA01 DATA02 : Digital Zoom adjustment value 00H 00H : 0 DATA03 DATA04 : Maximum value of Digital Zoom adjustment range 3FH 00H : 63 DATA05 DATA06 : Minimum value of Digital Zoom adjustment range 00H 00H : 0 DATA07 DATA08 : X coordinates of mouse cursor display position FFH 01H : 511 DATA09 DATA10 : Y coordinates of mouse cursor display position 7FH 01H : 383 DATA11 DATA12 : Upper left X coordinates of mouse cursor display range 00H 00H : 0 DATA13 DATA14 : Upper left Y coordinates of mouse cursor display range 00H 00H : 0 DATA15 DATA16 : Lower right X coordinates of mouse cursor display range FFH 03H : 1023 DATA17 DATA18 : Lower right Y coordinates of mouse cursor display range FFH 03H : 767 DATA19 : Mouse cursor display 00H : Not displayed DATA20..DATA32 : Reserved 092-1. DIGITAL ZOOM MOUSE SET ********************************************************************** Function: This command sets the mouse cursor display position for Digital Zoom. Command: 03H 21H 00H 00H 06H DATA01 .. DATA06 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 00H fixed DATA02 Setting mode 00H : Absolute value specification 01H : Relative value specification DATA03 .. 04 X coordinates of mouse cursor display position (short type) DATA05 .. 06 Y coordinates of mouse cursor display position (short type) Response: At the time of a success 23H 21H 01H xxH 05H DATA01 .. DATA05 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 00H fixed DATA02 .. 03 Results( coordinate X ) 0000H : Normal 0000H Other : Error DATA04 .. 05 Results( coordinate Y ) 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 21H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 092-2. DIGITAL ZOOM DATA SET ********************************************************************** Function: This command sets digital zoom. Command: 03H 21H 00H 00H 04H DATA01 .. DATA04 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 01H fixed DATA02 Setting mode 00H : Absolute value specification 01H : Relative value specification DATA03 Setting Value ( Lower ranking 8 bits ) DATA04 Setting Value ( Upper ranking 8 bits ) Response: At the time of a success 23H 21H 01H xxH 03H DATA01 .. DATA03 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 01H fixed DATA02 .. 03 Results 0000H : Normal 0000H Other : Error Response: At the time of a failure A3H 21H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 092-3. DIGITAL ZOOM MOUSE CONTROL ********************************************************************** Function: This command switches on/off the mouse cursor display for Digital Zoom. Command: 03H 21H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 02H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H 21H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 02H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H 21H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-1. MENU MODE REQUEST ********************************************************************** Function: This command acquires the Menu Mode of the projector. Command: 03H B0H 00H 00H 01H 00H B4H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 00H fixed DATA02 Setting Value 00H : Advanced Menu 01H : Basic Menu 02H : Custom Menu Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-2. LANGUAGE REQUEST ********************************************************************** Function: This command acquires the Language of the projector. Command: 03H B0H 00H 00H 01H 01H B5H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 01H fixed DATA02 Setting Value 00H : English 01H : Japanese 02H : German 03H : French 04H : Italian 05H : Spanish 06H : Swedish 07H : Chinese 08H : Finnish 09H : Norwegian 0AH : Dutch 0BH : Turkish 0CH : Polish 0DH : Russian 0EH : Greek 0FH : Korean 10H : Hungarian 11H : Portuguese 12H : Czech 13H : Arabic 14H : Danish 15H : Romanian 16H : Croatian 17H : Bulgarian 18H : Indonesian 19H : Hindi 1AH : Thai 1BH : Chinese(Traditional) 1CH : Uyghur Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-3. MENU COLOR SELECT REQUEST ********************************************************************** Function: This command acquires Menu Color Select of the projector. Command: 03H B0H 00H 00H 01H 02H B6H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 02H fixed DATA02 Setting Value 00H : Color 01H : Monochrome Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-4. PROJECTOR POINTER REQUEST ********************************************************************** Function: This command acquires the Projector Pointer of the projector. Command: 03H B0H 00H 00H 01H 03H B7H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 03H fixed DATA02 Setting Value 00H : Pointer1 01H : Pointer2 02H : Pointer3 03H : Pointer4 04H : Pointer5 05H : Pointer6 06H : Pointer7 07H : Pointer8 08H : Pointer9 Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-5. DISPLAY TIME REQUEST ********************************************************************** Function: This command acquires the Display Time of the projector. Command: 03H B0H 00H 00H 01H 04H B8H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 04H fixed DATA02 Setting Value 00H : Manual 01H : Auto 5 sec 02H : Auto 15 sec 03H : Auto 45 sec Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-6. SOURCE DISPLAY REQUEST ********************************************************************** Function: This command acquires the Source Display of the projector. Command: 03H B0H 00H 00H 01H 05H B9H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 05H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-7. MESSAGE REQUEST ********************************************************************** Function: This command acquires the setting of the message of projector. Command: 03H B0H 00H 00H 01H 06H BAH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 06H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-8. LAMP MODE REQUEST ********************************************************************** Function: This command acquires the setting of the lamp mode of projector. Command: 03H B0H 00H 00H 01H 07H BBH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 07H fixed DATA02 Setting Value +----------+----------------+---------+---------------+ | 設定値 | GT/HT/LT/LT80/ | P420 | P501 | | | MT/WT/VT/NP | | | +----------+----------------+---------+---------------+ | 00H | Normal | Off | Off | | 01H | Eco | Auto | Auto Eco | | 02H | - | Eco1 | Normal(Eco1) | | 03H | - | - | Eco(Eco2) | +----------+----------------+---------+---------------+ Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-9. IDLE MODE REQUEST ********************************************************************** Function: This command acquires the setting of the idle mode of projector. Command: 03H B0H 00H 00H 01H 08H BCH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 08H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-10. CLOSED CAPTION REQUEST ********************************************************************** Function: This command acquires the setting of the closed caption of projector. Command: 03H B0H 00H 00H 01H 09H BDH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 09H fixed DATA02 Setting Value 00H : OFF 01H : Caption 1 02H : Caption 2 03H : Caption 3 04H : Caption 4 05H : Text 1 06H : Text 2 07H : Text 3 08H : Text 4 Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-11. ORIENTATION REQUEST ********************************************************************** Function: This command acquires the setting of the orientation of projector. Command: 03H B0H 00H 00H 01H 0AH BEH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0AH fixed DATA02 Setting Value 00H : Desktop Front 01H : Ceiling Rear 02H : Desktop Rear 03H : Ceiling Front Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-12. BACKGROUND REQUEST ********************************************************************** Function: This command acquires the setting of the background of projector. Command: 03H B0H 00H 00H 01H 0BH BFH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0BH fixed DATA02 Setting Value 00H : Blue 01H : Black 02H : Logo Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-13. SCREEN TYPE REQUEST ********************************************************************** Function: This command acquires the setting of the screen type of projector. Command: 03H B0H 00H 00H 01H 0CH C0H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0CH fixed DATA02 Setting Value 00H : 4:3 Screen / 1.25:1(5:4) Screen 01H : 16:9 Screen / 1.33:1(4:3) Screen 02H : 1.78:1(16:9) Screen / Anamorphic / 16:10 Screen 03H : 1.85:1 Screen 04H : 2.35:1 Screen Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-14. SCREEN TRIGGER REQUEST ********************************************************************** Function: This command acquires the setting of the screen trigger of projector. Command: 03H B0H 00H 00H 01H 0DH C1H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0DH fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-15. VIEWER START MODE REQUEST ********************************************************************** Function: This command acquires the setting of the viewer start mode of projector. Command: 03H B0H 00H 00H 01H 0EH C2H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0EH fixed DATA02 Setting Value 00H : OFF 01H : Show Folder List Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-16. VIEWER MODE REQUEST ********************************************************************** Function: This command acquires the setting of the viewer play mode of projector. Command: 03H B0H 00H 00H 01H 0FH C3H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0FH fixed DATA02 Setting Value 00H : Auto Play 01H : Manual Play Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-17. VIEWER INTERVAL REQUEST ********************************************************************** Function: This command acquires the setting of the viewer play interval of projector. Command: 03H B0H 00H 00H 01H 10H C4H Response: At the time of a success 23H B0H 01H xxH 03H DATA01 .. DATA03 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 10H fixed DATA02 Lower ranking 8 bits of interval time(unit:second)(!) DATA03 Upper ranking 8 bits of interval time(unit:second)(!) Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Supplement: (!) Example of the acquisition of the interval time. DATA02 DATA03 Time 3CH 00H : 60 Second 097-18. CAPTURE OPTIONS REQUEST ********************************************************************** Function: This command acquires the setting of the capture options of projector. Command: 03H B0H 00H 00H 01H 11H C5H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 11H fixed DATA02 Setting Value 00H : High Quality 01H : Normal 02H : High Compress Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-19. MOUSE BUTTON REQUEST ********************************************************************** Function: This command acquires the setting of the mouse button of projector. Command: 03H B0H 00H 00H 01H 12H C6H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 12H fixed DATA02 Setting Value 00H : Right Hand 01H : Left Hand Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-20. MOUSE SENSITIVITY REQUEST ********************************************************************** Function: This command acquires the setting of the mouse sensitivity of projector. Command: 03H B0H 00H 00H 01H 13H C7H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 13H fixed DATA02 Setting Value 00H : Fast 01H : Medium 02H : Slow Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-21. SIGNAL SELECT REQUEST ********************************************************************** Function: This command acquires the setting of the signal select of projector. Command: 03H B0H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 14H fixed DATA02 Acquisition Object 00H : RGB / RGB1(*5) 01H : RGB2(*5) 02H : VIDEO 03H : S-VIDEO 04H : RGB1(VIDEO) 05H : RGB1(S-VIDEO) Response: At the time of a success 23H B0H 01H xxH 03H DATA01 .. DATA03 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 14H fixed DATA02 acquired item (same as DATA02 of the command) DATA03 Acquisition Object When the acquired items are RGB/RGB1(00H)/RGB2(01H) (*5) 00H : RGB/Component 01H : RGB 02H : Component 03H : Scart When the acquired items are other than RGB/RGB1(00H)/RGB2(01H) (*5) 00H : Auto 01H : NTSC3.58 02H : NTSC4.43 03H : PAL 04H : PAL60 05H : SECAM 06H : PAL-M 07H : PAL-N 08H : PAL-M/PAL-N/NTSC3.58 Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-23. AUTO START REQUEST ********************************************************************** Function: This command acquires the setting of the auto start of projector. Command: 03H B0H 00H 00H 01H 16H CAH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 16H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-24. POWER MANAGEMENT REQUEST ********************************************************************** Function: This command acquires the setting of the power management of projector. Command: 03H B0H 00H 00H 01H 17H CBH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 17H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-25. POWER CONFIRMATION REQUEST ********************************************************************** Function: This command acquires the setting of the power off confirmation of projector. Command: 03H B0H 00H 00H 01H 18H CCH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 18H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-26. KEYSTONE SAVE REQUEST ********************************************************************** Function: This command acquires the setting of the keystone save of projector. Command: 03H B0H 00H 00H 01H 19H CDH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 19H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-27. FAN MODE REQUEST ********************************************************************** Function: This command acquires the setting of the fan mode of projector. Command: 03H B0H 00H 00H 01H 1AH CEH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1AH fixed DATA02 Setting Value 00H : AUTO 01H : HIGH SPEED 02H : HIGH ALTITUDE Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-28. BUILT IN SPEAKER REQUEST ********************************************************************** Function: This command acquires the setting of the built in speaker of projector. Command: 03H B0H 00H 00H 01H 1BH CFH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1BH fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-29. REMOTE SENSOR REQUEST ********************************************************************** Function: This command acquires the setting of the remote sensor of projector. Command: 03H B0H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1CH fixed DATA02 Acquisition Object 00H : Front 01H : Back 02H : Right 03H : Left Response: At the time of a success 23H B0H 01H xxH 03H DATA01 .. DATA03 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1CH fixed DATA02 Acquisition item(Same as DATA02 of the transmit data) DATA03 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-30. PANEL KEY LOCK REQUEST ********************************************************************** Function: This command acquires the setting of the control panel key lock of projector. Command: 03H B0H 00H 00H 01H 1DH D1H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1DH fixed DATA02 Setting Value 00H : Disable 01H : Enable Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-31. S-VIDEO SELECT REQUEST ********************************************************************** Function: This command acquires the setting of the s-video mode select of projector. Command: 03H B0H 00H 00H 01H 1EH D2H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1EH fixed DATA02 Setting Value 00H : OFF 02H : S2 Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-32. COMMUNICATION REQUEST ********************************************************************** Function: This command acquires the setting of the communication speed of projector. Command: 03H B0H 00H 00H 01H 1FH D3H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1FH fixed DATA02 Setting Value 00H : 4800bps 01H : 9600bps 02H : 19200bps 03H : 38400bps Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-33. DEFAULT SOURCE REQUEST ********************************************************************** Function: This command acquires the setting of the default source select of projector. Command: 03H B0H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 20H fixed DATA02 Acquisition Object 00H : Select 01H : Source Response: At the time of a success 23H B0H 01H xxH 03H DATA01 .. DATA03 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 20H fixed DATA02 .. 03 Setting Value +--------+--------+---------------------------------------------------------+ | DATA02 | DATA03 | Setting Value | +--------+--------+---------------------------------------------------------+ | 00H | 00H | Last | | 00H | 01H | Auto | | 00H | 02H | Select | | 01H | 00H | RGB1 (MT/LT/LT80/GT/VT/NP/NP905/P420/PA600/PX750)(*5) | | | | Video (HT) | | | | RGB (WT) | | | | HDMI1 (P501/PA622/PX602/PH1202) | | 01H | 01H | RGB2 (MT/LT/LT80/GT/VT/NP/NP905/P420/PA600/PX750)(*5) | | | | S-Video (HT) | | | | DVI(DIGITAL) (WT) (*6) | | | | HDMI1 (P501) | | | | HDMI2(PA622) | | | | DisplayPort(PX602/PH1202) | | 01H | 02H | Video (MT/LT) | | | | Component (HT/VT) | | | | DVI(DIGITAL) (GT/LT80/NP) (*6) |(!) | | | DVI(ANALOG) (WT) (*6) | | | | HDMI (NP905/P420) | | | | RGB3 (PA600/PX750) | | | | HDMI2 (P501) | | | | DisplayPort(PA622) | | | | RGB2 (PX602/PH1202)(*5) | | 01H | 03H | S-Video (MT/LT) | | | | RGB (HT) (*5) | | | | Component (LT80/NP) | | | | Video (GT/WT/VT/NP905/P420/P501/PX602/PH1202) | | | | HDMI (PA600/PX750) | | | | RGB2 (PA622)(*5) | | 01H | 04H | DVI (MT/HT) (*6) |(!) | | | Video (LT80/NP/PA622) | | | | Viewer (LT) | | | | S-Video (GT/WT/VT/NP905/P420/P501/PX602/PH1202) | | | | DisplayPort (PA600/PX750) | | 01H | 05H | Viewer (MT/HT/GT/WT/VT/NP905/P420/P501) |(!!) | | | S-Video (LT80/NP/PA622) | | | | LAN (LT) | | | | Video (PA600/PX750) | | | | RGB1 (PX602/PH1202)(*5) | | 01H | 06H | LAN / Network (PX602/PH1202) |(!!) | | | Viewer (LT80/NP) | | | | S-Video (PA600/PX750) | | | | RGB1 (PA622)(*5) | | 01H | 07H | Slot1-1(PX602/PH1202) | | | | LAN (LT80/NP/PA622) | | | | USB Display (P420) | | | | Viewer (PA600/PX750) | | 01H | 08H | Slot1-2 | | | | LAN (PA600/PX750) | | | | USB-A (PA622) | | | | SLOT (PX750) | | 01H | 0AH | Slot2-2 | | 01H | 0BH | RGB1(Video) | | 01H | 0CH | RGB1(S-Video) | +--------+--------+---------------------------------------------------------+ (!) : The MT860 and LT280 does not support a DVI connector. (!!): The PE501X does not support a Viewer and a LAN/Network connector. Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-34. PJ ID ENABLE REQUEST ********************************************************************** Function: This command acquires the setting of the projector id enable of projector. Command: 03H B0H 00H 00H 01H 21H D5H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 21H fixed DATA02 Setting Value 00H : Disable 01H : Enable Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-35. PJ ID REQUEST ********************************************************************** Function: This command acquires the setting of the projector id of projector. Command: 03H B0H 00H 00H 01H 22H D6H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 22H fixed DATA02 Setting Value Projector ID ( 1 .. 254 ) Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-38. MENU PASSCODE REQUEST ********************************************************************** Function: This command acquires the Menu Passcode registration condition of the projector. Command: 03H B0H 00H 00H 01H 25H D9H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 25H fixed DATA02 Setting Value 00H : No registration 01H : Registration Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-39. TEST PATTERN REQUEST ********************************************************************** Function: This command acquires the setting of the test pattern of projector. Command: 03H B0H 00H 00H 01H 26H DAH Response: At the time of a success 23H B0H 01H xxH 04H DATA01 .. DATA04 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 26H fixed DATA02 .. 03 Test pattern ID +-----------------+-----------------+----+----+----+----+----+----+----+----+----+----+----+----+----+ | Pattern ID | | | | | | | | | | | | | | | +--------+--------| Pattern Name | MT | LT |LT80| HT | GT | WT | VT | NP | NP | NP | NP |P420|P501| | DATA02 | DATA03 | | | | | | | | |2000|3150|905 |3250| | | +--------+--------+-----------------+----+----+----+----+----+----+----+----+----+----+----+----+----+ | 02H | 00H | Cross Hatch | - | * | - | * | - | - | - | - | * | * | * | * | * | | 03H | 00H | Gray Bars | * | * | * | * | * | * | * | * | * | * | * | * | * | | 04H | 00H | Raster(0%) | * | * | * | * | * | * | * | * | * | * | * | * | * | | 05H | 00H | Raster(25%) | * | * | * | * | * | * | * | * | * | * | * | * | * | | 06H | 00H | Raster(50%) | * | * | * | * | * | * | * | * | * | * | * | * | * | | 07H | 00H | Raster(100%) | * | * | * | * | * | * | * | * | * | * | * | * | * | | 08H | 00H | Focus | * | * | * | * | * | * | * | * | - | - | - | - | - | | 09H | 00H | Raster Blue | * | - | * | - | * | - | * | * | * | * | * | * | * | | 0AH | 00H | Gray Raster 30 | * | * | * | * | * | * | * | * | * | * | * | * | * | | 17H | 00H | Gray Raster 10 | * | * | * | * | * | * | * | * | * | * | * | * | * | | 18H | 00H | RAMP WBGR | - | * | - | * | - | * | - | - | - | - | - | - | - | | 19H | 00H | Blue Raster 60 | - | * | - | * | - | * | - | - | - | - | - | * | * | | 1DH | 00H | Cross Hatch 3 | * | *1 | * | - | * | * | * | * | - | - | - | - | - | +--------+--------+-----------------+----+----+----+----+----+----+----+----+----+----+----+----+----+ [NP-PA600X/500X/550W/500U] [NP-PX750U] [NP-PA721X/PA621X/PA671W/PA571W/PA621W/PA521U/PA722X/PA622X/PA672W/PA572W/PA622W/PA522U] [NP-PX602UL/PX602WL] [NP-PH1202HL/PH1002HL] +-----------------+-----------------+----+----+----+----+----+ | Pattern ID | |PA |PX |PA |PX |PH | +--------+--------| Pattern Name |600 |750 |622 |602 |1202| | DATA02 | DATA03 | | | | | | | +--------+--------+-----------------+----+----+----+----+----+ | 01H | 00H | Cross Hatch | * | * | * | * | * | | 02H | 00H | Gray Bars | * | * | * | - | - | | 03H | 00H | Raster(0%) | * | * | * | * | * | | 04H | 00H | Raster(25%) | * | * | * | * | * | | 05H | 00H | Raster(50%) | * | * | * | * | * | | 06H | 00H | Raster(100%) | * | * | * | * | * | | 07H | 00H | Color Bar | * | * | * | * | * | | 18H | 00H | Gray Bars | - | - | - | * | * | +--------+--------+-----------------+----+----+----+----+----+ * : Supported - : Not supported *1: Only LT240K/260K DATA04 Pattern On/Off FFH : No display(Normal condition) FFH Other : Displaying +-----+-----------------+ | | R G B | +-----+-----------------+ | 00H | Off Off Off | | 01H | On Off Off | | 02H | Off On Off | | 03H | On On Off | | 04H | Off Off On | | 05H | On Off On | | 06H | Off On On | | 07H | On On On | +-----+-----------------+ Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-40. COLOR UNIFORMITY REQUEST ********************************************************************** Function: This command acquires the setting of the color uniformity of projector. Command: 03H B0H 00H 00H 01H 27H DBH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 27H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-41. AUTO FUNCTIONS REQUEST ********************************************************************** Function: This command acquires the setting of the auto functions of projector. Command: 03H B0H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 28H fixed DATA02 Acquisition Object 00H : Focus 01H : Wall Color Correction Response: At the time of a success 23H B0H 01H xxH 03H DATA01 .. DATA03 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 28H fixed DATA02 Acquisition item(Same as DATA02 of the transmit data) DATA03 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-72. LOGO PASSCODE REQUEST ********************************************************************** Function: This command acquires the Logo Passcode registration condition of the projector. Command: 03H B0H 00H 00H 01H 47H FBH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 47H fixed DATA02 Setting Value 00H : No registration 01H : Registration Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-73. RGBOUT TERMINAL REQUEST ********************************************************************** Function: This command acquires the setting of the rgbout terminal of projector. Command: 03H B0H 00H 00H 01H 48H FCH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 48H fixed DATA02 Setting Value 00H : Last 01H : RGB1 / RGB (*5) 02H : RGB2 / DVI(ANALOG) (*5) (*6) Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-74. MOUSE MODE REQUEST ********************************************************************** Function: This command acquires the setting of the mouse operation mode select of projector. Command: 03H B0H 00H 00H 01H 49H FDH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 49H fixed DATA02 Setting Value 00H : Auto 01H : Projector Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-75. MULTI DISPLAY REQUEST ********************************************************************** Function: This command acquires the setting of the Multi Display of projector. Command: 03H B0H 00H 00H 01H 4AH FEH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 4AH fixed DATA02 Setting Value 00H : Off 01H : Up Left 02H : Up Right 03H : Down Left 04H : Down Right Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-76. MOTORIZED LENS REQUEST ********************************************************************** Function: This command acquires the setting of the Motorized Lens of projector. Command: 03H B0H 00H 00H 01H 4BH FFH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 4BH fixed DATA01 Setting Value 00H : Off 01H : On Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-77. LAMP TYPE REQUEST ********************************************************************** Function: This command acquires the status of lamp type of projector. Command: 03H B0H 00H 00H 01H 4CH 00H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 4CH fixed DATA02 Setting Value 00H : Standard Lamp 01H : Option Lamp Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-78. 3D SURROUND REQUEST ********************************************************************** Function: This command acquires the setting of the 3D surround of projector. Command: 03H B0H 00H 00H 01H 4DH 01H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 4DH fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-79. WALL COLOR REQUEST ********************************************************************** Function: This command acquires the setting of the Wall Color Correction of projector. Command: 03H B0H 00H 00H 01H 4EH 02H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 4EH fixed DATA02 Setting Value 00H : Off 01H : User 1 02H : User 2 03H : User 3 04H : User 4 Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-88. LAMP SELECT REQUEST ********************************************************************** Function: This command acquires the setting of the Lamp Select of projector. Command: 03H B0H 00H 00H 01H 57H 0BH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 57H fixed DATA02 Setting Value 00H : Dual 01H : Lamp1 02H : Lamp2 03H : Single Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-89. LAMP INTERVAL REQUEST ********************************************************************** Function: This command acquires the setting of the Lamp Interval of projector. Command: 03H B0H 00H 00H 01H 58H 0CH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 58H fixed DATA02 Setting Value 00H : Auto 01H : 1 week 02H : 4 weeks 03H : 1300H 04H : 1800H 05H : 3000H 06H : 4000H 08H : OFF 09H : 12H 0AH : 24H Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-90. LAN CARD REQUEST ********************************************************************** Function: This command acquires the setting of the LAN Card of projector. Command: 03H B0H 00H 00H 01H 59H 0DH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 59H fixed DATA02 Setting Value 00H : Built-in 01H : PC Card Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-91. LAMP TYPE REQUEST 2 ********************************************************************** Function: This command acquires the setting of the Lamp Type of projector. Command: 03H B0H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 5AH fixed DATA02 Setting Value 00H : Lamp1 01H : Lamp2 Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 5AH fixed DATA02 Setting Value 00H : Standard Lamp 01H : Option Lamp Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-92. ON/OFF TIMER REQUEST ********************************************************************** Function: This command acquires the setting of the On/Off Timer of projector. Command: 03H B0H 00H 00H 01H 5BH 0FH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 5BH fixed DATA02 Setting Value 00H : Inactive 01H : Active Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-93. MOUSE POINTER REQUEST ********************************************************************** Function: This command acquires the setting of the Mouse Pointer of projector. Command: 03H B0H 00H 00H 01H 5CH 10H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 5CH fixed DATA02 Setting Value 00H : Pointer1 01H : Pointer2 02H : Pointer3 03H : Pointer4 04H : Pointer5 05H : Pointer6 06H : Pointer7 07H : Pointer8 08H : Pointer9 Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-94. BACK LIGHT REQUEST ********************************************************************** Function: This command acquires the setting of the Back Light of projector. Command: 03H B0H 00H 00H 01H 5DH 11H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 5DH fixed DATA02 Setting Value 00H : Off 01H : On Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-100. LAST MEMORY REQUEST ********************************************************************** Function: This command acquires the setting of the Last Memory of projector. Command: 03H B0H 00H 00H 01H 63H 17H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 63H fixed DATA02 Setting Value 00H : Off 01H : On Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-101. SYNC TERMINATION REQUEST ********************************************************************** Function: This command acquires the setting of the Sync Termination of projector. Command: 03H B0H 00H 00H 01H 64H 18H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 64H fixed DATA02 Setting Value 00H : Hi-Z 01H : 75Ω Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-102. LINK MODE REQUEST ********************************************************************** Function: This command acquires the setting of the Link Mode of projector. Command: 03H B0H 00H 00H 01H 65H 19H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 65H fixed DATA02 Setting Value 00H : Standalone 01H : Master 02H : Slave Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-105. LUMI UNIFORMITY REQUEST ********************************************************************** Function: This command acquires the setting of the Luminance Uniformity of projector. Command: 03H B0H 00H 00H 01H 68H 1CH Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 68H fixed DATA02 Setting Value 00H : Off 01H : On Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-109. AUTO 3D REFORM REQUEST 1 ********************************************************************** Function: This command acquires the setting of the 3D Reform of Auto Functions of projector. Command: 03H B0H 00H 00H 01H 6CH 20H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 6CH fixed DATA02 Setting Value 00H : Off 01H : On Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-110. AUTO 3D REFORM REQUEST 2 ********************************************************************** Function: This command acquires the setting of the 3D Reform Adjustment of Auto Functions of projector. Command: 03H B0H 00H 00H 01H 6DH 21H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 6DH fixed DATA02 Setting Value 00H : Inside Adjustment 01H : Outside Adjustment Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-111. AUTO 3D REFORM REQUEST 3 ********************************************************************** Function: This command acquires the setting of the 3D Reform Sensitivity of Auto Functions of projector. Command: 03H B0H 00H 00H 01H 6EH 22H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 6EH fixed DATA02 Setting Value 00H : Lower 01H : Middle 02H : Higher Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-145. VIEWER THUMBNAILS REQUEST ********************************************************************** Function: This command acquires the display setting of thumbnails on Viewer Option. Command: 03H B0H 00H 00H 01H 90H 44H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 90H fixed DATA02 Setting Value 00H : Off 01H : On Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-150. KEYSTONE SELECT REQUEST ********************************************************************** Function: This command acquires the setting of Keystone Select. Command: 03H B0H 00H 00H 01H 93H 47H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 95H fixed DATA02 Setting Value 00H : Auto 01H : Manual Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-174. REMOTE SENSOR REQUEST ********************************************************************** Function: This command acquires the setting of Remote Sensor. Command: 03H B0H 00H 00H 01H ADH 61H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 ADH fixed DATA02 Setting Value 00H : Front/Rear 01H : Front 02H : Rear Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-175. PROGRAM TIMER REQUEST ********************************************************************** Function: This command acquires the setting of Program Timer. Command: 03H B0H 00H 00H 01H AEH 62H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 AEH fixed DATA02 Setting Value 00H : Off 01H : On Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-176. PROGRAM TIMER DATA REQUEST ********************************************************************** Function: This command acquires the setting of entry for Program Timer. Command: 03H B0H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 AFH fixed DATA02 Setting Value 00H : Program 1 01H : Program 2 02H : Program 3 03H : Program 4 04H : Program 5 05H : Program 6 06H : Program 7 07H : Program 8 08H : Program 9 09H : Program 10 0AH : Program 11 0BH : Program 12 0CH : Program 13 0DH : Program 14 Response: At the time of a success 23H B0H 01H xxH 0DH DATA01 .. DATA13 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 AFH fixed DATA02 Acquisition item(Same as DATA02 of the transmit data) DATA03 Day of week data of On Time 00H : Sunday 01H : Monday 02H : Tuesday 03H : Wednesday 04H : Thursday 05H : Friday 06H : Saturday FFH : --- DATA04 Hours data of On Time (0 .. 23) DATA05 Minutes data of On Time (0 .. 59) DATA06 Day of week data of Off Time 00H : Sunday 01H : Monday 02H : Tuesday 03H : Wednesday 04H : Thursday 05H : Friday 06H : Saturday FFH : --- DATA07 Hours data of Off Time (0 .. 23) DATA08 Minutes data of Off Time (0 .. 59) DATA09 Repeat Setting Value 00H : Off 01H : On DATA10 Active Setting Value 00H : Inactive 01H : Active DATA11..13 Reserved Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-191. GEOMETRIC CORRECTION REQUEST ********************************************************************** Function: This command acquires the setting of the geometric correction of projector. Command: 03H B0H 00H 00H 01H BEH 72H Response: At the time of a success 23H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 BEH fixed DATA02 Setting Value 00H : Off 01H : 1 02H : 2 03H : 3 Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 097-198. PIP/SIDE BY SIDE REQUEST ********************************************************************** Function: This command acquires the setting of the PIP/SIDE BY SIDE of projector. Command: 03H B0H 00H 00H 02H DATA01 DATA02 CKS Data Portion Contents ------------------------------------------------------------------- DATA01 C5H fixed DATA02 Acquisition Object 00H : MODE 01H : POSITION 02H : SOURCE Response: At the time of a success 23H B0H 01H xxH 03H DATA01 DATA02 DATA03 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 C5H fixed DATA02 Acquisition item(Same as DATA02 of the transmit data) DATA03 Setting Value if DATA02 is MODE(00H) 00H : PIP 01H : SIDE BY SIDE if DATA02 is POSITION(01H) 00H : TOP-LEFT 01H : TOP-RIGHT 02H : BOTTOM-LEFT 03H : BOTTOM-RIGHT if DATA02 is SOURCE(02H) 00H : OFF 01H : VIDEO 02H : S-VIDEO Response: At the time of a failure A3H B0H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-1. MENU MODE SET ********************************************************************** Function: This command sets the menu mode of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 00H fixed DATA02 Setting Value 00H : Advanced Menu 01H : Basic Menu 02H : Custom Menu Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 00H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-2. LANGUAGE SET ********************************************************************** Function: This command sets the language of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 01H fixed DATA02 Setting Value 00H : English 01H : Japanese 02H : German 03H : French 04H : Italian 05H : Spanish 06H : Swedish 07H : Chinese 08H : Finnish 09H : Norwegian 0AH : Dutch 0BH : Turkish 0CH : Polish 0DH : Russian 0EH : Greek 0FH : Korean 10H : Hungarian 11H : Portuguese 12H : Czech 13H : Arabic 14H : Danish 15H : Romanian 16H : Croatian 17H : Bulgarian 18H : Indonesian 19H : Hindi 1AH : Thai 1BH : Chinese(Traditional) 1CH : Uyghur Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 01H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-3. MENU COLOR SELECT SET ********************************************************************** Function: This command sets the menu color select of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 02H fixed DATA02 Setting Value 00H : Color 01H : Monochrome Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 02H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-4. PROJECTOR POINTER SET ********************************************************************** Function: This command sets the projector pointer of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 03H fixed DATA02 Setting Value 00H : Pointer1 01H : Pointer2 02H : Pointer3 03H : Pointer4 04H : Pointer5 05H : Pointer6 06H : Pointer7 07H : Pointer8 08H : Pointer9 Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 02H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-5. DISPLAY TIME SET ********************************************************************** Function: This command sets the display time of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 04H fixed DATA02 Setting Value 00H : Manual 01H : Auto 5 sec 02H : Auto 15 sec 03H : Auto 45 sec Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 04H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-6. SOURCE DISPLAY SET ********************************************************************** Function: This command sets the source display of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 05H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 05H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-7. MESSAGE SET ********************************************************************** Function: This command sets the message of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 06H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 06H fixed DATA02 Results 00H : Normal 01H : Error A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-8. LAMP MODE SET ********************************************************************** Function: This command sets the lamp mode of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 07H fixed DATA02 Setting Value +----------+----------------+---------+---------------+ | 設定値 | GT/HT/LT/LT80/ | P420 | P501 | | | MT/WT/VT/NP | | | +----------+----------------+---------+---------------+ | 00H | Normal | Off | Off | | 01H | Eco | Auto | Auto Eco | | 02H | - | Eco1 | Normal(Eco1) | | 03H | - | - | Eco(Eco2) | +----------+----------------+---------+---------------+ Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 07H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-9. IDLE MODE SET ********************************************************************** Function: This command sets the idle mode of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 08H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 08H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-10. CLOSED CAPTION SET ********************************************************************** Function: This command sets the closed caption of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 09H fixed DATA02 Setting Value 00H : OFF 01H : Caption 1 02H : Caption 2 03H : Caption 3 04H : Caption 4 05H : Text 1 06H : Text 2 07H : Text 3 08H : Text 4 Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 09H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-11. ORIENTATION SET ********************************************************************** Function: This command sets the orientation of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0AH fixed DATA02 Setting Value 00H : Desktop Front 01H : Ceiling Rear 02H : Desktop Rear 03H : Ceiling Front Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0AH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-12. BACKGROUND SET ********************************************************************** Function: This command sets the background of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0BH fixed DATA02 Setting Value 00H : Blue 01H : Black 02H : Logo Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0BH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-13. SCREEN TYPE SET ********************************************************************** Function: This command sets the screen type of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0CH fixed DATA02 Setting Value 00H : 4:3 Screen / 1.25:1(5:4) Screen 01H : 16:9 Screen / 1.33:1(4:3) Screen 02H : 1.78:1(16:9) Screen / Anamorphic / 16:10 Screen 03H : 1.85:1 Screen 04H : 2.35:1 Screen Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0CH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-14. SCREEN TRIGGER SET ********************************************************************** Function: This command sets the screen trigger of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0DH fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0DH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-15. VIEWER START MODE SET ********************************************************************** Function: This command sets the viewer start mode of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0EH fixed DATA02 Setting Value 00H : OFF 01H : Show Folder List Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0EH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-16. VIEWER PLAY MODE SET ********************************************************************** Function: This command sets the viewer play mode of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0FH fixed DATA02 Setting Value 00H : Auto Play 01H : Manual Play Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 0FH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-17. VIEWER PLAY INTERVAL SET ********************************************************************** Function: This command sets the viewer play interval of projector. Command: 03H B1H 00H 00H 03H DATA01 .. DATA03 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 10H fixed DATA02 Lower ranking 8 bits of setting time (unit: second) (!) DATA03 Upper ranking 8 bits of Timer setting time (unit: second) (!) Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 10H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) Command example: (!) Setting to 60 seconds 03H B1H 00H 00H 03H 10H 3CH 00H 03H 098-18. CAPTURE OPTIONS SET ********************************************************************** Function: This command sets the capture options of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 11H fixed DATA02 Setting Value 00H : High Quality 01H : Normal 02H : High Compress Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 11H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-19. MOUSE BUTTON SET ********************************************************************** Function: This command sets the mouse button of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 12H fixed DATA02 Setting Value 00H : Right Hand 01H : Left Hand Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 12H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-20. MOUSE SENSITIVITY SET ********************************************************************** Function: This command sets the mouse sensitivity of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 13H fixed DATA02 Setting Value 00H : Fast 01H : Medium 02H : Slow Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 13H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-21. SIGNAL SELECT SET ********************************************************************** Function: This command sets the signal select of projector. Command: 03H B1H 00H 00H 03H DATA01 DATA02 DATA03 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 14H fixed DATA02 Update target 00H : RGB / RGB1 (*5) 01H : RGB2 (*5) 02H : VIDEO 03H : S-VIDEO 04H : RGB1(VIDEO) 05H : RGB1(S-VIDEO) DATA03 Setting Value When setting target is RGB/RGB1(00H)/RGB2/RGB2(01H) (*5) 00H : RGB/Component 01H : RGB 02H : Component 03H : Scart When setting target is other than RGB/RGB1(00H)/RGB2/RGB2(01H) (*5) 00H : Auto 01H : NTSC3.58 02H : NTSC4.43 03H : PAL 04H : PAL60 05H : SECAM 06H : PAL-M 07H : PAL-N 08H : PAL-M/PAL-N/NTSC3.58 Response: At the time of a success 23H B1H 01H xxH 03H DATA01 DATA02 DATA03 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 14H fixed DATA02 Update target ( Same as DATA02 of the transmit data ) DATA03 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-23. AUTO START SET ********************************************************************** Function: This command sets the auto start select of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 16H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 16H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-24. POWER MANAGEMENT SET ********************************************************************** Function: This command sets the power management of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 17H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 17H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-25. POWER OFF CONFIRMATION SET ********************************************************************** Function: This command sets the power off confirmation of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 18H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 18H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-26. KEYSTONE SAVE SET ********************************************************************** Function: This command sets the keystone save of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 19H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 19H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-27. FAN MODE SET ********************************************************************** Function: This command sets the fan mode of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1AH fixed DATA02 Setting Value 00H : AUTO 01H : HIGH SPEED 02H : HIGH ALTITUDE Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1AH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-28. BUILT IN SPEAKER SET ********************************************************************** Function: This command sets the built in speaker of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1BH fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1BH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-29. REMOTE SENSOR SET ********************************************************************** Function: This command sets the remote sensor of projector. Command: 03H B1H 00H 00H 03H DATA01 .. DATA03 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1CH fixed DATA02 Update target 00H : Front 01H : Back 02H : Right 03H : Left DATA03 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 03H DATA01 .. DATA03 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1CH fixed DATA02 Update target ( Same as DATA02 of the transmit data ) DATA03 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-30. CONTROL PANEL KEY LOCK SET ********************************************************************** Function: This command sets the control panel key lock of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1DH fixed DATA02 Setting Value 00H : Disable 01H : Enable Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1DH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-31. S-VIDEO MODE SELECT SET ********************************************************************** Function: This command sets the S-Video mode select of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1EH fixed DATA02 Setting Value 00H : OFF 02H : S2 Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1EH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-32. COMMUNICATION SPEED SET ********************************************************************** Function: This command sets the communication speed of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1FH fixed DATA02 Setting Value 00H : 4800 BPS 01H : 9600 BPS 02H : 19200 BPS 03H : 38400 BPS Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 1FH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-33. DEFAULT SOURCE SELECT SET ********************************************************************** Function: This command sets the default source select of projector. Command: 03H B1H 00H 00H 03H DATA01 .. DATA03 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 20H fixed DATA02 .. 03 Update target +--------+--------+---------------------------------------------------------+ | DATA02 | DATA03 | Setting Value | +--------+--------+---------------------------------------------------------+ | 00H | 00H | Last | | 00H | 01H | Auto | | 00H | 02H | Select | | 01H | 00H | RGB1 (MT/LT/LT80/GT/VT/NP/NP905/P420/PA600/PX750)(*5) | | | | Video (HT) | | | | RGB (WT) | | | | HDMI1 (P501/PA622/PX602/PH1202) | | 01H | 01H | RGB2 (MT/LT/LT80/GT/VT/NP/NP905/P420/PA600/PX750)(*5) | | | | S-Video (HT) | | | | DVI(DIGITAL) (WT) (*6) | | | | HDMI1 (P501) | | | | HDMI2(PA622) | | | | DisplayPort(PX602/PH1202) | | 01H | 02H | Video (MT/LT) | | | | Component (HT/VT) | | | | DVI(DIGITAL) (GT/LT80/NP) (*6) |(!) | | | DVI(ANALOG) (WT) (*6) | | | | HDMI (NP905/P420) | | | | RGB3 (PA600/PX750) | | | | HDMI2 (P501) | | | | DisplayPort(PA622) | | | | RGB2 (PX602/PH1202)(*5) | | 01H | 03H | S-Video (MT/LT) | | | | RGB (HT) (*5) | | | | Component (LT80/NP) | | | | Video (GT/WT/VT/NP905/P420/P501/PX602/PH1202) | | | | HDMI (PA600/PX750) | | | | RGB2 (PA622)(*5) | | 01H | 04H | DVI (MT/HT) (*6) |(!) | | | Video (LT80/NP/PA622) | | | | Viewer (LT) | | | | S-Video (GT/WT/VT/NP905/P420/P501/PX602/PH1202) | | | | DisplayPort (PA600/PX750) | | 01H | 05H | Viewer (MT/HT/GT/WT/VT/NP905/P420/P501) |(!!) | | | S-Video (LT80/NP/PA622) | | | | LAN (LT) | | | | Video (PA600/PX750) | | | | RGB1 (PX602/PH1202)(*5) | | 01H | 06H | LAN / Network (PX602/PH1202) |(!!) | | | Viewer (LT80/NP) | | | | S-Video (PA600/PX750) | | | | RGB1 (PA622)(*5) | | 01H | 07H | Slot1-1(PX602/PH1202) | | | | LAN (LT80/NP/PA622) | | | | USB Display (P420) | | | | Viewer (PA600/PX750) | | 01H | 08H | Slot1-2 | | | | LAN (PA600/PX750) | | | | USB-A (PA622) | | 01H | 09H | Slot2-1 | | | | SLOT (PX750) | | 01H | 0AH | Slot2-2 | | 01H | 0BH | RGB1(Video) | | 01H | 0CH | RGB1(S-Video) | +--------+--------+---------------------------------------------------------+ (!) : The MT860 and LT280 does not support a DVI connector. (!!): The PE501X does not support a Viewer and a LAN/Network connector. Response: At the time of a success 23H B1H 01H xxH 03H DATA01 .. DATA03 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 20H fixed DATA02 Update target ( Same as DATA02 of the transmit data ) DATA03 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-34. PROJECTOR ID ENABLE SET ********************************************************************** Function: This command sets the projector ID enable of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 21H fixed DATA02 Setting Value 00H : Disable 01H : Enable Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 21H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-35. PROJECTOR ID SET ********************************************************************** Function: This command sets the projector ID of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 22H fixed DATA02 Setting Value Projector ID ( 1 .. 254 ) Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 22H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-39. TEST PATTERN SET ********************************************************************** Function: This command sets the test pattern of projector. Command: 03H B1H 00H 00H 04H DATA01 .. DATA04 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 26H fixed DATA02 .. 03 Setting Value (Pattern ID) +-----------------+-----------------+----+----+----+----+----+----+----+----+----+----+----+----+----+ | Pattern ID | | | | | | | | | | | | | | | +--------+--------| Pattern Name | MT | LT |LT80| HT | GT | WT | VT | NP | NP | NP | NP |P420|P501| | DATA02 | DATA03 | | | | | | | | |2000|3150|905 |3250| | | +--------+--------+-----------------+----+----+----+----+----+----+----+----+----+----+----+----+----+ | 02H | 00H | Cross Hatch | - | * | - | * | - | - | - | - | * | * | * | * | * | | 03H | 00H | Gray Bars | * | * | * | * | * | * | * | * | * | * | * | * | * | | 04H | 00H | Raster(0%) | * | * | * | * | * | * | * | * | * | * | * | * | * | | 05H | 00H | Raster(25%) | * | * | * | * | * | * | * | * | * | * | * | * | * | | 06H | 00H | Raster(50%) | * | * | * | * | * | * | * | * | * | * | * | * | * | | 07H | 00H | Raster(100%) | * | * | * | * | * | * | * | * | * | * | * | * | * | | 08H | 00H | Focus | * | * | * | * | * | * | * | * | - | - | - | - | - | | 09H | 00H | Raster Blue | * | - | * | - | * | - | * | * | * | * | * | * | * | | 0AH | 00H | Gray Raster 30 | * | * | * | * | * | * | * | * | * | * | * | * | * | | 17H | 00H | Gray Raster 10 | * | * | * | * | * | * | * | * | * | * | * | * | * | | 18H | 00H | RAMP WBGR | - | * | - | * | - | * | - | - | - | - | - | - | - | | 19H | 00H | Blue Raster 60 | - | * | - | * | - | * | - | - | - | - | - | * | * | | 1DH | 00H | Cross Hatch 3 | * | *1 | * | - | * | * | * | * | - | - | - | - | - | | FFH | FFH | (!) | * | * | * | * | * | * | * | * | * | * | * | * | * | +--------+--------+-----------------+----+----+----+----+----+----+----+----+----+----+----+----+----+ [NP-PA600X/500X/550W/500U] [NP-PX750U] [NP-PA721X/PA621X/PA671W/PA571W/PA621W/PA521U/PA722X/PA622X/PA672W/PA572W/PA622W/PA522U] [NP-PX602UL/PX602WL] [NP-PH1202HL/PH1002HL] +-----------------+-----------------+----+----+----+----+----+ | Pattern ID | |PA |PX |PA |PX |PH | +--------+--------| Pattern Name |600 |750 |622 |602 |1202| | DATA02 | DATA03 | | | | | | | +--------+--------+-----------------+----+----+----+----+----+ | 01H | 00H | Cross Hatch | * | * | * | * | * | | 02H | 00H | Gray Bars | * | * | * | - | - | | 03H | 00H | Raster(0%) | * | * | * | * | * | | 04H | 00H | Raster(25%) | * | * | * | * | * | | 05H | 00H | Raster(50%) | * | * | * | * | * | | 06H | 00H | Raster(100%) | * | * | * | * | * | | 07H | 00H | Color Bar | * | * | * | * | * | | 18H | 00H | Gray Bars | - | - | - | * | * | +--------+--------+-----------------+----+----+----+----+----+ (!) Maintenance of current condition * : Supported - : Not supported *1: Only LT240K/260K DATA04 Setting value (Pattern on/off) +-----+-----------------+ | | R G B | +-----+-----------------+ | 00H | Off Off Off | | 01H | On Off Off | | 02H | Off On Off | | 03H | On On Off | | 04H | Off Off On | | 05H | On Off On | | 06H | Off On On | | 07H | On On On | | FFH | (!) | +-----+-----------------+ (!) Maintenance of current condition Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 26H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-40. COLOR UNIFORMITY SET ********************************************************************** Function: This command sets the color uniformity of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 27H fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 27H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-41. AUTO FUNCTIONS SET ********************************************************************** Function: This command sets the auto functions of projector. Command: 03H B1H 00H 00H 03H DATA01 DATA02 DATA03 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 28H fixed DATA02 Update target 00H : Auto Focus 01H : Wall Color Correction DATA03 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 03H DATA01 .. DATA03 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 28H fixed DATA02 Update target ( Same as DATA02 of the transmit data ) DATA03 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-73. RGBOUT TERMINAL SET ********************************************************************** Function: This command sets the RGBOUT terminal of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 48H fixed DATA02 Setting Value 00H : Last 01H : RGB1 / RGB (*5) 02H : RGB2 / DVI(ANALOG) (*5) (*6) Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 48H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-74. MOUSE MODE SELECT SET ********************************************************************** Function: This command sets the mouse operation mode select of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 49H fixed DATA02 Setting Value 00H : Auto 01H : Projector Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 49H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-75. MULTI DISPLAY SET ********************************************************************** Function: This command sets the Multi Display of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 4AH fixed DATA02 Setting Value 00H : Off 01H : Up Left 02H : Up Right 03H : Down Left 04H : Down Right Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 4AH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-78. 3D SURROUND SET ********************************************************************** Function: This command sets the 3D surround of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 4DH fixed DATA02 Setting Value 00H : OFF 01H : ON Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 4DH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-79. WALL COLOR SET ********************************************************************** Function: This command sets the Wall Color Correction of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 4EH fixed DATA02 Setting Value 00H : Off 01H : User 1 02H : User 2 03H : User 3 04H : User 4 Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 4EH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-88. LAMP SELECT SET ********************************************************************** Function: This command sets the Lamp Select of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 57H fixed DATA02 Setting Value 00H : Dual 01H : Lamp1 02H : Lamp2 03H : Single Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 57H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-89. LAMP INTERVAL SET ********************************************************************** Function: This command sets the Lamp Interval of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 58H fixed DATA02 Setting Value 00H : Auto 01H : 1 week 02H : 4 weeks 03H : 1300H 04H : 1800H 05H : 3000H 06H : 4000H 08H : OFF 09H : 12H 0AH : 24H Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 58H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-90. LAN CARD SET ********************************************************************** Function: This command sets the LAN Card of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 59H fixed DATA02 Setting Value 00H : Built-in 01H : PC Card Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 59H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-92. ON/OFF TIMER SET ********************************************************************** Function: This command sets the On/Off Timer of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 5BH fixed DATA02 Setting Value 00H : Inactive 01H : Active Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 5BH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-93. MOUSE POINTER SET ********************************************************************** Function: This command sets the Mouse Pointer of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 5CH fixed DATA02 Setting Value 00H : Pointer1 01H : Pointer2 02H : Pointer3 03H : Pointer4 04H : Pointer5 05H : Pointer6 06H : Pointer7 07H : Pointer8 08H : Pointer9 Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 5CH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-94. BACK LIGHT SET ********************************************************************** Function: This command sets the Back Light of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 5DH fixed DATA02 Setting Value 00H : Off 01H : On Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 5DH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-100. LAST MEMORY SET ********************************************************************** Function: This command sets the Last Memory of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 63H fixed DATA02 Setting Value 00H : Off 01H : On Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 63H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-101. SYNC TERMINATION SET ********************************************************************** Function: This command sets the Sync Termination of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 64H fixed DATA02 Setting Value 00H : Hi-Z 01H : 75Ω Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 64H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-102. LINK MODE SET ********************************************************************** Function: This command sets the Link Mode of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 65H fixed DATA02 Setting Value 00H : Standalone 01H : Master 02H : Slave Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 65H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-105. LUNI UNIFORMITY SET ********************************************************************** Function: This command sets the Luminance Uniformity of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 68H fixed DATA02 Setting Value 00H : Off 01H : On Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 68H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-109. AUTO 3D REFORM SET 1 ********************************************************************** Function: This command sets the 3D Reform of Auto Functions of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 6CH fixed DATA02 Setting Value 00H : Off 01H : On Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 6CH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-110. AUTO 3D REFORM SET 2 ********************************************************************** Function: This command sets the 3D Reform Adjustment of Auto Functions of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 6DH fixed DATA02 Setting Value 00H : Inside Adjustment 01H : Outside Adjustment Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 6DH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-111. AUTO 3D REFORM SET 3 ********************************************************************** Function: This command sets the 3D Reform Sensitivity of Auto Functions of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 6EH fixed DATA02 Setting Value 00H : Lower 01H : Middle 02H : Higher Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 6EH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-145. VIEWER OPTIONS SHOW THUMBNAILS SET ********************************************************************** Function: This command sets the thumbnail display on Viewer Option. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 90H fixed DATA02 Setting Value 00H : Off 01H : On Response: At the time of a success 23H B1H 01H 00H 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 90H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-150. KEYSTONE SELECT SET ********************************************************************** Function: This command sets the Keystone Select. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 93H fixed DATA02 Setting Value 00H : Auto 01H : Manual Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 95H fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-174. REMOTE SENSOR SET ********************************************************************** Function: This command sets the Remote Sensor. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 ADH fixed DATA02 Setting Value 00H : Front/Rear 01H : Front 02H : Rear Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 ADH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-175. PROGRAM TIMER SET ********************************************************************** Function: This command sets the Program Timer. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 AEH fixed DATA02 Setting Value 00H : Off 01H : On Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 AEH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-176. PROGRAM TIMER DATA SET ********************************************************************** Function: This command sets the entry for Program Timer. Command: 03H B1H 00H 00H 0DH DATA01 .. DATA13 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 AFH fixed DATA02 Program Number 00H : Program 1 01H : Program 2 02H : Program 3 03H : Program 4 04H : Program 5 05H : Program 6 06H : Program 7 07H : Program 8 08H : Program 9 09H : Program 10 0AH : Program 11 0BH : Program 12 0CH : Program 13 0DH : Program 14 DATA03 Day of week data of On Time 00H : Sunday 01H : Monday 02H : Tuesday 03H : Wednesday 04H : Thursday 05H : Friday 06H : Saturday FFH : --- DATA04 Hours data of On Time (0 .. 23) DATA05 Minutes data of On Time (0 .. 59) DATA06 Day of week data of Off Time 00H : Sunday 01H : Monday 02H : Tuesday 03H : Wednesday 04H : Thursday 05H : Friday 06H : Saturday FFH : --- DATA07 Hours data of Off Time (0 .. 23) DATA08 Minutes data of Off Time (0 .. 59) DATA09 Repeat Setting Value 00H : Off 01H : On DATA10 Active Setting Value 00H : Inactive 01H : Active DATA11..13 Reserved Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 AFH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-191. GEOMETRIC CORRECTION SET ********************************************************************** Function: This command set the geometric correction of projector. Command: 03H B1H 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 BEH fixed DATA02 Setting Value 00H : Off 01H : 1 02H : 2 03H : 3 Response: At the time of a success 23H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 BEH fixed DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 098-198. PIP/SIDE BY SIDE SET ********************************************************************** Function: This command sets the PIP/SIDE BY SIDE of projector. Command: 03H B1H 00H 00H 03H DATA01 DATA02 DATA03 CKS Data Portion Contents ------------------------------------------------------------------- DATA01 C5H fixed DATA02 Update target 00H : MODE 01H : POSITION 02H : SOURCE DATA03 Setting Value if DATA02 is MODE(00H) 00H : PIP 01H : SIDE BY SIDE if DATA02 is POSITION(01H) 00H : TOP-LEFT 01H : TOP-RIGHT 02H : BOTTOM-LEFT 03H : BOTTOM-RIGHT if DATA02 is SOURCE(02H) 00H : OFF 01H : VIDEO 02H : S-VIDEO Response: At the time of a success 23H B1H 01H xxH 03H DATA01 DATA02 DATA03 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 00H fixed DATA02 Update target ( Same as DATA02 of the transmit data ) DATA03 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B1H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 110. AUTO FUNCTIONS EXECUTE ********************************************************************** Function: This command executes the auto functions. Command: 03H B6H 00H 00H 01H DATA01 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Execution items +-----+---------+-------------------------+ | | Focus | Wall Color Correction | +-----+---------+-------------------------+ | 00H | ! | ! | | 01H | * | - | | 02H | - | * | | 03H | * | * | +-----+---------+-------------------------+ !: According to projector setting *: Executing -: Not executing Response: At the time of a success 23H B6H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Execution items(Same as DATA01 of the transmit data) DATA02 Results 00H : Normal 01H : Error Response: At the time of a failure A3H B6H 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 305-1. BASE MODEL TYPE REQUEST ********************************************************************** Function: This command acquires the projector type. Command: 00H BFH 00H 00H 01H 00H C0H Response: At the time of a success 20H BFH 01H xxH 10H DATA01 .. DATA16 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 00H fixed DATA02 .. 03 Projector type See DATA13 .. 14 DATA04 .. 12 Model name (NULL termination character string) DATA13 .. 14 Projector type +--------+--------+--------+--------+------------------+ | DATA02 | DATA03 | DATA13 | DATA14 | | +--------+--------+--------+--------+------------------+ | 00H | 01H | 00H | 03H | MT1060/1065 | | 00H | 01H | 01H | 03H | MT860 | | 00H | 01H | 02H | 03H | MT1075 | | 00H | 01H | 00H | 06H | NP1000/2000 | | 00H | 02H | 00H | 03H | LT240/260 | | 00H | 02H | 01H | 03H | LT220 | | 00H | 02H | 02H | 03H | LT260K | | 00H | 02H | 00H | 05H | LT265/245 | | 00H | 02H | 00H | 06H | LT380 | | 00H | 02H | 01H | 06H | LT280 | | 00H | 03H | 00H | 04H | VT770 | | 00H | 04H | 00H | 03H | GT5000 | | 00H | 04H | 01H | 03H | GT6000 | | 00H | 04H | 02H | 03H | GT6000R | | 00H | 05H | 00H | 03H | HT1000 | | 00H | 05H | 00H | 04H | HT1100 | | 00H | 06H | 00H | 03H | WT600 | | 00H | 06H | 00H | 05H | WT610/615 | | 01H | 10H | 00H | 08H | VT700 Series | | FFH | 12H | 00H | 08H | NP3150/2150/1150 | | FFH | 12H | 01H | 08H | NP3151W | | FFH | 12H | 00H | 09H | NP905 | | FFH | 12H | 01H | 09H | NP901W | | FFH | 12H | 02H | 09H | VT800 | | FFH | 12H | 00H | 10H | NP3250/2250/1250 | | FFH | 12H | 01H | 10H | NP3250W | | FFH | 13H | 00H | 11H | NP-P420X | | FFH | 13H | 01H | 11H | NP-P350X | | FFH | 13H | 02H | 11H | NP-P350W | | FFH | 15H | 00H | 10H | NP-PA600X | | FFH | 15H | 01H | 10H | NP-PA500X | | FFH | 15H | 02H | 10H | NP-PA550W | | FFH | 15H | 03H | 10H | NP-PA500U | | FFH | 17H | 00H | 10H | NP-PX750U | | FFH | 20H | 00H | 10H | NP-P501X | | FFH | 20H | 01H | 10H | NP-P451X | | FFH | 20H | 02H | 10H | NP-P451W | | FFH | 20H | 03H | 10H | NP-P401W | | FFH | 20H | 04H | 10H | NP-PE501X | | FFH | 21H | 00H | 10H | NP-PA621U | | FFH | 21H | 01H | 10H | NP-PA521U | | FFH | 21H | 02H | 10H | NP-PA671W | | FFH | 21H | 03H | 10H | NP-PA571W | | FFH | 21H | 04H | 10H | NP-PA721X | | FFH | 21H | 05H | 10H | NP-PA621X | | FFH | 21H | 00H | 11H | NP-PA622U | | FFH | 21H | 01H | 11H | NP-PA522U | | FFH | 21H | 02H | 11H | NP-PA672W | | FFH | 21H | 03H | 11H | NP-PA572W | | FFH | 21H | 04H | 11H | NP-PA722X | | FFH | 21H | 05H | 11H | NP-PA622X | | FFH | 25H | 00H | 10H | NP-PX602UL | | FFH | 25H | 01H | 10H | NP-PX602WL | | FFH | 26H | 00H | 10H | NP-PH1202HL | | FFH | 26H | 01H | 10H | NP-PH1002HL | +--------+--------+--------+--------+------------------+ DATA15 .. 16 Reserved Response: At the time of a failure A0H BFH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 305-2. VERSION INFORMATION REQUEST ********************************************************************** Function: This command acquires imformations of projector. Command: 00H BFH 00H 00H 02H DATA01 DATA02 CKS (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 01H : Version Information DATA02 06H : Serial Number Response: At the time of a success 20H BFH 01H xxH 12H DATA01 .. DATA12 CKS (*1) (*2) (*3) Data Portion Contents ------------------------------------------------------------------- DATA01 Same as DATA01 of the transmit data DATA02 Same as DATA02 of the transmit data DATA03-DATA18 Serial Number (NULL termination character string) Response: At the time of a failure A0H BFH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) 305-3. PROJECTOR INFORMATION REQUEST ********************************************************************** Function: This command acquires basic operation states of projector. Command: 00H BFH 00H 00H 01H 02H C2H Response: At the time of a success 20H BFH 01H xxH 10H DATA01 .. DATA16 CKS (*1) (*2) (*3) データ部 内容 ------------------------------------------------------------------- DATA01 02H fixed DATA02 Projector Processing Status 00H : Idle 04H : Power On 05H : Cooling 06H : Idle(Error Standby) Other : Not Support Other than above : (nondisclosure) internal use of code during a state transition period DATA03 Indicate Contents 00H : Picture signal displaying 01H : No Signal 02H : Viewr displaying 03H : Test Pattern displaying 04H : LAN displaying 05H : Test Pattern (User) displaying 10H : Signal selection in progress Other : Not Support DATA04 Select source input type 1 01H : 1 02H : 2 03H : 3 04H : 4 05H : 5 Other : Not Support DATA05 Select source input type 2 01H : COMPUTER (RGB) 02H : VIDEO 03H : S-VIDEO 04H : COMPONENT 05H : Reserved 06H : DIGITAL 07H : VIEWER 08H : SLOT1 09H : SLOT2 0AH : SLOT3 0BH : SLOT4 0CH : DIGITAL2 0DH : SCART 10H : AUTO 21H : HDMI 22H : DisplayPort 23H : VIEWER2 FFH : Not Source Input Other : Not Support DATA06 Indication signal type (Effective only when Select source input type 2 is 02H or 03H) x0H : NTSC3.58 x1H : NTSC4.43 x2H : PAL x3H : PAL60 x4H : SECAM x5H : B/W60 x6H : B/W50 x7H : PALNM x8H : NTSC3.58 LBX x9H : NTSC3.58 SQZ xAH : COMPONENT(60Hz) xBH : COMPONENT(50Hz) xCH : Un known xDH : NTSC xEH : PAL-M xFH : PAL-N FFH : Not Video Input Other : Not Support DATA07 Picture Mute 00H : OFF 01H : ON DATA08 Sound Mute 00H : OFF 01H : ON DATA09 On-screen mute 00H : OFF 01H : ON DATA10 Freeze Status 00H : OFF 01H : ON DATA11 .. DATA16 Reserved Response: At the time of a failure A0H BFH 01H xxH 02H DATA01 DATA02 CKS (*1) (*2) (*4) (*3) ====================================================================== 6. Communication Frame ---------------------------------------------------------------------- On the projectors communication is done in a frame composed of header, data, and checksum. The frame sent from the controller to the projector is referred to as a command, and the one sent from the projector to the command as an reply is referred to as a response. The response has two types; Acknowledge (hereafter referred to as ACK) that recognizes a command and Negative Acknowledge (hereafter referred to as NAK) that fails to recognize a command. +--------------+ Command +--------------+ | |-------------->| | | Controller | | Projector | | |<--------------| | +--------------+ Response +--------------+ (ACK or NAK) 6-1. Frame Format ********************************************************************** One frame comprises a header, a data portion, and a checksum. Frame Format: +-------------------------------+----------------------+--------+ | Header portion | Data portion |Checksum| | | (Max. 4095 Bytes) | | +-----+-----+-----+-------+-----+-----+-- --+-------+--------+ | 1 | 2 | 3 | 4 | 5 | 6 | ~ | n | m | +-----+-----+-----+---+---+-----+-----+-- --+-------+--------+ | 8 | 8 | 8 | 4 | 12 | 8 | ~ | 8 | 8 | | Bit | Bit | Bit |Bit| Bit | Bit | ~ | Bit | Bit | +-----+-----+-----+---+---------+-----+-- ~ --+-------+--------+ | | | | | | | | | +------------- Data length | | | +-------------------- Model code | | +------------------------- Projector ID | +------------------------------- ID2 +------------------------------------- ID1 * ID1: (8 Bit) This is an identification data assigned to each command. Command : This sets an identification data assigned to each command to send it. ( See each command description.) Response : This returns the 6th bit of received ID1 as HIGH. For ACK it sends the 8th bit back as LOW (recognized); for NAK it sends the 8th bit back as HIGH (not recognized). * ID2: (8 Bit) This is an identification data assigned to each command. Command : This sets an identification data assigned to each command to send it. ( See each command description.) Response : This returns the value of received ID2 as is. * Projector ID : (8 Bit) This is a projector ID for the projector that sends and receives frames. Command : This specifies a projector ID for the projector that sends and receives commands. (individual notification) Entering 00H or FFH becomes a common command for all the projectors. (broadcast notification) This is convenient for controlling multiple projectors at the same time. * When the controller is connected with the projector on a one-to-one basis Broadcast notification is recommended. * When the controller is connected with multiple projectors To control a certain projector, use "individual notification". For all others "broadcast notification" is recommended. Response : This returns the projector ID for a projector received regardless of individual notification or broadcast notification. CAUTION : To notify individually, specifying a model code from the following model codes is required. * Model code: (4 Bit) This is a model code for the projector that sends and receives frames. Command : This specifies a model code for the projector that sends commands. (individual notification) Entering 0000B or 1111B becomes a common command for all the projectors. (broadcast notification) This is convenient for controlling multiple projectors at the same time. * When the controller is connected with the projector on a one-to-one basis Broadcast notification is recommended. * When the controller is connected with multiple projectors To control a certain projector, use "individual notification". For all others "broadcast notification" is recommended. Response : This returns the model code for a projector received regardless of individual notification or broadcast notification. Table of Model codes ------------------------------------------- 0000B : (broadcast notification) 0001B : MT/NP2000/3150/3250/PA600 Series 0010B : LT/LT80 Series 0011B : Reserved 0100B : P420/P501X Series 0101B : GT Series 0110B : HT Series 1001B : NP905 Series 1111B : (broadcast notification) CAUTION : * When the model code is set to "broadcast notification", the command becomes broadcast notification command, regardless of values of the projector ID. * Model code is specified using upper ranking 4 bits of data length. The lower ranking 4 bits becomes the upper bits of data length. * Data length : (12 Bit) This is data length of data portion (unit:: byte). Command : This sets data length of data added to a command to send it. ( See each command description.) Response : This sets data length of data added to a response to send it. ( See each command description.) CAUTION : Data length is specified using total of 12 bits ( 0 - 4095) of 4 bits of the 4th byte and 8 bits of the 5th byte.* The upper ranking 4 bits of the 4th byte is model code. * Data portion This becomes data of data length specified in the data length portion. Command : This sets data added to a command to send it. ( See each command description.) Response : This sets data added to a response to send it. ( See each command description.) * Checksum This is lower ranking 8 bits of the sum total of the header and data portions of one transmit and receive data frame. 6-2. Data portion of response ********************************************************************** * At the time of a success( ACK ) This returns ACK without adding data portion to the command that does not request data. This returns ACK with adding data to the data portion for the command that requests data. * At the time of a failure( NAK ) This adds a cause of not accepting the command to data portion to return it. (Example) Power On Command: 02H 00H 00H 00H 00H CKS Response: A2H 00H 01H 20H 02H DATA01 DATA02 CKS +------------+------------+--------------------------------------+ | DATA01 | DATA02 | | | | Error | | | Error types| description| Error contents | +------------+------------+--------------------------------------+ | 00H | 00H | Unknown command | | 00H | 01H | The current model does not support | | | | this function. | | 01H | 00H | Invalid values specified. | | 01H | 01H | Specified terminal is unavailable or | | | | cannot be selected | | 01H | 02H | Selected language is not available. | | 02H | 00H | Available memory reservation error | | 02H | 02H | Operating memory | | 02H | 03H | Setting not possible | | 02H | 04H | On Forced on-screen mute mode | | 02H | 06H | Displaying a signal other than | | | | PC Viewer | | 02H | 07H | -No signal- | | 02H | 08H | Displaying a test pattern or PC Card | | | | Files screen. | | 02H | 09H | No PC card is inserted | | 02H | 0AH | Memory operation failed | | 02H | 0CH | Displaying the Entry List | | 02H | 0DH | Power Off inhibited | | 02H | 0EH | Execution error | | 02H | 0FH | No operation authority | | 03H | 00H | Specified gain number is wrong | | 03H | 01H | Selected gain is not available. | | 03H | 02H | Adjustment failed | +------------+------------+--------------------------------------+
