library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity sram_modul is port( clk : in std_logic; clk_led: inout std_logic; sram_data_led : inout std_logic_vector(0 to 4) ); end sram_modul; architecture Behavioral of sram_modul is signal status: std_logic_vector(0 to 2) := "000" ; signal write_counter: std_logic_vector(0 to 7):= "00000000" ; signal we_oe_change : std_logic_vector(0 to 2):= "000"; begin process(clk) begin if clk='1' and clk'event then clk_led <= not clk_led; case we_oe_change is when "000" => if write_counter < "00001100" then write_counter <= write_counter + 1; sram_data_led <= "00000"; else we_oe_change <= "011"; end if; when "001" => sram_data_led <= "01010"; when others => sram_data_led <= "01110"; end case; end if; end process; end Behavioral;
