wire (97.250000mm 40.000000mm) (97.189766mm 41.054452mm);wire (97.189766mm 41.054452mm) (97.011070mm 42.102246mm);wire (97.011070mm 42.102246mm) (96.719834mm 43.137140mm);wire (96.719834mm 43.137140mm) (96.325636mm 44.153701mm);wire (96.325636mm 44.153701mm) (95.841265mm 45.147643mm);wire (95.841265mm 45.147643mm) (95.282155mm 46.116108mm);wire (95.282155mm 46.116108mm) (94.665680mm 47.057853mm);wire (94.665680mm 47.057853mm) (94.010383mm 47.973345mm);wire (94.010383mm 47.973345mm) (93.335141mm 48.864751mm);wire (93.335141mm 48.864751mm) (92.658336mm 49.735821mm);wire (92.658336mm 49.735821mm) (91.997043mm 50.591679mm);wire (91.997043mm 50.591679mm) (91.366291mm 51.438512mm);wire (91.366291mm 51.438512mm) (90.778428mm 52.283203mm);wire (90.778428mm 52.283203mm) (90.242609mm 53.132895mm);wire (90.242609mm 53.132895mm) (89.764441mm 53.994539mm);wire (89.764441mm 53.994539mm) (89.345794mm 54.874423mm);wire (89.345794mm 54.874423mm) (88.984788mm 55.777742mm);wire (88.984788mm 55.777742mm) (88.675949mm 56.708194mm);wire (88.675949mm 56.708194mm) (88.410534mm 57.667663mm);wire (88.410534mm 57.667663mm) (88.176998mm 58.655984mm);wire (88.176998mm 58.655984mm) (87.961586mm 59.670813mm);wire (87.961586mm 59.670813mm) (87.749015mm 60.707615mm);wire (87.749015mm 60.707615mm) (87.523212mm 61.759771mm);wire (87.523212mm 61.759771mm) (87.268084mm 62.818798mm);wire (87.268084mm 62.818798mm) (86.968265mm 63.874681mm);wire (86.968265mm 63.874681mm) (86.609815mm 64.916300mm);wire (86.609815mm 64.916300mm) (86.180840mm 65.931921mm);wire (86.180840mm 65.931921mm) (85.672000mm 66.909751mm);wire (85.672000mm 66.909751mm) (85.076884mm 67.838504mm);wire (85.076884mm 67.838504mm) (84.392238mm 68.707966mm);wire (84.392238mm 68.707966mm) (83.618039mm 69.509524mm);wire (83.618039mm 69.509524mm) (82.757407mm 70.236631mm);wire (82.757407mm 70.236631mm) (81.816381mm 70.885182mm);wire (81.816381mm 70.885182mm) (80.803548mm 71.453783mm);wire (80.803548mm 71.453783mm) (79.729569mm 71.943890mm);wire (79.729569mm 71.943890mm) (78.606615mm 72.359815mm);wire (78.606615mm 72.359815mm) (77.447749mm 72.708592mm);wire (77.447749mm 72.708592mm) (76.266283mm 72.999709mm);wire (76.266283mm 72.999709mm) (75.075148mm 73.244711mm);wire (75.075148mm 73.244711mm) (73.886297mm 73.456694mm);wire (73.886297mm 73.456694mm) (72.710189mm 73.649725mm);wire (72.710189mm 73.649725mm) (71.555358mm 73.838182mm);wire (71.555358mm 73.838182mm) (70.428101mm 74.036086mm);wire (70.428101mm 74.036086mm) (69.332294mm 74.256422mm);wire (69.332294mm 74.256422mm) (68.269339mm 74.510508mm);wire (68.269339mm 74.510508mm) (67.238243mm 74.807419mm);wire (67.238243mm 74.807419mm) (66.235826mm 75.153518mm);wire (66.235826mm 75.153518mm) (65.257035mm 75.552100mm);wire (65.257035mm 75.552100mm) (64.295352mm 76.003179mm);wire (64.295352mm 76.003179mm) (63.343265mm 76.503419mm);wire (63.343265mm 76.503419mm) (62.392780mm 77.046229mm);wire (62.392780mm 77.046229mm) (61.435947mm 77.622005mm);wire (61.435947mm 77.622005mm) (60.465354mm 78.218513mm);wire (60.465354mm 78.218513mm) (59.474592mm 78.821409mm);wire (59.474592mm 78.821409mm) (58.458632mm 79.414847mm);wire (58.458632mm 79.414847mm) (57.414123mm 79.982175mm);wire (57.414123mm 79.982175mm) (56.339575mm 80.506670mm);wire (56.339575mm 80.506670mm) (55.235428mm 80.972277mm);wire (55.235428mm 80.972277mm) (54.104012mm 81.364334mm);wire (54.104012mm 81.364334mm) (52.949377mm 81.670224mm);wire (52.949377mm 81.670224mm) (51.777034mm 81.879951mm);wire (51.777034mm 81.879951mm) (50.593603mm 81.986587mm);wire (50.593603mm 81.986587mm) (49.406397mm 81.986587mm);wire (49.406397mm 81.986587mm) (48.222966mm 81.879951mm);wire (48.222966mm 81.879951mm) (47.050623mm 81.670224mm);wire (47.050623mm 81.670224mm) (45.895988mm 81.364334mm);wire (45.895988mm 81.364334mm) (44.764572mm 80.972277mm);wire (44.764572mm 80.972277mm) (43.660425mm 80.506670mm);wire (43.660425mm 80.506670mm) (42.585877mm 79.982175mm);wire (42.585877mm 79.982175mm) (41.541368mm 79.414847mm);wire (41.541368mm 79.414847mm) (40.525408mm 78.821409mm);wire (40.525408mm 78.821409mm) (39.534646mm 78.218513mm);wire (39.534646mm 78.218513mm) (38.564053mm 77.622005mm);wire (38.564053mm 77.622005mm) (37.607220mm 77.046229mm);wire (37.607220mm 77.046229mm) (36.656735mm 76.503419mm);wire (36.656735mm 76.503419mm) (35.704648mm 76.003179mm);wire (35.704648mm 76.003179mm) (34.742965mm 75.552100mm);wire (34.742965mm 75.552100mm) (33.764174mm 75.153518mm);wire (33.764174mm 75.153518mm) (32.761757mm 74.807419mm);wire (32.761757mm 74.807419mm) (31.730661mm 74.510508mm);wire (31.730661mm 74.510508mm) (30.667706mm 74.256422mm);wire (30.667706mm 74.256422mm) (29.571899mm 74.036086mm);wire (29.571899mm 74.036086mm) (28.444642mm 73.838182mm);wire (28.444642mm 73.838182mm) (27.289811mm 73.649725mm);wire (27.289811mm 73.649725mm) (26.113703mm 73.456694mm);wire (26.113703mm 73.456694mm) (24.924852mm 73.244711mm);wire (24.924852mm 73.244711mm) (23.733717mm 72.999709mm);wire (23.733717mm 72.999709mm) (22.552251mm 72.708592mm);wire (22.552251mm 72.708592mm) (21.393385mm 72.359815mm);wire (21.393385mm 72.359815mm) (20.270431mm 71.943890mm);wire (20.270431mm 71.943890mm) (19.196452mm 71.453783mm);wire (19.196452mm 71.453783mm) (18.183619mm 70.885182mm);wire (18.183619mm 70.885182mm) (17.242593mm 70.236631mm);wire (17.242593mm 70.236631mm) (16.381961mm 69.509524mm);wire (16.381961mm 69.509524mm) (15.607762mm 68.707966mm);wire (15.607762mm 68.707966mm) (14.923116mm 67.838504mm);wire (14.923116mm 67.838504mm) (14.328000mm 66.909751mm);wire (14.328000mm 66.909751mm) (13.819160mm 65.931921mm);wire (13.819160mm 65.931921mm) (13.390185mm 64.916300mm);wire (13.390185mm 64.916300mm) (13.031735mm 63.874681mm);wire (13.031735mm 63.874681mm) (12.731916mm 62.818798mm);wire (12.731916mm 62.818798mm) (12.476788mm 61.759771mm);wire (12.476788mm 61.759771mm) (12.250985mm 60.707615mm);wire (12.250985mm 60.707615mm) (12.038414mm 59.670813mm);wire (12.038414mm 59.670813mm) (11.823002mm 58.655984mm);wire (11.823002mm 58.655984mm) (11.589466mm 57.667663mm);wire (11.589466mm 57.667663mm) (11.324051mm 56.708194mm);wire (11.324051mm 56.708194mm) (11.015212mm 55.777742mm);wire (11.015212mm 55.777742mm) (10.654206mm 54.874423mm);wire (10.654206mm 54.874423mm) (10.235559mm 53.994539mm);wire (10.235559mm 53.994539mm) (9.757391mm 53.132895mm);wire (9.757391mm 53.132895mm) (9.221572mm 52.283203mm);wire (9.221572mm 52.283203mm) (8.633709mm 51.438512mm);wire (8.633709mm 51.438512mm) (8.002957mm 50.591679mm);wire (8.002957mm 50.591679mm) (7.341664mm 49.735821mm);wire (7.341664mm 49.735821mm) (6.664859mm 48.864751mm);wire (6.664859mm 48.864751mm) (5.989617mm 47.973345mm);wire (5.989617mm 47.973345mm) (5.334320mm 47.057853mm);wire (5.334320mm 47.057853mm) (4.717845mm 46.116108mm);wire (4.717845mm 46.116108mm) (4.158735mm 45.147643mm);wire (4.158735mm 45.147643mm) (3.674364mm 44.153701mm);wire (3.674364mm 44.153701mm) (3.280166mm 43.137140mm);wire (3.280166mm 43.137140mm) (2.988930mm 42.102246mm);wire (2.988930mm 42.102246mm) (2.810234mm 41.054452mm);wire (2.810234mm 41.054452mm) (2.750000mm 40.000000mm);wire (2.750000mm 40.000000mm) (2.810234mm 38.945548mm);wire (2.810234mm 38.945548mm) (2.988930mm 37.897754mm);wire (2.988930mm 37.897754mm) (3.280166mm 36.862860mm);wire (3.280166mm 36.862860mm) (3.674364mm 35.846299mm);wire (3.674364mm 35.846299mm) (4.158735mm 34.852357mm);wire (4.158735mm 34.852357mm) (4.717845mm 33.883892mm);wire (4.717845mm 33.883892mm) (5.334320mm 32.942147mm);wire (5.334320mm 32.942147mm) (5.989617mm 32.026655mm);wire (5.989617mm 32.026655mm) (6.664859mm 31.135249mm);wire (6.664859mm 31.135249mm) (7.341664mm 30.264179mm);wire (7.341664mm 30.264179mm) (8.002957mm 29.408321mm);wire (8.002957mm 29.408321mm) (8.633709mm 28.561488mm);wire (8.633709mm 28.561488mm) (9.221572mm 27.716797mm);wire (9.221572mm 27.716797mm) (9.757391mm 26.867105mm);wire (9.757391mm 26.867105mm) (10.235559mm 26.005461mm);wire (10.235559mm 26.005461mm) (10.654206mm 25.125577mm);wire (10.654206mm 25.125577mm) (11.015212mm 24.222258mm);wire (11.015212mm 24.222258mm) (11.324051mm 23.291806mm);wire (11.324051mm 23.291806mm) (11.589466mm 22.332337mm);wire (11.589466mm 22.332337mm) (11.823002mm 21.344016mm);wire (11.823002mm 21.344016mm) (12.038414mm 20.329187mm);wire (12.038414mm 20.329187mm) (12.250985mm 19.292385mm);wire (12.250985mm 19.292385mm) (12.476788mm 18.240229mm);wire (12.476788mm 18.240229mm) (12.731916mm 17.181202mm);wire (12.731916mm 17.181202mm) (13.031735mm 16.125319mm);wire (13.031735mm 16.125319mm) (13.390185mm 15.083700mm);wire (13.390185mm 15.083700mm) (13.819160mm 14.068079mm);wire (13.819160mm 14.068079mm) (14.328000mm 13.090249mm);wire (14.328000mm 13.090249mm) (14.923116mm 12.161496mm);wire (14.923116mm 12.161496mm) (15.607762mm 11.292034mm);wire (15.607762mm 11.292034mm) (16.381961mm 10.490476mm);wire (16.381961mm 10.490476mm) (17.242593mm 9.763369mm);wire (17.242593mm 9.763369mm) (18.183619mm 9.114818mm);wire (18.183619mm 9.114818mm) (19.196452mm 8.546217mm);wire (19.196452mm 8.546217mm) (20.270431mm 8.056110mm);wire (20.270431mm 8.056110mm) (21.393385mm 7.640185mm);wire (21.393385mm 7.640185mm) (22.552251mm 7.291408mm);wire (22.552251mm 7.291408mm) (23.733717mm 7.000291mm);wire (23.733717mm 7.000291mm) (24.924852mm 6.755289mm);wire (24.924852mm 6.755289mm) (26.113703mm 6.543306mm);wire (26.113703mm 6.543306mm) (27.289811mm 6.350275mm);wire (27.289811mm 6.350275mm) (28.444642mm 6.161818mm);wire (28.444642mm 6.161818mm) (29.571899mm 5.963914mm);wire (29.571899mm 5.963914mm) (30.667706mm 5.743578mm);wire (30.667706mm 5.743578mm) (31.730661mm 5.489492mm);wire (31.730661mm 5.489492mm) (32.761757mm 5.192581mm);wire (32.761757mm 5.192581mm) (33.764174mm 4.846482mm);wire (33.764174mm 4.846482mm) (34.742965mm 4.447900mm);wire (34.742965mm 4.447900mm) (35.704648mm 3.996821mm);wire (35.704648mm 3.996821mm) (36.656735mm 3.496581mm);wire (36.656735mm 3.496581mm) (37.607220mm 2.953771mm);wire (37.607220mm 2.953771mm) (38.564053mm 2.377995mm);wire (38.564053mm 2.377995mm) (39.534646mm 1.781487mm);wire (39.534646mm 1.781487mm) (40.525408mm 1.178591mm);wire (40.525408mm 1.178591mm) (41.541368mm 0.585153mm);wire (41.541368mm 0.585153mm) (42.585877mm 0.017825mm);wire (42.585877mm 0.017825mm) (43.660425mm -0.506670mm);wire (43.660425mm -0.506670mm) (44.764572mm -0.972277mm);wire (44.764572mm -0.972277mm) (45.895988mm -1.364334mm);wire (45.895988mm -1.364334mm) (47.050623mm -1.670224mm);wire (47.050623mm -1.670224mm) (48.222966mm -1.879951mm);wire (48.222966mm -1.879951mm) (49.406397mm -1.986587mm);wire (49.406397mm -1.986587mm) (50.593603mm -1.986587mm);wire (50.593603mm -1.986587mm) (51.777034mm -1.879951mm);wire (51.777034mm -1.879951mm) (52.949377mm -1.670224mm);wire (52.949377mm -1.670224mm) (54.104012mm -1.364334mm);wire (54.104012mm -1.364334mm) (55.235428mm -0.972277mm);wire (55.235428mm -0.972277mm) (56.339575mm -0.506670mm);wire (56.339575mm -0.506670mm) (57.414123mm 0.017825mm);wire (57.414123mm 0.017825mm) (58.458632mm 0.585153mm);wire (58.458632mm 0.585153mm) (59.474592mm 1.178591mm);wire (59.474592mm 1.178591mm) (60.465354mm 1.781487mm);wire (60.465354mm 1.781487mm) (61.435947mm 2.377995mm);wire (61.435947mm 2.377995mm) (62.392780mm 2.953771mm);wire (62.392780mm 2.953771mm) (63.343265mm 3.496581mm);wire (63.343265mm 3.496581mm) (64.295352mm 3.996821mm);wire (64.295352mm 3.996821mm) (65.257035mm 4.447900mm);wire (65.257035mm 4.447900mm) (66.235826mm 4.846482mm);wire (66.235826mm 4.846482mm) (67.238243mm 5.192581mm);wire (67.238243mm 5.192581mm) (68.269339mm 5.489492mm);wire (68.269339mm 5.489492mm) (69.332294mm 5.743578mm);wire (69.332294mm 5.743578mm) (70.428101mm 5.963914mm);wire (70.428101mm 5.963914mm) (71.555358mm 6.161818mm);wire (71.555358mm 6.161818mm) (72.710189mm 6.350275mm);wire (72.710189mm 6.350275mm) (73.886297mm 6.543306mm);wire (73.886297mm 6.543306mm) (75.075148mm 6.755289mm);wire (75.075148mm 6.755289mm) (76.266283mm 7.000291mm);wire (76.266283mm 7.000291mm) (77.447749mm 7.291408mm);wire (77.447749mm 7.291408mm) (78.606615mm 7.640185mm);wire (78.606615mm 7.640185mm) (79.729569mm 8.056110mm);wire (79.729569mm 8.056110mm) (80.803548mm 8.546217mm);wire (80.803548mm 8.546217mm) (81.816381mm 9.114818mm);wire (81.816381mm 9.114818mm) (82.757407mm 9.763369mm);wire (82.757407mm 9.763369mm) (83.618039mm 10.490476mm);wire (83.618039mm 10.490476mm) (84.392238mm 11.292034mm);wire (84.392238mm 11.292034mm) (85.076884mm 12.161496mm);wire (85.076884mm 12.161496mm) (85.672000mm 13.090249mm);wire (85.672000mm 13.090249mm) (86.180840mm 14.068079mm);wire (86.180840mm 14.068079mm) (86.609815mm 15.083700mm);wire (86.609815mm 15.083700mm) (86.968265mm 16.125319mm);wire (86.968265mm 16.125319mm) (87.268084mm 17.181202mm);wire (87.268084mm 17.181202mm) (87.523212mm 18.240229mm);wire (87.523212mm 18.240229mm) (87.749015mm 19.292385mm);wire (87.749015mm 19.292385mm) (87.961586mm 20.329187mm);wire (87.961586mm 20.329187mm) (88.176998mm 21.344016mm);wire (88.176998mm 21.344016mm) (88.410534mm 22.332337mm);wire (88.410534mm 22.332337mm) (88.675949mm 23.291806mm);wire (88.675949mm 23.291806mm) (88.984788mm 24.222258mm);wire (88.984788mm 24.222258mm) (89.345794mm 25.125577mm);wire (89.345794mm 25.125577mm) (89.764441mm 26.005461mm);wire (89.764441mm 26.005461mm) (90.242609mm 26.867105mm);wire (90.242609mm 26.867105mm) (90.778428mm 27.716797mm);wire (90.778428mm 27.716797mm) (91.366291mm 28.561488mm);wire (91.366291mm 28.561488mm) (91.997043mm 29.408321mm);wire (91.997043mm 29.408321mm) (92.658336mm 30.264179mm);wire (92.658336mm 30.264179mm) (93.335141mm 31.135249mm);wire (93.335141mm 31.135249mm) (94.010383mm 32.026655mm);wire (94.010383mm 32.026655mm) (94.665680mm 32.942147mm);wire (94.665680mm 32.942147mm) (95.282155mm 33.883892mm);wire (95.282155mm 33.883892mm) (95.841265mm 34.852357mm);wire (95.841265mm 34.852357mm) (96.325636mm 35.846299mm);wire (96.325636mm 35.846299mm) (96.719834mm 36.862860mm);wire (96.719834mm 36.862860mm) (97.011070mm 37.897754mm);wire (97.011070mm 37.897754mm) (97.189766mm 38.945548mm);wire (97.189766mm 38.945548mm) (97.250000mm 40.000000mm);wire (86.750000mm 40.000000mm) (86.703151mm 40.790839mm);wire (86.703151mm 40.790839mm) (86.564165mm 41.576684mm);wire (86.564165mm 41.576684mm) (86.337649mm 42.352855mm);wire (86.337649mm 42.352855mm) (86.031050mm 43.115276mm);wire (86.031050mm 43.115276mm) (85.654317mm 43.860732mm);wire (85.654317mm 43.860732mm) (85.219454mm 44.587081mm);wire (85.219454mm 44.587081mm) (84.739974mm 45.293390mm);wire (84.739974mm 45.293390mm) (84.230298mm 45.980009mm);wire (84.230298mm 45.980009mm) (83.705110mm 46.648563mm);wire (83.705110mm 46.648563mm) (83.178706mm 47.301866mm);wire (83.178706mm 47.301866mm) (82.664367mm 47.943759mm);wire (82.664367mm 47.943759mm) (82.173782mm 48.578884mm);wire (82.173782mm 48.578884mm) (81.716555mm 49.212402mm);wire (81.716555mm 49.212402mm) (81.299807mm 49.849672mm);wire (81.299807mm 49.849672mm) (80.927898mm 50.495904mm);wire (80.927898mm 50.495904mm) (80.602284mm 51.155817mm);wire (80.602284mm 51.155817mm) (80.321502mm 51.833306mm);wire (80.321502mm 51.833306mm) (80.081293mm 52.531145mm);wire (80.081293mm 52.531145mm) (79.874859mm 53.250747mm);wire (79.874859mm 53.250747mm) (79.693221mm 53.991988mm);wire (79.693221mm 53.991988mm) (79.525678mm 54.753110mm);wire (79.525678mm 54.753110mm) (79.360345mm 55.530712mm);wire (79.360345mm 55.530712mm) (79.184720mm 56.319828mm);wire (79.184720mm 56.319828mm) (78.986288mm 57.114098mm);wire (78.986288mm 57.114098mm) (78.753095mm 57.906011mm);wire (78.753095mm 57.906011mm) (78.474300mm 58.687225mm);wire (78.474300mm 58.687225mm) (78.140653mm 59.448941mm);wire (78.140653mm 59.448941mm) (77.744889mm 60.182313mm);wire (77.744889mm 60.182313mm) (77.282021mm 60.878878mm);wire (77.282021mm 60.878878mm) (76.749519mm 61.530974mm);wire (76.749519mm 61.530974mm) (76.147363mm 62.132143mm);wire (76.147363mm 62.132143mm) (75.477983mm 62.677473mm);wire (75.477983mm 62.677473mm) (74.746074mm 63.163886mm);wire (74.746074mm 63.163886mm) (73.958315mm 63.590337mm);wire (73.958315mm 63.590337mm) (73.122998mm 63.957917mm);wire (73.122998mm 63.957917mm) (72.249589mm 64.269861mm);wire (72.249589mm 64.269861mm) (71.348249mm 64.531444mm);wire (71.348249mm 64.531444mm) (70.429331mm 64.749782mm);wire (70.429331mm 64.749782mm) (69.502893mm 64.933533mm);wire (69.502893mm 64.933533mm) (68.578231mm 65.092521mm);wire (68.578231mm 65.092521mm) (67.663480mm 65.237294mm);wire (67.663480mm 65.237294mm) (66.765278mm 65.378636mm);wire (66.765278mm 65.378636mm) (65.888523mm 65.527064mm);wire (65.888523mm 65.527064mm) (65.036229mm 65.692317mm);wire (65.036229mm 65.692317mm) (64.209486mm 65.882881mm);wire (64.209486mm 65.882881mm) (63.407522mm 66.105564mm);wire (63.407522mm 66.105564mm) (62.627865mm 66.365139mm);wire (62.627865mm 66.365139mm) (61.866583mm 66.664075mm);wire (61.866583mm 66.664075mm) (61.118607mm 67.002384mm);wire (61.118607mm 67.002384mm) (60.378095mm 67.377564mm);wire (60.378095mm 67.377564mm) (59.638829mm 67.784672mm);wire (59.638829mm 67.784672mm) (58.894625mm 68.216503mm);wire (58.894625mm 68.216503mm) (58.139720mm 68.663885mm);wire (58.139720mm 68.663885mm) (57.369127mm 69.116057mm);wire (57.369127mm 69.116057mm) (56.578936mm 69.561135mm);wire (56.578936mm 69.561135mm) (55.766540mm 69.986631mm);wire (55.766540mm 69.986631mm) (54.930780mm 70.380002mm);wire (54.930780mm 70.380002mm) (54.072000mm 70.729208mm);wire (54.072000mm 70.729208mm) (53.192009mm 71.023250mm);wire (53.192009mm 71.023250mm) (52.293960mm 71.252668mm);wire (52.293960mm 71.252668mm) (51.382137mm 71.409963mm);wire (51.382137mm 71.409963mm) (50.461691mm 71.489940mm);wire (50.461691mm 71.489940mm) (49.538309mm 71.489940mm);wire (49.538309mm 71.489940mm) (48.617863mm 71.409963mm);wire (48.617863mm 71.409963mm) (47.706040mm 71.252668mm);wire (47.706040mm 71.252668mm) (46.807991mm 71.023250mm);wire (46.807991mm 71.023250mm) (45.928000mm 70.729208mm);wire (45.928000mm 70.729208mm) (45.069220mm 70.380002mm);wire (45.069220mm 70.380002mm) (44.233460mm 69.986631mm);wire (44.233460mm 69.986631mm) (43.421064mm 69.561135mm);wire (43.421064mm 69.561135mm) (42.630873mm 69.116057mm);wire (42.630873mm 69.116057mm) (41.860280mm 68.663885mm);wire (41.860280mm 68.663885mm) (41.105375mm 68.216503mm);wire (41.105375mm 68.216503mm) (40.361171mm 67.784672mm);wire (40.361171mm 67.784672mm) (39.621905mm 67.377564mm);wire (39.621905mm 67.377564mm) (38.881393mm 67.002384mm);wire (38.881393mm 67.002384mm) (38.133417mm 66.664075mm);wire (38.133417mm 66.664075mm) (37.372135mm 66.365139mm);wire (37.372135mm 66.365139mm) (36.592478mm 66.105564mm);wire (36.592478mm 66.105564mm) (35.790514mm 65.882881mm);wire (35.790514mm 65.882881mm) (34.963771mm 65.692317mm);wire (34.963771mm 65.692317mm) (34.111477mm 65.527064mm);wire (34.111477mm 65.527064mm) (33.234722mm 65.378636mm);wire (33.234722mm 65.378636mm) (32.336520mm 65.237294mm);wire (32.336520mm 65.237294mm) (31.421769mm 65.092521mm);wire (31.421769mm 65.092521mm) (30.497107mm 64.933533mm);wire (30.497107mm 64.933533mm) (29.570669mm 64.749782mm);wire (29.570669mm 64.749782mm) (28.651751mm 64.531444mm);wire (28.651751mm 64.531444mm) (27.750411mm 64.269861mm);wire (27.750411mm 64.269861mm) (26.877002mm 63.957917mm);wire (26.877002mm 63.957917mm) (26.041685mm 63.590337mm);wire (26.041685mm 63.590337mm) (25.253926mm 63.163886mm);wire (25.253926mm 63.163886mm) (24.522017mm 62.677473mm);wire (24.522017mm 62.677473mm) (23.852637mm 62.132143mm);wire (23.852637mm 62.132143mm) (23.250481mm 61.530974mm);wire (23.250481mm 61.530974mm) (22.717979mm 60.878878mm);wire (22.717979mm 60.878878mm) (22.255111mm 60.182313mm);wire (22.255111mm 60.182313mm) (21.859347mm 59.448941mm);wire (21.859347mm 59.448941mm) (21.525700mm 58.687225mm);wire (21.525700mm 58.687225mm) (21.246905mm 57.906011mm);wire (21.246905mm 57.906011mm) (21.013712mm 57.114098mm);wire (21.013712mm 57.114098mm) (20.815280mm 56.319828mm);wire (20.815280mm 56.319828mm) (20.639655mm 55.530712mm);wire (20.639655mm 55.530712mm) (20.474322mm 54.753110mm);wire (20.474322mm 54.753110mm) (20.306779mm 53.991988mm);wire (20.306779mm 53.991988mm) (20.125141mm 53.250747mm);wire (20.125141mm 53.250747mm) (19.918707mm 52.531145mm);wire (19.918707mm 52.531145mm) (19.678498mm 51.833306mm);wire (19.678498mm 51.833306mm) (19.397716mm 51.155817mm);wire (19.397716mm 51.155817mm) (19.072102mm 50.495904mm);wire (19.072102mm 50.495904mm) (18.700193mm 49.849672mm);wire (18.700193mm 49.849672mm) (18.283445mm 49.212402mm);wire (18.283445mm 49.212402mm) (17.826218mm 48.578884mm);wire (17.826218mm 48.578884mm) (17.335633mm 47.943759mm);wire (17.335633mm 47.943759mm) (16.821294mm 47.301866mm);wire (16.821294mm 47.301866mm) (16.294890mm 46.648563mm);wire (16.294890mm 46.648563mm) (15.769702mm 45.980009mm);wire (15.769702mm 45.980009mm) (15.260026mm 45.293390mm);wire (15.260026mm 45.293390mm) (14.780546mm 44.587081mm);wire (14.780546mm 44.587081mm) (14.345683mm 43.860732mm);wire (14.345683mm 43.860732mm) (13.968950mm 43.115276mm);wire (13.968950mm 43.115276mm) (13.662351mm 42.352855mm);wire (13.662351mm 42.352855mm) (13.435835mm 41.576684mm);wire (13.435835mm 41.576684mm) (13.296849mm 40.790839mm);wire (13.296849mm 40.790839mm) (13.250000mm 40.000000mm);wire (13.250000mm 40.000000mm) (13.296849mm 39.209161mm);wire (13.296849mm 39.209161mm) (13.435835mm 38.423316mm);wire (13.435835mm 38.423316mm) (13.662351mm 37.647145mm);wire (13.662351mm 37.647145mm) (13.968950mm 36.884724mm);wire (13.968950mm 36.884724mm) (14.345683mm 36.139268mm);wire (14.345683mm 36.139268mm) (14.780546mm 35.412919mm);wire (14.780546mm 35.412919mm) (15.260026mm 34.706610mm);wire (15.260026mm 34.706610mm) (15.769702mm 34.019991mm);wire (15.769702mm 34.019991mm) (16.294890mm 33.351437mm);wire (16.294890mm 33.351437mm) (16.821294mm 32.698134mm);wire (16.821294mm 32.698134mm) (17.335633mm 32.056241mm);wire (17.335633mm 32.056241mm) (17.826218mm 31.421116mm);wire (17.826218mm 31.421116mm) (18.283445mm 30.787598mm);wire (18.283445mm 30.787598mm) (18.700193mm 30.150328mm);wire (18.700193mm 30.150328mm) (19.072102mm 29.504096mm);wire (19.072102mm 29.504096mm) (19.397716mm 28.844183mm);wire (19.397716mm 28.844183mm) (19.678498mm 28.166694mm);wire (19.678498mm 28.166694mm) (19.918707mm 27.468855mm);wire (19.918707mm 27.468855mm) (20.125141mm 26.749253mm);wire (20.125141mm 26.749253mm) (20.306779mm 26.008012mm);wire (20.306779mm 26.008012mm) (20.474322mm 25.246890mm);wire (20.474322mm 25.246890mm) (20.639655mm 24.469288mm);wire (20.639655mm 24.469288mm) (20.815280mm 23.680172mm);wire (20.815280mm 23.680172mm) (21.013712mm 22.885902mm);wire (21.013712mm 22.885902mm) (21.246905mm 22.093989mm);wire (21.246905mm 22.093989mm) (21.525700mm 21.312775mm);wire (21.525700mm 21.312775mm) (21.859347mm 20.551059mm);wire (21.859347mm 20.551059mm) (22.255111mm 19.817687mm);wire (22.255111mm 19.817687mm) (22.717979mm 19.121122mm);wire (22.717979mm 19.121122mm) (23.250481mm 18.469026mm);wire (23.250481mm 18.469026mm) (23.852637mm 17.867857mm);wire (23.852637mm 17.867857mm) (24.522017mm 17.322527mm);wire (24.522017mm 17.322527mm) (25.253926mm 16.836114mm);wire (25.253926mm 16.836114mm) (26.041685mm 16.409663mm);wire (26.041685mm 16.409663mm) (26.877002mm 16.042083mm);wire (26.877002mm 16.042083mm) (27.750411mm 15.730139mm);wire (27.750411mm 15.730139mm) (28.651751mm 15.468556mm);wire (28.651751mm 15.468556mm) (29.570669mm 15.250218mm);wire (29.570669mm 15.250218mm) (30.497107mm 15.066467mm);wire (30.497107mm 15.066467mm) (31.421769mm 14.907479mm);wire (31.421769mm 14.907479mm) (32.336520mm 14.762706mm);wire (32.336520mm 14.762706mm) (33.234722mm 14.621364mm);wire (33.234722mm 14.621364mm) (34.111477mm 14.472936mm);wire (34.111477mm 14.472936mm) (34.963771mm 14.307683mm);wire (34.963771mm 14.307683mm) (35.790514mm 14.117119mm);wire (35.790514mm 14.117119mm) (36.592478mm 13.894436mm);wire (36.592478mm 13.894436mm) (37.372135mm 13.634861mm);wire (37.372135mm 13.634861mm) (38.133417mm 13.335925mm);wire (38.133417mm 13.335925mm) (38.881393mm 12.997616mm);wire (38.881393mm 12.997616mm) (39.621905mm 12.622436mm);wire (39.621905mm 12.622436mm) (40.361171mm 12.215328mm);wire (40.361171mm 12.215328mm) (41.105375mm 11.783497mm);wire (41.105375mm 11.783497mm) (41.860280mm 11.336115mm);wire (41.860280mm 11.336115mm) (42.630873mm 10.883943mm);wire (42.630873mm 10.883943mm) (43.421064mm 10.438865mm);wire (43.421064mm 10.438865mm) (44.233460mm 10.013369mm);wire (44.233460mm 10.013369mm) (45.069220mm 9.619998mm);wire (45.069220mm 9.619998mm) (45.928000mm 9.270792mm);wire (45.928000mm 9.270792mm) (46.807991mm 8.976750mm);wire (46.807991mm 8.976750mm) (47.706040mm 8.747332mm);wire (47.706040mm 8.747332mm) (48.617863mm 8.590037mm);wire (48.617863mm 8.590037mm) (49.538309mm 8.510060mm);wire (49.538309mm 8.510060mm) (50.461691mm 8.510060mm);wire (50.461691mm 8.510060mm) (51.382137mm 8.590037mm);wire (51.382137mm 8.590037mm) (52.293960mm 8.747332mm);wire (52.293960mm 8.747332mm) (53.192009mm 8.976750mm);wire (53.192009mm 8.976750mm) (54.072000mm 9.270792mm);wire (54.072000mm 9.270792mm) (54.930780mm 9.619998mm);wire (54.930780mm 9.619998mm) (55.766540mm 10.013369mm);wire (55.766540mm 10.013369mm) (56.578936mm 10.438865mm);wire (56.578936mm 10.438865mm) (57.369127mm 10.883943mm);wire (57.369127mm 10.883943mm) (58.139720mm 11.336115mm);wire (58.139720mm 11.336115mm) (58.894625mm 11.783497mm);wire (58.894625mm 11.783497mm) (59.638829mm 12.215328mm);wire (59.638829mm 12.215328mm) (60.378095mm 12.622436mm);wire (60.378095mm 12.622436mm) (61.118607mm 12.997616mm);wire (61.118607mm 12.997616mm) (61.866583mm 13.335925mm);wire (61.866583mm 13.335925mm) (62.627865mm 13.634861mm);wire (62.627865mm 13.634861mm) (63.407522mm 13.894436mm);wire (63.407522mm 13.894436mm) (64.209486mm 14.117119mm);wire (64.209486mm 14.117119mm) (65.036229mm 14.307683mm);wire (65.036229mm 14.307683mm) (65.888523mm 14.472936mm);wire (65.888523mm 14.472936mm) (66.765278mm 14.621364mm);wire (66.765278mm 14.621364mm) (67.663480mm 14.762706mm);wire (67.663480mm 14.762706mm) (68.578231mm 14.907479mm);wire (68.578231mm 14.907479mm) (69.502893mm 15.066467mm);wire (69.502893mm 15.066467mm) (70.429331mm 15.250218mm);wire (70.429331mm 15.250218mm) (71.348249mm 15.468556mm);wire (71.348249mm 15.468556mm) (72.249589mm 15.730139mm);wire (72.249589mm 15.730139mm) (73.122998mm 16.042083mm);wire (73.122998mm 16.042083mm) (73.958315mm 16.409663mm);wire (73.958315mm 16.409663mm) (74.746074mm 16.836114mm);wire (74.746074mm 16.836114mm) (75.477983mm 17.322527mm);wire (75.477983mm 17.322527mm) (76.147363mm 17.867857mm);wire (76.147363mm 17.867857mm) (76.749519mm 18.469026mm);wire (76.749519mm 18.469026mm) (77.282021mm 19.121122mm);wire (77.282021mm 19.121122mm) (77.744889mm 19.817687mm);wire (77.744889mm 19.817687mm) (78.140653mm 20.551059mm);wire (78.140653mm 20.551059mm) (78.474300mm 21.312775mm);wire (78.474300mm 21.312775mm) (78.753095mm 22.093989mm);wire (78.753095mm 22.093989mm) (78.986288mm 22.885902mm);wire (78.986288mm 22.885902mm) (79.184720mm 23.680172mm);wire (79.184720mm 23.680172mm) (79.360345mm 24.469288mm);wire (79.360345mm 24.469288mm) (79.525678mm 25.246890mm);wire (79.525678mm 25.246890mm) (79.693221mm 26.008012mm);wire (79.693221mm 26.008012mm) (79.874859mm 26.749253mm);wire (79.874859mm 26.749253mm) (80.081293mm 27.468855mm);wire (80.081293mm 27.468855mm) (80.321502mm 28.166694mm);wire (80.321502mm 28.166694mm) (80.602284mm 28.844183mm);wire (80.602284mm 28.844183mm) (80.927898mm 29.504096mm);wire (80.927898mm 29.504096mm) (81.299807mm 30.150328mm);wire (81.299807mm 30.150328mm) (81.716555mm 30.787598mm);wire (81.716555mm 30.787598mm) (82.173782mm 31.421116mm);wire (82.173782mm 31.421116mm) (82.664367mm 32.056241mm);wire (82.664367mm 32.056241mm) (83.178706mm 32.698134mm);wire (83.178706mm 32.698134mm) (83.705110mm 33.351437mm);wire (83.705110mm 33.351437mm) (84.230298mm 34.019991mm);wire (84.230298mm 34.019991mm) (84.739974mm 34.706610mm);wire (84.739974mm 34.706610mm) (85.219454mm 35.412919mm);wire (85.219454mm 35.412919mm) (85.654317mm 36.139268mm);wire (85.654317mm 36.139268mm) (86.031050mm 36.884724mm);wire (86.031050mm 36.884724mm) (86.337649mm 37.647145mm);wire (86.337649mm 37.647145mm) (86.564165mm 38.423316mm);wire (86.564165mm 38.423316mm) (86.703151mm 39.209161mm);wire (86.703151mm 39.209161mm) (86.750000mm 40.000000mm);move LED1 (92.000000mm 40.000000mm);move LED2 (90.117959mm 45.559803mm);move LED3 (86.503419mm 50.378095mm);move LED4 (84.198582mm 55.246917mm);move LED5 (82.860680mm 60.890346mm);move LED6 (79.698485mm 65.986174mm);move LED7 (73.874681mm 68.753095mm);move LED8 (67.425048mm 69.923759mm);move LED9 (61.860680mm 71.940492mm);move LED10 (56.354060mm 75.103214mm);move LED11 (50.000000mm 76.750000mm);move LED12 (43.645940mm 75.103214mm);move LED13 (38.139320mm 71.940492mm);move LED14 (32.574952mm 69.923759mm);move LED15 (26.125319mm 68.753095mm);move LED16 (20.301515mm 65.986174mm);move LED17 (17.139320mm 60.890346mm);move LED18 (15.801418mm 55.246917mm);move LED19 (13.496581mm 50.378095mm);move LED20 (9.882041mm 45.559803mm);move LED21 (8.000000mm 40.000000mm);move LED22 (9.882041mm 34.440197mm);move LED23 (13.496581mm 29.621905mm);move LED24 (15.801418mm 24.753083mm);move LED25 (17.139320mm 19.109654mm);move LED26 (20.301515mm 14.013826mm);move LED27 (26.125319mm 11.246905mm);move LED28 (32.574952mm 10.076241mm);move LED29 (38.139320mm 8.059508mm);move LED30 (43.645940mm 4.896786mm);move LED31 (50.000000mm 3.250000mm);move LED32 (56.354060mm 4.896786mm);move LED33 (61.860680mm 8.059508mm);move LED34 (67.425048mm 10.076241mm);move LED35 (73.874681mm 11.246905mm);move LED36 (79.698485mm 14.013826mm);move LED37 (82.860680mm 19.109654mm);move LED38 (84.198582mm 24.753083mm);move LED39 (86.503419mm 29.621905mm);move LED40 (90.117959mm 34.440197mm);
