***************************************************************** * Modifiziertes Grundmodell: * ============ * * To improve convergence in LTSpice: * H&E-Sources replaced by shunted B-Sources * LIMIT() replaced by soft limit UpLim/DnLim * Series resistance added to C_PAR * VDR voltage calculation simplified * * Minor Changes: * Include R_SERIES within L_SERIES * Parameter Uliml/Ulimh replaces E_SW_L/E_SW_H * Upper current limit moved to B_I_SENSE * Linear resistance R_LIN added to suppress * simulation artifacts at zero crossing * Extended with low/high decision to support MLV-E Series model too * *================================================================ .SUBCKT SIOV 1 2 PARAMS: T=1 C=1pF L=1nH + B1=1 B2=1 B3=0 B4=0 + B1L={B1} B2L={B2} B3L={B3} B4L={B4} + B1H={B1} B2H={B2} B3H={B3} B4H={B4} .param tis=10n, Ris=10k, Cis=tis/Ris ;tau, R and C current sense .param logRis=log10(Ris) ;match log10(i)-X with Ris .param tvar=100p, Rvar=1, Cvar=tvar/Rvar ;tau, R and C main source, Rvar=1 calculates much faster, but ;affects pulse current and frequency response seriously .param Ilim=100n ;linear range current limit .param Uliml=ui_siovh(Ilim*Ris) ;linear range voltage limit .param Ulimsl=Uliml*10m ;soft limit zone .param Rlinl=Uliml/Ilim ;resulting linear resistance .param Rlincl=Rlinl/Ris ;to calculate real linear voltage from boosted is node .param Ulimh=ui_siovl(Ilim*Ris) ;upper range .param Ulimsh=Ulimh*10m .param Rlinh=Ulimh/Ilim .param Rlinch=Rlinh/Ris * Circuit L_SERIES 1 4 {L} Rser=100n V_I_SENSE 4 5 0 B_I_SENSE 0 is I=UpLim(I(V_I_SENSE), 10Meg, 10k) ;upper soft limit C_I_SENSE is 0 {Cis} Rpar={Ris} C_PAR 4 2 {C} Rser=1m R_LIN 5 2 {Rlinl} ;use lower range B_VAR 2 5 I=T*(if(abs(I(V_I_SENSE))<=1m, b_varl(V(is)), b_varh(V(is))))/Rvar ;match source resistance C_VAR 5 2 {Cvar} Rpar={Rvar} * Main function, lower (<=1mA) and upper range for MLV-E Series * calculates linear range and the VDR curve using absolute values of i (mirrored at i0), combines both with * soft limits and returns the properly signed voltage .func b_varl(i) sgn(i)*UpLim(abs(i)*Rlincl, DnLim(ui_siovl(abs(i)), Uliml, Ulimsl), Ulimsl) .func b_varh(i) sgn(i)*UpLim(abs(i)*Rlinch, DnLim(ui_siovh(abs(i)), Ulimh, Ulimsh), Ulimsh) * General SIOV U(I) characteristic, parameter i expected to be 10k times the actual value * at least there is no difference in LTspice, but the calculation * is probably more accurate for low currents .func ui_siovl(i) PWR(10, + B1L+ + B2L*(LOG10(i)-logRis)+ + B3L*EXP(-LOG10(i)+logRis)+ + B4L*EXP(LOG10(i)-logRis) + ) .func ui_siovh(i) PWR(10, + B1H+ + B2H*(LOG10(i)-logRis)+ + B3H*EXP(-LOG10(i)+logRis)+ + B4H*EXP(LOG10(i)-logRis) + ) .ENDS
