library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.numeric_std.ALL; ---- Uncomment the following library declaration if instantiating ---- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity sram_modul is port( clk : in std_logic; clk_led: out std_logic; sram_data_led : out std_logic_vector(0 to 4) ); end sram_modul; architecture Behavioral of sram_modul is signal write_counter: unsigned (7 downto 0); signal we_oe_change : unsigned (2 downto 0); signal sig_clk_led: std_logic; begin process(clk) begin if clk='1' and clk'event then if sig_clk_led = '0' then sig_clk_led <= '1'; else sig_clk_led <= '0'; end if; case we_oe_change is when "000" => if write_counter < 6 then write_counter <= write_counter + 1; sram_data_led <= "00000"; else we_oe_change <= "011"; end if; when "001" => sram_data_led <= "01010"; when others => sram_data_led <= "01110"; end case; end if; end process; clk_led <= sig_clk_led; end Behavioral; WARNING:Xst:646 - Signal is assigned but never used. WARNING:Cpld:310 - Cannot apply TIMESPEC TS1000 = PERIOD:PERIOD_clk:0.000 nS WARNING:Cpld:2 - Cannot apply TIMESPEC AUTO_TS_F2F =
