test1.cof: file format coff-ext-avr D:\_Elektronik\WinAVR\Test1/test1.c: typedef int16 int; int main () { /* 0x4a */ /* file D:\_Elektronik\WinAVR\Test1/test1.c line 4 addr 0x4a */ { /* 0x52 */ register uint8 counter /* 0x12 */; /* file D:\_Elektronik\WinAVR\Test1/test1.c line 7 addr 0x52 */ /* file D:\_Elektronik\WinAVR\Test1/test1.c line 11 addr 0x56 */ /* file D:\_Elektronik\WinAVR\Test1/test1.c line 13 addr 0x58 */ { /* 0x5a */ register uint16 __count /* 0x18 */; /* file D:\_Elektronik\WinAVR\Test1/test1.c line 17 addr 0x5a */ /* file D:\_Elektronik\WinAVR\Test1/test1.c line 50 addr 0x5a */ /* file D:\_Elektronik\WinAVR\Test1/test1.c line 51 addr 0x5e */ } /* 0x62 */ /* file D:\_Elektronik\WinAVR\Test1/test1.c line 18 addr 0x62 */ /* file D:\_Elektronik\WinAVR\Test1/test1.c line 21 addr 0x68 */ /* file D:\_Elektronik\WinAVR\Test1/test1.c line 23 addr 0x6a */ { /* 0x6c */ register uint16 __count /* 0x18 */; /* file D:\_Elektronik\WinAVR\Test1/test1.c line 27 addr 0x6c */ /* file D:\_Elektronik\WinAVR\Test1/test1.c line 50 addr 0x6c */ /* file D:\_Elektronik\WinAVR\Test1/test1.c line 51 addr 0x70 */ } /* 0x74 */ /* file D:\_Elektronik\WinAVR\Test1/test1.c line 28 addr 0x74 */ } /* 0x7c */ } /* 0x7c */ typedef uint8 unsigned char; typedef uint16 unsigned int; : typedef void void; void __vector_1 /* 0x48 */; void _etext /* 0x7c */; void __bad_interrupt /* 0x48 */; void __data_load_end /* 0x7c */; void __vector_6 /* 0x48 */; void __vector_3 /* 0x48 */; void __data_load_start /* 0x7c */; void __dtors_end /* 0x16 */; void __bss_end /* 0x60 */; void __init /* 0x16 */; void __vector_7 /* 0x48 */; void __do_clear_bss /* 0x36 */; void __eeprom_end /* 0x0 */; void __vectors /* 0x0 */; void __data_end /* 0x60 */; void __vector_default /* 0x0 */; void __vector_5 /* 0x48 */; void __ctors_start /* 0x16 */; void __do_copy_data /* 0x1e */; void __bss_start /* 0x60 */; void __vector_4 /* 0x48 */; void __heap_end /* 0x0 */; void __vector_9 /* 0x48 */; void __vector_2 /* 0x48 */; void __dtors_start /* 0x16 */; void __ctors_end /* 0x16 */; void __stack /* 0xdf */; void _edata /* 0x60 */; void _end /* 0x60 */; void __vector_8 /* 0x48 */; void __vector_10 /* 0x48 */; void __data_start /* 0x60 */;
