***************************************************************** * OSRAM OS * * PSPICE Library for Phototransistor * * Version 08/2011 / hh * ***************************************************************** * internet : www.osram-os.com * ***************************************************************** * * * Models provided by OSRAM are not warranted by OSRAM as * * fully representing all the specifications and operating * * characteristics of the semiconductor product to which the * * model relates. The models describe the characteristics of * * typical devices. * * In all cases, the current data sheet information for a given * * device is the final design guideline and the only actual * * performance specification. * * Although models can be a useful tool in evaluating device * * performance, they cannot model exact device performance under * * all conditions, nor are they intended to replace bread- * * boarding for final verification. OSRAM therefore does not * * assume any liability arising from their use. * * OSRAM reserves the right to change models without prior * * notice. * * * ***************************************************************** * * * This library contains models of the following OSRAM * * photodiodes * * 1. enhanced models (parts may be not available any more) * * F003 * * BPX-38 BPX-43 * * F049 * * SFH-3410 SFH-3710 SFH-3310 * * F092 * * SFH-309 SFH-320 SFH-3211 SFH-3219 * * SFH-325 * * F144 * * SFH-314 SFH-3400 SFH-3401 SFH-313 * * SFH-3201 SFH-3500 * * F351 * * SFH-3010 SFH-3600 SFH-3605 SFH-3204 * * SFH-3015 * * F431 * * SFH-300 SFH-305 SFH-3100 SFH-303 * * LPT-80 BPY-62 BP-103 BPX-80 * * BPX-81 BPX-83 BPX-84 BPX-85 * * BPX-86 BPX-87 BPX-88 BPX-89 * * SFH-310 * *---------------------------------------------------------------* * connections: optical input(+) * * | optical input(-) * * | | Collector * * | | | Emitter * * | | | | * *.subckt SFHXXXX Opt_In+ Opt_In- Coll Emit * * * * for BP103, BPX38, BPX43, BPY62, SFH303 and SFH3401 only: * * connections: optical input(+) * * | optical input(-) * * | | Collector * * | | | Base * * | | | | Emitter * * | | | | | * *.subckt SFHXXXX Opt_In+ Opt_In- Coll Base Emit * *---------------------------------------------------------------* * optical input: * * connect voltage source between optical input(+) and * * optical input(-) with voltage representing * * irradiance (1 mV represents 1 mW/cm2) * * For default (no light), set both optical inputs to * * ground (0) = 0VDC * * base: * * for default, connect base node via R=10G to GND(0)/Emitter * *---------------------------------------------------------------* * parameter SENS: * * the subcircuit also contains a parameter that may * * be changed/handed over by the user: * * SENS = rel. spectral sensitivity in % for the wavelength * * of interest normalized to the peak rel. sensitivity * * default = 100 (%). Needs to be adapted according to * * datasheet for wavelength of interest * * For standard IR phototransistor 100(%) works * * typ. well for 850-950 nm * * For ambient light sensors 100(%) refers to * * around 550 nm * * RESP = photocurrent / irradiance, * * e.g. 50uA/1mW/cm2 = 50e-3 (mA/(mW/cm2)) * * usually this parameter don’t need to be changed * * *1e-2 to compensate for percentage in SENS * * LENS = lens-factor, defaut = 1 for no lens * *---------------------------------------------------------------* * The model includes parameters for: * * 1) forward direction (Vcollector > Vemitter) * * The model has limited accuracy for: * * 2) near-saturation and saturation condition * * 3) base transit time (dynamic behavor) * * 4) noise * * 5) intrinsic optical-electrical conversion frequ. response * ***************************************************************** *F003 **** BPX38 SENS=100 at 880nm, lens=1 **** BASE CONNECTION .subckt BPX38 Opt_In+ Opt_In- Base Coll Emit +params: SENS=100 resp=3.6e-5 lens=1 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F003 .MODEL F003 NPN (IS=4.92e-14 BF=220 NF=1.035 VAF=468 + ISE=4.92e-14 NE=2 RE=1.42 RC=43 IKF=130e-3 + CJE=5.37E-11 MJE=0.347 VJE=0.69 FC=0.5 CJC=3.67E-12 + MJC=0.43 VJC=0.481 TF=12e-9) .ends ***************************************************************** **** BPX43 SENS=100 at 880nm, lens=6.4 **** BASE CONNECTION .subckt BPX43 Opt_In+ Opt_In- Base Coll Emit +params: SENS=100 resp=3.6e-5 lens=6.4 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F003 .MODEL F003 NPN (IS=4.92e-14 BF=220 NF=1.035 VAF=468 + ISE=4.92e-14 NE=2 RE=1.42 RC=43 IKF=130e-3 + CJE=5.37E-11 MJE=0.347 VJE=0.69 FC=0.5 CJC=3.67E-12 + MJC=0.43 VJC=0.481 TF=12e-9) .ends ***************************************************************** *F049 **** SFH3410 SENS=100 at 570nm, lens=1 * NO BASE .subckt SFH3410 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=1e-5 lens=1 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F049 .MODEL F049 NPN (IS=6.12e-15 BF=480 NF=1.053 VAF=25.6 + ISE=6.12E-15 NE=2 RE=19.8 RC=13 + CJE=3.98E-12 MJE=0.234 VJE=0.696 FC=0.5 CJC=7.07E-11 + MJC=0.312 VJC=0.539 TF=1e-13) .ends ***************************************************************** **** SFH3710 SENS=100 at 570nm, lens=1 * NO BASE .subckt SFH3710 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=1e-5 lens=1 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F049 .MODEL F049 NPN (IS=6.12e-15 BF=480 NF=1.053 VAF=25.6 + ISE=6.12E-15 NE=2 RE=19.8 RC=13 + CJE=3.98E-12 MJE=0.234 VJE=0.696 FC=0.5 CJC=7.07E-11 + MJC=0.312 VJC=0.539 TF=1e-13) .ends ***************************************************************** **** SFH3310 SENS=100 at 570nm, lens=1 * NO BASE .subckt SFH3310 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=1e-5 lens=1 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F049 .MODEL F049 NPN (IS=6.12e-15 BF=480 NF=1.053 VAF=25.6 + ISE=6.12E-15 NE=2 RE=19.8 RC=13 + CJE=3.98E-12 MJE=0.234 VJE=0.696 FC=0.5 CJC=7.07E-11 + MJC=0.312 VJC=0.539 TF=1e-13) .ends ***************************************************************** ***************************************************************** **** SFH309 SENS=100 at 860nm, lens=11 * NO BASE .subckt SFH309 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=7.18e-6 lens=11 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F092 .MODEL F092 NPN(IS=22.500E-15 BF=714.44 NF=1.0100 VAF=93.200 + IKF=10.010E-3 ISE=22.500E-15 NE=1.7206 VAR=300 NK=.2987 RE=59.2 + CJE=9.212E-12 MJE=0.286 VJE=0.627 FC=0.5 CJC=8.735E-12 + MJC=0.275 VJC=0.467 TF=0.1E-9) .ends ***************************************************************** **** SFH320 SENS=100 at 980nm, lens=1 * NO BASE .subckt SFH320 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=7.18e-6 lens=1 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F092 .MODEL F092 NPN(IS=22.500E-15 BF=714.44 NF=1.0100 VAF=93.200 + IKF=10.010E-3 ISE=22.500E-15 NE=1.7206 VAR=300 NK=.2987 RE=59.2 + CJE=9.212E-12 MJE=0.286 VJE=0.627 FC=0.5 CJC=8.735E-12 + MJC=0.275 VJC=0.467 TF=0.1E-9) .ends ***************************************************************** **** SFH3211 SENS=100 at 980nm, lens=1 * NO BASE .subckt SFH3211 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=7.18e-6 lens=1 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F092 .MODEL F092 NPN(IS=22.500E-15 BF=714.44 NF=1.0100 VAF=93.200 + IKF=10.010E-3 ISE=22.500E-15 NE=1.7206 VAR=300 NK=.2987 RE=59.2 + CJE=9.212E-12 MJE=0.286 VJE=0.627 FC=0.5 CJC=8.735E-12 + MJC=0.275 VJC=0.467 TF=0.1E-9) .ends ***************************************************************** **** SFH3219 SENS=100 at 990nm, lens=4 * NO BASE .subckt SFH3219 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=7.18e-6 lens=4 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F092 .MODEL F092 NPN(IS=22.500E-15 BF=714.44 NF=1.0100 VAF=93.200 + IKF=10.010E-3 ISE=22.500E-15 NE=1.7206 VAR=300 NK=.2987 RE=59.2 + CJE=9.212E-12 MJE=0.286 VJE=0.627 FC=0.5 CJC=8.735E-12 + MJC=0.275 VJC=0.467 TF=0.1E-9) .ends ***************************************************************** **** SFH325 SENS=100 at 980nm, lens=1 * NO BASE .subckt SFH325 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=7.18e-6 lens=1 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F092 .MODEL F092 NPN(IS=22.500E-15 BF=714.44 NF=1.0100 VAF=93.200 + IKF=10.010E-3 ISE=22.500E-15 NE=1.7206 VAR=300 NK=.2987 RE=59.2 + CJE=9.212E-12 MJE=0.286 VJE=0.627 FC=0.5 CJC=8.735E-12 + MJC=0.275 VJC=0.467 TF=0.1E-9) .ends ***************************************************************** ***************************************************************** *F144 **** SFH314 SENS=100 at 850nm, lens=2.8 * NO BASE .subckt SFH314 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=2.5e-5 lens=2.8 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F144 .MODEL F144 NPN (IS=6.02e-14 BF=510 NF=1.043 VAF=229 + IKF=61E-3 ISE=6.02E-14 NE=2 RE=2.84 + CJE=1.96E-11 MJE=0.336 VJE=0.671 FC=0.5 CJC=3.87E-11 + MJC=0.445 VJC=0.539 TF=0.1e-13) .ends ***************************************************************** **** SFH3400 SENS=100 at 850nm, lens=1 * NO BASE .subckt SFH3400 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=2.5e-5 lens=1 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F144 .MODEL F144 NPN (IS=6.02e-14 BF=510 NF=1.043 VAF=229 + IKF=61E-3 ISE=6.02E-14 NE=2 RE=2.84 + CJE=1.96E-11 MJE=0.336 VJE=0.671 FC=0.5 CJC=3.87E-11 + MJC=0.445 VJC=0.539 TF=0.1e-13) .ends ***************************************************************** **** SFH3401 SENS=100 at 850nm, lens=1 **** BASE CONNECTION .subckt SFH3401 Opt_In+ Opt_In- Base Coll Emit +params: SENS=100 resp=2.5e-5 lens=1 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F144 .MODEL F144 NPN (IS=6.02e-14 BF=510 NF=1.043 VAF=229 + IKF=61E-3 ISE=6.02E-14 NE=2 RE=2.84 + CJE=1.96E-11 MJE=0.336 VJE=0.671 FC=0.5 CJC=3.87E-11 + MJC=0.445 VJC=0.539 TF=0.1e-13) .ends ***************************************************************** **** SFH313 SENS=100 at 850nm, lens=10 * NO BASE .subckt SFH313 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=2.5e-5 lens=10 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F144 .MODEL F144 NPN (IS=6.02e-14 BF=510 NF=1.043 VAF=229 + IKF=61E-3 ISE=6.02E-14 NE=2 RE=2.84 + CJE=1.96E-11 MJE=0.336 VJE=0.671 FC=0.5 CJC=3.87E-11 + MJC=0.445 VJC=0.539 TF=0.1e-13) .ends ***************************************************************** **** SFH3201 SENS=100 at 850nm, lens=1 * NO BASE .subckt SFH3201 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=2.5e-5 lens=1 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F144 .MODEL F144 NPN (IS=6.02e-14 BF=510 NF=1.043 VAF=229 + IKF=61E-3 ISE=6.02E-14 NE=2 RE=2.84 + CJE=1.96E-11 MJE=0.336 VJE=0.671 FC=0.5 CJC=3.87E-11 + MJC=0.445 VJC=0.539 TF=0.1e-13) .ends ***************************************************************** **** SFH3500 SENS=100 at 850nm, lens=10 * NO BASE .subckt SFH3500 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=2.5e-5 lens=10 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F144 .MODEL F144 NPN (IS=6.02e-14 BF=510 NF=1.043 VAF=229 + IKF=61E-3 ISE=6.02E-14 NE=2 RE=2.84 + CJE=1.96E-11 MJE=0.336 VJE=0.671 FC=0.5 CJC=3.87E-11 + MJC=0.445 VJC=0.539 TF=0.1e-13) .ends ***************************************************************** ***************************************************************** **** F351 SENS=100 at 880nm *** SFH 3010, SENS = 100 at 860 nm, lens = 1 * NO BASE .subckt SFH3010 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=3.16e-6 lens=1 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F351 .MODEL F351 NPN (IS=21E-15 BF=898 NF=1.02 VAF=62 IKF=81.2E-3 + ISE=21E-15 NE=1.998 VAR=300 NK=0.595 CJE=5.4E-12 MJE=0.3 + VJE=0.627 FC=0.5 CJC=7.1E-12 MJC=0.306 VJC=0.503 TF=2.000E-9) .ends ***************************************************************** *** SFH 3600, SENS = 100 at 990 nm, lens = 8 * NO BASE .subckt SFH3600 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=3.16e-6 lens=8 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F351 .MODEL F351 NPN (IS=21E-15 BF=898 NF=1.02 VAF=62 IKF=81.2E-3 + ISE=21E-15 NE=1.998 VAR=300 NK=0.595 CJE=5.4E-12 MJE=0.3 + VJE=0.627 FC=0.5 CJC=7.1E-12 MJC=0.306 VJC=0.503 TF=2.000E-9) .ends ***************************************************************** *** SFH 3605, SENS = 100 at 990 nm, lens = 8 * NO BASE .subckt SFH3605 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=3.16e-6 lens=8 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F351 .MODEL F351 NPN (IS=21E-15 BF=898 NF=1.02 VAF=62 IKF=81.2E-3 + ISE=21E-15 NE=1.998 VAR=300 NK=0.595 CJE=5.4E-12 MJE=0.3 + VJE=0.627 FC=0.5 CJC=7.1E-12 MJC=0.306 VJC=0.503 TF=2.000E-9) .ends ***************************************************************** *** SFH 3204, SENS = 100 at 920 nm, lens = 3 * NO BASE .subckt SFH3204 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=3.16e-6 lens=3 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F351 .MODEL F351 NPN (IS=21E-15 BF=898 NF=1.02 VAF=62 IKF=81.2E-3 + ISE=21E-15 NE=1.998 VAR=300 NK=0.595 CJE=5.4E-12 MJE=0.3 + VJE=0.627 FC=0.5 CJC=7.1E-12 MJC=0.306 VJC=0.503 TF=2.000E-9) .ends ***************************************************************** *** SFH 3015, SENS = 100 at 870 nm, lens = 11 * NO BASE .subckt SFH3015 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=3.16e-6 lens=11 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F351 .MODEL F351 NPN (IS=21E-15 BF=898 NF=1.02 VAF=62 IKF=81.2E-3 + ISE=21E-15 NE=1.998 VAR=300 NK=0.595 CJE=5.4E-12 MJE=0.3 + VJE=0.627 FC=0.5 CJC=7.1E-12 MJC=0.306 VJC=0.503 TF=2.000E-9) .ends ***************************************************************** ***************************************************************** **** SFH300 SENS=100 at 880nm, lens=6.2 * NO BASE .subckt SFH300 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=2.13e-5 lens=6.2 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F431 .MODEL F431 NPN (IS=20.000E-15 BF=223.74 NF=1.0100 VAF=315 + IKF=.93501 ISE=41.698E-15 NE=1.9980 VAR=300 RE=34.400 RC=17.600 + CJE=25.058E-12 MJE=0.332 VJE=0.678 FC=0.5 CJC=2.0000E-12 + MJC=0.350 VJC=0.545 TF=6.5E-9) .ends ***************************************************************** **** SFH305 SENS=100 at 850nm, lens=2.5 * NO BASE .subckt SFH305 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=2.13e-5 lens=2.5 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F431 .MODEL F431 NPN (IS=20.000E-15 BF=223.74 NF=1.0100 VAF=315 + IKF=.93501 ISE=41.698E-15 NE=1.9980 VAR=300 RE=34.400 RC=17.600 + CJE=25.058E-12 MJE=0.332 VJE=0.678 FC=0.5 CJC=2.0000E-12 + MJC=0.350 VJC=0.545 TF=6.5E-9) .ends ***************************************************************** **** SFH3100 SENS=100 at 920nm, lens=7 * NO BASE .subckt SFH3100 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=2.13e-5 lens=7 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F431 .MODEL F431 NPN (IS=20.000E-15 BF=223.74 NF=1.0100 VAF=315 + IKF=.93501 ISE=41.698E-15 NE=1.9980 VAR=300 RE=34.400 RC=17.600 + CJE=25.058E-12 MJE=0.332 VJE=0.678 FC=0.5 CJC=2.0000E-12 + MJC=0.350 VJC=0.545 TF=6.5E-9) .ends ***************************************************************** **** SFH303 SENS=100 at 990nm, lens=4 **** BASE CONNECTION .subckt SFH303 Opt_In+ Opt_In- Base Coll Emit +params: SENS=100 resp=2.13e-5 lens=4 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F431 .MODEL F431 NPN (IS=20.000E-15 BF=383.74 NF=1.0100 VAF=315 + IKF=.93501 ISE=41.698E-15 NE=1.9980 VAR=300 RE=34.400 RC=17.600 + CJE=25.058E-12 MJE=0.332 VJE=0.678 FC=0.5 CJC=2.0000E-12 + MJC=0.350 VJC=0.545 TF=6.5E-9) .ends ***************************************************************** **** LPT80 SENS=100 at 880nm, lens=3 * NO BASE .subckt LPT80 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=2.13e-5 lens=3 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F431 .MODEL F431 NPN (IS=20.000E-15 BF=223.74 NF=1.0100 VAF=315 + IKF=.93501 ISE=41.698E-15 NE=1.9980 VAR=300 RE=34.400 RC=17.600 + CJE=25.058E-12 MJE=0.332 VJE=0.678 FC=0.5 CJC=2.0000E-12 + MJC=0.350 VJC=0.545 TF=6.5E-9) .ends ***************************************************************** **** BPY62 SENS=100 at 830nm, lens=5.5 **** BASE CONNECTION .subckt BPY62 Opt_In+ Opt_In- Base Coll Emit +params: SENS=100 resp=2.13e-5 lens=5.5 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F431 .MODEL F431 NPN (IS=20.000E-15 BF=223.74 NF=1.0100 VAF=315 + IKF=.93501 ISE=41.698E-15 NE=1.9980 VAR=300 RE=34.400 RC=17.600 + CJE=25.058E-12 MJE=0.332 VJE=0.678 FC=0.5 CJC=2.0000E-12 + MJC=0.350 VJC=0.545 TF=6.5E-9) .ends ***************************************************************** **** BP103 SENS=100 at 850nm, lens=1 **** BASE CONNECTION .subckt BP103 Opt_In+ Opt_In- Base Coll Emit +params: SENS=100 resp=2.13e-5 lens=1 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F431 .MODEL F431 NPN (IS=20.000E-15 BF=223.74 NF=1.0100 VAF=315 + IKF=.93501 ISE=41.698E-15 NE=1.9980 VAR=300 RE=34.400 RC=17.600 + CJE=25.058E-12 MJE=0.332 VJE=0.678 FC=0.5 CJC=2.0000E-12 + MJC=0.350 VJC=0.545 TF=6.5E-9) .ends ***************************************************************** **** BPX8x SENS=100 at 850nm, lens=2.5 * NO BASE .subckt BPX8x Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=2.13e-5 lens=2.5 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F431 .MODEL F431 NPN (IS=20.000E-15 BF=223.74 NF=1.0100 VAF=315 + IKF=.93501 ISE=41.698E-15 NE=1.9980 VAR=300 RE=34.400 RC=17.600 + CJE=25.058E-12 MJE=0.332 VJE=0.678 FC=0.5 CJC=2.0000E-12 + MJC=0.350 VJC=0.545 TF=6.5E-9) .ends ***************************************************************** **** BPX81 SENS=100 at 850nm, lens=2.5 * NO BASE .subckt BPX81 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=2.13e-5 lens=2.5 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F431 .MODEL F431 NPN (IS=20.000E-15 BF=223.74 NF=1.0100 VAF=315 + IKF=.93501 ISE=41.698E-15 NE=1.9980 VAR=300 RE=34.400 RC=17.600 + CJE=25.058E-12 MJE=0.332 VJE=0.678 FC=0.5 CJC=2.0000E-12 + MJC=0.350 VJC=0.545 TF=6.5E-9) .ends ***************************************************************** **** SFH310 SENS=100 at 880nm, lens=8 * NO BASE .subckt SFH310 Opt_In+ Opt_In- Coll Emit +params: SENS=100 resp=2.13e-5 lens=8 G001 Emit Base Opt_In+ Opt_In- {SENS*resp*lens} Q001 Coll Base Emit F431 .MODEL F431 NPN (IS=20.000E-15 BF=223.74 NF=1.0100 VAF=315 + IKF=.93501 ISE=41.698E-15 NE=1.9980 VAR=300 RE=34.400 RC=17.600 + CJE=25.058E-12 MJE=0.332 VJE=0.678 FC=0.5 CJC=2.0000E-12 + MJC=0.350 VJC=0.545 TF=6.5E-9) .ends *****************************************************************
