<?php
//Check for Update - return newest version
function checkUpdate()
	//Check on GitHub for new Update
	$API_CALL = 'https://api.github.com/repos/jbtronics/Part-DB/releases';
	$context  = stream_context_create(array('http' => array('user_agent' => 'Get Releases')));
	$response = json_decode(file_get_contents($API_CALL, false, $context), true);
	return $response[0]['tag_name'];
//Download zipped update from source - returns downloaded bytes, error, or 'already downloaded'
function downloadUpdate($newestVersion)
	//Generate Update-Link
	if($newestVersion != 'nextgen')
		if(file_exists($newestVersion . '.zip'))
			return 'Update bereits heruntergeladen.';
		else
			$link = "https://github.com/jbtronics/Part-DB/archive/" . $newestVersion . ".zip";
	elseif($newestVersion == 'nextgen')
		$link = "https://github.com/jbtronics/Part-DB/archive/nextgen.zip";
	//Download Update from $link
	if(isset($link))
		return file_put_contents($newestVersion . '.zip',file_get_contents($link));
	else
		return false;
//Deletes recursive all data from the path $dirname except the files and folders listet in array $deleteExceptions
function rmdirr($dirname, $deleteExceptions)
    // Sanity check
    if (!file_exists($dirname)) {
        return false;
    // Simple delete for a file
    if (is_file($dirname) || is_link($dirname)) {
        return unlink($dirname);
    // Loop through the folder
    $dir = dir($dirname);
    while (false !== $entry = $dir->read()) {
        // Skip pointers
        if ($entry == '.' || $entry == '..' || $entry == 'test.php' || in_array($entry, $deleteExceptions)) {
            continue;
        // Recurse
        rmdirr($dirname . DIRECTORY_SEPARATOR . $entry, $deleteExceptions);
    // Clean up
    $dir->close();
	if($dirname != getcwd())
		return rmdir($dirname);
//Writes the new data from $newestVersion.zip to $dirname except the files and folders listet in array $unzipExceptions
function unzipUpdate($dirname, $newestVersion, $unzipExceptions)
	$updatePath = $newestVersion . '.zip';
	//Check for Update-File
	if(!file_exists($updatePath))
		return 'Keine ZIP-Archive gefunden';
	//Proceed with Update
	else
		$zipPaths = array();
		$zip = new ZipArchive;
		//Reading all Paths from ZIP
		if($zip->open($updatePath) == TRUE)
			for($i = 1; $i < $zip->numFiles; $i++)
				$zipPaths[] = $zip->getNameIndex($i);
			//Alle PATHS durchlaufen
			foreach($zipPaths as $zipPath)
				foreach($unzipExceptions as $exception)
					if(strpos($zipPath, $exception) !== false)
						//zipPath überspringen da in Ausnahme enthalten
						$skip = TRUE;
				//UNZIP
				//if $zipPath is a file, move that file from zip to target
				if(!(substr($zipPath, -1) == '/') && !$skip)
					//Generate UnZip-Target Path
					$target = $dirname . '/' . explode('/', $zipPath, 2)[1];
					$fp = $zip->getStream($zipPath);
					$ofp = fopen($target, 'w');
					while(!feof($fp)) 
						fwrite($ofp, fread($fp, 8192));
					fclose($fp); 
					fclose($ofp);
					//Set rights for files
					chmod($target, 0444);
				//if $zipPath is a folder, create a new folder to $target
				elseif((substr($zipPath, -1) == '/') && !$skip)
					mkdir($target, 0555, true);
				$skip = FALSE;
			$zip->close();
			//Delete ZIP-File
			unlink($updatePath);
			return TRUE;
		else
			//open zip failed
			return FALSE;
