Version 4 SHEET 1 1892 1708 WIRE 320 16 -48 16 WIRE 608 16 320 16 WIRE 320 48 320 16 WIRE 608 96 608 16 WIRE 320 144 320 112 WIRE -48 240 -48 16 WIRE 80 240 80 176 WIRE 112 240 80 240 WIRE 208 240 192 240 WIRE 320 240 320 208 WIRE 320 240 272 240 WIRE 320 304 320 240 WIRE 608 320 608 176 WIRE 80 368 80 240 WIRE 320 400 320 368 WIRE 464 400 464 368 WIRE 464 400 320 400 WIRE 560 400 464 400 WIRE 464 448 464 400 WIRE -48 560 -48 320 WIRE 80 560 80 448 WIRE 80 560 -48 560 WIRE 464 560 464 528 WIRE 464 560 80 560 WIRE 608 560 608 416 WIRE 608 560 464 560 WIRE -48 592 -48 560 FLAG -48 592 0 FLAG 464 368 Vgate FLAG 80 176 MCout SYMBOL voltage -48 224 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V1 SYMATTR Value 3.7 SYMBOL voltage 80 352 R0 WINDOW 3 -13 248 Left 2 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V2 SYMATTR Value PULSE(0.2 3.5 2m 0.1u 0.1u 10u 20u 10) SYMBOL diode 304 304 R0 SYMATTR InstName D1 SYMATTR Value 1N4148 SYMBOL res 592 80 R0 SYMATTR InstName Last SYMATTR Value 3.7 SYMBOL res 208 224 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R1 SYMATTR Value 100 SYMBOL cap 272 224 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 32 32 VTop 2 SYMATTR InstName C2 SYMATTR Value 100n SYMBOL diode 304 48 R0 SYMATTR InstName D2 SYMATTR Value 1N4148 SYMBOL res 448 432 R0 SYMATTR InstName R3 SYMATTR Value 47k SYMBOL diode 304 144 R0 SYMATTR InstName D3 SYMATTR Value 1N4148 SYMBOL nmos 560 320 R0 SYMATTR InstName M1 SYMATTR Value irfz44n SYMATTR Prefix X SYMATTR Value2 irfz44n TEXT -82 632 Left 2 !.tran 10m TEXT 768 24 Left 2 !.SUBCKT irfz44n 1 2 3\n**************************************\n* Model Generated by MODPEX *\n*Copyright(c) Symmetry Design Systems*\n* All Rights Reserved *\n* UNPUBLISHED LICENSED SOFTWARE *\n* Contains Proprietary Information *\n* Which is The Property of *\n* SYMMETRY OR ITS LICENSORS *\n*Commercial Use or Resale Restricted *\n* by Symmetry License Agreement *\n**************************************\n* Model generated on Apr 24, 96\n* Model format: SPICE3\n* Symmetry POWER MOS Model (Version 1.0)\n* External Node Designations\n* Node 1 -> Drain\n* Node 2 -> Gate\n* Node 3 -> Source\nM1 9 7 8 8 MM L=100u W=100u\n* Default values used in MM:\n* The voltage-dependent capacitances are\n* not included. Other default values are:\n* RS=0 RD=0 LD=0 CBD=0 CBS=0 CGBO=0\n.MODEL MM NMOS LEVEL=1 IS=1e-32\n+VTO=3.56214 LAMBDA=0 KP=39.3974\n+CGSO=1.25255e-05 CGDO=2.2826e-07\nRS 8 3 0.0133305\nD1 3 1 MD\n.MODEL MD D IS=9.64635e-13 RS=0.00967689 N=1.01377 BV=55\n+IBV=0.00025 EG=1.08658 XTI=2.9994 TT=1e-07\n+CJO=1.39353e-09 VJ=0.5 M=0.42532 FC=0.5\nRDS 3 1 2.2e+06\nRD 9 1 0.0001\nRG 2 7 2.20235\nD2 4 5 MD1\n* Default values used in MD1:\n* RS=0 EG=1.11 XTI=3.0 TT=0\n* BV=infinite IBV=1mA\n.MODEL MD1 D IS=1e-32 N=50\n+CJO=1.52875e-09 VJ=0.5 M=0.584414 FC=1e-08\nD3 0 5 MD2\n* Default values used in MD2:\n* EG=1.11 XTI=3.0 TT=0 CJO=0\n* BV=infinite IBV=1mA\n.MODEL MD2 D IS=1e-10 N=0.408752 RS=3e-06\nRL 5 10 1\nFI2 7 9 VFI2 -1\nVFI2 4 0 0\nEV16 10 0 9 7 1\nCAP 11 10 2.06741e-09\nFI1 7 9 VFI1 -1\nVFI1 11 6 0\nRCAP 6 10 1\nD4 0 6 MD3\n* Default values used in MD3:\n* EG=1.11 XTI=3.0 TT=0 CJO=0\n* RS=0 BV=infinite IBV=1mA\n.MODEL MD3 D IS=1e-10 N=0.408752\n.ENDS
