(module TTB_Power (layer F.Cu) (tedit 57827189)
  (fp_text reference REF** (at 0 6.1) (layer F.SilkS)
    (effects (font (size 1.016 1.016) (thickness 0.1524)))
  (fp_text value TTB_Power (at 0 -9.9) (layer F.Fab)
  (fp_line (start 4.5 -8.8) (end 2.8 -8.8) (layer F.SilkS) (width 0.15))
  (fp_line (start -2.8 -8.8) (end -4.5 -8.8) (layer F.SilkS) (width 0.15))
  (fp_line (start -4.5 -8.8) (end -4.5 5) (layer F.SilkS) (width 0.15))
  (fp_line (start 4.5 -3) (end 4.5 5) (layer F.SilkS) (width 0.15))
  (fp_line (start 4.5 -8.4) (end 4.5 -8.8) (layer F.SilkS) (width 0.15))
  (fp_line (start 0.4 4) (end 1.05 4) (layer F.SilkS) (width 0.1))
  (fp_line (start -1.05 4) (end -0.4 4) (layer F.SilkS) (width 0.1))
  (fp_line (start 1.05 4) (end 1.05 3) (layer F.SilkS) (width 0.1))
  (fp_line (start 1.05 2) (end 1.05 0) (layer F.SilkS) (width 0.1))
  (fp_line (start 1.05 -1) (end 1.05 -1.2) (layer F.SilkS) (width 0.1))
  (fp_line (start -1.05 4) (end -1.05 3) (layer F.SilkS) (width 0.1))
  (fp_line (start -1.05 2) (end -1.05 0) (layer F.SilkS) (width 0.1))
  (fp_line (start -1.05 -1) (end -1.05 -1.2) (layer F.SilkS) (width 0.1))
  (fp_line (start 3.15 5) (end 3.15 3) (layer F.SilkS) (width 0.1))
  (fp_line (start 3.15 2) (end 3.15 0) (layer F.SilkS) (width 0.1))
  (fp_line (start 3.15 -1) (end 3.15 -2) (layer F.SilkS) (width 0.1))
  (fp_line (start -3.15 -1) (end -3.15 -2) (layer F.SilkS) (width 0.1))
  (fp_line (start -3.15 2) (end -3.15 0) (layer F.SilkS) (width 0.1))
  (fp_line (start 3.15 -2) (end 2.7 -2) (layer F.SilkS) (width 0.1))
  (fp_line (start -3.15 -2) (end -2.7 -2) (layer F.SilkS) (width 0.1))
  (fp_line (start -3.15 5) (end -3.15 3) (layer F.SilkS) (width 0.1))
  (fp_line (start -4.5 5) (end 4.5 5) (layer F.SilkS) (width 0.15))
  (pad 1 thru_hole oval (at 0 -8.8) (size 5 2.2) (drill oval 3.2 0.8) (layers *.Cu *.Mask))
  (pad 2 thru_hole oval (at 0 -2.6) (size 5 2.2) (drill oval 2.6 0.8) (layers *.Cu *.Mask))
  (pad 3 thru_hole oval (at 5 -5.7) (size 2.2 5) (drill oval 0.8 2.6) (layers *.Cu *.Mask))
  (model Connect.3dshapes/JACK_ALIM.wrl
    (at (xyz 0 0.1 0))
    (scale (xyz 0.8 0.8 0.8))
    (rotate (xyz 0 0 270))
