(module LED_LT-G6SP_Osram_RevA_07Nov2017 (layer F.Cu) (tedit 5A0201FD)
  (fp_text reference H (at 0 5.25) (layer F.SilkS)
    (effects (font (size 1 1) (thickness 0.15)))
  (fp_text value LED_LT-G6SP_Thermals_Osram_RevA_07Nov2017 (at -0.05 -6) (layer F.Fab) hide
  (fp_line (start 2.5 2.5) (end 2.5 2.3) (layer F.SilkS) (width 0.25))
  (fp_line (start 2.3 2.5) (end 2.5 2.5) (layer F.SilkS) (width 0.25))
  (fp_line (start -2 -1.8) (end -2 1.8) (layer F.CrtYd) (width 0.25))
  (fp_line (start 2 -1.8) (end 2 1.8) (layer F.CrtYd) (width 0.25))
  (fp_line (start -2 1.8) (end 2 1.8) (layer F.CrtYd) (width 0.25))
  (fp_line (start -2 -1.8) (end 2 -1.8) (layer F.CrtYd) (width 0.25))
  (fp_line (start 1.95 -0.4) (end 1.95 0.4) (layer F.SilkS) (width 0.25))
  (fp_line (start -1.95 -0.4) (end -1.95 0.4) (layer F.SilkS) (width 0.25))
  (pad 4 smd roundrect (at 0 0) (size 1.6 0.8) (layers F.Adhes)(roundrect_rratio 0.25))
  (pad 1 thru_hole rect (at 2 3) (size 1.2 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at 3 3) (size 1.2 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at 3 2) (size 1.2 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at 2 2) (size 1 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at -3 2) (size 1.2 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at -3 3) (size 1.2 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at -2 3) (size 1.2 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at -2 2) (size 1 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at 3 -2) (size 1.2 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at 3 -3) (size 1.2 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at 2 -3) (size 1.2 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at 2 -2) (size 1 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at -2 -2) (size 1 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at -3 -2) (size 1.2 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at -2 -3) (size 1.2 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 thru_hole rect (at -3 -3) (size 1.2 1.2) (drill 0.6) (layers *.Cu))
  (pad 1 smd rect (at 2.15 2.2) (size 3 3) (layers B.Cu))
  (pad 1 smd rect (at 2.15 -2.2) (size 3 3) (layers B.Cu))
  (pad 1 smd rect (at -2.15 2.2) (size 3 3) (layers B.Cu))
  (pad 1 smd rect (at -2.15 -2.2) (size 3 3) (layers B.Cu))
  (pad 1 smd rect (at -2.15 2.2) (size 3 3) (layers F.Cu))
  (pad 1 smd rect (at 2.15 2.2) (size 3 3) (layers F.Cu))
  (pad 1 smd rect (at 2.15 -2.2) (size 3 3) (layers F.Cu))
  (pad 1 smd rect (at -2.15 -2.2) (size 3 3) (layers F.Cu))
  (pad 3 smd rect (at 0 1.525) (size 0.6 1.65) (layers F.Cu F.Paste F.Mask)
    (solder_mask_margin -0.1) (solder_paste_margin -0.1))
  (pad 2 smd rect (at 0 -1.525) (size 0.6 1.65) (layers F.Cu F.Paste F.Mask)
  (pad 1 smd rect (at 1.05 -1.525) (size 0.8 1.65) (layers F.Cu F.Paste F.Mask)
  (pad 1 smd rect (at 1.05 1.525) (size 0.8 1.65) (layers F.Cu F.Paste F.Mask)
  (pad 1 smd rect (at -1.05 -1.525) (size 0.8 1.65) (layers F.Cu F.Paste F.Mask)
  (pad 1 smd rect (at -1.05 1.525) (size 0.8 1.65) (layers F.Cu F.Paste F.Mask)
