(module LED_Osram_Adv_TOPLED (layer F.Cu) (tedit 5A02C5C9)
  (fp_text reference REF** (at 0 -3.5) (layer F.SilkS)
    (effects (font (size 1 1) (thickness 0.15)))
  (fp_text value LED_Osram_Adv_TOPLED (at 0 3.5) (layer F.Fab)
  (fp_line (start 1.75 -0.5) (end 1.75 0.5) (layer F.SilkS) (width 0.1))
  (fp_line (start -0.85 -0.55) (end -0.8 -0.25) (layer F.Mask) (width 0))
  (fp_line (start -0.45 -0.5) (end -0.85 -0.55) (layer F.Mask) (width 0))
  (fp_line (start -1.65 1.5) (end -1.65 -1.5) (layer F.CrtYd) (width 0.254))
  (fp_line (start 1.65 1.5) (end -1.65 1.5) (layer F.CrtYd) (width 0.254))
  (fp_line (start 1.65 -1.5) (end 1.65 1.5) (layer F.CrtYd) (width 0.254))
  (fp_line (start -1.65 -1.5) (end 1.65 -1.5) (layer F.CrtYd) (width 0.254))
  (fp_circle (center 2 2) (end 2 2.1) (layer F.SilkS) (width 0.1))
  (fp_line (start 0.29 -2.35) (end 0.3 -2.35) (layer F.Paste) (width 0.01))
  (fp_line (start -1.75 -0.5) (end -1.75 0.5) (layer F.SilkS) (width 0.1))
  (pad 2 smd rect (at 2.65 2.7) (size 4 4) (layers F.Cu))
  (pad DNC smd rect (at 0 2.7) (size 0.6 4) (layers F.Cu F.Paste)
    (zone_connect 0))
  (pad 2 smd rect (at -2.65 2.7) (size 4 4) (layers F.Cu))
  (pad 2 smd rect (at -2.65 -2.7) (size 4 4) (layers F.Cu))
  (pad 2 smd rect (at 2.65 -2.7) (size 4 4) (layers F.Cu F.Paste))
  (pad 1 smd rect (at 0 -2.7) (size 0.6 4) (layers F.Cu))
  (pad 2 smd rect (at -0.95 -1.425) (size 0.6 1.45) (layers F.Mask))
  (pad 2 smd rect (at 0.95 -1.425) (size 0.6 1.45) (layers F.Mask))
  (pad 2 smd rect (at 0.95 1.425) (size 0.6 1.45) (layers F.Mask))
  (pad 2 smd rect (at -0.95 1.425) (size 0.6 1.45) (layers F.Mask))
  (pad DNC smd rect (at 0 1.425) (size 0.6 1.45) (layers F.Mask))
  (pad 1 smd rect (at 0 -1.425) (size 0.6 1.45) (layers F.Mask))
  (pad 2 smd rect (at -1.05 -1.525) (size 0.8 1.65) (layers F.Paste))
  (pad 2 smd rect (at 1.05 -1.525) (size 0.8 1.65) (layers F.Paste))
  (pad 2 smd rect (at 1.05 1.525) (size 0.8 1.65) (layers F.Paste))
  (pad 2 smd rect (at -1.05 1.525) (size 0.8 1.65) (layers F.Paste))
  (pad 1 smd rect (at 0 -1.525) (size 0.6 1.65) (layers F.Paste))
