(module LED_Osram_Adv_TOPLED (layer F.Cu) (tedit 5A0550E3)
  (fp_text reference REF** (at 0 -3) (layer F.SilkS)
    (effects (font (size 0.5 0.5) (thickness 0.075)))
  (fp_text value VAL** (at 0 3) (layer F.Fab)
  (fp_line (start 1.75 -0.5) (end 1.75 0.5) (layer F.SilkS) (width 0.1))
  (fp_line (start -0.85 -0.55) (end -0.8 -0.25) (layer F.Mask) (width 0))
  (fp_line (start -0.45 -0.5) (end -0.85 -0.55) (layer F.Mask) (width 0))
  (fp_line (start -1.65 1.5) (end -1.65 -1.5) (layer F.CrtYd) (width 0.254))
  (fp_line (start 1.65 1.5) (end -1.65 1.5) (layer F.CrtYd) (width 0.254))
  (fp_line (start 1.65 -1.5) (end 1.65 1.5) (layer F.CrtYd) (width 0.254))
  (fp_line (start -1.65 -1.5) (end 1.65 -1.5) (layer F.CrtYd) (width 0.254))
  (fp_circle (center 2 2) (end 2 2.1) (layer F.SilkS) (width 0.1))
  (fp_line (start 0.29 -2.35) (end 0.3 -2.35) (layer F.Paste) (width 0.01))
  (fp_line (start -1.75 -0.5) (end -1.75 0.5) (layer F.SilkS) (width 0.1))
  (pad 2 smd rect (at 2.15 2.2) (size 3 3) (layers F.Cu))
  (pad DNC smd rect (at 0 2.2) (size 0.6 3) (layers F.Cu)
    (zone_connect 0))
  (pad 2 smd rect (at -2.15 2.2) (size 3 3) (layers F.Cu))
  (pad 2 smd rect (at -2.15 -2.2) (size 3 3) (layers F.Cu))
  (pad 2 smd rect (at 2.15 -2.2) (size 3 3) (layers F.Cu))
  (pad 1 smd rect (at 0 -2.2) (size 0.6 3) (layers F.Cu))
  (pad 2 smd rect (at -0.95 -1.425) (size 0.6 1.45) (layers F.Mask))
  (pad 2 smd rect (at 0.95 -1.425) (size 0.6 1.45) (layers F.Mask))
  (pad 2 smd rect (at 0.95 1.425) (size 0.6 1.45) (layers F.Mask))
  (pad 2 smd rect (at -0.95 1.425) (size 0.6 1.45) (layers F.Mask))
  (pad DNC smd rect (at 0 1.425) (size 0.6 1.45) (layers F.Mask))
  (pad 1 smd rect (at 0 -1.425) (size 0.6 1.45) (layers F.Mask))
  (pad 2 smd rect (at -1.05 -1.525) (size 0.8 1.65) (layers F.Paste))
  (pad 2 smd rect (at 1.05 -1.525) (size 0.8 1.65) (layers F.Paste))
  (pad 2 smd rect (at 1.05 1.525) (size 0.8 1.65) (layers F.Paste))
  (pad 2 smd rect (at -1.05 1.525) (size 0.8 1.65) (layers F.Paste))
  (pad 1 smd rect (at 0 -1.525) (size 0.6 1.65) (layers F.Paste))
  (pad DNC smd rect (at 0 1.525) (size 0.6 1.65) (layers F.Paste))
  (model C:/Users/Florian/Documents/Projekte/shared_soft/kicad_libs.pretty/LED_Osram_Adv_TOPLED.wrl
    (at (xyz 0 0 0.06900000000000001))
    (scale (xyz 0.393701 0.393701 0.393701))
    (rotate (xyz 0 0 0))
