Version 4 SHEET 1 2248 1708 WIRE 320 16 -48 16 WIRE 608 16 320 16 WIRE 320 32 320 16 WIRE 608 96 608 16 WIRE 320 112 320 96 WIRE 320 208 320 176 WIRE -48 240 -48 16 WIRE 112 256 80 256 WIRE 608 256 608 176 WIRE 640 256 608 256 WIRE 320 288 320 272 WIRE 608 320 608 256 WIRE 80 400 80 256 WIRE 128 400 80 400 WIRE 224 400 208 400 WIRE 320 400 320 352 WIRE 320 400 288 400 WIRE 464 400 464 368 WIRE 464 400 320 400 WIRE 560 400 464 400 WIRE 80 448 80 400 WIRE 464 448 464 400 WIRE -48 560 -48 320 WIRE 80 560 80 528 WIRE 80 560 -48 560 WIRE 464 560 464 528 WIRE 464 560 80 560 WIRE 608 560 608 416 WIRE 608 560 464 560 WIRE -48 592 -48 560 FLAG -48 592 0 FLAG 464 368 Gate IOPIN 464 368 In FLAG 640 256 Out IOPIN 640 256 Out FLAG 112 256 MC-out IOPIN 112 256 In SYMBOL voltage -48 224 R0 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR InstName V1 SYMATTR Value 3.7 SYMBOL voltage 80 432 R0 WINDOW 3 0 173 Left 2 WINDOW 123 0 0 Left 2 WINDOW 39 0 0 Left 2 SYMATTR Value PULSE(0.2 3.5 20m 1u 1u 16m 32m 5) SYMATTR InstName V2 SYMBOL res 592 80 R0 SYMATTR InstName Last SYMATTR Value 1k SYMBOL res 224 384 R90 WINDOW 0 0 56 VBottom 2 WINDOW 3 32 56 VTop 2 SYMATTR InstName R1 SYMATTR Value 220 SYMBOL cap 288 384 R90 WINDOW 0 0 32 VBottom 2 WINDOW 3 32 32 VTop 2 SYMATTR InstName C2 SYMATTR Value 150n SYMBOL diode 304 112 R0 SYMATTR InstName D2 SYMATTR Value 1N4148 SYMBOL res 448 432 R0 SYMATTR InstName R3 SYMATTR Value 1Meg SYMBOL nmos 560 320 R0 SYMATTR InstName M1 SYMATTR Value IRF1010N SYMATTR Prefix X SYMATTR Value2 IRF1010N SYMBOL diode 304 208 R0 SYMATTR InstName D1 SYMBOL diode 304 288 R0 SYMATTR InstName D3 SYMBOL diode 304 32 R0 SYMATTR InstName D4 TEXT -80 632 Left 2 !.tran 200m TEXT 768 24 Left 2 !.SUBCKT irf1010n 1 2 3\n**************************************\n* Model Generated by MODPEX *\n*Copyright(c) Symmetry Design Systems*\n* All Rights Reserved *\n* UNPUBLISHED LICENSED SOFTWARE *\n* Contains Proprietary Information *\n* Which is The Property of *\n* SYMMETRY OR ITS LICENSORS *\n*Commercial Use or Resale Restricted *\n* by Symmetry License Agreement *\n**************************************\n* Model generated on Mar 24, 01\n* MODEL FORMAT: SPICE3\n* Symmetry POWER MOS Model (Version 1.0)\n* External Node Designations\n* Node 1 -> Drain\n* Node 2 -> Gate\n* Node 3 -> Source\nM1 9 7 8 8 MM L=100u W=100u\n.MODEL MM NMOS LEVEL=1 IS=1e-32\n+VTO=3.64178 LAMBDA=0 KP=115.276\n+CGSO=3.00969e-05 CGDO=1.17481e-08\nRS 8 3 0.00757655\nD1 3 1 MD\n.MODEL MD D IS=8.38397e-11 RS=0.0043176 N=1.1863 BV=55\n+IBV=0.00025 EG=1.2 XTI=4 TT=4.24995e-07\n+CJO=1.91846e-09 VJ=4.94006 M=0.696882 FC=0.489612\nRDS 3 1 1e+06\nRD 9 1 0.0001\nRG 2 7 4.03401\nD2 4 5 MD1\n* Default values used in MD1:\n* RS=0 EG=1.11 XTI=3.0 TT=0\n* BV=infinite IBV=1mA\n.MODEL MD1 D IS=1e-32 N=50\n+CJO=2.6014e-09 VJ=1.21238 M=0.9 FC=1e-08\nD3 0 5 MD2\n* Default values used in MD2:\n* EG=1.11 XTI=3.0 TT=0 CJO=0\n* BV=infinite IBV=1mA\n.MODEL MD2 D IS=1e-10 N=0.400216 RS=3e-06\nRL 5 10 1\nFI2 7 9 VFI2 -1\nVFI2 4 0 0\nEV16 10 0 9 7 1\nCAP 11 10 3.78367e-09\nFI1 7 9 VFI1 -1\nVFI1 11 6 0\nRCAP 6 10 1\nD4 0 6 MD3\n* Default values used in MD3:\n* EG=1.11 XTI=3.0 TT=0 CJO=0\n* RS=0 BV=infinite IBV=1mA\n.MODEL MD3 D IS=1e-10 N=0.400216\n.ENDS irf1010n
