pi@raspberrypi:/ $ journalctl -xe Dez 21 20:54:01 raspberrypi CRON[8575]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 20:54:01 raspberrypi CRON[8579]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/lcd.php && python /var/www/rennergy/scripts/hz_lcd.py) Dez 21 20:54:05 raspberrypi CRON[8575]: pam_unix(cron:session): session closed for user root Dez 21 20:55:01 raspberrypi CRON[8606]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 20:55:01 raspberrypi CRON[8610]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 20:55:01 raspberrypi CRON[8623]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/lcd.php && python /var/www/rennergy/scripts/hz_lcd.py) Dez 21 20:55:01 raspberrypi CRON[8608]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 20:55:01 raspberrypi CRON[8609]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 20:55:01 raspberrypi CRON[8607]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 20:55:01 raspberrypi CRON[8630]: (root) CMD (/usr/bin/rw_rsp_sql.sh >/dev/null 2>&1 ) Dez 21 20:55:01 raspberrypi CRON[8632]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/gen_rss_short.php >/dev/null 2>&1) Dez 21 20:55:01 raspberrypi CRON[8631]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/gen_rss.php >/dev/null 2>&1) Dez 21 20:55:01 raspberrypi CRON[8633]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/push.php >/var/log/push.log) Dez 21 20:55:03 raspberrypi CRON[8610]: pam_unix(cron:session): session closed for user root Dez 21 20:55:03 raspberrypi CRON[8608]: pam_unix(cron:session): session closed for user root Dez 21 20:55:03 raspberrypi CRON[8609]: pam_unix(cron:session): session closed for user root Dez 21 20:55:04 raspberrypi CRON[8607]: pam_unix(cron:session): session closed for user root Dez 21 20:55:05 raspberrypi CRON[8606]: pam_unix(cron:session): session closed for user root Dez 21 20:56:01 raspberrypi CRON[8728]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 20:56:01 raspberrypi CRON[8732]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/lcd.php && python /var/www/rennergy/scripts/hz_lcd.py) Dez 21 20:56:04 raspberrypi CRON[8728]: pam_unix(cron:session): session closed for user root Dez 21 20:57:01 raspberrypi CRON[8756]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 20:57:01 raspberrypi CRON[8760]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/lcd.php && python /var/www/rennergy/scripts/hz_lcd.py) Dez 21 20:57:05 raspberrypi CRON[8756]: pam_unix(cron:session): session closed for user root Dez 21 20:58:01 raspberrypi CRON[8797]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 20:58:01 raspberrypi CRON[8801]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/lcd.php && python /var/www/rennergy/scripts/hz_lcd.py) Dez 21 20:58:05 raspberrypi CRON[8797]: pam_unix(cron:session): session closed for user root Dez 21 20:59:01 raspberrypi CRON[8824]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 20:59:01 raspberrypi CRON[8828]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/lcd.php && python /var/www/rennergy/scripts/hz_lcd.py) Dez 21 20:59:05 raspberrypi CRON[8824]: pam_unix(cron:session): session closed for user root Dez 21 21:00:01 raspberrypi CRON[8857]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 21:00:01 raspberrypi CRON[8858]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 21:00:01 raspberrypi CRON[8874]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/lcd.php && python /var/www/rennergy/scripts/hz_lcd.py) Dez 21 21:00:01 raspberrypi CRON[8861]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 21:00:01 raspberrypi CRON[8875]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/push.php >/var/log/push.log) Dez 21 21:00:01 raspberrypi CRON[8859]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 21:00:01 raspberrypi CRON[8860]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 21:00:01 raspberrypi CRON[8880]: (root) CMD (/usr/bin/rw_rsp_sql.sh >/dev/null 2>&1 ) Dez 21 21:00:01 raspberrypi CRON[8881]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/gen_rss.php >/dev/null 2>&1) Dez 21 21:00:01 raspberrypi CRON[8883]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/gen_rss_short.php >/dev/null 2>&1) Dez 21 21:00:03 raspberrypi CRON[8861]: pam_unix(cron:session): session closed for user root Dez 21 21:00:03 raspberrypi CRON[8860]: pam_unix(cron:session): session closed for user root Dez 21 21:00:03 raspberrypi CRON[8859]: pam_unix(cron:session): session closed for user root Dez 21 21:00:04 raspberrypi CRON[8858]: pam_unix(cron:session): session closed for user root Dez 21 21:00:04 raspberrypi CRON[8857]: pam_unix(cron:session): session closed for user root Dez 21 21:01:01 raspberrypi CRON[8977]: pam_unix(cron:session): session opened for user root by (uid=0) Dez 21 21:01:01 raspberrypi CRON[8981]: (root) CMD (sleep 2s && /usr/bin/php5 /var/www/rennergy/scripts/lcd.php && python /var/www/rennergy/scripts/hz_lcd.py) Dez 21 21:01:05 raspberrypi CRON[8977]: pam_unix(cron:session): session closed for user root lines 1603-1650/1650 (END) pi@raspberrypi:/ $ systemctl status grafana-server ● grafana.service - Starts and stops a single grafana instance on this system Loaded: loaded (/lib/systemd/system/grafana.service; enabled; vendor preset: enabled) Active: active (running) since Thu 2017-12-21 18:49:20 CET; 2h 12min ago Docs: http://docs.grafana.org Main PID: 405 (grafana) CGroup: /system.slice/grafana.service └─405 /usr/sbin/grafana --config=/etc/grafana/grafana.ini cfg:default.paths.logs=/var/log/grafana cfg:default.paths.data=/var/lib/grafana Dez 21 18:49:21 raspberrypi grafana[405]: data: /var/lib/grafana Dez 21 18:49:21 raspberrypi grafana[405]: logs: /var/log/grafana Dez 21 18:49:21 raspberrypi grafana[405]: 2017/12/21 18:49:21 [I] Database: sqlite3 Dez 21 18:49:22 raspberrypi grafana[405]: 2017/12/21 18:49:21 [I] Migrator: Starting DB migration Dez 21 18:49:22 raspberrypi grafana[405]: 2017/12/21 18:49:22 [I] Listen: http://0.0.0.0:3000 Dez 21 18:51:39 raspberrypi grafana[405]: 2017/12/21 18:51:39 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 4150us Dez 21 18:59:05 raspberrypi grafana[405]: 2017/12/21 18:59:05 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 4712us Dez 21 19:36:47 raspberrypi grafana[405]: 2017/12/21 19:36:47 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 4014us Dez 21 20:16:11 raspberrypi grafana[405]: 2017/12/21 20:16:11 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 7307us Dez 21 20:23:19 raspberrypi grafana[405]: 2017/12/21 20:23:19 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 4209us
