pi@raspberrypi:/var/log/grafana $ ls -la insgesamt 20 drwxr-xr-x 2 grafana grafana 4096 Dez 21 18:30 . drwxr-xr-x 12 root root 4096 Dez 22 06:25 .. -rw-r----- 1 grafana grafana 10623 Dez 21 21:48 grafana.log -rw-r----- 1 grafana grafana 0 Dez 21 21:27 xorm.log pi@raspberrypi:/var/log/grafana $ sudo cat xorm.log pi@raspberrypi:/var/log/grafana $ -->scheint leer zu sein pi@raspberrypi:/var/log/grafana $ sudo cat grafana.log --> 2017/12/21 18:29:48 [I] Starting Grafana 2017/12/21 18:29:48 [I] Version: master, Commit: NA, Build date: 1970-01-01 01:00:00 +0100 CET 2017/12/21 18:29:48 [I] Configuration Info Config files: [0]: /usr/share/grafana/conf/defaults.ini [1]: /etc/grafana/grafana.ini Command lines overrides: [0]: default.paths.data=/var/lib/grafana [1]: default.paths.logs=/var/log/grafana Paths: home: /usr/share/grafana data: /var/lib/grafana logs: /var/log/grafana 2017/12/21 18:29:48 [I] Database: sqlite3 2017/12/21 18:29:48 [I] Migrator: Starting DB migration 2017/12/21 18:29:48 [I] Migrator: exec migration id: create migration_log table 2017/12/21 18:29:48 [I] Migrator: exec migration id: create user table 2017/12/21 18:29:48 [I] Migrator: exec migration id: add unique index user.login 2017/12/21 18:29:48 [I] Migrator: exec migration id: add unique index user.email 2017/12/21 18:29:48 [I] Migrator: exec migration id: drop index UQE_user_login - v1 2017/12/21 18:29:49 [I] Migrator: exec migration id: drop index UQE_user_email - v1 2017/12/21 18:29:49 [I] Migrator: exec migration id: Rename table user to user_v1 - v1 2017/12/21 18:29:49 [I] Migrator: exec migration id: create user table v2 2017/12/21 18:29:49 [I] Migrator: exec migration id: create index UQE_user_login - v2 2017/12/21 18:29:49 [I] Migrator: exec migration id: create index UQE_user_email - v2 2017/12/21 18:29:49 [I] Migrator: exec migration id: copy data_source v1 to v2 2017/12/21 18:29:50 [I] Migrator: exec migration id: Drop old table user_v1 2017/12/21 18:29:51 [I] Migrator: exec migration id: create temp user table v1-7 2017/12/21 18:29:51 [I] Migrator: exec migration id: create index IDX_temp_user_email - v1-7 2017/12/21 18:29:51 [I] Migrator: exec migration id: create index IDX_temp_user_org_id - v1-7 2017/12/21 18:29:51 [I] Migrator: exec migration id: create index IDX_temp_user_code - v1-7 2017/12/21 18:29:51 [I] Migrator: exec migration id: create index IDX_temp_user_status - v1-7 2017/12/21 18:29:51 [I] Migrator: exec migration id: create star table 2017/12/21 18:29:51 [I] Migrator: exec migration id: add unique index star.user_id_dashboard_id 2017/12/21 18:29:52 [I] Migrator: exec migration id: create org table v1 2017/12/21 18:29:52 [I] Migrator: exec migration id: create index UQE_org_name - v1 2017/12/21 18:29:52 [I] Migrator: exec migration id: create org_user table v1 2017/12/21 18:29:52 [I] Migrator: exec migration id: create index IDX_org_user_org_id - v1 2017/12/21 18:29:52 [I] Migrator: exec migration id: create index UQE_org_user_org_id_user_id - v1 2017/12/21 18:29:55 [I] Migrator: exec migration id: copy data account to org 2017/12/21 18:29:55 [I] Migrator: skipping migration id: copy data account to org, condition not fulfilled 2017/12/21 18:29:55 [I] Migrator: exec migration id: copy data account_user to org_user 2017/12/21 18:29:55 [I] Migrator: skipping migration id: copy data account_user to org_user, condition not fulfilled 2017/12/21 18:29:55 [I] Migrator: exec migration id: Drop old table account 2017/12/21 18:29:55 [I] Migrator: exec migration id: Drop old table account_user 2017/12/21 18:29:55 [I] Migrator: exec migration id: create dashboard table 2017/12/21 18:29:55 [I] Migrator: exec migration id: add index dashboard.account_id 2017/12/21 18:29:55 [I] Migrator: exec migration id: add unique index dashboard_account_id_slug 2017/12/21 18:29:55 [I] Migrator: exec migration id: create dashboard_tag table 2017/12/21 18:29:55 [I] Migrator: exec migration id: add unique index dashboard_tag.dasboard_id_term 2017/12/21 18:29:55 [I] Migrator: exec migration id: drop index UQE_dashboard_tag_dashboard_id_term - v1 2017/12/21 18:29:55 [I] Migrator: exec migration id: Rename table dashboard to dashboard_v1 - v1 2017/12/21 18:29:55 [I] Migrator: exec migration id: create dashboard v2 2017/12/21 18:29:55 [I] Migrator: exec migration id: create index IDX_dashboard_org_id - v2 2017/12/21 18:29:55 [I] Migrator: exec migration id: create index UQE_dashboard_org_id_slug - v2 2017/12/21 18:29:55 [I] Migrator: exec migration id: copy dashboard v1 to v2 2017/12/21 18:29:55 [I] Migrator: exec migration id: drop table dashboard_v1 2017/12/21 18:29:55 [I] Migrator: exec migration id: alter dashboard.data to mediumtext v1 2017/12/21 18:29:55 [I] Migrator: exec migration id: create data_source table 2017/12/21 18:29:55 [I] Migrator: exec migration id: add index data_source.account_id 2017/12/21 18:29:55 [I] Migrator: exec migration id: add unique index data_source.account_id_name 2017/12/21 18:29:55 [I] Migrator: exec migration id: drop index IDX_data_source_account_id - v1 2017/12/21 18:29:55 [I] Migrator: exec migration id: drop index UQE_data_source_account_id_name - v1 2017/12/21 18:29:58 [I] Migrator: exec migration id: Rename table data_source to data_source_v1 - v1 2017/12/21 18:29:58 [I] Migrator: exec migration id: create data_source table v2 2017/12/21 18:29:58 [I] Migrator: exec migration id: create index IDX_data_source_org_id - v2 2017/12/21 18:29:58 [I] Migrator: exec migration id: create index UQE_data_source_org_id_name - v2 2017/12/21 18:29:58 [I] Migrator: exec migration id: copy data_source v1 to v2 2017/12/21 18:29:58 [I] Migrator: exec migration id: Drop old table data_source_v1 #2 2017/12/21 18:29:58 [I] Migrator: exec migration id: Add column with_credentials 2017/12/21 18:29:58 [I] Migrator: exec migration id: create api_key table 2017/12/21 18:29:58 [I] Migrator: exec migration id: add index api_key.account_id 2017/12/21 18:29:58 [I] Migrator: exec migration id: add index api_key.key 2017/12/21 18:29:58 [I] Migrator: exec migration id: add index api_key.account_id_name 2017/12/21 18:29:58 [I] Migrator: exec migration id: drop index IDX_api_key_account_id - v1 2017/12/21 18:29:58 [I] Migrator: exec migration id: drop index UQE_api_key_key - v1 2017/12/21 18:29:58 [I] Migrator: exec migration id: drop index UQE_api_key_account_id_name - v1 2017/12/21 18:29:58 [I] Migrator: exec migration id: Rename table api_key to api_key_v1 - v1 2017/12/21 18:29:58 [I] Migrator: exec migration id: create api_key table v2 2017/12/21 18:29:58 [I] Migrator: exec migration id: create index IDX_api_key_org_id - v2 2017/12/21 18:29:58 [I] Migrator: exec migration id: create index UQE_api_key_key - v2 2017/12/21 18:29:58 [I] Migrator: exec migration id: create index UQE_api_key_org_id_name - v2 2017/12/21 18:29:59 [I] Migrator: exec migration id: copy api_key v1 to v2 2017/12/21 18:30:00 [I] Migrator: exec migration id: Drop old table api_key_v1 2017/12/21 18:30:00 [I] Migrator: exec migration id: create dashboard_snapshot table v4 2017/12/21 18:30:00 [I] Migrator: exec migration id: drop table dashboard_snapshot_v4 #1 2017/12/21 18:30:00 [I] Migrator: exec migration id: create dashboard_snapshot table v5 #2 2017/12/21 18:30:00 [I] Migrator: exec migration id: create index UQE_dashboard_snapshot_key - v5 2017/12/21 18:30:00 [I] Migrator: exec migration id: create index UQE_dashboard_snapshot_delete_key - v5 2017/12/21 18:30:00 [I] Migrator: exec migration id: create index IDX_dashboard_snapshot_user_id - v5 2017/12/21 18:30:00 [I] Migrator: exec migration id: alter dashboard_snapshot to mediumtext v2 2017/12/21 18:30:00 [I] Migrator: exec migration id: create quota table v1 2017/12/21 18:30:00 [I] Migrator: exec migration id: create index UQE_quota_org_id_user_id_target - v1 2017/12/21 18:30:01 [I] Created default admin user: admin 2017/12/21 18:30:01 [I] Listen: http://0.0.0.0:3000 2017/12/21 18:31:09 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 4197us 2017/12/21 18:34:22 [I] Completed 192.168.178.40 - "GET /favicon.ico HTTP/1.1" 404 Not Found 2189 bytes in 5192us 2017/12/21 18:34:49 [I] Received signal terminated. shutting down 2017/12/21 18:34:57 [I] Starting Grafana 2017/12/21 18:34:57 [I] Version: master, Commit: NA, Build date: 1970-01-01 01:00:00 +0100 CET 2017/12/21 18:34:57 [I] Configuration Info Config files: [0]: /usr/share/grafana/conf/defaults.ini [1]: /etc/grafana/grafana.ini Command lines overrides: [0]: default.paths.data=/var/lib/grafana [1]: default.paths.logs=/var/log/grafana Paths: home: /usr/share/grafana data: /var/lib/grafana logs: /var/log/grafana 2017/12/21 18:34:57 [I] Database: sqlite3 2017/12/21 18:34:57 [I] Migrator: Starting DB migration 2017/12/21 18:35:01 [I] Listen: http://0.0.0.0:3000 2017/12/21 18:42:38 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 3858us 2017/12/21 18:45:46 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 12055us 2017/12/21 18:45:59 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 5647us 2017/12/21 18:49:03 [I] Received signal terminated. shutting down 2017/12/21 18:49:21 [I] Starting Grafana 2017/12/21 18:49:21 [I] Version: master, Commit: NA, Build date: 1970-01-01 01:00:00 +0100 CET 2017/12/21 18:49:21 [I] Configuration Info Config files: [0]: /usr/share/grafana/conf/defaults.ini [1]: /etc/grafana/grafana.ini Command lines overrides: [0]: default.paths.data=/var/lib/grafana [1]: default.paths.logs=/var/log/grafana Paths: home: /usr/share/grafana data: /var/lib/grafana logs: /var/log/grafana 2017/12/21 18:49:21 [I] Database: sqlite3 2017/12/21 18:49:22 [I] Migrator: Starting DB migration 2017/12/21 18:49:22 [I] Listen: http://0.0.0.0:3000 2017/12/21 18:51:39 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 4150us 2017/12/21 18:59:05 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 4712us 2017/12/21 19:36:47 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 4014us 2017/12/21 20:16:11 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 7307us 2017/12/21 20:23:19 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 4209us 2017/12/21 21:27:24 [I] Received signal terminated. shutting down 2017/12/21 21:27:32 [I] Starting Grafana 2017/12/21 21:27:32 [I] Version: master, Commit: NA, Build date: 1970-01-01 01:00:00 +0100 CET 2017/12/21 21:27:32 [I] Configuration Info Config files: [0]: /usr/share/grafana/conf/defaults.ini [1]: /etc/grafana/grafana.ini Command lines overrides: [0]: default.paths.data=/var/lib/grafana [1]: default.paths.logs=/var/log/grafana Paths: home: /usr/share/grafana data: /var/lib/grafana logs: /var/log/grafana 2017/12/21 21:27:32 [I] Database: sqlite3 2017/12/21 21:27:32 [I] Migrator: Starting DB migration 2017/12/21 21:27:33 [I] Listen: http://0.0.0.0:3000 2017/12/21 21:48:02 [I] Completed 192.168.178.40 - "GET / HTTP/1.1" 302 Found 29 bytes in 5032us
