#include "dialog.h" #include "ui_dialog.h" #include #include #include #include #include Dialog::Dialog(QWidget *parent) : QDialog(parent), ui(new Ui::Dialog) { ui->setupUi(this); ui->temp_lcdNumber->display("-------"); arduino = new QSerialPort(this); serialBuffer = ""; parsed_data = ""; temperature_value = 0.0; /* * Testing code, prints the description, vendor id, and product id of all ports. * Used it to determine the values for the arduino uno. * */ qDebug() << "Number of ports: " << QSerialPortInfo::availablePorts().length() << "\n"; foreach(const QSerialPortInfo &serialPortInfo, QSerialPortInfo::availablePorts()){ qDebug() << "Description: " << serialPortInfo.description() << "\n"; qDebug() << "Has vendor id?: " << serialPortInfo.hasVendorIdentifier() << "\n"; qDebug() << "Vendor ID: " << serialPortInfo.vendorIdentifier() << "\n"; qDebug() << "Has product id?: " << serialPortInfo.hasProductIdentifier() << "\n"; qDebug() << "Product ID: " << serialPortInfo.productIdentifier() << "\n"; } //*/ /* * Identify the port the arduino uno is on. */ bool arduino_is_available = false; QString arduino_uno_port_name; // // For each available serial port foreach(const QSerialPortInfo &serialPortInfo, QSerialPortInfo::availablePorts()){ // check if the serialport has both a product identifier and a vendor identifier if(serialPortInfo.hasProductIdentifier() && serialPortInfo.hasVendorIdentifier()){ // check if the product ID and the vendor ID match those of the arduino uno if((serialPortInfo.productIdentifier() == arduino_uno_product_id) && (serialPortInfo.vendorIdentifier() == arduino_uno_vendor_id)){ arduino_is_available = true; // arduino uno is available on this port arduino_uno_port_name = serialPortInfo.portName(); } } } /* * Open and configure the arduino port if available */ if(arduino_is_available){ qDebug() << "Found the arduino port...\n"; arduino->setPortName(arduino_uno_port_name); arduino->open(QSerialPort::ReadOnly); arduino->setBaudRate(QSerialPort::Baud9600); arduino->setDataBits(QSerialPort::Data8); arduino->setFlowControl(QSerialPort::NoFlowControl); arduino->setParity(QSerialPort::NoParity); arduino->setStopBits(QSerialPort::OneStop); QObject::connect(arduino, SIGNAL(readyRead()), this, SLOT(readSerial())); }else{ qDebug() << "Couldn't find the correct port for the arduino.\n"; QMessageBox::information(this, "Serial Port Error", "Couldn't open serial port to arduino."); } } Dialog::~Dialog() { if(arduino->isOpen()){ arduino->close(); // Close the serial port if it's open. } delete ui; } void Dialog::readSerial() { /* * readyRead() doesn't guarantee that the entire message will be received all at once. * The message can arrive split into parts. Need to buffer the serial data and then parse for the temperature value. * */ //qDebug() << "serialport works"; QByteArray serialData = arduino->readAll(); QString temp = QString::fromStdString(serialData.toStdString()); qDebug() << temp; /* QStringList buffer_split = serialBuffer.split(","); // split the serialBuffer string, parsing with ',' as the separator // Check to see if there less than 3 tokens in buffer_split. // If there are at least 3 then this means there were 2 commas, // means there is a parsed temperature value as the second token (between 2 commas) if(buffer_split.length() < 3){ // no parsed value yet so continue accumulating bytes from serial in the buffer. serialData = arduino->readAll(); serialBuffer = serialBuffer + QString::fromStdString(serialData.toStdString()); serialData.clear(); }else{ // the second element of buffer_split is parsed correctly, update the temperature value on temp_lcdNumber serialBuffer = ""; qDebug() << buffer_split << "\n"; parsed_data = buffer_split[1]; temperature_value = (9/5.0) * (parsed_data.toDouble()) + 32; // convert to fahrenheit qDebug() << "Temperature: " << temperature_value << "\n"; parsed_data = QString::number(temperature_value, 'g', 4); // format precision of temperature_value to 4 digits or fewer Dialog::updateTemperature(parsed_data); */ } //} void Dialog::updateTemperature(QString sensor_reading) { // update the value displayed on the lcdNumber ui->temp_lcdNumber->display(sensor_reading); }
