2016.3:
 * Version 2.0 (Rev. 14)
 * Bug Fix: GUI related updates. GUI allows setting of only valid baud rate values.
 * Other: Source HDL files are concatenated into a single file to speed up synthesis and simulation. No changes required by the user
 * Revision change in one or more subcores
2016.2:
 * Version 2.0 (Rev. 13)
2016.1:
 * Version 2.0 (Rev. 12)
 * Updated example design subcore version.No functional changes
2015.4.2:
 * Version 2.0 (Rev. 11)
 * No changes
2015.4.1:
 * No changes
2015.4:
2015.3:
 * Version 2.0 (Rev. 10)
 * Minor updates to example design. No functional changes.
 * IP revision number added to HDL module, library, and include file names, to support designs with both locked and upgraded IP instances
2015.2.1:
 * Version 2.0 (Rev. 9)
 * No changes
2015.2:
2015.1:
 * Version 2.0 (Rev. 8)
 * Supported devices and production status are now determined automatically, to simplify support for future devices
 * Enhanced support for IP Integrator
2014.4.1:
 * Version 2.0 (Rev. 7)
 * No changes
2014.4:
2014.3:
 * Version 2.0 (Rev. 6)
 * axi uartlite is modified to use new sub-cores in place of proc_common. No functional changes.
 * Updating core to use utils.tcl needed for board flow from common location
2014.2:
 * Version 2.0 (Rev. 5)
 * Example design XDC updated
 * Minor GUI related updates, no functional changes
2014.1:
 * Version 2.0 (Rev. 4)
 * Internal device family name change, no functional changes
 * Virtex UltraScale Pre-Production support.
2013.4:
 * Version 2.0 (Rev. 3)
 * Kintex UltraScale Pre-Production support
2013.3:
 * Version 2.0 (Rev. 2)
 * Added example design and demonstration testbench
 * Reduced warnings in synthesis and simulation
 * Added support for Cadence IES and Synopsys VCS simulators
 * Updated synchronizers for clock domain crossing to reduce Mean Time Between Failures (MTBF) from metastability
2013.2:
 * Version 2.0 (Rev. 1)
 * Enable support for future devices
2013.1:
 * Version 2.0
 * Native Vivado Release
 * There have been no functional or interface changes to this IP.  The version number has changed to support unique versioning in Vivado starting with 2013.1.
(c) Copyright 2012 - 2016 Xilinx, Inc. All rights reserved.
This file contains confidential and proprietary information
of Xilinx, Inc. and is protected under U.S. and
international copyright and other intellectual property
laws.
DISCLAIMER
This disclaimer is not a license and does not grant any
rights to the materials distributed herewith. Except as
otherwise provided in a valid license issued to you by
Xilinx, and to the maximum extent permitted by applicable
law: (1) THESE MATERIALS ARE MADE AVAILABLE "AS IS" AND
WITH ALL FAULTS, AND XILINX HEREBY DISCLAIMS ALL WARRANTIES
AND CONDITIONS, EXPRESS, IMPLIED, OR STATUTORY, INCLUDING
BUT NOT LIMITED TO WARRANTIES OF MERCHANTABILITY, NON-
INFRINGEMENT, OR FITNESS FOR ANY PARTICULAR PURPOSE; and
(2) Xilinx shall not be liable (whether in contract or tort,
including negligence, or under any other theory of
liability) for any loss or damage of any kind or nature
related to, arising under or in connection with these
materials, including for any direct, or any indirect,
special, incidental, or consequential loss or damage
(including loss of data, profits, goodwill, or any type of
loss or damage suffered as a result of any action brought
by a third party) even if such damage or loss was
reasonably foreseeable or Xilinx had been advised of the
possibility of the same.
CRITICAL APPLICATIONS
Xilinx products are not designed or intended to be fail-
safe, or for use in any application requiring fail-safe
performance, such as life-support or safety devices or
systems, Class III medical devices, nuclear facilities,
applications related to the deployment of airbags, or any
other applications that could lead to death, personal
injury, or severe property or environmental damage
(individually and collectively, "Critical
Applications"). Customer assumes the sole risk and
liability of any use of Xilinx products in Critical
Applications, subject only to applicable laws and
regulations governing limitations on product liability.
THIS COPYRIGHT NOTICE AND DISCLAIMER MUST BE RETAINED AS
PART OF THIS FILE AT ALL TIMES.
