'Ansteuerung eines Nokia 3510i Farb-Display 'Original von Martin Kuehn 'Zeichenausgabe mit lcd_doublesize 0=16x8 zeichen 12=8x4 Zeichen 2=16x4 'Copyright Stefan Horn - Dezember 2004 'Controller D15G14E_14_030526 'Atmega 128 'HWSTACK-256 'SWSTACK-256 'FRAMESIZE-256 '------------------------------------------------------------------------------- 'Display Pin 1 Reset => AVR Pin a0 ' 2 CS a1 ' 3 GND GND ' 4 Sdata a2 ' 5 Sclk a3 ' 6 Vdigital Vdd (3 Volt) ' 7 Vbooster Vdd ' 8 Vlcd über Elko (10uF/10V) an GND '------------------------------------------------------------------------------- ' $regfile = "m16def.dat" $crystal = 8000000 'Config Spi = Hard , Interrupt = Off , Data Order = Msb , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 128 , Noss = 1 'Spsr = 1 'double speed 'Configure for software SPI ' MISO MOSI SS SCK 'Config Spi = Soft , Din = Pinb.3 , Dout = Portb.2 , Ss = Portb.0 , Clock = Portb.1 'Config Spi = Soft , Din = Pinb.3 , Dout = Porta.2 , Ss = None , Clock = Porta.3 Declare Sub Lcd_init Declare Sub Lcd_cls Declare Sub Lcd_setcolor(byval Forecolor As Byte , Byval Backcolor As Byte) Declare Sub Lcd_setdoublesize(byval Size As Byte) Declare Sub Lcd_setframe(byval Lcd_left As Byte , Byval Lcd_top As Byte , Byval Lcd_width As Byte , Byval Lcd_height As Byte) Declare Sub Lcd_sendbyte(byval Lcd_command As Byte , Byval Lcd_data As Byte) Declare Sub Lcd_locate(byval Lcd_x As Byte , Byval Lcd_y As Byte) Declare Sub Lcd_print(byval Lcd_text As String) Dim Lcd_doublesize As Byte Dim Lcd_posx As Byte Dim Lcd_posy As Byte Dim Lcd_fcolor As Byte Dim Lcd_bcolor As Byte Ddra = &B11111111 Const P_io = &B11111111 Dim I2c_buffer(4) As Byte 'Config Porta = Output P_ddr Alias Ddra P_out Alias Porta ' statt c --> a Const Lcd_rs = 0 Const Lcd_cs = 1 Const Lcd_sdata = 2 Const Lcd_sclk = 3 Const Lcd_cmd = 0 Const Lcd_prm = 1 P_ddr = P_io $eeprom Data &H00 , &H00 , &H00 , &H00 , &H00 ' "(space)" Data &H00 , &H06 , &H5F , &H06 , &H00 ' "!" Data &H07 , &H03 , &H00 , &H07 , &H03 ' """ Data &H24 , &H7E , &H24 , &H7E , &H24 ' "#" Data &H24 , &H2B , &H6A , &H12 , &H00 ' "$" Data &H63 , &H13 , &H08 , &H64 , &H63 ' "%" Data &H36 , &H49 , &H56 , &H20 , &H50 ' "&" Data &H00 , &H07 , &H03 , &H00 , &H00 ' "'" '40 Data &H00 , &H3E , &H41 , &H00 , &H00 ' "(" Data &H00 , &H41 , &H3E , &H00 , &H00 ' ")" Data &H08 , &H3E , &H1C , &H3E , &H08 ' "*" Data &H08 , &H08 , &H3E , &H08 , &H08 ' "+" Data &H00 , &HE0 , &H60 , &H00 , &H00 ' "," Data &H08 , &H08 , &H08 , &H08 , &H08 ' "-" Data &H00 , &H60 , &H60 , &H00 , &H00 ' "." Data &H20 , &H10 , &H08 , &H04 , &H02 ' "/" Data &H3E , &H51 , &H49 , &H45 , &H3E ' "0" Data &H00 , &H42 , &H7F , &H40 , &H00 ' "1" '50 Data &H62 , &H51 , &H49 , &H49 , &H46 ' "2" Data &H22 , &H49 , &H49 , &H49 , &H36 ' "3" Data &H18 , &H14 , &H12 , &H7F , &H10 ' "4" Data &H2F , &H49 , &H49 , &H49 , &H31 ' "5" Data &H3C , &H4A , &H49 , &H49 , &H30 ' "6" Data &H01 , &H71 , &H09 , &H05 , &H03 ' "7" Data &H36 , &H49 , &H49 , &H49 , &H36 ' "8" Data &H06 , &H49 , &H49 , &H29 , &H1E ' "9" Data &H00 , &H6C , &H6C , &H00 , &H00 ' ":" Data &H00 , &HEC , &H6C , &H00 , &H00 ' ";" '60 Data &H08 , &H14 , &H22 , &H41 , &H00 ' "<" Data &H24 , &H24 , &H24 , &H24 , &H24 ' "=" Data &H00 , &H41 , &H22 , &H14 , &H08 ' ">" Data &H02 , &H01 , &H59 , &H09 , &H06 ' "?" Data &H3E , &H41 , &H5D , &H55 , &H1E ' "@" Data &H7E , &H09 , &H09 , &H09 , &H7E ' "A" Data &H7F , &H49 , &H49 , &H49 , &H36 ' "B" Data &H3E , &H41 , &H41 , &H41 , &H22 ' "C" Data &H7F , &H41 , &H41 , &H41 , &H3E ' "D" Data &H7F , &H49 , &H49 , &H49 , &H41 ' "E" '70 Data &H7F , &H09 , &H09 , &H09 , &H01 ' "F" Data &H3E , &H41 , &H49 , &H49 , &H7A ' "G" Data &H7F , &H08 , &H08 , &H08 , &H7F ' "H" Data &H00 , &H41 , &H7F , &H41 , &H00 ' "I" Data &H30 , &H40 , &H40 , &H40 , &H3F ' "J" Data &H7F , &H08 , &H14 , &H22 , &H41 ' "K" Data &H7F , &H40 , &H40 , &H40 , &H40 ' "L" Data &H7F , &H02 , &H04 , &H02 , &H7F ' "M" Data &H7F , &H02 , &H04 , &H08 , &H7F ' "N" Data &H3E , &H41 , &H41 , &H41 , &H3E ' "O" Data &H7F , &H09 , &H09 , &H09 , &H06 ' "P" '80 Data &H3E , &H41 , &H51 , &H21 , &H5E ' "Q" Data &H7F , &H09 , &H09 , &H19 , &H66 ' "R" Data &H26 , &H49 , &H49 , &H49 , &H32 ' "S" Data &H01 , &H01 , &H7F , &H01 , &H01 ' "T" Data &H3F , &H40 , &H40 , &H40 , &H3F ' "U" Data &H1F , &H20 , &H40 , &H20 , &H1F ' "V" Data &H3F , &H40 , &H3C , &H40 , &H3F ' "W" Data &H63 , &H14 , &H08 , &H14 , &H63 ' "X" Data &H07 , &H08 , &H70 , &H08 , &H07 ' "Y" Data &H71 , &H49 , &H45 , &H43 , &H00 ' "Z" Data &H00 , &H7F , &H41 , &H41 , &H00 ' "[" '90 Data &H02 , &H04 , &H08 , &H10 , &H20 ' "\" Data &H00 , &H41 , &H41 , &H7F , &H00 ' "]" Data &H04 , &H02 , &H01 , &H02 , &H04 ' "^" Data &H80 , &H80 , &H80 , &H80 , &H80 ' "_" Data &H00 , &H03 , &H07 , &H00 , &H00 ' "`" Data &H20 , &H54 , &H54 , &H54 , &H78 ' "a" Data &H7F , &H44 , &H44 , &H44 , &H38 ' "b" Data &H38 , &H44 , &H44 , &H44 , &H28 ' "c" Data &H38 , &H44 , &H44 , &H44 , &H7F ' "d" Data &H38 , &H54 , &H54 , &H54 , &H18 ' "e" Data &H08 , &H7E , &H09 , &H09 , &H00 ' "f" '100 Data &H18 , &HA4 , &HA4 , &HA4 , &H7C ' "g" Data &H7F , &H04 , &H04 , &H78 , &H00 ' "h" Data &H00 , &H00 , &H7D , &H00 , &H00 ' "i" Data &H40 , &H80 , &H84 , &H7D , &H00 ' "j" Data &H7F , &H10 , &H28 , &H44 , &H00 ' "k" Data &H00 , &H00 , &H7F , &H40 , &H00 ' "l" Data &H7C , &H04 , &H18 , &H04 , &H78 ' "m" Data &H7C , &H04 , &H04 , &H78 , &H00 ' "n" Data &H38 , &H44 , &H44 , &H44 , &H38 ' "o" Data &HFC , &H44 , &H44 , &H44 , &H38 ' "p" Data &H38 , &H44 , &H44 , &H44 , &HFC ' "q" '110 Data &H44 , &H78 , &H44 , &H04 , &H08 ' "r" Data &H08 , &H54 , &H54 , &H54 , &H20 ' "s" Data &H04 , &H3E , &H44 , &H24 , &H00 ' "t" Data &H3C , &H40 , &H20 , &H7C , &H00 ' "u" Data &H1C , &H20 , &H40 , &H20 , &H1C ' "v" Data &H3C , &H60 , &H30 , &H60 , &H3C ' "w" Data &H6C , &H10 , &H10 , &H6C , &H00 ' "x" Data &H9C , &HA0 , &H60 , &H3C , &H00 ' "y" Data &H64 , &H54 , &H54 , &H4C , &H00 ' "z" Data &H08 , &H3E , &H41 , &H41 , &H00 ' "{" '120 Data &H00 , &H00 , &H7F , &H00 , &H00 ' "|" Data &H00 , &H41 , &H41 , &H3E , &H08 ' "}" Data &H02 , &H01 , &H02 , &H01 , &H00 ' "~" Data &H3F , &H21 , &H21 , &H21 , &H21 ' "[" Data &H21 , &H21 , &H21 , &H21 , &H21 Data &H21 , &H21 , &H21 , &H21 . &H3F ' "]" Data &H3F , &H3F , &H3F , &H3F , &H3F Data &H3F , &H00 , &H00 , &H00 , &H00 $data '------------------------------------------------------------------------------- 'Hauptprogramm '------------------------------------------------------------------------------- Hauptprogramm: Dim Temp As Byte Dim Tast As Long Dim Ss As String * 32 Dim Temp2 As Integer Do Call Lcd_init Call Lcd_setcolor(&Hff , &H0) Call Lcd_cls Call Lcd_setdoublesize(2) Call Lcd_locate(1 , 2) Call Lcd_print( " TEST ") Call Lcd_print( " V1.0 ") Call Lcd_setdoublesize(0) Call Lcd_locate(1 , 8) Call Lcd_print( "Hallo ") Wait 4 '------------------------------------------------------------------------------- 'Zeichenausgabe '------------------------------------------------------------------------------- Loop End 'end program Sub Lcd_cls Local R As Integer Call Lcd_setframe(0 , 0 , 97 , 67) For R = 1 To 6566 Call Lcd_sendbyte(lcd_prm , Lcd_bcolor) Next End Sub '------------------------------------------------------------------------------- 'Zeichenausgabe '------------------------------------------------------------------------------- Sub Lcd_print(byval Lcd_text As String) Local R As Integer Local A As Byte Local B As Byte Local C As Long Local D As Byte Local E As Byte Local F As Byte Local G As Long Local Zeichen As String Call Lcd_sendbyte(lcd_cmd , &H36) 'von oben nach unten zeichnen Call Lcd_sendbyte(lcd_prm , &B00100000) Call Lcd_sendbyte(lcd_cmd , &H2C) 'Und wieder Daten For R = 1 To Len(lcd_text) Zeichen = Mid(lcd_text , R , 1) 'Hole char G = Asc(zeichen) 'Bestimme Pos in Tabelle G = G - 32 G = G * 5 Readeeprom B , G Call Lcd_locate(lcd_posx , Lcd_posy) A = 8 '1.linie frei If Lcd_doublesize = 1 Then A = 32 If Lcd_doublesize = 2 Then A = 16 While A > 0 Call Lcd_sendbyte(lcd_prm , Lcd_bcolor) Decr A Wend 'linie 2-6 For F = 1 To 5 C = 1 If Lcd_doublesize = 1 Then C = C + 1 '2x ?? While C > 0 D = B 'Byte darf nicht verändert werden für 2. durchlauf For E = 1 To 8 A = D And 1 If A = 1 Then Call Lcd_sendbyte(lcd_prm , Lcd_fcolor) If Lcd_doublesize > 0 Then Call Lcd_sendbyte(lcd_prm , Lcd_fcolor) Else Call Lcd_sendbyte(lcd_prm , Lcd_bcolor) If Lcd_doublesize > 0 Then Call Lcd_sendbyte(lcd_prm , Lcd_bcolor) End If Shift D , Right , 1 Next Decr C Wend G = G + 1 Readeeprom B , G Next Incr Lcd_posx If Lcd_doublesize = 1 Then If Lcd_posx > 8 Then Lcd_posx = 1 Incr Lcd_posy If Lcd_posy > 4 Then Lcd_posy = 1 End If Else If Lcd_posx > 16 Then Lcd_posx = 1 Incr Lcd_posy If Lcd_posy > 8 Then Lcd_posy = 1 End If End If Next Call Lcd_sendbyte(lcd_cmd , &H36) 'und wieder von links nach rechts Call Lcd_sendbyte(lcd_prm , 0) Call Lcd_sendbyte(lcd_cmd , &H2C) 'Und wieder Daten End Sub '------------------------------------------------------------------------------- 'Koordinatenfenster '------------------------------------------------------------------------------- Sub Lcd_locate(byval Lcd_x As Byte , Byval Lcd_y As Byte) Local A As Byte Local B As Byte Local C As Byte Local D As Byte Lcd_posx = Lcd_x Lcd_posy = Lcd_y If Lcd_doublesize = 1 Then A = Lcd_x - 1 A = A * 12 C = A + 11 B = Lcd_y - 1 B = B * 16 B = B + 2 D = B + 15 Elseif Lcd_doublesize = 2 Then A = Lcd_x - 1 A = A * 6 C = A + 5 B = Lcd_y - 1 B = B * 16 B = B + 2 D = B + 15 Else A = Lcd_x - 1 A = A * 6 C = A + 5 B = Lcd_y - 1 B = B * 8 B = B + 2 D = B + 7 End If Call Lcd_setframe(a , B , C , D) End Sub '------------------------------------------------------------------------------- 'Frame '------------------------------------------------------------------------------- Sub Lcd_setframe(byval Lcd_left As Byte , Byval Lcd_top As Byte , Byval Lcd_width As Byte , Byval Lcd_height As Byte) Call Lcd_sendbyte(lcd_cmd , &H2A) Call Lcd_sendbyte(lcd_prm , Lcd_left) Call Lcd_sendbyte(lcd_prm , Lcd_width) 'Set Lcd_out.lcd_cs 'Cs auf 1 Ende der Sequenz Call Lcd_sendbyte(lcd_cmd , &H2B) Call Lcd_sendbyte(lcd_prm , Lcd_top) Call Lcd_sendbyte(lcd_prm , Lcd_height) 'Set Lcd_out.lcd_cs 'Cs auf 1 Ende der Sequenz Call Lcd_sendbyte(lcd_cmd , &H2C) 'Und wieder Daten End Sub '------------------------------------------------------------------------------- 'Color '------------------------------------------------------------------------------- Sub Lcd_setcolor(byval Forecolor As Byte , Byval Backcolor As Byte) Lcd_fcolor = Forecolor Lcd_bcolor = Backcolor End Sub '------------------------------------------------------------------------------- 'Initialisierung (8bit-Modus) '------------------------------------------------------------------------------- Sub Lcd_setdoublesize(byval Size As Byte) Lcd_doublesize = Size End Sub '------------------------------------------------------------------------------- 'Initialisierung (8bit-Modus) '------------------------------------------------------------------------------- Sub Lcd_init Reset P_out.lcd_rs 'Initialisierung Reset Waitms 5 Set P_out.lcd_rs Set P_out.lcd_cs Set P_out.lcd_sdata Set P_out.lcd_sclk Call Lcd_sendbyte(lcd_cmd , &H01) 'Software Reset 'Set Lcd_out.lcd_cs 'Cs auf 1 Ende der Sequenz Waitms 5 Call Lcd_sendbyte(lcd_cmd , &H11) 'Sleep out 'Set Lcd_out.lcd_cs 'Cs auf 1 Ende der Sequenz Call Lcd_sendbyte(lcd_cmd , &H25) 'Contrast Call Lcd_sendbyte(lcd_prm , 63) 'Set Lcd_out.lcd_cs 'Cs auf 1 Ende der Sequenz Call Lcd_sendbyte(lcd_cmd , &H29) 'Display ON 'Set Lcd_out.lcd_cs 'Cs auf 1 Ende der Sequenz Call Lcd_sendbyte(lcd_cmd , &H03) 'Booster voltage ON 'Set Lcd_out.lcd_cs 'Cs auf 1 Ende der Sequenz Waitms 40 Call Lcd_sendbyte(lcd_cmd , &H3A) 'Interface pixel format 8 bit Call Lcd_sendbyte(lcd_prm , &H02) 'Set Lcd_out.lcd_cs 'Cs auf 1 Ende der Sequenz Call Lcd_sendbyte(lcd_cmd , &H2D) 'Colour set 'Grün Call Lcd_sendbyte(lcd_prm , &H00) Call Lcd_sendbyte(lcd_prm , &H02) Call Lcd_sendbyte(lcd_prm , &H04) Call Lcd_sendbyte(lcd_prm , &H06) Call Lcd_sendbyte(lcd_prm , &H09) Call Lcd_sendbyte(lcd_prm , &H0B) Call Lcd_sendbyte(lcd_prm , &H0D) Call Lcd_sendbyte(lcd_prm , &H0F) 'Rot Call Lcd_sendbyte(lcd_prm , &H00) Call Lcd_sendbyte(lcd_prm , &H02) Call Lcd_sendbyte(lcd_prm , &H04) Call Lcd_sendbyte(lcd_prm , &H06) Call Lcd_sendbyte(lcd_prm , &H09) Call Lcd_sendbyte(lcd_prm , &H0B) Call Lcd_sendbyte(lcd_prm , &H0D) Call Lcd_sendbyte(lcd_prm , &H0F) 'Blau Call Lcd_sendbyte(lcd_prm , &H00) Call Lcd_sendbyte(lcd_prm , &H04) Call Lcd_sendbyte(lcd_prm , &H0B) Call Lcd_sendbyte(lcd_prm , &H0F) 'Set Lcd_out.lcd_cs 'Cs auf 1 Ende der Sequenz Call Lcd_sendbyte(lcd_cmd , &H2C) 'Und wieder Daten Lcd_doublesize = 0 Lcd_posx = 1 Lcd_posy = 1 End Sub '------------------------------------------------------------------------------- 'Übertragen eines Commandos oder eines Parameters / Datenbytes '------------------------------------------------------------------------------- Sub Lcd_sendbyte(byval Lcd_command As Byte , Byval Lcd_data As Byte) Local R As Integer Local A As Byte Reset P_out.lcd_cs 'Cs auf 0 Start der Sequenz If Lcd_command = Lcd_cmd Then Reset P_out.lcd_sclk Reset P_out.lcd_sdata '0 für Command Set P_out.lcd_sclk Else Reset P_out.lcd_sclk Set P_out.lcd_sdata '1 für Data Set P_out.lcd_sclk End If Shiftout P_out.lcd_sdata , P_out.lcd_sclk , Lcd_data , Msbl Set P_out.lcd_cs 'Cs auf 1 Ende der Sequenz End Sub '------------------------------------------------------------------------------- 'VS1001k '-------------------------------------------------------------------------------
