Option Explicit Public Sub createKemet300() Const StartLine = 2 Dim lineCnt As Long Dim cntSerie As Integer Dim cntStyleSize As Integer Dim cntVoltage As Integer Dim cntTolerance As Integer Dim cntCapValues As Integer Dim tmpI As Integer Dim tmpDbl As Double Dim tmpStr As String Dim Series As Collection Dim StyleSize As Collection Dim Voltages As Collection Dim Tolerances As Collection Dim CapacitorValues As Collection Dim startTime As Date Dim endTime As Date 'Variablen und Konstanten für Werte zum Eintragen: Const SymbolPath = "Symbolpfadstring" Const SymbolRef = "Kondensator DIN/ANSI" Dim FootprintRef As String Const FootprintPath = "Footprintpfadstring" Dim Description As String Const Manufacturer = "Kemet" Dim ManufacturerNumber As String Const ComponentSeries = "GoldMax 300 Auto C0G Series" Const CmpLinkDescription = "Datenblatt" Const CmpLinkUrl = "Datenblattpfadstring" Dim PrimValue As String Dim PrimTolerance As String Const SecValue = "-" Const SecTolerance = "-" Dim OperatingVoltage As String Const OperatingTemperature = "-55°C - +125°C" Dim PackageInformation As String Const Standards = "UL 94V–0, RoHS, REACH" Const Grade = "Automotive" startTime = Now() 'Parameter für die Berechnung der Tabellenwerte erstellen Set Series = New Collection With Series .Add "C31" .Add "C32" .Add "C33" End With Set StyleSize = New Collection With StyleSize .Add "315" .Add "316" .Add "317" .Add "318" .Add "320" .Add "321" .Add "322" .Add "323" .Add "324" .Add "325" .Add "326" .Add "327" .Add "328" .Add "330" .Add "331" .Add "333" .Add "335" .Add "336" End With Set Voltages = New Collection With Voltages .Add "25" .Add "50" .Add "100" .Add "200" .Add "250" End With Set Tolerances = New Collection With Tolerances .Add "0,1pF" .Add "0,25pF" .Add "0,5pF" .Add "1%" .Add "2%" .Add "5%" .Add "10%" End With Set CapacitorValues = createESeries(0.000000000001, 0.00000022, 24, eSerieskhochm) With Application .ScreenUpdating = False .EnableEvents = False .Calculation = xlCalculationManual End With 'Schleifenparameter (von außen nach innen): 'Serie - StyleSize - Spannung - Toleranz - Kapazität 'Tabellenwerte berechnen cntSerie = 1 cntVoltage = 1 cntTolerance = 1 cntCapValues = 1 lineCnt = StartLine Do While cntSerie <= Series.Count cntStyleSize = 1 Do While cntStyleSize <= StyleSize.Count cntVoltage = 1 Do While cntVoltage <= Voltages.Count cntTolerance = 1 Do While cntTolerance <= Tolerances.Count cntCapValues = 1 Do While cntCapValues <= CapacitorValues.Count 'Hier die Werte berechnen, die nachher in der Tabelle landen sollen 'Werte überspringen falls nötig weil es diese Kombinationen z.B. nicht gibt: 'Toleranzen-Kapazitätskombinationen überspringen die es nicht gibt If CapacitorValues(cntCapValues) > 0.0000000000091 And cntTolerance <= 3 Then GoTo nextToleranceValue If CapacitorValues(cntCapValues) <= 0.0000000000091 And cntTolerance > 3 Then GoTo nextCapacityValue 'Serien-Spannungs-Kapazitätskompinationen überspringen die es nicht gibt: Select Case Series(cntSerie) Case "C31", "C32": Select Case Voltages(cntVoltage) Case "25": If CapacitorValues(cntCapValues) > 0.00000018 Then GoTo nextToleranceValue Case "50": If CapacitorValues(cntCapValues) > 0.00000015 Then GoTo nextToleranceValue Case "100": If CapacitorValues(cntCapValues) > 0.0000001 Then GoTo nextToleranceValue Case "200": If CapacitorValues(cntCapValues) > 0.000000047 Then GoTo nextToleranceValue Case "250": If CapacitorValues(cntCapValues) > 0.000000047 Then GoTo nextToleranceValue End Select Case "C33": Select Case Voltages(cntVoltage) Case "25": If CapacitorValues(cntCapValues) > 0 Then GoTo nextToleranceValue Case "50": If CapacitorValues(cntCapValues) > 0.00000022 Then GoTo nextToleranceValue Case "100": If CapacitorValues(cntCapValues) > 0.00000015 Then GoTo nextToleranceValue Case "200": If CapacitorValues(cntCapValues) > 0.0000001 Then GoTo nextToleranceValue Case "250": If CapacitorValues(cntCapValues) > 0.0000001 Then GoTo nextToleranceValue End Select End Select 'Serien-Gehäusekombinationen überspringen die es nicht gibt Select Case Series(Series.Count) Case "C31": Select Case StyleSize(cntStyleSize) Case "315", "316", "317", "318": 'Tue nichts, gehe weiter Case Default: GoTo nextStyleSize 'Überspringe diesen Case, weiter mit nächstem Style/Size End Select Case "C32": Select Case StyleSize(cntStyleSize) Case "324", "320", "326", "321", "322", "323", "325", "328", "327": 'Tue nichts, gehe weiter Case Default: GoTo nextStyleSize 'Überspringe diesen Case, weiter mit nächstem Style/Size End Select Case "C33": Select Case StyleSize(cntStyleSize) Case "330", "331", "333", "335", "336": 'Tue nichts, gehe weiter Case Default: GoTo nextStyleSize 'Überspringe diesen Case, weiter mit nächstem Style/Size End Select End Select 'Werte berechnen 'Footprintreferenz: FootprintRef = "C-" & StyleSize(cntStyleSize) 'Beschreibung erstellen: Description = "Low ESR/ESL, " & formatSI(CapacitorValues(cntCapValues), 1) & "F/" & ChrW(177) & Tolerances(cntTolerance) 'Herstellerbezeichnung erstellen ManufacturerNumber = "'" ManufacturerNumber = "C" & StyleSize(cntStyleSize) & "C" tmpStr = CapacitorValues(cntCapValues) * 10 ^ (-1 * Application.RoundUp(Log(CapacitorValues(cntCapValues)) / Log(10#), 0) + 1) tmpStr = Format(Replace(tmpStr, ",", ""), "00") tmpStr = tmpStr & (-1 * Application.RoundUp(Log(CapacitorValues(cntCapValues)) / Log(10#), 0) - 3) 'Anzahl der Nullen, wenn man die Kapazität im Format x,y pF schreibt ManufacturerNumber = ManufacturerNumber & tmpStr Select Case Tolerances(cntTolerance) Case "0,1pF": ManufacturerNumber = ManufacturerNumber & "B" Case "0,25pF": ManufacturerNumber = ManufacturerNumber & "C" Case "0,5pF": ManufacturerNumber = ManufacturerNumber & "D" Case "1%": ManufacturerNumber = ManufacturerNumber & "F" Case "2%": ManufacturerNumber = ManufacturerNumber & "G" Case "5%": ManufacturerNumber = ManufacturerNumber & "J" Case "10%": ManufacturerNumber = ManufacturerNumber & "K" End Select Select Case Voltages(cntVoltage) Case "25": ManufacturerNumber = ManufacturerNumber & "3" Case "50": ManufacturerNumber = ManufacturerNumber & "5" Case "100": ManufacturerNumber = ManufacturerNumber & "1" Case "200": ManufacturerNumber = ManufacturerNumber & "2" Case "250": ManufacturerNumber = ManufacturerNumber & "A" End Select ManufacturerNumber = ManufacturerNumber & "G5TA9170" 'Primären Bauteilwert erstellen PrimValue = "'" & formatSI(CapacitorValues(cntCapValues), 1) & "F" 'Primäre Bauteiltoleranz, Betriebsspannung und Gehäusebeschreibung erstellen PrimTolerance = "'" & ChrW(177) & Tolerances(cntTolerance) OperatingVoltage = "'" & Voltages(cntVoltage) & "V" PackageInformation = "(THT) C-" & StyleSize(cntStyleSize) 'Werte in die Tabelle eintragen With ThisWorkbook.Worksheets("01 Keramik") With .Range("A" & lineCnt) .HorizontalAlignment = xlLeft .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = SymbolRef End With With .Range("B" & lineCnt) .HorizontalAlignment = xlLeft .VerticalAlignment = xlCenter .NumberFormat = "@" .ShrinkToFit = True .Value = SymbolPath End With With .Range("C" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = FootprintRef End With With .Range("D" & lineCnt) .HorizontalAlignment = xlLeft .VerticalAlignment = xlCenter .NumberFormat = "@" .ShrinkToFit = True .Value = FootprintPath End With With .Range("E" & lineCnt) .HorizontalAlignment = xlLeft .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = Description End With With .Range("F" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = Manufacturer End With With .Range("G" & lineCnt) .HorizontalAlignment = xlLeft .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = ManufacturerNumber End With With .Range("H" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = ComponentSeries End With With .Range("I" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .ShrinkToFit = True .Value = CmpLinkDescription End With With .Range("J" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .ShrinkToFit = True .Value = CmpLinkUrl End With With .Range("K" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = PrimValue End With With .Range("L" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = PrimTolerance End With With .Range("M" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = SecValue End With With .Range("N" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = SecTolerance End With With .Range("O" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = OperatingVoltage End With With .Range("P" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = OperatingTemperature End With With .Range("Q" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = PackageInformation End With With .Range("R" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = Standards End With With .Range("S" & lineCnt) .HorizontalAlignment = xlCenter .VerticalAlignment = xlCenter .NumberFormat = "@" .Value = Grade End With With .Range("A" & lineCnt & ":S" & lineCnt).Borders(xlInsideVertical) .LineStyle = xlContinuous .ColorIndex = xlAutomatic .TintAndShade = 0 .Weight = xlThin End With End With lineCnt = lineCnt + 1 nextCapacityValue: cntCapValues = cntCapValues + 1 Loop nextToleranceValue: cntTolerance = cntTolerance + 1 Loop cntVoltage = cntVoltage + 1 Loop nextStyleSize: cntStyleSize = cntStyleSize + 1 Loop cntSerie = cntSerie + 1 Loop endTime = Now() With Application .ScreenUpdating = True .EnableEvents = True .Calculation = xlCalculationAutomatic End With MsgBox ("Fertig :)" & vbNewLine & vbNewLine & vbNewLine & "Ausführungszeit: " & vbNewLine & Format(endTime - startTime, "hh:mm:ss")) End Sub
