Plecs { Name "Capacitive half-bridge with synchronous rectifier" Version "4.1" CircuitModel "ContStateSpace" StartTime "0.0" StopTime "0.001" Timeout "" Solver "radau" MaxStep "1e-3" InitStep "-1" FixedStep "1e-3" Refine "1" ZCStepSize "1e-9" RelTol "1e-6" AbsTol "-1" TurnOnThreshold "0" SyncFixedStepTasks "2" UseSingleCommonBaseRate "2" LossVariableLimitExceededMsg "3" NegativeSwitchLossMsg "3" DivisionByZeroMsg "3" StiffnessDetectionMsg "2" MaxConsecutiveZCs "1000" AlgebraicLoopWithStateMachineMsg "3" AssertionAction "1" InitializationCommands "Uin=36\nUout=14.2\nD=Uout/Uin" InitialState "1" SystemState "" CodeGenParameterInlining "2" CodeGenInliningExceptions "AAAACwAAAAAA" CodeGenFloatingPointFormat "2" CodeGenIntegerWordSize "32" CodeGenAbsTimeUsageMsg "3" CodeGenBaseName "" CodeGenOutputDir "" CodeGenExtraOpts "" CodeGenTarget "Generic" CodeGenTargetSettings "" ExtendedMatrixPrecision "1" MatrixSignificanceCheck "2" EnableStateSpaceSplitting "2" DisplayStateSpaceSplitting "1" DiscretizationMethod "2" ExternalModeSettings "" AlgebraicLoopMethod "1" AlgebraicLoopTolerance "1e-6" Schematic { Location [0, 63; 1366, 687] ZoomFactor 1 SliderPosition [0, 0] ShowBrowser off BrowserWidth 78 Component { Type Transformer Name "Tr3" Show off Position [465, 230] Direction right Flipped on Parameter { Variable "Windings" Value "[1 2]" Show off } Parameter { Variable "n" Value "[5 5 5]" Show off } Parameter { Variable "Polarity" Value "+" Show off } Parameter { Variable "Lm" Value "inf" Show off } Parameter { Variable "im0" Value "0" Show off } } Component { Type Capacitor Name "C1" Show on Position [360, 135] Direction down Flipped on Parameter { Variable "C" Value "10e-6" Show on } Parameter { Variable "v_init" Value "0" Show off } } Component { Type Capacitor Name "C3" Show on Position [360, 335] Direction down Flipped on Parameter { Variable "C" Value "10e-6" Show on } Parameter { Variable "v_init" Value "0" Show off } } Component { Type Inductor Name "L1" Show on Position [625, 115] Direction left Flipped off Parameter { Variable "L" Value "1.853e-3" Show on } Parameter { Variable "i_init" Value "0" Show off } } Component { Type Capacitor Name "C2" Show on Position [755, 240] Direction down Flipped on Parameter { Variable "C" Value "50e-6" Show on } Parameter { Variable "v_init" Value "0" Show off } } Component { Type Resistor Name "R1" Show on Position [835, 240] Direction up Flipped off Parameter { Variable "R" Value "2" Show on } } Component { Type PulseGenerator Name "Pulse\nGenerator" Show on Position [115, 415] Direction right Flipped off Parameter { Variable "Hi" Value "1" Show off } Parameter { Variable "Lo" Value "0" Show off } Parameter { Variable "f" Value "200000" Show on } Parameter { Variable "DutyCycle" Value "D" Show on } Parameter { Variable "Delay" Value "0" Show off } } Component { Type Scope Name "Scope" Show on Position [965, 65] Direction up Flipped off Location [363, 144; 713, 371] State "AAAA/wAAAAD9AAAAAgAAAAEAAAAAAAAAAPwCAAAAA/sAAAAQAFoAbwBvA" "G0AQQByAGUAYQAAAAAA/////wAAAFwA////+wAAABQAUwBhAHYAZQBkAFYAaQBlAHcAcwAAAAAA//" "///wAAAGYA////+wAAAAwAVAByAGEAYwBlAHMAAAAAAP////8AAABmAP///wAAAAMAAAAAAAAAAPw" "BAAAAAfsAAAAUAEQAYQB0AGEAVwBpAGQAZwBlAHQAAAAAAP////8AAABQAP///wAAAV4AAADIAAAA" "BAAAAAQAAAAIAAAACPwAAAABAAAAAgAAAAEAAAAOAFQAbwBvAGwAQgBhAHIBAAAAAP////8AAAAAA" "AAAAA==" SavedViews "AAAAAgAAAAA=" HeaderState "AAAA/wAAAAAAAAABAAAAAQAAAAAAAAAAAAAAAAAAAAAL/gMAAAAJAAAAA" "QAAAGQAAAADAAAAZAAAAAIAAABkAAAABQAAAGQAAAAEAAAAZAAAAAcAAABkAAAABgAAAGQAAAAJAA" "AAZAAAAAgAAABkAAAAugAAAAsBAAABAAAAAAAAAAAAAAAAZP////8AAACBAAAAAAAAAAsAAABWAAA" "AAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAA" "AAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAQAAAAAAA" "ABkAAAAAQAAAAAAAAPoAA==" PlotPalettes "AAAAAQAAAAEAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAA" "AEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=" Axes "2" TimeRange "0" ScrollingMode "1" SingleTimeAxis "1" Open "0" Ts "-1" SampleLimit "0" XAxisLabel "" Axis { Name "" AutoScale 1 MinValue 0 MaxValue 1 Signals {} SignalTypes [ ] Untangle 0 KeepBaseline off BaselineValue 0 } Axis { Name "" AutoScale 1 MinValue 0 MaxValue 1 Signals {} SignalTypes [ ] Untangle 0 KeepBaseline off BaselineValue 0 } Fourier { SingleXAxis on AxisLabel "Frequency" Scaling 0 PhaseDisplay 0 Axis { Name "" AutoScale 1 MinValue 0 MaxValue 1 Signals {} Untangle 0 KeepBaseline off BaselineValue 0 } Axis { Name "" AutoScale 1 MinValue 0 MaxValue 1 Signals {} Untangle 0 KeepBaseline off BaselineValue 0 } } } Component { Type Voltmeter Name "Vm1" Show on Position [900, 240] Direction up Flipped off } Component { Type Ammeter Name "Am1" Show on Position [705, 115] Direction left Flipped off } Component { Type Resistor Name "R2" Show on Position [360, 170] Direction up Flipped off Parameter { Variable "R" Value "0.001" Show on } } Component { Type Resistor Name "R3" Show on Position [360, 290] Direction up Flipped off Parameter { Variable "R" Value "0.001" Show on } } Component { Type DCVoltageSource Name "V_dc" Show on Position [165, 235] Direction down Flipped on Parameter { Variable "V" Value "Uin" Show on } } Component { Type Reference SrcComponent "Components/Control/Delays/Pulse Delay" Name "Pulse Delay2" Show on Position [205, 415] Direction up Flipped off Frame [-15, -15; 15, 15] LabelPosition [0, 18] LabelAlign up Parameter { Variable "T_d" Value "2.5e-6" Show on } Parameter { Variable "y_init" Value "0" Show off } Parameter { Variable "buffer_size" Value "1024" Show off } Terminal { Type Output Position [19, 0] Direction right } Terminal { Type Input Position [-15, 0] Direction left } } Component { Type MosfetWithDiode Name "FETD1" Show off Position [280, 150] Direction up Flipped off Parameter { Variable "Ron" Value "0" Show off } Parameter { Variable "s_init" Value "0" Show off } Parameter { Variable "thermal" Value "" Show off } Parameter { Variable "T_init" Value "0" Show off } } Component { Type MosfetWithDiode Name "FETD2" Show off Position [280, 310] Direction up Flipped off Parameter { Variable "Ron" Value "0" Show off } Parameter { Variable "s_init" Value "0" Show off } Parameter { Variable "thermal" Value "" Show off } Parameter { Variable "T_init" Value "0" Show off } } Component { Type MosfetWithDiode Name "FETD3" Show off Position [475, 300] Direction down Flipped on Parameter { Variable "Ron" Value "0" Show off } Parameter { Variable "s_init" Value "0" Show off } Parameter { Variable "thermal" Value "" Show off } Parameter { Variable "T_init" Value "0" Show off } } Component { Type MosfetWithDiode Name "FETD4" Show off Position [585, 300] Direction down Flipped on Parameter { Variable "Ron" Value "0" Show off } Parameter { Variable "s_init" Value "0" Show off } Parameter { Variable "thermal" Value "" Show off } Parameter { Variable "T_init" Value "0" Show off } } Component { Type Scope Name "Scope1" Show on Position [110, 325] Direction up Flipped off Location [363, 144; 713, 483] State "AAAA/wAAAAD9AAAAAgAAAAEAAAAAAAAAAPwCAAAAA/sAAAAQAFoAbwBvA" "G0AQQByAGUAYQAAAAAA/////wAAAFwA////+wAAABQAUwBhAHYAZQBkAFYAaQBlAHcAcwAAAAAA//" "///wAAAGYA////+wAAAAwAVAByAGEAYwBlAHMAAAAAAP////8AAABmAP///wAAAAMAAAAAAAAAAPw" "BAAAAAfsAAAAUAEQAYQB0AGEAVwBpAGQAZwBlAHQAAAAAAP////8AAABQAP///wAAAV4AAAE4AAAA" "BAAAAAQAAAAIAAAACPwAAAABAAAAAgAAAAEAAAAOAFQAbwBvAGwAQgBhAHIBAAAAAP////8AAAAAA" "AAAAA==" SavedViews "AAAAAgAAAAA=" HeaderState "AAAA/wAAAAAAAAABAAAAAQAAAAAAAAAAAAAAAAAAAAAL/gMAAAAJAAAAA" "QAAAGQAAAADAAAAZAAAAAIAAABkAAAABQAAAGQAAAAEAAAAZAAAAAcAAABkAAAABgAAAGQAAAAJAA" "AAZAAAAAgAAABkAAAAtwAAAAsBAAABAAAAAAAAAAAAAAAAZP////8AAACBAAAAAAAAAAsAAACSAAA" "AAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAA" "AAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAQAAAAAAA" "AAlAAAAAQAAAAAAAAPoAA==" PlotPalettes "AAAAAQAAAAEAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAA" "AEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=" Axes "2" TimeRange "0" ScrollingMode "1" SingleTimeAxis "1" Open "0" Ts "-1" SampleLimit "0" XAxisLabel "" Axis { Name "" AutoScale 1 MinValue 0 MaxValue 1 Signals {} SignalTypes [ ] Untangle 0 KeepBaseline off BaselineValue 0 } Axis { Name "" AutoScale 1 MinValue 0 MaxValue 1 Signals {} SignalTypes [ ] Untangle 0 KeepBaseline off BaselineValue 0 } Fourier { SingleXAxis on AxisLabel "Frequency" Scaling 0 PhaseDisplay 0 Axis { Name "" AutoScale 1 MinValue 0 MaxValue 1 Signals {} Untangle 0 KeepBaseline off BaselineValue 0 } Axis { Name "" AutoScale 1 MinValue 0 MaxValue 1 Signals {} Untangle 0 KeepBaseline off BaselineValue 0 } } } Connection { Type Wire SrcComponent "Tr3" SrcTerminal 4 Points [475, 225] Branch { Points [595, 225; 595, 115] DstComponent "L1" DstTerminal 1 } Branch { DstComponent "Tr3" DstTerminal 5 } } Connection { Type Wire SrcComponent "C2" SrcTerminal 2 Points [755, 355] Branch { Points [585, 355] Branch { Points [475, 355] DstComponent "FETD3" DstTerminal 2 } Branch { DstComponent "FETD4" DstTerminal 2 } } Branch { Points [835, 355] Branch { DstComponent "R1" DstTerminal 2 } Branch { Points [900, 355] DstComponent "Vm1" DstTerminal 2 } } } Connection { Type Wire SrcComponent "Am1" SrcTerminal 2 Points [755, 115] Branch { DstComponent "C2" DstTerminal 1 } Branch { Points [835, 115] Branch { DstComponent "R1" DstTerminal 1 } Branch { Points [900, 115] DstComponent "Vm1" DstTerminal 1 } } } Connection { Type Signal SrcComponent "Am1" SrcTerminal 3 Points [705, 60] DstComponent "Scope" DstTerminal 1 } Connection { Type Signal SrcComponent "Vm1" SrcTerminal 3 Points [925, 240; 925, 70] DstComponent "Scope" DstTerminal 2 } Connection { Type Wire SrcComponent "R2" SrcTerminal 1 DstComponent "C1" DstTerminal 2 } Connection { Type Wire SrcComponent "C3" SrcTerminal 1 DstComponent "R3" DstTerminal 2 } Connection { Type Wire SrcComponent "C1" SrcTerminal 1 Points [360, 115; 280, 115] Branch { DstComponent "FETD1" DstTerminal 1 } Branch { Points [165, 115] DstComponent "V_dc" DstTerminal 1 } } Connection { Type Wire SrcComponent "FETD3" SrcTerminal 1 DstComponent "Tr3" DstTerminal 6 } Connection { Type Wire SrcComponent "FETD4" SrcTerminal 1 Points [585, 115; 475, 115] DstComponent "Tr3" DstTerminal 3 } Connection { Type Wire SrcComponent "C3" SrcTerminal 2 Points [360, 355; 280, 355] Branch { Points [165, 355] DstComponent "V_dc" DstTerminal 2 } Branch { DstComponent "FETD2" DstTerminal 2 } } Connection { Type Wire SrcComponent "R3" SrcTerminal 1 Points [360, 255] Branch { DstComponent "R2" DstTerminal 2 } Branch { Points [455, 255] DstComponent "Tr3" DstTerminal 2 } } Connection { Type Wire SrcComponent "FETD2" SrcTerminal 1 Points [280, 195] Branch { Points [455, 195] DstComponent "Tr3" DstTerminal 1 } Branch { DstComponent "FETD1" DstTerminal 2 } } Connection { Type Wire SrcComponent "Am1" SrcTerminal 1 DstComponent "L1" DstTerminal 2 } Connection { Type Signal SrcComponent "Pulse Delay2" SrcTerminal 1 Points [245, 415; 245, 380] Branch { DstComponent "FETD2" DstTerminal 3 } Branch { Points [80, 380] DstComponent "Scope1" DstTerminal 2 } Branch { Points [620, 380] DstComponent "FETD4" DstTerminal 3 } } Connection { Type Signal SrcComponent "Pulse\nGenerator" SrcTerminal 1 Points [145, 415] Branch { Points [145, 480; 510, 480] DstComponent "FETD3" DstTerminal 3 } Branch { Points [145, 415] Branch { Points [145, 280] Branch { Points [145, 150] DstComponent "FETD1" DstTerminal 3 } Branch { Points [80, 280] DstComponent "Scope1" DstTerminal 1 } } Branch { DstComponent "Pulse Delay2" DstTerminal 2 } } } Annotation { Name "T1" Position [255, 170] } Annotation { Name "T2" Position [265, 285] } Annotation { Name "T3" Position [490, 330] } Annotation { Name "T4" Position [595, 335] } } }
