Conversion of tabulated data to binary/ASCII raw file file format. ----------------------------------------------------------------- It converts and copies a text data file to either an ASCII-data file or a binary data file in raw format. The data can be then viewed with LTSPICE like a normal simulation result. The output file can be also used for further processing, e.g. for Merge or NMerge. Parameter sweepNo duplicates the data multiple times. This can be convenient for stepped parameter simulation, if you only need the same data for every sweep. An offset can be added to the x-axis numbers. This option is required if negative time data is in the input file. The source file have to contain a standard raw file header followed by the data table. This table is then converted to the raw file format in the destination file. The header of the input file will become the header of the output raw-file. Usage Ltsputil.exe -t[o][a|b|][z] source dest [sweepNo] .. Option 'o' : Overwrite an existing output file. Option 'a|b' : Output data format is 'a'SCII or 'b'inary. If none of these two options is given, output data format is binary. Option 'z' : Add x-axis offset to x-axis, zero offset. The value is in the header behind 'Offset:' sweepNo : Number of sweeps with the same data Default is 1 if no number is given Example Ltsputil.exe -toa limits.txt limits.raw Option -o overwrite, -a ASCII The input file must have the standard header of a raw-file starting with the line 'Title ...' and ending with the line 'Values:' The number behind 'Offset:' is used with the 'z'-option. The data is in the lines following the line 'Values:'. Data for generating .AC raw-files has to be in real,imag format. Example for a .TRAN data file ----------------------------- Title: * D:\Daten\table_2_tran.txt Date: Wed Jan 01 19:30:00 2005 Plotname: Transient Analysis Flags: real forward No. Variables: 3 No. Points: 8 Offset: 0.0000000000000000e+000 Command: Linear Technology Corporation LTspice Variables: 0 time time 1 V(limit1) voltage 2 V(limit2) voltage Values: 0 0.5 -0.2 10e-9 0.5 -0.2 11e-9 6 -0.2 14e-9 6 -0.2 15e-9 6 -0.2 21e-9 6 4 35e-9 5.5 4.5 50e-9 5.5 4.5 Example for a .AC data file --------------------------- Title: * D:\Daten\table_2_ac.txt Date: Wed Jan 01 19:30:00 2005 Plotname: AC Analysis Flags: complex forward log No. Variables: 3 No. Points: 8 Offset: 0.0000000000000000e+000 Command: Linear Technology Corporation LTspice Variables: 0 frequency frequency 1 V(max) voltage 2 V(min) voltage Values: 1e6 1.05,0 0.95,0 10e6 1.05,0 0.95,0 20e6 1.1,0 0.9,0 40e6 1.15,0 0.9,0 60e6 1.15,0 0.8,0 80e6 1,0 0.6,0 100e6 0.7,0 0.3,0 200e6 0.4,0 0.05,0 Example for a .DC data file --------------------------- Title: * D:\Daten\Test.txt Date: Wed Jan 01 19:30:00 2005 Plotname: DC transfer characteristic Flags: real forward No. Variables: 3 No. Points: 4 Offset: 0.0000000000000000e+000 Command: Linear Technology Corporation LTspice Variables: 0 v1 voltage 1 V(n001) voltage 2 I(V1) device_current Values: 2 1 1.3e-3 5 2.1 1.5e-3 6 3.0 2.1e-3 7 4.1 4.56e-3
