* @file startup_stm32h743xx.s
* @author MCD Application Team
* @version V1.2.0
* @date 29-December-2017
* @brief STM32H743xx Devices vector table for GCC based toolchain.
* This module performs:
* - Set the initial SP
* - Set the initial PC == Reset_Handler,
* - Set the vector table entries with the exceptions ISR address
* - Branches to main in the C library (which eventually
* calls main()).
* After Reset the Cortex-M processor is in Thread mode,
* priority is Privileged, and the Stack is set to Main.
* @attention
© COPYRIGHT 2017 STMicroelectronics
* Redistribution and use in source and binary forms, with or without modification,
* are permitted provided that the following conditions are met:
* 1. Redistributions of source code must retain the above copyright notice,
* this list of conditions and the following disclaimer.
* 2. Redistributions in binary form must reproduce the above copyright notice,
* this list of conditions and the following disclaimer in the documentation
* and/or other materials provided with the distribution.
* 3. Neither the name of STMicroelectronics nor the names of its contributors
* may be used to endorse or promote products derived from this software
* without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
* DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
* SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
* CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
.syntax unified
.cpu cortex-m7
.fpu softvfp
.thumb
.global g_pfnVectors
.global Default_Handler
/* start address for the initialization values of the .data section.
defined in linker script */
.word _sidata
/* start address for the .data section. defined in linker script */
.word _sdata
/* end address for the .data section. defined in linker script */
.word _edata
/* start address for the .bss section. defined in linker script */
.word _sbss
/* end address for the .bss section. defined in linker script */
.word _ebss
/* stack used for SystemInit_ExtMemCtl; always internal RAM used */
* @brief This is the code that gets called when the processor first
* starts execution following a reset event. Only the absolutely
* necessary set is performed, after which the application
* supplied main() routine is called.
* @param None
* @retval : None
.section .text.Reset_Handler
.weak Reset_Handler
.type Reset_Handler, %function
Reset_Handler:
ldr sp, =_estack /* set stack pointer */
/* Copy the data segment initializers from flash to SRAM */
movs r1, #0
b LoopCopyDataInit
CopyDataInit:
ldr r3, =_sidata
ldr r3, [r3, r1]
str r3, [r0, r1]
adds r1, r1, #4
LoopCopyDataInit:
ldr r0, =_sdata
ldr r3, =_edata
adds r2, r0, r1
cmp r2, r3
bcc CopyDataInit
ldr r2, =_sbss
b LoopFillZerobss
/* Zero fill the bss segment. */
FillZerobss:
movs r3, #0
str r3, [r2], #4
LoopFillZerobss:
ldr r3, = _ebss
cmp r2, r3
bcc FillZerobss
/* Call the clock system intitialization function.*/
bl SystemInit
/* Call static constructors */
bl __libc_init_array
/* Call the application's entry point.*/
bl main
bx lr
.size Reset_Handler, .-Reset_Handler
* @brief This is the code that gets called when the processor receives an
* unexpected interrupt. This simply enters an infinite loop, preserving
* the system state for examination by a debugger.
* @param None
* @retval None
.section .text.Default_Handler,"ax",%progbits
Default_Handler:
Infinite_Loop:
b Infinite_Loop
.size Default_Handler, .-Default_Handler
* The minimal vector table for a Cortex M. Note that the proper constructs
* must be placed on this to ensure that it ends up at physical address
* 0x0000.0000.
.section .isr_vector,"a",%progbits
.type g_pfnVectors, %object
.size g_pfnVectors, .-g_pfnVectors
g_pfnVectors:
.word _estack
.word Reset_Handler
.word NMI_Handler
.word HardFault_Handler
.word MemManage_Handler
.word BusFault_Handler
.word UsageFault_Handler
.word 0
.word 0
.word 0
.word 0
.word SVC_Handler
.word DebugMon_Handler
.word 0
.word PendSV_Handler
.word SysTick_Handler
/* External Interrupts */
.word WWDG_IRQHandler /* Window WatchDog */
.word PVD_AVD_IRQHandler /* PVD/AVD through EXTI Line detection */
.word TAMP_STAMP_IRQHandler /* Tamper and TimeStamps through the EXTI line */
.word RTC_WKUP_IRQHandler /* RTC Wakeup through the EXTI line */
.word FLASH_IRQHandler /* FLASH */
.word RCC_IRQHandler /* RCC */
.word EXTI0_IRQHandler /* EXTI Line0 */
.word EXTI1_IRQHandler /* EXTI Line1 */
.word EXTI2_IRQHandler /* EXTI Line2 */
.word EXTI3_IRQHandler /* EXTI Line3 */
.word EXTI4_IRQHandler /* EXTI Line4 */
.word DMA1_Stream0_IRQHandler /* DMA1 Stream 0 */
.word DMA1_Stream1_IRQHandler /* DMA1 Stream 1 */
.word DMA1_Stream2_IRQHandler /* DMA1 Stream 2 */
.word DMA1_Stream3_IRQHandler /* DMA1 Stream 3 */
.word DMA1_Stream4_IRQHandler /* DMA1 Stream 4 */
.word DMA1_Stream5_IRQHandler /* DMA1 Stream 5 */
.word DMA1_Stream6_IRQHandler /* DMA1 Stream 6 */
.word ADC_IRQHandler /* ADC1, ADC2 and ADC3s */
.word FDCAN1_IT0_IRQHandler /* FDCAN1 interrupt line 0 */
.word FDCAN2_IT0_IRQHandler /* FDCAN2 interrupt line 0 */
.word FDCAN1_IT1_IRQHandler /* FDCAN1 interrupt line 1 */
.word FDCAN2_IT1_IRQHandler /* FDCAN2 interrupt line 1 */
.word EXTI9_5_IRQHandler /* External Line[9:5]s */
.word TIM1_BRK_IRQHandler /* TIM1 Break interrupt */
.word TIM1_UP_IRQHandler /* TIM1 Update interrupt */
.word TIM1_TRG_COM_IRQHandler /* TIM1 Trigger and Commutation interrupt */
.word TIM1_CC_IRQHandler /* TIM1 Capture Compare */
.word TIM2_IRQHandler /* TIM2 */
.word TIM3_IRQHandler /* TIM3 */
.word TIM4_IRQHandler /* TIM4 */
.word I2C1_EV_IRQHandler /* I2C1 Event */
.word I2C1_ER_IRQHandler /* I2C1 Error */
.word I2C2_EV_IRQHandler /* I2C2 Event */
.word I2C2_ER_IRQHandler /* I2C2 Error */
.word SPI1_IRQHandler /* SPI1 */
.word SPI2_IRQHandler /* SPI2 */
.word USART1_IRQHandler /* USART1 */
.word USART2_IRQHandler /* USART2 */
.word USART3_IRQHandler /* USART3 */
.word EXTI15_10_IRQHandler /* External Line[15:10]s */
.word RTC_Alarm_IRQHandler /* RTC Alarm (A and B) through EXTI Line */
.word 0 /* Reserved */
.word TIM8_BRK_TIM12_IRQHandler /* TIM8 Break and TIM12 */
.word TIM8_UP_TIM13_IRQHandler /* TIM8 Update and TIM13 */
.word TIM8_TRG_COM_TIM14_IRQHandler /* TIM8 Trigger and Commutation and TIM14 */
.word TIM8_CC_IRQHandler /* TIM8 Capture Compare */
.word DMA1_Stream7_IRQHandler /* DMA1 Stream7 */
.word FMC_IRQHandler /* FMC */
.word SDMMC1_IRQHandler /* SDMMC1 */
.word TIM5_IRQHandler /* TIM5 */
.word SPI3_IRQHandler /* SPI3 */
.word UART4_IRQHandler /* UART4 */
.word UART5_IRQHandler /* UART5 */
.word TIM6_DAC_IRQHandler /* TIM6 and DAC1&2 underrun errors */
.word TIM7_IRQHandler /* TIM7 */
.word DMA2_Stream0_IRQHandler /* DMA2 Stream 0 */
.word DMA2_Stream1_IRQHandler /* DMA2 Stream 1 */
.word DMA2_Stream2_IRQHandler /* DMA2 Stream 2 */
.word DMA2_Stream3_IRQHandler /* DMA2 Stream 3 */
.word DMA2_Stream4_IRQHandler /* DMA2 Stream 4 */
.word ETH_IRQHandler /* Ethernet */
.word ETH_WKUP_IRQHandler /* Ethernet Wakeup through EXTI line */
.word FDCAN_CAL_IRQHandler /* FDCAN calibration unit interrupt*/
.word DMA2_Stream5_IRQHandler /* DMA2 Stream 5 */
.word DMA2_Stream6_IRQHandler /* DMA2 Stream 6 */
.word DMA2_Stream7_IRQHandler /* DMA2 Stream 7 */
.word USART6_IRQHandler /* USART6 */
.word I2C3_EV_IRQHandler /* I2C3 event */
.word I2C3_ER_IRQHandler /* I2C3 error */
.word OTG_HS_EP1_OUT_IRQHandler /* USB OTG HS End Point 1 Out */
.word OTG_HS_EP1_IN_IRQHandler /* USB OTG HS End Point 1 In */
.word OTG_HS_WKUP_IRQHandler /* USB OTG HS Wakeup through EXTI */
.word OTG_HS_IRQHandler /* USB OTG HS */
.word DCMI_IRQHandler /* DCMI */
.word RNG_IRQHandler /* Rng */
.word FPU_IRQHandler /* FPU */
.word UART7_IRQHandler /* UART7 */
.word UART8_IRQHandler /* UART8 */
.word SPI4_IRQHandler /* SPI4 */
.word SPI5_IRQHandler /* SPI5 */
.word SPI6_IRQHandler /* SPI6 */
.word SAI1_IRQHandler /* SAI1 */
.word LTDC_IRQHandler /* LTDC */
.word LTDC_ER_IRQHandler /* LTDC error */
.word DMA2D_IRQHandler /* DMA2D */
.word SAI2_IRQHandler /* SAI2 */
.word QUADSPI_IRQHandler /* QUADSPI */
.word LPTIM1_IRQHandler /* LPTIM1 */
.word CEC_IRQHandler /* HDMI_CEC */
.word I2C4_EV_IRQHandler /* I2C4 Event */
.word I2C4_ER_IRQHandler /* I2C4 Error */
.word SPDIF_RX_IRQHandler /* SPDIF_RX */
.word OTG_FS_EP1_OUT_IRQHandler /* USB OTG FS End Point 1 Out */
.word OTG_FS_EP1_IN_IRQHandler /* USB OTG FS End Point 1 In */
.word OTG_FS_WKUP_IRQHandler /* USB OTG FS Wakeup through EXTI */
.word OTG_FS_IRQHandler /* USB OTG FS */
.word DMAMUX1_OVR_IRQHandler /* DMAMUX1 Overrun interrupt */
.word HRTIM1_Master_IRQHandler /* HRTIM Master Timer global Interrupt */
.word HRTIM1_TIMA_IRQHandler /* HRTIM Timer A global Interrupt */
.word HRTIM1_TIMB_IRQHandler /* HRTIM Timer B global Interrupt */
.word HRTIM1_TIMC_IRQHandler /* HRTIM Timer C global Interrupt */
.word HRTIM1_TIMD_IRQHandler /* HRTIM Timer D global Interrupt */
.word HRTIM1_TIME_IRQHandler /* HRTIM Timer E global Interrupt */
.word HRTIM1_FLT_IRQHandler /* HRTIM Fault global Interrupt */
.word DFSDM1_FLT0_IRQHandler /* DFSDM Filter0 Interrupt */
.word DFSDM1_FLT1_IRQHandler /* DFSDM Filter1 Interrupt */
.word DFSDM1_FLT2_IRQHandler /* DFSDM Filter2 Interrupt */
.word DFSDM1_FLT3_IRQHandler /* DFSDM Filter3 Interrupt */
.word SAI3_IRQHandler /* SAI3 global Interrupt */
.word SWPMI1_IRQHandler /* Serial Wire Interface 1 global interrupt */
.word TIM15_IRQHandler /* TIM15 global Interrupt */
.word TIM16_IRQHandler /* TIM16 global Interrupt */
.word TIM17_IRQHandler /* TIM17 global Interrupt */
.word MDIOS_WKUP_IRQHandler /* MDIOS Wakeup Interrupt */
.word MDIOS_IRQHandler /* MDIOS global Interrupt */
.word JPEG_IRQHandler /* JPEG global Interrupt */
.word MDMA_IRQHandler /* MDMA global Interrupt */
.word SDMMC2_IRQHandler /* SDMMC2 global Interrupt */
.word HSEM1_IRQHandler /* HSEM1 global Interrupt */
.word ADC3_IRQHandler /* ADC3 global Interrupt */
.word DMAMUX2_OVR_IRQHandler /* DMAMUX Overrun interrupt */
.word BDMA_Channel0_IRQHandler /* BDMA Channel 0 global Interrupt */
.word BDMA_Channel1_IRQHandler /* BDMA Channel 1 global Interrupt */
.word BDMA_Channel2_IRQHandler /* BDMA Channel 2 global Interrupt */
.word BDMA_Channel3_IRQHandler /* BDMA Channel 3 global Interrupt */
.word BDMA_Channel4_IRQHandler /* BDMA Channel 4 global Interrupt */
.word BDMA_Channel5_IRQHandler /* BDMA Channel 5 global Interrupt */
.word BDMA_Channel6_IRQHandler /* BDMA Channel 6 global Interrupt */
.word BDMA_Channel7_IRQHandler /* BDMA Channel 7 global Interrupt */
.word COMP1_IRQHandler /* COMP1 global Interrupt */
.word LPTIM2_IRQHandler /* LP TIM2 global interrupt */
.word LPTIM3_IRQHandler /* LP TIM3 global interrupt */
.word LPTIM4_IRQHandler /* LP TIM4 global interrupt */
.word LPTIM5_IRQHandler /* LP TIM5 global interrupt */
.word LPUART1_IRQHandler /* LP UART1 interrupt */
.word CRS_IRQHandler /* Clock Recovery Global Interrupt */
.word SAI4_IRQHandler /* SAI4 global interrupt */
.word WAKEUP_PIN_IRQHandler /* Interrupt for all 6 wake-up pins */
* Provide weak aliases for each Exception handler to the Default_Handler.
* As they are weak aliases, any function with the same name will override
* this definition.
.weak NMI_Handler
.thumb_set NMI_Handler,Default_Handler
.weak HardFault_Handler
.thumb_set HardFault_Handler,Default_Handler
.weak MemManage_Handler
.thumb_set MemManage_Handler,Default_Handler
.weak BusFault_Handler
.thumb_set BusFault_Handler,Default_Handler
.weak UsageFault_Handler
.thumb_set UsageFault_Handler,Default_Handler
.weak SVC_Handler
.thumb_set SVC_Handler,Default_Handler
.weak DebugMon_Handler
.thumb_set DebugMon_Handler,Default_Handler
.weak PendSV_Handler
.thumb_set PendSV_Handler,Default_Handler
.weak SysTick_Handler
.thumb_set SysTick_Handler,Default_Handler
.weak WWDG_IRQHandler
.thumb_set WWDG_IRQHandler,Default_Handler
.weak PVD_AVD_IRQHandler
.thumb_set PVD_AVD_IRQHandler,Default_Handler
.weak TAMP_STAMP_IRQHandler
.thumb_set TAMP_STAMP_IRQHandler,Default_Handler
.weak RTC_WKUP_IRQHandler
.thumb_set RTC_WKUP_IRQHandler,Default_Handler
.weak FLASH_IRQHandler
.thumb_set FLASH_IRQHandler,Default_Handler
.weak RCC_IRQHandler
.thumb_set RCC_IRQHandler,Default_Handler
.weak EXTI0_IRQHandler
.thumb_set EXTI0_IRQHandler,Default_Handler
.weak EXTI1_IRQHandler
.thumb_set EXTI1_IRQHandler,Default_Handler
.weak EXTI2_IRQHandler
.thumb_set EXTI2_IRQHandler,Default_Handler
.weak EXTI3_IRQHandler
.thumb_set EXTI3_IRQHandler,Default_Handler
.weak EXTI4_IRQHandler
.thumb_set EXTI4_IRQHandler,Default_Handler
.weak DMA1_Stream0_IRQHandler
.thumb_set DMA1_Stream0_IRQHandler,Default_Handler
.weak DMA1_Stream1_IRQHandler
.thumb_set DMA1_Stream1_IRQHandler,Default_Handler
.weak DMA1_Stream2_IRQHandler
.thumb_set DMA1_Stream2_IRQHandler,Default_Handler
.weak DMA1_Stream3_IRQHandler
.thumb_set DMA1_Stream3_IRQHandler,Default_Handler
.weak DMA1_Stream4_IRQHandler
.thumb_set DMA1_Stream4_IRQHandler,Default_Handler
.weak DMA1_Stream5_IRQHandler
.thumb_set DMA1_Stream5_IRQHandler,Default_Handler
.weak DMA1_Stream6_IRQHandler
.thumb_set DMA1_Stream6_IRQHandler,Default_Handler
.weak ADC_IRQHandler
.thumb_set ADC_IRQHandler,Default_Handler
.weak FDCAN1_IT0_IRQHandler
.thumb_set FDCAN1_IT0_IRQHandler,Default_Handler
.weak FDCAN2_IT0_IRQHandler
.thumb_set FDCAN2_IT0_IRQHandler,Default_Handler
.weak FDCAN1_IT1_IRQHandler
.thumb_set FDCAN1_IT1_IRQHandler,Default_Handler
.weak FDCAN2_IT1_IRQHandler
.thumb_set FDCAN2_IT1_IRQHandler,Default_Handler
.weak EXTI9_5_IRQHandler
.thumb_set EXTI9_5_IRQHandler,Default_Handler
.weak TIM1_BRK_IRQHandler
.thumb_set TIM1_BRK_IRQHandler,Default_Handler
.weak TIM1_UP_IRQHandler
.thumb_set TIM1_UP_IRQHandler,Default_Handler
.weak TIM1_TRG_COM_IRQHandler
.thumb_set TIM1_TRG_COM_IRQHandler,Default_Handler
.weak TIM1_CC_IRQHandler
.thumb_set TIM1_CC_IRQHandler,Default_Handler
.weak TIM2_IRQHandler
.thumb_set TIM2_IRQHandler,Default_Handler
.weak TIM3_IRQHandler
.thumb_set TIM3_IRQHandler,Default_Handler
.weak TIM4_IRQHandler
.thumb_set TIM4_IRQHandler,Default_Handler
.weak I2C1_EV_IRQHandler
.thumb_set I2C1_EV_IRQHandler,Default_Handler
.weak I2C1_ER_IRQHandler
.thumb_set I2C1_ER_IRQHandler,Default_Handler
.weak I2C2_EV_IRQHandler
.thumb_set I2C2_EV_IRQHandler,Default_Handler
.weak I2C2_ER_IRQHandler
.thumb_set I2C2_ER_IRQHandler,Default_Handler
.weak SPI1_IRQHandler
.thumb_set SPI1_IRQHandler,Default_Handler
.weak SPI2_IRQHandler
.thumb_set SPI2_IRQHandler,Default_Handler
.weak USART1_IRQHandler
.thumb_set USART1_IRQHandler,Default_Handler
.weak USART2_IRQHandler
.thumb_set USART2_IRQHandler,Default_Handler
.weak USART3_IRQHandler
.thumb_set USART3_IRQHandler,Default_Handler
.weak EXTI15_10_IRQHandler
.thumb_set EXTI15_10_IRQHandler,Default_Handler
.weak RTC_Alarm_IRQHandler
.thumb_set RTC_Alarm_IRQHandler,Default_Handler
.weak TIM8_BRK_TIM12_IRQHandler
.thumb_set TIM8_BRK_TIM12_IRQHandler,Default_Handler
.weak TIM8_UP_TIM13_IRQHandler
.thumb_set TIM8_UP_TIM13_IRQHandler,Default_Handler
.weak TIM8_TRG_COM_TIM14_IRQHandler
.thumb_set TIM8_TRG_COM_TIM14_IRQHandler,Default_Handler
.weak TIM8_CC_IRQHandler
.thumb_set TIM8_CC_IRQHandler,Default_Handler
.weak DMA1_Stream7_IRQHandler
.thumb_set DMA1_Stream7_IRQHandler,Default_Handler
.weak FMC_IRQHandler
.thumb_set FMC_IRQHandler,Default_Handler
.weak SDMMC1_IRQHandler
.thumb_set SDMMC1_IRQHandler,Default_Handler
.weak TIM5_IRQHandler
.thumb_set TIM5_IRQHandler,Default_Handler
.weak SPI3_IRQHandler
.thumb_set SPI3_IRQHandler,Default_Handler
.weak UART4_IRQHandler
.thumb_set UART4_IRQHandler,Default_Handler
.weak UART5_IRQHandler
.thumb_set UART5_IRQHandler,Default_Handler
.weak TIM6_DAC_IRQHandler
.thumb_set TIM6_DAC_IRQHandler,Default_Handler
.weak TIM7_IRQHandler
.thumb_set TIM7_IRQHandler,Default_Handler
.weak DMA2_Stream0_IRQHandler
.thumb_set DMA2_Stream0_IRQHandler,Default_Handler
.weak DMA2_Stream1_IRQHandler
.thumb_set DMA2_Stream1_IRQHandler,Default_Handler
.weak DMA2_Stream2_IRQHandler
.thumb_set DMA2_Stream2_IRQHandler,Default_Handler
.weak DMA2_Stream3_IRQHandler
.thumb_set DMA2_Stream3_IRQHandler,Default_Handler
.weak DMA2_Stream4_IRQHandler
.thumb_set DMA2_Stream4_IRQHandler,Default_Handler
.weak ETH_IRQHandler
.thumb_set ETH_IRQHandler,Default_Handler
.weak ETH_WKUP_IRQHandler
.thumb_set ETH_WKUP_IRQHandler,Default_Handler
.weak FDCAN_CAL_IRQHandler
.thumb_set FDCAN_CAL_IRQHandler,Default_Handler
.weak DMA2_Stream5_IRQHandler
.thumb_set DMA2_Stream5_IRQHandler,Default_Handler
.weak DMA2_Stream6_IRQHandler
.thumb_set DMA2_Stream6_IRQHandler,Default_Handler
.weak DMA2_Stream7_IRQHandler
.thumb_set DMA2_Stream7_IRQHandler,Default_Handler
.weak USART6_IRQHandler
.thumb_set USART6_IRQHandler,Default_Handler
.weak I2C3_EV_IRQHandler
.thumb_set I2C3_EV_IRQHandler,Default_Handler
.weak I2C3_ER_IRQHandler
.thumb_set I2C3_ER_IRQHandler,Default_Handler
.weak OTG_HS_EP1_OUT_IRQHandler
.thumb_set OTG_HS_EP1_OUT_IRQHandler,Default_Handler
.weak OTG_HS_EP1_IN_IRQHandler
.thumb_set OTG_HS_EP1_IN_IRQHandler,Default_Handler
.weak OTG_HS_WKUP_IRQHandler
.thumb_set OTG_HS_WKUP_IRQHandler,Default_Handler
.weak OTG_HS_IRQHandler
.thumb_set OTG_HS_IRQHandler,Default_Handler
.weak DCMI_IRQHandler
.thumb_set DCMI_IRQHandler,Default_Handler
.weak RNG_IRQHandler
.thumb_set RNG_IRQHandler,Default_Handler
.weak FPU_IRQHandler
.thumb_set FPU_IRQHandler,Default_Handler
.weak UART7_IRQHandler
.thumb_set UART7_IRQHandler,Default_Handler
.weak UART8_IRQHandler
.thumb_set UART8_IRQHandler,Default_Handler
.weak SPI4_IRQHandler
.thumb_set SPI4_IRQHandler,Default_Handler
.weak SPI5_IRQHandler
.thumb_set SPI5_IRQHandler,Default_Handler
.weak SPI6_IRQHandler
.thumb_set SPI6_IRQHandler,Default_Handler
.weak SAI1_IRQHandler
.thumb_set SAI1_IRQHandler,Default_Handler
.weak LTDC_IRQHandler
.thumb_set LTDC_IRQHandler,Default_Handler
.weak LTDC_ER_IRQHandler
.thumb_set LTDC_ER_IRQHandler,Default_Handler
.weak DMA2D_IRQHandler
.thumb_set DMA2D_IRQHandler,Default_Handler
.weak SAI2_IRQHandler
.thumb_set SAI2_IRQHandler,Default_Handler
.weak QUADSPI_IRQHandler
.thumb_set QUADSPI_IRQHandler,Default_Handler
.weak LPTIM1_IRQHandler
.thumb_set LPTIM1_IRQHandler,Default_Handler
.weak CEC_IRQHandler
.thumb_set CEC_IRQHandler,Default_Handler
.weak I2C4_EV_IRQHandler
.thumb_set I2C4_EV_IRQHandler,Default_Handler
.weak I2C4_ER_IRQHandler
.thumb_set I2C4_ER_IRQHandler,Default_Handler
.weak SPDIF_RX_IRQHandler
.thumb_set SPDIF_RX_IRQHandler,Default_Handler
.weak OTG_FS_EP1_OUT_IRQHandler
.thumb_set OTG_FS_EP1_OUT_IRQHandler,Default_Handler
.weak OTG_FS_EP1_IN_IRQHandler
.thumb_set OTG_FS_EP1_IN_IRQHandler,Default_Handler
.weak OTG_FS_WKUP_IRQHandler
.thumb_set OTG_FS_WKUP_IRQHandler,Default_Handler
.weak OTG_FS_IRQHandler
.thumb_set OTG_FS_IRQHandler,Default_Handler
.weak DMAMUX1_OVR_IRQHandler
.thumb_set DMAMUX1_OVR_IRQHandler,Default_Handler
.weak HRTIM1_Master_IRQHandler
.thumb_set HRTIM1_Master_IRQHandler,Default_Handler
.weak HRTIM1_TIMA_IRQHandler
.thumb_set HRTIM1_TIMA_IRQHandler,Default_Handler
.weak HRTIM1_TIMB_IRQHandler
.thumb_set HRTIM1_TIMB_IRQHandler,Default_Handler
.weak HRTIM1_TIMC_IRQHandler
.thumb_set HRTIM1_TIMC_IRQHandler,Default_Handler
.weak HRTIM1_TIMD_IRQHandler
.thumb_set HRTIM1_TIMD_IRQHandler,Default_Handler
.weak HRTIM1_TIME_IRQHandler
.thumb_set HRTIM1_TIME_IRQHandler,Default_Handler
.weak HRTIM1_FLT_IRQHandler
.thumb_set HRTIM1_FLT_IRQHandler,Default_Handler
.weak DFSDM1_FLT0_IRQHandler
.thumb_set DFSDM1_FLT0_IRQHandler,Default_Handler
.weak DFSDM1_FLT1_IRQHandler
.thumb_set DFSDM1_FLT1_IRQHandler,Default_Handler
.weak DFSDM1_FLT2_IRQHandler
.thumb_set DFSDM1_FLT2_IRQHandler,Default_Handler
.weak DFSDM1_FLT3_IRQHandler
.thumb_set DFSDM1_FLT3_IRQHandler,Default_Handler
.weak SAI3_IRQHandler
.thumb_set SAI3_IRQHandler,Default_Handler
.weak SWPMI1_IRQHandler
.thumb_set SWPMI1_IRQHandler,Default_Handler
.weak TIM15_IRQHandler
.thumb_set TIM15_IRQHandler,Default_Handler
.weak TIM16_IRQHandler
.thumb_set TIM16_IRQHandler,Default_Handler
.weak TIM17_IRQHandler
.thumb_set TIM17_IRQHandler,Default_Handler
.weak MDIOS_WKUP_IRQHandler
.thumb_set MDIOS_WKUP_IRQHandler,Default_Handler
.weak MDIOS_IRQHandler
.thumb_set MDIOS_IRQHandler,Default_Handler
.weak JPEG_IRQHandler
.thumb_set JPEG_IRQHandler,Default_Handler
.weak MDMA_IRQHandler
.thumb_set MDMA_IRQHandler,Default_Handler
.weak SDMMC2_IRQHandler
.thumb_set SDMMC2_IRQHandler,Default_Handler
.weak HSEM1_IRQHandler
.thumb_set HSEM1_IRQHandler,Default_Handler
.weak ADC3_IRQHandler
.thumb_set ADC3_IRQHandler,Default_Handler
.weak DMAMUX2_OVR_IRQHandler
.thumb_set DMAMUX2_OVR_IRQHandler,Default_Handler
.weak BDMA_Channel0_IRQHandler
.thumb_set BDMA_Channel0_IRQHandler,Default_Handler
.weak BDMA_Channel1_IRQHandler
.thumb_set BDMA_Channel1_IRQHandler,Default_Handler
.weak BDMA_Channel2_IRQHandler
.thumb_set BDMA_Channel2_IRQHandler,Default_Handler
.weak BDMA_Channel3_IRQHandler
.thumb_set BDMA_Channel3_IRQHandler,Default_Handler
.weak BDMA_Channel4_IRQHandler
.thumb_set BDMA_Channel4_IRQHandler,Default_Handler
.weak BDMA_Channel5_IRQHandler
.thumb_set BDMA_Channel5_IRQHandler,Default_Handler
.weak BDMA_Channel6_IRQHandler
.thumb_set BDMA_Channel6_IRQHandler,Default_Handler
.weak BDMA_Channel7_IRQHandler
.thumb_set BDMA_Channel7_IRQHandler,Default_Handler
.weak COMP1_IRQHandler
.thumb_set COMP1_IRQHandler,Default_Handler
.weak LPTIM2_IRQHandler
.thumb_set LPTIM2_IRQHandler,Default_Handler
.weak LPTIM3_IRQHandler
.thumb_set LPTIM3_IRQHandler,Default_Handler
.weak LPTIM4_IRQHandler
.thumb_set LPTIM4_IRQHandler,Default_Handler
.weak LPTIM5_IRQHandler
.thumb_set LPTIM5_IRQHandler,Default_Handler
.weak LPUART1_IRQHandler
.thumb_set LPUART1_IRQHandler,Default_Handler
.weak CRS_IRQHandler
.thumb_set CRS_IRQHandler,Default_Handler
.weak SAI4_IRQHandler
.thumb_set SAI4_IRQHandler,Default_Handler
.weak WAKEUP_PIN_IRQHandler
.thumb_set WAKEUP_PIN_IRQHandler,Default_Handler
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
