Version 4 SHEET 1 880 984 SYMBOL npn 176 64 R0 SYMATTR InstName Q1 SYMATTR Value KSC2690_KSC2690A SYMATTR Prefix X SYMBOL pnp 176 288 R0 SYMATTR InstName Q2 SYMATTR Value KSA1220_KSA1220A SYMATTR Prefix X TEXT -1192 -440 Left 2 !* KSA1220/KSA1220A PNP EPITAXIAL SILICON TRANSISTOR\n\n*-----------------------------------------------------------\n\n* AUDIO FREQUENCY POWER AMPLIFIER\n\n* HIGH FREQUENCY POWER AMPLIFIER \n\n* Complement to KSC2690/KSC2690A\n\n* PARAMETER MODELS EXTRACTED FROM MEASURED DATA: KSA1220A-Y\n\n*-----------------------------------------------------------\n\n* If QCO and RCO are set to zero, this model applies to\n\n* the Gummel-Poon model LEVEL 1.\n\n* If IBC and IBE are specified, they are used instead of IS.\n\n*-----------------------------------------------------------\n\n.MODEL KSA1220_KSA1220A PNP ( LEVEL=2\n\n+ IS =4.7863E-13 \n\n+ BF =289.3\n\n+ NF =1.0 \n\n+ BR =9.76\n\n+ NR =1.006\n\n*+ IBC =4.7863E-13\n\n*+ IBC =4.7863E-13\n\n+ ISE =5.2481E-12\n\n+ NE =2\n\n+ ISC =2.4909E-11\n\n+ NC =1.5\n\n+ VAF =98.5\n\n+ VAR =6.7\n\n+ IKF =2.7061\n\n+ IKR =0.0759\n\n+ RB =2.26\n\n+ RBM =0.2308\n\n+ IRB =0.001\n\n+ RE =0.1908\n\n+ RC =1.1748\n\n+ QCO =0.02\n\n+ RCO =3.9811\n\n+ VO =11.078\n\n+ GAMMA =5.01187E-8\n\n+ CJE =3.4786E-10\n\n+ VJE =0.9575\n\n+ MJE =0.4694\n\n+ FC =0.5\n\n+ CJC =1.1224E-10\n\n+ VJC =0.5761\n\n+ MJC =0.4365\n\n+ XCJC =0.4955 \n\n+ XTB =1.7978 \n\n+ EG =1.2255 \n\n+ XTI =3.0 )\n\n*---------------------------------------------------------\n\n* FAIRCHILD CASE: TO-126 PID:KSA1220A-Y\n\n* 2000-03-30 CREATION TEXT -2000 -432 Left 2 !* KSC2690/KSC2690A NPN EPITAXIAL SILICON TRANSISTOR\n\n*-----------------------------------------------------------\n\n* AUDIO FREQUENCY, HIGH FREQUENCY POWER AMPLIFIER\n\n* Complement to KSA1220/KSA1220A\n\n* PARAMETER MODELS EXTRACTED FROM MEASURED DATA: KSC2690A-O\n\n*-----------------------------------------------------------\n\n* If QCO and RCO are set to zero, this model applies to\n\n* the Gummel-Poon model LEVEL 1.\n\n* If IBC and IBE are specified, they are used instead of IS.\n\n*-----------------------------------------------------------\n\n.MODEL KSC2690_KSC2690A NPN ( LEVEL=2\n\n+ IS =1.7783E-13 \n\n+ BF =132.5\n\n+ NF =1.0 \n\n+ BR =8.495\n\n+ NR =1.005\n\n*+ IBC =1.7783E-13 \n\n*+ IBC =1.7783E-13 \n\n+ ISE =1.9953E-13\n\n+ NE =1.5\n\n+ ISC =1.5849E-9\n\n+ NC =1.98\n\n+ VAF =580.75\n\n+ VAR =18.15\n\n+ IKF =4.0271\n\n+ IKR =0.0120\n\n+ RB =2.98\n\n+ RBM =0.001\n\n+ IRB =0.6396\n\n+ RE =0.0909\n\n+ RC =1.4705\n\n+ QCO =0.68\n\n+ RCO =3.6239\n\n+ VO =6.587\n\n+ GAMMA =2.8216E-7\n\n+ CJE =4.0082E-10\n\n+ VJE =0.6696\n\n+ MJE =0.3296\n\n+ FC =0.5\n\n+ CJC =6.0404E-11\n\n+ VJC =0.5\n\n+ MJC =0.4266\n\n+ XCJC =0.4955 \n\n+ XTB =1.2590 \n\n+ EG =1.2277 \n\n+ XTI =3.0 )\n\n*---------------------------------------------------------\n\n* FAIRCHILD CASE: TO-126 PID:KSC2690A-O\n\n* 2000-03-30 CREATION TEXT -2002 968 Left 2 !.tran 0 10m 0 1m
