 * This file is part of the µOS++ distribution.
 *   (https://github.com/micro-os-plus)
 * Copyright (c) 2014 Liviu Ionescu.
 * Permission is hereby granted, free of charge, to any person
 * obtaining a copy of this software and associated documentation
 * files (the "Software"), to deal in the Software without
 * restriction, including without limitation the rights to use,
 * copy, modify, merge, publish, distribute, sublicense, and/or
 * sell copies of the Software, and to permit persons to whom
 * the Software is furnished to do so, subject to the following
 * conditions:
 * The above copyright notice and this permission notice shall be
 * included in all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 * EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
 * OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 * NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 * HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
 * WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 * OTHER DEALINGS IN THE SOFTWARE.
#if defined(TRACE)
#include "cmsis_device.h"
#include "diag/Trace.h"
// One of these definitions must be passed via the compiler command line
// Note: small Cortex-M0/M0+ might implement a simplified debug interface.
//#define OS_USE_TRACE_ITM
//#define OS_USE_TRACE_SEMIHOSTING_DEBUG
//#define OS_USE_TRACE_SEMIHOSTING_STDOUT
#if !(defined(__ARM_ARCH_7M__) || defined(__ARM_ARCH_7EM__))
#if defined(OS_USE_TRACE_ITM)
#undef OS_USE_TRACE_ITM
#warning "ITM unavailable"
#endif // defined(OS_USE_TRACE_ITM)
#endif // !(defined(__ARM_ARCH_7M__) || defined(__ARM_ARCH_7EM__))
#if defined(OS_DEBUG_SEMIHOSTING_FAULTS)
#if defined(OS_USE_TRACE_SEMIHOSTING_STDOUT) || defined(OS_USE_TRACE_SEMIHOSTING_DEBUG)
#error "Cannot debug semihosting using semihosting trace; use OS_USE_TRACE_ITM"
#endif
#endif
// Forward definitions.
static ssize_t
_trace_write_itm (const char* buf, size_t nbyte);
#endif
static ssize_t
_trace_write_semihosting_stdout(const char* buf, size_t nbyte);
#endif
#if defined(OS_USE_TRACE_SEMIHOSTING_DEBUG)
static ssize_t
_trace_write_semihosting_debug(const char* buf, size_t nbyte);
#endif
void
trace_initialize(void)
  // For regular ITM / semihosting, no inits required.
// This function is called from _write() for fd==1 or fd==2 and from some
// of the trace_* functions.
ssize_t
trace_write (const char* buf __attribute__((unused)),
	     size_t nbyte __attribute__((unused)))
  return _trace_write_itm (buf, nbyte);
#elif defined(OS_USE_TRACE_SEMIHOSTING_STDOUT)
  return _trace_write_semihosting_stdout(buf, nbyte);
#elif defined(OS_USE_TRACE_SEMIHOSTING_DEBUG)
  return _trace_write_semihosting_debug(buf, nbyte);
#endif
  return -1;
#if defined(__ARM_ARCH_7M__) || defined(__ARM_ARCH_7EM__)
// ITM is the ARM standard mechanism, running over SWD/SWO on Cortex-M3/M4
// devices, and is the recommended setting, if available.
// The JLink probe and the GDB server fully support SWD/SWO
// and the JLink Debugging plug-in enables it by default.
// The current OpenOCD does not include support to parse the SWO stream,
// so this configuration will not work on OpenOCD (will not crash, but
// nothing will be displayed in the output console).
#if !defined(OS_INTEGER_TRACE_ITM_STIMULUS_PORT)
#define OS_INTEGER_TRACE_ITM_STIMULUS_PORT     (0)
#endif
static ssize_t
  for (size_t i = 0; i < nbyte; i++)
      // Check if ITM or the stimulus port are not enabled
      if (((ITM->TCR & ITM_TCR_ITMENA_Msk) == 0)
	  || ((ITM->TER & (1UL << OS_INTEGER_TRACE_ITM_STIMULUS_PORT)) == 0))
	  return (ssize_t)i; // return the number of sent characters (may be 0)
      // Wait until STIMx is ready...
      while (ITM->PORT[OS_INTEGER_TRACE_ITM_STIMULUS_PORT].u32 == 0)
      // then send data, one byte at a time
      ITM->PORT[OS_INTEGER_TRACE_ITM_STIMULUS_PORT].u8 = (uint8_t) (*buf++);
  return (ssize_t)nbyte; // all characters successfully sent
#endif // defined(__ARM_ARCH_7M__) || defined(__ARM_ARCH_7EM__)
#endif // OS_USE_TRACE_ITM
#if defined(OS_USE_TRACE_SEMIHOSTING_DEBUG) || defined(OS_USE_TRACE_SEMIHOSTING_STDOUT)
#include "arm/semihosting.h"
// Semihosting is the other output channel that can be used for the trace
// messages. It comes in two flavours: STDOUT and DEBUG. The STDOUT channel
// is the equivalent of the stdout in POSIX and in most cases it is forwarded
// to the GDB server stdout stream. The debug channel is a separate
// channel. STDOUT is buffered, so nothing is displayed until a \n;
// DEBUG is not buffered, but can be slow.
// Choosing between semihosting stdout and debug depends on the capabilities
// of your GDB server, and also on specific needs. It is recommended to test
// DEBUG first, and if too slow, try STDOUT.
// The JLink GDB server fully support semihosting, and both configurations
// are available; to activate it, use "monitor semihosting enable" or check
// the corresponding button in the JLink Debugging plug-in.
// In OpenOCD, support for semihosting can be enabled using
// "monitor arm semihosting enable".
// Note: Applications built with semihosting output active normally cannot
// be executed without the debugger connected and active, since they use
// BKPT to communicate with the host. However, with a carefully written
// HardFault_Handler, the semihosting BKPT calls can be processed, making
// possible to run semihosting applications as standalone, without being
// terminated with hardware faults.
#endif // OS_USE_TRACE_SEMIHOSTING_DEBUG_*
static ssize_t
_trace_write_semihosting_stdout (const char* buf, size_t nbyte)
  static int handle;
  void* block[3];
  int ret;
  if (handle == 0)
      // On the first call get the file handle from the host
      block[0] = ":tt"; // special filename to be used for stdin/out/err
      block[1] = (void*) 4; // mode "w"
      // length of ":tt", except null terminator
      block[2] = (void*) (sizeof(":tt") - 1);
      ret = call_host (SEMIHOSTING_SYS_OPEN, (void*) block);
      if (ret == -1)
        return -1;
      handle = ret;
  block[0] = (void*) handle;
  block[1] = (void*) buf;
  block[2] = (void*) nbyte;
  // send character array to host file/device
  ret = call_host (SEMIHOSTING_SYS_WRITE, (void*) block);
  // this call returns the number of bytes NOT written (0 if all ok)
  // -1 is not a legal value, but SEGGER seems to return it
  if (ret == -1)
    return -1;
  // The compliant way of returning errors
  if (ret == (int) nbyte)
    return -1;
  // Return the number of bytes written
  return (ssize_t) (nbyte) - (ssize_t) ret;
#endif // OS_USE_TRACE_SEMIHOSTING_STDOUT
#define OS_INTEGER_TRACE_TMP_ARRAY_SIZE  (16)
static ssize_t
_trace_write_semihosting_debug (const char* buf, size_t nbyte)
  // Since the single character debug channel is quite slow, try to
  // optimise and send a null terminated string, if possible.
  if (buf[nbyte] == '\0')
      // send string
      call_host (SEMIHOSTING_SYS_WRITE0, (void*) buf);
  else
      // If not, use a local buffer to speed things up
      char tmp[OS_INTEGER_TRACE_TMP_ARRAY_SIZE];
      size_t togo = nbyte;
      while (togo > 0)
          unsigned int n = ((togo < sizeof(tmp)) ? togo : sizeof(tmp));
          unsigned int i = 0;
          for (; i < n; ++i, ++buf)
              tmp[i] = *buf;
          tmp[i] = '\0';
          call_host (SEMIHOSTING_SYS_WRITE0, (void*) tmp);
          togo -= n;
  // All bytes written
  return (ssize_t) nbyte;
#endif // TRACE
