(module Oddities:NetTie-I_Connected (layer F.Cu) (tedit 0)
  (descr "Just a \"Net tie\" as an more or less elegant way to connect two different nets without disturbing ERC and DRC.")
  (tags "Just a \"Net tie\" as an more or less elegant way to connect two different nets without disturbing ERC and DRC.")
  (fp_text reference REF** (at -0.04064 4.06908) (layer F.SilkS)
    (effects (font (size 1 1) (thickness 0.15)))
  (fp_text value NetTie-I_InnerLayer_Connected (at 0 -3.048) (layer F.Fab)
  (fp_line (start 1.778 1.016) (end -1.778 1.016) (layer In1.Cu) (width 0.3048))
  (fp_line (start -1.778 1.016) (end -1.778 0.762) (layer In1.Cu) (width 0.3048))
  (fp_line (start -1.778 0.762) (end 1.778 0.762) (layer In1.Cu) (width 0.3048))
  (fp_line (start 1.778 0.762) (end 1.778 0.508) (layer In1.Cu) (width 0.3048))
  (fp_line (start 1.778 0.508) (end -1.778 0.508) (layer In1.Cu) (width 0.3048))
  (fp_line (start -1.778 0.508) (end -1.778 0.254) (layer In1.Cu) (width 0.3048))
  (fp_line (start -1.778 0.254) (end 1.778 0.254) (layer In1.Cu) (width 0.3048))
  (fp_line (start 1.778 0.254) (end 1.778 0) (layer In1.Cu) (width 0.3048))
  (fp_line (start 1.778 0) (end -1.778 0) (layer In1.Cu) (width 0.3048))
  (fp_line (start -1.778 0) (end -1.778 -0.254) (layer In1.Cu) (width 0.3048))
  (fp_line (start -1.778 -0.254) (end 1.778 -0.254) (layer In1.Cu) (width 0.3048))
  (fp_line (start 1.778 -0.254) (end 1.778 -0.508) (layer In1.Cu) (width 0.3048))
  (fp_line (start 1.778 -0.508) (end -1.778 -0.508) (layer In1.Cu) (width 0.3048))
  (fp_line (start -1.778 -0.508) (end -1.778 -0.762) (layer In1.Cu) (width 0.3048))
  (fp_line (start -1.778 -0.762) (end 1.778 -0.762) (layer In1.Cu) (width 0.3048))
  (fp_line (start 1.778 -0.762) (end 1.778 -1.016) (layer In1.Cu) (width 0.3048))
  (fp_line (start 1.778 -1.016) (end -1.778 -1.016) (layer In1.Cu) (width 0.3048))
  (pad 1 thru_hole rect (at -2.54 0) (size 1.99898 1.99898) (drill 1.00076) (layers *.Cu *.Mask))
  (pad 2 thru_hole rect (at 2.54 0) (size 1.99898 1.99898) (drill 1.00076) (layers *.Cu *.Mask))
