################################################################################ # Automatically-generated file. Do not edit! ################################################################################ SHELL := cmd.exe RM := rm -rf USER_OBJS := LIBS := PROJ := O_SRCS := C_SRCS := S_SRCS := S_UPPER_SRCS := OBJ_SRCS := ASM_SRCS := PREPROCESSING_SRCS := OBJS := OBJS_AS_ARGS := C_DEPS := C_DEPS_AS_ARGS := EXECUTABLES := OUTPUT_FILE_PATH := OUTPUT_FILE_PATH_AS_ARGS := AVR_APP_PATH :=$$$AVR_APP_PATH$$$ QUOTE := " ADDITIONAL_DEPENDENCIES:= OUTPUT_FILE_DEP:= LIB_DEP:= LINKER_SCRIPT_DEP:= # Every subdirectory with source files must be described here SUBDIRS := \ ../Device_Startup/ # Add inputs and outputs from these tool invocations to the build variables C_SRCS += \ ../Device_Startup/startup_sam3xa.c \ ../Device_Startup/system_sam3xa.c \ ../DUE_clock.c \ ../DUE_global.c \ ../DUE_LCD_display.c \ ../DUE_TWI1.c \ ../main.c \ ../syscalls.c PREPROCESSING_SRCS += ASM_SRCS += OBJS += \ Device_Startup/startup_sam3xa.o \ Device_Startup/system_sam3xa.o \ DUE_clock.o \ DUE_global.o \ DUE_LCD_display.o \ DUE_TWI1.o \ main.o \ syscalls.o OBJS_AS_ARGS += \ Device_Startup/startup_sam3xa.o \ Device_Startup/system_sam3xa.o \ DUE_clock.o \ DUE_global.o \ DUE_LCD_display.o \ DUE_TWI1.o \ main.o \ syscalls.o C_DEPS += \ Device_Startup/startup_sam3xa.d \ Device_Startup/system_sam3xa.d \ DUE_clock.d \ DUE_global.d \ DUE_LCD_display.d \ DUE_TWI1.d \ main.d \ syscalls.d C_DEPS_AS_ARGS += \ Device_Startup/startup_sam3xa.d \ Device_Startup/system_sam3xa.d \ DUE_clock.d \ DUE_global.d \ DUE_LCD_display.d \ DUE_TWI1.d \ main.d \ syscalls.d OUTPUT_FILE_PATH +=test_printf_float.elf OUTPUT_FILE_PATH_AS_ARGS +=test_printf_float.elf ADDITIONAL_DEPENDENCIES:= OUTPUT_FILE_DEP:= ./makedep.mk LIB_DEP+= LINKER_SCRIPT_DEP+= \ ../Device_Startup/sam3x8e_flash.ld \ ../Device_Startup/sam3x8e_sram.ld \ ../Device_Startup/sam3xa_flash.ld \ ../Device_Startup/sam3xa_sram.ld # AVR32/GNU C Compiler Device_Startup/startup_sam3xa.o: ../Device_Startup/startup_sam3xa.c @echo Building file: $< @echo Invoking: ARM/GNU C Compiler : 6.3.1 $(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe$(QUOTE) -x c -funsigned-char -mthumb -D__SAM3X8E__ -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\arm\cmsis\5.0.1\CMSIS\Include" -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.50\include" -O1 -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m3 -c -std=gnu99 -Wl,-u,_printf_float -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)" -o "$@" "$<" @echo Finished building: $< Device_Startup/system_sam3xa.o: ../Device_Startup/system_sam3xa.c @echo Building file: $< @echo Invoking: ARM/GNU C Compiler : 6.3.1 $(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe$(QUOTE) -x c -funsigned-char -mthumb -D__SAM3X8E__ -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\arm\cmsis\5.0.1\CMSIS\Include" -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.50\include" -O1 -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m3 -c -std=gnu99 -Wl,-u,_printf_float -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)" -o "$@" "$<" @echo Finished building: $< ./DUE_clock.o: .././DUE_clock.c @echo Building file: $< @echo Invoking: ARM/GNU C Compiler : 6.3.1 $(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe$(QUOTE) -x c -funsigned-char -mthumb -D__SAM3X8E__ -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\arm\cmsis\5.0.1\CMSIS\Include" -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.50\include" -O1 -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m3 -c -std=gnu99 -Wl,-u,_printf_float -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)" -o "$@" "$<" @echo Finished building: $< ./DUE_global.o: .././DUE_global.c @echo Building file: $< @echo Invoking: ARM/GNU C Compiler : 6.3.1 $(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe$(QUOTE) -x c -funsigned-char -mthumb -D__SAM3X8E__ -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\arm\cmsis\5.0.1\CMSIS\Include" -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.50\include" -O1 -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m3 -c -std=gnu99 -Wl,-u,_printf_float -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)" -o "$@" "$<" @echo Finished building: $< ./DUE_LCD_display.o: .././DUE_LCD_display.c @echo Building file: $< @echo Invoking: ARM/GNU C Compiler : 6.3.1 $(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe$(QUOTE) -x c -funsigned-char -mthumb -D__SAM3X8E__ -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\arm\cmsis\5.0.1\CMSIS\Include" -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.50\include" -O1 -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m3 -c -std=gnu99 -Wl,-u,_printf_float -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)" -o "$@" "$<" @echo Finished building: $< ./DUE_TWI1.o: .././DUE_TWI1.c @echo Building file: $< @echo Invoking: ARM/GNU C Compiler : 6.3.1 $(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe$(QUOTE) -x c -funsigned-char -mthumb -D__SAM3X8E__ -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\arm\cmsis\5.0.1\CMSIS\Include" -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.50\include" -O1 -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m3 -c -std=gnu99 -Wl,-u,_printf_float -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)" -o "$@" "$<" @echo Finished building: $< ./main.o: .././main.c @echo Building file: $< @echo Invoking: ARM/GNU C Compiler : 6.3.1 $(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe$(QUOTE) -x c -funsigned-char -mthumb -D__SAM3X8E__ -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\arm\cmsis\5.0.1\CMSIS\Include" -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.50\include" -O1 -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m3 -c -std=gnu99 -Wl,-u,_printf_float -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)" -o "$@" "$<" @echo Finished building: $< ./syscalls.o: .././syscalls.c @echo Building file: $< @echo Invoking: ARM/GNU C Compiler : 6.3.1 $(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe$(QUOTE) -x c -funsigned-char -mthumb -D__SAM3X8E__ -DDEBUG -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\arm\cmsis\5.0.1\CMSIS\Include" -I"C:\Program Files (x86)\Atmel\Studio\7.0\Packs\atmel\SAM3X_DFP\1.0.50\include" -O1 -ffunction-sections -mlong-calls -g3 -Wall -mcpu=cortex-m3 -c -std=gnu99 -Wl,-u,_printf_float -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)" -o "$@" "$<" @echo Finished building: $< # AVR32/GNU Preprocessing Assembler # AVR32/GNU Assembler ifneq ($(MAKECMDGOALS),clean) ifneq ($(strip $(C_DEPS)),) -include $(C_DEPS) endif endif # Add inputs and outputs from these tool invocations to the build variables # All Target all: $(OUTPUT_FILE_PATH) $(ADDITIONAL_DEPENDENCIES) $(OUTPUT_FILE_PATH): $(OBJS) $(USER_OBJS) $(OUTPUT_FILE_DEP) $(LIB_DEP) $(LINKER_SCRIPT_DEP) @echo Building target: $@ @echo Invoking: ARM/GNU Linker : 6.3.1 $(QUOTE)C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-gcc.exe$(QUOTE) -o$(OUTPUT_FILE_PATH_AS_ARGS) $(OBJS_AS_ARGS) $(USER_OBJS) $(LIBS) -mthumb -Wl,-Map="test_printf_float.map" --specs=rdimon.specs -Wl,--start-group -lm -Wl,--end-group -L"..\\Device_Startup" -Wl,--gc-sections -mcpu=cortex-m3 -Tsam3x8e_flash.ld -u _print_float @echo Finished building target: $@ "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-objcopy.exe" -O binary "test_printf_float.elf" "test_printf_float.bin" "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature "test_printf_float.elf" "test_printf_float.hex" "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-objcopy.exe" -j .eeprom --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0 --no-change-warnings -O binary "test_printf_float.elf" "test_printf_float.eep" || exit 0 "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-objdump.exe" -h -S "test_printf_float.elf" > "test_printf_float.lss" "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-objcopy.exe" -O srec -R .eeprom -R .fuse -R .lock -R .signature "test_printf_float.elf" "test_printf_float.srec" "C:\Program Files (x86)\Atmel\Studio\7.0\toolchain\arm\arm-gnu-toolchain\bin\arm-none-eabi-size.exe" "test_printf_float.elf" # Other Targets clean: -$(RM) $(OBJS_AS_ARGS) $(EXECUTABLES) -$(RM) $(C_DEPS_AS_ARGS) rm -rf "test_printf_float.elf" "test_printf_float.a" "test_printf_float.hex" "test_printf_float.bin" "test_printf_float.lss" "test_printf_float.eep" "test_printf_float.map" "test_printf_float.srec"
