BASE.EXE ======== ..\..\..\..\os.031\c_source\agency.c Agency - Init Agency - Install Agency - Remove Agency - PutList Agency - AddList Agency - GetList Agency - FinishMacro Agency - TickList Agency - WorkList Agency - SuspendList Agency - SetTime Agency - RemoveTime Agency - ResetTime Agency - Error ..\..\..\..\os.031\c_source\dispatch.c Dispatcher - Loop Dispatcher - Error Dispatcher - OverloadCall Dispatcher - OverloadRecover Dispatcher - Init Dispatcher - Install Dispatcher - Remove Dispatcher - Start Dispatcher - Enable Dispatcher - Disable Dispatcher - ExitLoop Dispatcher - ExitLoopWithTimeout Dispatcher - Get Calling Instno Dispatcher - SetPriority Dispatcher - withTimeout Dispatcher - setTimeout Dispatcher - delTimeout Dispatcher - tickTimeout Dispatcher - GetAssociation Dispatcher - Unlock Dispatcher - Lock Dispatcher - ClearQueue Dispatcher - SetCallMethod Dispatcher - SetRecoverMethod Dispatcher - SwitchRecorderMode ..\..\..\..\os.031\c_source\queue.c Queue - Init Queue - Install Queue - Remove Queue - Inquiry Queue - Jam Queue - PostOrRecover Queue - PostOrRecoverN Queue - Accept Queue - AcceptOrRecover Queue - DeleteEntry Queue - CalculateData Queue - CalculateBlock Queue - DeleteData Queue - Error ..\..\..\..\userbase.031\c_source\userbase.c Userbase - Init Userbase - Install Userbase - TestRam Userbase - Reload Userbase - Remove Userbase - GetReference Userbase - GetValue Userbase - GetDefault Userbase - ChangeValue Userbase - BeginMeasureFrame Userbase - EndMeasureFrame Userbase - SendResult Userbase - SendSystemError Userbase - Shutdown Userbase - ReceiveProtocol Userbase Userbase - EnterTimerEvent Userbase - Recover Userbase - SetValueDrain Userbase - SetLimitDrain Userbase - SetCheckDrain Userbase - SetSpecialDrain Userbase - SetDefaultData Userbase - SetResetData Userbase - TestOverload Userbase - ShowEmptyNonvolatileError Userbase - ShowInstableNonvolatileError Userbase - getNonvolatileInfo Userbase - GetRealizationRange Userbase - GetFirstGroupMember Userbase - GetNextGroupMember Userbase - Lock Userbase - Unlock Userbase - disableNonvolatile Userbase - enableNonvolatile Userbase - determineUserbaseInstNo Userbase - EnterAnswer Userbase - EnterReset Userbase - EnterPreset Userbase - EnterSetdef Userbase - EnterGroup Userbase - EnterAvailableOptions Userbase - EnterStartup Userbase - EnterShutdown Userbase - EnterError Userbase: QueueFull Userbase - WorkProtocolSeq ..\..\..\..\userbase.031\c_source\paramete.c Parameter - Init Parameter - Install Parameter - Remove Parameter - Write Parameter - Show Parameter - Write_show Parameter - SystemError Parameter - BreakEditor Parameter - GetResult Parameter - InstallResult Parameter - TransferResult Parameter - CheckResult Parameter - LimitResult Parameter - SetDefResult Parameter - DefaultResult Parameter - Place Parameter - Update Parameter - Place_update Parameter - GetValue Parameter - GetReferences Parameter - Copy Parameter - CopyArray Parameter - Get Parameter - AttachRemote Parameter - Check Parameter - Limit Parameter - Convert Parameter - ConvertParameter Parameter - StartEdit Parameter - SwitchEdit Parameter - FinishEdit Parameter - AddAction Parameter - DeleteAction Parameter - InstallTimer Parameter - RemoveTimer Parameter - TimeoutFct Parameter - GetDefault Parameter - GetArray Parameter - PlaceArray Parameter - MoveArray Parameter - GetArrayRef Parameter - PlaceArrayRef Parameter - TransferRef Parameter - Reset Parameter - Preset Parameter - SetToFactoryDefault Parameter - Shutdown Parameter - PlaceIntoTransaction Parameter - GetValueFromTransaction Parameter - CopyBetweenTransactions Parameter - StartTransaction Parameter - StopTransaction Parameter - RealizeTransaction Parameter - JoinTransaction Parameter - CompareWithTransaction Parameter - searchIndexByValue Parameter - getNonvolatileInfo Parameter - disableNonvolatile Parameter - enableNonvolatile Parameter - getDependence Parameter - BreakTransaction Parameter - AddToTransaction Parameter - CheckAgainstTransaction Parameter - LimitInTransaction Parameter - Error Parameter - StartDiagram Parameter - EndDiagram Parameter - MeasureFrame Parameter - Reload Parameter - TestRam Parameter - EnterTimerEvent Parameter - ShowEmptyNonvolatileError Parameter - ShowInstableNonvolatileError Parameter - Lock Parameter - Unlock Parameter - CheckExistance 0,"No error -100,"Command error -101,"Invalid character -102,"Syntax error -103,"Invalid separator -104,"Data type error -105,"GET not allowed -108,"Parameter not allowed -109,"Missing parameter -111,"Header separator error -112,"Program mnemonic too long -113,"Undefined header -114,"Header suffix out of range -120,"Numeric data error -121,"Invalid character in number -123,"Exponent too large -124,"Too many digits -128,"Numeric data not allowed -131,"Invalid suffix -134,"Suffix too long -138,"Suffix not allowed -141,"Invalid character data -144,"Character data too long -148,"Character data not allowed -151,"Invalid string data -158,"String data not allowed -161,"Invalid block data -168,"Block data not allowed -171,"Invalid expression -178,"Expression data not allowed -180,"Macro error -200,"Execution error -203,"Command protected -211,"Trigger ignored -212,"Arm ignored -213,"Init ignored -221,"Setting conflict -222,"Data out of range -223,"Too much data -224,"Illegal parameter value -225,"Out of memory -226,"List not of same length -230,"Data corrupt or stale -240,"Hardware error -241,"Hardware missing -250,"Mass storage error -251,"Missing mass storage -252,"Missing media -253,"Corrupt media -254,"Media full -255,"Directory full -256,"File name not found -257,"File name error -258,"Media protected -300,"Device-specific error -310,"System error -311,"Memory error -313,"Calibration memory lost -314,"Save/recall memory lost -315,"Configuration memory lost -330,"Self test failed -350,"Queue overflow -360,"Communication error -361,"Parity error in program message -362,"Framing error in program message -363,"Input buffer overrun -400,"Query error -410,"Query INTERRUPTED -420,"Query UNTERMINATED -430,"Query DEADLOCKED -440,"Query UNTERMINATED after indefinite response 1,"Device dependent error Klasse: Measurement =================== InstNo |Req|Ack| Mod|Riv|FUC| UC| RC|AOC|RAC|WQ|WS|WR|WA|RDActive ------------------------------------------------------------------------------- %10d|%3d|%3d|%5d|%3d|%3d|%3d|%3d|%3d|%3d|%2d|%2d|%2d|%2d|%2d ----------------------------------------------------------------------------End BASE.DLL ========= TSK_MSG_ID_MEAS_RUN TSK_MSG_ID_MEAS_OFF TSK_MSG_ID_MEAS_SUPP TSK_MSG_ID_MEAS_HALT TSK_MSG_ID_MODIFICATION_RX_START TSK_MSG_ID_MODIFICATION_RX_FINISH TSK_MSG_ID_MODIFICATION_TX_START TSK_MSG_ID_MODIFICATION_TX_FINISH TSK_MSG_ID_MODIFICATION_SIG_STATE CMUDRV.DL0 ========== COR_CMD_SET_LO_FREQUENCY COR_CMD_CREATE_USER_TABLE COR_CMD_OPEN_TABLE COR_CMD_STORE_TABLE COR_CMD_CLOSE_TABLE COR_CMD_WRITE_TABLE COR_CMD_READ_TABLE COR_CMD_WRITE_TABLEITEM COR_CMD_READ_TABLEITEM COR_CMD_SET_MEASUREMENT_MODE COR_CMD_SET_FA1_FREQUENCY COR_CMD_SET_FREQUENCY COR_CMD_SET_FREQ_BOUNDARY COR_CMD_LOAD_PROGRAM COR_CMD_UPDATE_INTERNAL_TABLES COR_CMD_START_USER_PROGRAM COR_CMD_START_BOOT_PROGRAM COR_CMD_SUB_SUPP_SET_FREQ_BORDERS COR_CMD_GET_MEASUREMENT_MODE COR_CMD_SET_FRONTEND_TYPE COR_CMD_SET_FILTER_GROUP COR_ERR_INDEX_OUT_OF_RANGE COR_ERR_INVALID_ARGUMENT COR_ERR_INVALID_FREQ_BAND COR_ERR_UNKNOWN_PARAMETER_ID COR_ERR_INVALID_PARAMETER_SIZE COR_ERR_INVALID_MSG_STRUCTURE COR_ERR_PARAMETER_TOO_LARGE COR_SIG_RX COR_SIG_TX COR_FRB_LO COR_FRB_MED_1 COR_FRB_MED_2 COR_FRB_HI_1 COR_FRB_HI_2 COR_FRB_VHI_1 COR_FRB_VHI_2 COR_SW_RX_BWFLT COR_SW_RX_SELFLT COR_SW_RX_DET1 COR_SW_RX_DET2 COR_SW_RX_DET3 COR_SW_RX_SHRES COR_SW_RX_SPEED COR_SW_RX_FILTER COR_SW_RX_DETECTOR COR_SW_RX_ATT0 COR_SW_RX_ATT1 COR_SW_RX_ATT2 COR_SW_RX_ATT3 COR_SW_RX_ATT4 COR_SW_RX_ATT5 COR_SW_RX_ATT6 COR_SW_RX_AMP COR_SW_RX_LFGAIN COR_SW_RX_STEPATT COR_SW_RX_HIGHIF COR_SW_RX_HIGHRF COR_SW_RX_RF2700 COR_SW_RX_LOWRF COR_SW_RX_LO1EN COR_SW_RX_VCO1 COR_SW_RX_VCO2 COR_SW_RX_PDEN COR_SW_RX_TUNE COR_SW_RX_OFFSET COR_SW_RX_LO3EN COR_SW_RX_NCO set_rf_frequency() ..\..\src\auxtx.cpp Frequency out of range ..\..\src\auxtx.cpp InFrequency=%f, Bcounter=%d, Acounter=%d Ncl0=%d, Ncl1=%d, Ncl2=%d Switch=%x, IOffset=%d, , QOffset=%d, AttenuationSet=%d 0@AUXTXW: set_rf_frequency() @..\..\src\auxtx.cpp Frequency out of range ..\..\src\auxtx.cpp OffsetNCL0=%x, BASERegAdd=%x A..\..\src\auxtx.cpp $Revision: /main/5.20/1 $ UINT8 ACHAR UINT16 INT16 FIX16D2 UINT32 INT32 UINT64 DOUBLE COR_PBID_CONNECTOR(UINT16) COR_PBID_DIGITAL_LEVEL_PORT(UINT16) COR_PBID_IQIF_PATH(UINT16) COR_PBID_COPRO_PATH(UINT16) COR_PBID_MIXER_MODE(UINT16) COR_PBID_FILTER_GROUP(UINT16) COR_PBID_APPLICATION_MODE(UINT16) COR_PBID_TEMP_COR_FIX(UINT16) COR_PBID_CORRECTION_MODE(UINT16) COR_PBID_SUB_SUPP_MODE(UINT16) COR_PBID_TRIGGER_SOURCE(UINT16) COR_PBID_TXCAL_SOURCE(UINT16) COR_PBID_PULSE_CAL(UINT16) COR_PBID_FM_MODULATION(UINT16) COR_PBID_AUTO_INCREMENT(UINT16) COR_PBID_AUTO_RELOAD(UINT16) COR_PBID_UPDATE_ASYNCHRON(UINT16) COR_PBID_SSI_ACKNOWLEDGE1(UINT16) COR_PBID_SSI_ACKNOWLEDGE2(UINT16) COR_PBID_COMB_MODE(UINT16) COR_PBID_POWER_DETECTOR(UINT16) COR_PBID_JITTER_MODE(UINT16) COR_PBID_EXTERNAL_IF2(UINT16) COR_PBID_NO_OF_CHANNELS(UINT16) COR_PBID_ACTIVE_CHANNEL(UINT16) COR_PBID_TRIGGER_CHANNEL(UINT16) COR_PBID_SPECTRUM_STEPS_LO(UINT16) COR_PBID_DEBUG_OPTION(UINT16) COR_PBID_SSI_ENABLE(UINT16) COR_PBID_FREQ_BAND_OVERLAP(UINT16) COR_PBID_CALIBRATION_MODE(UINT16) COR_PBID_POWER_UP(UINT16) COR_PBID_FLT_CHAR_POINTS(UINT16) COR_PBID_FLT_BAND_POS_VIEW(UINT16) COR_PBID_SPECTRUM_STEPS_HI(UINT16) COR_PBID_EXGAIN_MODE(UINT16) COR_PBID_ACK_ACTIVE_TIME(UINT16) COR_PBID_TRIGGER_LEVEL(FIX16D2) COR_PBID_NOTCH_LEVEL_RESERVE(FIX16D2) COR_PBID_AT_OFFSET_LEVEL(FIX16D2) COR_PBID_AT_OFFSET_LEVEL(FIX16D2) COR_PBID_RXTX_RF_TEMPERATURE(FIX16D2) COR_PBID_RXTX_IF_TEMPERATURE(FIX16D2) COR_PBID_FE_TEMPERATURE(FIX16D2) COR_PBID_IQIF_TEMPERATURE(FIX16D2) COR_PBID_EXTERNAL_GAIN_LIST(FIX16D2) COR_PBID_IQIF_PATH_DEVIATION(FIX16D2) COR_PBID_DIGITAL_LEVEL_LIST(FIX16D2) COR_PBID_FREQUENCY_POINT_LIST(INT16) COR_PBID_SUBSUPP_INNERBOUND(DOUBLE) COR_PBID_SUBSUPP_OUTERBOUND(DOUBLE) COR_PBID_FA1_FREQUENCY(DOUBLE) COR_PBID_SPEC_START_FREQUENCY(DOUBLE) COR_PBID_SPEC_STOP_FREQUENCY(DOUBLE) COR_PBID_REGARDED_FREQUENCY(DOUBLE) COR_PBID_NEXT_ACTIVE_CHANNEL(UINT16) COR_PBID_BACKGND_OPERATION(UINT16) COR_PBID_PREFILTER_SETTING(UINT16) COR_PBID_NARROWFILTER_SETTING(UINT16) COR_PBID_SIMULATION(UINT16) COR_PBID_FILTER_DEV_INDEX(UINT16) COR_PBID_POWER_DETECTOR_INDEX(UINT16) COR_PBID_RCOUNTER_DEFAULT(UINT16) COR_PBID_NCOUNTER_DEFAULT(UINT16) COR_PBID_ACOUNTER_DEFAULT(UINT16) COR_PBID_RCOUNTER(UINT16) COR_PBID_NCOUNTER(UINT16) COR_PBID_ACOUNTER(UINT16) COR_PBID_IF_SIGNAL_MODE(UINT16) COR_PBID_EDIT_CHANNEL(UINT16) COR_PBID_BAND_USED(UINT16) COR_PBID_IF2_SHIFT_ENABLED(UINT16) COR_PBID_NOTCH_LEVEL_RESERVE_EN(UINT16) COR_PBID_LOW_RF_PREFILTER_EN(UINT16) COR_PBID_FREQ_PATH_SETUP_TIME_LIST(UINT16) COR_PBID_DIGITAL_LEVEL(FIX16D2) COR_PBID_MIXER_LEVEL(FIX16D2) COR_PBID_IF_AMP_SWITCH_LEVEL(FIX16D2) COR_PBID_FILTER_BAND_DEVIATION(FIX16D2) COR_PBID_SINGLE_FILTER_DEVIATION(FIX16D2) COR_PBID_LAST_SSI_OFFSET_LEVEL(FIX16D2) COR_PBID_COPRO_DEVIATION(FIX16D2) COR_PBID_RF1_PATH_GAIN(FIX16D2) COR_PBID_RF2_PATH_GAIN(FIX16D2) COR_PBID_IF_PATH_GAIN(FIX16D2) COR_PBID_IF1ATT_NOMINAL_GAIN(FIX16D2) COR_PBID_IF1ATT_DEVIATION(FIX16D2) COR_PBID_LOW_RF_PREFLT_DEVIATION(FIX16D2) COR_PBID_FILTER_NOMINAL_GAIN(FIX16D2) COR_PBID_IF2_SHIFT_TEMPERATURE(FIX16D2) COR_PBID_EXTERNAL_GAIN(FIX16D2) COR_PBID_IF3_FREQUENCY2(UINT64) COR_PBID_SYNCON_FACTOR(UINT64) COR_PBID_LO1_FREQUENCY(DOUBLE) COR_PBID_LO3_FREQUENCY(DOUBLE) COR_PBID_IF1_FREQUENCY(DOUBLE) COR_PBID_IF2_FREQUENCY(DOUBLE) COR_PBID_IF3_FREQUENCY(DOUBLE) COR_PBID_SUBSUPP_FREQUENCY_OFFSET(DOUBLE) Struct(COR_PBID_CHANNEL_TABLE) Struct(COR_PBID_FILL_CHANNEL_TABLE) Struct(COR_PBID_CHANNEL_INFO) Struct(COR_PBID_WRITE_SWITCH_STATE) Struct(COR_PBID_WRITE_SWITCH_VALUE) Struct(COR_PBID_READ_SWITCH_STATE) Struct(COR_PBID_READ_SWITCH_VALUE) Struct(COR_PBID_WRITE_DEVICE) Struct(COR_PBID_READ_DEVICE) Struct(COR_PBID_CLEAR_DEVICE) Struct(COR_PBID_WRITE_DEVICE_BLOCK) Struct(COR_PBID_READ_DEVICE_BLOCK) Struct(COR_PBID_GET_DIAGNOSIS) Struct(COR_PBID_SELF_TEST_SINGLE) Struct(COR_PBID_OVERLOAD_ADC_RESERVE) Struct(COR_PBID_LIST_TABLES) Struct(COR_PBID_CREATE_STD_TABLE) Struct(COR_PBID_CREATE_USER_TABLE) Struct(COR_PBID_OPEN_TABLE) Struct(COR_PBID_TRY_OPEN_TABLE) Struct(COR_PBID_CLOSE_TABLE) Struct(COR_PBID_STORE_TABLE) Struct(COR_PBID_READ_TABLE) Struct(COR_PBID_READ_TABLEITEM) Struct(COR_PBID_WRITE_TABLE) Struct(COR_PBID_WRITE_TABLEITEM) Struct(COR_PBID_GET_FLAGS) Struct(COR_PBID_SET_FLAGS) Struct(COR_PBID_GET_STATISTICS) Struct(COR_PBID_UPDATE_INTERNAL_TABLES) Struct(COR_PBID_GET_FILTER_CHARACT) Struct(COR_PBID_SET_FREQ_BOUNDARY) Struct(COR_PBID_GET_VERSION) Struct(COR_PBID_GET_BOARD_INFO) Struct(COR_PBID_GET_STATUS) Struct(COR_PBID_INITIALIZE) Struct(COR_PBID_SELF_TEST) Struct(COR_PBID_TRIGGER_SPECTRUM) Struct(COR_PBID_TRIGGER_RESTART_NCO) Struct(COR_PBID_GET_EXITCODE_PIPELINE) Struct(COR_PBID_SET_GAIN_ID) Struct(COR_PBID_GET_CHANNEL_STATISTIC) Struct(COR_PBID_SET_EXTERNAL_GAIN) Struct(COR_PBID_GET_IF_LEVEL) Struct(COR_PBID_RESTORE_CTC_TABLE) Struct(COR_PBID_FLASHCOPY_TRANSACT_BEGIN) Struct(COR_PBID_FLASHCOPY_TRANSACT_END) Struct(COR_PBID_RES_READ_SWITCH_STATE) Struct(COR_PBID_RES_READ_SWITCH_VALUE) Struct(COR_PBID_RES_READ_DEVICE) Struct(COR_PBID_RES_READ_DEVICE_BLOCK) Struct(COR_PBID_RES_ADC_OVERLOAD_RESERVE) Struct(COR_PBID_RES_LIST_TABLES) Struct(COR_PBID_RES_TRY_OPEN_TABLE) Struct(COR_PBID_RES_READ_TABLE) Struct(COR_PBID_RES_READ_TABLE_ITEM) Struct(COR_PBID_RES_GET_FLAGS) Struct(COR_PBID_RES_GET_DIAGNOSIS) Struct(COR_PBID_RES_DIAG) Struct(COR_PBID_RES_SELFT) Struct(COR_PBID_RES_SELFT_SINGLE) Struct(COR_PBID_RES_GET_STATISTICS) Struct(COR_PBID_RES_GET_FILTER_CHARACT) Struct(COR_PBID_RES_GET_VERSION) Struct(COR_PBID_RES_GET_BOARD_INFO) Struct(COR_PBID_RES_GET_STATUS) Struct(COR_PBID_RES_GET_MESSAGE) Struct(COR_PBID_RES_GET_EXITCODE) Struct(COR_PBID_RES_GET_SHORT_EXITCODE) Struct(COR_PBID_RES_GET_EXITCODE_PIPELINE) Struct(COR_PBID_RES_SET_GAIN_ID) Struct(COR_PBID_RES_GET_CHANNEL_STATISTIC) Struct(COR_PBID_RES_GET_IF_LEVEL) C331_TASK_STATE_RUNNING InRfTx1 >= C_MIN && InRfTx1 < C_MAX ..\..\src\conn.cpp InRfRx1 >= C_MIN && InRfRx1 < C_MAX ..\..\src\conn.cpp InRfTx2 >= C_MIN && InRfTx2 < C_MAX ..\..\src\conn.cpp InRfRx2 >= C_MIN && InRfRx2 < C_MAX $Revision: /main/5.20/1 $ TSK_STATE_ALLOCATE_RXTX_1 TSK_STATE_ALLOCATE_RXTX_2 TSK_STATE_ALLOCATE_L1COPRO TSK_STATE_PREPARE_MEAS TSK_STATE_START_MEAS HSD? InUsbIndex < FE_LIMIT_IN_RF_COUNT ..\..\src\rfl_base.cpp InUsbIndex < (FE_LIMIT_RF_COUNT-FE_LIMIT_IN_RF_COUNT) ..\..\src\rfl_base.cpp cmu_variant_of_part_number drivers CMU 200-1100.0008.02 CMU 200-1100.0008.10 CMU 200-1100.0008.30 CMU 200-1100.0008.53 CMU 200-1100.0008.83 ..\..\src\stuc.cpp Model not yet supported CMU 300-1100.0008.03 CRTU-RU 1138.4000.XX CBT-1153.9000.35 CBT32-1153.9000.32 TX MB Timeout - MC68k did not read the TX mailbox ..\..\src\ump_uuc.cpp diagnosis: 9 ..\..\src\ump_uuc.cpp diagnosis: 10 RX MB RX MB ..\..\src\ump_uuc.cpp diagnosis: 11 DPRAM test failed: wrong test value in RX mailbox (expected, actual): ..\..\src\ump_uuc.cpp diagnosis: 12 DPRAM test failed: wrong test value in RX buffer (expected, actual): UMP_UUC_C_DPRAM_TEST::fill_tx_buffer_and_mailbox_with_testpattern() UMP_UUC_C_DPRAM_TEST::message_in_rx_mailbox() in STATE_MAILBOXTEST UMP_UUC_C_DPRAM_TEST::message_in_rx_mailbox() in STATE_RX_BUFFERTEST_PATTERN_AA UMP_UUC_C_DPRAM_TEST::message_in_rx_mailbox() in STATE_RX_BUFFERTEST_PATTERN_55 ..\..\src\ump_uuc.cp UMP_UUC_C_DATA UMP_UUC_C_PROT_TX::segment_is_sent() UMP_UUC_C_PROT_RX::segment_is_received() >strings CMUDRV.DL0 | grep -i '^MSG_' MSG_ID_AUXTX_SEND_DATA message MSG_ID_AUXTX_READ_DATA message MSG_ID_AUXTX_SEND_DATA MSG_ID_AUXTX_READ_DATA MSG_ID_AUXTX_CALLBACK_MSG MSG_ID_AUXTX_CALLBACK_FCT MSG_ID_CTC_FIRMWARE_CHECK MSG_ID_CTC_CONTROLL_FIRMWARE_CHECK MSG_ID_TMP_COR_TSK_START MSG_ID_CONVERSION_READY MSG_ID_C331_CALLBACK MSG_ID_TASK_RECALL MSG_ID_TMP_COR_TSK_STOP MSG_ID_AUXTX_CALLBACK MSG_ID_DDR_START_DIAGNOSIS_ACCESS MSG_ID_DDR_COR_CALLBACK MSG_RESET_TASKCTRL MSG_START_POLL MSG_STOP_POLL MSG_DO_POLL MSG_ID_BOOT_LOAD_COMPLETE MSG_ID_PROCESS_START MSG_ID_REF_FREQ_ADJUSTED MSG_ID_PROCESS_STOP MSG_ID_START MSG_ID_OK MSG_ID_FAIL MSG_ID_START MSG_ID_OK MSG_ID_FAIL MSG_ID_WRITE_IS_COMPLETE MSG_ID_READ_IS_COMPLETE MSG_ID_VERSION_IS_COMPLETE MSG_ID_PHASE_COR_START_CORRECTION == InMsgId MSG_ID_PHASE_COR_START_CORRECTION MSG_ID_START_SURVEILLANCE MSG_ID_RXTX_BIC_START_BORAD_CHECK MSG_ID_RXTX_BIC_C331_CALLBACK MSG_ID_DO_OPTION_POLL MSG_ID_OPTION_POLL_DONE MSG_ID_ENTER_TASKSTATE MSG_ID_CAL_START MSG_ID_CAL_MEAS_COMPLETE MSG_ID_MSG_QUEUE_EMPTY MSG_ID_DO_OPTION_POLL MSG_ID_ACTIVATE_UMP MSG_ID_CONTINUE MSG_ID_INTERRUPT MSG_ID_ENTER_TASKSTATE MSG_ID_DO_OPTION_POLL MSG_ID_ACTIVATE_UMP MSG_ID_INTERRUPT MSG_ID_FROM_UMP MSG_ID_ENTER_TASKSTATE MSG_ID_DO_OPTION_POLL MSG_ID_ACTIVATE_UMP MSG_ID_INTERRUPT MSG_ID_ENTER_TASKSTATE MSG_ID_DO_OPTION_POLL MSG_ID_ACTIVATE_UMP MSG_ID_CONTINUE MSG_ID_INTERRUPT MSG_ID_READ_EEPROM_OK MSG_ID_READ_EEPROM_FAIL MSG_ID_ENTER_TASKSTATE MSG_ID_DO_OPTION_POLL MSG_ID_ACTIVATE_UMP MSG_ID_ENTER_TASKSTATE CMU.DL1 ======= >strings CMU.DL1 | grep '^MSG_' MSG_B83_CALIBRATION_PREPARED MSG_B83_CALIBRATION_EXECUTED MSG_B83_CALIBRATION_TIMEOUT MSG_B83_CALIBRATION_REFRESH MSG_ID_C331_CALLBACK MSG_ID_CONVERSION_READY MSG_ID_CALLBACK_OFF MSG_ID_CALLBACK_RUN MSG_ID_DSP_UPDATE_ALL MSG_ID_DSP_UPDATE_OFFSET MSG_ID_UPDATE_DSP_C331 MSG_ID_START_INITIALISATION MSG_ID_RXTX_INIT_CALLBACK MSG_ID_LBK_RUN MSG_ID_LBK_GOON MSG_C331_ANSWER_TX MSG_C331_ANSWER_RX MSG_RES_APPLICATION MSG_CW_SIGNAL_ON MSG_ID_EXTERNAL_SIGNAL_ON MSG_ID_EXTERNAL_SIGNAL_OFF MSG_ID_EXTERNAL_GENERATOR_NOT_AVAILABLE MSG_ID_DLL_LOCKED MSG_ID_PHASE_SKIPPED MSG_ID_DELAY MSG_RES_APPLICATION MSG_INTRES_APPLICATION MSG_OFF_PENDING MSG_ERR_PENDING MSG_PAR_UPDATE_NOTIFY MSG_PAR_UPD_PENDING MSG_PAR_UPD_COMPLETE MSG_OTHER_UPD_COMPLETE MSG_ARG_CYCLE_COMPLETE MSG_RESTART_MEAS_SPONT MSG_SUPP_PENDING MSG_SUSPEND_PENDING MSG_SPONT_SUSPEND_PENDING MSG_C331_ANSWER MSG_RUN_EXT_EVENT_FINI MSG_OFF_EXT_EVENT_FINI MSG_START_MEAS MSG_START_SPONT MSG_MEAS_READY MSG_B83_LH_REBOOTED MSG_ID_STC_SYS_READY MSG_ID_STC_LBK_READY MSG_ID_STC_RESTART >strings CMU.DL1 | grep '_MSG_' DTST_MSG_ID_SOFTKEY_PRESSED ARG_CTRL_MSG_TIMEOUT_1 ARG_CTRL_MSG_TIMEOUT_2 ARG_CTRL_MSG_VETO_1 ARG_CTRL_MSG_VETO_2 ARG_CTRL_MSG_ACCEPT_1 ARG_CTRL_MSG_ACCEPT_2 ARG_M_MSG_AR_ON ARG_M_MSG_RSLT_ADCP ARG_M_MSG_RSLT_BBP ARG_M_MSG_C331_ANSWER ARG_M_MSG_SPONT_ON ARG_M_MSG_AR_PERMITTED ARG_M_MSG_AR_RESTART ARG_M_MSG_MAX ARG_MASTER_MSG_ACCEPT ARG_MASTER_MSG_VETO ARG_MASTER_MSG_REQUEST ARG_MASTER_MSG_NO_PATH ARG_MASTER_MSG_CYCLE_RDY ARG_MASTER_MSG_READ_EEPROM ARG_MASTER_MSG_EEP_COMPLETE ARG_MASTER_MSG_EEP_FAILED BLA_MSG_ACTION_START BLA_MSG_ACTION_COMPLETE TSK_MSG_ID_INIT TSK_MSG_ID_PATH_ALLOCATED TSK_MSG_ID_PATH_REFUSED TSK_MSG_ID_MEAS_SUPP TSK_MSG_ID_TIMEOUT TSK_MSG_ID_MEAS_RUN TSK_MSG_ID_MEAS_OFF DTST_MSG_ID_SOFTKEY_PRESSED %d SELF_MSG_ID_GOTO_NEXT_STATE Path 1: PmgrPathChannel1.free %d SELF_MSG_ID_GOTO_NEXT_STATE Path 2: PmgrPathChannel2.free %d TSK_MSG_ID_MEAS_OFF %d DTST_MSG_ID_SOFTKEY_PRESSED %d TSK_MSG_ID_MEAS_RUN %d SELF_MSG_ID_AUXTX_PATH_IS_ALLOCATED 1 %d SELF_MSG_ID_AUXTX_PATH_IS_ALLOCATED 2 %d TSK_SEND ( TSK_MSG_ID_MEAS_OFF NULL); %d TSK_MSG_ID_PATH_REFUSED_2 %d TSK_SEND ( TSK_MSG_ID_MEAS_OFF, NULL); %d TSK_SEND ( DTST_MSG_ID_GET_AUXTX_STATUS_REGISTER, NULL); %d TSK_SEND ( SELF_MSG_ID_CONVERSION_READY, NULL); %d TSK_SEND ( TSK_MSG_ID_MEAS_HALT, NULL); DTST_MSG_ID_AUXTX_PATH_IS_ALLOCATED DTST_MSG_ID_GET_AUXTX_DIAGNOSIS DTST_MSG_ID_AUXTX_CHECK_AND_REPORT DTST_MSG_ID_NCLK_DELAY DTST_MSG_ID_C331_CALLBACK DTST_MSG_ID_CONVERSION_READY DTST_MSG_ID_GET_AUXTX_STATUS_REGISTER DTST_MSG_ID_REPORT_AUXTX_STATUS_REGISTER DTST_MSG_ID_SOFTKEY_PRESSED DTST_MSG_ID_SOFTKEY_PRESSED TSK_MSG_ID_MEAS_OFF TSK_MSG_ID_MEAS_RUN DTST_MSG_ID_SOFTKEY_PRESSED InMsgId == TSK_MSG_ID_INIT InMsgId == TSK_MSG_ID_MEAS_RUN || InMsgId == TSK_MSG_ID_MEAS_OFF TSK_MSG_ID_MEAS_OFF TSK_MSG_ID_MEAS_RUN DTST_MSG_ID_DLL_LOCKED DTST_MSG_ID_SOFTKEY_PRESSED TSK_MSG_ID_MEAS_OFF TSK_MSG_ID_MEAS_RUN DTST_MSG_ID_SOFTKEY_PRESSED InMsgId == TSK_MSG_ID_INIT InMsgId == TSK_MSG_ID_MEAS_RUN || InMsgId == TSK_MSG_ID_MEAS_OFF TSK_MSG_ID_MEAS_OFF TSK_MSG_ID_MEAS_RUN DTST_MSG_ID_SOFTKEY_PRESSED Message CAL_GENERATOR_ANSWER_MSG_OFF_ERROR received TSK_MSG_ID_ACK_REQUEST_REFUSED received upon switching on RF analyzer HDV_MSG_ID_READ_SUCCESS HDV_MSG_ID_READ_FAIL DTST_MSG_ID_SOFTKEY_PRESSED IDTY_MSG_ID_C331_0_READY IDTY_MSG_ID_C331_1_READY IDTY_MSG_ID_BLOCK_READ_DONE DSP_APP_RET_MSG_START: %d DSP_MSG_BOOT_PROC_START DSP_APP_RET_MSG_ACTIV DSP_APP_RET_MSG_DEACTIV DSP_APP_RET_MSG_INTERM_RESULT DSP_APP_RET_MSG_RESULT DSP_APP_RET_MSG_UPD DSP_APP_RET_MSG_FIL DSP_APP_RET_MSG_START DSP_APP_RET_MSG_ERROR DSP_MSG_BOOT_PROC_START DSP_APP_RET_MSG_ACTIV DSP_APP_RET_MSG_DEACTIV DSP_APP_RET_MSG_INTERM_RESULT DSP_APP_RET_MSG_RESULT DSP_APP_RET_MSG_UPD DSP_APP_RET_MSG_FIL DSP_APP_RET_MSG_START DSP_APP_RET_MSG_ERROR DSP_APP_RET_MSG_ACTIV DSP_APP_RET_MSG_DEACTIV DSP_APP_RET_MSG_INTERM_RESULT DSP_APP_RET_MSG_RESULT DSP_APP_RET_MSG_UPD DSP_APP_RET_MSG_FIL DSP_APP_RET_MSG_START DSP_APP_RET_MSG_ERROR NPM_TSK_MSG_RES_APPLICATION NPM_TSK_MSG_INTRES_APPLICATION NPM_TSK_MSG_HALT_PENDING NPM_TSK_MSG_SP_HALT_PENDING NPM_TSK_MSG_OFF_PENDING NPM_TSK_MSG_SUPP_PENDING NPM_TSK_MSG_ERR_PENDING NPM_TSK_MSG_PAR_UPD_PENDING NPM_TSK_MSG_C331_ANSWER NPM_TSK_MSG_EXT_ADJUSTMENT_FINISHED NPM_TSK_MSG_HW_CONTROL_STABLE NPM_TSK_MSG_HW_CONTROL_FAIL InMsgId == TSK_MSG_ID_INIT T_MSG_START T_MSG_STOP T_MSG_START_CONFIRM T_MSG_STOP_CONFIRM T_MSG_MEAS_ACTION T_MSG_MEAS_WORK T_MSG_C331_ANSWER T_MSG_DSP_RESULT T_MSG_DSP_RESULT_INT DSP_APP_RET_MSG_ACTIV DSP_APP_RET_MSG_DEACTIV DSP_APP_RET_MSG_FIL DSP_APP_RET_MSG_START DSP_APP_RET_MSG_ERROR T_MSG_PATH_ACCESS_IMPOSSIBLE TSK_MSG_ID_TIMEOUT TSK_MSG_ID_DELAY TSK_MSG_ID_INIT TSK_MSG_ID_MEAS_OFF TSK_MSG_ID_MEAS_RUN TSK_MSG_ID_MEAS_SUPP TSK_MSG_ID_PATH_ALLOCATED TSK_MSG_ID_PATH_REFUSED TSK_MSG_ID_RSRC_ALLOCATED TSK_MSG_ID_RSRC_REFUSED TSK_MSG_ID_BROADCAST_OFF TSK_MSG_ID_INVALID TSK_MSG_ID_ERROR TSK_MSG_ID_NO_MESSAGE TSK_MSG_ID_REQ_DISCOVER_OPTIONS TSK_MSG_ID_REQ_COMPLETE_STARTUP TSK_MSG_ID_REQ_LOCK TSK_MSG_ID_REQ_UNLOCK TSK_MSG_ID_REQ_MEAS_RUN TSK_MSG_ID_REQ_MEAS_ABORT TSK_MSG_ID_REQ_MEAS_OFF TSK_MSG_ID_REQ_MEAS_HALT TSK_MSG_ID_REQ_MEAS_SUPP TSK_MSG_ID_REQ_MEAS_DISABLE TSK_MSG_ID_REQ_MEAS_ENABLE TSK_MSG_ID_REQ_MEAS_RESULTS TSK_MSG_ID_REQ_PAR_UPD_APP TSK_MSG_ID_REQ_PAR_UPD_PATH TSK_MSG_ID_ACK_REQUEST_REFUSED TSK_MSG_ID_ACK_DISCOVER_OPTIONS TSK_MSG_ID_ACK_COMPLETE_STARTUP TSK_MSG_ID_ACK_LOCK TSK_MSG_ID_ACK_UNLOCK TSK_MSG_ID_ACK_MEAS_RUN TSK_MSG_ID_ACK_MEAS_ABORT TSK_MSG_ID_ACK_MEAS_OFF TSK_MSG_ID_ACK_MEAS_HALT TSK_MSG_ID_ACK_MEAS_SUPP TSK_MSG_ID_ACK_MEAS_DISABLE TSK_MSG_ID_ACK_MEAS_ENABLE TSK_MSG_ID_ACK_MEAS_RESULTS TSK_MSG_ID_ACK_PAR_UPD_APP TSK_MSG_ID_ACK_PAR_UPD_PATH DSP_APP_RET_MSG_ACTIV DSP_APP_RET_MSG_DEACTIV DSP_APP_RET_MSG_INTERM_RESULT DSP_APP_RET_MSG_RESULT DSP_APP_RET_MSG_UPD DSP_APP_RET_MSG_FIL DSP_APP_RET_MSG_START DSP_APP_RET_MSG_ERROR %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_MSG_ID_MEAS_OFF: AUXTX switched ON %d TSK_MSG_ID_MEAS_OFF %d SELF_MSG_ID_AUXTX_HALT: AUXTX switched ON %d TSK_MSG_ID_MEAS_HALT %d TSK_MSG_ID_TIMEOUT: AUXTX switched ON %d SELF_MSG_ID_AUXTX_PATH_IS_ALLOCATED 1 %d SELF_MSG_ID_AUXTX_PATH_IS_ALLOCATED 2 %d Path 1: TSK_MSG_ID_PATH_REFUSED; TESTMODE_SYSTEM|| TESTMODE_CONTINUOUS %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_MSG_ID_PATH_REFUSED_1 %d TSK_MSG_ID_PATH_REFUSED_2 %d Path 2: TSK_MSG_ID_PATH_REFUSED; TESTMODE_SYSTEM|| TESTMODE_CONTINUOUS %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_CONVERSION_READY, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d TSK_SEND ( SELF_MSG_ID_GOTO_NEXT_STATE, NULL); %d SELF_MSG_ID_GOTO_NEXT_STATE Path 1: PmgrPathChannel1.free %d SELF_MSG_ID_GOTO_NEXT_STATE Path 2: PmgrPathChannel2.free SELF_MSG_ID_C331_CALLBACK DTST_MSG_ID_SOFTKEY_PRESSED SELF_MSG_PATH_REQUEST SELF_MSG_ID_GOTO_NEXT_STATE SELF_MSG_ID_CONVERSION_READY SELF_MSG_ID_NCLK_DELAY SELF_MSG_ID_START SELF_MSG_DISPLAY_NEXT_RES SELF_MSG_ID_AUXTX_PATH_IS_ALLOCATED SELF_MSG_ID_GET_AUXTX_DIAGNOSIS SELF_MSG_ID_AUXTX_CHECK_AND_REPORT SELF_MSG_ID_POWER_OFF SELF_MSG_ID_SET_FREQUENCY_OFF SELF_MSG_ID_GET_TUNE_OFF SELF_MSG_ID_REPORT_INIT_CHECK_OFF SELF_MSG_ID_POWER_ON SELF_MSG_ID_SET_FREQUENCY_ON SELF_MSG_ID_GET_TUNE_ON SELF_MSG_ID_REPORT_INIT_CHECK_ON SELF_MSG_ID_AUXTX_HALT SELF_MSG_ID_AUXTX_HALTED SELF_MSG_ID_AUXTX_TIMEOUT SELF_MSG_ID_ON_AFTER_TIMEOUT SELF_MSG_ID_AUXTX_SWITCHED_OFF SELF_MSG_CTM_DISABLED_IN_REF SELF_MSG_IF3_TEST_FINISHED SELF_MSG_B83_TEST TSK_MSG_ID_INIT TSK_MSG_ID_PATH_ALLOCATED TSK_MSG_ID_PATH_REFUSED TSK_MSG_ID_MEAS_SUPP TSK_MSG_ID_TIMEOUT TSK_MSG_ID_MEAS_OFF TSK_MSG_ID_MEAS_RUN DTST_MSG_ID_SOFTKEY_PRESSED C_PRC_MEAS::TSK_MSG_ID_INVALID C_PRC_MEAS::TSK_MSG_ID_ERROR C_PRC_MEAS::TSK_MSG_ID_NO_MESSAGE C_PRC_MEAS::TSK_MSG_ID_REQ_DISCOVER_OPTIONS C_PRC_MEAS::TSK_MSG_ID_ACK_DISCOVER_OPTIONS received TSK_MSG_ID_INIT TSK_MSG_ID_INIT TSK_MSG_ID_BROADCAST_OFF Optpoll Chan. A lowest freq Chan. A center freq Chan. A max freq Optpoll Chan. B lowest freq Chan. B center freq Chan. B max freq @ %s.write_table_item(UserHead) UserHead.Rows = %u UserHead.Columns = %u UserHead.Row_ID_Type = %u UserHead.Column_ID_Type = %u UserHead.DataType = %u UserHead.Filler = %u UserHead.AUX1 = %d UserHead.AUX2 = %d UserHead.AUX3 = %d MSG_ID_LBK_RUN MSG_ID_LBK_GOON MSG_C331_ANSWER_TX MSG_C331_ANSWER_RX MSG_RES_APPLICATION MSG_CW_SIGNAL_ON MSG_ID_EXTERNAL_SIGNAL_ON MSG_ID_EXTERNAL_SIGNAL_OFF MSG_ID_EXTERNAL_GENERATOR_NOT_AVAILABLE MSG_ID_DLL_LOCKED MSG_ID_PHASE_SKIPPED MSG_ID_DELAY ADJUST_INFO_NONE ADJUST_INFO_C331_LEVEL ADJUST_INFO_C331_FREQUENCY ADJUST_INFO_C331_ATTENUATION ADJUST_INFO_TRIGGER ADJUST_INFO_DISP_MODE ADJUST_INFO_DSP_APPCTRL ADJUST_INFO_DSP_APP ADJUST_INFO_DSP_TSC ADJUST_INFO_DSP_POWERRAMP ADJUST_INFO_DSP_TEMPLATE ADJUST_INFO_DSP_LEVEL ADJUST_INFO_DSP_STATISTIC ADJUST_INFO_DSP_TRIGGER ADJUST_INFO_DSP_OVERSAMPLING ADJUST_INFO_DSP_RUNMODE ADJUST_INFO_MAX MEAS_INFO_MIN MEAS_INFO_NONE MEAS_INFO_HW_INITIALIZED MEAS_INFO_PATH_ALLOCATED MEAS_INFO_RESOURCE_ALLOCATED MEAS_INFO_C331_INITIALIZED MEAS_INFO_DDC_INITIALIZED MEAS_INFO_DSP_INITIALIZED MEAS_INFO_DSP_APP_ACTIVE MEAS_INFO_DSP_APP_RUNNING MEAS_INFO_MEASUREMENT_ON MEAS_INFO_MAX STATE_INIT STATE_MEAS_Off STATE_MEAS_Running STATE_MEAS_Halted STATE_MEAS_Suppressed STATE_MEAS_Undefined TSK_MSG_ID_REQ_MEAS_RUN TSK_MSG_ID_REQ_MEAS_ABORT TSK_MSG_ID_REQ_MEAS_OFF TSK_MSG_ID_REQ_MEAS_HALT TSK_MSG_ID_REQ_MEAS_SUPP TSK_MSG_ID_REQ_MEAS_DISABLE TSK_MSG_ID_REQ_MEAS_ENABLE TSK_MSG_ID_REQ_MEAS_RESULTS TSK_MSG_ID_ACK_MEAS_RUN TSK_MSG_ID_ACK_MEAS_ABORT TSK_MSG_ID_ACK_MEAS_OFF TSK_MSG_ID_ACK_MEAS_HALT TSK_MSG_ID_ACK_MEAS_SUPP TSK_MSG_ID_ACK_MEAS_DISABLE TSK_MSG_ID_ACK_MEAS_ENABLE TSK_MSG_ID_ACK_MEAS_RESULTS REQUEST_COMMAND_MeasRun REQUEST_COMMAND_MeasAbort REQUEST_COMMAND_MeasOff REQUEST_COMMAND_MeasHalt REQUEST_COMMAND_MeasSupp REQUEST_COMMAND_MeasDisable REQUEST_COMMAND_MeasEnable REQUEST_COMMAND_MeasResults
