.../R-S_CMU_HD/CMU/BIN_V5.21 # >find . -name \*.DL\? -exec strings {} \; | grep '^MSG_' | sort -u MSG_ACTIVATE MSG_ARG_CYCLE_COMPLETE MSG_AUXTX_CALLBACK_OFF MSG_B83_CALIBRATION_EXECUTED MSG_B83_CALIBRATION_PREPARED MSG_B83_CALIBRATION_REFRESH MSG_B83_CALIBRATION_TIMEOUT MSG_B83_LH_REBOOTED MSG_C331_ANSWER MSG_C331_ANSWER_RX MSG_C331_ANSWER_TX MSG_C_LOG_MMI_DATA MSG_C_LOG U MSG_CLOSE_LOOP_FAILED MSG_CLOSE_LOOP_SUCCEEDED MSG_CMR_ACK_TIMEOUT MSG_CMR_CONTINUE_AFTER_PARAM_CHG MSG_CMR_DTM_PAGING MSG_CMR_PAR_CHG MSG_CMR_SGC_OFF MSG_CMR_TARGET_LEVELS_SET MSG_CONTINUE_HALT MSG_CW_SIGNAL_ON MSG_DDC_LOAD_FAILURE MSG_DDC_LOAD_SUCCESS MSG_DEACTIVATE MSG_DO_POLL MSG_ERR_PENDING MSG_EXT_ADJUSTMENT_FINISHED MSG_FER_ACK_TIMEOUT MSG_FER_CONTINUE_AFTER_LOOP_TYPE_CHG MSG_FER_CONTINUE_AFTER_PARAM_CHG MSG_FER_DTM_DISCONNECT MSG_FER_DTM_DISCONNECT_END MSG_FER_DTM_PAGING MSG_FER_DTM_PAGING_END MSG_FER_LEVELS_SET MSG_FER_MDL_T200_TIMEOUT MSG_FER_PAR_CHG MSG_FER_SGC_OFF MSG_HW_ADJUSTMENT_READY MSG_ID_ACTIVATE_UMP MSG_ID_ADJUSTMENT_READY MSG_ID_AUXTX_ALLOC_OVERRANGE_PATH MSG_ID_AUXTX_ALLOC_PATH MSG_ID_AUXTX_CALLBACK MSG_ID_AUXTX_CALLBACK_FCT MSG_ID_AUXTX_CALLBACK_MSG MSG_ID_AUXTX_FREE_OVERRANGE_PATH MSG_ID_AUXTX_FREE_PATH MSG_ID_AUXTX_READ_DATA MSG_ID_AUXTX_READ_DATA message MSG_ID_AUXTX_SEND_DATA MSG_ID_AUXTX_SEND_DATA message MSG_ID_BOOT_LOAD_COMPLETE MSG_ID_C331_CALLBACK MSG_ID_CALLBACK_OFF MSG_ID_CALLBACK_RUN MSG_ID_CAL_MEAS_COMPLETE MSG_ID_CAL_START MSG_ID_CONTINUE MSG_ID_CONVERSION_READY MSG_ID_CTC_CONTROLL_FIRMWARE_CHECK MSG_ID_CTC_FIRMWARE_CHECK MSG_ID_DDR_COR_CALLBACK MSG_ID_DDR_START_DIAGNOSIS_ACCESS MSG_ID_DELAY MSG_ID_DLL_LOCKED MSG_ID_DO_OPTION_POLL MSG_ID_DSP_UPDATE_ALL MSG_ID_DSP_UPDATE_GENERATOR_MODE MSG_ID_DSP_UPDATE_OFFSET MSG_ID_DSP_UPDATE_SDA_SETTING MSG_ID_EMIT_B21_EVENT MSG_ID_EMIT_B83_EVENT MSG_ID_EMIT_GSMMS_EVENT MSG_ID_ENTER_TASKSTATE MSG_ID_EXTERNAL_GENERATOR_NOT_AVAILABLE MSG_ID_EXTERNAL_SIGNAL_OFF MSG_ID_EXTERNAL_SIGNAL_ON MSG_ID_FAIL MSG_ID_FROM_UMP MSG_ID_GRPCFG_NOTIFY MSG_ID_INTERRUPT MSG_ID_LBK_GOON MSG_ID_LBK_RUN MSG_ID_MSG_QUEUE_EMPTY MSG_ID_OK MSG_ID_OPTION_POLL_DONE MSG_ID_PATH_CHANGE MSG_ID_PD_MEAS_ACTIVE MSG_ID_PD_MEAS_ACTIVE_HO MSG_ID_PD_MEAS_INACTIVE MSG_ID_PD_MEAS_INACTIVE_HO MSG_ID_PD_MEAS_INIT_USB MSG_ID_PD_RXLEV_REP_OFF MSG_ID_PD_RXLEV_REP_ON MSG_ID_PD_RXLEV_REP_ONETIME MSG_ID_PHASE_COR_START_CORRECTION MSG_ID_PHASE_COR_START_CORRECTION == InMsgId MSG_ID_PHASE_SKIPPED MSG_ID_PPC_FAILURE MSG_ID_PPC_NOTIFY_DEACTIVATING MSG_ID_PPC_NOTIFY_RUNNING MSG_ID_PPC_RECEIVE_MSG MSG_ID_PPC_START MSG_ID_PROCESS_START MSG_ID_PROCESS_STOP MSG_ID_READ_EEPROM_FAIL MSG_ID_READ_EEPROM_OK MSG_ID_READ_IS_COMPLETE MSG_ID_REF_FREQ_ADJUSTED MSG_ID_RESET_START MSG_ID_RXTX_BIC_C331_CALLBACK MSG_ID_RXTX_BIC_START_BORAD_CHECK MSG_ID_RXTX_INIT_CALLBACK MSG_ID_START MSG_ID_START_INITIALISATION MSG_ID_START_SURVEILLANCE MSG_ID_STC_LBK_READY MSG_ID_STC_RESTART MSG_ID_STC_SYS_READY MSG_ID_TASK_RECALL MSG_ID_TMP_COR_TSK_START MSG_ID_TMP_COR_TSK_STOP MSG_ID_UAD_INT MSG_ID_UPDATE_DSP_C331 MSG_ID_VERSION_IS_COMPLETE MSG_ID_WRITE_IS_COMPLETE MSG_INTRES_APPLICATION MSG_INVOKE_PVXS_SIGNALLING_ACTION MSG_IQREC_BLOCK1_RECEIVED MSG_IQREC_BLOCK2_RECEIVED MSG_LH_ACTION_FINISHED MSG_LH_MESSAGE_APPEARED MSG_LOOP_OPENED MSG_MAX MSG_MAX_LEVEL_ADJ_FCT_CALLED MSG_MEAS_READY MSG_NORMAL_LEVELS_SET MSG_OFF_EXT_EVENT_FINI MSG_OFF_PENDING MSG_OTHER_TASK_REQUESTS_MY_DDC_FILTER MSG_OTHER_UPD_COMPLETE MSG_PARAM_CHANGED MSG_PAR_UPDATE_NOTIFY MSG_PAR_UPD_COMPLETE MSG_PAR_UPD_PENDING MSG_REF_MODE_ADJ_FCT_CALLED MSG_RES_APPLICATION MSG_RESET_TASKCTRL MSG_RESTART_DSP MSG_RESTART_MEAS_SPONT MSG_RESTART_REQUESTED MSG_RESULT MSG_RUN_EXT_EVENT_FINI MSG_SAC_REP_ACK_TIMEOUT MSG_SAC_REP_CONTINUE_AFTER_PARAM_CHG MSG_SAC_REP_DTM_DISCONNECT MSG_SAC_REP_DTM_DISCONNECT_END MSG_SAC_REP_DTM_PAGING MSG_SAC_REP_DTM_PAGING_END MSG_SAC_REP_LEVELS_SET MSG_SAC_REP_PAR_CHG MSG_SAC_REP_SGC_OFF MSG_SG_OFF MSG_SIG_OFF_READY MSG_SIG_SG_OFF_PENDING MSG_SPONT_SUSPEND_PENDING MSG_START_AUTO MSG_START_MEAS MSG_START_POLL MSG_START_SINGLE MSG_START_SINGLE_IMMEDIATE MSG_START_SINGLE_QUICK MSG_START_SINGLE_QUICK_INT MSG_START_SPONT MSG_STOP_POLL MSG_STOP_WORK MSG_SUPP_PENDING MSG_SUSPEND_PENDING MSG_TCH_LEVELS_RESTORED MSG_TCH_LEVELS_SET MSG_TRAFFIC_MODE_CHANGED >find . -name \*.DL\? -exec strings {} \; | grep '^get_' | sort -u get_3g_nc_desc get_abs_level_0dbfs_channel get_absolute_l1c_power_result get_absolute_level_pk get_absolute_level_rms get_absolute_level_rms_min get_abs_usb_parameter get_aclr_base get_aclr_base().meas_fg_hw_sig_interface().rx_table_size() >= CHANNEL_TABLE_SIZE get_aclr_params get_aclr_result get_actual_level_type get_actual_scenario get_actual_stack_frame_number get_actual_status_message get_adc_entry get_adcp_measurement_errors get_add_info get_addressing_type get_addressing_type_as_string get_adjacent_channel_result get_adjust get_adjust_dsp_any get_adjust_possible get_agch_reporting_interval_in_ttis#U get_AgpsParameters get_AgpsResultParams get_ag_value get_aich get_AICH_preambles_to_skip get_allocator get_allowed_options get_amr_mode_status get_amr_operation_mode get_amr_traffic_type get_and_check_real_address get_app get_app_cor_fil get_app_ctrl get_app_ctrl_par ( PAR_APPLICATIONCONTROL_MEASUREMENT_SELECTION ).get_uint32 ( ) <= 0x000007 get_app_ctrl_par ( PAR_APPLICATIONCONTROL_MEASUREMENT_SELECTION ).get_uint32 ( ) <= 0x0001FF get_app_ctrl_par ( PAR_APPLICATIONCONTROL_MEASUREMENT_STOP_MODE ).get_uint32 ( ) <= 0x000003 get_app_ctrl_par ( PAR_APPLICATIONCONTROL_RESERVED_2 ).get_uint32 ( ) == 0x000000 get_app_ctrl_par ( PAR_APPLICATIONCONTROL_STOP_ON_LIMIT_SELECTION ).get_uint32 ( ) <= 0x000007 get_app_ctrl_par ( PAR_APPLICATIONCONTROL_UPDATE_CONTROL ).get_uint32 ( ) == 0x000000 get_app_par get_app_par_HSDPA get_app_par_lim_cur get_app_par ( PAR_APPLICATION_BURST_TYPE ).get_uint32 ( ) >= 1 && get_app_par ( PAR_APPLICATION_BURST_TYPE ).get_uint32 ( ) <= 3 get_app_par ( PAR_APPLICATION_DDC_FILTER ).get_uint32 ( ) <= 0x000001 get_app_par ( PAR_APPLICATION_ERROR_DECREMENT ).get_uint32 ( ) >= 1 && get_app_par ( PAR_APPLICATION_ERROR_DECREMENT ).get_uint32 ( ) <= get_app_par ( PAR_APPLICATION_MAX_ERROR_COUNT ).get_uint32 ( ) get_app_par ( PAR_APPLICATION_ERROR_INCREMENT ).get_uint32 ( ) >= 1 && get_app_par ( PAR_APPLICATION_ERROR_INCREMENT ).get_uint32 ( ) <= get_app_par ( PAR_APPLICATION_MAX_ERROR_COUNT ).get_uint32 ( ) get_app_par ( PAR_APPLICATION_HARDWARE_DELAY ).get_int32 ( ) >= -1024 && get_app_par ( PAR_APPLICATION_HARDWARE_DELAY ).get_int32 ( ) <= ( (DOUBLE) 3200.0 ) / ( (DOUBLE) 39000000L ) get_app_par ( PAR_APPLICATION_MAX_ERROR_COUNT ).get_uint32 ( ) >= 1 && get_app_par ( PAR_APPLICATION_MAX_ERROR_COUNT ).get_uint32 ( ) <= 100 get_app_par ( PAR_APPLICATION_RESERVED_2 ).get_uint32 ( ) == 0x000000 get_app_par ( PAR_APPLICATION_RESERVED_3 ).get_uint32 ( ) == 0x000000 get_app_par ( PAR_APPLICATION_RESERVED_4 ).get_uint32 ( ) == 0x000000 get_app_par ( PAR_APPLICATION_RESERVED_5 ).get_uint32 ( ) == 0x000000 get_app_par ( PAR_APPLICATION_RESERVED_6 ).get_uint32 ( ) == 0x000000 get_app_par ( PAR_APPLICATION_STATISTIC_LENGTH ).get_int32 ( ) >= -1 && get_app_par ( PAR_APPLICATION_STATISTIC_LENGTH ).get_int32 ( ) <= 1000 get_app_par ( PAR_APPLICATION_TIMING_ADVANCE ).get_uint32 ( ) == 0x000000 get_app_par ( PAR_APPLICATION_UPDATE_CONTROL ).get_uint32 ( ) == 0x000000 get_app_res_return_code get_app_result get_app_res_valid_results get_arg_ctrl get_array_index get_array_size get_array U get_asn1_message get_asn1_msg get_asp get_asp_header get_asp()->message()->isActive_radioBearerSetup() get_attach_type get_autoranging_control get_autoranging_error_maximum_wait_delay(U get_autoranging_loop_maximum_wait_delay'U get_autoranging_mode get_autoresync get_auto_trigger_type get_auxtx_cmd(), Cmd=%d get_auxtx_fallback_source_data get_auxtx_ho_source_data get_auxtx_off_level get_auxtx_overrange_off_level get_auxtx_ovr_rf_level get_average_peak_limit get_average_rms_limit get_awgn get_b83_revision get_band_position get_base get_base_ctrl_msg_log get_base().meas_fg_hw_sig_interface().rx_table_size() >= required_table_size() get_base_user_time_changed_usb_parameter(U get_bbp_measurement_errors get_bbp_measurement_errors: %f / %f get_ber_results get_BER_stop_condition get_beta_c get_beta_d get_beta_dpcch get_beta_dpdch get_beta_factor get_bits get_BLER_stop_condition get_blocksize_index get_board_name get_board_temperature_unconverted() get_bs_frequency get_c331_center_freq get_c331_channel_frequency get_c331_ctrl get_c331_freq get_c331_narrowband_level get_c331_nb_level get_C331_table_index get_c331_tx get_c331_wb_level get_c331_wideband_level get_calibrated_wide_7M68_filter get_callback_fct get_callback_fct_data() get_callback_id get_callback_msg_data() get_cam_muf get_CBK2Log get_cdp_base get_cdp_res_e_dpdch1_code_number U get_cdp_res_e_dpdch2_code_number U get_cdp_res_e_dpdch3_code_number U get_cdp_res_e_dpdch4_code_number U get_cdp_res_e_dpdch5_code_number U get_cdp_res_e_dpdch6_code_number U get_cdp_result get_cdpstep_res_dpcch_max get_cdpstep_res_dpcch_min get_cdpstep_res_dpdch1_max get_cdpstep_res_dpdch1_min get_cdpstep_res_hsdpcch_max get_cdpstep_res_hsdpcch_min get_cdpstep_res_nof_valid_slots get_cdpstep_res_ue_power_max get_cdpstep_res_ue_power_min get_cdpt_limit_select get_cdpt_res_beta_c_max get_cdpt_res_beta_c_min get_cdpt_res_beta_d_max get_cdpt_res_beta_d_min get_cdpt_res_beta_ec_max get_cdpt_res_beta_ec_min get_cdpt_res_beta_ed1_max get_cdpt_res_beta_ed1_min get_cdpt_res_beta_ed2_max get_cdpt_res_beta_ed2_min get_cdpt_res_beta_ed3_max get_cdpt_res_beta_ed3_min get_cdpt_res_beta_ed4_max get_cdpt_res_beta_ed4_min get_cdpt_res_beta_hs_max get_cdpt_res_beta_hs_min get_cdpt_res_dpcch_max get_cdpt_res_dpcch_min get_cdpt_res_dpdch1_code_number get_cdpt_res_dpdch1_max get_cdpt_res_dpdch1_min get_cdpt_res_dpdch2_code_number get_cdpt_res_dpdch3_code_number get_cdpt_res_dpdch4_code_number get_cdpt_res_dpdch5_code_number get_cdpt_res_dpdch6_code_number get_cdpt_res_edpcch_max get_cdpt_res_edpcch_min get_cdpt_res_edpdch1_max get_cdpt_res_edpdch1_min get_cdpt_res_edpdch2_max get_cdpt_res_edpdch2_min get_cdpt_res_edpdch3_max get_cdpt_res_edpdch3_min get_cdpt_res_edpdch4_max get_cdpt_res_edpdch4_min get_cdpt_res_hsdpcch_max get_cdpt_res_hsdpcch_min get_cdpt_res_nof_valid_slots get_cdpt_res_ue_power_max get_cdpt_res_ue_power_min get_cdpt_run_mode get_cell get_cell0 U get_cell_power_without_ocns get_changed_item get_channel_name get_channel_selection get_clone_ptr get_cmace_service_name get_cmachs_service_name get_cmac_service_name get_CM_test_step get_cnf_mode get_cola_meas_hw_interface_tx_cal!U get_config get_config get_config_mode get_config_usb get_confirmed_service_number get_connector_limit get_connector_limits get_connector_type get_conn_limits get_control_task get_cor_ctrl get_correction_type get_correction_type_rrc get_correction_type_wide get_correction_value get_cphy_cell_id get_cphy_gain_noise get_cphy_power_level get_cphy_power_level_max get_cphy_power_level_min get_cphy_power_offset get_cphy_service_name get_cp_poweron_results get_cqi_feedback_cycle get_CQI_InterTTIDistance get_cqi_list_length get_CQIMappingUserDef_ptr get_cqi_max get_cqi_min get_CQITbl_report_count get_CQITbl_report_data get_crest_factor get_crlc_service_name get_csarr_index get_cs_rab get_ctrl get_ctrl_task get_curr_block_length get_current_frequency get_current_mac_hs_type get_current_peak_limit get_current_ref_level_offset get_current_rms_limit get_current_stat_count get_current_traffic_mode=%d get_curr_expected_ue_power get_curr_expected_ue_power_rnd get_curr_meas_position get_curr_sf get_curr_sf_for_edpdch_2 get_data get_data_pattern get_data_pattern_mode get_data_pointer get_data_ptr get_datatype_size get_date get_date_and_time get_day get_DBLER_stop_condition get_ddc_filter get_ddc_filter_index get_ddc_request get_ddc_resource_request get_default_channel_10M0_filter get_default_channel_7M68_filter get_default_gateway get_default_item get_default_wide_10M0_filter get_default_wide_7M68_filter get_delay_hsdpa get_delay U get_delta_ack get_delta_cqi get_delta_ed1 get_delta_ed2 get_delta_factor get_delta_nack get_desired_max_level get_detector get_diagram get_diagram_on_off get_diag_result get_display_unit_and_statistics get_dl_crc_size get_dld_name get_dl_dpch_spreading_factor get_DlDpchSpreadingFactor get_DlDpchSpreadingFactor_r3 get_DlDpchSpreadingFactor_r4 get_DlDpchSpreadingFactor_r5 get_DlDpchSpreadingFactor_r6 get_dl_dtch_tti get_dl_no_of_tblocks get_dl_results get_dl_tb_size get_double get_dpcch U get_dpch get_DPCH_CompressedModeInfo get_dpch_dl_ul_timing get_dpch_phase_reference get_dpch_slot_format get_dpch_slot_power get_dpch_spreading_fact get_dpch_timing_offset get_dpc_mode get_dpc_stepsize get_dpdch_fec_mode get_dpdch U get_dsch_no_codes get_dsp_app_name get_dsp_channel_offset get_dsp_hopping_table get_dsp_maximum_wait_delay get_dsp_narrowband_level get_dsp_nb_level get_dsp_par_block get_dsp_par_block().is_registered() get_dsp_rbw get_dsp_request get_dsp_result_block get_dsp_result_block().is_registered() get_dsp_result_delay get_dsp_run_mode get_dtch_tfi get_DTCH_TTI get_dummy_parameter get_duty_cycle get_dynamic_cmu_host_name get_eagch U get_eagch_value get_edch_ne_j get_edpch_spreading_factor get_edpdch_sf_and_codes_max_ue_cap"U get_edpdch_sf_and_codes_max_utran!U get_edpdch_trbl_size get_effective_limit get_ehich_harq_rv get_ehich_pattern_mode get_ehich_reporting_interval_in_ttis$U get_eip get_element get_enable_size get_encoded_ho_to_utran_data get_env_len get_ergch_ehich get_ergch_ehich_str_ch_offset get_ergch_pattern_mode get_error_count get_error_indication get_error_level get_etfci_index get_ethput_reporting_interval_in_ttis%U get_evaluated_blocks get_evaluated_meas_cycles get_event_level get_event_type get_event U get_expected_dBfullscale get_expected_max_power get_expected_power get_expected_power_ack get_expected_power_cqi get_expected_power_dpcch get_expected_power_dpcch_ack get_expected_power_dpcch_cqi get_expected_power_dpcch_with_edpdch$U get_expected_power_dpdch get_expected_power_dpdch_ack get_expected_power_dpdch_cqi get_expected_power_dpdch_with_edpdch$U get_expected_power_edpcch get_expected_power_edpcch_with_edpdch%U get_expected_power_edpdch1 get_expected_power_edpdch2 get_expected_power_hsdpcch_with_edpdch&U get_expected_service_confirm get_expected_ue_max_power get_expected_value_for_limit_hsdpa"U get_expected_value_for_limit_hsupa"U get_exp_etfci_list_reverse get_exp_max_throughput_HSUPA_for_RLC_BLER)U get_ext_attenuation get_external_attenuation get_external_tx_path get_FDR_stop_condition get_file get_filelength get_filename get_filename_template get_filter get_filter_bandwidth get_filter_characteristic get_filter_i_values get_filter_length get_filter_q_values get_filter_request get_filter_to_use get_filter_type get_first_element_position get_first_element_position of cycle buffer already called get_free get_free_code_no get_freq_settling_time get_frequency get_fsw_row_offset get_full get_generator_type get_generator_type, Rftype=%d, Mode=%d get_gsm_map_rab_identity get_handover_path get_handover_path_request get_hardware_serial_number get_harq_memory_size get_HARQ_report_count get_HARQ_report_data get_hdm get_header get_heplog_mode get_hig_byte get_high_dynamic_condition get_HomWcdma get_hsdpa_rab_config get_HsdpcchLog_report_count get_HsdpcchLog_report_data get_HSDSCH_data_pattern get_HSetData get_HSetIdxConvert get_hspdsch get_hsscch get_HSSCCHConfig get_hsupa_ag_index get_hsupa_ag_pattern_length get_hw_channel_level get_hw_channel_level_hspdsch get_hw_channel_level_max get_hw_channel_level_min get_hw_level_limits get_id get_identity_cnf get_if2_profile_switch get_if_level get_income_ho_type get_income_ho_type_count get_IncomHoTypes get_index_from_path get_index ( ) == ITEM_ANY get_index ( ) != ITEM_ANY get_info get_initialization_adjust get_input_level_attenuation get_in_reset get_inst get_instance get_instance_count get_int get_int get_int16 U get_int32 U get_internal_trigger_type get_intervall_for_average get_in_use get_ip_address get_iq_if_attenuation get_iqif_instance get_iqif_path_deviation get_iqif_rx_path get_iqif_rx_path() get_iqif_tx_path get_iqif_tx_path() get_iq_offset get_iq_scaling_factor get_IR_buffer_size get_item get_item_ptr get_l1c_calibration_factor get_l1c_level_correction get_l1c_power_result get_l1c_power_result_state get_l1c_power_result_value get_l1c_power_state get_l1c_rcv get_l1c_sap get_l1c_service get_last_command() get_last_known_ue_power get_layer_name get_lbk_b96_test_cdma2k get_lbk_b96_test_wcdma get_LBlocks_stop_condition get_len get_length get_level_limits get_level_limits get_level_mode get_lh_delay get_lh_slope get_lh_source get_limit_buffer get_limit_enable_parameter get_limit_evaluation get_limit_parameter get_limits get_limit_selection get_limit U get_linear_interpolation get_linear_level_pk get_linear_level_rms get_llc_eprom_task get_log get_log_ber_int_results_or_not get_log_prefix get_low_byte get_lower_bargraph_limit get_margin_result get_marker_position get_master_task get_master_task_index get_max_allowed_etfci get_max_blocks get_max_blocksize_for_ir_buffer get_max_crest_factor get_max_HSDSCH_no_codes get_max_level get_max_level_external_value get_max_min_output_power get_max_min_value get_max_no_of_bits get_max_power_overwrite_value get_max_span=%f get_max_stat_count get_max_wait_delay_for_settling get_mcl get_mdl_service get_mdl_service() == Global::GMMREG_ATTACH get_mdl_service() == Global::GMMREG_DETACH get_mdl_service() == Global::MMREG_IDENTITY get_mdl_service() == Global::MMREG_REGISTRATION_COMPLETE get_mdl_service() == Global::MNCC_CALL_CONF || get_mdl_service() == Global::MNCC_SETUP get_mdl_service() == Global::MNCC_SETUP get_mdl_service() == Global::RRC_CRRC_ERROR_INDICATION get_mdl_service() == Global::RRC_CRRC_RAB_RELEASE_GET get_mdl_service() == Global::RRC_CRRC_RAB_SETUP_GET get_mdl_service() == Global::RRC_CRRC_SIB_CONFIG_GET get_mdl_service() == Global::RRC_CRRC_SRB_SETUP_GET get_mdl_service() == Global::SMSREG_SM_RECEIVED get_meas_ctrl get_meas_ctrl_block get_meas_flag get_meas_id_of_first_missing_ack U get_meas_length get_meas_limit get_meas_limit_ena get_meas_limit_mode get_meas_result get_meas_select get_meas_UE_level_peak get_meas_UE_level_rms get_measurement_identity get_measurement_length_10ns get_measurement_name get_measurement_parameters get_measurement_report get_measurement_report_agps get_measurement_selection get_measurement_settings get_measurement_specific_max_underdrive'U get_measurement_specific_meas_adcp_duration+U get_measurement_specific_meas_bbp_duration*U get_measurement_specific_rx_rfl_pointer'U get_measurement_state get_measurement_time get_measurement_type get_measure_mode get_measure_position get_memory_config get_memory_name get_message_name_from_number get_message_name_from_number(TaskName,MessageNumber) get_message_number_to_notify_on_parameter_change0U get_message_sap get_mid_byte get_min_inter_TTI_interval get_min_limit_of_max_chan_code get_mmi_row_offset get_mmop_base get_MMREG_IDENTITY_REQ get_mobile_identity_lv get_mode get_model_type get_ModificationIndex get_modification_time get_mod_par ( ).parameter ( PAR_MODULATIONANALYSIS_AVERAGE_PE_PEAK_LIMIT ).get_double_from_int_n_frac ( DSC_INT_FRAC_1 ) >= -1.0 && get_mod_par ( ).parameter ( PAR_MODULATIONANALYSIS_AVERAGE_PE_PEAK_LIMIT ).get_double_from_int_n_frac ( DSC_INT_FRAC_1 ) <= 1.0 get_mod_par ( ).parameter ( PAR_MODULATIONANALYSIS_AVERAGE_PE_RMS_LIMIT ).get_double_from_int_n_frac ( DSC_INT_FRAC_1 ) >= -1.0 && get_mod_par ( ).parameter ( PAR_MODULATIONANALYSIS_AVERAGE_PE_RMS_LIMIT ).get_double_from_int_n_frac ( DSC_INT_FRAC_1 ) <= 1.0 get_mod_par ( ).parameter ( PAR_MODULATIONANALYSIS_CURRENT_MAXIMUM_PE_PEAK_LIMIT ).get_double_from_int_n_frac ( DSC_INT_FRAC_1 )>= -1.0 && get_mod_par ( ).parameter ( PAR_MODULATIONANALYSIS_CURRENT_MAXIMUM_PE_PEAK_LIMIT ).get_double_from_int_n_frac ( DSC_INT_FRAC_1 )<= 1.0 get_mod_par ( ).parameter ( PAR_MODULATIONANALYSIS_CURRENT_MAXIMUM_PE_RMS_LIMIT ).get_double_from_int_n_frac ( DSC_INT_FRAC_1 ) >= -1.0 && get_mod_par ( ).parameter ( PAR_MODULATIONANALYSIS_CURRENT_MAXIMUM_PE_RMS_LIMIT ).get_double_from_int_n_frac ( DSC_INT_FRAC_1 ) <= 1.0 get_mod_par ( ).parameter ( PAR_MODULATIONANALYSIS_RESERVED_1 ).get_uint32 ( ) == 0x000000 get_mod_par ( ).parameter ( PAR_MODULATIONANALYSIS_RESERVED_2 ).get_uint32 ( ) == 0x000000 get_mod_par ( ).parameter ( PAR_MODULATIONANALYSIS_TAILBITDECODE ).get_uint32 ( ) <= 1 get_mod_par ( ).parameter ( PAR_MODULATIONANALYSIS_UPDATE_CONTROL ).get_uint32 ( ) == 0x000000 get_mod_result get_modulation get_module get_month U get_msg get_msg_id() MsgId =%d get_name get_name_string get_narrow_band_level get_nas_number_v get_nb_dl_coding_mode get_nb_ul_coding_mode get_N_e_data get_netclock_frequencies get_NetType get_NetWcdmaControl get_NetWcdmaQuality get_network_specific_arg_uncertainty$U get_next_element_position get_next_element_position called before get_first_element_position get_next_item get_nof_channels get_nof_columns get_nof_rows get_No_HARQ_processes get_nom_iq_intf_level get_no_of_add_infos get_no_of_adjust_functions get_no_of_cells get_no_of_completely_adjusted_functions'U get_no_of_diagram_points get_no_of_diagram_points_hsdpa get_no_of_transport_blocks_confidence%U get_no_of_update_functions get_no_satellites_from_input_flags"U get_npm_filter get_nsig_bla get_nsig_gen get_nsig_hw_rx get_number_of_channels get_number_of_edpdch_equivSF4_codes#U get_number_of_edpdch_physical_codes#U get_number_of_measure_points get_number_of_results get_object get_object_info get_object_pointer get_obw_params get_obw_result get_ocns get_off_power_level_wide_narrow get_off_power_narrowband_level get_off_power_wideband_level get_offset_strongest_channel get_oloo_base get_open_mode get_operation_mode get_options get_options_from_env get_options_from_ini get_option_sumtion get_option_version_string get_optpoll_diag_gain_offset get_optpoll_diagnose_unconverted() get_optpool_diag_gain get_ordered_mmi_ref_etfci get_OutgoHoTypes get_output_channel_pwr get_output_channel_pwr_parameter U get_output_shift get_overdrive_dpdch_dpcch get_overdrive_reserve get_overload_level get_overridden_result_limits get_parameter get_par_ctrl get_par_ctrl_array get_parent_task get_par_name get_PartNumber get_path get_path_items get_path_manager_maximum_wait_delay#U get_path_request get_path().rx().get_c331_ctrl () != NULL get_pccpch get_pci_memory_size get_pcpich get_percentage_of_evaluated_statistic_cycles,U get_percentage_of_evaluated_transport_blocks,U get_phase_time get_phd_limit_select get_phd_res_nof_valid_slots get_phd_res_stat_count get_phd_res_stat_count_limit_phd U get_phd_res_stat_count_total get_phd_res_ue_last_step get_phd_res_ue_power_max get_phd_res_ue_power_min get_phy_channel_type get_pich get_pilot_bits_from_slot_format get_pmar_ue_power_peak_fullscale U get_pmar_ue_power_rms_fullscale get_pmgr_ref get_pmod_base get_PMOD_result get_PNDiscont_stop_condition get_poweroffset_delta get_power_result get_power_result_state get_power_result_value get_power_step_ACKNACK_CQI get_power_step_CQI_CQI get_power_step_CQI_DTX get_power_step_DTX_ACKNACK get_ppc_ctrl_task get_predecessor get_primitive_type get_primitve_name get_profile_bool get_profile_double get_profile_int get_profile_length get_profile_string get_profile_uint get_progress get_psch get_qmod_base get_qpsk_result get_quant_amplitude get_quant_amplitude_hsdpa get_quantised_ampl_ratio_from_delta_edpdch*U get_rab get_rab_name get_rab_release get_rab_release_index get_rab_rel_name get_rabrel_type get_rab_setup_index get_rab_type get_ranging_initial_table_entry get_ranging_lower_threshold get_ranging_operation_mode get_ranging_table_entries get_ranging_upper_threshold get_rb_id U get_rbw get_rcv get_rcv_cmac get_rcv_cmace get_rcv_cmachs get_rcv_cphy get_rcv_crlc get_received_sm get_receiver get_receiver_name get_recent_event get_reference get_reference_dpcch_dpdch get_reference_dpcch_dpdch_ack get_reference_dpcch_dpdch_cqi get_reference_edpdch get_reference_level get_register_address(), RegAdd=%x get_registration_complete_ind get_registration_srb get_relative_level get_relative_level_max get_relative_level_min get_release_5_mode get_rel_level_0dbfs_channel get_remainding_level_error(), RemErr=%f get_remote_timeout get_remote_values get_RepCQI_report_count get_RepCQI_report_data get_repetition_factor get_request get_res_dpdch1_code_number get_reserve_adcp get_reserve_bbp get_reset_process get_resource_manager_maximum_wait_delay'U get_resource_request get_rest_timeout_ms get_result get_result_control get_result_control() %d %d get_result_data_len(), ResultDataLen %d get_result_data_ptr() get_result_delay get_result_delay_remote get_result() %f get_result_HSDPA get_result_limits get_result_overflow get_results get_results() get_results_for_testing get_result_valid get_ReTrans_report_count get_ReTrans_report_data get_rfl get_rf_level get_rfl_hdyn_type get_rfl_instance get_rfl_levelmode get_RfSignal get_rgch_reporting_interval_in_ttis#U get_ric get_ric_class_id get_ric_timeout get_rlc_header_size get_rlc_max_throughput_dl get_rlc_max_throughput_ul get_rlc_rab_data_index get_rmc_type get_round_trip_delay get_rrc_connection_setup_complete!U get_rrc_meas_control_horizontal_accuracy(U get_rrc_meas_control_vert_accuracy"U get_rrc_ref_ue_pos_latitude get_rrc_ref_ue_pos_longitude get_rrc_ref_ue_pos_orientation_maxis$U get_rrc_ref_ue_pos_uncertain_alt U get_rrc_ref_ue_pos_uncertain_smajor#U get_rrc_ref_ue_pos_uncertain_sminor#U get_rrc_scaling_for_bitstring get_rrc_scaling_for_bitstring_unsigned&U get_rrc_TransactionIdentifier get_run_mode get_RV_coding_seq get_RvCodingSequences get_rx_ddc_filter get_rx_dsp_delay get_rx_dsp_request get_rx_extatt_hw_setting get_rx_narrow_band_level get_rx_path get_rx_resource_request get_rx_step_nb_level_dB get_rx_switch_frequency_Hz get_rx_switch_level_dB get_rx_switch_position get_rxtx_diag_voltage get_rxtx_index_from_pmgr_ref get_rxtx_revision get_samples_captured get_samples_captured_free_run get_sap get_sap_name get_save_to_file_info get_scale_y_default get_sccpch get_scenario get_Scenario get_schedule_timing get_scpich get_scpich_phase get_secret_key get_secret_key= get_selected_application get_selected_bsw_control get_selected_connector get_selected_expected_etfci_value!U get_selected_handover_type get_selected_info_parameter get_sem_1MHz_filter get_sem_params get_sem_result get_send_data_len(), SendDataLen %d get_send_data_ptr() get_SerialNumber get_service get_service_and_type get_service_name get_service_number get_set_level_function_data get_setting get_setup_ind get_sfn get_short_filter_i_values get_short_filter_length get_short_filter_q_values get_short_name get_sib_name get_sib_type get_sig_bla get_sig_bla_1 get_SigGenMmiConst get_SigGenMmiConstHsupa get_SigGenParams get_SigGenParamsHsupa get_sig_mmi_par get_signal_confirm get_signalling_command_task get_signalling_ctrl_task get_signalling_generator get_signalling_hardware_interface!U get_signalling_hardware_task get_signalling_parameter_task get_signalling_ps_task get_signalling_setup get_signalling_task get_signal_manager get_signals get_sip get_size get_size_of_list get_slope U get_SNR_gain_factors get_snr_offset get_softkey_count get_source get_speech_dsp get_spreading_factor get_srb get_srb_dl_dpch_chan_code get_srb_dl_dpch_spreading_fact get_srb_name get_srb_setup_index get_ssch get_stack_consumption get_stack_size get_startup_screen_tsr_segadr get_startup_time_seconds get_state_change_maximum_wait_delay#U get_state_name_from_number get_state_name_from_number(TaskName,StateNumber) get_state U get_statistic_count_max get_statistic_diag get_statistic_length get_statistic_type get_status get_status_item get_status_register() get_stepat(), AttenuationSet=%d get_step_config get_step_display_mode get_step_width_10ns get_string get_string get_string_ptr get_strongest_channel get_subframes_to_measure_for_bler!U get_sub_layer get_subnet_mask get_sub_val_type get_sum_duty_cycle get_suppressed get_switch(), AuxTxSwitch=%d get_sw_version_fsw get_tag get_task get_task_array get_task_control get_task_name get_tblock_mode get_tbs_per_second get_temperature_diag_gain get_temperature_diag_gain_offset get_template_par_blk get_test get_test_entries get_test_name get_test_parameter get_test_parameter_count get_tfci_state get_TGCFN U get_ti_flag get_TimeInMs get_timeout get_timeout() get_timeout_ctrl get_timeout_ctrl() == TRUE get_timeout_ctr() , TimeOutCtr =%d get_timeout_duration get_timeout_manager get_TimeStamp get_ti_value get_tl_info_number_of_rb get_tl_info_rb_id get_tl_info_ul_rlc_sdu_size get_total_power get_tpc_cmd get_tpc_command_alg_1 get_tpc_command_alg_2 get_tpc_dynamic_overhead get_tpc_dynamic_window get_tpc_pattern get_tpc_pattern_length get_tpc_pattern_shift get_tpc_queue_busy get_tpc_read_out_mode get_TPC_test_step get_transmit_RFN get_trg_delay_dsp_chips get_trg_delay_offset get_trg_delay_offset_chips get_trg_delay_rx_path_ns get_trg_delay_slot get_trg_delay_slot_slot get_trg_delay_total_chips get_trg_delay_tx_path_ns get_trg_delay_tx_path_ns_internal!U get_trg_dsp_slope get_trg_dsp_source get_trigger_delay_10ns get_trigger_level get_trigger_parameter get_trigger_type_fsw get_trigger_type_fsw_to_mmi get_trigger_type_mmi get_trigger_type_wcd_enum get_trigger_type_wcd_enum_to_mmi U get_tti_time_dl get_tti_time_ul get_tune_diag_gain_offset get_tune_diagnose_unconverted() get_tx_cal_arg_ctrl get_txcal_nsig_hw_rx get_tx_cal_wcdma_gen get_tx_dsp_request get_tx_path get_tx_resource_request get_tx_selection get_type get_type ()== DSP_RX_TYPE_WDDC400 get_UECatMapping get_ue_frequency get_ue_loopback_restdelay_ms get_ue_power_mode get_UeReportParameters get_uint get_uint get_uint32 get_ul_dpcch_slotformat get_ul_dpch_symbol_rate get_ul_dtch_tti get_ul_nb_dpdch get_ul_no_of_tblocks get_ul_results get_ul_tb_size get_uncertainty_adcp get_uncertainty_bbp get_update_time get_uplink_transport_block_size get_upper_bargraph_limit get_usb_class_par get_usb_class_parameter get_usb_class_parameter() on invalid par get_usb_name get_usb_par get_usb_parameter get_usb_parameter_DPCMode get_usb_parameter_MaxLevel get_usb_parameter_MinLevel get_usb_parameter() on invalid par get_usb_queue_par get_UsbSigAfRfConAttOut get_UsbSigAfRfConOut get_userbase_index get_UTF_stop_condition get_valid_result_mask get_value U get_VariantOfPartNumber get_version get_version() get_version_string get_waiting_usb_instance get_warning_res get_wb_dl_coding_mode get_wb_ul_coding_mode get_wcdmacus get_wcdma_result get_wide_band_level get_wide_band_level: BBP=%f(%d) WBL=%f get_window_count get_wmod_base get_x_array_size get_x_scale get_y_array_size get_year get_y_scale >find . -name \*.DL\? -exec strings {} \; | grep '^set_' | sort -u set_active_channel set_additional_settings set_address set_adjust_fct set_adjustment_pending set_af_freq set_algorithm set_amr_codec_mode set_array U set_asp_choice set_asp_choice msgtype set_asp_choice service set_auc_filter set_AUC_filter set_audio_output set_auto_ranging set_auxtx_channel(), InChannelNr=%d, IsOffLevel=%d, CurrentNetwork=%d set_auxtx_cmd(), InCmd=%d set_auxtx_connector(), Connector=%d, InConnector=%d set_auxtx_connector(), Connector=%d, InConnector=%d, InExtAtt=%f, InLevel=%f set_auxtx_fallback_source_data set_auxtx_ho_source_data set_awgn_changed set_b21_parameters set_b21_parameters IP set_b83_addressing_type set_b83_parameters set_b83_static_ip set_b83_static_ip IP set_ba_ca_channel_list() set_ba_ca_channel_list_sorted() set_bit set_bits set_bits_for_limit_enable set_bits_for_measurement_interval!U set_bitstring_from_int set_bitstring_from_int_unsigned set_BLER_QualityValue_r3 set_BLER_QualityValue_r4 set_BLER_QualityValue_r5 set_block_bit set_buffer set_c331_level set_c331_path_deviation: %f set_callback set_callback_fct set_callback_fct_data() set_callback_freed set_callback_id set_callback_locked set_callback_msg_data() set_callback_reason set_cc_status set_cell_changed set_channel_changed set_ChannelFullscale set_check_fct set_class_adjust_fct set_clock_switches set_CMACE_EtfcRestrictionInfo set_CMACE_MeasCtrlParams set_cm_gaps set_cm_initial_deltas set_cmr_results_invalid set_commit_mode set_commit_mode %d (was %d) set_completely_adjusted_fct set_compressed_mode set_compressed_mode_factor set_compressed_mode_pattern set_compressed_mode_r3 set_compressed_mode_r5 set_compressed_mode_r6 set_compressor set_compressor_reference set_compressor_time_constant set_confidence_decision set_confidence_mmi set_connector set_controller set_correction set_correction to set_coupling set_cphy_ulcc_data_log_request set_CQIMappingUserDef set_crest_factor set_crest_multitone set_CRRC_GENERAL_PARAM_SET_REQ set_CRRC_HO_FROM_UTRAN set_CRRC_HO_FROM_UTRAN_data set_CRRC_HO_TO_UTRAN set_CRRC_TIMER set_CRRC_TIMER_SET_REQ set_ctrl set_curr_pass_and_fail set_cw_signal_off set_cw_signal_on set_date set_dch_type_ps_to_data_application#U set_ddc_filter_index set_ddc_is_initialized set_DDS_frequency() only supported on B96 board set_DDS_frequency(), wrong channel set_debounce_mode set_debounce_time set_debounce_time_us set_de_emphasis set_default_values set_delay_connection set_delay_for_message set_delay U set_desired_result set_desired_result_bits set_desired_result call missing set_detector set_determined_nb_level_dB set_dhcp_error_occurred set_diagram_lower_limit_level set_diagram_lower_limit_onoff_switch set_diagram_reference_level set_diagram_ref_level set_diagram_result_mode set_diagram_upper_limit_level set_diagram_upper_limit_onoff_switch set_diagram_validities set_DIG_setting set_DL_DPCH_PowerControlInfo set_DL_InformationPerRL_List_r3 set_DL_InformationPerRL_List_r5 set_dpcch_slot_format set_dpcch_slot_format set_DPCH_FrameOffset_r3 set_DPCH_FrameOffset_r4 set_DPCH_FrameOffset_r5 set_DPCH_FrameOffset_r6 set_dsp_all_parameter set_dsp_am_parameter set_dsp_dsb_parameter set_dsp_gtconfig_parameter set_dsp_ignore_narrowband_level set_dsp_parameters set_dsp_param_RX set_dsp_request set_dsp_result_delay set_dsp_ssb_parameter set_dsp_ssb_parameter AfFrequency1/SAMPLE_FREQUENCY=%f, ModIndex1=%f set_duplicate_step_values set_duty_cycle set_edit_channel set_event U set_expandor set_expandor_reference set_expandor_time_constant set_expected_level set_expected_level: set_expected_level - level not changed set_exp_level set_ext_att set_ext_attenuation set_external_attenuation(), InConnector=%d, InExtAtt=%f set_external_attenuation(), InConnector=%d, InExtAtt=%f, InLevel=%f set_fa1_frequency set_fer_results_invalid set_FE_setting set_filename set_filename_template set_filter set_filter_bandlimit set_filter_bandpass set_filter_coeff set_filter_hipass set_filter_notch set_filter_weighting set_follow_state set_freed U set_frequency set_frequencyInfo set_frequencyInfoFDD set_generator_frequency set_generator_level set_generator_mode set_generator_type set_gen_lead set_graph_scale set_gsmms_apptesting_parameters set_handover_from_utran_command_gsm#U set_hardware_is_initialized set_hig_byte set_holdoff_time set_hopping_off set_hopping_run set_hopping_state set_ho_without_ack_time set_hsd_switches set_HsUlTriggerSelect set_idx set_iec_scalar_result_validity set_if3_corr set_if_level set_input_overdriven set_input_source set_input_underdriven set_in_reset set_int16_values set_int16_values_by_meas_val set_interval set_interval_meas_mode set_in_use set_inversion set_io_mode set_iq_if_att_changed set_iqif_path set_IQ_Path() only supported on B96 board set_IQ_Path(), wrong channel set_l1c_ber_state set_l1c_level_correction set_level set_level_and_frequency_RX set_level_and_frequency_TX set_level_fct set_level_rf set_level U set_lh_slope set_lh_source set_lh_trigger_delay set_limit_check set_limit_check_by_meas_val set_limited_ABC_table_dB set_limited_nb_level_dB set_limit_fct set_limit_line set_limit_update_fct set_local_mem_invalid: set_locked set_logging_mode set_logging_mode set_logging_prefix set_log_ptr set_loop_state_method set_low_byte set_lower_limits set_masterclock_select set_MaxAllowedUL_TX_Power set_max_level set_max_level_mobile_power set_meas_duration set_meas_error set_meas_flag set_meas_interval_time set_meas_related_info set_meas_start_pcl set_measure_delay set_measurement_control set_measurement_control_agps set_measurement_interval set_measurement_interval_mode set_measurement_mode set_mem_ctrl set_message_suppression set_mid_byte set_mode set_model_type set_molr_results_for_ss_facility U set_msg_id() InMsgId =%d set_ms_loop_mode(), MS_LOOP_MODE_FER set_ms_loop_mode(), MS_LOOP_MODE_NORMAL set_multi_channel_list set_multislot_class_dtm %d set_multislot_class_dtm default set_multitone_frequency set_multitone_level set_multitone_onoff_switch set_narrowband_level set_new_adcp_level set_new_adcp_level: WBL=%f NBL=%f dBm set_new_bbp_level set_new_bbp_level: NBL=WBL=%f dBm set_new_frequency set_next_meas_pcl: Commanded = %d Reported = %d -> NextPcl = %d set_next_setting set_next_state set_number_of_active_channels set_operation_mode set_opt_bit set_options set_option_value_for_userbase set_output_shift set_par_adjustment_pending set_par_ctrl set_par_ctrl_array set_par_ctrl_flags set_parupd_flag set_par_validity set_path() failed set_path_mgr set_pending_message set_periodicity_of_sched_info set_permission_process_running set_phych_reconfig_config set_phys_chan_reconfig_failed set_physical_channel_reconfiguration_r3'U set_physical_channel_reconfiguration_r5'U set_physical_channel_reconfiguration_r6'U set_physical_channel_reconfiguration$U set_pmgr_item set_power_control_intervall set_power_off() set_power_off() not supported on B96 board set_powerOffsetInformation set_power_on() set_precision set_predecessor set_pre_emphasis set_PrimaryCPICH_TX_Power set_PrimaryScramblingCode set_priority set_PriorityQInfo set_QualityTarget set_radiobearer_reconfig set_radiobearer_reconfig_r3 set_radiobearer_reconfig_r5 set_radiobearer_reconfig_r6 set_radiobearer_release set_radiobearer_release_r3 set_radiobearer_release_r5 set_radiobearer_release_r6 set_radiobearer_setup set_radiobearer_setup_r3 set_radiobearer_setup_r5 set_radiobearer_setup_r6 set_ramping_and_hopping set_receiver set_receiver: parameter is NULL set_receiver_report() set_receiver_report: DTX unused set_receiver_report: DTX used set_receiver_report_emr() set_receiver_report_emr: DTX unused set_receiver_report_emr: DTX used set_reference set_reference_frequency_not_locked"U set_reference_level set_ref_level set_REF_setting set_register_address(), InRegAdd=%x set_remote_control set_report_for_exception set_reset_data set_reset_ue_position set_result_data(), InResultDataLen %d set_result_delay set_result_is_final set_result_latitude set_result_longitude set_result_orient_maxis set_result_report_number set_results_failed set_results_for_tti_10ms set_results_for_tti_2ms set_result_type_multitone set_result_uncertainty_alt set_result_uncertainty_code set_result_uncertainty_smajor set_result_uncertainty_sminor set_rf_connector set_rf_connector_ext_attenuation set_rf_connector_ext_attenuation U set_rf_freq set_rf_freq_offset set_rf_frequency set_rf_frequency() set_rf_level set_rf_level(), Inlevel=%f, ExtAtt1=%f, ExtAtt2=%f set_rf_level_Out3() only supported on B96 board set_rfl_level_check_suppressed set_rfl_level_offsets set_rf_max_manual_level set_rf_off() set_RfSignal set_RNTI set_rrc_connection_setup set_rrc_connection_setup_r3 set_rrc_connection_setup_r5 set_RRC_CRRC_MEAS_CONTROL set_RRC_CRRC_PHYCH_RECONFIG set_RRC_CRRC_RAB_RECONFIG set_RRC_CRRC_RAB_RELEASE set_RRC_CRRC_RAB_SETUP set_RRC_CRRC_SIB_CONFIG set_RRC_CRRC_SRB_SETUP set_run_mode set_rx1_to_both_rx_dsps set_rxdsp_trigger_delay set_rx_frequency set_rx_level set_rx_level set_sac_rep_results_invalid set_samples_captured set_samples_captured_free_run set_save_to_file_info set_scale_y_to_default set_Scenario set_SecondaryCpich set_secondaryScramblingCode set_send_data set_set_bit set_set_level_fct set_SF512_AndCodeNumber set_shared set_sib5_ies set_signalledGainFactors_r3 set_signalledGainFactors_r4 set_sig_status set_sleep_delay set_slope U set_slot_format set_snr_offset_changed set_softkey_label set_source set_startup_adjust_count set_statistic_counter set_status set_step_size_diagram_limits set_string set_synchronise_ready set_synchronise_wait set_system_error_occurred set_tag set_target_path set_task_timeout set_task_timeout set_task_timeout_in_ms set_ti set_timed_out set_timeout set_timeout() set_timeout_for_message set_timeout_internal set_timeout_ms set_timeout_ms_to_min set_timer_counter set_timer_mode set_timer_task_control set_timer U set_timestamp set_to_boot_mode() set_to_fractional set_to_halt set_to_off set_to_run set_total_power set_tpc_after_call_setup set_tpc_after_gen_reconfig set_tpc_algorithm set_tpc_command set_trg_adjust_fct set_trg_adjust_fcts set_trig set_trigadj_count set_trigger_connection set_trigger_if_level_offset set_trigger_level set_trigger_mode set_trigger_slope set_trigger_source set_tx_levels(), TX_LEVEL_MODE_FER set_tx_levels(), TX_LEVEL_MODE_NORMAL set_tx_levels(), TX_LEVEL_MODE_SAC_REP set_tx_level_to_c331() set_UL_DPCH_Info_r3 set_UL_DPCH_Info_r4 set_UL_DPCH_Info_r5 set_UL_DPCH_Info_r6 set_ul_trch_destination set_update_fct set_upper_end set_upper_limits set_usb_invalid: set_valid U set_value_DOUBLE set_value_INT16 set_version set_volume set_wb_amr_rlc_size_type1 set_wb_amr_rlc_size_type2 set_wb_amr_rlc_size_type3 set_wideband_level set_x_array set_x_axis set_x_extents set_x_scale set_x_values set_y_offset set_y_scale set_y_values .../R-S_CMU_HD/CMU/BIN_V5.21 # >find . -name \*.EXE -exec strings {} \; | grep '^get'_ | sort -u get_actual_stack_frame_number get_adress get_allocator get_and_check_real_address get_bit_stream_name_for_switch get_board_by_index get_board_name_for_table get_buffer_string_len get_ch get_clock U get_command get_controller get_cor_version get_data get_data_ptr get_datatype_columnhead get_datatype_elemnr get_datatype_formatstr get_datatype_name get_datatype_size get_datatype_string get_date_and_time get_debug_option get_double get_eip get_float_value get_fp get_fp_ext get_gldes ret'd bad result on recursive call get_gldes ret'd bad result to dt_search get_gldes ret'd bad result to mread get_gldes ret'd bad result to mwrite get_ident_name get_ident_string get_int16 U get_int32 U get_int_symbol get_int_value get_isa_mem_byte get_isa_mem_word get_jbc_names get_len get_logical_base get_max_no_elements get_mirror_id get_mirror_label get_mirror_label_desc get_next_buffer_address get_next_params get_no_new_elements get_no_new_modification_elements U get_no_old_elements get_parameter_unit get_pci_irq get_rest_timeout_ms get_result_string get_size get_string get_switch_index_out_of_stream get_switch_state get_table_header_for_matrix get_table_header_for_table get_table_list_from_cor get_table_name_for_id get_uint32 get_user_cal_info get_var_arg get_var_value get_version get_xil_busy get_xil_done get_xil_init get_xil_ready_for_next_byte >find . -name \*.EXE -exec strings {} \; | grep '^set'_ | sort -u set_address set_clock U set_ctrl set_data set_default_service_table set_device_may_be_busy set_dpram_addr set_flash_address set_hlim unexpectedly ret'd err during cleanup set_isa_mem_byte set_isa_mem_word set_job_error set_limits set_matrix_pointer set_PPC_MAC_Address set_rf_board set_timeout_ms set_timeout_ms_to_min set_timer_counter set_timer_mode
