>mkimage -l initrd3g.bin Image Name: Ramdisk Tar Image Created: Thu Mar 25 19:03:35 2010 Image Type: PowerPC Linux RAMDisk Image (gzip compressed) Data Size: 6756479 Bytes = 6598.12 KiB = 6.44 MiB Load Address: 00000000 Entry Point: 00000000 tail -c+65 < initrd3g.bin > initrd3g.bin.tar wcdmV5.20A.mw/FW/USU/WCDMA/initrd3g.bin.tar.dir/etc cat hosts ... # FSU slave systems 192.168.48.179 ppclan-fsu fsu # FSU Spectrum analyzer (alt. conn. using RSIB32.DLL) cat passwd ... elinos:x:100:100:ELinOS example user:/:/bin/bash guest:x:101:101:Guest user:/mnt/sys/prg:/bin/bash cat profile ... # CMU200 : MONCBCC requires prompt = UBOOT-prompt PS1='=> ' PS2='> ' ... # helper aliases for pbfpga driver-ing etc. alias imp='insmod pbfpga.ko' alias rmp='rmmod pbfpga' alias pt='pbfpgatst' alias pi='echo -ne "\nPlatform: "; cat /proc/driver/pbfpga/Platform; echo -ne "\nClientIP: "; cat /proc/driver/pbfpga/ClientIP; echo -ne "\nServerIP: ";cat /proc/driver/pbfpga/ServerIP; echo; cat /proc/driver/pbfpga/all' alias pe='cat /sys/bus/i2c/devices/0-0049/eeprom > /smb/ppctype.bin' alias moncbcc='bash &> /dev/misc/cbcc mkimage -l busybox.bin Image Name: Ramdisk Tar Image Created: Thu Mar 25 19:03:23 2010 Image Type: PowerPC Linux RAMDisk Image (gzip compressed) Data Size: 6648814 Bytes = 6492.98 KiB = 6.34 MiB Load Address: 00000000 Entry Point: 00000000 >tail -c+65 < busybox.bin > busybox.bin.tar CMU200_Firmware/wcdmV5.20A.mw/FW/USU/WCDMA/busybox.bin.tar.dir/etc >cat shadow ... elinos:V0tDTUN3E9haI:1:0:99999:::: guest:V0tDTUN3E9haI:1:0:99999:::: wcdmV5.20A.mw/FW/USU/WCDMA/busybox.bin.tar.dir/lib/modules/2.6.12.6-elinos-226-rsdpq2/extra -rwxr-xr-x 1 x users 9187 Sep 28 2007 cbcc.ko -rwxr-xr-x 1 x users 35386 Jun 6 2007 pbfpga.ko -rwxr-xr-x 1 x users 20751 Sep 2 2009 ppc2isa.ko -rwxr-xr-x 1 x users 15861 Sep 28 2007 usudsp.ko >objdump -x cbcc.ko cbcc.ko: file format elf32-powerpc cbcc.ko architecture: powerpc:common, flags 0x00000011: HAS_RELOC, HAS_SYMS start address 0x00000000 Sections: Idx Name Size VMA LMA File off Algn 0 .text 00000708 00000000 00000000 00000034 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 1 .init.text 00000204 00000000 00000000 0000073c 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 2 .exit.text 00000098 00000000 00000000 00000940 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 3 .rodata 00000044 00000000 00000000 000009d8 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 4 .modinfo 00000148 00000000 00000000 00000a1c 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 5 .rodata.str1.4 00000340 00000000 00000000 00000b64 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 6 .data 0000006c 00000000 00000000 00000ea4 2**2 CONTENTS, ALLOC, LOAD, RELOC, DATA 7 .gnu.linkonce.this_module 00000140 00000000 00000000 00000f20 2**5 CONTENTS, ALLOC, LOAD, RELOC, DATA, LINK_ONCE_DISCARD 8 .sbss 00000018 00000000 00000000 00001060 2**2 ALLOC 9 .plt 00000000 00000000 00000000 00001060 2**3 ALLOC, READONLY, CODE 10 .bss 0000005c 00000000 00000000 00001060 2**2 ALLOC 11 .init.plt 00000000 00000000 00000000 00001060 2**3 ALLOC, READONLY, CODE 12 .comment 00000068 00000000 00000000 00001060 2**0 CONTENTS, READONLY 13 .note.GNU-stack 00000000 00000000 00000000 000010c8 2**0 CONTENTS, READONLY SYMBOL TABLE: 00000000 l d .text 00000000 .text 00000000 l d *ABS* 00000000 .rela.text 00000000 l d .init.text 00000000 .init.text 00000000 l d *ABS* 00000000 .rela.init.text 00000000 l d .exit.text 00000000 .exit.text 00000000 l d *ABS* 00000000 .rela.exit.text 00000000 l d .rodata 00000000 .rodata 00000000 l d .modinfo 00000000 .modinfo 00000000 l d .rodata.str1.4 00000000 .rodata.str1.4 00000000 l d .data 00000000 .data 00000000 l d *ABS* 00000000 .rela.data 00000000 l d .gnu.linkonce.this_module 00000000 .gnu.linkonce.this_module 00000000 l d *ABS* 00000000 .rela.gnu.linkonce.this_module 00000000 l d .sbss 00000000 .sbss 00000000 l d .plt 00000000 .plt 00000000 l d .bss 00000000 .bss 00000000 l d .init.plt 00000000 .init.plt 00000000 l d .comment 00000000 .comment 00000000 l d .note.GNU-stack 00000000 .note.GNU-stack 00000000 l d *ABS* 00000000 .shstrtab 00000000 l d *ABS* 00000000 .symtab 00000000 l d *ABS* 00000000 .strtab 00000000 l df *ABS* 00000000 cbcc_drv.c 00000000 l F .init.text 00000204 cbcc_drv_init 00000000 l F .exit.text 00000098 cbcc_drv_exit 00000000 l O .modinfo 0000007a __mod_description137 0000007c l O .modinfo 0000007d __mod_author133 000000fc l O .modinfo 0000000c __mod_license1966 00000000 l O .data 0000006c cbcc_drv_fops 000000f8 l F .text 000002c8 cbcc_drv_read 000003c0 l F .text 00000238 cbcc_drv_write 000005f8 l F .text 00000008 cbcc_drv_ioctl 00000600 l F .text 000000b0 cbcc_drv_open 000006b0 l F .text 00000058 cbcc_drv_release 00000000 l O .sbss 00000004 ModUseCount 00000004 l O .sbss 00000004 shell_pid 00000000 l F .text 0000005c safe_write_dpram_offs 00000008 l O .sbss 00000004 dpram_start 0000005c l F .text 0000009c safe_read_dpram_offs 00000010 l O .sbss 00000008 cbccShadowChannel 00000000 l O .rodata 0000000e __PRETTY_FUNCTION__.3 00000010 l O .rodata 00000011 __PRETTY_FUNCTION__.2 00000024 l O .rodata 0000000e __PRETTY_FUNCTION__.1 0000000c l O .sbss 00000004 dpram_size 00000000 l O .bss 0000005c cbcc_dev 00000034 l O .rodata 0000000e __PRETTY_FUNCTION__.0 00000000 l O .bss 00000000 Cbcc_Drv_Mutex 00000000 l df *ABS* 00000000 cbcc.mod.c 00000108 l O .modinfo 00000009 __module_depends 00000114 l O .modinfo 00000034 __mod_vermagic5 00000000 *UND* 00000000 misc_deregister 00000000 *UND* 00000000 pRsdpqXHwCtrl 00000000 g O .gnu.linkonce.this_module 00000140 __this_module 00000000 *UND* 00000000 __symbol_put 00000000 g F .exit.text 00000098 cleanup_module 00000000 *UND* 00000000 msleep_interruptible 00000000 g F .init.text 00000204 init_module 00000000 *UND* 00000000 __symbol_get 00000000 *UND* 00000000 preempt_schedule 00000000 *UND* 00000000 printk 00000000 *UND* 00000000 misc_register 00000000 *UND* 00000000 send_sig RELOCATION RECORDS FOR [.text]: OFFSET TYPE VALUE 0000001e R_PPC_ADDR16_HA .sbss+0x00000008 00000022 R_PPC_ADDR16_LO .sbss+0x00000008 00000054 R_PPC_REL24 preempt_schedule 00000082 R_PPC_ADDR16_HA .sbss+0x00000008 00000086 R_PPC_ADDR16_LO .sbss+0x00000008 000000f0 R_PPC_REL24 preempt_schedule 0000011a R_PPC_ADDR16_HA .sbss+0x00000004 00000122 R_PPC_ADDR16_LO .sbss+0x00000004 00000152 R_PPC_ADDR16_HA .sbss+0x00000010 0000015e R_PPC_ADDR16_LO .sbss+0x00000010 0000018a R_PPC_ADDR16_LO .sbss+0x00000010 00000192 R_PPC_ADDR16_HA .sbss+0x00000008 00000196 R_PPC_ADDR16_LO .sbss+0x00000008 000001d6 R_PPC_ADDR16_HA .sbss+0x00000010 000001da R_PPC_ADDR16_LO .sbss+0x00000010 000001e6 R_PPC_ADDR16_LO .sbss+0x00000008 00000232 R_PPC_ADDR16_LO .sbss+0x00000010 000002c0 R_PPC_REL24 msleep_interruptible 000002d6 R_PPC_ADDR16_HA .rodata.str1.4 000002da R_PPC_ADDR16_LO .rodata.str1.4 000002e0 R_PPC_REL24 printk 000002f2 R_PPC_ADDR16_LO .sbss+0x00000004 0000030c R_PPC_REL24 send_sig 0000033a R_PPC_ADDR16_HA .rodata.str1.4 0000033e R_PPC_ADDR16_LO .rodata.str1.4 00000340 R_PPC_REL24 printk 00000352 R_PPC_ADDR16_LO .sbss+0x00000004 000003ac R_PPC_REL24 preempt_schedule 000003b4 R_PPC_REL24 preempt_schedule 00000402 R_PPC_ADDR16_HA .sbss+0x00000010 00000406 R_PPC_ADDR16_HA .sbss+0x00000010 0000040a R_PPC_ADDR16_LO .sbss+0x00000010 00000412 R_PPC_ADDR16_HA .sbss+0x00000004 0000041a R_PPC_ADDR16_LO .sbss+0x00000004 00000476 R_PPC_ADDR16_LO .sbss+0x00000010 0000047a R_PPC_ADDR16_LO .sbss+0x00000010 00000486 R_PPC_ADDR16_HA .sbss+0x00000004 0000048c R_PPC_REL24 msleep_interruptible 000004a2 R_PPC_ADDR16_HA .rodata.str1.4 000004a6 R_PPC_ADDR16_LO .rodata.str1.4 000004c6 R_PPC_ADDR16_LO .sbss+0x00000010 000004ca R_PPC_ADDR16_LO .sbss+0x00000010 000004da R_PPC_ADDR16_LO .sbss+0x00000004 000004ec R_PPC_REL24 msleep_interruptible 00000502 R_PPC_ADDR16_HA .rodata.str1.4 00000506 R_PPC_ADDR16_LO .rodata.str1.4 0000050c R_PPC_REL24 printk 0000051e R_PPC_ADDR16_LO .sbss+0x00000004 00000538 R_PPC_REL24 send_sig 0000059e R_PPC_ADDR16_HA .rodata.str1.4 000005a2 R_PPC_ADDR16_LO .rodata.str1.4 000005a4 R_PPC_REL24 printk 000005b6 R_PPC_ADDR16_HA .sbss+0x00000004 000005ba R_PPC_ADDR16_LO .sbss+0x00000004 000005ce R_PPC_ADDR16_HA .rodata.str1.4+0x00000024 000005d2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000024 000005d4 R_PPC_REL24 printk 0000060e R_PPC_ADDR16_HA .sbss 00000616 R_PPC_ADDR16_LO .sbss 0000062e R_PPC_ADDR16_HA .sbss+0x00000010 00000636 R_PPC_ADDR16_LO .sbss+0x00000010 00000642 R_PPC_ADDR16_LO .sbss+0x00000010 00000666 R_PPC_ADDR16_LO .sbss 0000066e R_PPC_ADDR16_HA .rodata 00000676 R_PPC_ADDR16_HA .rodata.str1.4+0x00000040 0000067a R_PPC_ADDR16_LO .rodata.str1.4+0x00000040 0000067e R_PPC_ADDR16_LO .rodata 00000684 R_PPC_REL24 printk 000006a6 R_PPC_ADDR16_HA .sbss+0x00000004 000006aa R_PPC_ADDR16_LO .sbss+0x00000004 000006ba R_PPC_ADDR16_HA .sbss 000006c2 R_PPC_ADDR16_LO .sbss 000006d6 R_PPC_ADDR16_HA .rodata.str1.4+0x00000074 000006da R_PPC_ADDR16_LO .sbss 000006e2 R_PPC_ADDR16_HA .rodata+0x00000010 000006e6 R_PPC_ADDR16_LO .rodata.str1.4+0x00000074 000006ea R_PPC_ADDR16_LO .rodata+0x00000010 000006f0 R_PPC_REL24 printk RELOCATION RECORDS FOR [.init.text]: OFFSET TYPE VALUE 0000000e R_PPC_ADDR16_HA .rodata.str1.4+0x000000a8 00000016 R_PPC_ADDR16_HA .rodata+0x00000024 0000001a R_PPC_ADDR16_HA .rodata.str1.4+0x000000b0 0000001e R_PPC_ADDR16_HA .rodata.str1.4+0x000000bc 00000022 R_PPC_ADDR16_HA .rodata.str1.4+0x000000c8 00000026 R_PPC_ADDR16_LO .rodata.str1.4+0x000000a8 0000002a R_PPC_ADDR16_LO .rodata.str1.4+0x000000b0 0000002e R_PPC_ADDR16_LO .rodata.str1.4+0x000000bc 00000032 R_PPC_ADDR16_LO .rodata+0x00000024 0000003a R_PPC_ADDR16_LO .rodata.str1.4+0x000000c8 0000003e R_PPC_ADDR16_HA .rodata.str1.4+0x00000110 00000040 R_PPC_REL24 printk 00000046 R_PPC_ADDR16_LO .rodata.str1.4+0x00000110 00000048 R_PPC_REL24 __symbol_get 00000056 R_PPC_ADDR16_HA pRsdpqXHwCtrl 0000005a R_PPC_ADDR16_LO pRsdpqXHwCtrl 0000005e R_PPC_ADDR16_HA .sbss+0x00000008 00000062 R_PPC_ADDR16_HA .rodata.str1.4+0x00000120 0000006a R_PPC_ADDR16_LO .rodata+0x00000024 00000072 R_PPC_ADDR16_LO .sbss+0x00000008 00000076 R_PPC_ADDR16_LO .rodata.str1.4+0x00000120 0000007e R_PPC_ADDR16_HA .sbss+0x0000000c 00000086 R_PPC_ADDR16_LO .sbss+0x0000000c 00000088 R_PPC_REL24 printk 00000090 R_PPC_REL24 .text+0x0000005c 000000a8 R_PPC_REL24 .text 000000b4 R_PPC_REL24 .text 000000bc R_PPC_REL24 .text+0x0000005c 000000c2 R_PPC_ADDR16_HA .sbss+0x00000010 000000c6 R_PPC_ADDR16_LO .sbss+0x00000010 000000cc R_PPC_REL24 .text+0x0000005c 000000d2 R_PPC_ADDR16_LO .sbss+0x00000010 000000e0 R_PPC_REL24 .text 000000e8 R_PPC_REL24 .text+0x0000005c 00000100 R_PPC_REL24 .text 0000010c R_PPC_REL24 .text 00000112 R_PPC_ADDR16_HA .sbss+0x00000010 00000118 R_PPC_REL24 .text+0x0000005c 0000011e R_PPC_ADDR16_LO .sbss+0x00000010 00000128 R_PPC_REL24 .text+0x0000005c 00000138 R_PPC_REL24 .text 0000013e R_PPC_ADDR16_HA .rodata.str1.4+0x00000160 00000142 R_PPC_ADDR16_HA .bss 00000146 R_PPC_ADDR16_LO .rodata.str1.4+0x00000160 0000014a R_PPC_ADDR16_HA .data 0000014e R_PPC_ADDR16_LO .bss 00000152 R_PPC_ADDR16_LO .data 00000166 R_PPC_ADDR16_LO .bss 00000168 R_PPC_REL24 misc_register 00000176 R_PPC_ADDR16_LO .rodata.str1.4+0x00000110 00000178 R_PPC_REL24 __symbol_put 0000017e R_PPC_ADDR16_HA .rodata.str1.4+0x00000168 00000182 R_PPC_ADDR16_LO .rodata+0x00000024 0000018a R_PPC_ADDR16_LO .rodata.str1.4+0x00000168 00000190 R_PPC_REL24 printk 00000196 R_PPC_ADDR16_HA .rodata.str1.4+0x000001a8 0000019a R_PPC_ADDR16_LO .rodata.str1.4+0x000001a8 0000019e R_PPC_ADDR16_LO .rodata+0x00000024 000001a4 R_PPC_REL24 printk 000001c2 R_PPC_ADDR16_HA .rodata.str1.4+0x000001e0 000001c6 R_PPC_ADDR16_LO .rodata.str1.4+0x000001e0 000001ca R_PPC_ADDR16_LO .rodata+0x00000024 000001d6 R_PPC_ADDR16_HA .rodata.str1.4+0x00000210 000001da R_PPC_ADDR16_LO .rodata+0x00000024 000001e2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000210 000001e4 R_PPC_REL24 printk 000001ea R_PPC_ADDR16_HA .rodata.str1.4+0x00000248 000001ee R_PPC_ADDR16_LO .rodata.str1.4+0x00000248 000001f2 R_PPC_ADDR16_LO .rodata+0x00000024 000001f8 R_PPC_REL24 printk RELOCATION RECORDS FOR [.exit.text]: OFFSET TYPE VALUE 0000000e R_PPC_ADDR16_HA .rodata.str1.4+0x000000a8 00000012 R_PPC_ADDR16_HA .rodata+0x00000034 0000001a R_PPC_ADDR16_HA .rodata.str1.4+0x000000b0 0000001e R_PPC_ADDR16_HA .rodata.str1.4+0x000000bc 00000022 R_PPC_ADDR16_HA .rodata.str1.4+0x00000280 00000026 R_PPC_ADDR16_LO .rodata+0x00000034 0000002e R_PPC_ADDR16_LO .rodata.str1.4+0x000000a8 00000032 R_PPC_ADDR16_LO .rodata.str1.4+0x000000b0 00000036 R_PPC_ADDR16_LO .rodata.str1.4+0x000000bc 0000003a R_PPC_ADDR16_LO .rodata.str1.4+0x00000280 0000003c R_PPC_REL24 printk 00000042 R_PPC_ADDR16_HA .rodata.str1.4+0x00000110 00000046 R_PPC_ADDR16_LO .rodata.str1.4+0x00000110 00000048 R_PPC_REL24 __symbol_put 0000004e R_PPC_ADDR16_HA .bss 00000052 R_PPC_ADDR16_LO .bss 00000054 R_PPC_REL24 misc_deregister 0000005a R_PPC_ADDR16_LO .rodata+0x00000034 00000062 R_PPC_ADDR16_HA .rodata.str1.4+0x000002cc 00000066 R_PPC_ADDR16_LO .rodata.str1.4+0x000002cc 00000072 R_PPC_ADDR16_HA .rodata.str1.4+0x0000030c 00000076 R_PPC_ADDR16_LO .rodata.str1.4+0x0000030c 0000007a R_PPC_ADDR16_LO .rodata+0x00000034 00000080 R_PPC_REL24 printk RELOCATION RECORDS FOR [.data]: OFFSET TYPE VALUE 00000000 R_PPC_ADDR32 __this_module 00000008 R_PPC_ADDR32 .text+0x000000f8 00000010 R_PPC_ADDR32 .text+0x000003c0 00000020 R_PPC_ADDR32 .text+0x000005f8 00000030 R_PPC_ADDR32 .text+0x00000600 00000038 R_PPC_ADDR32 .text+0x000006b0 RELOCATION RECORDS FOR [.gnu.linkonce.this_module]: OFFSET TYPE VALUE 000000a4 R_PPC_ADDR32 init_module 0000010c R_PPC_ADDR32 cleanup_module >strings cbcc.ko Z.9? <| Z <})Z H}}[xH }c[x cbcc_drv_open cbcc_drv_release cbcc_drv_init cbcc_drv_exit description= LKM providing a bidirectional communication interface over circular buffers between the PPC and the CMU/DOS author= -* Copyright (c) 2002-2005 Rohde & Schwarz **********- -* Vlad Perianu, Waldemar Bittner, Hartmut Schaefer - 1CM2 *- license=GPL depends= vermagic=2.6.12.6-elinos-226-rsdpq2 preempt gcc-3.4 CTRL_C from CBCC channel received CTRL_C signal received <3>cbcc: %-13s [%4d]: pid=%d opened,now %d users <3>cbcc: %-13s [%4d]: pid=%d closed,now %d users V2.1 11:08:33 Sep 28 2007 <3>cbcc: %-13s [%4d]: Installing CBCC driver -> %s [build %s - %s] pRsdpqXHwCtrl <3>cbcc: %-13s [%4d]: DPRAM mapped to 0x%08X [size = 0x%X] cbcc <3>cbcc: %-13s [%4d]: Can't register CBCC device: /dev/misc/%s <3>cbcc: %-13s [%4d]: Can't install CBCC driver ! <3>cbcc: %-13s [%4d]: CBCC driver installed <3>cbcc: %-13s [%4d]: PB-FPGA driver not installed ! <3>cbcc: %-13s [%4d]: Please load PB-FPGA LKM first. <3>cbcc: %-13s [%4d]: Uninstalling the CBCC driver -> %s [build %s - %s] <3>cbcc: %-13s [%4d]: CBCC driver uninstalled with errors <3>cbcc: %-13s [%4d]: CBCC driver uninstalled cbcc GCC: (GNU) 3.4.4 (ELinOS V4.0 3.4.4-14 2005-12-05) GCC: (GNU) 3.4.4 (ELinOS V4.0 3.4.4-14 2005-12-05) .symtab .strtab .shstrtab .rela.text .rela.init.text .rela.exit.text .rodata .modinfo .rodata.str1.4 .rela.data .rela.gnu.linkonce.this_module .sbss .bss .init.plt .comment .note.GNU-stack cbcc_drv.c cbcc_drv_init cbcc_drv_exit __mod_description137 __mod_author133 __mod_license1966 cbcc_drv_fops cbcc_drv_read cbcc_drv_write cbcc_drv_ioctl cbcc_drv_open cbcc_drv_release ModUseCount shell_pid safe_write_dpram_offs dpram_start safe_read_dpram_offs cbccShadowChannel __PRETTY_FUNCTION__.3 __PRETTY_FUNCTION__.2 __PRETTY_FUNCTION__.1 dpram_size cbcc_dev __PRETTY_FUNCTION__.0 Cbcc_Drv_Mutex cbcc.mod.c __module_depends __mod_vermagic5 misc_deregister pRsdpqXHwCtrl __this_module __symbol_put cleanup_module msleep_interruptible init_module __symbol_get preempt_schedule printk misc_register send_sig >objdump -x pbfpga.ko pbfpga.ko: file format elf32-powerpc pbfpga.ko architecture: powerpc:common, flags 0x00000011: HAS_RELOC, HAS_SYMS start address 0x00000000 Sections: Idx Name Size VMA LMA File off Algn 0 .text 00002538 00000000 00000000 00000034 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 1 .init.text 00000d48 00000000 00000000 0000256c 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 2 .exit.text 00000218 00000000 00000000 000032b4 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 3 .rodata 00000084 00000000 00000000 000034cc 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 4 .modinfo 000002f4 00000000 00000000 00003550 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 5 .rodata.str1.4 00000a48 00000000 00000000 00003844 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 6 __ksymtab 00000008 00000000 00000000 0000428c 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA 7 __ksymtab_strings 00000010 00000000 00000000 00004294 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 8 __ex_table 00000030 00000000 00000000 000042a4 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, DATA 9 .fixup 00000040 00000000 00000000 000042d4 2**0 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 10 .data 000004a8 00000000 00000000 00004314 2**2 CONTENTS, ALLOC, LOAD, RELOC, DATA 11 __obsparm 00000200 00000000 00000000 000047bc 2**2 CONTENTS, ALLOC, LOAD, RELOC, DATA 12 .gnu.linkonce.this_module 00000140 00000000 00000000 000049c0 2**5 CONTENTS, ALLOC, LOAD, RELOC, DATA, LINK_ONCE_DISCARD 13 .sbss 0000002c 00000000 00000000 00004b00 2**2 ALLOC 14 .plt 00000000 00000000 00000000 00004b00 2**3 ALLOC, READONLY, CODE 15 .bss 00000278 00000000 00000000 00004b00 2**2 ALLOC 16 .init.plt 00000000 00000000 00000000 00004b00 2**3 ALLOC, READONLY, CODE 17 .comment 00000068 00000000 00000000 00004b00 2**0 CONTENTS, READONLY 18 .note.GNU-stack 00000000 00000000 00000000 00004b68 2**0 CONTENTS, READONLY SYMBOL TABLE: 00000000 l d .text 00000000 .text 00000000 l d *ABS* 00000000 .rela.text 00000000 l d .init.text 00000000 .init.text 00000000 l d *ABS* 00000000 .rela.init.text 00000000 l d .exit.text 00000000 .exit.text 00000000 l d *ABS* 00000000 .rela.exit.text 00000000 l d .rodata 00000000 .rodata 00000000 l d .modinfo 00000000 .modinfo 00000000 l d .rodata.str1.4 00000000 .rodata.str1.4 00000000 l d __ksymtab 00000000 __ksymtab 00000000 l d *ABS* 00000000 .rela__ksymtab 00000000 l d __ksymtab_strings 00000000 __ksymtab_strings 00000000 l d __ex_table 00000000 __ex_table 00000000 l d *ABS* 00000000 .rela__ex_table 00000000 l d .fixup 00000000 .fixup 00000000 l d *ABS* 00000000 .rela.fixup 00000000 l d .data 00000000 .data 00000000 l d *ABS* 00000000 .rela.data 00000000 l d __obsparm 00000000 __obsparm 00000000 l d *ABS* 00000000 .rela__obsparm 00000000 l d .gnu.linkonce.this_module 00000000 .gnu.linkonce.this_module 00000000 l d *ABS* 00000000 .rela.gnu.linkonce.this_module 00000000 l d .sbss 00000000 .sbss 00000000 l d .plt 00000000 .plt 00000000 l d .bss 00000000 .bss 00000000 l d .init.plt 00000000 .init.plt 00000000 l d .comment 00000000 .comment 00000000 l d .note.GNU-stack 00000000 .note.GNU-stack 00000000 l d *ABS* 00000000 .shstrtab 00000000 l d *ABS* 00000000 .symtab 00000000 l d *ABS* 00000000 .strtab 00000000 l df *ABS* 00000000 pbfpgadrv.c 000009a0 l F .text 0000018c PbFpgaProcReadPlatform 0000089c l F .text 00000104 PbFpgaProcReadServerIp 00000770 l F .text 0000012c PbFpgaProcReadClientIp 000002d0 l F .text 00000318 PbFpgaProcReadAll 000005e8 l F .text 0000014c PbFpgaProcWriteAll 000001a4 l F .text 000000a8 PbFpgaMbxSemTaskletFct 00000000 l O .modinfo 00000045 __mod_cpld_waits176 00000048 l O .modinfo 0000004a __mod_dpram_ext_waits175 00000094 l O .modinfo 00000046 __mod_dpram_waits174 000000dc l O .modinfo 00000044 __mod_reg_waits173 00000120 l O .modinfo 0000003d __mod_devname167 00000160 l O .modinfo 0000001b __mod_dpram_ext_waitstype164 00000000 l F .text 00000004 MODULE_PARM_ 0000017c l O .modinfo 00000017 __mod_dpram_waitstype163 00000194 l O .modinfo 00000015 __mod_reg_waitstype162 000001ac l O .modinfo 00000013 __mod_devnametype158 000001c0 l O .modinfo 00000080 __mod_description155 00000240 l O .modinfo 00000065 __mod_author152 00000000 l O __ksymtab 00000008 __ksymtab_pRsdpqXHwCtrl 00000000 l O __ksymtab_strings 0000000e __kstrtab_pRsdpqXHwCtrl 000002a8 l O .modinfo 0000000c __mod_license1966 00000004 l O .sbss 00000004 MbxIrqDisable 00000008 l O .sbss 00000004 cpld_waits 000001d4 l O .data 00000004 dpram_ext_waits 000001d8 l O .data 00000004 dpram_waits 000001dc l O .data 00000004 reg_waits 000001e0 l O .data 00000004 devname 0000000c l O .sbss 00000004 isCRTUrsdpq2 000001e4 l O .data 00000217 buildinfo 000003fb l O .data 00000040 IPAddr 00000010 l O .sbss 00000004 MbxFtEvt 00000014 l O .sbss 00000004 MbxIrqEnable 0000043c l O .data 0000006c PbFpgaFileOps 00000bcc l F .text 0000003c PbFpgaRead 00000c08 l F .text 0000003c PbFpgaWrite 00000e08 l F .text 00001440 PbFpgaUnlockedIoctl 00000c44 l F .text 000001c4 PbFpgaMmap 00002248 l F .text 0000016c PbFpgaOpen 000023b4 l F .text 00000184 PbFpgaClose 00000018 l O .sbss 00000004 FtIrqEnable 0000001c l O .sbss 00000004 ModUseCount 00000020 l O .sbss 00000004 IrqStat.6 00000004 l F .text 000001a0 PbFpgaIsr 00000024 l O .sbss 00000004 pPbFpgaCtrl 0000024c l F .text 00000084 PbFpgaMbxIsr 00000000 l O .rodata 00000011 __PRETTY_FUNCTION__.2 00000028 l O .sbss 00000004 pProcOutBuffer 00000014 l O .rodata 00000013 __PRETTY_FUNCTION__.0 00000000 l O .bss 00000100 ProcInBuffer.1 00000734 l F .text 0000003c PbFpgaProcOutIp 00000b2c l F .text 000000a0 PbFpgaReset 00000028 l O .rodata 0000000b __PRETTY_FUNCTION__.11 00000034 l O .rodata 0000000c __PRETTY_FUNCTION__.10 00000040 l O .rodata 0000000b __PRETTY_FUNCTION__.7 0000004c l O .rodata 00000014 __PRETTY_FUNCTION__.8 00000100 l O .bss 0000011c MbxStat.9 00000060 l O .rodata 0000000b __PRETTY_FUNCTION__.5 0000006c l O .rodata 0000000c __PRETTY_FUNCTION__.4 00000078 l O .rodata 0000000b __PRETTY_FUNCTION__.3 0000021c l O .bss 0000005c PbFpgaDev 00000000 l df *ABS* 00000000 pbfpga.mod.c 000002b4 l O .modinfo 00000009 __module_depends 000002c0 l O .modinfo 00000034 __mod_vermagic5 00000000 *UND* 00000000 strcpy 00000000 *UND* 00000000 free_irq 00000180 g O __obsparm 00000080 __parm_devname 00000080 g O __obsparm 00000080 __parm_dpram_waits 00000000 *UND* 00000000 misc_deregister 00000000 g F .exit.text 00000218 PbFpgaCleanup 00000000 g O .sbss 00000004 pRsdpqXHwCtrl 00000000 g O .gnu.linkonce.this_module 00000140 __this_module 00000144 g O .data 0000006c PbFpgaProcFileOpsAll 000001b0 g O .data 00000014 PbFpgaMbxSemTasklet 00000000 *UND* 00000000 iounmap 00000000 g F .exit.text 00000218 cleanup_module 00000000 *UND* 00000000 memcpy 00000000 *UND* 00000000 remap_pfn_range 00000000 g O .data 0000006c PbFpgaProcFileOpsPlatform 00000000 *UND* 00000000 kfree 00000000 *UND* 00000000 enable_irq 00000000 *UND* 00000000 __wake_up 00000000 g F .init.text 00000d48 init_module 00000000 *UND* 00000000 create_proc_entry 00000000 *UND* 00000000 schedule 00000000 *UND* 00000000 request_irq 00000000 *UND* 00000000 kmem_cache_alloc 00000000 *UND* 00000000 strcat 00000000 *UND* 00000000 preempt_schedule 00000000 *UND* 00000000 strstr 00000000 *UND* 00000000 ioremap 000000d8 g O .data 0000006c PbFpgaProcFileOpsClientIp 00000000 *UND* 00000000 printk 00000000 *UND* 00000000 __copy_tofrom_user 000001c4 g O .data 00000010 szTimeStat 00000000 *UND* 00000000 _ctype 00000000 *UND* 00000000 proc_mkdir 00000000 *UND* 00000000 memset 00000000 *UND* 00000000 misc_register 00000000 g O __obsparm 00000080 __parm_dpram_ext_waits 00000000 *UND* 00000000 strcmp 00000000 *UND* 00000000 sprintf 00000000 *UND* 00000000 remove_proc_entry 00000000 *UND* 00000000 interruptible_sleep_on 00000000 *UND* 00000000 __tasklet_hi_schedule 00000000 *UND* 00000000 malloc_sizes 00000000 g F .init.text 00000d48 PbFpgaInit 00000100 g O __obsparm 00000080 __parm_reg_waits 00000000 *UND* 00000000 __down_interruptible 00000000 *UND* 00000000 strlen 0000006c g O .data 0000006c PbFpgaProcFileOpsServerIp 00000000 *UND* 00000000 disable_irq RELOCATION RECORDS FOR [.text]: OFFSET TYPE VALUE 00000012 R_PPC_ADDR16_HA .sbss+0x00000024 0000001a R_PPC_ADDR16_LO .sbss+0x00000024 0000001e R_PPC_ADDR16_HA .sbss+0x0000000c 00000022 R_PPC_ADDR16_LO .sbss+0x0000000c 0000002e R_PPC_ADDR16_HA .sbss+0x00000020 0000003a R_PPC_ADDR16_LO .sbss+0x00000020 0000004a R_PPC_ADDR16_LO .sbss+0x00000020 000000e6 R_PPC_ADDR16_LO .sbss+0x00000024 000000ea R_PPC_ADDR16_LO .sbss+0x0000000c 00000102 R_PPC_ADDR16_LO .sbss+0x00000020 0000010a R_PPC_ADDR16_LO .sbss+0x00000024 00000114 R_PPC_REL24 __wake_up 0000011e R_PPC_ADDR16_LO .sbss+0x00000024 00000126 R_PPC_ADDR16_LO .sbss+0x0000000c 00000142 R_PPC_ADDR16_LO .sbss+0x00000020 0000014a R_PPC_ADDR16_LO .sbss+0x00000024 00000150 R_PPC_REL24 __wake_up 00000156 R_PPC_ADDR16_LO .sbss+0x00000024 0000015a R_PPC_ADDR16_HA .sbss+0x00000010 0000015e R_PPC_ADDR16_LO .sbss+0x00000010 00000198 R_PPC_REL24 __wake_up 000001ae R_PPC_ADDR16_HA .sbss+0x00000004 000001b6 R_PPC_ADDR16_LO .sbss+0x00000004 000001e2 R_PPC_ADDR16_HA .sbss+0x00000024 000001e6 R_PPC_ADDR16_LO .sbss+0x00000024 00000230 R_PPC_REL24 disable_irq 00000238 R_PPC_REL24 __wake_up 00000256 R_PPC_ADDR16_HA .sbss+0x00000024 0000025e R_PPC_ADDR16_HA .sbss+0x0000000c 00000262 R_PPC_ADDR16_LO .sbss+0x00000024 0000026a R_PPC_ADDR16_LO .sbss+0x0000000c 0000026e R_PPC_ADDR16_HA PbFpgaMbxSemTasklet 00000276 R_PPC_ADDR16_LO PbFpgaMbxSemTasklet 000002c4 R_PPC_REL24 __tasklet_hi_schedule 000002de R_PPC_ADDR16_HA .sbss+0x00000028 000002e6 R_PPC_ADDR16_LO .sbss+0x00000028 00000308 R_PPC_REL24 memset 0000030e R_PPC_ADDR16_HA .rodata.str1.4+0x0000004c 00000312 R_PPC_ADDR16_HA .sbss+0x00000024 0000031a R_PPC_ADDR16_LO .rodata.str1.4+0x0000004c 0000031c R_PPC_REL24 sprintf 00000322 R_PPC_ADDR16_LO .sbss+0x00000024 00000326 R_PPC_ADDR16_HA .rodata.str1.4+0x00000050 0000032e R_PPC_ADDR16_LO .rodata.str1.4+0x00000050 00000338 R_PPC_REL24 sprintf 0000033e R_PPC_ADDR16_LO .sbss+0x00000024 00000346 R_PPC_ADDR16_LO .rodata.str1.4+0x00000050 00000350 R_PPC_REL24 sprintf 00000356 R_PPC_ADDR16_HA .rodata.str1.4+0x00000054 0000035e R_PPC_ADDR16_HA .data+0x000001e4 00000362 R_PPC_ADDR16_LO .rodata.str1.4+0x00000054 00000366 R_PPC_ADDR16_LO .data+0x000001e4 0000036c R_PPC_REL24 sprintf 00000372 R_PPC_ADDR16_LO .sbss+0x00000024 0000037e R_PPC_ADDR16_HA .rodata.str1.4+0x00000058 00000382 R_PPC_ADDR16_LO .rodata.str1.4+0x00000058 00000388 R_PPC_REL24 sprintf 0000038e R_PPC_ADDR16_HA .sbss+0x0000000c 00000392 R_PPC_ADDR16_LO .sbss+0x00000024 0000039a R_PPC_ADDR16_LO .sbss+0x0000000c 000003a6 R_PPC_ADDR16_HA .rodata.str1.4+0x00000094 000003b2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000094 000003c0 R_PPC_REL24 sprintf 000003c6 R_PPC_ADDR16_LO .sbss+0x00000024 000003ca R_PPC_ADDR16_LO .sbss+0x0000000c 000003e2 R_PPC_ADDR16_HA .rodata.str1.4+0x000000e8 000003ea R_PPC_ADDR16_LO .rodata.str1.4+0x000000e8 000003f4 R_PPC_REL24 sprintf 000003fa R_PPC_ADDR16_LO .sbss+0x00000024 00000406 R_PPC_ADDR16_HA .rodata.str1.4+0x00000140 0000040a R_PPC_ADDR16_LO .rodata.str1.4+0x00000140 00000410 R_PPC_REL24 sprintf 00000416 R_PPC_ADDR16_LO .sbss+0x00000024 00000422 R_PPC_ADDR16_HA .rodata.str1.4+0x0000017c 00000426 R_PPC_ADDR16_LO .rodata.str1.4+0x0000017c 0000042c R_PPC_REL24 sprintf 00000432 R_PPC_ADDR16_LO .sbss+0x00000024 0000043e R_PPC_ADDR16_HA .rodata.str1.4+0x000001b8 00000442 R_PPC_ADDR16_LO .rodata.str1.4+0x000001b8 00000448 R_PPC_REL24 sprintf 0000044e R_PPC_ADDR16_LO .sbss+0x00000024 0000045a R_PPC_ADDR16_HA .rodata.str1.4+0x000001f4 0000045e R_PPC_ADDR16_LO .rodata.str1.4+0x000001f4 00000464 R_PPC_REL24 sprintf 0000046a R_PPC_ADDR16_LO .sbss+0x00000024 0000046e R_PPC_ADDR16_LO .sbss+0x0000000c 00000482 R_PPC_ADDR16_HA .rodata.str1.4+0x00000230 00000492 R_PPC_ADDR16_LO .rodata.str1.4+0x00000230 000004a0 R_PPC_REL24 sprintf 000004a6 R_PPC_ADDR16_HA .data+0x000001e0 000004aa R_PPC_ADDR16_HA .data+0x000001dc 000004ae R_PPC_ADDR16_LO .data+0x000001e0 000004b2 R_PPC_ADDR16_HA .data+0x000001d8 000004b6 R_PPC_ADDR16_LO .data+0x000001dc 000004ba R_PPC_ADDR16_LO .data+0x000001d8 000004be R_PPC_ADDR16_HA .data+0x000001d4 000004c2 R_PPC_ADDR16_HA .sbss+0x00000008 000004c6 R_PPC_ADDR16_LO .data+0x000001d4 000004ce R_PPC_ADDR16_LO .sbss+0x00000008 000004da R_PPC_ADDR16_HA .rodata.str1.4+0x00000250 000004e2 R_PPC_ADDR16_HA .rodata.str1.4+0x00000044 000004ee R_PPC_ADDR16_LO .rodata.str1.4+0x00000044 000004fa R_PPC_ADDR16_LO .rodata.str1.4+0x00000250 00000504 R_PPC_REL24 sprintf 0000050a R_PPC_ADDR16_LO .sbss+0x00000028 00000590 R_PPC_REL24 memcpy 000005f6 R_PPC_ADDR16_HA .bss 000005fe R_PPC_ADDR16_LO .bss 0000061c R_PPC_REL24 memcpy 00000622 R_PPC_ADDR16_HA .rodata.str1.4+0x000002b8 00000626 R_PPC_ADDR16_LO .rodata.str1.4+0x000002b8 00000638 R_PPC_REL24 strlen 00000670 R_PPC_REL24 strstr 00000686 R_PPC_ADDR16_HA _ctype 00000692 R_PPC_ADDR16_LO _ctype 000006ce R_PPC_ADDR16_HA .rodata.str1.4+0x000002c0 000006d2 R_PPC_ADDR16_HA .rodata+0x00000014 000006da R_PPC_ADDR16_LO .rodata.str1.4+0x000002c0 000006de R_PPC_ADDR16_LO .rodata+0x00000014 000006e8 R_PPC_REL24 printk 000006ee R_PPC_ADDR16_HA .sbss+0x00000004 000006f2 R_PPC_ADDR16_HA .rodata.str1.4+0x000002d8 000006f8 R_PPC_REL24 printk 0000070e R_PPC_ADDR16_LO .sbss+0x00000004 00000716 R_PPC_ADDR16_LO .rodata.str1.4+0x000002d8 00000722 R_PPC_ADDR16_LO .sbss+0x00000004 00000726 R_PPC_ADDR16_HA .rodata.str1.4+0x00000304 0000072a R_PPC_ADDR16_LO .rodata.str1.4+0x00000304 0000072c R_PPC_REL24 printk 00000736 R_PPC_ADDR16_HA .data+0x000003fb 0000073e R_PPC_ADDR16_LO .data+0x000003fb 00000758 R_PPC_REL24 strlen 00000870 R_PPC_REL24 memcpy 00000948 R_PPC_REL24 memcpy 000009b2 R_PPC_ADDR16_HA .sbss+0x00000024 000009b6 R_PPC_ADDR16_LO .sbss+0x00000024 000009ba R_PPC_ADDR16_HA .rodata.str1.4+0x0000034c 000009d2 R_PPC_ADDR16_LO .rodata.str1.4+0x0000034c 000009e2 R_PPC_ADDR16_HA .rodata.str1.4+0x00000354 000009e6 R_PPC_ADDR16_LO .rodata.str1.4+0x00000354 000009f4 R_PPC_REL24 strcpy 000009fa R_PPC_ADDR16_LO .sbss+0x00000024 000009fe R_PPC_ADDR16_HA .rodata.str1.4+0x0000035c 00000a06 R_PPC_ADDR16_LO .rodata.str1.4+0x0000035c 00000a12 R_PPC_ADDR16_HA .rodata.str1.4+0x00000368 00000a16 R_PPC_ADDR16_LO .rodata.str1.4+0x00000368 00000a1c R_PPC_REL24 strcat 00000a24 R_PPC_REL24 strlen 00000ace R_PPC_ADDR16_HA .rodata.str1.4+0x00000374 00000ad2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000374 00000b00 R_PPC_REL24 memcpy 00000b2e R_PPC_ADDR16_HA .sbss+0x00000024 00000b32 R_PPC_ADDR16_LO .sbss+0x00000024 00000b36 R_PPC_ADDR16_HA .sbss+0x0000000c 00000b3a R_PPC_ADDR16_LO .sbss+0x0000000c 00000b56 R_PPC_ADDR16_LO .sbss+0x00000024 00000b5e R_PPC_ADDR16_LO .sbss+0x0000000c 00000b76 R_PPC_ADDR16_LO .sbss+0x0000000c 00000b7a R_PPC_ADDR16_LO .sbss+0x00000024 00000b92 R_PPC_ADDR16_LO .sbss+0x00000024 00000b96 R_PPC_ADDR16_LO .sbss+0x0000000c 00000bb2 R_PPC_ADDR16_LO .sbss+0x00000024 00000bba R_PPC_ADDR16_LO .sbss+0x0000000c 00000bd2 R_PPC_ADDR16_HA .rodata.str1.4+0x0000037c 00000bd6 R_PPC_ADDR16_HA .rodata+0x00000028 00000be6 R_PPC_ADDR16_LO .rodata.str1.4+0x0000037c 00000bea R_PPC_ADDR16_LO .rodata+0x00000028 00000bf0 R_PPC_REL24 printk 00000c0e R_PPC_ADDR16_HA .rodata.str1.4+0x0000037c 00000c12 R_PPC_ADDR16_HA .rodata+0x00000034 00000c22 R_PPC_ADDR16_LO .rodata.str1.4+0x0000037c 00000c26 R_PPC_ADDR16_LO .rodata+0x00000034 00000c2c R_PPC_REL24 printk 00000c56 R_PPC_ADDR16_HA .sbss+0x00000024 00000c5a R_PPC_ADDR16_LO .sbss+0x00000024 00000cf8 R_PPC_REL24 remap_pfn_range 00000d34 R_PPC_REL24 remap_pfn_range 00000d70 R_PPC_REL24 remap_pfn_range 00000dc4 R_PPC_REL24 remap_pfn_range 00000dda R_PPC_ADDR16_HA .rodata.str1.4+0x000003a4 00000dde R_PPC_ADDR16_HA .rodata+0x00000040 00000dea R_PPC_ADDR16_LO .rodata.str1.4+0x000003a4 00000dee R_PPC_ADDR16_LO .rodata+0x00000040 00000dfc R_PPC_REL24 printk 00000ed2 R_PPC_ADDR16_HA .sbss+0x00000024 00000ed6 R_PPC_ADDR16_LO .sbss+0x00000024 00000eda R_PPC_ADDR16_HA .sbss+0x0000000c 00000ede R_PPC_ADDR16_LO .sbss+0x0000000c 00000f10 R_PPC_REL24 preempt_schedule 00000f1a R_PPC_ADDR16_HA .sbss+0x00000014 00000f1e R_PPC_ADDR16_LO .sbss+0x00000014 00000f2a R_PPC_ADDR16_HA .sbss+0x00000024 00000f2e R_PPC_ADDR16_LO .sbss+0x00000024 00000f5a R_PPC_ADDR16_LO .sbss+0x00000014 00000f5e R_PPC_ADDR16_HA .sbss+0x00000010 00000f62 R_PPC_ADDR16_LO .sbss+0x00000010 00000f7e R_PPC_ADDR16_LO .sbss+0x00000024 00000fa2 R_PPC_ADDR16_HA .sbss+0x00000014 00000fa6 R_PPC_ADDR16_LO .sbss+0x00000014 00000fb2 R_PPC_ADDR16_HA .sbss+0x00000024 00000fb6 R_PPC_ADDR16_LO .sbss+0x00000024 00000fe2 R_PPC_ADDR16_LO .sbss+0x00000014 00000ff6 R_PPC_ADDR16_HA .sbss+0x00000024 00000ffa R_PPC_ADDR16_LO .sbss+0x00000024 00001034 R_PPC_REL24 __wake_up 0000103e R_PPC_ADDR16_HA .sbss+0x00000004 00001042 R_PPC_ADDR16_LO .sbss+0x00000004 00001064 R_PPC_REL24 enable_irq 0000106e R_PPC_ADDR16_HA .sbss+0x00000004 00001072 R_PPC_ADDR16_LO .sbss+0x00000004 00001094 R_PPC_REL24 enable_irq 000010cc R_PPC_REL24 __copy_tofrom_user 000010ea R_PPC_ADDR16_HA .sbss+0x00000024 000010ee R_PPC_ADDR16_HA .sbss+0x0000000c 000010f2 R_PPC_ADDR16_LO .sbss+0x00000024 000010f6 R_PPC_ADDR16_LO .sbss+0x0000000c 00001144 R_PPC_REL24 __copy_tofrom_user 00001190 R_PPC_REL24 __copy_tofrom_user 0000129a R_PPC_ADDR16_HA .sbss+0x00000024 0000129e R_PPC_ADDR16_LO .sbss+0x00000024 000012a2 R_PPC_ADDR16_HA .sbss+0x0000000c 000012a6 R_PPC_ADDR16_LO .sbss+0x0000000c 000012f8 R_PPC_REL24 __copy_tofrom_user 00001342 R_PPC_ADDR16_HA .rodata.str1.4+0x000003ec 00001346 R_PPC_ADDR16_HA .rodata+0x0000004c 0000134a R_PPC_ADDR16_LO .rodata.str1.4+0x000003ec 0000134e R_PPC_ADDR16_LO .rodata+0x0000004c 00001354 R_PPC_REL24 printk 000013a6 R_PPC_ADDR16_HA .sbss+0x00000024 000013aa R_PPC_ADDR16_LO .sbss+0x00000024 000013ae R_PPC_ADDR16_HA .sbss+0x0000000c 000013b2 R_PPC_ADDR16_LO .sbss+0x0000000c 00001408 R_PPC_REL24 __copy_tofrom_user 00001416 R_PPC_ADDR16_HA .sbss+0x00000024 0000141a R_PPC_ADDR16_LO .sbss+0x00000024 00001428 R_PPC_REL24 interruptible_sleep_on 0000143e R_PPC_ADDR16_HA .sbss+0x00000018 00001442 R_PPC_ADDR16_LO .sbss+0x00000018 00001452 R_PPC_ADDR16_LO .sbss+0x00000024 000014b4 R_PPC_REL24 __copy_tofrom_user 000014cc R_PPC_REL24 __copy_tofrom_user 000014d4 R_PPC_REL24 __down_interruptible 0000151c R_PPC_REL24 __copy_tofrom_user 0000154e R_PPC_ADDR16_HA .sbss+0x00000024 00001556 R_PPC_ADDR16_HA .sbss+0x0000000c 0000155a R_PPC_ADDR16_LO .sbss+0x00000024 0000155e R_PPC_ADDR16_LO .sbss+0x0000000c 0000158a R_PPC_ADDR16_LO .sbss+0x0000000c 00001592 R_PPC_ADDR16_LO .sbss+0x00000024 000015ba R_PPC_ADDR16_LO .sbss+0x0000000c 000015be R_PPC_ADDR16_LO .sbss+0x00000024 000015fa R_PPC_ADDR16_HA .sbss+0x00000024 000015fe R_PPC_ADDR16_HA .sbss+0x0000000c 00001602 R_PPC_ADDR16_LO .sbss+0x00000024 00001606 R_PPC_ADDR16_LO .sbss+0x0000000c 00001634 R_PPC_REL24 __down_interruptible 0000167a R_PPC_ADDR16_HA .sbss+0x00000024 0000167e R_PPC_ADDR16_LO .sbss+0x00000024 00001682 R_PPC_ADDR16_HA .sbss+0x0000000c 00001686 R_PPC_ADDR16_LO .sbss+0x0000000c 000016ce R_PPC_ADDR16_HA .sbss+0x00000024 000016d2 R_PPC_ADDR16_LO .sbss+0x00000024 000016d6 R_PPC_ADDR16_HA .sbss+0x0000000c 000016da R_PPC_ADDR16_LO .sbss+0x0000000c 000017a6 R_PPC_ADDR16_HA .sbss+0x00000024 000017aa R_PPC_ADDR16_LO .sbss+0x00000024 000017ae R_PPC_ADDR16_HA .sbss+0x0000000c 000017b2 R_PPC_ADDR16_LO .sbss+0x0000000c 0000180a R_PPC_ADDR16_HA .sbss+0x00000024 0000180e R_PPC_ADDR16_LO .sbss+0x00000024 00001812 R_PPC_ADDR16_HA .sbss+0x0000000c 00001816 R_PPC_ADDR16_LO .sbss+0x0000000c 0000188a R_PPC_ADDR16_HA .sbss+0x00000024 0000188e R_PPC_ADDR16_LO .sbss+0x00000024 00001892 R_PPC_ADDR16_HA .sbss+0x0000000c 00001896 R_PPC_ADDR16_LO .sbss+0x0000000c 00001904 R_PPC_REL24 __copy_tofrom_user 00001964 R_PPC_REL24 __copy_tofrom_user 00001984 R_PPC_REL24 __copy_tofrom_user 00001a1c R_PPC_REL24 __copy_tofrom_user 00001a42 R_PPC_ADDR16_HA .sbss+0x00000024 00001a46 R_PPC_ADDR16_HA .sbss+0x0000000c 00001a4a R_PPC_ADDR16_LO .sbss+0x00000024 00001a4e R_PPC_ADDR16_LO .sbss+0x0000000c 00001afa R_PPC_ADDR16_HA .sbss+0x00000024 00001afe R_PPC_ADDR16_HA .sbss+0x0000000c 00001b02 R_PPC_ADDR16_LO .sbss+0x00000024 00001b06 R_PPC_ADDR16_LO .sbss+0x0000000c 00001b2e R_PPC_ADDR16_LO .sbss+0x00000024 00001b36 R_PPC_ADDR16_LO .sbss+0x0000000c 00001b98 R_PPC_REL24 __copy_tofrom_user 00001bba R_PPC_ADDR16_HA .sbss+0x00000024 00001bbe R_PPC_ADDR16_LO .sbss+0x00000024 00001bc2 R_PPC_ADDR16_HA .sbss+0x0000000c 00001bc6 R_PPC_ADDR16_LO .sbss+0x0000000c 00001bfe R_PPC_ADDR16_LO .sbss+0x00000024 00001c6c R_PPC_REL24 __copy_tofrom_user 00001c8e R_PPC_ADDR16_HA .sbss+0x00000024 00001c92 R_PPC_ADDR16_LO .sbss+0x00000024 00001cc8 R_PPC_REL24 __copy_tofrom_user 00001cf6 R_PPC_ADDR16_HA .sbss+0x00000024 00001cfa R_PPC_ADDR16_LO .sbss+0x00000024 00001cfe R_PPC_ADDR16_HA .sbss+0x0000000c 00001d02 R_PPC_ADDR16_LO .sbss+0x0000000c 00001d34 R_PPC_REL24 __copy_tofrom_user 00001d96 R_PPC_ADDR16_HA .sbss+0x00000024 00001d9a R_PPC_ADDR16_LO .sbss+0x00000024 00001d9e R_PPC_ADDR16_HA .sbss+0x0000000c 00001da2 R_PPC_ADDR16_LO .sbss+0x0000000c 00001dda R_PPC_ADDR16_HA .sbss+0x00000024 00001dde R_PPC_ADDR16_HA .sbss+0x0000000c 00001de2 R_PPC_ADDR16_LO .sbss+0x00000024 00001de6 R_PPC_ADDR16_LO .sbss+0x0000000c 00001e0a R_PPC_ADDR16_LO .sbss+0x00000024 00001e0e R_PPC_ADDR16_LO .sbss+0x0000000c 00001e36 R_PPC_ADDR16_HA .sbss+0x00000014 00001e3a R_PPC_ADDR16_LO .sbss+0x00000014 00001e3e R_PPC_ADDR16_HA .sbss+0x00000024 00001e4a R_PPC_ADDR16_LO .sbss+0x00000024 00001e5e R_PPC_ADDR16_HA .sbss+0x00000024 00001e64 R_PPC_REL24 schedule 00001e6a R_PPC_ADDR16_LO .sbss+0x00000024 00001e7a R_PPC_ADDR16_LO .sbss+0x00000024 00001eb4 R_PPC_REL24 __wake_up 00001ece R_PPC_ADDR16_HA .sbss+0x00000024 00001ed2 R_PPC_ADDR16_LO .sbss+0x00000024 00001ed6 R_PPC_ADDR16_HA .sbss+0x0000000c 00001eda R_PPC_ADDR16_LO .sbss+0x0000000c 00001f34 R_PPC_REL24 __copy_tofrom_user 00001f56 R_PPC_ADDR16_HA .sbss+0x00000024 00001f5a R_PPC_ADDR16_HA .sbss+0x0000000c 00001f5e R_PPC_ADDR16_LO .sbss+0x00000024 00001f62 R_PPC_ADDR16_LO .sbss+0x0000000c 00001fb8 R_PPC_REL24 __copy_tofrom_user 00001fd6 R_PPC_ADDR16_HA .sbss+0x00000024 00001fda R_PPC_ADDR16_LO .sbss+0x00000024 00001fde R_PPC_ADDR16_HA .sbss+0x0000000c 00001fe2 R_PPC_ADDR16_LO .sbss+0x0000000c 00002012 R_PPC_ADDR16_HA .sbss+0x00000014 00002016 R_PPC_ADDR16_HA .sbss+0x00000004 0000201a R_PPC_ADDR16_LO .sbss+0x00000014 0000201e R_PPC_ADDR16_HA .bss+0x00000100 00002022 R_PPC_ADDR16_LO .sbss+0x00000004 00002026 R_PPC_ADDR16_HA .sbss+0x00000024 0000202a R_PPC_ADDR16_LO .bss+0x00000100 0000202e R_PPC_ADDR16_LO .bss+0x00000100 00002032 R_PPC_ADDR16_LO .sbss+0x00000024 00002042 R_PPC_ADDR16_HA .bss+0x0000011c 00002046 R_PPC_ADDR16_HA .rodata.str1.4+0x00000418 0000204e R_PPC_ADDR16_LO .rodata.str1.4+0x00000418 0000205a R_PPC_ADDR16_LO .bss+0x0000011c 00002070 R_PPC_REL24 sprintf 000020b4 R_PPC_REL24 __copy_tofrom_user 000020cc R_PPC_REL24 __copy_tofrom_user 000020e0 R_PPC_REL24 __copy_tofrom_user 00002102 R_PPC_ADDR16_HA .sbss+0x00000014 00002106 R_PPC_ADDR16_LO .sbss+0x00000014 00002112 R_PPC_ADDR16_HA .sbss+0x00000024 00002116 R_PPC_ADDR16_LO .sbss+0x00000024 0000211a R_PPC_ADDR16_HA .text+0x0000024c 0000211e R_PPC_ADDR16_HA .rodata.str1.4+0x00000484 00002126 R_PPC_ADDR16_LO .text+0x0000024c 0000212a R_PPC_ADDR16_LO .rodata.str1.4+0x00000484 0000213c R_PPC_REL24 request_irq 0000214e R_PPC_ADDR16_LO .sbss+0x00000014 00002156 R_PPC_ADDR16_LO .sbss+0x00000024 00002162 R_PPC_ADDR16_LO .sbss+0x00000014 00002164 R_PPC_REL24 free_irq 0000216a R_PPC_ADDR16_HA .sbss+0x00000004 0000216e R_PPC_ADDR16_LO .sbss+0x00000004 00002190 R_PPC_REL24 __copy_tofrom_user 000021a4 R_PPC_REL24 __copy_tofrom_user 000021dc R_PPC_REL24 __copy_tofrom_user 000021f0 R_PPC_REL24 __copy_tofrom_user 00002204 R_PPC_REL24 __copy_tofrom_user 0000220e R_PPC_ADDR16_HA .rodata.str1.4+0x00000494 00002212 R_PPC_ADDR16_HA .rodata+0x0000004c 00002216 R_PPC_ADDR16_LO .rodata+0x0000004c 00002226 R_PPC_ADDR16_LO .rodata.str1.4+0x00000494 00002228 R_PPC_REL24 printk 00002252 R_PPC_ADDR16_HA .sbss+0x0000001c 0000225e R_PPC_ADDR16_LO .sbss+0x0000001c 0000227a R_PPC_ADDR16_HA .rodata+0x00000060 0000227e R_PPC_ADDR16_HA .rodata.str1.4+0x000004dc 00002282 R_PPC_ADDR16_HA .rodata.str1.4+0x00000514 00002286 R_PPC_ADDR16_HA .sbss+0x00000024 0000228a R_PPC_ADDR16_LO .rodata.str1.4+0x000004dc 0000228e R_PPC_ADDR16_LO .rodata+0x00000060 00002296 R_PPC_ADDR16_LO .rodata.str1.4+0x00000514 0000229a R_PPC_ADDR16_HA .sbss+0x00000024 000022ba R_PPC_ADDR16_LO .sbss+0x00000024 000022cc R_PPC_REL24 printk 000022d2 R_PPC_ADDR16_LO .sbss+0x00000024 000022d6 R_PPC_ADDR16_HA .text+0x00000004 000022da R_PPC_ADDR16_HA .rodata.str1.4+0x00000518 000022de R_PPC_ADDR16_LO .text+0x00000004 000022e2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000518 000022ec R_PPC_REL24 request_irq 000022fa R_PPC_ADDR16_HA .rodata.str1.4+0x00000524 000022fe R_PPC_ADDR16_LO .rodata.str1.4+0x00000524 00002302 R_PPC_ADDR16_LO .rodata+0x00000060 00002316 R_PPC_ADDR16_LO .sbss+0x00000024 0000231a R_PPC_ADDR16_HA .sbss+0x00000018 0000231e R_PPC_ADDR16_LO .sbss+0x00000018 00002322 R_PPC_ADDR16_HA .sbss+0x00000010 0000232a R_PPC_ADDR16_LO .sbss+0x00000010 00002332 R_PPC_ADDR16_HA .text+0x0000024c 0000233a R_PPC_ADDR16_HA .rodata.str1.4+0x00000484 00002342 R_PPC_ADDR16_LO .text+0x0000024c 00002346 R_PPC_ADDR16_LO .sbss+0x00000024 0000234a R_PPC_ADDR16_LO .rodata.str1.4+0x00000484 00002370 R_PPC_REL24 request_irq 00002376 R_PPC_ADDR16_LO .rodata+0x00000060 0000237e R_PPC_ADDR16_HA .rodata.str1.4+0x00000494 00002382 R_PPC_ADDR16_LO .rodata.str1.4+0x00000494 00002396 R_PPC_ADDR16_HA .sbss+0x00000014 0000239a R_PPC_ADDR16_LO .sbss+0x00000014 000023a2 R_PPC_ADDR16_HA .rodata.str1.4+0x00000568 000023a6 R_PPC_ADDR16_LO .rodata.str1.4+0x00000568 000023ac R_PPC_REL24 printk 000023be R_PPC_ADDR16_HA .sbss+0x0000001c 000023ca R_PPC_ADDR16_LO .sbss+0x0000001c 000023fe R_PPC_ADDR16_HA .sbss+0x00000024 00002402 R_PPC_ADDR16_LO .sbss+0x00000024 00002406 R_PPC_ADDR16_HA .rodata.str1.4+0x00000514 0000240a R_PPC_ADDR16_LO .rodata.str1.4+0x00000514 0000241a R_PPC_ADDR16_HA .rodata+0x0000006c 0000241e R_PPC_ADDR16_HA .rodata.str1.4+0x0000056c 00002422 R_PPC_ADDR16_LO .rodata+0x0000006c 0000242a R_PPC_ADDR16_LO .rodata.str1.4+0x0000056c 0000242c R_PPC_REL24 printk 00002436 R_PPC_ADDR16_HA .sbss+0x00000018 0000243a R_PPC_ADDR16_LO .sbss+0x00000018 00002446 R_PPC_ADDR16_HA .sbss+0x00000014 0000244a R_PPC_ADDR16_LO .sbss+0x00000014 0000245e R_PPC_ADDR16_LO .sbss+0x00000024 00002474 R_PPC_REL24 __wake_up 00002486 R_PPC_ADDR16_LO .sbss+0x00000024 00002496 R_PPC_ADDR16_HA .sbss+0x00000024 0000249c R_PPC_REL24 schedule 000024a2 R_PPC_ADDR16_LO .sbss+0x00000024 000024b2 R_PPC_ADDR16_LO .sbss+0x00000024 000024ec R_PPC_REL24 __wake_up 000024f6 R_PPC_ADDR16_HA .rodata.str1.4+0x00000568 000024fa R_PPC_ADDR16_LO .rodata.str1.4+0x00000568 00002502 R_PPC_ADDR16_LO .sbss+0x00000024 0000250e R_PPC_ADDR16_LO .sbss+0x00000014 00002510 R_PPC_REL24 free_irq 00002516 R_PPC_ADDR16_HA .sbss+0x00000004 0000251a R_PPC_ADDR16_LO .sbss+0x00000004 00002522 R_PPC_ADDR16_LO .sbss+0x00000024 0000252e R_PPC_ADDR16_LO .sbss+0x00000018 00002530 R_PPC_REL24 free_irq RELOCATION RECORDS FOR [.init.text]: OFFSET TYPE VALUE 00000016 R_PPC_ADDR16_HA .data+0x000001dc 00000022 R_PPC_ADDR16_LO .data+0x000001dc 00000032 R_PPC_ADDR16_HA .data+0x000001d8 00000036 R_PPC_ADDR16_LO .data+0x000001d8 00000046 R_PPC_ADDR16_HA .data+0x000001d4 0000004a R_PPC_ADDR16_LO .data+0x000001d4 0000005a R_PPC_ADDR16_HA malloc_sizes 0000005e R_PPC_ADDR16_LO malloc_sizes 0000006a R_PPC_ADDR16_HA .sbss+0x00000024 0000006c R_PPC_REL24 kmem_cache_alloc 00000076 R_PPC_ADDR16_LO .sbss+0x00000024 00000084 R_PPC_REL24 memset 00000090 R_PPC_REL24 kmem_cache_alloc 00000096 R_PPC_ADDR16_HA .sbss+0x00000028 0000009e R_PPC_ADDR16_LO .sbss+0x00000028 000000ac R_PPC_REL24 memset 000000b2 R_PPC_ADDR16_LO .sbss+0x00000024 000000c2 R_PPC_ADDR16_LO .sbss+0x00000024 000000c8 R_PPC_REL24 ioremap 000000ce R_PPC_ADDR16_HA .sbss+0x0000000c 000000d6 R_PPC_ADDR16_LO .sbss+0x00000024 000000de R_PPC_ADDR16_LO .sbss+0x00000024 000000fa R_PPC_ADDR16_LO .sbss+0x0000000c 00000112 R_PPC_ADDR16_LO .data+0x000001dc 0000011a R_PPC_ADDR16_LO .data+0x000001dc 00000122 R_PPC_ADDR16_HA .data+0x000001dc 00000132 R_PPC_ADDR16_LO .sbss+0x00000024 0000014a R_PPC_ADDR16_LO .sbss+0x00000024 0000015a R_PPC_ADDR16_LO .sbss+0x00000024 0000016e R_PPC_ADDR16_LO .sbss+0x00000024 0000017e R_PPC_ADDR16_LO .sbss+0x00000024 00000186 R_PPC_ADDR16_LO .sbss+0x00000024 0000019a R_PPC_ADDR16_LO .sbss+0x00000024 000001ae R_PPC_ADDR16_LO .sbss+0x00000024 000001be R_PPC_ADDR16_HA pRsdpqXHwCtrl 000001c2 R_PPC_ADDR16_LO .sbss+0x00000024 000001ca R_PPC_ADDR16_LO .data+0x000001dc 000001ce R_PPC_ADDR16_LO .sbss+0x00000024 000001d6 R_PPC_ADDR16_LO pRsdpqXHwCtrl 000001f6 R_PPC_ADDR16_LO .sbss+0x00000024 00000216 R_PPC_ADDR16_LO .sbss+0x00000024 0000021e R_PPC_ADDR16_LO .sbss+0x0000000c 00000276 R_PPC_ADDR16_LO .sbss+0x00000024 00000286 R_PPC_ADDR16_LO .sbss+0x00000024 0000028e R_PPC_ADDR16_LO .data+0x000001dc 00000292 R_PPC_ADDR16_LO .sbss+0x00000024 0000029a R_PPC_ADDR16_LO .sbss+0x0000000c 000002ba R_PPC_ADDR16_LO .sbss+0x00000024 000002da R_PPC_ADDR16_LO .sbss+0x00000024 000002de R_PPC_ADDR16_LO .sbss+0x0000000c 0000032e R_PPC_ADDR16_LO .sbss+0x00000024 00000342 R_PPC_ADDR16_LO .sbss+0x00000024 0000034a R_PPC_ADDR16_LO .data+0x000001d4 0000034e R_PPC_ADDR16_LO .sbss+0x00000024 0000036e R_PPC_ADDR16_HA .sbss+0x00000024 00000372 R_PPC_ADDR16_LO .sbss+0x00000024 0000038a R_PPC_ADDR16_HA .rodata.str1.4+0x000005a4 0000038e R_PPC_ADDR16_HA .rodata+0x00000078 00000392 R_PPC_ADDR16_LO .rodata.str1.4+0x000005a4 00000396 R_PPC_ADDR16_LO .rodata+0x00000078 0000039c R_PPC_REL24 printk 000003a6 R_PPC_ADDR16_HA .sbss+0x00000028 000003aa R_PPC_ADDR16_LO .sbss+0x00000028 000003b6 R_PPC_ADDR16_HA .sbss+0x00000024 000003ba R_PPC_ADDR16_LO .sbss+0x00000024 00000402 R_PPC_ADDR16_HA .rodata.str1.4+0x000005ec 00000406 R_PPC_ADDR16_LO .rodata.str1.4+0x000005ec 0000040c R_PPC_REL24 remove_proc_entry 00000412 R_PPC_ADDR16_LO .sbss+0x00000024 00000416 R_PPC_ADDR16_HA .sbss+0x00000024 00000430 R_PPC_REL24 kfree 0000043a R_PPC_ADDR16_LO .sbss+0x00000024 0000045e R_PPC_ADDR16_LO .data+0x000001d4 00000476 R_PPC_ADDR16_LO .sbss+0x00000024 00000496 R_PPC_ADDR16_LO .sbss+0x00000024 0000049a R_PPC_ADDR16_LO .data+0x000001d8 000004b2 R_PPC_ADDR16_LO .sbss+0x00000024 000004d2 R_PPC_ADDR16_LO .sbss+0x00000024 000004ee R_PPC_ADDR16_HA .sbss+0x00000008 000004f2 R_PPC_ADDR16_LO .sbss+0x00000024 000004f6 R_PPC_ADDR16_LO .sbss+0x00000008 00000512 R_PPC_ADDR16_LO .sbss+0x00000024 00000532 R_PPC_ADDR16_LO .sbss+0x00000024 0000053a R_PPC_ADDR16_LO .sbss+0x0000000c 00000566 R_PPC_ADDR16_LO .sbss+0x00000024 0000057a R_PPC_ADDR16_LO .sbss+0x00000024 0000058e R_PPC_ADDR16_LO .sbss+0x00000024 000005a2 R_PPC_ADDR16_LO .sbss+0x00000024 000005b6 R_PPC_ADDR16_LO .sbss+0x00000024 000005da R_PPC_ADDR16_LO .sbss+0x00000024 000005ea R_PPC_ADDR16_LO .sbss+0x00000024 000005f6 R_PPC_ADDR16_LO .sbss+0x00000024 000005fe R_PPC_ADDR16_HA .rodata.str1.4+0x00000514 00000602 R_PPC_ADDR16_LO .sbss+0x00000024 00000606 R_PPC_ADDR16_LO .rodata.str1.4+0x00000514 0000061a R_PPC_ADDR16_HA .rodata.str1.4+0x00000568 0000061e R_PPC_ADDR16_LO .rodata.str1.4+0x00000568 00000622 R_PPC_ADDR16_HA .rodata.str1.4+0x000005fc 00000626 R_PPC_ADDR16_HA .rodata.str1.4+0x00000608 0000062a R_PPC_ADDR16_HA .rodata.str1.4+0x00000614 00000636 R_PPC_ADDR16_LO .rodata.str1.4+0x000005fc 0000063a R_PPC_ADDR16_LO .rodata.str1.4+0x00000608 0000063e R_PPC_ADDR16_LO .rodata.str1.4+0x00000614 00000644 R_PPC_REL24 sprintf 0000064a R_PPC_ADDR16_LO .sbss+0x00000024 0000064e R_PPC_ADDR16_LO .sbss+0x0000000c 00000672 R_PPC_ADDR16_LO .sbss+0x00000024 0000067e R_PPC_ADDR16_HA .rodata.str1.4+0x00000514 00000682 R_PPC_ADDR16_LO .sbss+0x00000024 00000686 R_PPC_ADDR16_LO .rodata.str1.4+0x00000514 0000068e R_PPC_ADDR16_LO .sbss+0x00000024 000006a2 R_PPC_ADDR16_HA .rodata.str1.4+0x00000568 000006a6 R_PPC_ADDR16_LO .rodata.str1.4+0x00000568 000006aa R_PPC_ADDR16_HA .rodata.str1.4+0x0000063c 000006c2 R_PPC_ADDR16_LO .rodata.str1.4+0x0000063c 000006d8 R_PPC_REL24 sprintf 000006de R_PPC_ADDR16_LO .sbss+0x00000024 000006ee R_PPC_ADDR16_HA .data+0x000001e0 000006f6 R_PPC_ADDR16_LO .sbss+0x00000024 00000702 R_PPC_ADDR16_LO .sbss+0x00000024 00000712 R_PPC_ADDR16_LO .sbss+0x00000024 00000716 R_PPC_ADDR16_LO .sbss+0x0000000c 00000724 R_PPC_REL24 .text+0x00000b2c 0000072a R_PPC_ADDR16_HA .bss+0x0000021c 00000732 R_PPC_ADDR16_LO .data+0x000001e0 00000736 R_PPC_ADDR16_LO .bss+0x0000021c 0000073a R_PPC_ADDR16_LO .bss+0x0000021c 0000073e R_PPC_ADDR16_HA .data+0x0000043c 00000746 R_PPC_ADDR16_LO .data+0x0000043c 00000750 R_PPC_REL24 misc_register 0000075e R_PPC_ADDR16_HA .sbss+0x00000024 00000762 R_PPC_ADDR16_LO .sbss+0x00000024 00000766 R_PPC_ADDR16_HA .rodata.str1.4+0x00000514 0000076a R_PPC_ADDR16_LO .rodata.str1.4+0x00000514 0000077a R_PPC_ADDR16_HA .rodata.str1.4+0x00000568 0000077e R_PPC_ADDR16_LO .rodata.str1.4+0x00000568 00000782 R_PPC_ADDR16_LO .sbss+0x00000024 00000786 R_PPC_ADDR16_HA .rodata.str1.4+0x0000034c 0000078a R_PPC_ADDR16_LO .rodata.str1.4+0x0000034c 0000079e R_PPC_ADDR16_HA .rodata.str1.4+0x00000354 000007a2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000354 000007ae R_PPC_ADDR16_HA .rodata.str1.4+0x00000374 000007b2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000374 000007b6 R_PPC_ADDR16_LO .sbss+0x00000024 000007ba R_PPC_ADDR16_HA .rodata.str1.4+0x00000670 000007be R_PPC_ADDR16_LO .rodata.str1.4+0x00000670 000007ce R_PPC_ADDR16_HA .rodata.str1.4+0x00000678 000007d2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000678 000007d6 R_PPC_ADDR16_HA .rodata.str1.4+0x00000684 000007de R_PPC_ADDR16_LO .rodata.str1.4+0x000005fc 000007e2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000608 000007f2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000684 000007f6 R_PPC_ADDR16_HA .rodata.str1.4+0x000005ec 000007f8 R_PPC_REL24 printk 000007fe R_PPC_ADDR16_LO .sbss+0x00000024 00000802 R_PPC_ADDR16_LO .rodata.str1.4+0x000005ec 00000808 R_PPC_REL24 proc_mkdir 0000080e R_PPC_ADDR16_HA .rodata.str1.4+0x000005ec 00000816 R_PPC_ADDR16_LO .sbss+0x00000024 00000826 R_PPC_ADDR16_HA .rodata.str1.4+0x000006c8 0000082a R_PPC_ADDR16_LO .rodata.str1.4+0x000006c8 00000830 R_PPC_REL24 create_proc_entry 0000083a R_PPC_ADDR16_LO .sbss+0x00000024 0000084a R_PPC_ADDR16_HA PbFpgaProcFileOpsAll 0000084e R_PPC_ADDR16_LO PbFpgaProcFileOpsAll 00000856 R_PPC_ADDR16_LO .sbss+0x00000024 0000085a R_PPC_ADDR16_HA .rodata.str1.4+0x000006cc 0000085e R_PPC_ADDR16_LO .rodata.str1.4+0x000006cc 00000868 R_PPC_REL24 create_proc_entry 00000872 R_PPC_ADDR16_LO .sbss+0x00000024 00000882 R_PPC_ADDR16_HA PbFpgaProcFileOpsClientIp 00000886 R_PPC_ADDR16_LO PbFpgaProcFileOpsClientIp 0000088e R_PPC_ADDR16_LO .sbss+0x00000024 00000892 R_PPC_ADDR16_HA .rodata.str1.4+0x000006d8 00000896 R_PPC_ADDR16_LO .rodata.str1.4+0x000006d8 000008a0 R_PPC_REL24 create_proc_entry 000008aa R_PPC_ADDR16_LO .sbss+0x00000024 000008ba R_PPC_ADDR16_HA PbFpgaProcFileOpsServerIp 000008be R_PPC_ADDR16_LO PbFpgaProcFileOpsServerIp 000008c6 R_PPC_ADDR16_LO .sbss+0x00000024 000008ca R_PPC_ADDR16_HA .rodata.str1.4+0x000006e4 000008ce R_PPC_ADDR16_LO .rodata.str1.4+0x000006e4 000008d8 R_PPC_REL24 create_proc_entry 000008e2 R_PPC_ADDR16_LO .sbss+0x00000024 000008f2 R_PPC_ADDR16_HA PbFpgaProcFileOpsPlatform 000008f6 R_PPC_ADDR16_LO PbFpgaProcFileOpsPlatform 0000090a R_PPC_ADDR16_LO .sbss+0x00000024 00000926 R_PPC_ADDR16_LO .sbss+0x00000024 0000092e R_PPC_ADDR16_HA .sbss+0x00000014 00000932 R_PPC_ADDR16_LO .sbss+0x00000014 0000093a R_PPC_ADDR16_HA .sbss+0x00000004 0000093e R_PPC_ADDR16_HA .sbss+0x00000010 00000942 R_PPC_ADDR16_LO .sbss+0x00000004 00000946 R_PPC_ADDR16_LO .sbss+0x00000010 00000974 R_PPC_REL24 kfree 0000097e R_PPC_ADDR16_LO .sbss+0x00000028 0000098e R_PPC_ADDR16_HA .data+0x000003fb 00000992 R_PPC_ADDR16_LO .data+0x000003fb 000009ba R_PPC_ADDR16_LO .sbss+0x00000024 000009de R_PPC_ADDR16_HA .rodata.str1.4+0x000006f0 000009e2 R_PPC_ADDR16_LO .sbss+0x00000024 000009f2 R_PPC_ADDR16_LO .rodata.str1.4+0x000006f0 00000a10 R_PPC_REL24 sprintf 00000a22 R_PPC_ADDR16_HA .rodata.str1.4+0x000006f4 00000a26 R_PPC_ADDR16_LO .rodata.str1.4+0x000006f4 00000a2c R_PPC_REL24 strcmp 00000a4e R_PPC_ADDR16_HA .rodata.str1.4+0x00000700 00000a52 R_PPC_ADDR16_LO .rodata.str1.4+0x00000700 00000a58 R_PPC_REL24 strcmp 00000a78 R_PPC_REL24 strcpy 00000a8a R_PPC_ADDR16_LO .data+0x000001dc 00000a92 R_PPC_ADDR16_LO .data+0x000001dc 00000a9a R_PPC_ADDR16_HA .rodata.str1.4+0x00000714 00000a9e R_PPC_ADDR16_HA .rodata+0x00000078 00000aa2 R_PPC_ADDR16_LO .rodata+0x00000078 00000aa6 R_PPC_ADDR16_LO .rodata.str1.4+0x000005ec 00000aae R_PPC_ADDR16_LO .rodata.str1.4+0x00000714 00000ab0 R_PPC_REL24 printk 00000aba R_PPC_ADDR16_HA .rodata.str1.4+0x0000073c 00000abe R_PPC_ADDR16_HA .rodata+0x00000078 00000ac2 R_PPC_ADDR16_LO .rodata.str1.4+0x0000073c 00000ac6 R_PPC_ADDR16_LO .rodata+0x00000078 00000ad2 R_PPC_ADDR16_HA .rodata.str1.4+0x00000780 00000ad6 R_PPC_ADDR16_HA .rodata+0x00000078 00000ada R_PPC_ADDR16_LO .rodata.str1.4+0x00000780 00000ade R_PPC_ADDR16_LO .rodata+0x00000078 00000aec R_PPC_REL24 iounmap 00000af2 R_PPC_ADDR16_LO .sbss+0x00000024 00000afc R_PPC_REL24 iounmap 00000b02 R_PPC_ADDR16_LO .sbss+0x00000024 00000b12 R_PPC_ADDR16_LO .data+0x000001e0 00000b16 R_PPC_ADDR16_HA .rodata.str1.4+0x000007c4 00000b1a R_PPC_ADDR16_HA .rodata+0x00000078 00000b1e R_PPC_ADDR16_HA .rodata.str1.4+0x00000800 00000b22 R_PPC_ADDR16_LO .rodata.str1.4+0x000007c4 00000b26 R_PPC_ADDR16_LO .rodata+0x00000078 00000b2a R_PPC_ADDR16_LO .rodata.str1.4+0x00000800 00000b30 R_PPC_REL24 printk 00000b42 R_PPC_ADDR16_HA .rodata.str1.4+0x000006e4 00000b46 R_PPC_ADDR16_LO .rodata.str1.4+0x000006e4 00000b48 R_PPC_REL24 remove_proc_entry 00000b56 R_PPC_ADDR16_HA .rodata.str1.4+0x000006d8 00000b5a R_PPC_ADDR16_LO .rodata.str1.4+0x000006d8 00000b5c R_PPC_REL24 remove_proc_entry 00000b62 R_PPC_ADDR16_LO .sbss+0x00000024 00000b6e R_PPC_ADDR16_HA .rodata.str1.4+0x000006cc 00000b72 R_PPC_ADDR16_LO .rodata.str1.4+0x000006cc 00000b74 R_PPC_REL24 remove_proc_entry 00000b7a R_PPC_ADDR16_LO .sbss+0x00000024 00000b82 R_PPC_ADDR16_HA .rodata.str1.4+0x000006c8 00000b86 R_PPC_ADDR16_LO .rodata.str1.4+0x000006c8 00000b88 R_PPC_REL24 remove_proc_entry 00000b8e R_PPC_ADDR16_LO .sbss+0x00000024 00000b96 R_PPC_ADDR16_HA .rodata.str1.4+0x00000808 00000b9a R_PPC_ADDR16_HA .rodata+0x00000078 00000b9e R_PPC_ADDR16_LO .rodata.str1.4+0x00000808 00000ba2 R_PPC_ADDR16_LO .rodata+0x00000078 00000ba8 R_PPC_REL24 printk 00000bb6 R_PPC_ADDR16_HA .rodata.str1.4+0x000006f4 00000bba R_PPC_ADDR16_LO .rodata.str1.4+0x000006f4 00000bc0 R_PPC_REL24 strcmp 00000bd6 R_PPC_ADDR16_HA .rodata.str1.4+0x00000848 00000bda R_PPC_ADDR16_HA .rodata+0x00000078 00000bde R_PPC_ADDR16_LO .rodata+0x00000078 00000be2 R_PPC_ADDR16_LO .rodata.str1.4+0x000006cc 00000bea R_PPC_ADDR16_LO .rodata.str1.4+0x000005ec 00000bee R_PPC_ADDR16_LO .rodata.str1.4+0x00000848 00000bf0 R_PPC_REL24 printk 00000bfa R_PPC_ADDR16_HA .rodata.str1.4+0x00000848 00000bfe R_PPC_ADDR16_HA .rodata+0x00000078 00000c02 R_PPC_ADDR16_LO .rodata+0x00000078 00000c06 R_PPC_ADDR16_LO .rodata.str1.4+0x000005ec 00000c0a R_PPC_ADDR16_LO .rodata.str1.4+0x000006c8 00000c12 R_PPC_ADDR16_LO .rodata.str1.4+0x00000848 00000c14 R_PPC_REL24 printk 00000c1e R_PPC_ADDR16_HA .rodata.str1.4+0x00000848 00000c22 R_PPC_ADDR16_HA .rodata+0x00000078 00000c26 R_PPC_ADDR16_LO .rodata+0x00000078 00000c2a R_PPC_ADDR16_LO .rodata.str1.4+0x000005ec 00000c2e R_PPC_ADDR16_LO .rodata.str1.4+0x000006e4 00000c36 R_PPC_ADDR16_LO .rodata.str1.4+0x00000848 00000c38 R_PPC_REL24 printk 00000c42 R_PPC_ADDR16_HA .rodata.str1.4+0x00000848 00000c46 R_PPC_ADDR16_HA .rodata+0x00000078 00000c4a R_PPC_ADDR16_LO .rodata+0x00000078 00000c4e R_PPC_ADDR16_LO .rodata.str1.4+0x000006d8 00000c56 R_PPC_ADDR16_LO .rodata.str1.4+0x000005ec 00000c5a R_PPC_ADDR16_LO .rodata.str1.4+0x00000848 00000c5c R_PPC_REL24 printk 00000c6e R_PPC_ADDR16_HA .rodata.str1.4+0x00000874 00000c72 R_PPC_ADDR16_HA .rodata+0x00000078 00000c76 R_PPC_ADDR16_HA .rodata.str1.4+0x0000004c 00000c7a R_PPC_ADDR16_LO .rodata.str1.4+0x00000874 00000c7e R_PPC_ADDR16_LO .rodata+0x00000078 00000c82 R_PPC_ADDR16_LO .rodata.str1.4+0x0000004c 00000c88 R_PPC_REL24 printk 00000c9e R_PPC_ADDR16_HA .data+0x000001e0 00000ca2 R_PPC_ADDR16_LO .data+0x000001e0 00000ca6 R_PPC_ADDR16_HA .rodata+0x00000078 00000caa R_PPC_ADDR16_HA .rodata.str1.4+0x00000800 00000cae R_PPC_ADDR16_HA .rodata.str1.4+0x000008bc 00000cb2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000800 00000cb6 R_PPC_ADDR16_LO .rodata+0x00000078 00000cbe R_PPC_ADDR16_LO .rodata.str1.4+0x000008bc 00000cc0 R_PPC_REL24 printk 00000cc6 R_PPC_ADDR16_LO .sbss+0x00000024 00000cca R_PPC_ADDR16_HA .rodata.str1.4+0x00000924 00000cd2 R_PPC_ADDR16_LO .rodata+0x00000078 00000cda R_PPC_ADDR16_LO .rodata.str1.4+0x00000924 00000cdc R_PPC_REL24 printk 00000ce2 R_PPC_ADDR16_LO .sbss+0x00000024 00000ce6 R_PPC_ADDR16_LO .data+0x000001dc 00000cea R_PPC_ADDR16_HA .rodata.str1.4+0x00000968 00000cf2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000968 00000cfe R_PPC_ADDR16_HA .rodata.str1.4+0x000009b8 00000d00 R_PPC_REL24 printk 00000d0a R_PPC_ADDR16_LO .sbss+0x00000024 00000d12 R_PPC_ADDR16_LO .sbss+0x0000000c 00000d16 R_PPC_ADDR16_LO .rodata.str1.4+0x000009b8 00000d34 R_PPC_REL24 printk RELOCATION RECORDS FOR [.exit.text]: OFFSET TYPE VALUE 0000000e R_PPC_ADDR16_HA .sbss+0x00000028 00000014 R_PPC_REL24 .text+0x00000b2c 0000001a R_PPC_ADDR16_LO .sbss+0x00000028 0000002a R_PPC_ADDR16_HA .sbss+0x00000024 0000002e R_PPC_ADDR16_LO .sbss+0x00000024 00000046 R_PPC_ADDR16_LO .sbss+0x00000024 0000004e R_PPC_ADDR16_HA pRsdpqXHwCtrl 00000056 R_PPC_ADDR16_HA .sbss+0x00000024 0000005a R_PPC_ADDR16_LO pRsdpqXHwCtrl 00000074 R_PPC_REL24 kfree 0000007a R_PPC_ADDR16_LO .sbss+0x00000024 0000007e R_PPC_ADDR16_HA .bss+0x0000021c 00000082 R_PPC_ADDR16_LO .bss+0x0000021c 00000084 R_PPC_REL24 misc_deregister 00000096 R_PPC_ADDR16_HA .rodata.str1.4+0x00000514 0000009a R_PPC_ADDR16_LO .rodata.str1.4+0x00000514 000000a2 R_PPC_ADDR16_HA .rodata.str1.4+0x00000568 000000a6 R_PPC_ADDR16_LO .rodata.str1.4+0x00000568 000000aa R_PPC_ADDR16_HA .rodata.str1.4+0x000009fc 000000ae R_PPC_ADDR16_LO .rodata.str1.4+0x000009fc 000000bc R_PPC_REL24 printk 000000da R_PPC_ADDR16_HA .rodata.str1.4+0x00000514 000000de R_PPC_ADDR16_LO .rodata.str1.4+0x00000514 000000e6 R_PPC_ADDR16_HA .rodata.str1.4+0x00000a24 000000ea R_PPC_ADDR16_LO .rodata.str1.4+0x00000a24 000000f8 R_PPC_REL24 printk 00000112 R_PPC_ADDR16_HA .rodata.str1.4+0x00000568 00000116 R_PPC_ADDR16_LO .rodata.str1.4+0x00000568 0000014e R_PPC_ADDR16_HA .rodata.str1.4+0x000005ec 00000152 R_PPC_ADDR16_LO .rodata.str1.4+0x000005ec 00000158 R_PPC_REL24 remove_proc_entry 0000015e R_PPC_ADDR16_LO .sbss+0x00000024 00000166 R_PPC_ADDR16_HA pRsdpqXHwCtrl 0000016e R_PPC_ADDR16_LO pRsdpqXHwCtrl 00000172 R_PPC_ADDR16_HA .sbss+0x00000024 00000184 R_PPC_REL24 iounmap 0000018a R_PPC_ADDR16_LO .sbss+0x00000024 0000019c R_PPC_REL24 iounmap 000001a2 R_PPC_ADDR16_LO .sbss+0x00000024 000001a4 R_PPC_REL24 kfree 000001aa R_PPC_ADDR16_LO .sbss+0x00000024 000001b0 R_PPC_REL24 kfree 000001ba R_PPC_ADDR16_LO .sbss+0x00000028 000001c2 R_PPC_ADDR16_HA .rodata.str1.4+0x000006c8 000001c6 R_PPC_ADDR16_LO .rodata.str1.4+0x000006c8 000001c8 R_PPC_REL24 remove_proc_entry 000001ce R_PPC_ADDR16_LO .sbss+0x00000024 000001da R_PPC_ADDR16_HA .rodata.str1.4+0x000006e4 000001de R_PPC_ADDR16_LO .rodata.str1.4+0x000006e4 000001e0 R_PPC_REL24 remove_proc_entry 000001ee R_PPC_ADDR16_HA .rodata.str1.4+0x000006d8 000001f2 R_PPC_ADDR16_LO .rodata.str1.4+0x000006d8 000001f4 R_PPC_REL24 remove_proc_entry 000001fa R_PPC_ADDR16_LO .sbss+0x00000024 00000206 R_PPC_ADDR16_HA .rodata.str1.4+0x000006cc 0000020a R_PPC_ADDR16_LO .rodata.str1.4+0x000006cc 0000020c R_PPC_REL24 remove_proc_entry 00000212 R_PPC_ADDR16_LO .sbss+0x00000024 RELOCATION RECORDS FOR [__ksymtab]: OFFSET TYPE VALUE 00000000 R_PPC_ADDR32 pRsdpqXHwCtrl 00000004 R_PPC_ADDR32 __ksymtab_strings RELOCATION RECORDS FOR [__ex_table]: OFFSET TYPE VALUE 00000000 R_PPC_ADDR32 .text+0x00000f84 00000004 R_PPC_ADDR32 .fixup 00000008 R_PPC_ADDR32 .text+0x00001264 0000000c R_PPC_ADDR32 .fixup+0x00000008 00000010 R_PPC_ADDR32 .text+0x00001718 00000014 R_PPC_ADDR32 .fixup+0x00000014 00000018 R_PPC_ADDR32 .text+0x00001770 0000001c R_PPC_ADDR32 .fixup+0x0000001c 00000020 R_PPC_ADDR32 .text+0x00001ac4 00000024 R_PPC_ADDR32 .fixup+0x00000028 00000028 R_PPC_ADDR32 .text+0x00001d60 0000002c R_PPC_ADDR32 .fixup+0x00000034 RELOCATION RECORDS FOR [.fixup]: OFFSET TYPE VALUE 00000004 R_PPC_REL24 .text+0x00000f88 00000010 R_PPC_REL24 .text+0x00001268 00000018 R_PPC_REL24 .text+0x0000171c 00000024 R_PPC_REL24 .text+0x00001774 00000030 R_PPC_REL24 .text+0x00001ac8 0000003c R_PPC_REL24 .text+0x00001d64 RELOCATION RECORDS FOR [.data]: OFFSET TYPE VALUE 00000008 R_PPC_ADDR32 .text+0x000009a0 00000074 R_PPC_ADDR32 .text+0x0000089c 000000e0 R_PPC_ADDR32 .text+0x00000770 0000014c R_PPC_ADDR32 .text+0x000002d0 00000154 R_PPC_ADDR32 .text+0x000005e8 000001bc R_PPC_ADDR32 .text+0x000001a4 000001c4 R_PPC_ADDR32 .rodata.str1.4 000001c8 R_PPC_ADDR32 .rodata.str1.4+0x00000014 000001cc R_PPC_ADDR32 .rodata.str1.4+0x00000024 000001d0 R_PPC_ADDR32 .rodata.str1.4+0x00000034 000001e0 R_PPC_ADDR32 .rodata.str1.4+0x00000044 0000043c R_PPC_ADDR32 __this_module 00000444 R_PPC_ADDR32 .text+0x00000bcc 0000044c R_PPC_ADDR32 .text+0x00000c08 00000460 R_PPC_ADDR32 .text+0x00000e08 00000468 R_PPC_ADDR32 .text+0x00000c44 0000046c R_PPC_ADDR32 .text+0x00002248 00000474 R_PPC_ADDR32 .text+0x000023b4 RELOCATION RECORDS FOR [__obsparm]: OFFSET TYPE VALUE 0000007c R_PPC_ADDR32 .text 000000fc R_PPC_ADDR32 .text 0000017c R_PPC_ADDR32 .text 000001fc R_PPC_ADDR32 .text RELOCATION RECORDS FOR [.gnu.linkonce.this_module]: OFFSET TYPE VALUE 000000a4 R_PPC_ADDR32 init_module 0000010c R_PPC_ADDR32 cleanup_module >strings pbfpga.ko })P0| @.9~ } X(} .pU) X0| (}HXx} }@X9; iH0U) :| P. })X0| P.8 0}I@.8 }@H(}K x}`I-@ }c[x8! #x<` Q.9 Q.9 X0Uk U%`&/ HP}E EHP| x}FSx}^SxH H(}`I-@ | H0U) :| @. H9|| T})@0| 8. }#Kx }KX0Uk | X08 }RsdpqXHwCtrl.PbFpgaRegBase @ 0x%08X pPbFpgaCtrl->RsdpqXHwCtrl.PbFpgaRegBase [0x%02X] @ 0x%08X = 0x%08X [A_D3G_VERSION] pPbFpgaCtrl->RsdpqXHwCtrl.PbFpgaRegBase [0x%02X] @ 0x%08X = 0x%08X [A_PHONE_HOTLINE] pPbFpgaCtrl->RsdpqXHwCtrl.PbFpgaRamBase' @ 0x%08X pPbFpgaCtrl->RsdpqXHwCtrl.PbDpramBase @ 0x%08X pPbFpgaCtrl->RsdpqXHwCtrl.PbDpramExtBase @ 0x%08X pPbFpgaCtrl->RsdpqXHwCtrl.PbCpldBase @ 0x%08X Module parameters [defaults]: devname=%s [%s] reg_waits=%d [%d] dpram_waits=%d [%d] dpram_ext_waits=%d [%d] cpld_waits=%d [%d] mbx= <6>%-13s [%4d]: %s%d calling PbFpgaMbxSemTaskletFct [%2d] ... skipping PbFpgaMbxSemTaskletFct [%2d]: MbxIrqDisable = %d - break ... CRTU-W CRTU-G [rsdpq2] [rsdpq3] CMU-USU <4>%-13s [%4d]: (%d bytes) - EINVAL <3>%-13s [%4d]: VirtSize = %u (0x%08X)] exceeds PhysSize = %u (0x%08X) <3>%-13s [%4d]: default [0x%08X] -> EINVAL MbxIrqEnable = %d MbxIrqDisable = %d MbxIrqCnt = %d MbxSemSigCnt = %d MbxSemCnt = %d MbxWaiters = %d PbFpgaMbxIsr <3>%-13s [%4d]: Can't register PbFpgaMbxIsr for [IRQ2 @ 0x%02X]: %d <6>%-13s [%4d]: first user -> activating %s-FPGA... PbFpgaIsr <3>%-13s [%4d]: Can't register PbFpgaIsr for [IRQ3 @ 0x%02X]: %d <6>%-13s [%4d]: last user -> de-activating %s-FPGA... <3>%-13s [%4d]: Invalid module parameter: dpram_ext_waits = %d [2..15] driver/pbfpga Jun 6 2007 16:35:45 %s-FPGA LKM v%d.%d%d [build %s - %s] %s-FPGA Firmware v%d.%d0 [build %d%d.%d%d.'%d%d] [PQ-II] [PQ-III] %s-FPGA LKM v%d.%d%d [build %s - %s] installed on platform %s %s ClientIP ServerIP Platform 0.0.0.0. 255.255.255.255. <4>%-13s [%4d]: Can't create '/proc/%s <3>%-13s [%4d]: Invalid module parameter: reg_waits = %d [2..15] <3>%-13s [%4d]: Invalid module parameter: dpram_waits = %d [2..15] <3>%-13s [%4d]: Can't register PB-FPGA device: /dev/%s%s misc/ <3>%-13s [%4d]: Out of memory allocating internal structures ! <4>%-13s [%4d]: Can't create '/proc/%s/%s <3>%-13s [%4d]: Out of memory allocating text buffer for proc-fs !%s <3>%-13s [%4d]: Can't register PB-FPGA device: /dev/%s%s - neither CRTU-W nor CMU/CRTU-G HW present ! <3>%-13s [%4d]: pPbFpgaCtrl->RsdpqXHwCtrl.PbFpgaRegBase = 0x%08X pPbFpgaCtrl->pMemCtl->br3 = 0x%08X -> phys. base = 0x%08X [%d WAIT-state(s)] pPbFpgaCtrl->RsdpqXHwCtrl.PbFpgaRegBase [0x%02X] = 0x%08X: 0x%08X %s-FPGA LKM v%d.%d%d uninstall failed %s-FPGA LKM v%d.%d%d uninstalled pRsdpqXHwCtrl DBuild information: ------------------ Compiled LKM 'pbfpga.ko' for RSDPQ2 PB-HW rev.3 (CRTU-W) / USU-HW rev.1 (CMU) + LKM is stand-alone (performs PPC-HW setup and automagic platform detection by itself). + Using normal 32 bit HW access. + Using DEVFS feature for LKM install. + This PB-FPGA firmware version supports 4 FTs. + Default IP addr's retrieved from: /home/schaa/rsdpq2/src/etc/hosts DEFAULT_CLIENT_IP [ ppclan-ppc-master ]: 192.168.168.170 DEFAULT_SERVER_IP [ ppclan-winnt-master ]: 192.168.168.169 192.168.168.170 192.168.168.169 dpram_ext_waits dpram_waits reg_waits devname pbfpga GCC: (GNU) 3.4.4 (ELinOS V4.0 3.4.4-14 2005-12-05) GCC: (GNU) 3.4.4 (ELinOS V4.0 3.4.4-14 2005-12-05) .symtab .strtab .shstrtab .rela.text .rela.init.text .rela.exit.text .rodata .modinfo .rodata.str1.4 .rela__ksymtab __ksymtab_strings .rela__ex_table .rela.fixup .rela.data .rela__obsparm .rela.gnu.linkonce.this_module .sbss .bss .init.plt .comment .note.GNU-stack pbfpgadrv.c PbFpgaProcReadPlatform PbFpgaProcReadServerIp PbFpgaProcReadClientIp PbFpgaProcReadAll PbFpgaProcWriteAll PbFpgaMbxSemTaskletFct __mod_cpld_waits176 __mod_dpram_ext_waits175 __mod_dpram_waits174 __mod_reg_waits173 __mod_devname167 __mod_dpram_ext_waitstype164 MODULE_PARM_ __mod_dpram_waitstype163 __mod_reg_waitstype162 __mod_devnametype158 __mod_description155 __mod_author152 __ksymtab_pRsdpqXHwCtrl __kstrtab_pRsdpqXHwCtrl __mod_license1966 MbxIrqDisable cpld_waits dpram_ext_waits dpram_waits reg_waits devname isCRTUrsdpq2 buildinfo IPAddr MbxFtEvt MbxIrqEnable PbFpgaFileOps PbFpgaRead PbFpgaWrite PbFpgaUnlockedIoctl PbFpgaMmap PbFpgaOpen PbFpgaClose FtIrqEnable ModUseCount IrqStat.6 PbFpgaIsr pPbFpgaCtrl PbFpgaMbxIsr __PRETTY_FUNCTION__.2 pProcOutBuffer __PRETTY_FUNCTION__.0 ProcInBuffer.1 PbFpgaProcOutIp PbFpgaReset __PRETTY_FUNCTION__.11 __PRETTY_FUNCTION__.10 __PRETTY_FUNCTION__.7 __PRETTY_FUNCTION__.8 MbxStat.9 __PRETTY_FUNCTION__.5 __PRETTY_FUNCTION__.4 __PRETTY_FUNCTION__.3 PbFpgaDev pbfpga.mod.c __module_depends __mod_vermagic5 strcpy free_irq __parm_devname __parm_dpram_waits misc_deregister PbFpgaCleanup pRsdpqXHwCtrl __this_module PbFpgaProcFileOpsAll PbFpgaMbxSemTasklet iounmap cleanup_module memcpy remap_pfn_range PbFpgaProcFileOpsPlatform kfree enable_irq __wake_up init_module create_proc_entry schedule request_irq kmem_cache_alloc strcat preempt_schedule strstr ioremap PbFpgaProcFileOpsClientIp printk __copy_tofrom_user szTimeStat _ctype proc_mkdir memset misc_register __parm_dpram_ext_waits strcmp sprintf remove_proc_entry interruptible_sleep_on __tasklet_hi_schedule malloc_sizes PbFpgaInit __parm_reg_waits __down_interruptible strlen PbFpgaProcFileOpsServerIp disable_irq >objdump -x ppc2isa.ko ppc2isa.ko: file format elf32-powerpc ppc2isa.ko architecture: powerpc:common, flags 0x00000011: HAS_RELOC, HAS_SYMS start address 0x00000000 Sections: Idx Name Size VMA LMA File off Algn 0 .text 00001098 00000000 00000000 00000034 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 1 .init.text 0000052c 00000000 00000000 000010cc 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 2 .exit.text 000001b4 00000000 00000000 000015f8 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 3 .rodata 0000008c 00000000 00000000 000017ac 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 4 .modinfo 00000140 00000000 00000000 00001838 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 5 .rodata.str1.4 000009a4 00000000 00000000 00001978 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 6 .data 000000f8 00000000 00000000 0000231c 2**2 CONTENTS, ALLOC, LOAD, RELOC, DATA 7 .gnu.linkonce.this_module 00000120 00000000 00000000 00002420 2**5 CONTENTS, ALLOC, LOAD, RELOC, DATA, LINK_ONCE_DISCARD 8 .sbss 00000060 00000000 00000000 00002540 2**2 ALLOC 9 .plt 00000000 00000000 00000000 00002540 2**3 ALLOC, READONLY, CODE 10 .bss 00000fe0 00000000 00000000 00002540 2**2 ALLOC 11 .init.plt 00000000 00000000 00000000 00002540 2**3 ALLOC, READONLY, CODE 12 .comment 00000068 00000000 00000000 00002540 2**0 CONTENTS, READONLY 13 .note.GNU-stack 00000000 00000000 00000000 000025a8 2**0 CONTENTS, READONLY SYMBOL TABLE: 00000000 l d .text 00000000 .text 00000000 l d *ABS* 00000000 .rela.text 00000000 l d .init.text 00000000 .init.text 00000000 l d *ABS* 00000000 .rela.init.text 00000000 l d .exit.text 00000000 .exit.text 00000000 l d *ABS* 00000000 .rela.exit.text 00000000 l d .rodata 00000000 .rodata 00000000 l d .modinfo 00000000 .modinfo 00000000 l d .rodata.str1.4 00000000 .rodata.str1.4 00000000 l d .data 00000000 .data 00000000 l d *ABS* 00000000 .rela.data 00000000 l d .gnu.linkonce.this_module 00000000 .gnu.linkonce.this_module 00000000 l d *ABS* 00000000 .rela.gnu.linkonce.this_module 00000000 l d .sbss 00000000 .sbss 00000000 l d .plt 00000000 .plt 00000000 l d .bss 00000000 .bss 00000000 l d .init.plt 00000000 .init.plt 00000000 l d .comment 00000000 .comment 00000000 l d .note.GNU-stack 00000000 .note.GNU-stack 00000000 l d *ABS* 00000000 .shstrtab 00000000 l d *ABS* 00000000 .symtab 00000000 l d *ABS* 00000000 .strtab 00000000 l df *ABS* 00000000 ump2ChannelDrv.c 00000000 l F .init.text 0000052c ump_channel_drv_init 00000000 l F .exit.text 000001b4 ump_channel_drv_exit 00000400 l F .text 00000518 ReaderTaskletFct 00000000 l F .text 000002bc Ppc2IsaProcReadDbg 000002bc l F .text 00000144 Ppc2IsaProcWriteDbg 00000000 l O .modinfo 00000073 __mod_description225 00000074 l O .modinfo 0000007d __mod_author221 000000f4 l O .modinfo 0000000c __mod_license1966 00000008 l O .sbss 00000004 pProcEntryDbg 0000000c l O .sbss 00000004 pProcEntry 0000008c l O .data 0000006c ump_channel_fops 00000a90 l F .text 000001a0 ump2channel_read 00000c30 l F .text 00000368 channel2ump_write 00000f98 l F .text 0000001c channel2ump_ioctl 00000fb4 l F .text 0000008c ump_channel_open 00001040 l F .text 00000058 ump_channel_release 00000000 l O .bss 00000300 ProcOutBuffer.2 00000000 l O .rodata 00000014 __PRETTY_FUNCTION__.0 00000300 l O .bss 00000100 ProcInBuffer.1 00000014 l O .rodata 00000011 __PRETTY_FUNCTION__.3 00000010 l O .sbss 00000004 pCurrentDataDest.4 00000400 l O .bss 000004b0 UMPChannelsRD 00000028 l O .rodata 0000000c __PRETTY_FUNCTION__.9 00000918 l F .text 00000178 isa2ppc_isr 00000034 l O .rodata 00000011 __PRETTY_FUNCTION__.7 00000048 l O .rodata 00000014 __PRETTY_FUNCTION__.6 0000005c l O .rodata 00000015 __PRETTY_FUNCTION__.8 000008b0 l O .bss 00000730 ump_channel_dev 00000074 l O .rodata 00000015 __PRETTY_FUNCTION__.5 00000400 l O .bss 00000000 UmpDrvMutex 00000000 l df *ABS* 00000000 ppc2isa.mod.c 00000100 l O .modinfo 00000009 __module_depends 0000010c l O .modinfo 00000034 __mod_vermagic5 00000000 *UND* 00000000 free_irq 00000080 g O .data 0000000c FpgaDpramRx_Semaphore 00000000 *UND* 00000000 misc_deregister 00000000 *UND* 00000000 pRsdpqXHwCtrl 00000000 g O .gnu.linkonce.this_module 00000120 __this_module 00000000 *UND* 00000000 __symbol_put 00000018 g O .sbss 00000004 pFpgaDpramRxBuff 00000000 *UND* 00000000 finish_wait 00000000 g F .exit.text 000001b4 cleanup_module 00000000 *UND* 00000000 prepare_to_wait 00000000 *UND* 00000000 memcpy 00000000 *UND* 00000000 kfree 00000000 *UND* 00000000 __wake_up 00000000 g O .data 00000014 ReaderTasklet 00000000 g F .init.text 0000052c init_module 00000000 *UND* 00000000 create_proc_entry 00000000 *UND* 00000000 schedule 00000000 *UND* 00000000 request_irq 00000050 g O .sbss 00000004 no_of_bytes_left 00000030 g O .sbss 00000004 rx_buffer_size 00000000 *UND* 00000000 kmem_cache_alloc 00000058 g O .sbss 00000004 message_queue_state 0000002c g O .sbss 00000004 tx_buffer_size 00000000 *UND* 00000000 __symbol_get 00000014 g O .sbss 00000004 pFpgaDpramTxBuff 00000000 *UND* 00000000 preempt_schedule 00000028 g O .sbss 00000004 pFpgaRxIrq 00000000 *UND* 00000000 strstr 00000000 g O .sbss 00000004 echo_test_on_at 0000003c g O .sbss 00000004 read_int_event 00000000 *UND* 00000000 printk 00000048 g O .sbss 00000004 new_message_available 00000000 *UND* 00000000 __copy_tofrom_user 00000000 *UND* 00000000 _ctype 00000000 *UND* 00000000 proc_mkdir 00000004 g O .sbss 00000004 pCurrentUmpMsg 00000000 *UND* 00000000 memset 00000000 *UND* 00000000 misc_register 0000001c g O .sbss 00000004 pFpgaTxMbx 00000044 g O .sbss 00000004 write_message_id 00000000 *UND* 00000000 sprintf 00000000 *UND* 00000000 __up 00000034 g O .sbss 00000008 write_wait_queue 00000000 *UND* 00000000 remove_proc_entry 0000005c g O .sbss 00000004 total_ump_msg_cnt_atomic 0000004c g O .sbss 00000004 msg_data_blen 00000000 *UND* 00000000 __tasklet_hi_schedule 00000014 g O .data 0000006c Ppc2IsaProcFileOpsDbg 00000000 *UND* 00000000 malloc_sizes 00000000 *UND* 00000000 __down_interruptible 00000000 *UND* 00000000 autoremove_wake_function 00000000 *UND* 00000000 strlen 00000054 g O .sbss 00000004 expected_segment_no 00000040 g O .sbss 00000004 write_int_event 00000024 g O .sbss 00000004 pFpgaTxIrq 00000020 g O .sbss 00000004 pFpgaRxMbx 00000000 *UND* 00000000 __kmalloc RELOCATION RECORDS FOR [.text]: OFFSET TYPE VALUE 0000000e R_PPC_ADDR16_HA .bss 00000016 R_PPC_ADDR16_LO .bss 0000001e R_PPC_ADDR16_HA .rodata.str1.4 00000034 R_PPC_REL24 memset 0000003e R_PPC_ADDR16_LO .rodata.str1.4 00000040 R_PPC_REL24 sprintf 00000046 R_PPC_ADDR16_HA .rodata.str1.4+0x00000004 0000004e R_PPC_ADDR16_HA .rodata.str1.4+0x00000010 00000052 R_PPC_ADDR16_HA .rodata.str1.4+0x00000018 00000056 R_PPC_ADDR16_HA .rodata.str1.4+0x00000024 0000005a R_PPC_ADDR16_LO .rodata.str1.4+0x00000004 0000005e R_PPC_ADDR16_LO .rodata.str1.4+0x00000010 00000062 R_PPC_ADDR16_LO .rodata.str1.4+0x00000018 00000066 R_PPC_ADDR16_LO .rodata.str1.4+0x00000024 0000006c R_PPC_REL24 sprintf 00000072 R_PPC_ADDR16_LO .rodata.str1.4 0000007c R_PPC_REL24 sprintf 00000082 R_PPC_ADDR16_HA .rodata.str1.4+0x0000004c 0000008a R_PPC_ADDR16_LO .rodata.str1.4+0x0000004c 00000090 R_PPC_REL24 sprintf 00000096 R_PPC_ADDR16_HA pFpgaDpramTxBuff 0000009a R_PPC_ADDR16_HA tx_buffer_size 0000009e R_PPC_ADDR16_LO pFpgaDpramTxBuff 000000a2 R_PPC_ADDR16_LO tx_buffer_size 000000aa R_PPC_ADDR16_HA .rodata.str1.4+0x0000005c 000000ae R_PPC_ADDR16_LO .rodata.str1.4+0x0000005c 000000b4 R_PPC_REL24 sprintf 000000ba R_PPC_ADDR16_HA pFpgaDpramRxBuff 000000be R_PPC_ADDR16_HA rx_buffer_size 000000c2 R_PPC_ADDR16_LO pFpgaDpramRxBuff 000000c6 R_PPC_ADDR16_LO rx_buffer_size 000000ce R_PPC_ADDR16_HA .rodata.str1.4+0x00000088 000000d2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000088 000000d8 R_PPC_REL24 sprintf 000000de R_PPC_ADDR16_HA pFpgaTxIrq 000000e2 R_PPC_ADDR16_HA pFpgaRxIrq 000000e6 R_PPC_ADDR16_LO pFpgaTxIrq 000000ea R_PPC_ADDR16_LO pFpgaRxIrq 000000f2 R_PPC_ADDR16_HA .rodata.str1.4+0x000000b4 000000f6 R_PPC_ADDR16_LO .rodata.str1.4+0x000000b4 000000fc R_PPC_REL24 sprintf 00000102 R_PPC_ADDR16_HA pFpgaTxMbx 00000106 R_PPC_ADDR16_HA pFpgaRxMbx 0000010a R_PPC_ADDR16_LO pFpgaTxMbx 0000010e R_PPC_ADDR16_LO pFpgaRxMbx 00000116 R_PPC_ADDR16_HA .rodata.str1.4+0x000000e4 0000011a R_PPC_ADDR16_LO .rodata.str1.4+0x000000e4 00000120 R_PPC_REL24 sprintf 00000126 R_PPC_ADDR16_HA expected_segment_no 0000012a R_PPC_ADDR16_LO expected_segment_no 00000132 R_PPC_ADDR16_HA .rodata.str1.4+0x00000114 00000136 R_PPC_ADDR16_LO .rodata.str1.4+0x00000114 0000013c R_PPC_REL24 sprintf 00000142 R_PPC_ADDR16_HA total_ump_msg_cnt_atomic 00000146 R_PPC_ADDR16_LO total_ump_msg_cnt_atomic 0000014e R_PPC_ADDR16_HA .rodata.str1.4+0x00000134 00000152 R_PPC_ADDR16_LO .rodata.str1.4+0x00000134 00000158 R_PPC_REL24 sprintf 0000015e R_PPC_ADDR16_HA message_queue_state 00000162 R_PPC_ADDR16_LO message_queue_state 0000016a R_PPC_ADDR16_HA .rodata.str1.4+0x0000015c 0000016e R_PPC_ADDR16_LO .rodata.str1.4+0x0000015c 00000174 R_PPC_REL24 sprintf 0000017a R_PPC_ADDR16_HA FpgaDpramRx_Semaphore 0000017e R_PPC_ADDR16_LO FpgaDpramRx_Semaphore 00000186 R_PPC_ADDR16_HA .rodata.str1.4+0x00000180 0000018a R_PPC_ADDR16_LO .rodata.str1.4+0x00000180 00000190 R_PPC_REL24 sprintf 00000196 R_PPC_ADDR16_HA echo_test_on_at 0000019a R_PPC_ADDR16_LO echo_test_on_at 000001a2 R_PPC_ADDR16_HA .rodata.str1.4+0x000001a4 000001a6 R_PPC_ADDR16_LO .rodata.str1.4+0x000001a4 000001ac R_PPC_REL24 sprintf 000001b2 R_PPC_ADDR16_HA .rodata.str1.4+0x000001c0 000001ba R_PPC_ADDR16_HA .rodata.str1.4+0x000001e8 000001be R_PPC_ADDR16_HA .rodata.str1.4+0x000001f8 000001c2 R_PPC_ADDR16_LO .rodata.str1.4+0x000001f8 000001c6 R_PPC_ADDR16_LO .rodata.str1.4+0x000001c0 000001ca R_PPC_ADDR16_LO .rodata.str1.4+0x000001e8 000001d0 R_PPC_REL24 sprintf 000001d6 R_PPC_ADDR16_LO .rodata.str1.4 000001e0 R_PPC_REL24 sprintf 000001e6 R_PPC_ADDR16_LO .bss 00000264 R_PPC_REL24 memcpy 000002ca R_PPC_ADDR16_HA .bss+0x00000300 000002d2 R_PPC_ADDR16_LO .bss+0x00000300 000002f0 R_PPC_REL24 memcpy 000002f6 R_PPC_ADDR16_HA .rodata.str1.4+0x000001fc 000002fa R_PPC_ADDR16_LO .rodata.str1.4+0x000001fc 0000030c R_PPC_REL24 strlen 00000344 R_PPC_REL24 strstr 0000035a R_PPC_ADDR16_HA _ctype 00000366 R_PPC_ADDR16_LO _ctype 0000039e R_PPC_ADDR16_HA .rodata.str1.4+0x00000204 000003a2 R_PPC_ADDR16_HA .rodata 000003ae R_PPC_ADDR16_LO .rodata.str1.4+0x00000204 000003b2 R_PPC_ADDR16_LO .rodata 000003b8 R_PPC_REL24 printk 000003be R_PPC_ADDR16_HA echo_test_on_at 000003c2 R_PPC_ADDR16_LO echo_test_on_at 000003de R_PPC_ADDR16_HA .rodata.str1.4+0x00000224 000003e2 R_PPC_ADDR16_HA .rodata 000003e6 R_PPC_ADDR16_LO .rodata 000003f6 R_PPC_ADDR16_LO .rodata.str1.4+0x00000224 000003f8 R_PPC_REL24 printk 0000040e R_PPC_ADDR16_HA write_int_event 00000416 R_PPC_ADDR16_LO write_int_event 00000422 R_PPC_ADDR16_HA pFpgaDpramTxBuff 00000426 R_PPC_ADDR16_LO pFpgaDpramTxBuff 0000042a R_PPC_ADDR16_HA expected_segment_no 0000042e R_PPC_ADDR16_LO expected_segment_no 00000442 R_PPC_ADDR16_HA .rodata+0x00000014 00000446 R_PPC_ADDR16_HA .rodata.str1.4+0x00000254 0000044a R_PPC_ADDR16_LO .rodata.str1.4+0x00000254 0000044e R_PPC_ADDR16_LO .rodata+0x00000014 00000454 R_PPC_REL24 printk 0000045e R_PPC_ADDR16_LO pFpgaDpramTxBuff 00000462 R_PPC_ADDR16_LO expected_segment_no 00000472 R_PPC_ADDR16_HA .rodata.str1.4+0x000002b4 00000476 R_PPC_ADDR16_LO .rodata.str1.4+0x000002b4 0000047a R_PPC_ADDR16_LO .rodata+0x00000014 00000480 R_PPC_REL24 printk 00000486 R_PPC_ADDR16_LO pFpgaDpramTxBuff 00000496 R_PPC_ADDR16_HA tx_buffer_size 0000049a R_PPC_ADDR16_LO tx_buffer_size 0000049e R_PPC_ADDR16_HA no_of_bytes_left 000004ae R_PPC_ADDR16_LO no_of_bytes_left 000004c6 R_PPC_ADDR16_LO no_of_bytes_left 000004ee R_PPC_ADDR16_HA .sbss+0x00000010 000004f2 R_PPC_ADDR16_LO .sbss+0x00000010 00000506 R_PPC_ADDR16_LO .sbss+0x00000010 0000052a R_PPC_ADDR16_LO no_of_bytes_left 00000536 R_PPC_ADDR16_HA pCurrentUmpMsg 0000053a R_PPC_ADDR16_LO expected_segment_no 0000053e R_PPC_ADDR16_LO pCurrentUmpMsg 00000542 R_PPC_ADDR16_HA .bss+0x00000400 00000546 R_PPC_ADDR16_LO .bss+0x00000400 0000054e R_PPC_ADDR16_HA total_ump_msg_cnt_atomic 00000552 R_PPC_ADDR16_LO total_ump_msg_cnt_atomic 000005ca R_PPC_ADDR16_LO total_ump_msg_cnt_atomic 000005d6 R_PPC_ADDR16_LO pCurrentUmpMsg 000005da R_PPC_ADDR16_HA .bss+0x00000428 000005de R_PPC_ADDR16_LO .bss+0x00000428 00000602 R_PPC_ADDR16_LO pCurrentUmpMsg 00000620 R_PPC_REL24 __wake_up 00000626 R_PPC_ADDR16_LO pCurrentUmpMsg 0000062e R_PPC_ADDR16_LO write_int_event 00000642 R_PPC_ADDR16_HA pFpgaTxMbx 00000646 R_PPC_ADDR16_LO pFpgaTxMbx 0000064a R_PPC_ADDR16_HA pFpgaRxIrq 00000656 R_PPC_ADDR16_LO pFpgaRxIrq 0000068a R_PPC_ADDR16_HA pCurrentUmpMsg 0000068e R_PPC_ADDR16_LO pCurrentUmpMsg 0000069a R_PPC_ADDR16_HA .rodata.str1.4+0x000002e4 0000069e R_PPC_ADDR16_HA .rodata+0x00000014 000006a2 R_PPC_ADDR16_LO .rodata.str1.4+0x000002e4 000006a6 R_PPC_ADDR16_LO .rodata+0x00000014 000006ac R_PPC_REL24 printk 000006b2 R_PPC_ADDR16_LO pCurrentUmpMsg 000006b8 R_PPC_REL24 kfree 000006d6 R_PPC_ADDR16_LO pFpgaDpramTxBuff 000006e2 R_PPC_ADDR16_LO pCurrentUmpMsg 0000071a R_PPC_ADDR16_LO pCurrentUmpMsg 0000071e R_PPC_ADDR16_HA pCurrentUmpMsg 0000073e R_PPC_ADDR16_HA no_of_bytes_left 00000752 R_PPC_ADDR16_LO no_of_bytes_left 00000754 R_PPC_REL24 __kmalloc 0000075e R_PPC_ADDR16_HA tx_buffer_size 00000762 R_PPC_ADDR16_LO pCurrentUmpMsg 00000766 R_PPC_ADDR16_LO tx_buffer_size 00000772 R_PPC_ADDR16_LO no_of_bytes_left 0000077a R_PPC_ADDR16_LO pFpgaDpramTxBuff 0000077e R_PPC_ADDR16_HA .sbss+0x00000010 00000782 R_PPC_ADDR16_LO .sbss+0x00000010 00000796 R_PPC_ADDR16_LO expected_segment_no 000007a6 R_PPC_ADDR16_HA no_of_bytes_left 000007aa R_PPC_ADDR16_LO expected_segment_no 000007ae R_PPC_ADDR16_LO no_of_bytes_left 000007b6 R_PPC_ADDR16_HA .rodata.str1.4+0x00000334 000007ba R_PPC_ADDR16_LO .rodata+0x00000014 000007c2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000334 000007c4 R_PPC_REL24 printk 000007ca R_PPC_ADDR16_LO write_int_event 000007de R_PPC_ADDR16_HA pFpgaTxMbx 000007e2 R_PPC_ADDR16_LO pFpgaTxMbx 000007e6 R_PPC_ADDR16_HA pFpgaRxIrq 000007f2 R_PPC_ADDR16_LO pFpgaRxIrq 0000080e R_PPC_ADDR16_HA malloc_sizes+0x00000004 00000812 R_PPC_ADDR16_LO malloc_sizes+0x00000004 00000818 R_PPC_REL24 kmem_cache_alloc 0000081e R_PPC_ADDR16_LO pCurrentUmpMsg 0000083c R_PPC_REL24 preempt_schedule 00000846 R_PPC_ADDR16_HA .rodata.str1.4+0x00000360 0000084a R_PPC_ADDR16_HA .rodata+0x00000014 0000084e R_PPC_ADDR16_LO .rodata.str1.4+0x00000360 00000852 R_PPC_ADDR16_LO .rodata+0x00000014 0000085c R_PPC_REL24 printk 00000862 R_PPC_ADDR16_HA no_of_bytes_left 0000086a R_PPC_ADDR16_HA message_queue_state 0000086e R_PPC_ADDR16_LO message_queue_state 00000872 R_PPC_ADDR16_HA .rodata.str1.4+0x000003b4 00000876 R_PPC_ADDR16_HA .rodata+0x00000014 0000087e R_PPC_ADDR16_LO .rodata+0x00000014 00000882 R_PPC_ADDR16_LO message_queue_state 0000088e R_PPC_ADDR16_LO .rodata.str1.4+0x000003b4 00000890 R_PPC_REL24 printk 0000089a R_PPC_ADDR16_HA .rodata.str1.4+0x0000040c 0000089e R_PPC_ADDR16_HA .rodata+0x00000014 000008a2 R_PPC_ADDR16_LO .rodata+0x00000014 000008ae R_PPC_ADDR16_LO .rodata.str1.4+0x0000040c 000008b0 R_PPC_REL24 printk 000008b8 R_PPC_REL24 preempt_schedule 000008c2 R_PPC_ADDR16_HA .rodata+0x00000014 000008c6 R_PPC_ADDR16_HA .rodata.str1.4+0x00000460 000008ca R_PPC_ADDR16_LO .rodata+0x00000014 000008d6 R_PPC_ADDR16_LO .rodata.str1.4+0x00000460 000008d8 R_PPC_REL24 printk 000008de R_PPC_ADDR16_HA .rodata.str1.4+0x000004ac 000008e2 R_PPC_ADDR16_LO .rodata+0x00000014 000008e6 R_PPC_ADDR16_LO .rodata.str1.4+0x000004ac 000008f0 R_PPC_REL24 printk 000008f6 R_PPC_ADDR16_LO pCurrentUmpMsg 00000902 R_PPC_ADDR16_LO pCurrentUmpMsg 00000908 R_PPC_REL24 preempt_schedule 00000910 R_PPC_REL24 preempt_schedule 0000092a R_PPC_ADDR16_HA pFpgaTxIrq 0000092e R_PPC_ADDR16_LO pFpgaTxIrq 0000093a R_PPC_ADDR16_HA pFpgaTxMbx 00000942 R_PPC_ADDR16_LO pFpgaTxMbx 0000095e R_PPC_ADDR16_HA pFpgaRxMbx 00000962 R_PPC_ADDR16_LO pFpgaRxMbx 00000966 R_PPC_ADDR16_HA write_wait_queue 0000096a R_PPC_ADDR16_HA .rodata+0x00000028 00000972 R_PPC_ADDR16_LO write_wait_queue 0000098e R_PPC_ADDR16_HA .rodata.str1.4+0x000004e8 00000992 R_PPC_ADDR16_LO .rodata.str1.4+0x000004e8 00000996 R_PPC_ADDR16_LO .rodata+0x00000028 000009b8 R_PPC_REL24 __wake_up 000009ca R_PPC_ADDR16_HA read_int_event 000009ce R_PPC_ADDR16_HA .rodata.str1.4+0x000004e8 000009d2 R_PPC_ADDR16_LO read_int_event 000009d6 R_PPC_ADDR16_LO .rodata.str1.4+0x000004e8 000009da R_PPC_ADDR16_LO .rodata+0x00000028 000009e4 R_PPC_REL24 printk 000009ea R_PPC_ADDR16_LO pFpgaTxMbx 000009ee R_PPC_ADDR16_HA .rodata.str1.4+0x00000518 000009f6 R_PPC_ADDR16_LO .rodata+0x00000028 000009fe R_PPC_ADDR16_LO .rodata.str1.4+0x00000518 00000a00 R_PPC_REL24 printk 00000a06 R_PPC_ADDR16_LO pFpgaRxMbx 00000a0a R_PPC_ADDR16_HA .rodata.str1.4+0x00000548 00000a12 R_PPC_ADDR16_LO .rodata+0x00000028 00000a16 R_PPC_ADDR16_LO .rodata.str1.4+0x00000548 00000a1c R_PPC_REL24 printk 00000a3a R_PPC_ADDR16_HA message_queue_state 00000a3e R_PPC_ADDR16_LO message_queue_state 00000a42 R_PPC_ADDR16_HA ReaderTasklet 00000a46 R_PPC_ADDR16_LO ReaderTasklet 00000a5a R_PPC_ADDR16_HA write_int_event 00000a5e R_PPC_ADDR16_LO write_int_event 00000a84 R_PPC_REL24 __tasklet_hi_schedule 00000ada R_PPC_ADDR16_HA autoremove_wake_function 00000aea R_PPC_ADDR16_LO autoremove_wake_function 00000b14 R_PPC_REL24 schedule 00000b24 R_PPC_REL24 prepare_to_wait 00000b40 R_PPC_REL24 finish_wait 00000b5c R_PPC_REL24 kfree 00000b70 R_PPC_REL24 __copy_tofrom_user 00000b80 R_PPC_REL24 kfree 00000b92 R_PPC_ADDR16_HA total_ump_msg_cnt_atomic 00000b9a R_PPC_ADDR16_LO total_ump_msg_cnt_atomic 00000bb6 R_PPC_ADDR16_HA message_queue_state 00000bba R_PPC_ADDR16_LO message_queue_state 00000bc6 R_PPC_ADDR16_LO total_ump_msg_cnt_atomic 00000bea R_PPC_ADDR16_HA ReaderTasklet 00000bf2 R_PPC_ADDR16_LO ReaderTasklet 00000bf6 R_PPC_ADDR16_LO message_queue_state 00000bfe R_PPC_ADDR16_HA write_int_event 00000c02 R_PPC_ADDR16_LO write_int_event 00000c20 R_PPC_REL24 __tasklet_hi_schedule 00000c66 R_PPC_ADDR16_HA echo_test_on_at 00000c6a R_PPC_ADDR16_LO echo_test_on_at 00000c7a R_PPC_ADDR16_HA FpgaDpramRx_Semaphore 00000c7e R_PPC_ADDR16_LO FpgaDpramRx_Semaphore 00000cae R_PPC_ADDR16_HA read_int_event 00000cba R_PPC_ADDR16_LO read_int_event 00000cca R_PPC_ADDR16_HA autoremove_wake_function 00000cda R_PPC_ADDR16_LO autoremove_wake_function 00000ce2 R_PPC_ADDR16_HA write_wait_queue 00000d00 R_PPC_REL24 schedule 00000d06 R_PPC_ADDR16_LO write_wait_queue 00000d10 R_PPC_REL24 prepare_to_wait 00000d16 R_PPC_ADDR16_LO read_int_event 00000d22 R_PPC_ADDR16_LO write_wait_queue 00000d28 R_PPC_REL24 finish_wait 00000d46 R_PPC_ADDR16_HA pFpgaDpramRxBuff 00000d4a R_PPC_ADDR16_LO pFpgaDpramRxBuff 00000d4e R_PPC_ADDR16_HA pFpgaDpramRxBuff 00000d5a R_PPC_ADDR16_HA echo_test_on_at 00000d5e R_PPC_ADDR16_LO echo_test_on_at 00000d6a R_PPC_ADDR16_LO pFpgaDpramRxBuff 00000d7a R_PPC_ADDR16_LO pFpgaDpramRxBuff 00000d82 R_PPC_ADDR16_LO pFpgaDpramRxBuff 00000d96 R_PPC_ADDR16_LO pFpgaDpramRxBuff 00000da2 R_PPC_ADDR16_HA rx_buffer_size 00000da6 R_PPC_ADDR16_LO pFpgaDpramRxBuff 00000daa R_PPC_ADDR16_LO rx_buffer_size 00000de6 R_PPC_ADDR16_HA pFpgaRxMbx 00000dea R_PPC_ADDR16_LO pFpgaRxMbx 00000df6 R_PPC_ADDR16_LO read_int_event 00000dfa R_PPC_ADDR16_HA pFpgaRxIrq 00000e02 R_PPC_ADDR16_LO pFpgaRxIrq 00000e2e R_PPC_ADDR16_LO FpgaDpramRx_Semaphore 00000eba R_PPC_ADDR16_HA rx_buffer_size 00000ebe R_PPC_ADDR16_LO pFpgaDpramRxBuff 00000ec2 R_PPC_ADDR16_LO rx_buffer_size 00000ed6 R_PPC_ADDR16_HA write_message_id 00000eda R_PPC_ADDR16_LO pFpgaDpramRxBuff 00000ee6 R_PPC_ADDR16_LO pFpgaDpramRxBuff 00000eee R_PPC_ADDR16_LO pFpgaDpramRxBuff 00000ef6 R_PPC_ADDR16_LO write_message_id 00000efa R_PPC_ADDR16_LO pFpgaDpramRxBuff 00000f06 R_PPC_ADDR16_LO write_message_id 00000f10 R_PPC_REL24 __up 00000f1e R_PPC_ADDR16_LO write_wait_queue 00000f24 R_PPC_REL24 finish_wait 00000f36 R_PPC_ADDR16_LO pFpgaDpramRxBuff 00000f54 R_PPC_REL24 __down_interruptible 00000f7c R_PPC_REL24 preempt_schedule 00000f8c R_PPC_REL24 __up 00000fce R_PPC_ADDR16_HA .rodata+0x00000034 00000fd2 R_PPC_ADDR16_HA .rodata.str1.4+0x00000578 00000fda R_PPC_ADDR16_LO .rodata.str1.4+0x00000578 00000fde R_PPC_ADDR16_LO .rodata+0x00000034 00000fe8 R_PPC_REL24 printk 00000ff6 R_PPC_ADDR16_HA .bss+0x00000400 00000ffa R_PPC_ADDR16_LO .bss+0x00000400 00001052 R_PPC_ADDR16_HA .rodata+0x00000048 0000105a R_PPC_ADDR16_HA .rodata.str1.4+0x000005a8 0000105e R_PPC_ADDR16_LO .rodata.str1.4+0x000005a8 00001066 R_PPC_ADDR16_LO .rodata+0x00000048 00001070 R_PPC_REL24 printk RELOCATION RECORDS FOR [.init.text]: OFFSET TYPE VALUE 0000000e R_PPC_ADDR16_HA .rodata.str1.4+0x00000010 00000016 R_PPC_ADDR16_HA .rodata+0x0000005c 0000001a R_PPC_ADDR16_HA .rodata.str1.4+0x00000018 0000001e R_PPC_ADDR16_HA .rodata.str1.4+0x00000004 00000022 R_PPC_ADDR16_HA .rodata.str1.4+0x000005d8 00000026 R_PPC_ADDR16_LO .rodata.str1.4+0x00000010 0000002a R_PPC_ADDR16_LO .rodata.str1.4+0x00000018 0000002e R_PPC_ADDR16_LO .rodata.str1.4+0x00000004 00000032 R_PPC_ADDR16_LO .rodata+0x0000005c 0000003a R_PPC_ADDR16_LO .rodata.str1.4+0x000005d8 0000003e R_PPC_ADDR16_HA .rodata.str1.4+0x00000628 00000040 R_PPC_REL24 printk 00000046 R_PPC_ADDR16_LO .rodata.str1.4+0x00000628 00000048 R_PPC_REL24 __symbol_get 0000005a R_PPC_ADDR16_HA pRsdpqXHwCtrl 0000005e R_PPC_ADDR16_LO pRsdpqXHwCtrl 00000062 R_PPC_ADDR16_HA .rodata.str1.4+0x00000638 00000066 R_PPC_ADDR16_LO .rodata+0x0000005c 00000076 R_PPC_ADDR16_LO .rodata.str1.4+0x00000638 00000080 R_PPC_REL24 printk 00000096 R_PPC_ADDR16_HA pFpgaDpramRxBuff 0000009a R_PPC_ADDR16_LO pFpgaDpramRxBuff 0000009e R_PPC_ADDR16_HA rx_buffer_size 000000a6 R_PPC_ADDR16_LO rx_buffer_size 000000b2 R_PPC_ADDR16_HA pFpgaRxIrq 000000b6 R_PPC_ADDR16_HA pFpgaDpramTxBuff 000000ba R_PPC_ADDR16_LO pFpgaRxIrq 000000be R_PPC_ADDR16_HA .rodata.str1.4+0x0000067c 000000c2 R_PPC_ADDR16_LO pFpgaDpramTxBuff 000000c6 R_PPC_ADDR16_HA pFpgaRxMbx 000000ce R_PPC_ADDR16_HA write_message_id 000000d2 R_PPC_ADDR16_LO pFpgaRxMbx 000000d6 R_PPC_ADDR16_HA tx_buffer_size 000000da R_PPC_ADDR16_LO write_message_id 000000e2 R_PPC_ADDR16_LO tx_buffer_size 000000ea R_PPC_ADDR16_LO .rodata.str1.4+0x0000067c 000000ee R_PPC_ADDR16_HA pFpgaTxMbx 000000f2 R_PPC_ADDR16_HA pFpgaTxIrq 000000f6 R_PPC_ADDR16_LO pFpgaTxMbx 000000fa R_PPC_ADDR16_LO .rodata+0x0000005c 000000fe R_PPC_ADDR16_LO pFpgaTxIrq 00000104 R_PPC_REL24 printk 0000010a R_PPC_ADDR16_HA write_wait_queue 0000010e R_PPC_ADDR16_LO write_wait_queue 00000112 R_PPC_ADDR16_LO pFpgaRxMbx 00000116 R_PPC_ADDR16_LO write_wait_queue 0000011a R_PPC_ADDR16_HA write_int_event 00000126 R_PPC_ADDR16_HA read_int_event 0000012a R_PPC_ADDR16_LO write_int_event 0000012e R_PPC_ADDR16_LO read_int_event 00000132 R_PPC_ADDR16_HA .bss+0x00000428 00000136 R_PPC_ADDR16_HA .bss+0x00000400 0000013e R_PPC_ADDR16_LO .bss+0x00000428 00000142 R_PPC_ADDR16_HA malloc_sizes 00000146 R_PPC_ADDR16_HA .bss+0x00000430 0000014a R_PPC_ADDR16_LO malloc_sizes 0000014e R_PPC_ADDR16_LO .bss+0x00000430 00000152 R_PPC_ADDR16_LO .bss+0x00000400 00000174 R_PPC_REL24 kmem_cache_alloc 000001ae R_PPC_ADDR16_HA FpgaDpramRx_Semaphore 000001b2 R_PPC_ADDR16_LO pFpgaTxIrq 000001b6 R_PPC_ADDR16_LO FpgaDpramRx_Semaphore 000001ba R_PPC_ADDR16_LO pFpgaTxMbx 000001be R_PPC_ADDR16_HA total_ump_msg_cnt_atomic 000001c2 R_PPC_ADDR16_HA expected_segment_no 000001c6 R_PPC_ADDR16_LO total_ump_msg_cnt_atomic 000001ca R_PPC_ADDR16_LO expected_segment_no 000001d2 R_PPC_ADDR16_HA pCurrentUmpMsg 000001da R_PPC_ADDR16_LO pCurrentUmpMsg 000001de R_PPC_ADDR16_HA message_queue_state 000001e2 R_PPC_ADDR16_LO FpgaDpramRx_Semaphore 000001e6 R_PPC_ADDR16_LO message_queue_state 0000020a R_PPC_ADDR16_HA .rodata.str1.4+0x000006b8 0000020e R_PPC_ADDR16_HA .text+0x00000918 00000212 R_PPC_ADDR16_HA .rodata.str1.4+0x000006c8 00000216 R_PPC_ADDR16_LO .text+0x00000918 0000021a R_PPC_ADDR16_LO .rodata.str1.4+0x000006c8 00000226 R_PPC_ADDR16_LO .rodata.str1.4+0x000006b8 00000228 R_PPC_REL24 request_irq 0000023a R_PPC_ADDR16_HA .rodata.str1.4+0x000001e8 0000023e R_PPC_ADDR16_LO .rodata.str1.4+0x000001e8 00000244 R_PPC_REL24 proc_mkdir 0000024a R_PPC_ADDR16_HA .sbss+0x0000000c 00000252 R_PPC_ADDR16_LO .sbss+0x0000000c 0000025a R_PPC_ADDR16_HA .rodata.str1.4+0x000001f8 00000266 R_PPC_ADDR16_LO .rodata.str1.4+0x000001f8 00000268 R_PPC_REL24 create_proc_entry 0000026e R_PPC_ADDR16_HA .sbss+0x00000008 00000276 R_PPC_ADDR16_LO .sbss+0x00000008 0000027e R_PPC_ADDR16_HA Ppc2IsaProcFileOpsDbg 00000282 R_PPC_ADDR16_LO Ppc2IsaProcFileOpsDbg 0000028a R_PPC_ADDR16_HA .bss+0x000008b0 0000028e R_PPC_ADDR16_HA .data+0x0000008c 00000292 R_PPC_ADDR16_LO .bss+0x000008b0 00000296 R_PPC_ADDR16_LO .data+0x0000008c 000002a2 R_PPC_ADDR16_HA .rodata.str1.4+0x000006d4 000002be R_PPC_ADDR16_LO .rodata.str1.4+0x000006d4 000002c2 R_PPC_ADDR16_LO .rodata.str1.4+0x000006b8 000002c8 R_PPC_REL24 sprintf 000002e4 R_PPC_REL24 misc_register 000002f6 R_PPC_ADDR16_HA .rodata.str1.4+0x000006dc 000002fa R_PPC_ADDR16_LO .rodata.str1.4+0x000006dc 000002fe R_PPC_ADDR16_LO .rodata+0x0000005c 00000308 R_PPC_REL24 printk 00000316 R_PPC_ADDR16_HA .bss+0x000008b0 0000031e R_PPC_ADDR16_LO .bss+0x000008b0 00000322 R_PPC_ADDR16_HA .rodata.str1.4+0x00000728 00000348 R_PPC_REL24 misc_deregister 0000034e R_PPC_ADDR16_LO .rodata+0x0000005c 0000035a R_PPC_ADDR16_LO .rodata.str1.4+0x00000728 00000364 R_PPC_REL24 printk 0000037a R_PPC_ADDR16_HA .bss+0x00000400 0000037e R_PPC_ADDR16_LO .bss+0x00000400 00000398 R_PPC_REL24 kfree 000003b8 R_PPC_REL24 kfree 000003d0 R_PPC_REL24 kfree 000003de R_PPC_ADDR16_HA .sbss+0x0000000c 000003e2 R_PPC_ADDR16_LO .sbss+0x0000000c 000003e6 R_PPC_ADDR16_LO .bss+0x00000400 000003fa R_PPC_ADDR16_HA .sbss+0x00000008 000003fe R_PPC_ADDR16_LO .sbss+0x00000008 0000040a R_PPC_ADDR16_HA .rodata.str1.4+0x000001e8 0000040e R_PPC_ADDR16_LO .rodata.str1.4+0x000001e8 00000414 R_PPC_REL24 remove_proc_entry 0000041a R_PPC_ADDR16_LO .rodata.str1.4+0x00000628 0000041c R_PPC_REL24 __symbol_put 00000422 R_PPC_ADDR16_HA .rodata.str1.4+0x00000778 00000426 R_PPC_ADDR16_LO .rodata.str1.4+0x00000778 0000042a R_PPC_ADDR16_LO .rodata+0x0000005c 00000430 R_PPC_REL24 printk 0000044e R_PPC_ADDR16_HA .rodata.str1.4+0x000007b4 00000452 R_PPC_ADDR16_LO .rodata.str1.4+0x000001e8 00000456 R_PPC_ADDR16_LO .rodata+0x0000005c 0000045e R_PPC_ADDR16_LO .rodata.str1.4+0x000007b4 00000460 R_PPC_REL24 printk 0000046a R_PPC_ADDR16_HA ReaderTasklet 0000046e R_PPC_ADDR16_LO write_int_event 00000472 R_PPC_ADDR16_LO ReaderTasklet 00000490 R_PPC_REL24 __tasklet_hi_schedule 0000049a R_PPC_ADDR16_HA .rodata.str1.4+0x000007e8 0000049e R_PPC_ADDR16_LO .rodata.str1.4+0x000007e8 000004a2 R_PPC_ADDR16_LO .rodata+0x0000005c 000004ae R_PPC_ADDR16_HA .rodata.str1.4+0x00000820 000004b2 R_PPC_ADDR16_LO .rodata.str1.4+0x000001e8 000004b6 R_PPC_ADDR16_LO .rodata.str1.4+0x000001f8 000004ba R_PPC_ADDR16_LO .rodata+0x0000005c 000004c2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000820 000004c4 R_PPC_REL24 printk 000004ce R_PPC_ADDR16_HA .rodata.str1.4+0x00000854 000004d2 R_PPC_ADDR16_LO .rodata+0x0000005c 000004e2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000854 000004e4 R_PPC_REL24 printk 000004ee R_PPC_ADDR16_HA .rodata.str1.4+0x000001f8 000004f2 R_PPC_ADDR16_LO .rodata.str1.4+0x000001f8 000004f4 R_PPC_REL24 remove_proc_entry 000004fe R_PPC_ADDR16_HA .rodata.str1.4+0x000008a4 00000502 R_PPC_ADDR16_LO .rodata+0x0000005c 0000050a R_PPC_ADDR16_LO .rodata.str1.4+0x000008a4 0000050c R_PPC_REL24 printk 00000512 R_PPC_ADDR16_HA .rodata.str1.4+0x000008e0 00000516 R_PPC_ADDR16_LO .rodata.str1.4+0x000008e0 0000051a R_PPC_ADDR16_LO .rodata+0x0000005c 00000520 R_PPC_REL24 printk RELOCATION RECORDS FOR [.exit.text]: OFFSET TYPE VALUE 0000000e R_PPC_ADDR16_HA .rodata.str1.4+0x0000091c 00000016 R_PPC_ADDR16_HA .rodata+0x00000074 0000001a R_PPC_ADDR16_HA .rodata.str1.4+0x00000010 0000001e R_PPC_ADDR16_HA .rodata.str1.4+0x00000018 00000022 R_PPC_ADDR16_HA .rodata.str1.4+0x00000004 00000026 R_PPC_ADDR16_LO .rodata.str1.4+0x0000091c 0000002a R_PPC_ADDR16_LO .rodata.str1.4+0x00000010 0000002e R_PPC_ADDR16_LO .rodata.str1.4+0x00000018 00000032 R_PPC_ADDR16_LO .rodata.str1.4+0x00000004 00000036 R_PPC_ADDR16_LO .rodata+0x00000074 0000003c R_PPC_REL24 printk 00000042 R_PPC_ADDR16_HA .bss+0x00000400 00000046 R_PPC_ADDR16_LO .bss+0x00000400 0000004a R_PPC_ADDR16_HA .bss+0x000008b0 0000004e R_PPC_ADDR16_LO .bss+0x000008b0 0000005a R_PPC_ADDR16_HA .data+0x0000008c 00000088 R_PPC_REL24 kfree 000000ac R_PPC_REL24 kfree 000000c0 R_PPC_REL24 kfree 000000d6 R_PPC_ADDR16_LO .data+0x0000008c 000000f0 R_PPC_REL24 misc_deregister 00000116 R_PPC_ADDR16_HA .rodata.str1.4+0x000006b8 0000011a R_PPC_ADDR16_LO .rodata.str1.4+0x000006b8 00000120 R_PPC_REL24 free_irq 00000126 R_PPC_ADDR16_HA .sbss+0x0000000c 0000012a R_PPC_ADDR16_LO .sbss+0x0000000c 00000136 R_PPC_ADDR16_HA .sbss+0x00000008 0000013a R_PPC_ADDR16_LO .sbss+0x00000008 00000146 R_PPC_ADDR16_HA .rodata.str1.4+0x000001e8 0000014a R_PPC_ADDR16_LO .rodata.str1.4+0x000001e8 00000150 R_PPC_REL24 remove_proc_entry 00000156 R_PPC_ADDR16_HA .rodata.str1.4+0x00000628 0000015a R_PPC_ADDR16_LO .rodata.str1.4+0x00000628 0000015c R_PPC_REL24 __symbol_put 00000162 R_PPC_ADDR16_HA .rodata.str1.4+0x0000096c 00000166 R_PPC_ADDR16_LO .rodata+0x00000074 0000016a R_PPC_ADDR16_LO .rodata.str1.4+0x0000096c 00000170 R_PPC_REL24 printk 0000018a R_PPC_ADDR16_HA .rodata.str1.4+0x00000728 0000018e R_PPC_ADDR16_LO .rodata+0x00000074 0000019a R_PPC_ADDR16_LO .rodata.str1.4+0x00000728 0000019c R_PPC_REL24 printk 000001a6 R_PPC_ADDR16_HA .rodata.str1.4+0x000001f8 000001aa R_PPC_ADDR16_LO .rodata.str1.4+0x000001f8 000001ac R_PPC_REL24 remove_proc_entry RELOCATION RECORDS FOR [.data]: OFFSET TYPE VALUE 0000000c R_PPC_ADDR32 .text+0x00000400 0000001c R_PPC_ADDR32 .text 00000024 R_PPC_ADDR32 .text+0x000002bc 00000084 R_PPC_ADDR32 FpgaDpramRx_Semaphore+0x00000004 00000088 R_PPC_ADDR32 FpgaDpramRx_Semaphore+0x00000004 0000008c R_PPC_ADDR32 __this_module 00000094 R_PPC_ADDR32 .text+0x00000a90 0000009c R_PPC_ADDR32 .text+0x00000c30 000000ac R_PPC_ADDR32 .text+0x00000f98 000000bc R_PPC_ADDR32 .text+0x00000fb4 000000c4 R_PPC_ADDR32 .text+0x00001040 RELOCATION RECORDS FOR [.gnu.linkonce.this_module]: OFFSET TYPE VALUE 000000a4 R_PPC_ADDR32 init_module 0000010c R_PPC_ADDR32 cleanup_module >strings ppc2isa.ko @@9J HP9k (}I[x} }@Sxp (}jKx}@ } Kx9) .}#Kx .}#Kx (}+#x}` }#Kx t8c l8 Ppc2IsaProcWriteDbg ReaderTaskletFct isa2ppc_isr ump_channel_open ump_channel_release ump_channel_drv_init ump_channel_drv_exit description= UMP-Protocol DPRAM driver providing multiple channel interface services to the FSW running on CMU-FMR author= -* Copyright (c) 2002-2009 Rohde & Schwarz **********- -* Vlad Perianu, Waldemar Bittner, Hartmut Schaefer - 1CM2 *- license=GPL depends= vermagic=2.6.12.6-elinos-226-rsdpq2 preempt gcc-3.4 Sep 2 2009 V2.2 09:27:14 PPC2ISA driver -> %s [build %s - %s] Addresses: pFpgaDpramTxBuff = 0x%08X [%d bytes] pFpgaDpramRxBuff = 0x%08X [%d bytes] pFpgaTxIrq = 0x%08X - pFpgaRxIrq = 0x%08X pFpgaTxMbx = 0x%08X - pFpgaRxMbx = 0x%08X expected_segment_no = %d total_ump_msg_cnt_atomic = %08X message_queue_state = %08X FpgaDpramRx_Semaphore = %08X echo_test_on_at = %d set with 'echo "echo=1|0" > %s%s' driver/ppc2isa echo= <3>ppc2isa: %-13s [%4d]: %s%d <3>ppc2isa: %-13s [%4d]: unknown command: %s%d <3>ppc2isa: %-13s [%4d]: UMP protocol error : wrong segment no received %d, expected was %d <3>ppc2isa: %-13s [%4d]: resynchronising ... <3>ppc2isa: %-13s [%4d]: UMP protocol error : last message not completed ! <3>ppc2isa: %-13s [%4d]: data discarded <3>ppc2isa: %-13s [%4d]: message destination id %d > %d (max) -> data discared ! <3>ppc2isa: %-13s [%4d]: WARNING :-> max no of %d messages on all channels reached <3>ppc2isa: %-13s [%4d]: WARNING :-> max no of %d messages on channel %d reached <3>ppc2isa: %-13s [%4d]: message received too big (len = %d > = %d (max) <3>ppc2isa: %-13s [%4d]: -> message truncated to len = %d <3>ppc2isa: %-13s [%4d]: interrupt 1 dropped <3>ppc2isa: %-13s [%4d]: pFpgaTxMbx == %8X <3>ppc2isa: %-13s [%4d]: pFpgaRxMbx == %8X <3>ppc2isa: %-13s [%4d]: open on channel %d <3>ppc2isa: %-13s [%4d]: close on channel %d <3>ppc2isa: %-13s [%4d]: Installing the PPC2ISA driver -> %s [build %s - %s] pRsdpqXHwCtrl <3>ppc2isa: %-13s [%4d]: DPRAM mapped to 0x%08X [size = 0x%X] <3>ppc2isa: %-13s [%4d]: DPR-IRQ:0x%08X, DPR-MBX:0x%08X UMP_ChannelDrv isa2ppc_isr %s%d <3>ppc2isa: %-13s [%4d]: Can't register UMP Channel device: /dev/misc/%s <3>ppc2isa: %-13s [%4d]: Can't de-register UMP Channel device: /dev/misc/%s <3>ppc2isa: %-13s [%4d]: Can't install PPC2ISA driver ! <3>ppc2isa: %-13s [%4d]: Can't create '/proc/%s <3>ppc2isa: %-13s [%4d]: PPC2ISA driver installed <3>ppc2isa: %-13s [%4d]: Can't create '/proc/%s/%s <3>ppc2isa: %-13s [%4d]: Can't register isa2ppc_isr for [IRQ1 @ 0x%02X]: %d <3>ppc2isa: %-13s [%4d]: PB-FPGA driver not installed ! <3>ppc2isa: %-13s [%4d]: Please load PB-FPGA LKM first. <3>ppc2isa: %-13s [%4d]: Uninstalling PPC2ISA driver -> %s [build %s - %s] <3>ppc2isa: %-13s [%4d]: PPC2ISA driver uninstalled ppc2isa GCC: (GNU) 3.4.4 (ELinOS V4.0 3.4.4-14 2005-12-05) GCC: (GNU) 3.4.4 (ELinOS V4.0 3.4.4-14 2005-12-05) .symtab .strtab .shstrtab .rela.text .rela.init.text .rela.exit.text .rodata .modinfo .rodata.str1.4 .rela.data .rela.gnu.linkonce.this_module .sbss .bss .init.plt .comment .note.GNU-stack ump2ChannelDrv.c ump_channel_drv_init ump_channel_drv_exit ReaderTaskletFct Ppc2IsaProcReadDbg Ppc2IsaProcWriteDbg __mod_description225 __mod_author221 __mod_license1966 pProcEntryDbg pProcEntry ump_channel_fops ump2channel_read channel2ump_write channel2ump_ioctl ump_channel_open ump_channel_release ProcOutBuffer.2 __PRETTY_FUNCTION__.0 ProcInBuffer.1 __PRETTY_FUNCTION__.3 pCurrentDataDest.4 UMPChannelsRD __PRETTY_FUNCTION__.9 isa2ppc_isr __PRETTY_FUNCTION__.7 __PRETTY_FUNCTION__.6 __PRETTY_FUNCTION__.8 ump_channel_dev __PRETTY_FUNCTION__.5 UmpDrvMutex ppc2isa.mod.c __module_depends __mod_vermagic5 free_irq FpgaDpramRx_Semaphore misc_deregister pRsdpqXHwCtrl __this_module __symbol_put pFpgaDpramRxBuff finish_wait cleanup_module prepare_to_wait memcpy kfree __wake_up ReaderTasklet init_module create_proc_entry schedule request_irq no_of_bytes_left rx_buffer_size kmem_cache_alloc message_queue_state tx_buffer_size __symbol_get pFpgaDpramTxBuff preempt_schedule pFpgaRxIrq strstr echo_test_on_at read_int_event printk new_message_available __copy_tofrom_user _ctype proc_mkdir pCurrentUmpMsg memset misc_register pFpgaTxMbx write_message_id sprintf __up write_wait_queue remove_proc_entry total_ump_msg_cnt_atomic msg_data_blen __tasklet_hi_schedule Ppc2IsaProcFileOpsDbg malloc_sizes __down_interruptible autoremove_wake_function strlen expected_segment_no write_int_event pFpgaTxIrq pFpgaRxMbx __kmalloc >objdump -x usudsp.ko usudsp.ko: file format elf32-powerpc usudsp.ko architecture: powerpc:common, flags 0x00000011: HAS_RELOC, HAS_SYMS start address 0x00000000 Sections: Idx Name Size VMA LMA File off Algn 0 .text 00000f18 00000000 00000000 00000034 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 1 .init.text 0000032c 00000000 00000000 00000f4c 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 2 .exit.text 00000120 00000000 00000000 00001278 2**2 CONTENTS, ALLOC, LOAD, RELOC, READONLY, CODE 3 .rodata 00000080 00000000 00000000 00001398 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 4 .modinfo 00000130 00000000 00000000 00001418 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 5 .rodata.str1.4 00000658 00000000 00000000 00001548 2**2 CONTENTS, ALLOC, LOAD, READONLY, DATA 6 .data 000000d8 00000000 00000000 00001ba0 2**2 CONTENTS, ALLOC, LOAD, RELOC, DATA 7 .gnu.linkonce.this_module 00000140 00000000 00000000 00001c80 2**5 CONTENTS, ALLOC, LOAD, RELOC, DATA, LINK_ONCE_DISCARD 8 .sbss 00000018 00000000 00000000 00001dc0 2**2 ALLOC 9 .plt 00000000 00000000 00000000 00001dc0 2**3 ALLOC, READONLY, CODE 10 .bss 00001bac 00000000 00000000 00001dc0 2**2 ALLOC 11 .init.plt 00000000 00000000 00000000 00001dc0 2**3 ALLOC, READONLY, CODE 12 .comment 00000068 00000000 00000000 00001dc0 2**0 CONTENTS, READONLY 13 .note.GNU-stack 00000000 00000000 00000000 00001e28 2**0 CONTENTS, READONLY SYMBOL TABLE: 00000000 l d .text 00000000 .text 00000000 l d *ABS* 00000000 .rela.text 00000000 l d .init.text 00000000 .init.text 00000000 l d *ABS* 00000000 .rela.init.text 00000000 l d .exit.text 00000000 .exit.text 00000000 l d *ABS* 00000000 .rela.exit.text 00000000 l d .rodata 00000000 .rodata 00000000 l d .modinfo 00000000 .modinfo 00000000 l d .rodata.str1.4 00000000 .rodata.str1.4 00000000 l d .data 00000000 .data 00000000 l d *ABS* 00000000 .rela.data 00000000 l d .gnu.linkonce.this_module 00000000 .gnu.linkonce.this_module 00000000 l d *ABS* 00000000 .rela.gnu.linkonce.this_module 00000000 l d .sbss 00000000 .sbss 00000000 l d .plt 00000000 .plt 00000000 l d .bss 00000000 .bss 00000000 l d .init.plt 00000000 .init.plt 00000000 l d .comment 00000000 .comment 00000000 l d .note.GNU-stack 00000000 .note.GNU-stack 00000000 l d *ABS* 00000000 .shstrtab 00000000 l d *ABS* 00000000 .symtab 00000000 l d *ABS* 00000000 .strtab 00000000 l df *ABS* 00000000 usudspdrv.c 00000000 l F .init.text 0000032c usudspdrv_init 00000000 l F .exit.text 00000120 usudspdrv_exit 00000000 l F .text 000001bc UsuDspProcReadDbg 000001bc l F .text 00000138 UsuDspProcWriteDbg 00000000 l O .modinfo 00000086 __mod_description206 00000088 l O .modinfo 0000005b __mod_author202 000000e4 l O .modinfo 0000000c __mod_license1966 00000004 l O .sbss 00000004 dbgwrite 0000006c l O .data 0000006c usudsp_fops 000007b8 l F .text 00000234 usudsp_read 000009ec l F .text 00000280 usudsp_write 00000c6c l F .text 00000094 usudsp_ioctl 00000d00 l F .text 000001a8 usudsp_open 00000ea8 l F .text 00000070 usudsp_close 00000008 l O .sbss 00000004 pProcEntryDbg 0000000c l O .sbss 00000004 pProcEntry 00000010 l O .sbss 00000004 ModUseCount 00000000 l O .bss 00000300 ProcOutBuffer.2 00000400 l O .bss 00001464 atUsuDspCtrls 00000000 l O .rodata 00000013 __PRETTY_FUNCTION__.0 00000300 l O .bss 00000100 ProcInBuffer.1 000002f4 l F .text 0000012c UsuDspIsr 00000014 l O .sbss 00000004 fpga_start 00000014 l O .rodata 0000000e __PRETTY_FUNCTION__.9 00000024 l O .rodata 00000011 __PRETTY_FUNCTION__.8 000004c0 l F .text 000000fc UsuDspTransIntBh 000005bc l F .text 000001fc UsuDspReceiveIntBh 00000038 l O .rodata 0000000c __PRETTY_FUNCTION__.6 00000044 l O .rodata 0000000d __PRETTY_FUNCTION__.5 00000054 l O .rodata 0000000c __PRETTY_FUNCTION__.4 00000060 l O .rodata 0000000f __PRETTY_FUNCTION__.7 000019e0 l O .bss 000001cc usudsp_dev 00000070 l O .rodata 0000000f __PRETTY_FUNCTION__.3 00000000 l df *ABS* 00000000 usudsp.mod.c 000000f0 l O .modinfo 00000009 __module_depends 000000fc l O .modinfo 00000034 __mod_vermagic5 00000000 *UND* 00000000 free_irq 00000000 *UND* 00000000 misc_deregister 000018c8 g O .bss 00000064 stRecTask 00000000 *UND* 00000000 pRsdpqXHwCtrl 00000000 g O .gnu.linkonce.this_module 00000140 __this_module 00000000 *UND* 00000000 __symbol_put 00000000 *UND* 00000000 finish_wait 00000000 g F .exit.text 00000120 cleanup_module 00000000 *UND* 00000000 prepare_to_wait 00000000 *UND* 00000000 memcpy 00000000 *UND* 00000000 __wake_up 00000000 g F .init.text 0000032c init_module 00000000 *UND* 00000000 create_proc_entry 00000000 *UND* 00000000 local_bh_enable 00000000 *UND* 00000000 schedule 00000000 *UND* 00000000 request_irq 000019b8 g O .bss 00000028 wait_q_ar 00000000 *UND* 00000000 __symbol_get 00000000 *UND* 00000000 tasklet_init 00000000 *UND* 00000000 strstr 00000000 *UND* 00000000 printk 00000000 *UND* 00000000 __copy_tofrom_user 000004bc g F .text 00000004 UsuDspRecTimeout 00000000 *UND* 00000000 _ctype 00000000 *UND* 00000000 proc_mkdir 00000000 *UND* 00000000 memset 00000000 *UND* 00000000 misc_register 00000000 g O .bss 00000000 state_lock 00000000 *UND* 00000000 jiffies 00000000 g O .data 0000006c UsuDspProcFileOpsDbg 00000420 g F .text 0000009c UsuDspTimeout 00000000 *UND* 00000000 sprintf 00001864 g O .bss 00000064 stTrTask 00000000 *UND* 00000000 remove_proc_entry 0000192c g O .bss 0000008c UsuDspTimer 00000000 *UND* 00000000 __tasklet_hi_schedule 00000000 *UND* 00000000 autoremove_wake_function 00000000 *UND* 00000000 strlen 00000000 *UND* 00000000 del_timer 00000000 *UND* 00000000 __mod_timer 00000000 g O .sbss 00000004 err_count_buf_in_use RELOCATION RECORDS FOR [.text]: OFFSET TYPE VALUE 0000000e R_PPC_ADDR16_HA .bss 00000016 R_PPC_ADDR16_LO .bss 00000026 R_PPC_ADDR16_HA .rodata.str1.4 0000003c R_PPC_REL24 memset 00000046 R_PPC_ADDR16_LO .rodata.str1.4 00000048 R_PPC_REL24 sprintf 0000004e R_PPC_ADDR16_HA .rodata.str1.4+0x00000004 00000056 R_PPC_ADDR16_HA .rodata.str1.4+0x0000002c 0000005a R_PPC_ADDR16_HA .rodata.str1.4+0x00000034 0000005e R_PPC_ADDR16_HA .rodata.str1.4+0x00000040 00000062 R_PPC_ADDR16_LO .rodata.str1.4+0x00000004 00000066 R_PPC_ADDR16_LO .rodata.str1.4+0x0000002c 0000006a R_PPC_ADDR16_LO .rodata.str1.4+0x00000034 0000006e R_PPC_ADDR16_LO .rodata.str1.4+0x00000040 00000074 R_PPC_REL24 sprintf 0000007a R_PPC_ADDR16_LO .rodata.str1.4 00000084 R_PPC_REL24 sprintf 0000008a R_PPC_ADDR16_HA .bss+0x00000400 00000092 R_PPC_ADDR16_LO .bss+0x00000400 0000009a R_PPC_ADDR16_HA .rodata.str1.4+0x0000004c 000000b6 R_PPC_ADDR16_LO .rodata.str1.4+0x0000004c 000000bc R_PPC_REL24 sprintf 000000d6 R_PPC_ADDR16_LO .rodata.str1.4 000000d8 R_PPC_REL24 sprintf 000000de R_PPC_ADDR16_LO .bss 00000170 R_PPC_REL24 memcpy 000001ca R_PPC_ADDR16_HA .bss+0x00000300 000001d2 R_PPC_ADDR16_LO .bss+0x00000300 000001f0 R_PPC_REL24 memcpy 000001f6 R_PPC_ADDR16_HA .rodata.str1.4+0x00000078 000001fa R_PPC_ADDR16_LO .rodata.str1.4+0x00000078 0000020c R_PPC_REL24 strlen 00000244 R_PPC_REL24 strstr 0000025a R_PPC_ADDR16_HA _ctype 00000266 R_PPC_ADDR16_LO _ctype 0000029e R_PPC_ADDR16_HA .rodata.str1.4+0x00000084 000002aa R_PPC_ADDR16_LO .rodata.str1.4+0x00000084 000002ac R_PPC_REL24 printk 000002b2 R_PPC_ADDR16_HA .sbss+0x00000004 000002b6 R_PPC_ADDR16_LO .sbss+0x00000004 000002d2 R_PPC_ADDR16_HA .rodata.str1.4+0x0000008c 000002d6 R_PPC_ADDR16_HA .rodata 000002da R_PPC_ADDR16_LO .rodata 000002ea R_PPC_ADDR16_LO .rodata.str1.4+0x0000008c 000002ec R_PPC_REL24 printk 00000306 R_PPC_ADDR16_HA .sbss+0x00000014 0000030a R_PPC_ADDR16_LO .sbss+0x00000014 0000035a R_PPC_ADDR16_HA stTrTask 0000035e R_PPC_ADDR16_LO stTrTask 000003e6 R_PPC_ADDR16_HA stRecTask 000003ea R_PPC_ADDR16_LO stRecTask 00000410 R_PPC_REL24 __tasklet_hi_schedule 00000436 R_PPC_ADDR16_HA .bss+0x00000400 0000043a R_PPC_ADDR16_LO .bss+0x00000400 00000446 R_PPC_ADDR16_HA .rodata.str1.4+0x000000bc 0000044a R_PPC_ADDR16_HA .rodata+0x00000014 0000044e R_PPC_ADDR16_LO .rodata+0x00000014 00000456 R_PPC_ADDR16_LO .rodata.str1.4+0x000000bc 00000458 R_PPC_REL24 printk 0000048c R_PPC_REL24 local_bh_enable 00000492 R_PPC_ADDR16_HA .sbss+0x00000014 00000496 R_PPC_ADDR16_LO .sbss+0x00000014 0000049a R_PPC_ADDR16_HA .rodata.str1.4+0x000000f8 0000049e R_PPC_ADDR16_LO .rodata.str1.4+0x000000f8 000004a4 R_PPC_REL24 printk 000004de R_PPC_ADDR16_HA UsuDspTimer 000004e2 R_PPC_ADDR16_LO UsuDspTimer 000004e8 R_PPC_REL24 del_timer 00000506 R_PPC_ADDR16_HA .bss+0x00000400 0000050e R_PPC_ADDR16_LO .bss+0x00000400 00000522 R_PPC_ADDR16_HA .rodata.str1.4+0x00000108 00000526 R_PPC_ADDR16_HA .rodata+0x00000024 0000052a R_PPC_ADDR16_LO .rodata.str1.4+0x00000108 0000052e R_PPC_ADDR16_LO .rodata+0x00000024 0000053c R_PPC_REL24 printk 0000054c R_PPC_REL24 local_bh_enable 00000578 R_PPC_REL24 local_bh_enable 000005a4 R_PPC_REL24 local_bh_enable 000005f2 R_PPC_ADDR16_HA .bss+0x00000400 000005fa R_PPC_ADDR16_LO .bss+0x00000400 0000061c R_PPC_REL24 local_bh_enable 00000622 R_PPC_ADDR16_HA err_count_buf_in_use 00000626 R_PPC_ADDR16_LO err_count_buf_in_use 0000062e R_PPC_ADDR16_LO err_count_buf_in_use 0000064a R_PPC_ADDR16_HA .sbss+0x00000014 00000658 R_PPC_REL24 local_bh_enable 0000065e R_PPC_ADDR16_LO .sbss+0x00000014 00000686 R_PPC_ADDR16_HA .bss+0x00000614 0000068a R_PPC_ADDR16_LO .bss+0x00000614 000006d2 R_PPC_ADDR16_HA .bss+0x00000408 000006d6 R_PPC_ADDR16_LO .bss+0x00000408 000006f2 R_PPC_ADDR16_LO .bss+0x00000400 00000714 R_PPC_REL24 local_bh_enable 0000071a R_PPC_ADDR16_LO .sbss+0x00000014 0000071e R_PPC_ADDR16_HA wait_q_ar 00000732 R_PPC_ADDR16_LO wait_q_ar 00000748 R_PPC_REL24 __wake_up 00000774 R_PPC_REL24 local_bh_enable 0000077a R_PPC_ADDR16_HA .sbss+0x00000014 00000782 R_PPC_ADDR16_LO .sbss+0x00000014 000007a2 R_PPC_ADDR16_HA .rodata.str1.4+0x0000014c 000007a6 R_PPC_ADDR16_LO .rodata.str1.4+0x0000014c 000007ac R_PPC_REL24 printk 00000898 R_PPC_REL24 local_bh_enable 000008c2 R_PPC_ADDR16_HA wait_q_ar 000008ca R_PPC_ADDR16_HA autoremove_wake_function 000008d6 R_PPC_ADDR16_LO autoremove_wake_function 000008ee R_PPC_ADDR16_LO wait_q_ar 00000904 R_PPC_REL24 schedule 00000914 R_PPC_REL24 prepare_to_wait 00000926 R_PPC_ADDR16_LO wait_q_ar 00000930 R_PPC_REL24 finish_wait 0000093e R_PPC_ADDR16_HA .rodata.str1.4+0x00000164 00000942 R_PPC_ADDR16_HA .rodata+0x00000038 00000946 R_PPC_ADDR16_LO .rodata.str1.4+0x00000164 0000094a R_PPC_ADDR16_LO .rodata+0x00000038 00000954 R_PPC_REL24 printk 00000962 R_PPC_ADDR16_HA .rodata.str1.4+0x0000019c 00000966 R_PPC_ADDR16_HA .rodata+0x00000038 0000096a R_PPC_ADDR16_LO .rodata+0x00000038 00000976 R_PPC_ADDR16_LO .rodata.str1.4+0x0000019c 00000978 R_PPC_REL24 printk 0000099c R_PPC_REL24 __copy_tofrom_user 000009b0 R_PPC_REL24 __copy_tofrom_user 000009c6 R_PPC_ADDR16_HA .rodata.str1.4+0x00000214 000009ca R_PPC_ADDR16_HA .rodata+0x00000038 000009ce R_PPC_ADDR16_LO .rodata.str1.4+0x00000214 000009d2 R_PPC_ADDR16_LO .rodata+0x00000038 000009d8 R_PPC_REL24 printk 00000a64 R_PPC_REL24 local_bh_enable 00000ab6 R_PPC_ADDR16_HA .sbss+0x00000014 00000aba R_PPC_ADDR16_LO .sbss+0x00000014 00000ae6 R_PPC_ADDR16_HA .sbss+0x00000004 00000aea R_PPC_ADDR16_LO .sbss+0x00000004 00000b02 R_PPC_ADDR16_HA .rodata.str1.4+0x00000250 00000b0a R_PPC_ADDR16_LO .rodata.str1.4+0x00000250 00000b10 R_PPC_REL24 printk 00000b1e R_PPC_ADDR16_LO .sbss+0x00000014 00000b36 R_PPC_ADDR16_HA jiffies 00000b3a R_PPC_ADDR16_LO jiffies 00000b3e R_PPC_ADDR16_HA UsuDspTimer 00000b42 R_PPC_ADDR16_LO UsuDspTimer 00000b52 R_PPC_ADDR16_HA UsuDspTimeout 00000b62 R_PPC_ADDR16_LO UsuDspTimeout 00000b7c R_PPC_REL24 __mod_timer 00000b82 R_PPC_ADDR16_LO .sbss+0x00000014 00000bc8 R_PPC_REL24 local_bh_enable 00000bf0 R_PPC_REL24 __copy_tofrom_user 00000c0c R_PPC_REL24 __copy_tofrom_user 00000c2e R_PPC_ADDR16_HA .rodata.str1.4+0x00000260 00000c36 R_PPC_ADDR16_LO .rodata.str1.4+0x00000260 00000c40 R_PPC_REL24 printk 00000c4e R_PPC_ADDR16_HA .rodata.str1.4+0x00000278 00000c52 R_PPC_ADDR16_HA .rodata+0x00000044 00000c56 R_PPC_ADDR16_LO .rodata.str1.4+0x00000278 00000c5a R_PPC_ADDR16_LO .rodata+0x00000044 00000c60 R_PPC_REL24 printk 00000c96 R_PPC_ADDR16_HA .sbss+0x00000014 00000c9a R_PPC_ADDR16_LO .sbss+0x00000014 00000cc6 R_PPC_ADDR16_HA .sbss+0x00000014 00000cca R_PPC_ADDR16_LO .sbss+0x00000014 00000cd6 R_PPC_ADDR16_LO .sbss+0x00000014 00000cde R_PPC_ADDR16_LO .sbss+0x00000014 00000cea R_PPC_ADDR16_HA .sbss+0x00000014 00000cee R_PPC_ADDR16_LO .sbss+0x00000014 00000d1a R_PPC_ADDR16_HA .rodata.str1.4+0x000002b4 00000d22 R_PPC_ADDR16_LO .rodata.str1.4+0x000002b4 00000d30 R_PPC_REL24 printk 00000d4a R_PPC_ADDR16_HA .sbss+0x00000010 00000d4e R_PPC_ADDR16_LO .sbss+0x00000010 00000d82 R_PPC_ADDR16_HA .rodata.str1.4+0x000002dc 00000d86 R_PPC_ADDR16_LO .rodata.str1.4+0x000002dc 00000d88 R_PPC_REL24 printk 00000d8e R_PPC_ADDR16_HA .sbss+0x00000014 00000d92 R_PPC_ADDR16_LO .sbss+0x00000014 00000dae R_PPC_ADDR16_LO .sbss+0x00000014 00000de2 R_PPC_ADDR16_LO .sbss+0x00000014 00000dfe R_PPC_ADDR16_HA .text+0x000002f4 00000e02 R_PPC_ADDR16_HA .rodata.str1.4+0x00000304 00000e06 R_PPC_ADDR16_HA .bss+0x00000400 00000e0a R_PPC_ADDR16_LO .text+0x000002f4 00000e0e R_PPC_ADDR16_LO .rodata.str1.4+0x00000304 00000e12 R_PPC_ADDR16_LO .bss+0x00000400 00000e1c R_PPC_REL24 request_irq 00000e2a R_PPC_ADDR16_HA .rodata.str1.4+0x00000310 00000e2e R_PPC_ADDR16_HA .rodata+0x00000054 00000e32 R_PPC_ADDR16_LO .rodata+0x00000054 00000e42 R_PPC_ADDR16_LO .rodata.str1.4+0x00000310 00000e44 R_PPC_REL24 printk 00000e52 R_PPC_ADDR16_HA .bss+0x00000400 00000e56 R_PPC_ADDR16_LO .bss+0x00000400 00000e86 R_PPC_ADDR16_HA .rodata.str1.4+0x0000035c 00000e8a R_PPC_ADDR16_HA .rodata+0x00000054 00000e8e R_PPC_ADDR16_LO .rodata.str1.4+0x0000035c 00000e92 R_PPC_ADDR16_LO .rodata+0x00000054 00000e9c R_PPC_REL24 printk 00000eb2 R_PPC_ADDR16_HA .sbss+0x00000010 00000eba R_PPC_ADDR16_LO .sbss+0x00000010 00000ed2 R_PPC_ADDR16_HA .rodata.str1.4+0x000003a0 00000ed6 R_PPC_ADDR16_LO .rodata.str1.4+0x000003a0 00000ef0 R_PPC_REL24 printk 00000ef6 R_PPC_ADDR16_HA .bss+0x00000400 00000efe R_PPC_ADDR16_LO .bss+0x00000400 00000f00 R_PPC_REL24 free_irq RELOCATION RECORDS FOR [.init.text]: OFFSET TYPE VALUE 0000000e R_PPC_ADDR16_HA .rodata.str1.4+0x0000002c 00000012 R_PPC_ADDR16_HA .rodata.str1.4+0x00000034 0000001a R_PPC_ADDR16_HA .rodata.str1.4+0x00000040 00000022 R_PPC_ADDR16_HA .rodata.str1.4+0x000003c4 0000002a R_PPC_ADDR16_LO .rodata.str1.4+0x0000002c 0000002e R_PPC_ADDR16_LO .rodata.str1.4+0x00000034 00000032 R_PPC_ADDR16_LO .rodata.str1.4+0x00000040 00000036 R_PPC_ADDR16_LO .rodata.str1.4+0x000003c4 0000003a R_PPC_ADDR16_HA .rodata.str1.4+0x000003f8 0000003c R_PPC_REL24 printk 00000042 R_PPC_ADDR16_LO .rodata.str1.4+0x000003f8 00000044 R_PPC_REL24 __symbol_get 00000052 R_PPC_ADDR16_HA pRsdpqXHwCtrl 00000056 R_PPC_ADDR16_LO pRsdpqXHwCtrl 0000005a R_PPC_ADDR16_HA .sbss+0x00000014 00000066 R_PPC_ADDR16_HA wait_q_ar 0000006a R_PPC_ADDR16_LO wait_q_ar 0000006e R_PPC_ADDR16_LO .sbss+0x00000014 00000072 R_PPC_ADDR16_HA stRecTask 00000076 R_PPC_ADDR16_HA stTrTask 0000007a R_PPC_ADDR16_LO stTrTask 0000007e R_PPC_ADDR16_LO stRecTask 00000082 R_PPC_ADDR16_HA .text+0x000004c0 00000086 R_PPC_ADDR16_HA .text+0x000005bc 000000a6 R_PPC_ADDR16_LO .text+0x000004c0 000000a8 R_PPC_REL24 tasklet_init 000000b6 R_PPC_ADDR16_LO .text+0x000005bc 000000bc R_PPC_REL24 tasklet_init 000000ce R_PPC_ADDR16_HA .rodata.str1.4+0x00000408 000000d2 R_PPC_ADDR16_LO .rodata.str1.4+0x00000408 000000d8 R_PPC_REL24 proc_mkdir 000000de R_PPC_ADDR16_HA .sbss+0x0000000c 000000e6 R_PPC_ADDR16_LO .sbss+0x0000000c 000000ee R_PPC_ADDR16_HA .rodata.str1.4+0x00000418 000000fa R_PPC_ADDR16_LO .rodata.str1.4+0x00000418 000000fc R_PPC_REL24 create_proc_entry 00000102 R_PPC_ADDR16_HA .sbss+0x00000008 0000010a R_PPC_ADDR16_LO .sbss+0x00000008 00000112 R_PPC_ADDR16_HA UsuDspProcFileOpsDbg 00000116 R_PPC_ADDR16_LO UsuDspProcFileOpsDbg 0000011a R_PPC_ADDR16_HA .rodata+0x00000060 00000122 R_PPC_ADDR16_HA .bss+0x000019e0 00000126 R_PPC_ADDR16_HA .data+0x0000006c 0000012a R_PPC_ADDR16_LO .bss+0x000019e0 0000012e R_PPC_ADDR16_LO .data+0x0000006c 0000013a R_PPC_ADDR16_HA .rodata.str1.4+0x0000041c 0000013e R_PPC_ADDR16_HA .rodata.str1.4+0x00000424 0000014a R_PPC_ADDR16_LO .rodata.str1.4+0x0000041c 0000014e R_PPC_ADDR16_LO .rodata.str1.4+0x00000424 00000154 R_PPC_REL24 sprintf 00000170 R_PPC_REL24 misc_register 00000192 R_PPC_ADDR16_HA .rodata.str1.4+0x00000428 00000196 R_PPC_ADDR16_LO .rodata.str1.4+0x00000428 0000019a R_PPC_ADDR16_LO .rodata+0x00000060 000001a0 R_PPC_REL24 printk 000001c6 R_PPC_ADDR16_HA .rodata+0x00000060 000001ca R_PPC_ADDR16_HA .rodata.str1.4+0x0000045c 000001ce R_PPC_ADDR16_LO .rodata+0x00000060 000001d6 R_PPC_ADDR16_LO .rodata.str1.4+0x00000408 000001da R_PPC_ADDR16_LO .rodata.str1.4+0x0000045c 000001dc R_PPC_REL24 printk 000001e6 R_PPC_ADDR16_HA .rodata.str1.4+0x0000048c 000001ea R_PPC_ADDR16_LO .rodata.str1.4+0x0000048c 000001ee R_PPC_ADDR16_LO .rodata+0x00000060 000001f8 R_PPC_REL24 printk 00000206 R_PPC_ADDR16_HA .bss+0x000019e0 0000020e R_PPC_ADDR16_LO .bss+0x000019e0 00000212 R_PPC_ADDR16_HA .rodata.str1.4+0x000004d0 00000238 R_PPC_REL24 misc_deregister 00000246 R_PPC_ADDR16_LO .rodata+0x00000060 0000024a R_PPC_ADDR16_LO .rodata.str1.4+0x000004d0 00000258 R_PPC_REL24 printk 0000026a R_PPC_ADDR16_LO .sbss+0x0000000c 00000276 R_PPC_ADDR16_HA .sbss+0x00000008 0000027a R_PPC_ADDR16_LO .sbss+0x00000008 00000286 R_PPC_ADDR16_LO .rodata.str1.4+0x00000408 0000028c R_PPC_REL24 remove_proc_entry 00000292 R_PPC_ADDR16_LO .rodata.str1.4+0x000003f8 00000294 R_PPC_REL24 __symbol_put 0000029a R_PPC_ADDR16_HA .rodata.str1.4+0x0000048c 0000029e R_PPC_ADDR16_LO .rodata+0x00000060 000002a6 R_PPC_ADDR16_LO .rodata.str1.4+0x0000048c 000002aa R_PPC_ADDR16_LO .rodata.str1.4+0x00000424 000002ac R_PPC_REL24 printk 000002b2 R_PPC_ADDR16_HA .rodata.str1.4+0x00000518 000002b6 R_PPC_ADDR16_LO .rodata.str1.4+0x00000518 000002ba R_PPC_ADDR16_LO .rodata+0x00000060 000002c6 R_PPC_ADDR16_HA .rodata+0x00000060 000002ca R_PPC_ADDR16_HA .rodata.str1.4+0x00000554 000002ce R_PPC_ADDR16_LO .rodata.str1.4+0x00000418 000002d2 R_PPC_ADDR16_LO .rodata+0x00000060 000002da R_PPC_ADDR16_LO .rodata.str1.4+0x00000408 000002de R_PPC_ADDR16_LO .rodata.str1.4+0x00000554 000002e0 R_PPC_REL24 printk 000002ea R_PPC_ADDR16_HA .rodata.str1.4+0x00000418 000002ee R_PPC_ADDR16_LO .rodata.str1.4+0x00000418 000002f0 R_PPC_REL24 remove_proc_entry 000002fa R_PPC_ADDR16_HA .rodata+0x00000060 000002fe R_PPC_ADDR16_HA .rodata.str1.4+0x00000588 00000302 R_PPC_ADDR16_LO .rodata+0x00000060 0000030a R_PPC_ADDR16_LO .rodata.str1.4+0x00000588 0000030c R_PPC_REL24 printk 00000312 R_PPC_ADDR16_HA .rodata.str1.4+0x000005c4 00000316 R_PPC_ADDR16_LO .rodata.str1.4+0x000005c4 0000031a R_PPC_ADDR16_LO .rodata+0x00000060 00000320 R_PPC_REL24 printk RELOCATION RECORDS FOR [.exit.text]: OFFSET TYPE VALUE 00000006 R_PPC_ADDR16_HA .rodata.str1.4+0x0000002c 0000000a R_PPC_ADDR16_HA .rodata.str1.4+0x00000034 00000012 R_PPC_ADDR16_HA .rodata.str1.4+0x00000040 0000001a R_PPC_ADDR16_HA .rodata.str1.4+0x00000600 0000001e R_PPC_ADDR16_LO .rodata.str1.4+0x0000002c 00000022 R_PPC_ADDR16_LO .rodata.str1.4+0x00000034 00000026 R_PPC_ADDR16_LO .rodata.str1.4+0x00000040 0000002a R_PPC_ADDR16_LO .rodata.str1.4+0x00000600 00000030 R_PPC_REL24 printk 00000036 R_PPC_ADDR16_HA .rodata.str1.4+0x000003f8 0000003a R_PPC_ADDR16_LO .rodata.str1.4+0x000003f8 0000003c R_PPC_REL24 __symbol_put 00000042 R_PPC_ADDR16_HA .sbss+0x0000000c 00000046 R_PPC_ADDR16_LO .sbss+0x0000000c 00000052 R_PPC_ADDR16_HA .sbss+0x00000008 00000056 R_PPC_ADDR16_LO .sbss+0x00000008 00000062 R_PPC_ADDR16_HA .rodata.str1.4+0x00000408 00000066 R_PPC_ADDR16_LO .rodata.str1.4+0x00000408 0000006c R_PPC_REL24 remove_proc_entry 00000072 R_PPC_ADDR16_HA .bss+0x000019e0 00000076 R_PPC_ADDR16_HA .data+0x0000006c 0000007a R_PPC_ADDR16_LO .bss+0x000019e0 0000007e R_PPC_ADDR16_LO .data+0x0000006c 0000008a R_PPC_ADDR16_HA .rodata.str1.4+0x000004d0 0000008e R_PPC_ADDR16_HA .rodata+0x00000070 000000ac R_PPC_REL24 misc_deregister 000000be R_PPC_ADDR16_LO .rodata.str1.4+0x000004d0 000000c2 R_PPC_ADDR16_LO .rodata+0x00000070 000000da R_PPC_ADDR16_HA .rodata.str1.4+0x00000638 000000de R_PPC_ADDR16_LO .rodata.str1.4+0x00000638 000000e0 R_PPC_REL24 printk 000000f8 R_PPC_REL24 printk 00000102 R_PPC_ADDR16_HA .rodata.str1.4+0x00000418 00000106 R_PPC_ADDR16_LO .rodata.str1.4+0x00000418 00000108 R_PPC_REL24 remove_proc_entry 0000010e R_PPC_ADDR16_HA .rodata.str1.4+0x00000408 00000112 R_PPC_ADDR16_LO .rodata.str1.4+0x00000408 00000118 R_PPC_REL24 remove_proc_entry RELOCATION RECORDS FOR [.data]: OFFSET TYPE VALUE 00000008 R_PPC_ADDR32 .text 00000010 R_PPC_ADDR32 .text+0x000001bc 0000006c R_PPC_ADDR32 __this_module 00000074 R_PPC_ADDR32 .text+0x000007b8 0000007c R_PPC_ADDR32 .text+0x000009ec 0000008c R_PPC_ADDR32 .text+0x00000c6c 0000009c R_PPC_ADDR32 .text+0x00000d00 000000a4 R_PPC_ADDR32 .text+0x00000ea8 RELOCATION RECORDS FOR [.gnu.linkonce.this_module]: OFFSET TYPE VALUE 000000a4 R_PPC_ADDR32 init_module 0000010c R_PPC_ADDR32 cleanup_module >strings usudsp.ko }`H(}j x}@I-@ }`H(}j x}@I-@ K.9= (}kPx}` }c[x }`H(}k x}`I-@ .}#Kx .}#Kx }#Kx TUsuDspProcWriteDbg UsuDspTimeout UsuDspTransIntBh usudsp_read usudsp_write usudsp_open usudspdrv_init usudspdrv_exit description= The USU PPC-DSP driver provides the interface to transfer data between PPC and the Motorola 56xxx DSP on the USU board. author= -* Copyright (c) 2004-2005 Rohde & Schwarz **********- -* Max Winklhofer - 1CM5 *- license=GPL depends= vermagic=2.6.12.6-elinos-226-rsdpq2 preempt gcc-3.4 USUDSP driver -> %s [build %s - %s] V2.0 11:09:03 Sep 28 2007 DSP%d: eTrState = %d | eRecState = %d dbgwrite= %s%d <3>usdsp: %-13s [%4d]: unknown command: %s%d <3>usdsp: %-13s [%4d]: <1>write timeout DSP:%ld state:%d <1>int reg %x <3>usdsp: %-13s [%4d]: <1>unexp int from -> DSP%ld in state %d <1> dsp%x read %x <3>usdsp: %-13s [%4d]: <1>wait rec DSP%d forced event <3>usdsp: %-13s [%4d]: DPRAMDRV RCV: Received more data than requested (%d read, %d requested), data will be discarded <3>usdsp: %-13s [%4d]: <1> dsp read: priv_data ptr NULL <1> wr %x <1> dsp%d write %x <3>usdsp: %-13s [%4d]: <1> dsp write: priv_data ptr NULL <1> usu dsp driver opened minor %d <1> first user -> request interrupt UsuDspIsr <3>usdsp: %-13s [%4d]: <1> Can't register UsuDspIsr on IRQ %d - errno = %d <3>usdsp: %-13s [%4d]: <1> minor number %d > USUDSP_MAX_NUMBER <1> last user -> release interrupt Installing USUDSP driver -> %s [build %s - %s] pRsdpqXHwCtrl driver/usudsp %s%d <3>usdsp: %-13s [%4d]: USUDSP driver installed <3>usdsp: %-13s [%4d]: Can't create '/proc/%s <3>usdsp: %-13s [%4d]: Can't register USUDSP device: /dev/misc/%s <3>usdsp: %-13s [%4d]: Can't de-register USUDSP device: /dev/misc/%s <3>usdsp: %-13s [%4d]: Can't install USUDSP driver ! <3>usdsp: %-13s [%4d]: Can't create '/proc/%s/%s <3>usdsp: %-13s [%4d]: PB-FPGA driver not installed ! <3>usdsp: %-13s [%4d]: Please load PB-FPGA LKM first. Uninstalling the USUDSP driver -> %s [build %s - %s] USUDSP driver uninstalled usudsp GCC: (GNU) 3.4.4 (ELinOS V4.0 3.4.4-14 2005-12-05) GCC: (GNU) 3.4.4 (ELinOS V4.0 3.4.4-14 2005-12-05) .symtab .strtab .shstrtab .rela.text .rela.init.text .rela.exit.text .rodata .modinfo .rodata.str1.4 .rela.data .rela.gnu.linkonce.this_module .sbss .bss .init.plt .comment .note.GNU-stack usudspdrv.c usudspdrv_init usudspdrv_exit UsuDspProcReadDbg UsuDspProcWriteDbg __mod_description206 __mod_author202 __mod_license1966 dbgwrite usudsp_fops usudsp_read usudsp_write usudsp_ioctl usudsp_open usudsp_close pProcEntryDbg pProcEntry ModUseCount ProcOutBuffer.2 atUsuDspCtrls __PRETTY_FUNCTION__.0 ProcInBuffer.1 UsuDspIsr fpga_start __PRETTY_FUNCTION__.9 __PRETTY_FUNCTION__.8 UsuDspTransIntBh UsuDspReceiveIntBh __PRETTY_FUNCTION__.6 __PRETTY_FUNCTION__.5 __PRETTY_FUNCTION__.4 __PRETTY_FUNCTION__.7 usudsp_dev __PRETTY_FUNCTION__.3 usudsp.mod.c __module_depends __mod_vermagic5 free_irq misc_deregister stRecTask pRsdpqXHwCtrl __this_module __symbol_put finish_wait cleanup_module prepare_to_wait memcpy __wake_up init_module create_proc_entry local_bh_enable schedule request_irq wait_q_ar __symbol_get tasklet_init strstr printk __copy_tofrom_user UsuDspRecTimeout _ctype proc_mkdir memset misc_register state_lock jiffies UsuDspProcFileOpsDbg UsuDspTimeout sprintf stTrTask remove_proc_entry UsuDspTimer __tasklet_hi_schedule autoremove_wake_function strlen del_timer __mod_timer err_count_buf_in_use
