Welcome to WordClock Logger! ---------------------------- irmp_init... power_init... power_init() called power_on... switching power on delay_init... board_led_init... button_init... timer2_init... wpsbutton_init... Version: 2.9.4 Hardware: STM32F103 Display: WC12h LEDs: SK6812 RGBW rtc is online eeprom is online sk6812: external pullup detected eeprom is online current eeprom version: 0xff007e00 updating EEPROM to version 0x00020900... done DFPLAYER LOGGER ESP8266 LOGGER read rtc: Sa 2018-07-28 23:05:01 read rtc: Sa 2018-07-28 23:05:01 esp8266 now up (- setup UDP) (- local port: 2421) (- setup server UDP) (- local port: 2424) (FIRMWARE 2.9.2) (- tables found; wc12h-tables-local.txt) (- check tables successful) --> tabinfo<0d><0a> --> tabillu "0"<0d><0a> --> tabh "0","0"<0d><0a> --> tabm "0","0"<0d><0a> tables complete (- connected to AP) (AP The_Promise_LAN_2G4) (MODE client) (IPADDRESS 192.168.1.101) info: ip address = 192.168.1.101 esp8266 now online --> time "192.53.103.103"<0d><0a> (OK time) (TIME 3741774501) Welcome to WordClock Logger! ---------------------------- irmp_init... power_init... power_init() called power_on... switching power on delay_init... board_led_init... button_init... timer2_init... wpsbutton_init... Version: 2.9.4 Hardware: STM32F103 Display: WC12h LEDs: SK6812 RGBW rtc is online eeprom is online sk6812: external pullup detected eeprom is online current eeprom version: 0xff007e00 updating EEPROM to version 0x00020900... done DFPLAYER LOGGER ESP8266 LOGGER read rtc: Sa 2018-07-28 15:48:37 read rtc: Sa 2018-07-28 15:48:37 esp8266 now up (- setup UDP) (- local port: 2421) (- setup server UDP) (- local port: 2424) (FIRMWARE 2.9.2) (- tables found; wc12h-tables-local.txt) (- check tables successful) --> tabinfo<0d><0a> --> tabillu "0"<0d><0a> --> tabh "0","0"<0d><0a> --> tabm "0","0"<0d><0a> tables complete (- connected to AP) (AP The_Promise_LAN_2G4) (MODE client) (IPADDRESS 192.168.1.101) info: ip address = 192.168.1.101 esp8266 now online --> time "192.53.103.103"<0d><0a> (OK time) (TIME 3741774524) read rtc: Sa 2018-07-28 15:48:44 RTC temperature: 25
