<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<!--Created by yFiles for HTML 2.1.0.4 RC2-->
<graphml xsi:schemaLocation="http://graphml.graphdrawing.org/xmlns http://www.yworks.com/xml/schema/graphml.html/2.0/ygraphml.xsd " xmlns="http://graphml.graphdrawing.org/xmlns" xmlns:demostyle="http://www.yworks.com/yFilesHTML/demos/FlatDemoStyle/1.0" xmlns:bpmn="http://www.yworks.com/xml/yfiles-for-html/bpmn/2.0" xmlns:demotablestyle="http://www.yworks.com/yFilesHTML/demos/FlatDemoTableStyle/1.0" xmlns:uml="http://www.yworks.com/yFilesHTML/demos/UMLDemoStyle/1.0" xmlns:compat="http://www.yworks.com/xml/yfiles-compat-arrows/1.0" xmlns:VuejsNodeStyle="http://www.yworks.com/demos/yfiles-vuejs-node-style/1.0" xmlns:y="http://www.yworks.com/xml/yfiles-common/3.0" xmlns:x="http://www.yworks.com/xml/yfiles-common/markup/3.0" xmlns:yjs="http://www.yworks.com/xml/yfiles-for-html/2.0/xaml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
	<key id="d0" for="node" attr.type="boolean" attr.name="Expanded" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/folding/Expanded">
		<default>true</default>
	</key>
	<key id="d1" for="node" attr.name="NodeLabels" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/NodeLabels"/>
	<key id="d2" for="node" attr.name="NodeGeometry" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/NodeGeometry"/>
	<key id="d3" for="all" attr.name="UserTags" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/UserTags"/>
	<key id="d4" for="node" attr.name="NodeStyle" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/NodeStyle"/>
	<key id="d5" for="node" attr.name="NodeViewState" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/folding/1.1/NodeViewState"/>
	<key id="d6" for="edge" attr.name="EdgeLabels" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/EdgeLabels"/>
	<key id="d7" for="edge" attr.name="EdgeGeometry" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/EdgeGeometry"/>
	<key id="d8" for="edge" attr.name="EdgeStyle" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/EdgeStyle"/>
	<key id="d9" for="edge" attr.name="EdgeViewState" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/folding/1.1/EdgeViewState"/>
	<key id="d10" for="port" attr.name="PortLabels" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/PortLabels"/>
	<key id="d11" for="port" attr.name="PortLocationParameter" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/PortLocationParameter">
		<default>
			<x:Static Member="y:FreeNodePortLocationModel.NodeCenterAnchored"/>
		</default>
	</key>
	<key id="d12" for="port" attr.name="PortStyle" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/PortStyle">
		<default>
			<x:Static Member="y:VoidPortStyle.Instance"/>
		</default>
	</key>
	<key id="d13" for="port" attr.name="PortViewState" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/folding/1.1/PortViewState"/>
	<key id="d14" attr.name="SharedData" y:attr.uri="http://www.yworks.com/xml/yfiles-common/2.0/SharedData"/>
	<data key="d14">
		<y:SharedData>
			<yjs:SolidColorFill x:Key="1" color="#FFD2DEEE"/>
			<yjs:Font x:Key="2" fontSize="12"/>
			<yjs:Font x:Key="3" fontSize="12"/>
			<yjs:Font x:Key="4" fontSize="12"/>
			<yjs:Stroke x:Key="5" fill="#FF336699"/>
			<yjs:PolylineEdgeStyle x:Key="6" stroke="{y:GraphMLReference 5}">
				<yjs:PolylineEdgeStyle.targetArrow>
					<yjs:Arrow type="TRIANGLE" scale="0.75" stroke="{y:GraphMLReference 5}" fill="#FF336699" cropLength="1"/>
				</yjs:PolylineEdgeStyle.targetArrow>
			</yjs:PolylineEdgeStyle>
			<y:SmartEdgeLabelModel x:Key="7"/>
		</y:SharedData>
	</data>
	<graph id="G" edgedefault="directed">
		<data key="d3">
			<y:Json>{"version":"2.0.0","layout":"layout-flowchart"}</y:Json>
		</data>
		<node id="n0">
			<data key="d1">
				<x:List>
					<y:Label LayoutParameter="{x:Static y:InteriorStretchLabelModel.Center}">
						<y:Label.Text>MCU_RESTART</y:Label.Text>
						<y:Label.Style>
							<yjs:DefaultLabelStyle verticalTextAlignment="CENTER" horizontalTextAlignment="CENTER" wrapping="WORD" clipText="false" font="{y:GraphMLReference 4}" textFill="BLACK"/>
						</y:Label.Style>
					</y:Label>
				</x:List>
			</data>
			<data key="d2">
				<y:RectD X="373.75" Y="-251.25" Width="100.5" Height="30"/>
			</data>
			<data key="d4">
				<demostyle:FlowchartNodeStyle type="start1" fill="{y:GraphMLReference 1}"/>
			</data>
			<port name="p0"/>
			<port name="p1"/>
		</node>
		<node id="n1">
			<data key="d1">
				<x:List>
						<y:Label.Text>Init_TWI</y:Label.Text>
						<y:Label.Style>
							<yjs:DefaultLabelStyle verticalTextAlignment="CENTER" horizontalTextAlignment="CENTER" wrapping="WORD" clipText="false" textFill="BLACK">
								<yjs:DefaultLabelStyle.font>
									<yjs:Font fontSize="12"/>
								</yjs:DefaultLabelStyle.font>
							</yjs:DefaultLabelStyle>
						</y:Label.Style>
					</y:Label>
				</x:List>
			</data>
			<data key="d2">
				<y:RectD X="384.875" Y="-89.75" Width="75.25" Height="30"/>
			</data>
			<data key="d4">
				<demostyle:FlowchartNodeStyle type="predefinedProcess" fill="{y:GraphMLReference 1}"/>
			</data>
			<port name="p0"/>
			<port name="p1"/>
		</node>
		<node id="n2">
			<data key="d1">
				<x:List>
						<y:Label.Text><![CDATA[Stackpoiner initialisieren & Globale Interruptfreigabe]]></y:Label.Text>
						<y:Label.Style>
						</y:Label.Style>
					</y:Label>
				</x:List>
			</data>
			<data key="d2">
				<y:RectD X="342.375" Y="-157.25" Width="160.25" Height="38.5"/>
			</data>
			<data key="d4">
				<demostyle:FlowchartNodeStyle type="process" fill="{y:GraphMLReference 1}"/>
			</data>
			<port name="p0"/>
			<port name="p1"/>
		</node>
		<node id="n3">
			<data key="d1">
				<x:List>
						<y:Label.Text>Read_Temp2</y:Label.Text>
						<y:Label.Style>
						</y:Label.Style>
					</y:Label>
				</x:List>
			</data>
			<data key="d2">
				<y:RectD X="372.25" Y="-42.75" Width="100.5" Height="30"/>
			</data>
			<data key="d4">
			</data>
			<port name="p0"/>
			<port name="p1"/>
		</node>
		<node id="n4">
			<data key="d1">
				<x:List>
						<y:Label.Text>Get_TWI_Temp</y:Label.Text>
						<y:Label.Style>
							<yjs:DefaultLabelStyle verticalTextAlignment="CENTER" horizontalTextAlignment="CENTER" wrapping="WORD" clipText="false" font="{y:GraphMLReference 3}" textFill="BLACK"/>
						</y:Label.Style>
					</y:Label>
				</x:List>
			</data>
			<data key="d2">
				<y:RectD X="372.25" Y="63.25" Width="100.5" Height="30"/>
			</data>
			<data key="d4">
			</data>
			<port name="p0"/>
			<port name="p1"/>
		</node>
		<node id="n5">
			<data key="d1">
				<x:List>
						<y:Label.Text>TWI_ready?</y:Label.Text>
						<y:Label.Style>
							<yjs:DefaultLabelStyle verticalTextAlignment="CENTER" horizontalTextAlignment="CENTER" wrapping="WORD" clipText="false" font="{y:GraphMLReference 2}" textFill="BLACK"/>
						</y:Label.Style>
					</y:Label>
				</x:List>
			</data>
			<data key="d2">
				<y:RectD X="373.5" Y="7.25" Width="100.5" Height="30"/>
			</data>
			<data key="d4">
				<demostyle:FlowchartNodeStyle type="decision" fill="{y:GraphMLReference 1}"/>
			</data>
			<port name="p0"/>
			<port name="p1"/>
		</node>
		<node id="n6">
			<data key="d1">
				<x:List>
						<y:Label.Text>TWI_error?</y:Label.Text>
						<y:Label.Style>
						</y:Label.Style>
					</y:Label>
				</x:List>
			</data>
			<data key="d2">
				<y:RectD X="372.25" Y="112.75" Width="100.5" Height="30"/>
			</data>
			<data key="d4">
			</data>
			<port name="p0"/>
			<port name="p1"/>
		</node>
		<node id="n7">
			<data key="d1">
				<x:List>
						<y:Label.Text>Process_TWI_Error</y:Label.Text>
						<y:Label.Style>
						</y:Label.Style>
					</y:Label>
				</x:List>
			</data>
			<data key="d2">
				<y:RectD X="357.875" Y="162.25" Width="129.25" Height="30"/>
			</data>
			<data key="d4">
			</data>
			<port name="p0"/>
			<port name="p1"/>
		</node>
		<node id="n8">
			<data key="d1">
				<x:List>
						<y:Label.Text>main_loop</y:Label.Text>
						<y:Label.Style>
						</y:Label.Style>
					</y:Label>
				</x:List>
			</data>
			<data key="d2">
				<y:RectD X="372.25" Y="236.25" Width="100.5" Height="30"/>
			</data>
			<data key="d4">
			</data>
			<port name="p0"/>
			<port name="p1"/>
		</node>
		<edge id="e0" source="n0" target="n2" sourceport="p0" targetport="p0">
			<data key="d7">
				<x:List>
					<y:Bend Location="424,-138"/>
				</x:List>
			</data>
			<data key="d8">
				<y:GraphMLReference ResourceKey="6"/>
			</data>
		</edge>
		<edge id="e1" source="n2" target="n1" sourceport="p1" targetport="p0">
			<data key="d8">
			</data>
		</edge>
		<edge id="e2" source="n1" target="n3" sourceport="p1" targetport="p0">
			<data key="d8">
			</data>
		</edge>
		<edge id="e3" source="n3" target="n5" sourceport="p1" targetport="p0">
			<data key="d7">
				<x:List>
					<y:Bend Location="422.5,-4.25"/>
					<y:Bend Location="423.75,-4.25"/>
				</x:List>
			</data>
			<data key="d8">
			</data>
		</edge>
		<edge id="e4" source="n5" target="n4" sourceport="p1" targetport="p0">
			<data key="d6">
				<x:List>
					<y:Label>
						<y:Label.Text>J</y:Label.Text>
						<y:Label.LayoutParameter>
							<y:SmartEdgeLabelModelParameter Model="{y:GraphMLReference 7}" Distance="0.001"/>
						</y:Label.LayoutParameter>
						<y:Label.Style>
							<yjs:DefaultLabelStyle textFill="BLACK">
						</y:Label.Style>
					</y:Label>
				</x:List>
			</data>
			<data key="d7">
				<x:List>
					<y:Bend Location="422.5,22.25"/>
				</x:List>
			</data>
			<data key="d8">
			</data>
		</edge>
		<edge id="e5" source="n4" target="n6" sourceport="p1" targetport="p0">
			<data key="d8">
			</data>
		</edge>
		<edge id="e6" source="n6" target="n7" sourceport="p1" targetport="p0">
			<data key="d6">
				<x:List>
					<y:Label>
							<y:SmartEdgeLabelModelParameter Model="{y:GraphMLReference 7}" Distance="5"/>
						<y:Label.Style>
							<yjs:DefaultLabelStyle wrapping="WORD" textFill="BLACK">
						</y:Label.Style>
					</y:Label>
				</x:List>
			</data>
			<data key="d8">
			</data>
		</edge>
		<edge id="e7" source="n7" target="n8" sourceport="p1" targetport="p0">
			<data key="d8">
			</data>
		</edge>
		<edge id="e8" source="n8" target="n0" sourceport="p1" targetport="p1">
			<data key="d7">
				<x:List>
					<y:Bend Location="303.75,251.25"/>
					<y:Bend Location="303.75,-236.25"/>
				</x:List>
			</data>
			<data key="d8">
			</data>
		</edge>
	</graph>
</graphml>
