[Supported Model] All the MSO/DS1000Z Series Digital Oscilloscopes [Latest Revision Date] 2018/04/28 [Updated Contents] -------------------- v00.04.04.03.05 2018/04/28 - Fixed the login bug of lxi-web - Fixed the bug of average measure - Fixed the bug of information display [History] ------------- v00.04.04.01.01 2016/09/14 - Supported the multi-inteface of LXI - Fixed bugs about Measure v00.04.04.00.07 2016/07/19 - Added the full-screen display in the XY mode - Modified the Trace data of average sample mode - Fixed the bug of system halted for wave persistance in the Zoom mode - Fixed bugs about Measure v00.04.03.02.03 2015/10/20 - Added commands concerning the type and format of the image - Added four measurement items (+Pulses, -Pulses, +Edges, -Edges) and related commands - Added commands concerning the digital filter - Added more information to the last setting - Fixed option installation - Fixed Intg operation v00.04.03.01.05 2015/06/16 - Added French in system language - Added the mutual communication with DG4000 Series - Added the digital filter - Supported using memory data to carry out FFT operation - Supported invert and format setting when reading a image remotely - Fixed bugs when the data of the digital channel is saved in the CSV format v00.04.03.00.01 2015/05/05 - Added DS1104Z Plus and DS1074Z Plus - Fixed pass/fail test - Fixed FFT operation v00.04.02.04.07 2014/12/31 - Fixed triggering function - Fixed storage function - Fixed bugs of jitter in the signal under the AC or low-frequency coupling v00.04.02.03.00 2014/10/21 - Added commands concerning remote reading and download of pass/fail test rules - Improved the command set for decoding and waveform recording - Fixed bugs in RS232 decoding v00.04.01.02.00 2014/07/28 - Added traditional Chinese language for the measurement menu - Optimized the event table display - Pressed and held [Measure] to remove all the measurement items - Added hardware version number to the displayed system information - Fixed bugs in storage function - Fixed bugs in the Undo operation for AUTO - Fixed bugs in signal source function v00.04.00.00.00 2014/03/18 - Added remote reading of LA waveform data - Added commands concerning the measurement of MATH waveform - Optimized the prompt message of LA probe calibration - Fixed bugs in triggering function v00.02.03.05.00 2014/01/27 - Added the command set for the keypad - Added multiple system languages - Optimize the prompt message of LA probe calibration - Fixed bugs in frequency counter - Fixed bugs in storage - Fixed the crash problem when formatting U disk in NTFS format v00.02.01.01.00 2013/10/31 - Added measurement history function - Added the setting for measurement range - Adjusted the priority order of the remote interface - Realized the seamless integration of digital oscilloscope and the signal generator - Optimized trigger state display - Fixed bugs in horizontal scale v00.02.00.01.00 2013/09/02 - Optimized the brightness of waveform display - Optimized the waiting time for the slow sweep mode v00.01.00.16.09 2013/08/14 - Supported the remote access to memory data v00.01.00.13.09 2013/ 07/ 25 - Added the export function of deep memory waveform data - Added the delay calibration function for the channel - Optimized the persistence time of waveform display - Fixed bugs in slow sweep v00.01.00.12.08 2013/07/10 - Optimized the USB Device interface communication - Fixed bugs in print function - Modified the abnormal trigger level line after the AUTO operation v00.01.00.03.00 2013/05/21 - Fixed bugs for the expiration of the trial options v00.01.00.02.00 2013/05/19 - Added the display interface of the installed option v00.01.00.00.05 2013/05/19 - Released the first edition
