This documentation is designed to provide guidance to customers on how to upgrade the MSO/DS1000Z series digital oscilloscope to the version in the "DS1000Z(ARM)update.rar" file. The applicable models include DS1XX4Z, DS1XX4Z Plus, DS1XX4Z-S Plus, MSO1XX4Z and MSO1XX4Z-S. New versions of firmware are available at the following website. http://int.rigol.com/Support/SoftDownload/3 [Notices] - Before upgrading, please carefully refer to the "MSO_DS1000Z Release Notes.txt" file to obtain the updated information of the firmware version. - Please make sure your USB disk can be read correctly. MSO/DS1000Z series is required to use a USB Flash drive disk with FAT32 format. - During the upgrade process, please do not cut off power and pull out the USB disk, otherwise the instrument will fail to work normally. - MSO/DS1000Z series digital oscilloscope does not support the downgrading operations. [Upgrading Procedures] 1. Copy the upgrade file DS1000ZUpdate.GEL to the root directory of the USB disk. 2. Keep the instrument in the power-on state, then insert the USB disk into the USB HOST interface (next to the Power key). 3. A prompt message is automatically displayed on the interface, reminding you that an upgrade file has been detected and ask you whether to upgrade it. You can click Ok to start to upgrade. 4. During the upgrade, the instrument interface will display the current upgrade progress. 5. When the interface displays "Upgrade finished!", restart the instrument. 6. Check whether the firmware version number has been updated (press Utility -> System -> System Info). 7. After upgrading has been completed, perform the self-calibration operation. Make sure that the instrument has been warmed up or has been operating for more than 30 minutes before the self-calibration. a. Disconnect all input channels; b. Press Utility -> Self-Cal, then click Start to perform the self-calibration. c. It takes about 30 minutes to perform the self-calibration. d. After the calibration has been completed, a prompt message will be displayed on the interface. Then, restart the instrument. [Troubleshooting] - If the instrument failed to read the upgrade file from the USB disk, please try to replace the USB disk. - If the problem still persists, please try to re-download the upgrade file. - If the problem still persists after performing the above two operations, please visit the website int.rigol.com to find contacts in your area.
